16-EVPN Configuration Examples
HomeSupportSwitchesH3C S7500E-X Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-X Switch Series Configuration Examples-R7585P05-6W10016-EVPN Configuration Examples
02-H3C_MDC+EVPN_Configuration_Examples
02-H3C_MDC+EVPN_Configuration_Examples 173.37 KB
H3C MDC + EVPN Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples for deploying Multitenant Device Context (MDC) in combination with Ethernet Virtual Private Network (EVPN).
·          The MDC technology can partition a physical device or an IRF fabric into multiple logical devices. Each of the logical devices is called an MDC.
·          EVPN is a Layer 2 VPN technology. It uses MP-BGP to advertise EVPN routes in the control plane and uses VXLAN to forward traffic in the data plane.
By deploying MDC in combination with EVPN, you can quickly meet EVPN service requirements on traditional networks at a lower cost while isolating traditional services from EVPN services.
This document assumes that you have basic knowledge of MDC and EVPN.
Example: Configuring MDC in combination with EVPN
As shown in Figure 1, a company needs to use its existing IP network to provide IPTV and OTT services for users.
To provide IPTV and OTT services while reducing cost, the company needs to deploy MDC in combination with EVPN on the network as follows:
·          Virtualize Switch A into SWA-MDC1 and SWA-MDC2. Virtualize Switch B into SWB-MDC1 and SWB-MDC2. Configure SWA-MDC2 and SWB-MDC2 as RRs to reflect BGP EVPN routes on the EVPN network. Configure SWA-MDC1 as the gateway for the IPTV network. Configure SWB-MDC1 as the gateway for the OTT network.
·          Configure Switch C and Switch D as distributed EVPN gateways.
·          Configure Switch E as border gateway to the Internet.
·          Assign Server 1 and Server 3 to VXLAN 10. Assign Server 2 and Server 4 to VXLAN 20. Achieve the following goals:
¡  The hosts in the same VXLAN can communicate at Layer 2.
¡  The hosts in different VXLANs can communicate at Layer 3 through the distributed EVPN gateways.
¡  Hosts in the VXLANs can access the Internet at Layer 3 through border gateways.
·          The IPTV network needs to receive multicast information from Source through Switch F. Configure PIM on SWA-MDC1, SWA-MDC2, SWB-MDC2, Switch D, and Switch E to establish a multicast distribution tree. Configure SWA-MDC1 as the service gateway of the IPTV network.
·          The OTT network needs to provide traditional services. Configure SWB-MDC1 as the gateway of the OTT network.
Figure 1 Network diagram
Device
IP address
Device
IP address
SWA-MDC1
Loopback0
6.6.6.6/32
Switch D
Loopback0
4.4.4.4/32
Vlan-int10
17.1.1.6/24
Vlan-int10
14.1.1.4/24
Vlan-int20
18.1.1.6/24
Vlan-int20
13.1.1.4/24
SWA-MDC2
Loopback0
1.1.1.1/32
Vlan-int30
21.1.1.4/24
Vlan-int10
11.1.1.1/24
Switch E
Loopback0
5.5.5.5/32
Vlan-int20
13.1.1.1/24
Vlan-int10
22.1.1.5/24
Vlan-int30
15.1.1.1/24
Vlan-int20
18.1.1.5/24
SWB-MDC1
Loopback0
7.7.7.7/32
Vlan-int30
15.1.1.5/24
Vlan-int10
20.1.1.7/24
Vlan-int40
16.1.1.5/24
Vlan-int50
19.1.1.7/24
Vlan-int50
19.1.1.5/24
SWB-MDC2
Loopback0
2.2.2.2/32
Switch F
Loopback0
9.9.9.9/32
Vlan-int10
14.1.1.2/24
Vlan-int10
17.1.1.9/24
Vlan-int20
12.1.1.2/24
Vlan-int20
10.1.4.1/24
Vlan-int40
16.1.1.2/24
Switch C
Loopback0
3.3.3.3/32
Vlan-int10
11.1.1.3/24
Vlan-int20
12.1.1.3/24
Analysis
To virtualize Switch A and Switch B into the required MDCs, configure MDCs on Switch A and Switch B.
For IP connectivity between SWA-MDC1, SWA-MDC2, SWB-MDC1, SWB-MDC2, Switch C, Switch D, and Switch E, configure a routing protocol on them and assign IP addresses to their interfaces, including loopback interfaces. In this example, OSPF is configured.
For Switch C and Switch D to use a VXLAN tunnel to communicate with each other, configure them as distributed EVPN gateways.
For the downlink ports of Switch C and Switch D to identify the VXLANs to which user network packets belong, configure Ethernet service instances and frame match criteria on the ports.
To enable SWA-MDC1, SWA-MDC2, SWB-MDC2, Switch D, and Switch E to establish a multicast distribution tree, configure PIM on them.
For the IPTV network and OTT network to access external networks, configure SWA-MDC1 as the IPTV network and configure SWB-MDC1 as the OTT network.
Procedures
Configuring MDCs on Switch A and Switch B
1.        Configure SWA-MDC1 on Switch A:
# Create SWA-MDC1.
[SwitchA] mdc SWA-MDC1
It will take some time to create MDC...
MDC created successfully.
[SwitchA-mdc-2-SWA-MDC1] quit
# Reclaim the LPUs in slot 1 and slot 2 from the default MDC.
[SwitchA] mdc Admin
[SwitchA-mdc-1-Admin] undo location slot 1
Performing this command is equivalent to removing the card from the MDC. Continue? [Y/N]:y
[SwitchA-mdc-1-Admin] undo location slot 2
[SwitchA-mdc-1-Admin] quit
# Assign interfaces Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/24 to SWA-MDC1.
[SwitchA-mdc-2-SWA-MDC1] allocate interface ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/24
This operation will allocate the specified interfaces and all interfaces in the listed groups to the MDC. Continue? [Y/N]:y
Configuration of the interfaces will be lost. Continue? [Y/N]:y
Execute the location slot command in the current view to place the configuration into effect.
