19-DPI Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600 SR6600-X Routers Command Reference(V7)-R7809-6W30019-DPI Command Reference
04-Data analysis center commands
04-Data analysis center commands 81.38 KB
dac email-server client-authentication enable
Use dac email-server client-authentication enable to enable email client authentication.
Use undo dac email-server client-authentication enable to disable email client authentication.
Email client authentication is disabled.
Enable email client authentication on the device if the email server (specified by the dac email-server server-address command) requires client identity authentication.
For successful email client authentication, you must configure the correct username and password for connecting to the email server.
# Enable email client authentication.
[Sysname] dac email-server client-authentication enable
dac email-server username
dac email-server password
dac email-server dns-server
Use dac email-server dns-server to specify the DNS server address.
Use unto dac email-server dns-server to restore the default.
dac email-server dns-server ip-address
undo dac email-server dns-server
No DNS server address is specified.
ip-address: Specifies the IPv4 address of the DNS server, in dotted decimal notation.
The DNS server is required if you specify the host name of the email server. The DNS server resolves the host name into the IP address before the device sends emails through the email server.
# Set the DNS server address to 192.168.0.1.
[Sysname] dac email-server dns-server 192.168.0.1
Use dac email-server password to set the password for connecting to the email server.
Use unto dac email-server password to restore the default.
dac email-server password { cipher | simple } string
undo dac email-server password
The password for connecting to the email server is not specified.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
Both the username and password for connecting to the email server are required if email client authentication is enabled.
If you configure this command multiple times, the most recent configuration takes effect.
# Specify abc123 as the password for connecting to the email server.
[Sysname] dac email-server password simple abc123
dac email-server secure-authentication enable
Use dac email-server secure-authentication enable to enable secure transmission of authentication credentials.
Use undo dac email-server secure-authentication enable to disable secure transmission of authentication credentials.
Secure transmission of authentication credentials is disabled.
This command enables the device to transmit email client authentication credentials to the email server over a secure channel.
This command takes effect only after email client authentication is enabled.
# Enable secure transmission of authentication credentials.
[Sysname] dac email-server secure-authentication enable
dac email-server sender
Use dac email-server sender to specify the email sender address.
Use undo dac email-server sender to restore the default.
dac email-server sender address-string
The email sender address is not specified.
address-string: Specifies the email sender address, as case-sensitive string of 3 to 63 characters.
The data analysis center uses the specified email sender address send emails.
# Specify mailto:[email protected] as the email sender address.
[Sysname] dac email-server sender [email protected]
Use dac email-server server-address to specify the email server address for the data analysis center.
Use undo dac email-server server-address to restore the default.
dac email-server server-address address-string
No email server is specified for the data analysis center.
address-string: Specifies the IP address or host name of the email server. The host name is a case-sensitive string of 3 to 63 characters.
The data analysis center can send emails only after the both email server address and email sender address are configured.
# Specify 101.1.1.255 as email server address for the data analysis center.
[Sysname] dac email-server server-address 101.1.1.225
Use dac email-server username to set the username for connecting to the email server.
Use undo dac email-server username to restore the default.
dac email-server username username
The username for connecting to the email server is not specified.
username: Specifies the username, a case-sensitive string of 1 to 63 characters.
# Specify admin as the username for connecting to the email server.
[Sysname] dac email-server username admin
dac report
Use dac report to configure a subscriber for a report type.
Use undo dac report to remove subscribers for a report type.
dac report type { comparison | integrated | intelligent | summary } subscriber mail-address
undo dac report type { comparison | integrated | intelligent | summary } [ subscriber mail-address ]
No report subscribers are configured.
comparison: Specifies the comparison report.
integrated: Specifies the integrated report.
intelligent: Specifies the intelligent report.
summary: Specifies the summary report.
subscriber mail-address: Specifies the email address of the report subscriber, a case-sensitive string of 3 to 63 characters.
You can configure a maximum of 50 subscribers for each report type.
If you do not specify a subscriber, the undo command removes all subscribers for the specified report type.
# Specify subscriber address mailto:[email protected] for the summary report.
[Sysname] dac report type summary subscriber [email protected]
# Remove subscriber address mailto:[email protected] for the summary report.
[Sysname] undo dac report type summary subscriber [email protected]
dac storage
Use dac storage to configure the data storage limits for a service.
