02-Virtual Technologies Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600 SR6600-X Routers Command Reference(V7)-R7809-6W30002-Virtual Technologies Command Reference
02-MDC commands
02-MDC commands 90.48 KB
MDC commands
MDC commands for the default MDC
This section describes the MDC commands that you can use after logging in to the default MDC (the physical device).
The term "MDC view" refers to the view of a non-default MDC. After entering the view of a non-default MDC, you can start or stop the MDC, or assign resources to the MDC.
Unless otherwise stated, the term "MDC" in this section refers to a non-default MDC.
allocate interface
Use allocate interface to assign physical interfaces to an MDC.
Use undo allocate interface to reclaim physical interfaces assigned to an MDC.
allocate interface interface-list
undo allocate interface interface-list
All physical interfaces on the device belong to the default MDC. A non-default MDC cannot use any physical interfaces.
MDC view
interface-list: Specifies a space-separated list of up to 24 interfaces. Each item specifies an interface by its type and number or a range of interfaces on the same card in the form of start-interface-type start-interface-name to end-interface-type end-interface-name. The values of the start-interface-type and end-interface-type arguments must be the same.
You can use this command multiple times to assign multiple physical interfaces to a non-default MDC.
For more information about interface assignment guidelines, see MDC configuration in Virtual Technologies Configuration Guide.
# Assign GigabitEthernet 2/0/1 to MDC sub1.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] allocate interface gigabitethernet 2/0/1
Configuration of the interfaces will be lost. Continue? [Y/N]:y
This operation will allocate the specified interfaces and all interfaces in the listed groups to the MDC. Continue? [Y/N]:y
Execute the location slot command in the current view to place the configuration into effect.
display mdc
Use display mdc to display MDCs and their status information.
display mdc [ name mdc-name ]
name mdc-name: Specifies an MDC by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, the command displays all MDCs.
# Display all MDCs.
<Sysname> display mdc
ID         Name            Status
1          Admin           active
2          sub1            inactive
Status
Status of the MDC:
·     inactive—The MDC is stopped or not started yet.
·     starting—The device is executing the mdc start command to start the MDC.
·     active—The MDC is operating correctly.
·     updating—The device is executing the location command to assign an LPU to the MDC.
·     stopping—The device is executing the undo mdc start command to stop the MDC.
mdc
display mdc interface
Use display mdc interface to display the interfaces of MDCs.
display mdc [ name mdc-name ] interface
name mdc-name: Specifies an MDC by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, the command displays the interfaces of all MDCs.
# Display the interfaces of all MDCs.
<Sysname> display mdc interface
 MDC Admin's interface(s):
  M-Ethernet0/0/0                    GigabitEthernet2/0/1
 MDC sub1's interface(s):
  GigabitEthernet2/0/3
allocate interface
display mdc resource
Use display mdc resource to display the CPU and memory usage of MDCs.
In standalone mode:
display mdc [ name mdc-name ] resource [ cpu | memory ] [ slot slot-number ]
In IRF mode:
display mdc [ name mdc-name ] resource [ cpu | memory ] [ chassis chassis-number slot slot-number ]
name mdc-name: Specifies an MDC by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this option, the command displays the usage of all MDCs.
cpu: Displays the CPU usage.
memory: Displays the memory space usage.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the usage on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the usage on all cards in the IRF fabric. (In IRF mode.)
# Display the CPU and memory space usage of all MDCs.
<Sysname> display mdc resource
Memory usage:
Slot 0 CPU 0:
Used 207.2MB, Free 288.7MB, Total 495.9MB
  ID    Name             Quota(MB)    Used(MB)    Available(MB)
  1     Admin            495.9        172.1        288.7
  2     sub1             495.9        17.9         288.7
  3     sub2             495.9        17.2         288.7
CPU usage:
Slot 0 CPU 0:
  ID    Name             Weight       Usage(%)
  1     Admin            10           1
  2     sub1             10           0
  3     sub2             10           0
limit-resource cpu
Use limit-resource cpu to specify a CPU weight for an MDC.
Use undo limit-resource cpu to restore the default.
limit-resource cpu weight weight-value
The default MDC has a CPU weight of 10 on each MPU and each LPU. Each non-default MDC has a CPU weight of 10 on each MPU and each LPU that are assigned to it.
MDC view
weight weight-value: Specifies a CPU weight value in the range of 1 to 10.
The number of CPU resources available for an MDC depends on the CPU weight settings for all MDCs that share the same CPU. For example, if three MDCs share the same CPU, setting their weights to 10, 10, and 5 is equivalent to setting their weights to 2, 2, and 1.
·     The two MDCs with the same weight can use the CPU for approximately the same period of time.
·     The third MDC can use the CPU for about half of the time for each of the other two MDCs.
The CPU weight for the default MDC is fixed at 10. You cannot change it.
The CPU weight specified for an MDC takes effect on all MPUs and all LPUs that are assigned to the MDC. To assign an LPU to an MDC, use the location command.
# Set the CPU weight to 2 for MDC sub1.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] limit-resource cpu weight 2
limit-resource memory
Use limit-resource memory to specify a memory space percentage for an MDC.
Use undo limit-resource memory to restore the default.
In standalone mode:
limit-resource memory slot slot-number ratio limit-ratio
undo limit-resource memory slot slot-number
In IRF mode:
limit-resource memory chassis chassis-number slot slot-number ratio limit-ratio
undo limit-resource memory chassis chassis-number slot slot-number
All MDCs share the memory space in the system. An MDC can use all free memory space in the system.