# Assign LPU 1 to SWA-MDC1.
[SwitchA-mdc-2-SWA-MDC1] location slot 1
# Start SWA-MDC1.
[SwitchA-mdc-2-SWA-MDC1] mdc start
It will take some time to start MDC...
MDC started successfully.
2.        Configure SWA-MDC2 on Switch A:
# Create SWA-MDC2.
[SwitchA] mdc SWA-MDC2
# Assign interfaces Ten-GigabitEthernet 2/0/1 through Ten-GigabitEthernet 2/0/24 to SWA-MDC2.
[SwitchA-mdc-3-SWA-MDC2] allocate interface ten-gigabitethernet 2/0/1 to ten-gigabitethernet 2/0/24
# Assign LPU 2 to SWA-MDC2.
[SwitchA-mdc-3-SWA-MDC2] location slot 2
# Start SWA-MDC2.
 [SwitchA-mdc-3-SWA-MDC2] mdc start
[SwitchA-mdc-3-SWA-MDC2] quit
3.        Configure SWB-MDC1 on Switch B:
# Create SWB-MDC1.
[SwitchB] mdc SWB-MDC1
[SwitchB-mdc-2-SWB-MDC1] quit
[SwitchB] mdc Admin
[SwitchB-mdc-1-Admin] undo location slot 1
[SwitchB-mdc-1-Admin] undo location slot 2
[SwitchB-mdc-1-Admin] quit
# Assign interfaces Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/24 to SWB-MDC1.
[SwitchB-mdc-2-SWB-MDC1] allocate interface ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/24
# Assign LPU 1 to SWB-MDC1.
[SwitchB-mdc-2-SWB-MDC1] location slot 1
# Start SWB-MDC1.
[SwitchB-mdc-2-SWB-MDC1] mdc start
4.        Configure SWB-MDC2 on Switch B:
# Create SWB-MDC2.
[SwitchB] mdc SWB-MDC2
# Assign interfaces Ten-GigabitEthernet 2/0/1 through Ten-GigabitEthernet 2/0/24 to SWB-MDC2.
[SwitchB-mdc-3-SWB-MDC2] allocate interface ten-gigabitethernet 2/0/1 to ten-gigabitethernet 2/0/24
# Assign LPU 2 to SWB-MDC2.
[SwitchB-mdc-3-SWB-MDC2] location slot 2
# Start SWB-MDC2.
[SwitchB-mdc-3-SWB-MDC2] mdc start
[SwitchB-mdc-3-SWB-MDC2] quit
Configuring the IPTV and OTT networks
Assigning IP addresses to interfaces on the devices
# Log in to SWA-MDC1 and assign IP addresses to its interfaces.
[SwitchA] switchto mdc SWA-MDC1
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
Automatic configuration is running, press CTRL_D to break or press CTRL_B to
switch back to the default MDC.
