09-High Availability Command Reference
HomeSupportSecurityH3C SecPath F5000 FirewallReference GuidesCommand ReferencesH3C SecPath F50X0-D[F5000-AK] Firewalls Series Command References (V7) (R9620)-6W40109-High Availability Command Reference
01-RBM commands
01-RBM commands 97.20 KB
RBM commands
adjust-cost enable
Use adjust-cost enable to enable RBM to adjust the link cost for the specified routing protocol on the secondary device.
Use undo adjust-cost enable to disable RBM from adjusting the link cost for the specified routing protocol on the secondary device.
adjust-cost { bgp | isis | ospf | ospfv3 } enable { absolute [ absolute-cost ] | increment [ increment-cost ] }
undo adjust-cost { bgp | isis | ospf | ospfv3 } enable
RBM does not adjust the link cost for the specified routing protocol on the secondary device.
Remote backup group view
context-admin
bgp: Specifies the BGP protocol.
isis: Specifies the IS-IS protocol.
ospf: Specifies the OSPF protocol.
ospfv3: Specifies the OSPFv3 protocol.
absolute [ absolute-cost ]: Specifies an absolute cost in the range of 1 to 65535. The default value is 65500. If you specify this option, the secondary device will advertise an absolute link cost for the specified routing protocol.
increment [ increment-cost ]: Specifies an increment cost in the range of 1 to 65535. The default value is 100. If you specify this option, the secondary device will advertise the original link cost plus this increment cost for the specified routing protocol.
In an RBM hot backup system, the routing protocols on the primary and secondary devices advertise link cost according to their respective operation mechanisms. This command allows you to enable the routing protocols to advertise link cost modified as configured. The primary device still uses the original link cost advertisement method.
To ensure switchover of both uplink and downlink traffic to the new primary device, configure this command with the same parameters on both the primary and secondary devices.
In dual-active mode, both devices advertise link cost according to the operation mechanisms of the running routing protocols. When one device is faulty and becomes the secondary device, it will advertise link cost modified as configured.
To enable the feature for multiple routing protocols, execute this command multiple times by specifying the protocols.
If you execute the command multiple times for a specific routing protocol, the most recent configuration takes effect.
# Enable RBM to adjust OSPF link cost on the secondary device by specifying an absolute value of 6000.
[Sysname] remote-backup group
[Sysname-remote-backup-group] adjust-cost ospf enable absolute 6000
backup-mode
Use backup-mode to configure the RBM hot backup mode.
Use undo backup-mode to restore the default.
backup-mode dual-active
undo backup-mode
The RBM hot backup mode is active/standby.
context-admin
RBM hot backup supports active/standby mode and dual-active mode. In active/standby mode, only the primary device processes services. In dual-active mode, both devices process services.
Changing the dual-active mode to active/standby mode might affect services. Make sure you understand the potential impact before performing the operation.
# Configure the dual-active hot backup mode.
[Sysname-remote-backup-group] backup-mode dual-active
configuration auto-sync enable
Use configuration auto-sync enable to enable automatic configuration synchronization.
Use undo configuration auto-sync enable to disable automatic configuration synchronization.
Automatic configuration synchronization is disabled.
context-admin
The automatic configuration synchronization feature synchronizes existing configuration on the primary device in bulk to the secondary device. Consequent synchronization for added, deleted, or modified configuration will be performed in real time.
If the amount of configuration to be synchronized is large, bulk synchronization might take one to two hours.
# Enable automatic configuration synchronization.
[Sysname-remote-backup-group] configuration auto-sync enable
configuration manual-sync
Use configuration manual-sync to manually synchronize the configuration of the primary device to the secondary device.
context-admin
# Manually synchronize the configuration of the primary device to the secondary device.
[Sysname-remote-backup-group] configuration manual-sync
configuration sync-check
Use configuration sync-check to enable configuration consistency check.
Use undo configuration sync-check to restore the default.
configuration sync-check [ interval interval ]
Configuration consistency check is disabled.
context-admin
interval interval: Specifies the configuration consistency check interval, in the range of 1 to 168 hours. The default value is 24.
RBM verifies configuration consistency between the primary and secondary devices to avoid service interruption upon primary/secondary member switchover. If a device detects configuration inconsistency, it generates a log for you to manually synchronize configuration.
# Enable configuration consistency check and set the check interval to 120 hours.
<Sysname>system-view
[Sysname-remote-backup-group] configuration sync-check interval 120
data-channel
Use data-channel to configure an RBM data channel.
Use undo data-channel to restore the default.
data-channel interface interface-type interface-number
undo data-channel
No RBM data channel is configured.
context-admin
interface interface-type interface-number: Specifies an interface by its type and number to set up a data channel between the primary and secondary devices.
The primary and secondary devices use the interface specified in the command to set up an RBM data channel. The data channel transmits only hot backup packets and the packets that require transparent transmission.
