12-High Availability Configuration Examples
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-X Routers Configuration Examples-R7951P01-6W10012-High Availability Configuration Examples
03-H3C_VRRP_Configuration_Examples
03-H3C_VRRP_Configuration_Examples 191.29 KB
H3C VRRP Configuration Examples
Software version: Release 7951P01
Document version: 6W100-20200625
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides VRRP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of VRRP and IPsec.
Example: Configuring a single VRRP group
As shown in Figure 1, configure a VRRP group on Device A and Device B as the gateway for Host A to meet the following requirements:
·     Device A operates as the master to forward packets from Host A to the external network.
·     If Device A or its uplink interface fails, Host A can access the external network through Device B.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     For Device A to become the master when it recovers from a failure, configure the preemptive mode for the VRRP group.
·     For Device A to decrease its priority and become a backup when its uplink interface fails, configure VRRP tracking on Device A.
·     To avoid frequent role change in the VRRP group, set a preemption delay.
When you configure a single VRRP group, follow these restrictions and guidelines:
·     The virtual IP address of a VRRP group cannot be any of the following addresses:
¡     All-zero address (0.0.0.0).
¡     Broadcast address (255.255.255.255).
¡     Loopback address.
¡     IP address of other than Class A, Class B, and Class C.
¡     Invalid IP address (for example, 0.0.0.1).
·     For Host A to access the external network, make sure the following IP addresses are on the same subnet:
¡     The virtual IP address of the VRRP group.
¡     The downlink interface IP addresses of the VRRP group members.
·     IPv4 VRRP can use VRRPv2 or VRRPv3 (default version). For a VRRP group to operate correctly, make sure the VRRP versions on all devices in the VRRP group are the same.
·     Removal of the VRRP group on the IP address owner causes IP address collision. To avoid a collision, change the IP address of the interface on the IP address owner before you remove the VRRP group from the interface.
·     Configure the same virtual IP addresses for each device in the VRRP group.
·     Make sure the decreased priority of the master is lower than the priority of all the other devices in the VRRP group. Another device in the group can then be elected as the master.
Procedures
Configuring Device A
# Assign an IP address to Ten-GigabitEthernet 3/0/1.
[DeviceA] interface ten-gigabitethernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] ip address 192.168.0.2 24
# Create VRRP group 1, and set its virtual IP address to 192.168.0.1.
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 192.168.0.1
# Set the priority of Device A to 110 in VRRP group 1. Device A has a higher priority than Device B in VRRP group 1, so Device A can become the master.
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 priority 110
# Configure Device A to operate in preemptive mode, and set the preemption delay to 500 centiseconds.
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 preempt-mode delay 500
[DeviceA-Ten-GigabitEthernet3/0/1] quit
# Create track entry 1 to monitor the link status of the uplink interface Ten-GigabitEthernet 3/0/2.
[DeviceA] track 1 interface ten-gigabitethernet 3/0/2
# Associate VRRP group 1 with track entry 1 to decrease the weight of Device A by 50 when the track entry transits to Negative.
[DeviceA] interface ten-gigabitEthernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 priority reduced 50
Configuring Device B
[DeviceB] interface ten-gigabitethernet 3/0/1
[DeviceB-Ten-GigabitEthernet3/0/1] ip address 192.168.0.3 24
[DeviceB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 192.168.0.1
# Set the priority of Device B to 100 in VRRP group 1.
[DeviceB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 priority 100
# Configure Device B to operate in preemptive mode, and set the preemption delay to 500 centiseconds.
[DeviceB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 preempt-mode delay 500
[DeviceB-Ten-GigabitEthernet3/0/1] quit
1.     Verify that Host A can ping Host B. (Details not shown.)
2.     Verify that Device A is operating as the master in VRRP group 1 to forward packets from Host A to Host B.
# Display detailed information about VRRP group 1 on Device A.
[DeviceA] display vrrp verbose
IPv4 virtual router information:
 Running mode : Standard
   Interface Ten-GigabitEthernet3/0/1
     VRID             : 1                    Adver timer  : 100 centiseconds
     Admin status     : Up                   State        : Master
     Config pri       : 110                  Running pri  : 110
     Preempt mode     : Yes                  Delay time   : 500 centiseconds
     Auth type        : None
     Virtual IP       : 192.168.0.1
     Virtual MAC      : 0000-5e00-0101
     Master IP        : 192.168.0.2
   VRRP track information:
     Track object   : 1                   State : Positive   Pri reduced : 50
# Display detailed information about VRRP group 1 on Device B.
[DeviceB] display vrrp verbose
     Admin status     : Up                   State        : Backup
     Config pri       : 100                  Running pri  : 100
     Become master    : 412 milliseconds left
     Auth type        : None
3.     Disconnect the link between Host A and Device A, and verify that Host A can still ping Host B. (Details not shown.)
