12-FCoE Configuration Examples
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration ExamplesH3C S10500X Switch Series Configuration Examples-R7585P05-6W10012-FCoE Configuration Examples
01-H3C_FCoE_Configuration_Examples
01-H3C_FCoE_Configuration_Examples 331.93 KB
H3C FCoE Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring FC static routes, FSPF, and FC zones.
This document assumes that you have basic knowledge of FCoE.
General configuration restrictions and guidelines
When you configure FCoE, follow these restrictions and guidelines:
·          FCoE requires a license. To use FCoE, install a correct license.
·          The switch supports FCoE only when it operates in advanced or expert mode.
·          Only the following cards support FCoE:
¡  EC cards
¡  SE cards
¡  SF cards
¡  SG cards
Example: Configuring FC static routes
As shown in Figure 1, configure FCoE to meet the following requirements:
·          Any two FCF switches can communicate with each other.
·          SAN traffic can be transmitted on lossless Ethernet.
·          The server can access the disk device through the fabric.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·          To transmit SAN traffic over lossless Ethernet links, you must perform the following tasks:
¡  Configure DCBX, PFC in auto mode, and ETS on the Ethernet interface connecting a switch to a server.
¡  Configure DCBX and PFC in auto mode on the Ethernet interface connecting a switch to a disk device.
¡  Forcibly enable PFC on the Ethernet interfaces interconnecting switches.
·          For the server to access the resources in the disk device, configure the members in the default zone to access each other.
·          To adapt to the simple and stable network topology, use the static method to build the fabric and configure FC static routes.
Before configuring FC static routes, determine a domain ID for each FCF switch in the fabric.
Procedures
Configuring Switch A
1.        Configure the advanced mode:
# Configure the switch to operate in advanced mode. (Skip this step if the switch is already operating in advanced mode.)
[SwitchA] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the
 system to make it effective.
# Save the configuration.
[SwitchA] save
Slot 1:
Save next configuration file successfully.
[SwitchA] quit
# Reboot the switch.
<SwitchA> reboot
Now rebooting, please wait...
2.        Configure DCBX:
# Enable LLDP globally.
[SwitchA] lldp global enable
# Enable LLDP on Ten-GigabitEthernet 1/0/1, and enable the interface to advertise DCBX TLVs.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] lldp enable
[SwitchA-Ten-GigabitEthernet1/0/1] lldp tlv-enable dot1-tlv dcbx
[SwitchA-Ten-GigabitEthernet1/0/1] quit
# Create a Layer 2 ACL numbered 4000.
[SwitchA] acl mac 4000
# Configure two rules in the ACL to match FCoE frames (protocol type 0x8906) and FIP frames (protocol type 0x8914).
[SwitchA-acl-mac-4000] rule 0 permit type 8906 ffff
[SwitchA-acl-mac-4000] rule 5 permit type 8914 ffff
[SwitchA-acl-mac-4000] quit
# Create a class named app_c with the operator as OR, and specify ACL 4000 as the match criterion.
[SwitchA] traffic classifier app_c operator or
[SwitchA-classifier-app_c] if-match acl mac 4000
[SwitchA-classifier-app_c] quit
# Create a behavior named app_b, and configure the action of marking packets with 802.1p priority 3.
[SwitchA] traffic behavior app_b
[SwitchA-behavior-app_b] remark dot1p 3
[SwitchA-behavior-app_b] quit
# Create a QoS policy named plcy.
[SwitchA] qos policy plcy
# Associate the class app_c with the behavior app_b in the QoS policy, and specify that the class-behavior association applies only to DCBX.
[SwitchA-qospolicy-plcy] classifier app_c behavior app_b mode dcbx
[SwitchA-qospolicy-plcy] quit
# Apply the QoS policy plcy to the outbound direction of Ten-GigabitEthernet 1/0/1.
[SwitchA-Ten-GigabitEthernet1/0/1] qos apply policy plcy outbound
3.        Configure PFC:
# Enable PFC in auto mode on Ten-GigabitEthernet 1/0/1.
[SwitchA-Ten-GigabitEthernet1/0/1] priority-flow-control auto
# Enable PFC for 802.1p priority 3 on Ten-GigabitEthernet 1/0/1.
[SwitchA-Ten-GigabitEthernet1/0/1] priority-flow-control no-drop dot1p 3
# Configure Ten-GigabitEthernet 1/0/1 to trust the 802.1p priority carried in packets.
[SwitchA-Ten-GigabitEthernet1/0/1] qos trust dot1p
# Forcibly enable PFC on Ten-GigabitEthernet 1/0/2.
[SwitchA] interface ten-gigabitethernet 1/0/2
[SwitchA-Ten-GigabitEthernet1/0/2] priority-flow-control enable
# Enable PFC for 802.1p priority 3 on Ten-GigabitEthernet 1/0/2.
[SwitchA-Ten-GigabitEthernet1/0/2] priority-flow-control no-drop dot1p 3
# Configure Ten-GigabitEthernet 1/0/2 to trust the 802.1p priority carried in packets.
[SwitchA-Ten-GigabitEthernet1/0/2] qos trust dot1p
[SwitchA-Ten-GigabitEthernet1/0/2] quit
4.        Configure ETS:
# Configure the 802.1p-lp priority map as follows:
a.    Map 802.1p priority 3 to local precedence 1 (corresponding to queue 1).
b.    Map all other 802.1p priorities to local precedence 0 (corresponding to queue 0).
