05-Layer 2—WAN Access Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600 SR6600-X Routers Command Reference(V7)-R7809-6W30005-Layer 2—WAN Access Command Reference
05-DDR commands
05-DDR commands 147.38 KB
DDR commands
bandwidth
Use bandwidth to set the expected bandwidth for a dialer interface.
bandwidth bandwidth-value
undo bandwidth
Dialer interface view
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of Dialer 1 to 100 kbps.
[Sysname] interface dialer 1
[Sysname-Dialer1] bandwidth 100
default
Use default to restore the default settings for a dialer interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Dialer 1.
[Sysname-Dialer1] default
description
The description of a dialer interface is interface-name Interface, for example, Dialer1 Interface.
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of Dialer 1 to dialer-intf.
[Sysname-Dialer1] description dialer-intf
dialer bundle enable
Use dialer bundle enable to enable bundle DDR on a dialer interface.
Use undo dialer bundle enable to disable bundle DDR on a dialer interface.
Bundle DDR is disabled on a dialer interface.
DDR includes traditional DDR and bundle DDR.
Before using bundle DDR, use this command to enable bundle DDR on a dialer interface. Then assign physical interfaces to the corresponding dialer bundle by using the dialer bundle-member command. To enable bundle DDR to receive calls, configure the dialer peer-name command on the dialer interface.
After you configure this command on a dialer interface already enabled with traditional DDR, the system clears the original traditional DDR settings.
The undo dialer bundle enable command clears all bundle DDR settings on the dialer interface.
# Enable bundle DDR on Dialer 1.
[Sysname-Dialer1] dialer bundle enable
dialer circular enable
dialer peer-name
dialer disconnect
Use dialer disconnect to disconnect dialup links on an interface.
dialer disconnect [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command disconnects dialup links on all interfaces.
# Disconnect dialup links on Dialer 0.
<Sysname> dialer disconnect interface dialer0
dialer queue-length
Use dialer queue-length to set the number of packets that can be buffered on a dialup interface.
Use undo dialer queue-length to restore the default.
dialer queue-length packets
No packets are buffered on a dialup interface.
Dialup interface view
packets: Specifies the number of packets that can be buffered on the interface, in the range of 1 to 100.
If no connection is available when a dialup interface without a buffer queue receives a packet, the interface drops the packet. Configured with a buffer queue, the dialup interface buffers the packet until a connection is available for packet sending.
# Set the number of packets that can be buffered to 10 on Serial 2/1/0.
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] dialer queue-length 10
dialer timer autodial
Use dialer timer autodial to set the auto-dial timer.
Use undo dialer timer autodial to restore the default.
dialer timer autodial autodial-interval
The auto-dial timer is 300 seconds.
autodial-interval: Specifies the interval between auto-dial attempts, in the range of 1 to 604800 seconds.
This command takes effect only when the autodial keyword is specified in the dialer number or dialer route command. DDR automatically dials the dial string at the specified interval until a connection is established. In the auto-dial method, dial attempts are not traffic triggered. Once a connection is established, it will not disconnect based on the idle timer mechanism.
# Set the auto-dial timer to 60 seconds on Serial 2/1/0.
[Sysname-Serial2/1/0] dialer timer autodial 60
dialer number
dialer route
dialer timer enable
Use dialer timer enable to set the link holddown timer.
Use undo dialer timer enable to restore the default.
dialer timer enable interval
The link holddown timer is 5 seconds.
interval: Specifies the holddown timer value in the range of 5 to 65535 seconds.
The holddown timer starts when a link is disconnected. A call attempt to bring up this link can be made only after the timer expires. This is to prevent a remote SPCS from being overloaded.
To leave enough time for callback, set the holddown timer on the client 10 or more seconds longer than that on the server. As a best practice, set the link holddown timer to 5 seconds (the default) on the server, and 15 seconds on the client.
