- 06-IP Multicast Configuration Examples
- 01-H3C_Static_Multicast_MAC_Address_Entry_Configuration_Examples
- 02-H3C_IGMP_Snooping_Configuration_Examples
- 03-H3C_IGMP_Configuration_Examples
- 04-H3C_BIDIR-PIM_Configuration_Examples
- 05-H3C_MLD_Snooping_Configuration_Exampels
- 06-H3C_IPv6_Multicast_VLAN_Configuration_Examples
- 07-H3C_Multicast_VPN_Configuration_Examples
01-H3C_Static_Multicast_MAC_Address_Entry_Configuration_Examples | 62.90 KB |
H3C Static Multicast MAC Address Entry |
Configuration Examples |
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples of static multicast MAC address entries.
This document assumes that you have basic knowledge of multicast MAC addresses.
Example: Configuring static multicast MAC address entries
As shown in Figure 1, Router A runs IGMP and acts as the IGMP querier. Switch A does not run a Layer 2 multicast protocol.
Configure Switch A so that only Host A and Host C can receive multicast data addressed to multicast group 224.1.1.1.
Analysis
Multicast MAC address entries guide Layer 2 multicast forwarding. They can be dynamically created through Layer 2 multicast protocols or manually configured by binding multicast MAC addresses and ports.
In this example, Switch A does not run a Layer 2 multicast protocol. To control destination ports of Layer 2 multicast data, configure a static multicast MAC address entry on Switch A.
The manually configured multicast MAC address in the multicast MAC address entry must be unused.
Procedures
# On Switch A, create VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 to operate in Layer 2 mode, and assign the ports to VLAN 100.
[SwitchA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[SwitchA-if-range] port link-mode bridge
[SwitchA-if-range] port access vlan 100
[SwitchA-if-range] quit
# Translate multicast IP address 224.1.1.1 to a multicast MAC address (0100-5e01-0101). (Details not shown.)
# Create a static entry for multicast MAC address 0100-5e01-0101 with Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/4 in VLAN 100 as outgoing ports.
[SwitchA] mac-address multicast 0100-5e01-0101 interface ten-gigabitethernet 1/0/2 ten-gigabitethernet 1/0/4 vlan 100
# Display static multicast MAC address entries in VLAN 100 on Switch A.
[SwitchA] display mac-address multicast vlan 100
MAC Address VLAN ID State Port/NickName Aging
0100-5e01-0101 100 Multicast XGE1/0/2 N
XGE1/0/4
The output shows that Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/4 have become outgoing ports of multicast MAC group 0100-5e01-0101.
Configuration files
vlan 100
interface Ten-GigabitEthernet1/0/4
mac-address multicast 0100-5e01-0101 interface Ten-GigabitEthernet1/0/2 Ten-GigabitEthernet1/0/4 vlan 100
Related documentation
· H3C S7500E-X Switch Series IP Multicast Command Reference-R758X
· H3C S7500E-X Switch Series IP Multicast Configuration Guide-R758X
