03-Security Command Reference
HomeSupportSecurityH3C SecPath F5000 FirewallReference GuidesCommand ReferencesH3C SecPath F50X0-D[F5000-AK] Firewalls Series Command References (V7) (R9620)-6W40103-Security Command Reference
28-Crypto engine commands
28-Crypto engine commands 47.51 KB
display crypto-engine
Use display crypto-engine to display crypto engine information.
context-admin
context-operator
If the device does not have hardware crypto engines, this command displays information only about software crypto engines.
# Display crypto engine information.
<Sysname> display crypto-engine
  Crypto engine name: Software crypto engine
  Crypto engine state: Enabled
  Crypto engine type: Software
  Chassis ID: 1
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 0
  Crypto device name: Software
  Crypto device serial number:
  Symmetric algorithms:  des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac sm3 sm3-hmac sm4-cbc
  Asymmetric algorithms:
  Random number generation function: Supported
  Crypto engine name: Cavium crypto driver
  Crypto engine type: Hardware
  Chassis ID: 1
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 1
  Crypto device name: Cavium crypto
  Symmetric algorithms: des-cbc des-ecb 3des-cbc 3des-ecb aes-cbc aes-ecb aes-ctr md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc-hmac sm4-cbc
  Asymmetric algorithms: dh-group1 dh-group2 dh-group5 dh-group14
  Chassis ID: 1
  Slot ID: 2
  CPU ID: 0
  Crypto engine ID: 0
  Chassis ID: 1
  Slot ID: 2
  CPU ID: 0
  Crypto engine ID: 1
Crypto engine state
Hardware crypto engine state:
·     Enabled.
·     Disabled.
This field always displays Enabled for software crypto engines.
Crypto engine type
Crypto engine type:
·     Hardware.
·     Software.
Crypto device name
Name of the crypto device.
This field displays Software for software crypto engines.
For hardware crypto engines, the value of this field varies by device model.
Serial number of the crypto device.
This field is always empty for software crypto engines.
Supported symmetric algorithms.
Supported asymmetric algorithms.
Whether random number generation function is supported:
·     Supported.
·     Not supported.
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engine statistics.
display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
context-admin
context-operator
engine-id engine-id: Specifies a crypto engine by its ID.The value range for the engine-id argument is 0 to 4294967295.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card.
If hardware crypto engines are not enabled or the device does not have hardware crypto engines, this command displays statistics only for software crypto engines.
If you do not specify any parameters, this command displays crypto engine statistics for all cards.
# Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
  Chassis ID: 1
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 0
  Submitted sessions: 10
  Failed sessions: 0
  Symmetric operations: 10
  Symmetric errors: 0
  Asymmetric operations: 0
  Asymmetric errors: 0
  Get-random operations: 0
  Get-random errors: 0
  Chassis ID: 1
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 1
  Submitted sessions: 0
  Failed sessions: 0
  Symmetric operations: 0
  Symmetric errors: 0
  Chassis ID: 1
  Slot ID: 2
  CPU ID: 0
  Crypto engine ID: 0
  Failed sessions: 0
  Symmetric errors: 0
  Chassis ID: 1
  Slot ID: 2
  CPU ID: 0
  Crypto engine ID: 1
  Submitted sessions: 11
  Failed sessions: 0
  Symmetric operations: 131
  Symmetric errors: 0
  Asymmetric operations: 20
# Display statistics for crypto engine 1 on the specified slot.
<Sysname> display crypto-engine statistics engine-id 1 chassis 1 slot 2
  Failed sessions: 0
  Symmetric errors: 0
Submitted sessions
Number of established sessions.
Failed sessions
Number of failed sessions.
Number of operations using symmetric algorithms.
Symmetric errors
Number of failed operations using symmetric algorithms.
Number of operations using asymmetric algorithms.
Asymmetric errors
Number of failed operations using asymmetric algorithms.
Number of operations for obtaining random numbers.
Get-random errors
Number of failed operations for obtaining random numbers.
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
context-admin
If you do not specify any parameters, this command clears crypto engine statistics for all cards.
# Clear statistics for all crypto engines.
<Sysname> reset crypto-engine statistics
# Clear statistics for crypto engine 1 on the specified slot.
<Sysname> reset crypto-engine statistics engine-id 1 chassis 1 slot 2