<SWA-MDC1> system-view
[SWA-MDC1] interface loopback 0
[SWA-MDC1-Loopback0] ip address 6.6.6.6 32
[SWA-MDC1-Loopback0] quit
[SWA-MDC1] vlan 10
[SWA-MDC1-vlan10] port ten-gigabitethernet 1/0/1
[SWA-MDC1-vlan10] quit
[SWA-MDC1] interface vlan-interface 10
[SWA-MDC1-Vlan-interface10] ip address 17.1.1.6 24
[SWA-MDC1-Vlan-interface10] quit
[SWA-MDC1] vlan 20
[SWA-MDC1-vlan20] port ten-gigabitethernet 1/0/2
[SWA-MDC1-vlan20] quit
[SWA-MDC1] interface vlan-interface 20
[SWA-MDC1-Vlan-interface20] ip address 18.1.1.6 24
[SWA-MDC1-Vlan-interface20] quit
# Use the same method to log in to the other MDCs and assign IP addresses to interfaces. (Details not shown.)
# Assign IP addresses to interfaces on Switch C.
[SwitchC-Loopback0] ip address 3.3.3.3 32
[SwitchC-Loopback0] quit
[SwitchC] vlan 10
[SwitchC-vlan10] port ten-gigabitethernet 1/0/3
[SwitchC-vlan10] quit
[SwitchC] interface vlan-interface 10
[SwitchC-Vlan-interface10] ip address 11.1.1.3 24
[SwitchC-Vlan-interface10] quit
[SwitchC] vlan 20
[SwitchC-vlan20] port ten-gigabitethernet 1/0/4
[SwitchC-vlan20] quit
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 12.1.1.3 24
[SwitchC-Vlan-interface20] quit
# Use the same method to assign IP addresses to interfaces on the other switches. (Details not shown.)
Configuring the routing protocol
# On SWA-MDC1, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWA-MDC1] ospf 100 router-id 6.6.6.6
[SWA-MDC1-ospf-100] area 0
[SWA-MDC1-ospf-100-area-0.0.0.0] network 6.6.6.6 0.0.0.0
[SWA-MDC1-ospf-100-area-0.0.0.0] network 17.1.1.0 0.0.0.255
[SWA-MDC1-ospf-100-area-0.0.0.0] network 18.1.1.0 0.0.0.255
[SWA-MDC1-ospf-100-area-0.0.0.0] quit
[SWA-MDC1-ospf-100] quit
# On SWA-MDC2, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWA-MDC2] ospf 100 router-id 1.1.1.1
[SWA-MDC2-ospf-100] area 0
[SWA-MDC2-ospf-100-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SWA-MDC2-ospf-100-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SWA-MDC2-ospf-100-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SWA-MDC2-ospf-100-area-0.0.0.0] network 15.1.1.0 0.0.0.255
[SWA-MDC2-ospf-100-area-0.0.0.0] quit
[SWA-MDC2-ospf-100] quit
# On SWB-MDC1, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWB-MDC1] ospf 100 router-id 7.7.7.7
[SWB-MDC1-ospf-100] area 0
[SWB-MDC1-ospf-100-area-0.0.0.0] network 7.7.7.7 0.0.0.0
[SWB-MDC1-ospf-100-area-0.0.0.0] network 19.1.1.0 0.0.0.255
[SWB-MDC1-ospf-100-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SWB-MDC1-ospf-100-area-0.0.0.0] quit
[SWB-MDC1-ospf-100] quit
# On SWB-MDC2, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWB-MDC2] ospf 100 router-id 2.2.2.2
[SWB-MDC2-ospf-100] area 0
[SWB-MDC2-ospf-100-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[SWB-MDC2-ospf-100-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SWB-MDC2-ospf-100-area-0.0.0.0] network 14.1.1.0 0.0.0.255
[SWB-MDC2-ospf-100-area-0.0.0.0] network 16.1.1.0 0.0.0.255
[SWB-MDC2-ospf-100-area-0.0.0.0] quit
[SWB-MDC2-ospf-100] quit
# On Switch C, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchC] ospf 100 router-id 3.3.3.3
[SwitchC-ospf-100] area 0
[SwitchC-ospf-100-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[SwitchC-ospf-100-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchC-ospf-100-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchC-ospf-100-area-0.0.0.0] quit
[SwitchC-ospf-100] quit
# On Switch D, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchD] ospf 100 router-id 4.4.4.4
[SwitchD-ospf-100] area 0
[SwitchD-ospf-100-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-100-area-0.0.0.0] network 13.1.3.0 0.0.0.255
[SwitchD-ospf-100-area-0.0.0.0] network 14.1.1.0 0.0.0.255
[SwitchD-ospf-100-area-0.0.0.0] network 21.1.1.0 0.0.0.255
[SwitchD-ospf-100-area-0.0.0.0] quit
[SwitchD-ospf-100] quit
# On Switch E, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchE] ospf 100 router-id 5.5.5.5
[SwitchE-ospf-100] area 0
[SwitchE-ospf-100-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[SwitchE-ospf-100-area-0.0.0.0] network 15.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] network 16.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] network 18.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] network 19.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] quit
[SwitchE-ospf-100] quit
# On Switch F, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchF] ospf 100 router-id 9.9.9.9
[SwitchF-ospf-100] area 0
[SwitchF-ospf-100-area-0.0.0.0] network 9.9.9.9 0.0.0.0
[SwitchF-ospf-100-area-0.0.0.0] network 17.1.1.0 0.0.0.255
[SwitchF-ospf-100-area-0.0.0.0] quit
[SwitchF-ospf-100] quit
Configuring the multicast protocol
1.        Configure Switch D:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface10, VLAN-interface 20, and VLAN-interface 30.
[SwitchD] multicast routing
[SwitchD-mrib] quit
[SwitchD] interface vlan-interface 10
[SwitchD-Vlan-interface10] pim sm
[SwitchD-Vlan-interface10] quit
[SwitchD] interface vlan-interface 20
[SwitchD-Vlan-interface20] pim sm
[SwitchD-Vlan-interface20] quit
[SwitchD] interface vlan-interface 30
[SwitchD-Vlan-interface30] pim sm
[SwitchD-Vlan-interface30] quit
# Configure Loopback 0 of SWB-MDC2 as the static RP.
[SwitchD] pim
[SwitchD-pim] static-rp 2.2.2.2
[SwitchD-pim] quit
2.        Configure SWA-MDC2:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 20 and VLAN-interface 30.
<SWA-MDC2> system-view
[SWA-MDC2] multicast routing
[SWA-MDC2-mrib] quit
[SWA-MDC2] interface vlan-interface 20
[SWA-MDC2-Vlan-interface20] pim sm
[SWA-MDC2-Vlan-interface20] quit
[SWA-MDC2] interface vlan-interface 30
[SWA-MDC2-Vlan-interface30] pim sm
[SWA-MDC2-Vlan-interface30] quit
# Configure Loopback 0 of SWA-MDC2 as a C-BSR and C-RP, and configure Loopback 0 of SWB-MDC2 as the static RP.
[SWA-MDC2] pim
[SWA-MDC2-pim] c-bsr 1.1.1.1
[SWA-MDC2-pim] c-rp 1.1.1.1
[SWA-MDC2-pim] static-rp 2.2.2.2
[SWA-MDC2-pim] quit
3.        Configure SWB-MDC2:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 10 and VLAN-interface 40.
<SWB-MDC2> system-view
[SWB-MDC2] multicast routing
[SWB-MDC2-mrib] quit
[SWB-MDC2] interface vlan-interface 10
[SWB-MDC2-Vlan-interface10] pim sm
[SWB-MDC2-Vlan-interface10] quit
[SWB-MDC2] interface vlan-interface 40
[SWB-MDC2-Vlan-interface40] pim sm
[SWB-MDC2-Vlan-interface40] quit
[SWB-MDC2] pim
[SWB-MDC2-pim] static-rp 2.2.2.2
[SWB-MDC2-pim] quit
4.        Configure Switch E:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 20, VLAN-interface 30, and VLAN-interface 40.
