09-Security Configuration Examples
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7585P05-6W10009-Security Configuration Examples
01-H3C_AAA_Configuration_Examples
01-H3C_AAA_Configuration_Examples 351.02 KB
H3C AAA Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides AAA configuration examples for Telnet and SSH users.
This document assumes that you have basic knowledge of AAA.
Example: Configuring HWTACACS authentication and authorization for Telnet users
As shown in Figure 1, configure the device to meet the following requirements:
·          The HWTACACS server is used to provide authentication and authorization services for Telnet users.
·          The authenticated users are permitted to execute the display commands of all system features and resources.
Add a user account with username user@bbb and password aabbcc on the HWTACACS server.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·          Configure the Telnet username and password on the HWTACACS server to identify valid users.
·          For Telnet users to perform AAA, set the authentication mode to scheme on VTY user lines.
·          Configure the same shared key on the device and the HWTACACS server to secure HWTACACS communication. When the shared key is configured, the device and the HWTACACS server transfer passwords safely and the device can verify the integrity of each HWTACACS response.
·          Configure HWTACACS authentication and authorization by performing the following tasks on the device:
¡  Create an HWTACACS scheme.
¡  Specify the authentication and authorization servers.
¡  Apply the HWTACACS scheme to the ISP domain to which the Telnet users belong on the device.
·          Configure the HWTACACS server to assign the user role network-operator to the users, so the users can use all display commands.
Procedures
Configuring the HWTACACS server
In this example, the server runs ACS 4.0.
Adding a user
1.        In the navigation tree, click User Setup.
2.        Enter user@bbb in the User field and click Add/Edit, as shown in Figure 2.
Figure 2 Adding a user
Configuring the user
1.        On the User Setup page, configure the following parameters, as shown in Figure 3:
¡  Enter aabbcc in the Password and Confirm Password fields.
¡  Assign the user to user group Group 1.
Figure 3 Configuring the user password
2.        Click Submit.
Configuring the network settings
1.        In the navigation tree, click Network Configuration.
2.        On the Add AAA Client page, configure the following parameters, as shown in Figure 4:
¡  Enter an AAA client hostname in the AAA Client Hostname field. This example uses Device.
¡  Enter 10.1.1.2 in the AAA Client IP Address field.
The IP address is the source IP address for outgoing HWTACACS packets on the device.
¡  Enter expert in the Key field.
The key configured here is the same as the authentication, authorization, and accounting keys configured on the device for secure HWTACACS communication.
¡  Select TACACS+ (Cisco IOS) from the Authenticate Using list.
Figure 4 Configuring the network settings
3.        Click Submit + Apply.
Configuring the user group
1.        In the navigation tree, click Group Setup.
2.        Select 1: Group 1 (29 users) from the Group list and click Edit Settings, as shown in Figure 5.
Figure 5 Selecting a user group
3.        On the TACACS+ Settings page, configure the following parameters, as shown in Figure 6:
¡  Select Shell(exec), which enables command execution for all users in the group.
¡  Select Custom attributes, and enter roles=\"network-operator\" in the Custom attributes field.
¡  Configure other settings as needed.
Figure 6 Configuring the user group
4.        Click Submit.
Configuring the device
# Create VLAN 2 and assign Ten-GigabitEthernet 2/0/2 to the VLAN.
[Device] vlan 2
[Device-vlan2] port ten-gigabitethernet 2/0/2
[Device-vlan2] quit
# Assign an IP address to VLAN-interface 2.
[Device] interface vlan-interface 2
[Device-Vlan-interface2] ip address 192.168.57.12 255.255.255.0
[Device-Vlan-interface2] quit
# Create VLAN 3 and assign Ten-GigabitEthernet 2/0/1 to the VLAN.
[Device] vlan 3
[Device-vlan3] port ten-gigabitethernet 2/0/1
[Device-vlan3] quit
# Assign an IP address to VLAN-interface 3. The device will use this IP address as the source IP address for outgoing HWTACACS packets.