# Set the link holddown timer to 15 seconds for Serial 2/1/0.
[Sysname-Serial2/1/0] dialer timer enable 15
dialer timer idle
Use dialer timer idle to set the link idle-timeout timer.
Use undo dialer timer idle to restore the default.
dialer timer idle idle [ in | in-out ]
The link idle-timeout timer is 120 seconds, and only outgoing interesting packets reset this timer.
idle: Specifies the link idle-timeout timer value in the range of 0 to 65535 seconds.
in: Allows only incoming interesting packets to reset the timer.
in-out: Allows both incoming and outgoing interesting packets to reset the timer.
The link idle-timeout timer starts when a link is established. If no interesting packets arrive before the timer expires, DDR disconnects the link.
If you do not specify the in or in-out keyword, only outgoing interesting packets reset the timer.
If the timer is set to 0, DDR will never disconnect the link. For a PPPoE client application, if the timer is set to 0, a dialup connection is created automatically and remains active permanently.
# Set the link idle-timeout timer to 50 seconds on Serial 2/1/0.
[Sysname-Serial2/1/0] dialer timer idle 50
dialer timer wait-carrier
Use dialer timer wait-carrier to set the wait-carrier timer.
Use undo dialer timer wait-carrier to restore the default.
dialer timer wait-carrier wait-carrier
The wait-carrier timer is 60 seconds.
wait-carrier: Specifies the wait-carrier timer value in the range of 0 to 65535 seconds.
The wait-carrier timer limits the amount of time that DDR waits for a connection to be established for a call. The wait-carrier timer starts when a call is placed. If the connection is not established before the timer expires, DDR terminates the call.
# Set the wait-carrier timer to 100 seconds on Serial 2/1/0.
[Sysname-Serial2/1/0] dialer timer wait-carrier 100
dialer-group
Use dialer-group to assign a dialup interface to a dialer group.
Use undo dialer-group to restore the default.
dialer-group group-number
undo dialer-group
A dialup interface does not belong to any dialer group.
group-number: Specifies a dialer group by its number in the range of 1 to 255. Before the assignment, you must create the dialer group by using the dialer-group rule command.
A dialup interface can belong to only one dialer group. If you configure this command multiple times, the most recent configuration takes effect.
You must configure this command for DDR to send packets.
# Assign Serial 2/1/0 to dialer group 1.
[Sysname] dialer-group 1 rule acl 3101
[Sysname-Serial2/1/0] dialer-group 1
dialer-group rule
dialer-group rule
Use dialer-group rule to create a dialer group and configure a dial rule for it.
Use undo dialer-group rule to delete a dialer group.
dialer-group group-number rule { ip | ipv6 } { deny | permit | acl { acl-number | name acl-name } }
undo dialer-group group-number rule [ ip | ipv6 ]
No dialer group exists.
group-number: Specifies the number of the dialer group to be created, in the range of 1 to 255.
ip: Specifies the IPv4 protocol.
ipv6: Specifies the IPv6 protocol.
deny: Denies packets of the specified protocol.
permit: Permits packets of the specified protocol.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name.
A dial rule determines when an interface initiates DDR calls. You need to configure dial rules only on the initiator of DDR calls.
You can configure a dial rule to match only IP packets or use an ACL to match packets.
Permitted protocol packets or packets that match a permit statement of an ACL are interesting packets. When receiving an interesting packet, DDR performs one of the following operations:
·     Sends it out and resets the idle-timeout timer if a link is present.
·     Originates a new call to establish a link if no link is present.
Denied protocol packets or packets that match a deny statement of an ACL are uninteresting packets. When receiving an uninteresting packet, DDR performs one of the following operations:
·     Sends it out without resetting the idle-timeout timer if a link is present.
·     Drops it if no link is present.
For DDR to forward packets correctly, you must configure a dial rule and associate it with the dialup interface by using the dialer-group command.