[SwitchE] multicast routing
[SwitchE-mrib] quit
[SwitchE] interface vlan-interface 20
[SwitchE-Vlan-interface20] pim sm
[SwitchE-Vlan-interface20] quit
[SwitchE] interface vlan-interface 30
[SwitchE-Vlan-interface30] pim sm
[SwitchE-Vlan-interface30] quit
[SwitchE] interface vlan-interface 40
[SwitchE-Vlan-interface40] pim sm
[SwitchE-Vlan-interface40] quit
[SwitchE] pim
[SwitchE-pim] static-rp 2.2.2.2
[SwitchE-pim] quit
5.        Configure SWA-MDC1:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 10 and VLAN-interface 20.
[SWA-MDC1] multicast routing
[SWA-MDC1-mrib] quit
[SWA-MDC1-Vlan-interface10] pim sm
[SWA-MDC1-Vlan-interface20] pim sm
[SWA-MDC1] pim
[SWA-MDC1-pim] static-rp 2.2.2.2
[SWA-MDC1-pim] quit
6.        Configure Switch F:
# Enable IP multicast routing, enable IGMP on VLAN-interface 20 (the host-side interface), and enable PIM-SM on VLAN-interface 10.
[SwitchF] multicast routing
[SwitchF-mrib] quit
[SwitchF] interface vlan-interface 10
[SwitchF-Vlan-interface10] pim sm
[SwitchF-Vlan-interface10] quit
[SwitchF] interface vlan-interface 20
[SwitchF-Vlan-interface20] igmp enable
[SwitchF-Vlan-interface20] quit
[SwitchF] pim
[SwitchF-pim] static-rp 2.2.2.2
[SwitchF-pim] quit
Configuring the EVPN network
Creating VSIs, EVPN instances, and VXLANs
1.        Configure Switch C:
# Enable L2VPN.
[SwitchC] l2vpn enable
# Disable remote MAC address learning and remote ARP learning.
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] evpn encapsulation vxlan
[SwitchC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
# Create an EVPN instance on VSI vpnb, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] evpn encapsulation vxlan
[SwitchC-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchC-vsi-vpnb] vxlan 20
[SwitchC-vsi-vpnb-vxlan-20] quit
[SwitchC-vsi-vpnb] quit
2.        Configure Switch D:
# Enable L2VPN.
[SwitchD] l2vpn enable
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vxlan tunnel arp-learning disable
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] evpn encapsulation vxlan
[SwitchD-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchD-vsi-vpna] vxlan 10
[SwitchD-vsi-vpna-vxlan-10] quit
[SwitchD-vsi-vpna] quit
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] evpn encapsulation vxlan
[SwitchD-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchD-vsi-vpnb] vxlan 20
[SwitchD-vsi-vpnb-vxlan-20] quit
[SwitchD-vsi-vpnb] quit
Configuring Ethernet service instances to match packets and mapping the instances to VSIs
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 10 (Server 1), and map the Ethernet service instance to VSI vpna (VXLAN 10).
[SwitchC] interface ten-gigabitethernet 1/0/1
[SwitchC-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchC-Ten-GigabitEthernet1/0/1] quit
# On Ten-GigabitEthernet 1/0/2, create Ethernet service instance 1000 to match VLAN 11 (Server 2), and map the Ethernet service instance to VSI vpnb (VXLAN 20).
[SwitchC] interface ten-gigabitethernet 1/0/2
[SwitchC-Ten-GigabitEthernet1/0/2] service-instance 1000
[SwitchC-Ten-GigabitEthernet1/0/2-srv1000] encapsulation s-vid 11
[SwitchC-Ten-GigabitEthernet1/0/2-srv1000] xconnect vsi vpnb
[SwitchC-Ten-GigabitEthernet1/0/2-srv1000] quit
[SwitchC-Ten-GigabitEthernet1/0/2] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 12 (Server 3), and map the Ethernet service instance to VSI vpna (VXLAN 10).
[SwitchD] interface ten-gigabitethernet 1/0/1
[SwitchD-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchD-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 12
[SwitchD-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchD-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchD-Ten-GigabitEthernet1/0/1] quit
# On Ten-GigabitEthernet 1/0/2, create Ethernet service instance 1000 to match VLAN 13 (Server 4), and map the Ethernet service instance to VSI vpnb (VXLAN 20).
[SwitchD] interface ten-gigabitethernet 1/0/2
[SwitchD-Ten-GigabitEthernet1/0/2] service-instance 1000
[SwitchD-Ten-GigabitEthernet1/0/2-srv1000] encapsulation s-vid 13
[SwitchD-Ten-GigabitEthernet1/0/2-srv1000] xconnect vsi vpnb
[SwitchD-Ten-GigabitEthernet1/0/2-srv1000] quit
[SwitchD-Ten-GigabitEthernet1/0/2] quit
Configuring BGP to advertise BGP EVPN routes
1.        Configure SWA-MDC2:
# Configure SWA-MDC2 to establish BGP connections to other devices.
[SWA-MDC2] bgp 100
[SWA-MDC2-bgp-default] group evpn
[SWA-MDC2-bgp-default] peer 3.3.3.3 group evpn
[SWA-MDC2-bgp-default] peer 4.4.4.4 group evpn
[SWA-MDC2-bgp-default] peer 5.5.5.5 group evpn
[SWA-MDC2-bgp-default] peer evpn as-number 100
[SWA-MDC2-bgp-default] peer evpn connect-interface loopback 0
[SWA-MDC2-bgp-default] peer 2.2.2.2 as-number 100
[SWA-MDC2-bgp-default] peer 2.2.2.2 connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering for BGP EVPN routes.
