- 12-Layer 3—IP Services Command Reference
- 01-IP addressing commands
- 02-IP forwarding basics commands
- 03-Fast forwarding commands
- 04-ARP commands
- 05-IPv6 basics commands
- 06-IPv6 fast forwarding commands
- 07-DHCP commands
- 08-DHCPv6 commands
- 09-DNS commands
- 10-IP performance optimization commands
- 11-Adjacency table commands
- 12-Multi-CPU packet distribution commands
02-IP forwarding basics commands | 66.22 KB |
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
context-admin
context-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Destination count: 5 FIB entry count: 5
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
1.1.1.0/24 192.168.126.1 USGF MGE1/0/0/0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Destination count: 6 FIB entry count: 6
Flag:
R:Relay F:FRR
20.20.20.0/24 20.20.20.25 U MGE1/0/0/0 Null
20.20.20.0/32 20.20.20.25 UBH MGE1/0/0/0 Null
20.20.20.25/32 127.0.0.1 UH InLoop0 Null
20.20.20.25/32 20.20.20.25 H MGE1/0/0/0 Null
20.20.20.255/32 20.20.20.25 UBH MGE1/0/0/0 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
Destination count |
Total number of destination addresses. |
FIB entry count |
Total number of FIB entries. |
Destination/Mask |
Destination address and the mask length. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Relay route. · F—Fast reroute. |
OutInterface/Token |
Output interface/LSP index number. |
Label |
Inner label. |
ip forwarding apply vpn-peer-id enable
Use ip forwarding apply vpn-peer-id enable to enable the VPN peer-based processing.
Use undo ip forwarding apply vpn-peer-id enable to disable the VPN peer-based processing.
The VPN peer-based processing is disabled.
context-admin
context-operator
This feature enables the device to use the VPN peer ID of the routing information in the FIB table to process packets.
This command must be used together with the apply vpn-peer-id command. For more information about the command, see Layer 3—IP Routing Command Reference.
# Enable the VPN peer-based processing.
[Sysname] ip forwarding apply vpn-peer-id enable
ip last-hop backup enable
Use ip last-hop backup enable to enable last hop backup.
Use undo ip last-hop backup enable to disable last hop backup.
Last hop backup is disabled.
context-admin
context-operator
This command enables the IRF master device to perform the following operations when receiving the first IP packet of a forward flow on an interface enabled with last hop holding:
1. Saves the last hop information of the packet.
2. Synchronizes the last hop information to subordinate devices in the IRF fabric.
The last hop information can be used for guiding the backward flow when the flow arrives at the master device or is forwarded through a subordinate device.
This command takes effect only when the session synchronization is enabled by using the session synchronization enable command. For more information about the session synchronization enable command, see Security Command Reference.
This command is applicable only to IRF fabrics. Z-shaped traffic might be formed if packets are transparently sent from a subordinate device to the master device.
# Enable last hop backup.
[Sysname] ip last-hop backup enable
ip last-hop hold
session synchronization enable (Security Command Reference)
ip last-hop hold
Use ip last-hop hold to enable last hop holding.
Use undo ip last-hop hold to disable last hop holding.
ip last-hop hold
Last hop holding is disabled.
context-admin
Last hop holding implements symmetric routing. It tracks the last hop MAC address for the first incoming IP packet of a connection, and it sends the return packets to the hop that transmits the request.
Last hop holding is based on fast forwarding entries. If the MAC address of a last hop changes, this feature can function correctly only after the fast forwarding entry is updated for the MAC address.
# Enable the last hop holding feature.
[Sysname] interface gigabitethernet 1/2/5/1
[Sysname-GigabitEthernet1/2/5/1] ip last-hop hold
Load sharing commands
ip load-sharing local-first enable
Use ip load-sharing local-first enable to enable local-first load sharing.
Use undo ip load-sharing local-first enable to disable local-first load sharing.
Local-first load sharing is disabled.
context-admin
# Enable local-first load sharing.
[Sysname] ip load-sharing local-first enable
ip load-sharing mode
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * | per-packet } { chassis chassis-number slot slot-number | global }
undo ip load-sharing mode { chassis chassis-number slot slot-number | global }
The device performs per-flow load sharing.
context-admin
per-flow: Implements per-flow load sharing.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
global: Configures the load sharing mode globally.
per-packet: Implements per-packet load sharing.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command configures the load sharing mode for all cards.
The per-packet load sharing mode does not take effect in fast forwarding.
# Configure per-flow load sharing for slot 1.
[Sysname] ip load-sharing mode per-flow chassis 1 slot 1