4.     Verify that Device B takes over to forward packets from Host A to Host B when Device A fails.
     Auth type        : None
     Master IP        : 192.168.0.3
5.     Verify that Device A becomes the master to forward packets from Host A to Host B after Device A recovers.
     Auth type        : None
Configuration files
·     Device A:
interface Ten-GigabitEthernet3/0/1
 port link-mode route
 ip address 192.168.0.2 255.255.255.0
·     Device B:
 ip address 192.168.0.3 255.255.255.0
Example: Configuring multiple VRRP groups
As shown in Figure 2, configure two VRRP groups on Device A and Device B as gateways for internal hosts to meet the following requirements:
·     Device A operates as the master of VRRP group 1 to forward packets from Area A, and Device B operates as the master of VRRP group 2 to forward packets from Area B. When one of the devices fails, the other device provides gateway service for both areas.
·     If the uplink interface of one device fails, hosts can access the external network through the other device.
Figure 2 Network diagram
Analysis
When you configure multiple VRRP groups, follow these restrictions and guidelines:
¡     Loopback address.
·     Make sure the following configurations are the same on the members of a VRRP group:
¡     Number of virtual IP addresses.
¡     Virtual IP addresses.
¡     Advertisement interval.
Procedures
[DeviceA-Ten-GigabitEthernet3/0/1] ip address 10.0.0.2 24
# Assign IP addresses to other interfaces of Device A. (Details not shown.)
# Create VRRP group 1, and set its virtual IP address to 10.0.0.1.
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.0.0.1
# Set the priority of Device A to 120 in VRRP group 1. Device A has a higher priority than Device B in VRRP group 1, so Device A can become the master.
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 priority 120
# Create VRRP group 2, and set its virtual IP address to 11.0.0.1.
[DeviceA] interface ten-gigabitethernet 3/0/3
[DeviceA-Ten-GigabitEthernet3/0/3] vrrp vrid 2 virtual-ip 11.0.0.1
[DeviceA-Ten-GigabitEthernet3/0/3] vrrp vrid 2 preempt-mode delay 500
[DeviceA-Ten-GigabitEthernet3/0/3] quit
[DeviceB] interface ten-gigabitEthernet 3/0/1
[DeviceB-Ten-GigabitEthernet3/0/1] ip address 10.0.0.3 24
# Assign IP addresses to other VLAN interfaces of Device B. (Details not shown.)
[DeviceB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.0.0.1
[DeviceB] interface ten-gigabitethernet 3/0/3
[DeviceB-Ten-GigabitEthernet3/0/3] vrrp vrid 2 virtual-ip 11.0.0.1
# Set the priority of Device B to 120 in VRRP group 2. Device B has a higher priority than Device A in VRRP group 2, so Device B can become the master.
[DeviceB-Ten-GigabitEthernet3/0/3] vrrp vrid 2 priority 120
[DeviceB-Ten-GigabitEthernet3/0/3] vrrp vrid 2 preempt-mode delay 500
[DeviceB-Ten-GigabitEthernet3/0/3] quit
# Create track entry 2 to monitor the link status of the uplink interface Ten-GigabitEthernet 3/0/2.
[DeviceB] track 2 interface ten-gigabitethernet 3/0/2
# Associate VRRP group 2 with track entry 2 to decrease the weight of Device A by 50 when the track entry transits to Negative.
[DeviceB] interface ten-gigabitEthernet 3/0/3
[DeviceB-Ten-GigabitEthernet3/0/3] vrrp vrid 2 track 2 priority reduced 50
1.     Verify that the hosts in Area A and Area B can ping the external network.
# Ping 100.0.0.1 from Host A in Area A.
<host A> ping 100.0.0.1
PING 100.0.0.1 (100.0.0.1): 56 data bytes
56 bytes from 100.0.0.1: seq=0 ttl=128 time=22.43 ms
56 bytes from 100.0.0.1: seq=1 ttl=128 time=7.17 ms
56 bytes from 100.0.0.1: seq=2 ttl=128 time=8.91 ms
56 bytes from 100.0.0.1: seq=3 ttl=128 time=7.45 ms
56 bytes from 100.0.0.1: seq=4 ttl=128 time=9.11 ms
--- 100.0.0.1 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 7.17/11.01/22.43 ms
# Ping 100.1.0.1 from Host C in Area B.
<host C> ping 100.1.0.1
PING 100.1.0.1 (100.1.0.1): 56 data bytes
56 bytes from 100.1.0.1: seq=0 ttl=128 time=22.43 ms
56 bytes from 100.1.0.1: seq=1 ttl=128 time=7.17 ms
56 bytes from 100.1.0.1: seq=2 ttl=128 time=8.91 ms
56 bytes from 100.1.0.1: seq=3 ttl=128 time=7.45 ms
56 bytes from 100.1.0.1: seq=4 ttl=128 time=9.11 ms
--- 100.1.0.1 ping statistics ---
2.     Verify that Device A is operating as the master in VRRP group 1 and the backup in VRRP group 2. Device B is operating as the backup in VRRP group 1 and the master in VRRP group 2.
