11-Network Management and Monitoring Configuration Examples
HomeSupportSwitchesH3C S7500E-X Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-X Switch Series Configuration Examples-R7585P05-6W10011-Network Management and Monitoring Configuration Examples
03-H3C_SNMP_Configuration_Examples
03-H3C_SNMP_Configuration_Examples 302.96 KB
H3C SNMP Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides SNMP configuration examples.
This document assumes that you have basic knowledge of SNMP.
Example: Configuring SNMPv1 or SNMPv2c
As shown in Figure 1, an IMC server acts as the NMS and the device acts as the agent. The NMS uses SNMPv1/SNMPv2c to manage the SNMP agent, and the agent automatically sends notifications to report events to the NMS.
Figure 1 Network diagram
·          The configuration procedure is the same for SNMPv1 and SNMPv2c. This example uses SNMPv2c.
·          For the NMS to manage the SNMP agent, the SNMP settings on the agent and the NMS must match.
·          The NMS software configuration varies by vendor. This example uses IMC PLAT 7.0 (E0202). For information about configuring the NMS, see the NMS manual.
Procedures
Configuring the SNMP agent
# Specify SNMPv2c, and create read-only community readtest and read and write community writetest.
<Agent> system-view
[Agent] snmp-agent sys-info version v2c
[Agent] snmp-agent community read readtest
[Agent] snmp-agent community write writetest
# Configure contact and physical location information for the agent.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable SNMP notifications and configure the agent to send SNMP notifications to the NMS at 192.168.100.4 by using community name traptest.
[Agent] snmp-agent trap enable
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname traptest
Configuring the NMS
1.        Add the device (SNMP agent) to IMC:
a.    Click the Resource tab.
b.    From the navigation tree, select Resource Management > Add Device.
c.    On the Add Device page, configure the following parameters:
-      Enter 192.168.100.68 in the Host Name/IP field.
-      Use the default values for other parameters.
Figure 2 Adding a device
2.        Configure SNMP parameters:
a.    Expand the SNMP Settings area.
b.    Click Configure.
c.    On the page that opens, configure the following parameters:
-      Select SNMPv2c from the Parameter Type list.
-      Enter readtest in the Read-Only Community String field.
-      Enter writetest in the Read-Write Community String field.
-      Click OK.
Figure 3 Configuring SNMP parameters
3.        On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 4.
Figure 4 Device added
1.        Verify that the agent sends notifications to the NMS when the link state of an interface changes:
a.    Execute the shutdown or undo shutdown command on an idle interface to shut down or bring up the interface.
b.    Click the Alarm tab.
c.    From the navigation tree, select Alarm Browse > All Alarms.
You can see the alarms in Figure 5.
Figure 5 All Alarms page
2.        Back up the agent configuration file:
b.    From the navigation tree, select Device View.
c.    On the page that opens, click the device label link Agent(192.168.100.68).
d.    On the Configuration Center menu, select Backup Configuration File.
Figure 6 Backing up the configuration file
The configuration file is backed up, as shown in Figure 7.
Figure 7 Configuration file backed up
Configuration files
 snmp-agent
 snmp-agent trap enable arp
 snmp-agent trap enable syslog
Example: Configuring SNMPv3
As shown in Figure 8, an IMC server acts as the NMS and the device acts as the agent. The NMS uses SNMPv3 to manage the SNMP agent, and the agent automatically sends notifications to report events to the NMS. The NMS and the agent use the authentication with privacy security model.
Figure 8 Network diagram
When you configure SNMPv3, follow these restrictions and guidelines:
·          SNMPv3 supports VACM and RBAC access control modes. This example provides SNMPv3 configuration procedures in both modes. See "Configuring SNMPv3 in RBAC mode on the agent" and "Configuring SNMPv3 in VACM mode on the agent".
·          For the NMS to manage the SNMP agent, make sure the SNMP settings on the agent and the NMS are the same.
·          When configuring the notification target host, use an existing SNMPv3 username as the security parameter and make sure the agent and NMS use the same security model.
Procedures
# Enable SNMPv3.
<Agent> system-view
[Agent] snmp-agent sys-info version v3
# Create user role test, and assign test read and write access to the objects under the internet subtree (OID: 1.3.6.1).
[Agent] role name test
[Agent-role-test] rule 1 permit read write oid 1.3.6.1
[Agent-role-test] quit
# Create SNMPv3 user managev3user. Assign user role test to managev3user. Set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and encryption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user user-role test simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Enable SNMP notifications.
# Configure the SNMP agent to send SNMP notifications to the NMS at 192.168.100.4 by using username managev3user.
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname managev3user v3 privacy
# Enable SNMPv3.
<Agent> system-view
# Include the mib-2 (OID 1.3.6.1) subtree in the mibtest view.
[Agent] snmp-agent mib-view included mibtest 1.3.6.1
# Create SNMPv3 group managev3group, and specify the authentication with privacy security model for the group. Assign the group read, write, and notification accesses to the mibtest view.
[Agent] snmp-agent group v3 managev3group privacy read-view mibtest write-view mibtest notify-view mibtest
# Add user managev3user to SNMPv3 group managev3group, and set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and encryption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Configure the SNMP agent to send SNMP notifications to NMS at 192.168.100.4 by using username managev3user.
Configuring the NMS
1.        Add an SNMP template:
a.    Click the System tab.
b.    From the navigation tree, select Resource Management > SNMP Template.
c.    On the SNMP Template page, click Add.
d.    On the Add SNMP Template page, configure the following parameters:
-      Enter SNMPv3 in the Name field.
-      Select SNMPv3 Priv-Aes128 Auth-Sha from the Parameter Type list.
-      Enter managev3user in the Username field.
-      Enter 123456TESTauth&! in the Authentication Password field.
-      Enter 123456TESTencr&! in the Encryption Password field.
-      Click OK.
Figure 9 Adding an SNMP template
2.        Add the device (SNMP agent) to IMC:
Figure 10 Adding a device
3.        Configure SNMP parameters:
b.    Click Configure.
c.    Select the Select an Existing Template option.
d.    Select template name SNMPv3.
e.    Click OK.
Figure 11 Selecting an existing template
4.        On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 12.
Figure 12 Device added
You can see the alarms in Figure 13.
Figure 13 All Alarms page
2.        Back up the agent configuration file on the NMS:
Figure 14 Backing up the configuration file
The configuration file is backed up, as shown in Figure 15.
Figure 15 Configuration file backed up
Configuration files
SNMPv3 configuration in RBAC mode
 snmp-agent
 snmp-agent usm-user v3 managev3user user-role test cipher authentication-mode sha $c$3$5JaJZ6gNXlyNRq2FR2ELDT3QQH1exwJRWdYYq7eLfcBewuM5ncM= privacy-mode aes128 $c$3$+bbXZS4+PnsLDyr16OogzBckaLzR6XMDwZQuLBU8RM+dpw==
role name test
 rule 1 permit read oid 1.3.6.1
SNMPv3 configuration in VACM mode
 snmp-agent
notify-view mibtest
 snmp-agent mib-view included mibtest internet
 snmp-agent usm-user v3 managev3user managev3group cipher authentication-mode sha $c$3$5JaJZ6gNXlyNRq2FR2ELDT3QQH1exwJRWdYYq7eLfcBewuM5ncM= privacy-mode aes128 $c$3$+bbXZS4+PnsLDyr16OogzBckaLzR6XMDwZQuLBU8RM+dpw==
Related documentation
·          H3C S7500E-X Switch Series Network Management and Monitoring Configuration Guide-R758X
·          H3C S7500E-X Switch Series Network Management and Monitoring Command Reference-R758X