# Create dialer group 1 and configure DDR to place calls for IPv4 packets. Associate Serial 2/1/0 with dialer group 1.
[Sysname] dialer-group 1 rule ip permit
# Create dialer group 1 and configure DDR to place calls for IPv6 packets. Associate Serial 2/1/0 with dialer group 1.
[Sysname] dialer-group 1 rule ipv6 permit
dialer-group
display dialer
Use display dialer to display the DDR information for an interface.
display dialer [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the DDR information for all interfaces.
# Display the DDR information for all interfaces.
<Sysname> display dialer
Dialer0:
  Dialer Route:
    NextHop: 111.111.111.111  Dialer number: 123456789012345678901234567890
    NextHop: 222.222.222.222  Dialer number: 123456789012345678901234567890
  Dialer number:
  Dialer Timers(in seconds):
    Auto-dial: 300      Compete: 20           Enable: 5
    Idle: 120           Wait-for-Carrier: 60
  Total Channels: 1
  Free Channels: 1
Dialer0
Dialup interface: dialer or physical.
Dialer Route:
Remote IP address and dial string set by using the dialer route command.
Dialer number
Dial string for a remote IP address.
DDR timers in seconds:
·     Auto-dial—Auto-dial timer set by the dialer timer autodial command.
·     Compete—Compete-idle timer set by the dialer timer compete command.
·     Enable—Link holddown timer set by the dialer timer enable command.
·     Idle—Link idle-timeout timer set by the dialer timer idle command.
·     Wait-for-Carrier—Wait-carrier timer set by the dialer timer wait-carrier command.
Total Channels
Total number of physical interfaces on the interface. For an ISDN interface, it refers to the number of B channels.
Free Channels
Number of free channels.
display interface dialer
Use display interface dialer to display information about a dialer interface.
display interface [ dialer [ interface-number ] ] [ brief [ description | down ] ]
dialer [ interface-number ]: Specifies a dialer interface by its number. If you do not specify the dialer keyword, this command displays information about all interfaces on the device. If you specify the dialer keyword, this command displays information about all dialer interfaces.
down: Displays information about interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Dialer 1.
<Sysname> display interface dialer 1
Dialer1
Current state: UP
Line protocol state: UP (spoofing)
Description: Dialer1 Interface
Bandwidth: 64kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds, retry times: 5
Internet protocol processing: disabled
Link layer protocol: PPP
LCP: initial
Physical: Dialer, baudrate: 64000 bps
Input: 0 packets, 0 bytes, 0 dropped
Output: 0 packets, 0 bytes, 0 dropped
# Display brief information about Dialer 1.
<Sysname> display interface dialer 1 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Dia1                 UP   UP(s)    --
# Display brief information about all dialer interfaces in physically Down state.
<Sysname> display interface dialer brief down
Interface              Link Cause
Dia1                   ADM  Administratively
Dialer1
Current state
Physical state of the dialer interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
Hold timer
Interval for sending keepalive packets.
retry times
Maximum number of keepalive retransmission attempts. A link is removed after the maximum number of retransmission attempts is reached.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
The interface is not assigned an IP address and cannot process IP packets.
Internet Address
IP address of the interface. The primary attribute indicates that the address is the primary IP address.
LCP: initial
LCP initialization is complete.
Physical
Physical interface type.
Statistics on the packets in the urgent output queue.
Statistics on the packets in the protocol output queue.
Statistics on the packets in the FIFO output queue.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Input interface data rate during the latest 300 seconds.
Output interface data rate during the latest 300 seconds.
Statistics on the packets reaching the interface.
Statistics on the packets sent through the interface.
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Main IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
interface dialer
Use interface dialer to create a dialer interface and enter its view, or enter the view of an existing dialer interface.
Use undo interface dialer to delete a dialer interface.
interface dialer number
undo interface dialer number
No dialer interface exists.
number: Specifies the number of the dialer interface, in the range of 0 to 1023.
A dialer interface has a fixed baud rate of 64000 bps.