# Display detailed information about the VRRP groups on Device A.
     VRID             : 1                    Adver Timer  : 100 centiseconds
     Config pri       : 120                  Running pri  : 120
     Auth type        : None
     Virtual IP       : 10.0.0.1
     Master IP        : 10.0.0.2
   Interface Ten-GigabitEthernet3/0/3
     VRID             : 2                    Adver timer  : 100 centiseconds
     Auth type        : None
     Become master    : 3550 milliseconds left
     Virtual IP       : 11.0.0.1
     Master IP        : 11.0.0.3
# Display detailed information about the VRRP groups on Device B.
     Auth type        : None
     Become master    : 3500 milliseconds left
     Auth type        : None
     Virtual MAC      : 0000-5e00-0102
     Track object   : 2                   State : Positive   Pri reduced : 50
3.     Verify that Device B becomes the master in VRRP group 1 when Device A fails.
     Auth type        : None
     Master IP        : 10.0.0.3
     Auth type        : None
4.     Verify that Device A becomes the master in VRRP group 1 after it recovers.
     Auth type        : None
     Auth type        : None
Configuration files
·     Device A:
 ip address 10.0.0.2 255.255.255.0
interface Ten-GigabitEthernet3/0/2
 ip address 100.0.0.2 255.255.255.0
interface Ten-GigabitEthernet3/0/3
 ip address 11.0.0.2 255.255.255.0
·     Device B:
 ip address 10.0.0.3 255.255.255.0
 ip address 100.1.0.2 255.255.255.0
 ip address 11.0.0.3 255.255.255.0
Example: Configuring VRRP load balancing
As shown in Figure 3, configure a load-balanced VRRP group on Device A, Device B, and Device C as the gateway for the hosts to meet the following requirements:
·     Packets from the hosts are load balanced among the devices.
·     If one device fails, hosts can access the external network through the other devices.
Figure 3 Network diagram
Analysis
·     For traffic to be switched to the other two devices when the uplink interface of one device fails, configure VF tracking on Device A, Device B, and Device C. When the uplink interface of one device fails, the weights of the VFs (including the AVF) on the device decrease by the specified value.
·     For the failed device to become the master when it recovers, configure the preemptive mode for the VRRP group.
When you configure VRRP load balancing, follow these restrictions and guidelines:
¡     Loopback address.
·     For the hosts to access the external network, make sure the following IP addresses are on the same subnet:
·     In load balancing mode, the virtual IP address of a VRRP group cannot be the IP address of any interface in the VRRP group. Otherwise, VRRP load balancing cannot operate correctly.
·     If the uplink interface of the VF owner fails, an LVF must take over as the AVF. The switchover occurs when the weight of the VF owner drops below the lower limit of failure. This requires the reduced weight for the VF owner to be higher than 245.
Procedures
1.     Configure the interfaces:
[DeviceA-Ten-GigabitEthernet3/0/1] ip address 10.1.1.2 24
2.     Configure VRRP:
# Configure VRRP to operate in load balancing mode.
[DeviceA] vrrp mode load-balance
# Create VRRP group 1, and set its virtual IP address to 10.1.1.1.
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.1.1.1
# Set the priority of Device A to 120 in VRRP group 1. Device A has the highest priority in VRRP group 1, so Device A can become the master.
3.     Configure Track:
# Create track entry 1 to monitor the link status of the uplink interface Ten-GigabitEthernet 3/0/2. If the uplink interface fails, the track entry transits to Negative.
# Configure the VFs in VRRP group 1 to monitor track entry 1, and decrease their weights by 250 when the track entry transits to Negative.
[DeviceA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 weight reduced 250
[DeviceB-Ten-GigabitEthernet3/0/1] ip address 10.1.1.3 24
2.     Configure VRRP:
[DeviceB] vrrp mode load-balance
[DeviceB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.1.1.1
# Set the priority of Device B to 110 in VRRP group 1. Device B has a higher priority than Device C in VRRP group 1, so Device B can become the master when Device A fails.
[DeviceB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 priority 110
3.     Configure Track:
# Create track entry 1 to monitor the link status of the uplink interface Ten-GigabitEthernet3 /0/2. When the uplink interface fails, the track entry transits to Negative.