[SwitchA] qos map-table dot1p-lp
[SwitchA-maptbl-dot1p-lp] import 3 export 1
[SwitchA-maptbl-dot1p-lp] import 0 1 2 4 5 6 7 export 0
[SwitchA-maptbl-dot1p-lp] quit
# Enable byte-count WRR on Ten-GigabitEthernet 1/0/1.
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr byte-count
# Assign 50% of the interface bandwidth to queue 1 (af1) for FCoE traffic on Ten-GigabitEthernet 1/0/1.
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr af1 group 1 byte-count 1
# Assign 50% of the interface bandwidth to queue 0 (be) for standard LAN traffic on Ten-GigabitEthernet 1/0/1.
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr be group 1 byte-count 1
# Assign all other queues on Ten-GigabitEthernet 1/0/1 to the SP group.
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr af2 group sp
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr af3 group sp
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr af4 group sp
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr ef group sp
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr cs6 group sp
[SwitchA-Ten-GigabitEthernet1/0/1] qos wrr cs7 group sp
5.        Configure FCoE:
# Configure the switch to operate in FCF mode.
[SwitchA] fcoe-mode fcf
# Disable the fabric configuration function in VSAN 1.
[SwitchA] vsan 1
[SwitchA-vsan1] undo domain configure enable
# Configure a fabric name in VSAN 1.
[SwitchA-vsan1] fabric-name 11:11:11:11:11:11:11:11
# Configure the domain ID as 1 in VSAN 1.
[SwitchA-vsan1] domain-id 1 static
Non-disruptive reconfiguration or isolating the switch may be performed. Continue? [Y/N]:y
[SwitchA-vsan1] quit
# Create interface VFC 1, bind VFC 1 to interface Ten-GigabitEthernet 1/0/1, and assign VFC 1 to VSAN 1 as a trunk port.
[SwitchA] interface vfc 1
[SwitchA-Vfc1] bind interface ten-gigabitethernet 1/0/1
[SwitchA-Vfc1] port trunk vsan 1
[SwitchA-Vfc1] quit
# Create interface VFC 2, and configure it to operate in E mode.
[SwitchA] interface vfc 2
[SwitchA-Vfc2] fc mode e
# Bind interface VFC 2 to interface Ten-GigabitEthernet 1/0/2, and assign VFC 2 to VSAN 1 as a trunk port.
[SwitchA-Vfc2] bind interface ten-gigabitethernet 1/0/2
[SwitchA-Vfc2] port trunk vsan 1
[SwitchA-Vfc2] quit
# Assign Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to VLAN 10 as trunk ports.
[SwitchA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[SwitchA-if-range] port link-type trunk
[SwitchA-if-range] port trunk permit vlan 10
[SwitchA-if-range] quit
# Enable FCoE for VLAN 10 and map VLAN 10 to VSAN 1.
[SwitchA] vlan 10
[SwitchA-vlan10] fcoe enable vsan 1
[SwitchA-vlan10] quit
# Permit the members in the default zone of VSAN 1 to access each other.
[SwitchA] vsan 1
[SwitchA-vsan1] zone default-zone permit
# Configure static routes to Switch B and Switch C.
[SwitchA-vsan1] fc route-static 020000 8 vfc 2
[SwitchA-vsan1] fc route-static 030000 8 vfc 2
Configuring Switch B
[SwitchB] system-working-mode advance
[SwitchB] save
Slot 1:
[SwitchB] quit
<SwitchB> reboot
2.        Configure PFC:
# Forcibly enable PFC on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[SwitchB] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[SwitchB-if-range] priority-flow-control enable
# Enable PFC for 802.1p priority 3 on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[SwitchB-if-range] priority-flow-control no-drop dot1p 3
# Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to trust the 802.1p priority carried in packets.
[SwitchB-if-range] qos trust dot1p
[SwitchB-if-range] quit
3.        Configure FCoE:
[SwitchB] fcoe-mode fcf
[SwitchB] vsan 1
[SwitchB-vsan1] undo domain configure enable
[SwitchB-vsan1] fabric-name 11:11:11:11:11:11:11:11
# Configure the domain ID as 2 in VSAN 1.
[SwitchB-vsan1] domain-id 2 static
[SwitchB-vsan1] quit
# Create interface VFC 1, and configure it to operate in E mode.
[SwitchB] interface vfc 1
[SwitchB-Vfc1] fc mode e
# Bind interface VFC 1 to interface Ten-GigabitEthernet 1/0/1, and assign VFC 1 to VSAN 1 as a trunk port.
[SwitchB-Vfc1] bind interface ten-gigabitethernet 1/0/1
[SwitchB-Vfc1] port trunk vsan 1
[SwitchB-Vfc1] quit
[SwitchB] interface vfc 2
[SwitchB-Vfc2] fc mode e
[SwitchB-Vfc2] bind interface ten-gigabitethernet 1/0/2
[SwitchB-Vfc2] port trunk vsan 1
[SwitchB-Vfc2] quit
[SwitchB-if-range] port link-type trunk
[SwitchB-if-range] port trunk permit vlan 10
[SwitchB] vlan 10
[SwitchB-vlan10] fcoe enable vsan 1
[SwitchB-vlan10] quit
[SwitchB] vsan 1
[SwitchB-vsan1] zone default-zone permit
# Configure static routes to Switch A and Switch C.
[SwitchB-vsan1] fc route-static 010000 8 vfc 1
[SwitchB-vsan1] fc route-static 030000 8 vfc 2
Configuring Switch C
[SwitchC] system-working-mode advance
[SwitchC] save
Slot 1:
[SwitchC] quit
<SwitchC> reboot
2.        Configure DCBX:
[SwitchC] lldp global enable
# Enable LLDP on Ten-GigabitEthernet 1/0/2, and enable the interface to advertise DCBX TLVs.
[SwitchC] interface ten-gigabitethernet 1/0/2
[SwitchC-Ten-GigabitEthernet1/0/2] lldp enable
[SwitchC-Ten-GigabitEthernet1/0/2] lldp tlv-enable dot1-tlv dcbx
[SwitchC-Ten-GigabitEthernet1/0/2] quit
[SwitchC] acl mac 4000
[SwitchC-acl-mac-4000] rule 0 permit type 8906 ffff
[SwitchC-acl-mac-4000] rule 5 permit type 8914 ffff
[SwitchC-acl-mac-4000] quit
[SwitchC] traffic classifier app_c operator or
[SwitchC-classifier-app_c] if-match acl mac 4000
[SwitchC-classifier-app_c] quit
[SwitchC] traffic behavior app_b
[SwitchC-behavior-app_b] remark dot1p 3
[SwitchC-behavior-app_b] quit
[SwitchC] qos policy plcy
[SwitchC-qospolicy-plcy] classifier app_c behavior app_b mode dcbx
[SwitchC-qospolicy-plcy] quit
# Apply the QoS policy plcy to the outbound direction of Ten-GigabitEthernet 1/0/2.
[SwitchC-Ten-GigabitEthernet1/0/2] qos apply policy plcy outbound
3.        Configure PFC:
# Enable PFC in auto mode on Ten-GigabitEthernet 1/0/2.
[SwitchC-Ten-GigabitEthernet1/0/2] priority-flow-control auto
[SwitchC-Ten-GigabitEthernet1/0/2] priority-flow-control no-drop dot1p 3
[SwitchC-Ten-GigabitEthernet1/0/2] qos trust dot1p
# Forcibly enable PFC on Ten-GigabitEthernet 1/0/1.
[SwitchC] interface ten-gigabitethernet 1/0/1
[SwitchC-Ten-GigabitEthernet1/0/1] priority-flow-control enable
[SwitchC-Ten-GigabitEthernet1/0/1] priority-flow-control no-drop dot1p 3
[SwitchC-Ten-GigabitEthernet1/0/1] qos trust dot1p
[SwitchC-Ten-GigabitEthernet1/0/1] quit
4.        Configure FCoE:
[SwitchC] fcoe-mode fcf
[SwitchC] vsan 1
[SwitchC-vsan1] undo domain configure enable
[SwitchC-vsan1] fabric-name 11:11:11:11:11:11:11:11
# Configure the domain ID as 3 in VSAN 1.
[SwitchC-vsan1] domain-id 3 static
[SwitchC-vsan1] quit
[SwitchC] interface vfc 1
[SwitchC-Vfc1] fc mode e
[SwitchC-Vfc1] bind interface ten-gigabitethernet 1/0/1
[SwitchC-Vfc1] port trunk vsan 1
[SwitchC-Vfc1] quit
# Create interface VFC 2, bind VFC 2 to interface Ten-GigabitEthernet 1/0/2, and assign VFC 2 to VSAN 1 as a trunk port.
[SwitchC] interface vfc 2
[SwitchC-Vfc2] bind interface ten-gigabitethernet 1/0/2
[SwitchC-Vfc2] port trunk vsan 1
[SwitchC-Vfc2] quit
[SwitchC] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[SwitchC-if-range] port link-type trunk
[SwitchC-if-range] port trunk permit vlan 10
[SwitchC-if-range] quit
[SwitchC] vlan 10
[SwitchC-vlan10] fcoe enable vsan 1
[SwitchC-vlan10] quit
[SwitchC] vsan 1
[SwitchC-vsan1] zone default-zone permit
# Configure static routes to Switch A and Switch B.
[SwitchC-vsan1] fc route-static 010000 8 vfc 1
[SwitchC-vsan1] fc route-static 020000 8 vfc 1
# Verify that Switch A has static routes to Switch B and Switch C.
[SwitchA] display fc routing-table vsan 1
Routing Table: VSAN 1
  Destinations : 6          Routes : 6
  Destination/mask   Protocol   Preference   Cost     Interface
  0x020000/8         STATIC     10           0        Vfc2
  0x030000/8         STATIC     10           0        Vfc2
  0xfffc01/24        DIRECT     0            0        InLoop0
  0xfffffa/24        DIRECT     0            0        InLoop0
  0xfffffc/24        DIRECT     0            0        InLoop0
  0xfffffd/24        DIRECT     0            0        InLoop0
# Verify that Switch B has static routes to Switch A and Switch C.
[SwitchB] display fc routing-table vsan 1
  0x010000/8         STATIC     10           0        Vfc1
  0xfffc02/24        DIRECT     0            0        InLoop0
# Verify that Switch C has static routes to Switch A and Switch B.
[SwitchC] display fc routing-table vsan 1
  0x020000/8         STATIC     10           0        Vfc1
  0xfffc03/24        DIRECT     0            0        InLoop0
# Verify that you can successfully ping Switch C from Switch A.
[SwitchA] fcping fcid fffc03 vsan 1
FCPING fcid 0xfffc03: 128 data bytes, press CTRL_C to break
Reply from 0xfffc03: bytes = 128 time = 23 ms
Reply from 0xfffc03: bytes = 128 time = 9 ms
Reply from 0xfffc03: bytes = 128 time = 19 ms
Reply from 0xfffc03: bytes = 128 time = 14 ms
Reply from 0xfffc03: bytes = 128 time = 25 ms
--- 0xfffc03 fcping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 9/18/25 ms
Configuration files
·          Switch A:
 lldp global enable
 fcoe-mode fcf
vsan 1
 domain-id 1 static
 fc route-static 020000 8 Vfc2
 fc route-static 030000 8 Vfc2
vlan 10
 fcoe enable vsan 1
 import 0 export 0
 import 2 export 0
 import 3 export 1
 import 4 export 0
 import 5 export 0
 import 6 export 0
 import 7 export 0
 remark dot1p 3
qos policy plcy
 port link-mode bridge
 port trunk permit vlan 1 10
 qos wrr byte-count
 qos wrr ef group sp
interface Vfc1
 port trunk vsan 1
 bind interface Ten-GigabitEthernet1/0/1
interface Vfc2
 fc mode e
 port trunk vsan 1
 bind interface Ten-GigabitEthernet1/0/2
acl mac 4000
·          Switch B:
 fcoe-mode fcf
vsan 1
 domain-id 2 static
 fc route-static 010000 8 Vfc1
vlan 10
 fcoe enable vsan 1
interface Vfc1
 fc mode e
 port trunk vsan 1
interface Vfc2
 fc mode e
 port trunk vsan 1
·          Switch C:
 lldp global enable
 fcoe-mode fcf
vsan 1
 domain-id 3 static
 fc route-static 020000 8 Vfc1
vlan 10
 fcoe enable vsan 1
 remark dot1p 3
qos policy plcy
interface Vfc1
 fc mode e
 port trunk vsan 1
interface Vfc2
 port trunk vsan 1
acl mac 4000
Example: Configuring FSPF
As shown in Figure 2, configure FCoE to meet the following requirements:
·          Any FCF switch can forward FC packets to the destination along the shortest path and automatically adapt to network topology changes.
Figure 2 Network diagram
Analysis
·          To allow SAN traffic to be transmitted on lossless Ethernet:
¡  Configure DCBX and PFC in auto mode on the Ethernet interface connecting a switch to a disk.
·          To allow FC packets to be forwarded along the shortest path automatically computed, configure FSPF.
