04-Layer 3 - IP Services Configuration Examples
HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration ExamplesH3C S7500X Switch Series Configuration Examples-R7585P05-6W10004-Layer 3 - IP Services Configuration Examples
02-H3C_GRE_Tunnel_Configuration_Examples
02-H3C_GRE_Tunnel_Configuration_Examples 79.58 KB
H3C GRE Tunnel Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides GRE tunnel configuration examples.
This document assumes that you have basic knowledge of GRE.
Example: Configuring a GRE tunnel
As shown in Figure 1, Device A, Device B, and Device C are all on an IPv4 network. Dual stack devices Device A and Device B each connect to an IPv6 host.
Configure a GRE tunnel between Device A and Device B, so PC A and PC B can communicate with each other over the IPv4 network.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To enable the IPv6 hosts to communicate over the IPv4 network, specify the GRE tunnel mode as GRE/IPv4 and configure IPv6 addresses for the tunnel interfaces.
·     To transmit packets between PC A and PC B through the GRE tunnel, configure a route reaching the destination network through the tunnel interface on Device A and Device B. You can configure the routes by using either of the following methods:
¡     Configure static routes, using the peer tunnel interface as the next hop or using the local tunnel interface as the outgoing interface.
¡     Enable a dynamic routing protocol on both the tunnel interfaces and the Layer 3 interfaces connected to PC A and PC B.
·     For both ends of the GRE tunnel to reach each other, configure a static route reaching the remote end on Device A and Device B.
When you configure the GRE tunnel, follow these restrictions and guidelines:
·     You must configure the tunnel source address and destination address at both ends of the tunnel. The tunnel source or destination address at one end must be the tunnel destination or source address at the other end.
·     Encapsulated packets cannot be forwarded on Layer 3 according to the destination IP addresses and routing tables. You must create a service loopback group of the tunnel service type to loop encapsulated packets back to the forwarding module for Layer 3 forwarding.
Procedures
Configuring Device A
# Configure an IPv6 address for VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 2/0/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 192.13.2.2 24
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
# Create tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 1 mode gre
# Configure an IPv6 address for tunnel interface Tunnel 1.
[DeviceA-Tunnel1] ipv6 address 3001::1 64
# Configure the source address of Tunnel 1 as the IP address of VLAN-interface 10.
[DeviceA-Tunnel1] source 192.13.2.2
# Configure the destination address of Tunnel 1 as the IP address of VLAN-interface 11 on Device B.
[DeviceA-Tunnel1] destination 131.108.5.2
[DeviceA-Tunnel1] quit
# Configure a static route reaching PC B through tunnel interface Tunnel 1.
[DeviceA] ipv6 route-static 2001:: 64 tunnel 1
# Configure a static route reaching the remote end of the GRE tunnel.
[DeviceA] ip route-static 131.108.5.2 255.255.255.0 192.13.2.1
# Create service loopback group 1, and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Add Ten-GigabitEthernet 3/0/2 to service loopback group 1.
[DeviceA] interface ten-gigabitethernet 3/0/2
[DeviceA-Ten-GigabitEthernet3/0/2] port service-loopback group 1
[DeviceA-Ten-GigabitEthernet3/0/2] quit
Configuring Device B
# Configure an IPv6 address for VLAN-interface 11.
[DeviceB] vlan 11
[DeviceB-vlan 11] port ten-gigabitethernet 2/0/2
[DeviceB-vlan 11] quit
[DeviceB] interface vlan-interface 11
[DeviceB-Vlan-interface11] ip address 131.108.5.2 24
[DeviceB-Vlan-interface11] quit
# Configure other interfaces in the same way VLAN-interface 11 is configured. (Details not shown.)
[DeviceB] interface tunnel 1 mode gre
[DeviceB-Tunnel1] ipv6 address 3001::2 64
# Configure the source address of Tunnel 1 as the IP address of VLAN-interface 11.
[DeviceB-Tunnel1] source 131.108.5.2
# Configure the destination address of Tunnel 1 as the IP address of VLAN-interface 10 on Device A.
[DeviceB-Tunnel1] destination 192.13.2.2
[DeviceB-Tunnel1] quit
# Configure a static route reaching PC A through tunnel interface Tunnel 1.
[DeviceB] ipv6 route-static 1001:: 64 Tunnel 1
[DeviceB] ip route-static 192.13.2.2 255.255.255.0 131.108.5.1
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface ten-gigabitethernet 3/0/2
[DeviceB-Ten-GigabitEthernet3/0/2] port service-loopback group 1
Configuring Device C
# Configure an IP address for VLAN-interface 10.
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan 10] port ten-gigabitethernet 2/0/1
[DeviceC-vlan 10] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ip address 192.13.2.1 24
[DeviceC-Vlan-interface10] quit
# Configure an IP address for VLAN-interface 11.
[DeviceC] vlan 11
[DeviceC-vlan 11] port ten-gigabitethernet 2/0/2
[DeviceC-vlan 11] quit
[DeviceC] interface vlan-interface 11
[DeviceC-Vlan-interface11] ip address 131.108.5.1 24
[DeviceC-Vlan-interface11] quit
# Verify that PC A and PC B can ping each other successfully. This example uses PC A to ping PC B.
C:\>ping6 2001::2
Pinging 2001::2
from 1001::1 with 32 bytes of data:
Reply from 2001::2: bytes=32 time<1ms
Ping statistics for 2001::2:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
Configuration files
·     Device A:
vlan 10
vlan 20
interface Ten-GigabitEthernet2/0/1
 port link-mode bridge
 port access vlan 10
interface Ten-GigabitEthernet3/0/1
 port access vlan 20
interface Ten-GigabitEthernet3/0/2
interface Vlan-interface10
 ip address 192.13.2.2 255.255.255.0
interface Vlan-interface20
 ipv6 address 1001::1/64
interface Tunnel1 mode gre
 ipv6 address 3001::1/64
 source 192.13.2.2
 ipv6 route-static 2001:: 64 Tunnel 1
·     Device B:
vlan 11
vlan 20
interface Ten-GigabitEthernet2/0/2
 port access vlan 11
 port access vlan 20
interface Vlan-interface11
 ip address 131.108.5.2 255.255.255.0
 ipv6 address 2001::1/64
 ipv6 address 3001::2/64
 source 131.108.5.2
·     Device C:
vlan 10
vlan 11
 port access vlan 10
 port access vlan 11
 ip address 192.13.2.1 255.255.255.0
 ip address 131.108.5.1 255.255.255.0
Related documentation
·     H3C S7500X Switch Series Layer 3—IP Services Command Reference-R758X
·     H3C S7500X Switch Series Layer 3—IP Services Configuration Guide-R758X