[SWA-MDC2-bgp-default] address-family l2vpn evpn
[SWA-MDC2-bgp-default-evpn] peer evpn enable
[SWA-MDC2-bgp-default-evpn] peer 2.2.2.2 enable
[SWA-MDC2-bgp-default-evpn] undo policy vpn-target
# Configure SWA-MDC2 as the RR.
[SWA-MDC2-bgp-default-evpn] reflector cluster-id 8.8.8.8
[SWA-MDC2-bgp-default-evpn] peer evpn reflect-client
[SWA-MDC2-bgp-default-evpn] quit
[SWA-MDC2-bgp-default] quit
2.        Configure SWB-MDC2:
# Configure SWB-MDC2 to establish BGP connections to other devices.
[SWB-MDC2] bgp 100
[SWB-MDC2-bgp-default] group evpn
[SWB-MDC2-bgp-default] peer 3.3.3.3 group evpn
[SWB-MDC2-bgp-default] peer 4.4.4.4 group evpn
[SWB-MDC2-bgp-default] peer 5.5.5.5 group evpn
[SWB-MDC2-bgp-default] peer evpn as-number 100
[SWB-MDC2-bgp-default] peer evpn connect-interface loopback 0
[SWB-MDC2-bgp-default] peer 1.1.1.1 as-number 100
[SWB-MDC2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SWB-MDC2-bgp-default] address-family l2vpn evpn
[SWB-MDC2-bgp-default-evpn] peer evpn enable
[SWB-MDC2-bgp-default-evpn] peer 1.1.1.1 enable
[SWB-MDC2-bgp-default-evpn] undo policy vpn-target
# Configure SWB-MDC2 as the RR.
[SWB-MDC2-bgp-default-evpn] reflector cluster-id 8.8.8.8
[SWB-MDC2-bgp-default-evpn] peer evpn reflect-client
[SWB-MDC2-bgp-default-evpn] quit
[SWB-MDC2-bgp-default] quit
3.        Configure Switch C:
# Configure Switch C to establish BGP connections to other devices.
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 1.1.1.1 as-number 100
[SwitchC-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchC-bgp-default] peer 2.2.2.2 as-number 100
# Configure BGP to advertise BGP EVPN routes.
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchC-bgp-default-evpn] peer 2.2.2.2 enable
4.        Configure Switch D:
# Configure Switch D to establish BGP connections to other devices.
[SwitchD] bgp 100
[SwitchD-bgp-default] peer 1.1.1.1 as-number 100
[SwitchD-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchD-bgp-default] peer 2.2.2.2 as-number 100
[SwitchD-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchD-bgp-default-evpn] peer 2.2.2.2 enable
5.        Configure Switch E:
# Configure Switch E to establish BGP connections to other devices.
[SwitchE] bgp 100
[SwitchE-bgp-default] peer 1.1.1.1 as-number 100
[SwitchE-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchE-bgp-default] peer 2.2.2.2 as-number 100
[SwitchE-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchE-bgp-default] address-family l2vpn evpn
[SwitchE-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchE-bgp-default-evpn] peer 2.2.2.2 enable
Configuring the distributed EVPN gateways
# Configure RD and route target settings for VPN instance vpna.
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 1:1
[SwitchC-vpn-instance-vpna] address-family ipv4
[SwitchC-vpn-ipv4-vpna] vpn-target 2:2
[SwitchC-vpn-ipv4-vpna] quit
[SwitchC-vpn-instance-vpna] address-family evpn
[SwitchC-vpn-evpn-vpna] vpn-target 1:1
[SwitchC-vpn-evpn-vpna] quit
[SwitchC-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip binding vpn-instance vpna
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] mac-address 1-1-1
[SwitchC-Vsi-interface1] distributed-gateway local
[SwitchC-Vsi-interface1] local-proxy-arp enable
[SwitchC-Vsi-interface1] quit
# Configure VSI-interface 2.
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip binding vpn-instance vpna
[SwitchC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchC-Vsi-interface2] mac-address 2-2-2
[SwitchC-Vsi-interface2] distributed-gateway local
[SwitchC-Vsi-interface2] local-proxy-arp enable
[SwitchC-Vsi-interface2] quit
# Create VSI-interface 3. Associate VSI-interface 3 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchC] interface vsi-interface 3
[SwitchC-Vsi-interface3] ip binding vpn-instance vpna
[SwitchC-Vsi-interface3] l3-vni 1000
[SwitchC-Vsi-interface3] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna (the VSI of VXLAN 10).
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
# Specify VSI-interface 2 as the gateway interface for VSI vpnb (the VSI of VXLAN 20).
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] gateway vsi-interface 2
[SwitchD] ip vpn-instance vpna
[SwitchD-vpn-instance-vpna] route-distinguisher 1:1
[SwitchD-vpn-instance-vpna] address-family ipv4
[SwitchD-vpn-ipv4-vpna] vpn-target 2:2
[SwitchD-vpn-ipv4-vpna] quit
[SwitchD-vpn-instance-vpna] address-family evpn
[SwitchD-vpn-evpn-vpna] vpn-target 1:1
[SwitchD-vpn-evpn-vpna] quit
[SwitchD-vpn-instance-vpna] quit
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpna
[SwitchD-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchD-Vsi-interface1] mac-address 1-1-1
[SwitchD-Vsi-interface1] distributed-gateway local
[SwitchD-Vsi-interface1] local-proxy-arp enable
[SwitchD-Vsi-interface1] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] ip binding vpn-instance vpna
[SwitchD-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchD-Vsi-interface2] mac-address 2-2-2