When you configure FCoE, follow these configuration restrictions and guidelines:
·          Because the network topology is complex, use the dynamic method to build the fabric.
·          Configure the highest switch priority for the FCF switch with better performance, so that FCF switch can be selected as the principal switch.
Procedures
[SwitchA] save
Slot 1:
[SwitchA] quit
<SwitchA> reboot
2.        Configure DCBX:
3.        Configure PFC:
# Forcibly enable PFC on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchA] interface range ten-gigabitethernet 1/0/2 to ten-gigabitethernet 1/0/3
[SwitchA-if-range] priority-flow-control enable
# Enable PFC for 802.1p priority 3 on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchA-if-range] priority-flow-control no-drop dot1p 3
# Configure Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to trust the 802.1p priority carried in packets.
[SwitchA-if-range] qos trust dot1p
4.        Configure ETS:
¡  Map 802.1p priority 3 to local precedence 1 (corresponding to queue 1).
¡  Map all other 802.1p priorities to local precedence 0 (corresponding to queue 0).
5.        Configure FCoE:
# Enable the fabric configuration function in VSAN 1. By default, the fabric configuration function is enabled.
[SwitchA] vsan 1
[SwitchA-vsan1] domain configure enable
# Configure the switch priority as 1, so that Switch A can be selected as the principal switch.
[SwitchA-vsan1] priority 1
[SwitchA-Vfc1] quit
[SwitchA-Vfc2] quit
# Create interface VFC 3, and configure it to operate in E mode.
[SwitchA] interface vfc 3
[SwitchA-Vfc3] fc mode e
# Bind interface VFC 3 to interface Ten-GigabitEthernet 1/0/3, and assign VFC 3 to VSAN 1 as a trunk port.
[SwitchA-Vfc3] bind interface ten-gigabitethernet 1/0/3
[SwitchA-Vfc3] port trunk vsan 1
[SwitchA-Vfc3] quit
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to VLAN 10 as trunk ports.
[SwitchA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[SwitchA] vlan 10
[SwitchA] vsan 1
# Enable FSPF in VSAN 1. By default, FSPF is enabled.
[SwitchA-vsan1] fspf enable
[SwitchB] save
Slot 1:
[SwitchB] quit
<SwitchB> reboot
2.        Configure PFC:
3.        Configure FCoE:
[SwitchB] vsan 1
[SwitchB-vsan1] domain configure enable
[SwitchB-vsan1] domain-id 2 preferred
[SwitchB-Vfc1] quit
[SwitchB-Vfc2] quit
[SwitchB] vlan 10
[SwitchB] vsan 1
[SwitchC] save
Slot 1:
[SwitchC] quit
<SwitchC> reboot
2.        Configure DCBX:
[SwitchC-Ten-GigabitEthernet1/0/1] lldp enable
[SwitchC-Ten-GigabitEthernet1/0/1] lldp tlv-enable dot1-tlv dcbx
[SwitchC-Ten-GigabitEthernet1/0/1] qos apply policy plcy outbound
3.        Configure PFC:
[SwitchC-Ten-GigabitEthernet1/0/1] priority-flow-control auto
[SwitchC] interface range ten-gigabitethernet 1/0/2 to ten-gigabitethernet 1/0/3
[SwitchC-if-range] priority-flow-control enable
[SwitchC-if-range] priority-flow-control no-drop dot1p 3
[SwitchC-if-range] qos trust dot1p
4.        Configure FCoE:
[SwitchC] vsan 1
[SwitchC-vsan1] domain configure enable
[SwitchC-vsan1] domain-id 3 preferred
[SwitchC-Vfc1] quit
[SwitchC-Vfc2] fc mode e
[SwitchC-Vfc2] quit
[SwitchC] interface vfc 3
[SwitchC-Vfc3] fc mode e
[SwitchC-Vfc3] bind interface ten-gigabitethernet 1/0/3
[SwitchC-Vfc3] port trunk vsan 1
[SwitchC-Vfc3] quit
[SwitchC] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[SwitchC] vlan 10
[SwitchC] vsan 1
[SwitchC-vsan1] fspf enable
Verify the configuration on Switch A or Switch C, for example, Switch A.
1.        Verify the configuration when all links are available:
# Display the FSPF neighbor information for VSAN 1.
[SwitchA] display fspf neighbor
FSPF neighbor information of VSAN 1(01):
  Interface   NbrDomain   IfIndex   NbrIfIndex   Dead Time   State
  Vfc2        2           0x68      0x68         00:01:06    Full
  Vfc3        3           0x69      0x69         00:01:06    Full
The output shows that Switch A has two neighbors in VSAN 1 (Switch B with domain ID 2 and Switch C with domain ID 3).
# Display the FC routing table of VSAN 1.
  0x020000/8         FSPF       20           100      Vfc2
  0x030000/8         FSPF       20           100      Vfc3
The output shows that Switch A learned FSPF routes to Switch B and Switch C.
FCPING fcid 0xfffc03: 128 data bytes, press CTRL_C to break.
Reply from 0xfffc03: bytes = 128 time = 1.102 ms
Reply from 0xfffc03: bytes = 128 time = 0.276 ms
Reply from 0xfffc03: bytes = 128 time = 0.253 ms
Reply from 0xfffc03: bytes = 128 time = 0.270 ms
Reply from 0xfffc03: bytes = 128 time = 0.247 ms
0.00% packet loss
round-trip min/avg/max = 0.247/0.430/1.102 ms
# Verify that the path from Switch A to Switch C is Switch A > Switch C, but not Switch A > Switch B > Switch C.
[SwitchA] fctracert fcid fffc03 vsan 1
Route present for: 0xfffc03, press CTRL_C to break.
20:00:00:0b:46:00:02:82(0xfffc01)
20:00:00:05:30:00:18:db(0xfffc03)
Fctracert completed.
2.        Verify the configuration when the link between Switch A and Switch C is disconnected:
  0x030000/8         FSPF       20           200      Vfc2
The output shows that Switch A still has an FSPF route to Switch C.