MDC view
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
ratio limit-ratio: Specifies the ratio of the memory space that an MDC can use on the specified card to the total memory space of the card. The value range is 1 to 100.
This command sets the maximum amount of memory space that an MDC can use. Make sure this amount is sufficient for the MDC to operate correctly.
# (In standalone mode.) Allow MDC sub1 to use up to 30 percent of the memory space on a slot.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] limit-resource memory slot 1 ratio 30
location
Use location to assign an LPU to an MDC.
Use undo location to reclaim an LPU from an MDC.
In standalone mode:
location slot slot-number
undo location slot slot-number
In IRF mode:
location chassis chassis-number slot slot-number
undo location chassis chassis-number slot slot-number
All LPUs of the device belong to the default MDC. A non-default MDC cannot use any LPUs.
MDC view
slot slot-number: Specifies an LPU by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an LPU on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
When you assign physical interfaces to MDCs, follow these guidelines:
·     To assign physical interfaces to an MDC, you must assign the MDC the LPUs to which the physical interfaces belong.
·     You can enter different MDC views to assign multiple MDCs the same LPU.
·     Performing the following tasks for an LPU removes all authorization settings for the LPU:
¡     Remove the LPU.
¡     Save the running configuration.
¡     Reboot the device.
# (In standalone mode.) Assign the LPU in a slot to MDC sub1.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] location slot 2
mdc
Use mdc to create an MDC and enter its view, or enter the view of an existing MDC.
Use undo mdc to delete an MDC.
mdc mdc-name [ id mdc-id ]
undo mdc mdc-name
A default MDC exists. The MDC name is Admin and the MDC ID is 1.
mdc-name: Specifies the MDC name, a case-sensitive string of 1 to 15 characters.
id mdc-id: Specifies the MDC ID. The value range is 1 to 8. If you do not specify this option, the system assigns the lowest ID number among the available IDs to the MDC.
Delete an MDC with caution. Deleting an MDC deletes all settings and hard disk files of the MDC. The deleted settings and files cannot be restored.
The default MDC is system defined. You cannot delete it.
You can create multiple MDCs.
To enter the view of an existing MDC, you can specify the MDC name, or specify both the MDC name and the MDC ID. If you specify both the MDC name and the MDC ID, make sure the two arguments identify the same MDC.
# Create an MDC named sub1.
[Sysname] mdc sub1
It will take some time to create MDC...
MDC created successfully.
display mdc
mdc start
Use mdc start to start an MDC.
Use undo mdc start to stop an MDC.
mdc start
undo mdc start
MDC view
Stop an MDC with caution. Stopping an MDC interrupts all services on the MDC and logs out all login users on the MDC.
To avoid configuration loss, save the running configuration of an MDC before stopping the MDC.
Creating an MDC is the same as constructing a physical device. After creating an MDC, use this command to start the MDC to complete MDC initialization. After an MDC is started, administrators of the MDC can log in to the MDC for MDC configuration and maintenance.
# Start MDC sub1.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] mdc start
It will take some time to start MDC...
MDC started successfully.
switchto mdc
Use switchto mdc to log in to a non-default MDC from the system view of the default MDC and enter MDC user view.
switchto mdc mdc-name
You can log in to an MDC only when the MDC is in active state.
# Log in to MDC sub1 from the system view of the default MDC.
[Sysname] switchto mdc sub1
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
Automatic configuration is running, press CTRL_C or CTRL_D to break or press CTRL_B to switch back to the default MDC.
# Press CTRL+C or CTRL+D to abort automatic configuration and enter the CLI of MDC sub1.
Automatic configuration is aborted.
<Sysname>
switchback
MDC commands for non-default MDCs
This section describes the MDC commands that you can use after logging in to a non-default MDC.
display mdc
Use display mdc to display the ID, name, and status of the current MDC.
display mdc
# Display the ID, name, and status of the current MDC.
<sub1> display mdc
ID      Name         Status
2       sub1         active
For information about the Status field, see Table 1.
Use display mdc interface to display the interfaces of the current MDC.
# Display the interfaces of the current MDC.
<sub1> display mdc interface
  M-Ethernet2/0/1                    GigabitEthernet2/0/2
Use display mdc resource to display the CPU and memory usage of the current MDC.
In standalone mode:
display mdc resource [ cpu | memory ] [ slot slot-number ]
In IRF mode:
display mdc resource [ cpu | memory ] [ chassis chassis-number slot slot-number ]
# Display the CPU and memory space usage of the current MDC.
<sub1> display mdc resource
Memory usage:
Slot 0 CPU 0:
Used 232.3MB, Free 263.6MB, Total 495.9MB
  2     sub1             495.9        42.7         263.6
CPU usage:
Slot 0 CPU 0:
  2     sub1             10           0
switchback
Use switchback to return from a non-default MDC to the default MDC. This command will bring you from the user view of the non-default MDC to the system view of the default MDC.
switchback
You can use this command to return to the default MDC only after you use the switchto command to log in to a non-default MDC. If you log in to a non-default MDC by using any other method (such as Telnet), you cannot use this command to access the default MDC.
# Return from the current MDC to the default MDC.
<sub1> switchback
[Sysname]
switchto mdc