# Set up an RBM data channel using interface GigabitEthernet 1/2/5/1.
[Sysname-remote-backup-group] data-channel interface gigabitethernet 1/2/5/1
device-role
Use device-role to configure the RBM role.
Use undo device-role to restore the default.
device-role { primary | secondary }
undo device-role
The RBM role is not configured.
context-admin
primary: Assigns the primary role to the device.
secondary: Assigns the secondary role to the device.
RBM backs up important configuration from the primary device to the secondary device to prevent service interruption when a primary/secondary member switchover occurs. The configuration on the secondary device is overwritten. The unidirectional backup mechanism avoids configuration conflicts, especially in dual-active mode, and ensures configuration consistency on the primary and secondary devices.
# Assign the primary role to the device.
[Sysname-remote-backup-group] device-role primary
display remote-backup-group status
Use display remote-backup-group status to display remote backup group status information.
context-admin
context-operator
# Display remote backup group status information.
<Sysname> display remote-backup-group status
Remote backup group information:
  Backup mode: Dual-active
  Device role: Primary
  Data channel interface: GigabitEthernet1/2/5/1
  Local IPv4: 1.1.1.1
  Remote IPv4: 1.1.1.2    Destination port: 1028
  Local IPv6: 2019::1
  Remote IPv6: 2018::1    Destination port: 1028
  Control channel status: Connected
  Hot backup status: Enabled
  Auto configuration synchronization: Enabled
  Configuration consistency check interval: 30 hour
  Delay-time: 1 min
Backup mode
RBM hot backup mode:
·     Dual-active.
·     Active/standby.
Device role
RBM role of the device:
·     Primary.
·     Secondary.
Interface used to set up the data channel.
Local IPv4
Local IP address used by control channel packets. This field is not displayed if the parameter is not configured.
Remote IPv4
Peer IP address used by control channel packets. This field is not displayed if the parameter is not configured.
Local IPv6
Local IPv6 address used by control channel packets. This field is not displayed if the parameter is not configured.
Remote IPv6
Peer IPv6 address used by control channel packets. This field is not displayed if the parameter is not configured.
Destination port
Peer port number used by control channel packets.
·     Connected.
·     Disconnected.
Hot backup status
Hot backup status:
·     Enabled.
·     Disabled.
Automatic configuration synchronization status:
·     Enabled.
·     Disabled.
Configuration consistency check interval in hours. This field is displayed only when configuration consistency check is enabled.
Delay-time
Delay time for traffic switchover back to the original primary device in minutes. If the value is 0, this switchover feature is disabled for RBM hot backup.
display remote-backup-group sync-check
Use display remote-backup-group sync-check to display the configuration consistency check result for the remote backup group.
context-admin
context-operator
Use this command when the primary and secondary devices have inconsistent configuration.
The command displays detailed inconsistency information for only the service modules supported by RBM. For a module not supported by RBM, the command displays only the interface where configuration inconsistency exists.
# Display the configuration consistency check result for the remote backup group. (No inconsistent configuration exists.)
<Sysname> display remote-backup-group sync-check
# Display the configuration consistency check result for the remote backup group. (Inconsistent configuration exists.)
Configuration on secondary device:
security-policy ip
 rule 0 name abc
  source-zone trust
  destination-zone untrust
Configuration on primary device:
security-policy ip
 rule 0 name abc
  source-zone dmz
  destination-zone trust
hot-backup enable
Use hot-backup enable to enable RBM hot backup.
Use undo hot-backup enable to disable RBM hot backup.
hot-backup enable
RBM hot backup is enabled.
context-admin
This command enables the primary device in the remote backup group to back up service entries to the secondary device in real time. This prevents service interruption when a primary/secondary member switchover occurs.
# Enable RBM hot backup.
[Sysname-remote-backup-group] hot-backup enable
local-ip
Use local-ip to configure the local IPv4 address for setting up the RBM control channel.
Use undo local-ip to restore the default.
local-ip ipv4-address
undo local-ip
The local IPv4 address is not configured for setting up the RBM control channel.
context-admin
ipv4-address: Specifies the local IPv4 address for setting up the RBM control channel.
RBM compares the specified local and peer IP address to determine the device role for setting up the control channel. The device with higher IP address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
You can configure a local IPv4 address or a local IPv6 address, but not both.
# Configure the local IPv4 address as 1.1.1.2 for setting up the RBM control channel.
[Sysname-remote-backup-group] local-ip 1.1.1.2
local-ipv6
remote-ip
local-ipv6
Use local-ipv6 to configure the local IPv6 address for setting up the RBM control channel.
Use undo local-ipv6 to restore the default.
local-ipv6 ipv6-address
undo local-ipv6
The local IPv6 address is not configured for setting up the RBM control channel.
context-admin
ipv6-address: Specifies the local IPv6 address for setting up the RBM control channel.