Reply from 0xfffc03: bytes = 128 time = 2.846 ms
Reply from 0xfffc03: bytes = 128 time = 2.810 ms
Reply from 0xfffc03: bytes = 128 time = 2.799 ms
Reply from 0xfffc03: bytes = 128 time = 2.908 ms
Reply from 0xfffc03: bytes = 128 time = 3.840 ms
0.00% packet loss
round-trip min/avg/max = 2.799/3.041/3.840 ms
# Verify that Switch B is on the path from Switch A to Switch C.
20:00:00:e0:fc:00:c5:18(0xfffc02)
The output shows that FSPF selected an alternative path (Switch A > Switch B > Switch C) after the link between Switch A and Switch C is disconnected.
Configuration files
·          Switch A:
 lldp global enable
 fcoe-mode fcf
vsan 1
 priority 1
vlan 10
 fcoe enable vsan 1
 import 0 export 0
 import 2 export 0
 import 3 export 1
 import 4 export 0
 import 5 export 0
 import 6 export 0
 import 7 export 0
 remark dot1p 3
qos policy plcy
 qos wrr byte-count
 qos wrr ef group sp
interface Vfc1
 port trunk vsan 1
interface Vfc2
 fc mode e
 port trunk vsan 1
interface Vfc3
 fc mode e
 port trunk vsan 1
 bind interface Ten-GigabitEthernet1/0/3
acl mac 4000
·          Switch B:
 fcoe-mode fcf
vsan 1
vlan 10
 fcoe enable vsan 1
interface Vfc1
 fc mode e
 port trunk vsan 1
interface Vfc2
 fc mode e
 port trunk vsan 1
·          Switch C:
lldp global enable
 fcoe-mode fcf
vsan 1
vlan 10
 fcoe enable vsan 1
 remark dot1p 3
qos policy plcy
interface Vfc1
 port trunk vsan 1
interface Vfc2
 fc mode e
 port trunk vsan 1
interface Vfc3
 fc mode e
 port trunk vsan 1
acl mac 4000
Example: Configuring FC zones
As shown in Figure 3, Disk A is a dedicated disk of Dept A. Disk B is a dedicated disk of Dept B. Disk C is a common disk for Dept A and Dept B. Dept A and Dept B cannot access each other.
Configure FCoE to meet the following requirements:
·          Only Server A can access Disk A.
·          Only Server B can access Disk B.
·          Server A and Server B can access Disk C.
·          Server A and Server B cannot access each other.
Figure 3 Network diagram
Analysis
·          To allow SAN traffic to be transmitted on lossless Ethernet, perform the following configurations:
·          To implement access control in VSAN 1, divide VSAN 1 into two zones:
¡  Zone 1 (containing Server A, Disk A, and Disk C).
¡  Zone 2 (containing Server B, Disk B, and Disk C).
·          Enable Pairwise for Zone 1 and Zone 2 because each zone has one server and multiple disks. Configure Server A and Server B as initiators, and configure Disks A, B, and C as targets.
·          To ensure data consistency across the fabric, configure FC zones on only one switch, and activate the zone set and distribute it to the entire fabric.
Procedures
[SwitchA] save
Slot 1:
[SwitchA] quit
<SwitchA> reboot
2.        Configure DCBX:
# Enable LLDP on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4, and enable the interfaces to advertise DCBX TLVs.
[SwitchA] interface range ten-gigabitethernet 1/0/3 to ten-gigabitethernet 1/0/4
[SwitchA-if-range] lldp enable
[SwitchA-if-range] lldp tlv-enable dot1-tlv dcbx
# Apply the QoS policy plcy to the outbound direction of Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4.
[SwitchA-if-range] qos apply policy plcy outbound
3.        Configure PFC:
# Enable PFC in auto mode on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4.
[SwitchA-if-range] priority-flow-control auto
# Enable PFC for 802.1p priority 3 on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4.
# Configure Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4 to trust the 802.1p priority carried in packets.
4.        Configure ETS:
# Enable byte-count WRR on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4.
[SwitchA-if-range] qos wrr byte-count
# Assign 50% of the interface bandwidth to queue 1 (af1) for FCoE traffic on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4.
[SwitchA-if-range] qos wrr af1 group 1 byte-count 1
# Assign 50% of the interface bandwidth to queue 0 (be) for standard LAN traffic on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4.
[SwitchA-if-range] qos wrr be group 1 byte-count 1
# Assign all other queues on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4 to the SP group.
[SwitchA-if-range] qos wrr af2 group sp
[SwitchA-if-range] qos wrr af3 group sp
[SwitchA-if-range] qos wrr af4 group sp
[SwitchA-if-range] qos wrr ef group sp
[SwitchA-if-range] qos wrr cs6 group sp
[SwitchA-if-range] qos wrr cs7 group sp
5.        Configure FCoE:
# Create VSAN 1.
[SwitchA] vsan 1
[SwitchA-Vfc1] fc mode e
[SwitchA-Vfc1] quit
[SwitchA-Vfc2] quit
# Create interface VFC 3, bind VFC 3 to interface Ten-GigabitEthernet 1/0/3, and assign VFC 3 to VSAN 1 as a trunk port.
[SwitchA-Vfc3] quit
# Create interface VFC 4, bind VFC 4 to interface Ten-GigabitEthernet 1/0/4, and assign VFC 4 to VSAN 1 as a trunk port.
[SwitchA] interface vfc 4
[SwitchA-Vfc4] bind interface ten-gigabitethernet 1/0/4
[SwitchA-Vfc4] port trunk vsan 1
[SwitchA-Vfc4] quit
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 to VLAN 10 as trunk ports.
[SwitchA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[SwitchA] vlan 10
[SwitchB] save
Slot 1:
[SwitchB] quit
<SwitchB> reboot
2.        Configure PFC:
3.        Configure FCoE:
[SwitchB] vsan 1
[SwitchB-Vfc1] quit
[SwitchB-Vfc2] quit
[SwitchB] vlan 10
[SwitchC] save
Slot 1:
[SwitchC] quit
<SwitchC> reboot
2.        Configure DCBX:
# Enable LLDP on Ten-GigabitEthernet 1/0/3 through Ten-GigabitEthernet 1/0/5, and enable the interfaces to advertise DCBX TLVs.