[SwitchD-Vsi-interface2] distributed-gateway local
[SwitchD-Vsi-interface2] local-proxy-arp enable
[SwitchD-Vsi-interface2] quit
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance vpna
[SwitchD-Vsi-interface3] l3-vni 1000
[SwitchD-Vsi-interface3] quit
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] gateway vsi-interface 1
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] gateway vsi-interface 2
Configuring border gateway Switch E
# Enable L2VPN.
<SwitchE> system-view
[SwitchE] l2vpn enable
[SwitchE] vxlan tunnel mac-learning disable
[SwitchE] vxlan tunnel arp-learning disable
[SwitchE] ip vpn-instance vpna
[SwitchE-vpn-instance-vpna] route-distinguisher 1:1
[SwitchE-vpn-instance-vpna] address-family ipv4
[SwitchE-vpn-ipv4-vpna] vpn-target 2:2
[SwitchE-vpn-ipv4-vpna] quit
[SwitchE-vpn-instance-vpna] address-family evpn
[SwitchE-vpn-evpn-vpna] vpn-target 1:1
[SwitchE-vpn-evpn-vpna] quit
[SwitchE-vpn-instance-vpna] quit
[SwitchE] interface vsi-interface 3
[SwitchE-Vsi-interface3] ip binding vpn-instance vpna
[SwitchE-Vsi-interface3] l3-vni 1000
[SwitchE-Vsi-interface3] quit
# Configure a default route. Set the next hop to 22.1.1.100 (the IP address of a device in the Internet).
[SwitchE] ip route-static vpn-instance vpna 0.0.0.0 0 22.1.1.100
# Redistribute the default route to the BGP IPv4 unicast routing table of VPN instance vpna.
[SwitchE] bgp 100
[SwitchE-bgp-default] ip vpn-instance vpna
[SwitchE-bgp-default-vpna] address-family ipv4 unicast
[SwitchE-bgp-default-ipv4-vpna] default-route imported
[SwitchE-bgp-default-ipv4-vpna] import-route static
[SwitchE-bgp-default-ipv4-vpna] quit
[SwitchE-bgp-default-vpna] quit
[SwitchE-bgp-default] quit
# Associate VLAN-interface 10 (the interface connected to the Internet) with VPN instance vpna.
[SwitchE] interface vlan-interface 10
[SwitchE-Vlan-interface20] ip binding vpn-instance vpna
[SwitchE-Vlan-interface20] ip address 22.1.1.5 24
Verifying the MDC configuration
# Verify that the MDCs on Switch A exist and are operating correctly.
[SwitchA] display mdc
ID         Name            Status
1          Admin           active
2          SWA-MDC1        active
3          SWA-MDC2        active
The output shows that the MDCs have been created and are operating correctly.
# Log in to SWA-MDC2.
[SwitchA] switchto mdc SWA-MDC2
<SWA-MDC2>%Mar  2 10:43:04:214 2019 SWA-MDC2 SHELL/5/SHELL_LOGIN: -MDC=3; Console logged in from con0.
# Display the interfaces assigned to SWA-MDC2.
<SWA-MDC2> display interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
InLoop0              UP   UP(s)    --
Loop0                UP   UP(s)    1.1.1.1
MGE0/0/0             DOWN DOWN     --
NULL0                UP   UP(s)    --
REG0                 UP   --       --
Vlan10               UP   UP       11.1.1.1
Vlan20               UP   UP       13.1.1.1
Vlan30               UP   UP       15.1.1.1
Speed: (a) - auto
Interface             Link Speed   Duplex Type PVID Description
XGE2/0/1              UP   1G(a)   F      A    30
XGE2/0/2              ADM  auto    F      A    1
XGE2/0/3              UP   1G(a)   F      A    10
XGE2/0/4              UP   1G(a)   F      A    20
XGE2/0/5              ADM  auto    F      A    1
XGE2/0/6              ADM  auto    F      A    1
XGE2/0/7              ADM  auto    F      A    1
XGE2/0/8              ADM  auto    F      A    1
XGE2/0/9              ADM  auto    F      A    1
XGE2/0/10             ADM  auto    F      A    1
XGE2/0/11             ADM  auto    F      A    1
XGE2/0/12             ADM  auto    F      A    1
XGE2/0/13             ADM  auto    F      A    1
XGE2/0/14             ADM  auto    F      A    1
XGE2/0/15             ADM  auto    F      A    1
XGE2/0/16             ADM  auto    F      A    1
XGE2/0/17             ADM  auto    F      A    1
XGE2/0/18             ADM  auto    F      A    1
XGE2/0/19             ADM  auto    F      A    1
XGE2/0/20             ADM  auto    F      A    1
XGE2/0/21             ADM  auto    F      A    1
XGE2/0/22             ADM  auto    F      A    1
XGE2/0/23             ADM  auto    F      A    1
XGE2/0/24             ADM  auto    F      A    1
# Use the same method to verify the MDC configuration on Switch B. (Details not shown.)
Verifying the EVPN network
# Display EVPN routing information on distributed EVPN gateway Switch C.
[SwitchC] display bgp l2vpn evpn
 Status codes: * - valid, > - best, d - dampened, h - history
               a - additional-path
 Total number of routes from all PEs: 10
 Route distinguisher: 1:1(vpna)
 Total number of routes: 6
* >i [2][0][48][a21a-36c9-0806][32][10.1.1.20]/136
                        4.4.4.4         0          100        0       i
* >i [2][0][48][a21a-39de-0907][32][10.1.2.20]/136
                        4.4.4.4         0          100        0       i
* >i [5][0][0][0.0.0.0]/80
                        5.5.5.5         0          100        0       ?
*  i                    5.5.5.5         0          100        0       ?
* >  [5][0][24][10.1.1.0]/80
                        0.0.0.0         0          100        32768   i
* >  [5][0][24][10.1.2.0]/80
 Route distinguisher: 1:10
* >  [2][0][48][a21a-2df1-0606][32][10.1.1.10]/136
                        4.4.4.4         0          100        0       i
*  i                    4.4.4.4         0          100        0       i
* >  [3][0][32][3.3.3.3]/80
* >i [3][0][32][4.4.4.4]/80
                        4.4.4.4         0          100        0       i
 Route distinguisher: 1:20
* >  [2][0][48][a21a-3300-0707][32][10.1.2.10]/136
                        4.4.4.4         0          100        0       i
                        4.4.4.4         0          100        0       i
# Verify that the VXLAN tunnel interfaces are up.
[SwitchC] display interface tunnel
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 4.4.4.4
Input: 10 packets, 980 bytes, 0 drops
Output: 19 packets, 1520 bytes, 0 drops
Tunnel2
Current state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 5.5.5.5
Output: 0 packets, 0 bytes, 0 drops...