Use undo dac storage to restore the default.
dac storage service { threat | traffic } limit { hold-time time-value | usage usage-value | action { delete | log-only } }
undo dac storage service { threat | traffic } limit { hold-time | usage | action }
The service data can be saved for a maximum of 365 days.
The data of each service can occupy up to 20% of the total storage space.
If the storage time or storage space usage limit is exceeded, the system deletes the expired or the oldest data.
threat: Specifies the IPS service.
traffic: Specifies the traffic service.
limit: Configures the data storage limits for a service.
hold-time time-value: Specifies the storage time limit in days. The value range is 1 to 65535. The storage time limit should be longer than the number of days that the oldest service data has been stored for.
usage usage-value: Specifies the percentage of the total storage space the service data can occupy. The value range is 1 to 100. The storage usage limit should be higher than the current storage usage of the service.
action: Specifies the action to take when a data storage limit is exceeded.
delete: Deletes data collected on the oldest dates and generates a log message. The data of the current date cannot be deleted.
log-only: Generates a log message only. When a storage limit is exceeded, old data are not deleted and new data cannot be saved.
The data analysis center periodically checks the data of each service to determine if the storage time or storage space usage limit is exceeded.
·     If a storage limit is exceeded and the action is delete, the system deletes the expired or the oldest service data. A log will be generated to report the event.
·     If a storage limit is exceeded and the action is log-only, the system generates a log message. New data will not be saved.
If you configure this command to set the storage time limit for a service multiple times, the most recent configuration takes effect. The same is true for setting the storage space limit or storage limit-violated action for a service. You can view the storage space usage of each service on the Web interface.
This command is supported only on the default MDC. For more information about MDC, see MDC configuration in Virtual Technologies Configuration Guide.
# Set the storage time limit, storage space limit, and the action to take when the limits are exceeded for the traffic service.
[Sysname] dac storage service traffic limit hold-time 60
[Sysname] dac storage service traffic limit usage 30
[Sysname] dac storage service traffic limit action delete
display dac email-server
Use display dac email-server to display the email server configuration of the data analysis center.
# Display the email server configuration of the data analysis center.
<Sysname> display dac email-server
Mail server address : 2.2.2.2
        Mail sender address : [email protected]
         DNS server address : 1.1.1.1
             Authentication : Enable
      secure-authentication : Enable
                   Username : lkx
                   password : ******
Authentication
Enabling status of the email client authentication.
Secure-authentication
Enabling status of the secure transmission of authentication credentials.
Username
Username for connecting to the email server.
Password
Password for connecting to the email server.
display dac report
Use display dac report to display report subscriber information.
display dac report [ comparison | integrated | intelligent | summary ]
If you do not specify a report type, this command displays subscriber information for all report types.
# Display subscriber information for all report types.
<Sysname> display dac report
Total subscribers:4
Summary subscribers:1
Comparison subscribers:1
Intelligent subscribers:1
Integrated subscribers:1
Report type         Subscriber email address
Summary             [email protected]
Comparison          [email protected]
Intelligent         [email protected]
Integrated          [email protected]
Total subscribers
Total number of subscribers.
Summary subscribers
Number of subscribers for the summary report.
Number of subscribers for the comparison report.
Number of subscribers for the intelligent report.
Number of subscribers for the integrated report.
Email address of a report subscriber.
display dac storage
Use display dac storage to display the data storage limit configuration for services.
display dac storage [ threat | traffic ]
If you do not specify a service, this command displays the data storage limit configuration for all services.
This command is supported only on the default MDC. For more information about MDCs, see MDC configuration in Virtual Technologies Configuration Guide.
# Displays the data storage limit configuration for all services.
<Sysname> display dac storage
Total services        :5
Service          Time limit (days)  Usage limit      Action
traffic          128                50%              delete
threat           30                 30%              delete
Total services
Total number of services.
Service
Service type.
Time limit
Storage time limit in days.
Usage limit
Storage space usage limit in percentage.
Action
Action to take when the storage time limit or space limit is exceed.
·     delete—Delete the oldest data, and generates a log message.
·     log-only—Generate a log message only.