[SwitchC] interface range ten-gigabitethernet 1/0/3 to ten-gigabitethernet 1/0/5
[SwitchC-if-range] lldp enable
[SwitchC-if-range] lldp tlv-enable dot1-tlv dcbx
# Apply the QoS policy plcy to the outbound direction of Ten-GigabitEthernet 1/0/3 through Ten-GigabitEthernet 1/0/5.
[SwitchC-if-range] qos apply policy plcy outbound
3.        Configure PFC:
# Enable PFC in auto mode on Ten-GigabitEthernet 1/0/3 through Ten-GigabitEthernet 1/0/5.
[SwitchC-if-range] priority-flow-control auto
# Enable PFC for 802.1p priority 3 on Ten-GigabitEthernet 1/0/3 through Ten-GigabitEthernet 1/0/5.
# Configure Ten-GigabitEthernet 1/0/3 through Ten-GigabitEthernet 1/0/5 to trust the 802.1p priority carried in packets.
4.        Configure FCoE:
# Create VSAN 1.
[SwitchC] vsan 1
[SwitchC-Vfc1] quit
[SwitchC-Vfc2] quit
# Create interface VFC 3, bind it to interface Ten-GigabitEthernet 1/0/3, and assign VFC 3 to VSAN 1 as a trunk port.
[SwitchC-Vfc3] quit
# Create interface VFC 4, bind it to interface Ten-GigabitEthernet 1/0/4, and assign VFC 4 to VSAN 1 as a trunk port.
[SwitchC] interface vfc 4
[SwitchC-Vfc4] bind interface ten-gigabitethernet 1/0/4
[SwitchC-Vfc4] port trunk vsan 1
[SwitchC-Vfc4] quit
# Create interface VFC 5, bind it to interface Ten-GigabitEthernet 1/0/5, and assign VFC 5 to VSAN 1 as a trunk port.
[SwitchC] interface vfc 5
[SwitchC-Vfc5] bind interface ten-gigabitethernet 1/0/5
[SwitchC-Vfc5] port trunk vsan 1
[SwitchC-Vfc5] quit
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/5 to VLAN 10 as trunk ports.
[SwitchC] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/5
[SwitchC] vlan 10
Displaying FC SAN establishment
On Switch A
# Display domain information in VSAN 1.
[SwitchA] display fc domain vsan 1
Domain Information of VSAN 1:
  Running time information:
    State: Stable
    Switch WWN:  10:00:00:e0:fc:00:c5:18
    Fabric name: 10:00:00:e0:fc:00:c5:18
    Priority: 1
    Domain ID: 1
  Configuration information:
    Domain configure: Enabled
    Domain auto-reconfigure: Disabled
    Priority: 1
    Domain ID: 1 (preferred)
  Principal switch running time information:
    Priority: 1
    Path               Interface
    Downstream         Vfc1
    Downstream         Vfc2
The output shows that Switch A was selected as the principal switch and assigned itself domain ID 1.
# Display node login information in VSAN 1.
[SwitchA] display fc login vsan 1
Interface VSAN FCID     Node WWN                Port WWN
Vfc3      1    0x010000 21:01:00:1a:32:a0:fa:12 21:01:00:1a:32:a0:fa:11
Vfc4      1    0x010001 21:01:00:1b:32:b0:fb:12 21:01:00:1b:32:b0:fb:11
The output shows that Switch A assigned FC addresses 0x010000 and 0x010001 to Server A and Server B, respectively.
# Display brief information about the name service database in VSAN 1.
[SwitchA] display fc name-service database vsan 1
VSAN 1:
  FCID     Type               PWWN(vendor)                      FC4-type:feature
  0x010000 0x01(N)            21:01:00:1a:32:a0:fa:11           SCSI-FCP:Initiator
  0x010001 0x01(N)            21:01:00:1b:32:b0:fb:11           SCSI-FCP:Initiator
  0x030000 0x01(N)            10:00:00:05:30:00:25:a1           SCSI-FCP:Target
  0x030001 0x01(N)            10:00:00:05:30:00:25:c1           SCSI-FCP:Target
  0x030002 0x01(N)            10:00:00:05:30:00:25:b1           SCSI-FCP:Target
The output shows that all nodes completed name service registrations.
On Switch C
[SwitchC] display fc domain vsan 1
    State: Stable
    Switch WWN:  10:00:74:25:8a:02:4c:00
    Priority: 128
    Domain ID: 3
    Priority: 128
    Domain ID: 3 (preferred)
    Priority: 1
    Path          Interface
    Upstream      Vfc2
The output shows that the principal switch assigned domain ID 3 to Switch C.
[SwitchC] display fc login vsan 1
Vfc3      1    0x030000 10:00:00:05:30:00:25:a1 10:00:00:05:30:00:25:a2
Vfc4      1    0x030001 10:00:00:05:30:00:25:c1 10:00:00:05:30:00:25:c2
Vfc5      1    0x030002 10:00:00:05:30:00:25:b1 10:00:00:05:30:00:25:b2
The output shows that Switch C assigned FC addresses 0x030000, 0x030001, and 0x030002 to Disk A, Disk C, and Disk B, respectively.
[SwitchC] display fc name-service database vsan 1
VSAN 1:
# Enable the enhanced zoning mode in VSAN 1.
[SwitchA-vsan1] zone mode enhanced
The zoning database in this switch would be distributed throughout the fabric. Continue? [Y/N]:y
# Create a zone named Zone1, and enable the Pairwise feature for Zone1.
[SwitchA-vsan1] zone name Zone1
[SwitchA-vsan1-zone-Zone1] pairwise-zoning enable
# Specify FC ID 010000 as its initiator member, and specify FC IDs 030000 and 030001 as its target members.
[SwitchA-vsan1-zone-Zone1] member fcid 010000 initiator
[SwitchA-vsan1-zone-Zone1] member fcid 030000 target
[SwitchA-vsan1-zone-Zone1] member fcid 030001 target
[SwitchA-vsan1-zone-Zone1] quit
# Create a zone named Zone2, and enable the Pairwise feature for Zone2.
[SwitchA-vsan1] zone name Zone2
[SwitchA-vsan1-zone-Zone2] pairwise-zoning enable
# Specify FC ID 010001 as its initiator member, and specify FC IDs 030001 and 030002 as its target members.
[SwitchA-vsan1-zone-Zone2] member fcid 010001 initiator
[SwitchA-vsan1-zone-Zone2] member fcid 030001 target
[SwitchA-vsan1-zone-Zone2] member fcid 030002 target
[SwitchA-vsan1-zone-Zone2] quit
# Create a zone set named Zoneset1, and add zones Zone1 and Zone2 as its members.
[SwitchA-vsan1] zoneset name Zoneset1
[SwitchA-vsan1-zoneset-Zoneset1] member Zone1
[SwitchA-vsan1-zoneset-Zoneset1] member Zone2
[SwitchA-vsan1-zoneset-Zoneset1] quit
# Activate Zoneset1 as the active zone set, and distribute it to the entire fabric.
[SwitchA-vsan1] zoneset activate name Zoneset1
Verify the configuration on any switch, for example, Switch C.