[Device] interface vlan-interface 3
[Device-Vlan-interface3] ip address 10.1.1.2 255.255.255.0
[Device-Vlan-interface3] quit
# Enable the Telnet server feature.
[Device] telnet server enable
# Enable scheme authentication on VTY user lines 0 through 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
[Device-line-vty0-63] quit
# Create an HWTACACS scheme named hwtac.
[Device] hwtacacs scheme hwtac
# Specify the primary HWTACACS server with IP address 10.1.1.1 and port number 49.
[Device-hwtacacs-hwtac] primary authentication 10.1.1.1 49
[Device-hwtacacs-hwtac] primary authorization 10.1.1.1 49
[Device-hwtacacs-hwtac] primary accounting 10.1.1.1 49
# Specify the shared key as expert for secure HWTACACS communication between the device and HWTACACS server.
[Device-hwtacacs-hwtac] key authentication simple expert
[Device-hwtacacs-hwtac] key authorization simple expert
[Device-hwtacacs-hwtac] key accounting simple expert
[Device-hwtacacs-hwtac] quit
# Create an ISP domain named bbb, and specify the domain to use HWTACACS scheme hwtac as the AAA methods of login users.
[Device] domain bbb
[Device-isp-bbb] authentication login hwtacacs-scheme hwtac
[Device-isp-bbb] authorization login hwtacacs-scheme hwtac
[Device-isp-bbb] accounting login hwtacacs-scheme hwtac
[Device-isp-bbb] quit
# Telnet to the device, and enter username user@bbb and password aabbcc. The user logs in to the device. (Details not shown.)
# Verify that the user can use the display commands of all system features and resources. (Details not shown.)
Configuration files
vlan 2 to 3
interface Vlan-interface2
interface Vlan-interface3
interface Ten-GigabitEthernet2/0/2
 port link-mode bridge
 port access vlan 2
interface Ten-GigabitEthernet2/0/1
 port access vlan 3
line vty 0 63
 user-role network-operator
 key authentication cipher $c$3$X3oR/wjLFjDqIyjdAmvjwAhiuqewGABglQ==
 key authorization cipher $c$3$5pmuq0RJ9UWMWDkRNNERX6HFM0aRv5txFg==
 key accounting cipher $c$3$FSdSiBY1u+ZNkAYYlPw9YkGxJA4iR8MDjw==
 domain bbb
Example: Configuring RADIUS authentication and authorization for SSH users
As shown in Figure 7, configure the device to meet the following requirements:
·          The RADIUS servers are used to provide authentication and authorization services for SSH users. One server acts as the primary server and the other acts as the secondary server.
·          Domain names are included in the usernames sent to the RADIUS servers.
·          The authenticated users are permitted to use the display commands of all system features and resources.
The RADIUS servers run IMC. Add a user account with username hello@bbb and password aabbcc on each RADIUS server.
Figure 7 Network diagram
Analysis
·          Configure the SSH username and password on the primary and secondary RADIUS servers to identify valid users.
·          For SSH users to perform AAA, set the authentication mode to scheme on VTY user lines.
·          Configure the same shared key on the device and the RADIUS servers to secure RADIUS communication. When the shared key is configured, the device and the RADIUS servers transfer passwords safely and the device can verify the integrity of each RADIUS response.
·          Configure RADIUS authentication and authorization by performing the following tasks on the device:
¡  Create a RADIUS scheme.
¡  Specify the primary and secondary servers for authentication and authorization.
¡  Apply the RADIUS scheme to the ISP domain to which the SSH users belong.
·          Configure the RADIUS servers to assign the user role network-operator to the users, so the users can use all display commands.
When you configure RADIUS authentication and authorization for SSH users, follow these restrictions and guidelines:
·          The Stelnet server supports only 256-bit and 384-bit ECDSA key pairs.
·          Local DSA, ECDSA, and RSA key pairs for SSH use default names. You cannot assign names to the key pairs.
Procedures
Configuring RADIUS servers
In this example, RADIUS servers run IMC PLAT 7.0 (E0102) and IMC UAM 7.0 (E0201). This example describes the configuration of the primary RADIUS server. Configure the secondary RADIUS server in the same way the primary RADIUS server is configured.
Adding the device to IMC as an access device
1.        Click the User tab.
2.        From the navigation tree, select User Access Policy > Access Device Management > Access Device.
The access device list is displayed.
3.        Click Add.
4.        On the Add Access Device page, configure the following parameters, as shown in Figure 8:
¡  Enter 1812 and 1813 in the Authentication Port and Accounting Port fields, respectively.
¡  Enter expert in the Shared Key and Confirm Shared Key fields.
¡  Select Device Management Service from the Service Type list.
¡  Select H3C(General) from the Access Device Type list.
¡  Use the default values for other parameters in the Access Configuration area.
¡  In the Device List area, click Select or Add Manually to add the device (10.1.1.2) to IMC as an access device.
Figure 8 Adding an access device
5.        Click OK.
Adding a device management user
2.        From the navigation tree, select Access User > Device User.
The device management user list is displayed.
3.        Click Add.
4.        On the Add Device User page, configure the following parameters, as shown in Figure 9:
¡  Enter hello@bbb in the Account Name field.
¡  Enter aabbcc in the User Password and Confirm Password fields.
¡  Select SSH from the Service Type list.