# Verify that the VSI interfaces are up on Switch C.
[SwitchC] display interface vsi-interface
Vsi-interface1
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
Maximum transmission unit: 1444
IP packet frame type: Ethernet II, hardware address: 0001-0001-0001
IPv6 packet frame type: Ethernet II, hardware address: 0001-0001-0001
Output: 192 packets, 18816 bytes, 0 drops
Vsi-interface2
Current state: UP
Description: Vsi-interface2 Interface
IP packet frame type: Ethernet II, hardware address: 0002-0002-0002
IPv6 packet frame type: Ethernet II, hardware address: 0002-0002-0002
Output: 128 packets, 8960 bytes, 0 drops
Vsi-interface3
Current state: UP
Description: Vsi-interface3 Interface
IP packet frame type: Ethernet II, hardware address: a21a-0861-0300
IPv6 packet frame type: Ethernet II, hardware address: a21a-0861-0300
# Verify that the VXLAN tunnels have been assigned to the VXLANs, and the VSI interfaces are the gateway interfaces of their respective VXLANs.
[SwitchC] display l2vpn vsi verbose
VSI Name: Auto_L3VNI1000_3
  VSI Index               : 2
  VSI State               : Down
  Bandwidth               : -
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Statistics              : Disabled
  Gateway Interface       : VSI-interface 3
  VXLAN ID                : 1000
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : Unlimited
  MAC Table Limit         : -
  Drop Unknown            : -
  Gateway Interface       : VSI-interface 1
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood proxy
    Tunnel1              0x5000000  UP       Auto        Disabled
  ACs:
    AC                                Link ID  State       Type
    XGE1/0/1 srv1000                  0        Up          Manual
VSI Name: vpnb
  VSI Index               : 1
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Gateway Interface       : VSI-interface 2
  VXLAN ID                : 20
  Tunnels:
  ACs:
    XGE1/0/2 srv1000                  0        Up          Manual
# Verify that Switch C has created ARP entries for the VMs.
[SwitchC] display arp
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI   Interface                 Aging Type
11.1.1.1        a210-9a1c-0182 10         XGE1/0/3                  240   D
12.1.1.2        a21a-01b9-0242 20         XGE1/0/5                  240   D
10.1.1.10       a21a-2df1-0606 0          XGE1/0/1                  489   D
10.1.2.10       a21a-3300-0707 1          XGE1/0/2                  414   D
4.4.4.4         a21a-0fb2-0400 2          Tunnel1                   --    R
5.5.5.5         a21a-17fd-0500 2          Tunnel2                   --    R
# Verify that Switch C has created EVPN ARP entries for the local VMs.
[SwitchC] display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping
VPN instance: vpna                            Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0001-0001-0001  a21a-0861-0300  0           GL
10.1.1.10       a21a-2df1-0606  a21a-0861-0300  0           DL
10.1.1.20       a21a-36c9-0806  a21a-0fb2-0400  0           B
VPN instance: vpna                            Interface: Vsi-interface2
10.1.2.1        0002-0002-0002  a21a-0861-0300  1           GL
10.1.2.10       a21a-3300-0707  a21a-0861-0300  1           DL
10.1.2.20       a21a-39de-0907  a21a-0fb2-0400  1           B
<SwitchC>
# Verify that the servers can communicate with one another and can communicate with the Internet. (Details not shown.)
Verifying the multicast network
# On Switch F, display RP information in the PIM-SM domain.
[SwitchF] display pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: 225.1.1.0/24
       RP address               Priority  HoldTime  Uptime    Expires
       1.1.1.1                  192       180       00:51:45  00:02:22
Static RP information:
       RP address               ACL   Mode    Preferred
       2.2.2.2                  ----  pim-sm  No
[SwitchF] display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 1.1.1.1
       Priority: 64
       Hash mask length: 30
       Uptime: 00:11:18
[SwitchF]disp pim interface
Interface           NbrCnt HelloInt   DR-Pri     DR-Address
 Vlan10             0      30         1          10.1.4.1      (local)