# Display zone set information for VSAN 1.
<SwitchC> display zoneset vsan 1
VSAN 1:
    zone name Zone1
      fcid 0x010000 initiator
      fcid 0x030000 target
      fcid 0x030001 target
    zone name Zone2
      fcid 0x010001 initiator
      fcid 0x030002 target
The output shows that VSAN 1 was divided into two zones: Zone 1 and Zone 2.
# Display the zones to which FC ID 030001 belongs.
<SwitchC> display zone member fcid 030001
fcid 0x030001
VSAN 1:
    zone Zone1
    zone Zone2
The output shows that Disk C belongs to both Zone 1 and Zone 2 (both Server 1 and Server 2 can access Disk C).
# Display information about the active zone set in VSAN 1.
<SwitchC> display zoneset active vsan 1
VSAN 1:
    zone name Zone1
      *fcid 0x010000
      *fcid 0x030000
      *fcid 0x030001
    zone name Zone2
      *fcid 0x010001
      *fcid 0x030001
      *fcid 0x030002
The output shows that Zone set 1 is the active zone set of VSAN 1.
Configuration files
·          Switch A:
 lldp global enable
 fcoe-mode fcf
vsan 1
 priority 1
 zone mode enhanced
 zone name Zone1
 zone name Zone2
  member Zone1
  member Zone2
vlan 10
 fcoe enable vsan 1
 import 0 export 0
 import 2 export 0
 import 3 export 1
 import 4 export 0
 import 5 export 0
 import 6 export 0
 import 7 export 0
 remark dot1p 3
qos policy plcy
 qos wrr byte-count
 qos wrr ef group sp
interface Ten-GigabitEthernet1/0/4
 qos wrr byte-count
 qos wrr ef group sp
interface Vfc1
 fc mode e
 port trunk vsan 1
interface Vfc2
 fc mode e
 port trunk vsan 1
interface Vfc3
 port trunk vsan 1
interface Vfc4
 port trunk vsan 1
 bind interface Ten-GigabitEthernet1/0/4
acl mac 4000
·          Switch B:
 fcoe-mode fcf
vsan 1
vlan 10
 fcoe enable vsan 1
interface Vfc1
 fc mode e
 port trunk vsan 1
interface Vfc2
 fc mode e
 port trunk vsan 1
·          Switch C:
 lldp global enable
 fcoe-mode fcf
vsan 1
vlan 10
 fcoe enable vsan 1
 remark dot1p 3
qos policy plcy
interface Ten-GigabitEthernet1/0/5
interface Vfc1
 fc mode e
 port trunk vsan 1
interface Vfc2
 fc mode e
 port trunk vsan 1
interface Vfc3
 port trunk vsan 1
interface Vfc4
 port trunk vsan 1
interface Vfc5
 port trunk vsan 1
 bind interface Ten-GigabitEthernet1/0/5
acl mac 4000
Example: Configuring FIP snooping
As shown in Figure 4, configure FCoE to meet the following requirements:
·          Only successfully registered servers can access the fabric.
Figure 4 Network diagram
Analysis
·          To allow SAN traffic to be transmitted on lossless Ethernet, perform the following tasks:
·          To allow servers to access the fabric, configure the members in the default zone to access each other.
·          To allow only successfully registered servers to access the fabric and to deny access between Server A and Server B, configure FIP snooping on Switch B.
Procedures
[SwitchA] save
[SwitchA] quit
<SwitchA> reboot
2.        Configure PFC:
[SwitchA-Ten-GigabitEthernet1/0/1] priority-flow-control enable
3.        Configure FCoE:
# Set the FC-MAP value to 0x0efc01.
[SwitchA] fcoe fcmap 0efc01
Changing the FC-MAP will flap all VFC interfaces. Continue? [Y/N]:y
# Enable the fabric configuration feature in VSAN 1. By default, the fabric configuration feature is enabled.
[SwitchA] vsan 1
# Set the switch priority to 10.
[SwitchA-vsan1] priority 10
# Create interface VFC 1, and configure it to operate in F mode.
[SwitchA-Vfc1] fc mode f
[SwitchA-Vfc1] quit
[SwitchA-Vfc2] quit
# Assign Ten-GigabitEthernet 1/0/1 o VLAN 10 as a trunk port.
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 10
[SwitchA] vlan 10
# Configure the members in the default zone in VSAN 1 to access each other.
[SwitchA] vsan 1
[SwitchB] save
[SwitchB] quit
<SwitchB> reboot
2.        Configure DCBX:
[SwitchB] lldp global enable
# Enable LLDP and DCBX TLV advertising on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[SwitchB] interface range ten-gigabitethernet 1/0/2 to ten-gigabitethernet 1/0/3
[SwitchB-if-range] lldp enable
[SwitchB-if-range] lldp tlv-enable dot1-tlv dcbx
# Create Layer 2 ACL 4000.
[SwitchB] acl mac 4000
# Configure ACL 4000 to permit FCoE packets (protocol number is 0x8906) and FIP protocol packets (protocol number is 0x8914) to pass through.
[SwitchB-acl-mac-4000] rule 0 permit type 8906 ffff
[SwitchB-acl-mac-4000] rule 5 permit type 8914 ffff
[SwitchB-acl-mac-4000] quit
# Create a class named app_c, specify the operator of the class as OR, and use ACL 4000 as the match criterion of the class.