¡  Enter network-operator in the Role Name field.
The network-operator user role has access to the display commands of all system features and resources.
¡  In the IP Address List of Managed Devices area, click Add to specify an IP segment (from 10.1.1.0 to 10.1.1.255) for management. The IP segment must contain the IP address of the access device.
Figure 9 Adding a device management user
5.        Click OK.
[Device] vlan 2
[Device-vlan2] quit
[Device-Vlan-interface2] ip address 192.168.1.70 255.255.255.0
[Device] vlan 3
[Device-vlan3] quit
# Create local RSA key pairs with default names.
[Device] public-key local create rsa
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Create a local DSA key pair with the default name.
[Device] public-key local create dsa
Generating Keys...
# Create a local 256-bit ECDSA key pair with the default name.
[Device] public-key local create ecdsa secp256r1
Generating Keys...
# Create a local 384-bit ECDSA key pair with the default name.
 [Device] public-key local create ecdsa secp384r1
Generating Keys...
# Enable the Stelnet server feature.
[Device] ssh server enable
# Create a RADIUS scheme named rad.
[Device] radius scheme rad
# Specify the primary authentication RADIUS server with IP address 10.1.1.1 and port number 1812.
[Device-radius-rad] primary authentication 10.1.1.1 1812
# Specify the secondary authentication RADIUS server with IP address 10.1.1.11 and port number 1812.
[Device-radius-rad] secondary authentication 10.1.1.11 1812
# Specify the primary accounting RADIUS server with IP address 10.1.1.1 and port number 1813.
[Device-radius-rad] primary accounting 10.1.1.1 1813
# Specify the secondary accounting RADIUS server with IP address 10.1.1.11 and port number 1813.
[Device-radius-rad] secondary accounting 10.1.1.11 1813
# Set the authentication and accounting shared keys to expert in plain text for secure communication between the device and the RADIUS server.
[Device-radius-rad] key authentication simple expert
[Device-radius-rad] key accounting simple expert
# Include domain names in the usernames sent to the RADIUS server.
[Device-radius-rad] user-name-format with-domain
[Device-radius-rad] quit
# Create an ISP domain named bbb, and configure the ISP domain to use RADIUS scheme rad as the AAA methods of login users.
[Device] domain bbb
[Device-isp-bbb] authentication login radius-scheme rad
[Device-isp-bbb] authorization login radius-scheme rad
[Device-isp-bbb] accounting login radius-scheme rad
# Initiate an SSH connection to the device, and enter username hello@bbb and password aabbcc. The user logs in to the device. (Details not shown.)
# Display RADIUS scheme configuration.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: rad
  Index: 0
  Primary authentication server:
    IP   : 10.1.1.1                                 Port: 1812
    VPN  : Not configured
    State: Active
    Test profile: Not configured
    Weight: 0
  Primary accounting server:
    IP   : 10.1.1.1                                 Port: 1813
    State: Active
    Weight: 0
  Second authentication server:
    IP   : 10.1.1.11                                Port: 1812
    State: Active
    Weight: 0
  Second accounting server:
    IP   : 10.1.1.11                                Port: 1813
    State: Active
    Weight: 0
  Accounting-On function                     : Disabled
    extended function                        : Disabled
    retransmission times                     : 50
    retransmission interval(seconds)         : 3
  Timeout Interval(seconds)                  : 3
  Retransmission Times                       : 3
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(seconds)      : 720
  Stop-accounting packets buffering          : Enabled
    Retransmission times                     : 500
  NAS IP Address                             : Not configured
  User Name Format                           : with-domain
  Data flow unit                             : Byte
  Packet unit                                : One
  Attribute 15 check-mode                    : Strict
  Attribute 25                               : Standard
  Attribute Remanent-Volume unit             : Kilo
  server-load-sharing                        : Disabled
  Attribute 31 MAC format                    : HH-HH-HH-HH-HH-HH
The output shows that the primary RADIUS server is in Active state.
# Disconnect the device from the primary RADIUS server. (Details not shown.)
# Verify that the primary RADIUS server has changed to the Block state in the RADIUS scheme. (Details not shown.)
Configuration files
vlan 2 to 3
 port access vlan 2
 port access vlan 3
line vty 0 63
 ssh server enable
radius scheme rad
 key authentication cipher $c$3$GBZ1jhslcGwSOpSejsESMnOr8Gb8SIT5ew==
 key accounting cipher $c$3$nGb/DWK8pxbHaLXQVc+xsmbUr1etIZVd7Q==
domain bbb
Related documentation
·          H3C S7500E Switch Series Security Command Reference-R758X
·          H3C S7500E Switch Series Security Configuration Guide-R758X
