- 09-High Availability Command Reference
- 01-RBM commands
- 02-VRRP commands
- 03-BFD commands
- 04-Track commands
- 05-Reth interface and redundancy group commands
- 06-Failover group commands
- 07-Interface collaboration commands
- 08-Interface backup commands
- 09-Monitor Link commands
- 10-Smart Link commands
- 11-Process placement commands
| 00-Preface | 100.59 KB |
Preface
· This command reference describes configuration commands for VPN features, including SSL VPN, IPsec, tunneling, GRE, L2TP, and ADVPN.
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, configuration files, and licenses.
· FTP and TFTP.
· Tcl and Python.
· ISSU and common software upgrade.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