[SwitchB] traffic classifier app_c operator or
[SwitchB-classifier-app_c] if-match acl mac 4000
[SwitchB-classifier-app_c] quit
# Create a behavior named app_b, and configure the behavior to mark packets with 802.1p priority value 3.
[SwitchB] traffic behavior app_b
[SwitchB-behavior-app_b] remark dot1p 3
[SwitchB-behavior-app_b] quit
# Create a QoS policy named plcy, associate class app_c with traffic behavior app_b in the QoS policy, and specify that the association apply to DCBX.
[SwitchB] qos policy plcy
[SwitchB-qospolicy-plcy] classifier app_c behavior app_b mode dcbx
[SwitchB-qospolicy-plcy] quit
# Apply QoS policy plcy to the outgoing traffic of Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchB-if-range] qos apply policy plcy outbound
3.        Configure PFC:
# Enable PFC in auto mode on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchB-if-range] priority-flow-control auto
# Configure Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to trust the 802.1p priority carried in incoming packets.
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] priority-flow-control enable
[SwitchB-Ten-GigabitEthernet1/0/1] priority-flow-control no-drop dot1p 3
# Configure Ten-GigabitEthernet 1/0/1 to trust the 802.1p priority carried in incoming packets.
[SwitchB-Ten-GigabitEthernet1/0/1] qos trust dot1p
[SwitchB-Ten-GigabitEthernet1/0/1] quit
4.        Configure ETS:
# Configure the 802.1p-local priority mapping table as follows:
¡  Map 802.1p priority value 3 to local precedence 1.
¡  Map the other 802.1p priorities to local precedence 0.
[SwitchB] qos map-table dot1p-lp
[SwitchB-maptbl-dot1p-lp] import 3 export 1
[SwitchB-maptbl-dot1p-lp] import 0 1 2 4 5 6 7 export 0
[SwitchB-maptbl-dot1p-lp] quit
# Configure byte-count WRR on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchB-if-range] qos wrr byte-count
# Assign 50% of the interface bandwidth to the FCoE traffic (traffic assigned to queue 1) on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchB-if-range] qos wrr af1 group 1 byte-count 1
# Assign 50% of the interface bandwidth to the LAN traffic (traffic assigned to queue 0) on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchB-if-range] qos wrr be group 1 byte-count 1
# Assign the other queues to the SP group on Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3.
[SwitchB-if-range] qos wrr af2 group sp
[SwitchB-if-range] qos wrr af3 group sp
[SwitchB-if-range] qos wrr af4 group sp
[SwitchB-if-range] qos wrr ef group sp
[SwitchB-if-range] qos wrr cs6 group sp
[SwitchB-if-range] qos wrr cs7 group sp
5.        Configure FCoE:
# Configure the switch to operate in Transit mode.
[SwitchB] fcoe-mode transit
# Enable FIP snooping in VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] fip-snooping enable
# Set the FC-MAP value to 0x0EFC01 in VLAN 10.
[SwitchB-vlan10] fip-snooping fc-map 0efc01
Changing the FC-MAP will flap all interfaces. Continue? [Y/N]:y
# Configure Ten-GigabitEthernet 1/0/1 to allow VLAN 10.
[SwitchB-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 10
# Configure Ten-GigabitEthernet 1/0/1 to operate in FCF mode.
[SwitchB-Ten-GigabitEthernet1/0/1] fip-snooping port-mode fcf
# Configure Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to allow VLAN 10.
# Configure Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to operate in ENode mode.
[SwitchB-if-range] fip-snooping port-mode enode
# Display the domain information of VSAN 1 on Switch A.
        State: Stable
        Switch WWN: 20:01:ac:2d:57:97:07:00
        Fabric name: 48:33:43:2d:46:43:1B:1B
        Priority: 25
        Domain ID: 11
        Priority: 10
        Domain ID: 0 (preferred)
        Priority: 25
    Path          Interface
    Upstream      Vfc2
The output shows that the domain configuration is complete on Switch A, and the principal switch assigns domain ID 11 to Switch A.
# Display ENode information obtained by Switch B.
[SwitchB] display fip-snooping enode
VLAN 10:
Interface   ENode WWN                  ENode MAC
XGE1/0/2    10:00:00:11:22:00:0d:01    0000-1234-0e01
XGE1/0/3    11:00:00:11:22:00:0d:02    0000-1234-0f01
# Display FCF switch information obtained by Switch B.
[SwitchB] display fip-snooping fcf
VLAN 10:
Interface   FCF MAC          FCF WWN                 Fabric Name                ENode
XGE1/0/1    0000-1234-0d01   20:01:ac:2d:57:97:07:00 48:33:43:2d:46:43:1B:1B    2
# Display information about FIP snooping sessions.
[SwitchB] display fip-snooping sessions
VLAN 10:
FCF MAC          ENode MAC         VN_Port MAC     VN_Port WWN
0000-1234-0d01   0000-1234-0e01    0efc-0001-0000  af:10:01:11:22:00:0e:01
0000-1234-0d01   0000-1234-0f01    0efc-0002-0001  af:11:01:11:22:00:0f:01
# Display the FIP snooping rules that have been flushed.
[SwitchB] display fip-snooping rules
Slot 1:
  VLAN 10:
    FCF rules information:
      Interface   Source MAC/Mask     Destination MAC/Mask   Context
      XGE1/0/1    0000-1234-0d01/48   0efc-0000-0000/24      ffffffff
    ENode rules information:
      XGE1/0/2    0efc-0001-0000/48   0000-1234-0d01/48      ffffffff
      XGE1/0/3    0efc-0002-0000/48   0000-1234-0d01/48      ffffffff
Configuration files
·          Switch A:
 fcoe-mode fcf
 fcoe fcmap 0efc01
vsan 1
 priority 10
vlan 10
 fcoe enable vsan 1
 qos trust dot1p
interface Vfc1
 port trunk vsan 1
·          Switch B:
 lldp global enable
 fcoe-mode fcf
vlan 10
 fip-snooping enable
 import 0 export 0
 import 2 export 0
 import 3 export 1
 import 4 export 0
 import 5 export 0
 import 6 export 0
 import 7 export 0
 remark dot1p 3
qos policy plcy
 qos trust dot1p
 qos trust dot1p
 qos wrr ef group sp
 qos trust dot1p
 qos wrr ef group sp
acl mac 4000
Related documentation
·          H3C S10500X Switch Series FCoE Configuration Guide-R758X
·          H3C S10500X Switch Series FCoE Command Reference-R758X