# Create Dialer 1.
mtu
Use mtu to set the maximum transmission unit (MTU) of a dialer interface.
mtu size
undo mtu
The MTU of dialer interfaces is 1500 bytes.
size: Specifies the MTU in bytes. The value range for this argument is 128 to 1500.
The MTU setting of a dialer interface affects the fragmentation and reassembly of IP packets.
# Set the MTU of Dialer 1 to 1200 bytes.
[Sysname-Dialer1] mtu 1200
Use reset counters interface to clear the statistics of a dialer interface.
reset counters interface [ dialer [ interface-number ] ]
dialer [ interface-number ]: Specifies a dialer interface by its number. If you do not specify the dialer keyword, this command clears statistics for all interfaces. If you specify the dialer keyword, this command clears statistics for all dialer interfaces. If you specify a dialer interface, this command clears statistics for the specified dialer interface.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
# Clear the statistics of Dialer 1.
<Sysname> reset counters interface dialer 1
service
Use service to specify a primary traffic processing slot for an interface.
Use undo service to restore the default.
In standalone mode:
service slot slot-number
undo service slot
In IRF mode:
service chassis chassis-number slot slot-number
undo service chassis
No primary traffic processing slot is specified for an interface.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
This command is supported on distributed devices and IRF-capable centralized devices.
Specify traffic processing slots if a feature requires that all traffic on a dialer interface be processed on the same slot.
For high availability, you can specify one primary and one backup traffic processing slot by using the service command and the service standby command, respectively.
To avoid processing slot switchover, specify the primary slot before specifying the backup slot. If you specify the backup slot before specifying the primary slot, traffic is switched over to the primary slot immediately after you specify the primary slot.
If you specify both primary and backup slots for an interface, traffic on that interface is processed as follows:
·     The backup slot takes over when the primary slot becomes unavailable. The backup slot continues to process traffic for the interface after the primary slot becomes available again. The switchover will not occur until the backup slot becomes unavailable.
·     When no specified traffic processing slots are available, the traffic is processed on the slot at which it arrives. Then, the processing slot that first becomes available again takes over.
If you do not specify a primary or a backup traffic processing slot for an interface, traffic on that interface is processed on the slot at which the traffic arrives.
# Specify slot 2 as the primary traffic processing slot for Dialer 1.
[Sysname-Dialer1] service slot 2
service standby
service standby
Use service standby to specify a backup traffic processing slot for an interface.
Use undo service standby to restore the default.
In standalone mode:
service standby slot slot-number
undo service standby slot
In IRF mode:
service standby chassis chassis-number slot slot-number
undo service standby chassis
No backup traffic processing slot is specified for an interface.
# Specify slot 2 as the primary traffic processing slot and slot 3 as the backup traffic processing slot for Dialer 1.
[Sysname-Dialer1] service standby slot 3
service
shutdown
Use shutdown to shut down a dialer interface.
Use undo shutdown to bring up a dialer interface.
shutdown
A dialer interface is up.
# Shut down Dialer 1.
[Sysname-Dialer1] shutdown
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
seconds: Specifies the interval for sending keepalive packets, in the range of 0 to 32767 seconds. The value 0 disables keepalive packet sending.
On an interface encapsulated with PPP, the data link layer sends keepalive packets at keepalive intervals to detect the availability of the remote end. The data link layer determines that the peer end is down if it has not received any keepalive messages when the keepalive retry limit is reached. The data link layer then reports the link down event to the upper-layer protocols.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 1000 seconds on Dialer 1.
[Sysname-Dialer1] timer-hold 1000
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5.
retries: Specifies the maximum number of keepalive retransmission attempts, in the range of 1 to 255.
The interface determines that the remote end is down if it has not received a keepalive response when the keepalive retry limit is reached.
On a slow link, increase the keepalive retry limit to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive retry limit to 10 on Dialer 1.
[Sysname-Dialer1] timer-hold retry 10
timer-hold