RBM compares the specified local and peer IPv6 address to determine the device role for setting up the control channel. The device with higher IPv6 address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
# Configure the local IPv6 address as 2019::1 for setting up the RBM control channel.
[Sysname-remote-backup-group] local-ipv6 2019::1
local-ip
remote-ipv6
remote-backup group
Use remote-backup group command to enter remote backup group view.
Use undo remote-backup group to remove all settings of the remote backup group.
remote-backup group
context-admin
RBM provides backup for important configuration and service entries between devices. It collaborates with VRRP to implement hot backup that enables smooth master/backup switchover upon link failures for service continuity. For more information about VRRP, see High Availability Configuration Guide.
# Enter remote backup group view.
remote-ip
Use remote-ip to configure the peer IPv4 address for setting up the RBM control channel.
Use undo remote-ip to restore the default.
remote-ip ipv4-address [ port port-number ]
undo remote-ip ipv4-address
The peer IPv4 address is not configured for setting up the RBM control channel.
context-admin
ipv4-address: Specifies the peer IPv4 address for setting up the RBM control channel.
port port-number: Specifies a port by its number used for establishing TCP connection. The value range for the port-number argument is 1024 to 65535, and the default value is 60064.
The RBM control channel transmits data by using packets, including remote backup group status packets, configuration consistency check packets, and configuration synchronization packets. RBM compares the specified local and peer IP address to determine the device role for setting up the control channel. The device with higher IP address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
If the port number is configured on the server, the port provides services for the client. If the port number is configured on the client, the port serves as the destination port to establish TCP connection to the server. The source port is randomly generated on the client.
You can specify only one peer IP address with the same port number on the primary and secondary devices.
You can configure a remote IPv4 address or a remote IPv6 address, but not both.
# Configure the peer IPv4 address and port number as 1.1.1.1 and 4456 for setting up the RBM control channel.
[Sysname-remote-backup-group] remote-ip 1.1.1.1 port 4456
local-ip
remote-ipv6
remote-ipv6
Use remote-ipv6 to configure the peer IPv6 address for setting up the RBM control channel.
Use undo remote-ipv6 to restore the default.
remote-ipv6 ipv6-address [ port port-number ]
undo remote-ipv6 ipv6-address
The peer IPv6 address is not configured for setting up the RBM control channel.
context-admin
ipv6-address: Specifies the peer IPv6 address for setting up the RBM control channel.
port port-number: Specifies a port by its number used for establishing TCP connection. The value range for the port-number argument is 1024 to 65535, and the default value is 60064. Make sure the port number is not in use.
The RBM control channel transmits data by using packets, including remote backup group status packets, configuration consistency check packets, and configuration synchronization packets. RBM compares the specified local and peer IPv6 address to determine the device role for setting up the control channel. The device with higher IPv6 address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
You can specify only one peer IPv6 address with the same port number on the primary and secondary devices.
# Configure the peer IPv6 address and port number as 2018::1 and 4456 for setting up the RBM control channel.
[Sysname-remote-backup-group] remote-ipv6 2018::1 port 4456
local-ipv6
remote-ip
switchover request
Use switchover request to perform a primary/secondary member switchover.
switchover request
context-admin
If you want to replace components or upgrade software on the current primary device, you can execute this command to switch services to the secondary device.
This command applies only when RBM operates in active/standby hot backup mode.
In an RBM and VRRP associated network, executing this command might cause temporary virtual IP address conflict in the VRRP group, which is considered a normal condition.
# Perform a primary/secondary member switchover.
[Sysname-remote-backup-group] switchover request
track
Use track to associate RBM with Track.
Use undo track to remove the association.
track track-entry-number
undo track track-entry-number
RBM is not associated with Track.
context-admin
track-entry-number: Specifies a track entry by its ID in the range of 1 to 1024.
Use this command to associate RBM with Track to monitor links. If one of the monitored track entries becomes Negative, RBM performs a primary/secondary member switchover and switches traffic to the new primary device to ensure service continuity. For more information about Track, see High Availability Configuration Guide.
To associate RBM with multiple track entries, execute this command multiple times.
# Associate RBM with track entries 1 and 2.
[Sysname-remote-backup-group] track 1
[Sysname-remote-backup-group] track 2
track (High Availability Command Reference)
delay-time
Use delay-time to enable traffic switchover upon failure recovery.
Use undo delay-time to disable traffic switchover upon failure recovery.
delay-time [ delay-time ]
undo delay-time
Traffic switchover upon failure recovery is disabled.
context-admin
delay-time: Specifies the switchover delay time in the range of 1 to 50 minutes.
After a primary/secondary member switchover in an RBM hot backup system, if the original primary device recovers, traffic will not be switched back by default. Perform this task to enable traffic switchover to the original primary device upon failure recovery. You can set a delay timer to ensure smooth service switchover.
In dual-active hot backup mode, you must configure this command to ensure that both devices can operate after the failure is recovered.
# Enable traffic switchover upon failure recovery and set the switchover delay time to two minutes.
[Sysname-remote-backup-group] delay-time 2