 Vlan20             1      30         1          1.1.1.1
# On SWA-MDC2, display BSR information in the PIM-SM domain.
[SWA-MDC2] display pim bsr-info
 Scope: non-scoped
     State: Elected
       Priority: 64
       Uptime: 00:11:18
     Candidate BSR address: 1.1.1.1
       Priority: 64
# On SWA-MDC2, display C-RP information in the PIM-SM domain.
[SWA-MDC2] display pim c-rp
 Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4
       C-RP address             Priority  HoldTime  Uptime    Expires
       1.1.1.1 (local)          192       150       03:01:36  00:02:29
Configuration files
·          Switch A:
mdc Admin id 1
mdc SWA-MDC1 id 2
 location slot 1
 mdc start
 allocate interface Ten-GigabitEthernet1/0/1 to Ten-GigabitEthernet 1/0/24
mdc SWA-MDC2 id 3
 location slot 2
 mdc start
 allocate interface Ten-GigabitEthernet 2/0/1 to Ten-GigabitEthernet 2/0/24
·          SWA-MDC1:
 area 0.0.0.0
vlan 10
vlan 20
interface LoopBack0
 ip address 6.6.6.6 255.255.255.255
interface Vlan-interface10
 ip address 17.1.1.6 255.255.255.0
 pim sm
interface Vlan-interface20
 ip address 18.1.1.6 255.255.255.0
 pim sm
 port link-mode bridge
 port access vlan 10
 port access vlan 20
multicast routing
pim
 static-rp 2.2.2.2
·          SWA-MDC2:
 area 0.0.0.0
vlan 10
vlan 20
vlan 30
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
 ip address 11.1.1.1 255.255.255.0
 ip address 13.1.1.1 255.255.255.0
 pim sm
interface Vlan-interface30
 ip address 15.1.1.1 255.255.255.0
 pim sm
interface Ten-GigabitEthernet2/0/1
 port access vlan 30
interface Ten-GigabitEthernet2/0/3
 port access vlan 10
interface Ten-GigabitEthernet2/0/4
 port access vlan 20
bgp 100
 group evpn internal
 peer evpn connect-interface LoopBack0
 peer 2.2.2.2 connect-interface LoopBack0
  peer evpn enable
  peer 2.2.2.2 enable
multicast routing
pim
 c-bsr 1.1.1.1
 c-rp 1.1.1.1
 static-rp 2.2.2.2
·          Switch B:
mdc Admin id 1
mdc SWB-MDC1 id 2
 location slot 1
 mdc start
 allocate interface Ten-GigabitEthernet1/0/1 to Ten-GigabitEthernet1/0/24
mdc SWB-MDC2 id 3
 location slot 2
 mdc start
allocate interface Ten-GigabitEthernet2/0/1 to Ten-GigabitEthernet2/0/24
·          SWB-MDC1:
 area 0.0.0.0
vlan 10
vlan 50
interface LoopBack0
 ip address 7.7.7.7 255.255.255.255
 ip address 20.1.1.7 255.255.255.0
interface Vlan-interface50
 ip address 19.1.1.7 255.255.255.0
 port access vlan 10
 port access vlan 50
·          SWB-MDC2:
 area 0.0.0.0
vlan 10
vlan 20
vlan 40
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 14.1.1.2 255.255.255.0
 pim sm
 ip address 12.1.1.2 255.255.255.0
interface Vlan-interface40
 ip address 16.1.1.2 255.255.255.0
 pim sm
interface Ten-GigabitEthernet2/0/2
 port access vlan 40
 port access vlan 10
interface Ten-GigabitEthernet2/0/5
 port access vlan 20
bgp 100
 group evpn internal
 peer 1.1.1.1 connect-interface LoopBack0
  peer evpn enable
  peer 1.1.1.1 enable
multicast routing
pim
 static-rp 2.2.2.2
·          Switch C:
 address-family ipv4
  vpn-target 2:2 import-extcommunity
  vpn-target 2:2 export-extcommunity
 address-family evpn
  vpn-target 1:1 import-extcommunity
  vpn-target 1:1 export-extcommunity
 area 0.0.0.0
vlan 10
vlan 20
 l2vpn enable
vsi vpna
 vxlan 10
  vpn-target auto export-extcommunity
  vpn-target auto import-extcommunity
vsi vpnb
 vxlan 20
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 11.1.1.3 255.255.255.0
 ip address 12.1.1.3 255.255.255.0
  xconnect vsi vpna
  xconnect vsi vpnb
 port access vlan 10
interface Ten-GigabitEthernet1/0/4
 port access vlan 20
interface Ten-GigabitEthernet1/0/5
 port access vlan 20
interface Vsi-interface1
 mac-address 0001-0001-0001
interface Vsi-interface2
 mac-address 0002-0002-0002
interface Vsi-interface3
 l3-vni 1000
bgp 100
  peer 1.1.1.1 enable
  peer 2.2.2.2 enable
·          Switch D:
 address-family ipv4
 address-family evpn
 area 0.0.0.0
vlan 10
vlan 20
vlan 30
 l2vpn enable
vsi vpna
 vxlan 10
vsi vpnb
 vxlan 20
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 14.1.1.4 255.255.255.0
 pim sm
 ip address 13.1.1.4 255.255.255.0
 pim sm
 ip address 21.1.1.4 255.255.255.0
 pim sm
  xconnect vsi vpna
  xconnect vsi vpnb
 port access vlan 10
 port access vlan 20
 port access vlan 30
 l3-vni 1000
bgp 100
  peer 1.1.1.1 enable
  peer 2.2.2.2 enable
multicast routing
pim
 static-rp 2.2.2.2
·          Switch E:
 address-family ipv4
 address-family evpn
 area 0.0.0.0
  network 22.1.1.0 0.0.0.255
vlan 10
vlan 20
vlan 30
vlan 40
vlan 50
 l2vpn enable
interface LoopBack0
 ip address 5.5.5.5 255.255.255.255
 ip address 22.1.1.5 255.255.255.0
 ip address 18.1.1.5 255.255.255.0
 pim sm
 ip address 15.1.1.5 255.255.255.0
 pim sm
 ip address 16.1.1.5 255.255.255.0
 pim sm
 ip address 19.1.1.5 255.255.255.0
 port access vlan 30
 port access vlan 40
 port access vlan 10
interface Ten-GigabitEthernet1/0/17
 port access vlan 20
interface Ten-GigabitEthernet1/0/18
 port access vlan 50
 l3-vni 1000
bgp 100
  peer 1.1.1.1 enable
  peer 2.2.2.2 enable
   import-route static
multicast routing
pim
 static-rp 2.2.2.2
·          Switch F:
 area 0.0.0.0
vlan 10
vlan 20
interface LoopBack0
 ip address 9.9.9.9 255.255.255.255
 ip address 17.1.1.9 255.255.255.0
 pim sm
 ip address 10.1.4.1 255.255.255.0
 igmp enable
 port access vlan 20
 port access vlan 10
multicast routing
pim
 static-rp 2.2.2.2
Related documentation
·          H3C S7500E-X Switch Series EVPN Command Reference-R758X
·          H3C S7500E-X Switch Series EVPN Configuration Guide-R758X
·          H3C S7500E-X Switch Series MDC Command Reference-R758X
·          H3C S7500E-X Switch Series MDC Configuration Guide-R758X