[DeviceB] track 1 interface ten-gigabitethernet 3/0/2
[DeviceB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 weight reduced 250
Configuring Device C
<DeviceC> system-view
[DeviceC] interface ten-gigabitEthernet 3/0/1
[DeviceC-Ten-GigabitEthernet3/0/1] ip address 10.1.1.4 24
[DeviceC-Ten-GigabitEthernet3/0/1] quit
2.     Configure VRRP:
[DeviceC] vrrp mode load-balance
[DeviceC] interface ten-gigabitethernet 3/0/1
[DeviceC-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.1.1.1
# Configure Device C to operate in preemptive mode, and set the preemption delay to 500 centiseconds.
[DeviceC-Ten-GigabitEthernet3/0/1] vrrp vrid 1 preempt-mode delay 500
3.     Configure Track:
# Create track entry 1 to monitor the link status of the uplink interface Ten-GigabitEthernet 3/0/2. When the uplink interface fails, the track entry transits to Negative.
[DeviceC] track 1 interface ten-gigabitethernet 3/0/2
[DeviceC-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 weight reduced 250
1.     Verify that Host A can ping the external network. (Details not shown.)
2.     Verify that Device A is operating as the master and Device B and Device C as the backups in VRRP group 1. Each of the three devices has one AVF and two LVFs.
IPv4 virtual device information:
 Running mode      : Load balance
     Auth type        : None
     Virtual IP       : 10.1.1.1
     Member IP list   : 10.1.1.2 (Local, Master)
                        10.1.1.3 (Backup)
                        10.1.1.4 (Backup)
   Forwarder information: 3 Forwarders 1 Active
     Config weight  : 255
     Running weight : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Owner)
     Owner ID       : 0000-5e01-1101
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-0012 (Learnt)
     Owner ID       : 0000-5e01-1103
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Listening
     Virtual MAC    : 000f-e2ff-0013 (Learnt)
     Owner ID       : 0000-5e01-1105
     Priority       : 127
     Active         : 10.1.1.4
   Forwarder weight track information:
     Track object   : 1          State : Positive   Weight reduced : 250
     Preempt node     : Yes                  Delay time   : 500 centiseconds
     Auth type        : None
     Member IP list   : 10.1.1.3 (Local, Backup)
                        10.1.1.2 (Master)
                        10.1.1.4 (Backup)
     Config weight  : 255
    Forwarder 01
     State          : Listening
     Virtual MAC    : 000f-e2ff-0011 (Learnt)
     Priority       : 127
     Active         : 10.1.1.2
    Forwarder 02
     State          : Active
     Virtual MAC    : 000f-e2ff-0012 (Owner)
     Priority       : 255
     Active         : local
    Forwarder 03
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.4
# Display detailed information about VRRP group 1 on Device C.
[DeviceC] display vrrp verbose
     Auth type        : None
     Member IP list   : 10.1.1.4 (Local, Backup)
                        10.1.1.2 (Master)
                        10.1.1.3 (Backup)
     Config weight  : 255
    Forwarder 01
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.2
    Forwarder 02
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Virtual MAC    : 000f-e2ff-0013 (Owner)
     Priority       : 255
     Active         : local
3.     Verify that AVF switchover can be performed when the uplink interface of Device A fails.
     Auth type        : None
                        10.1.1.3 (Backup)
                        10.1.1.4 (Backup)
   Forwarder Information: 3 Forwarders 0 Active
     Config weight  : 255
     Running weight : 5
    Forwarder 01
     State          : Initialize
     Priority       : 0
     Active         : 10.1.1.4
    Forwarder 02
     State          : Initialize
     Priority       : 0
     Active         : 10.1.1.3
    Forwarder 03
     State          : Initialize
     Priority       : 0
     Active         : 10.1.1.4
     Track object   : 1          State : Negative   Weight reduced : 250
     Auth type      : None
                      10.1.1.2 (Master)
                      10.1.1.3 (Backup)
   Forwarder information: 3 Forwarders 2 Active
     Config weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Take Over)
     Priority       : 85
     Active         : local
     Redirect time  : 93 seconds
     Time-out time  : 1293 seconds
    Forwarder 02
     State          : Listening
     Priority       : 85
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Priority       : 255
     Active         : local
The output shows that when the uplink interface of Device A fails, the weights of the VFs on Device A drop below the lower limit of failure. All VFs on Device A transit to Initialized state and cannot forward traffic. The VF for MAC address 000f-e2ff-0011 on Device C becomes the AVF to forward traffic.
4.     #Verify that the VF for virtual MAC address 000f-e2ff-0011 is removed from Device C when the timeout timer (about 1800 seconds) expires. The VF no longer forwards the packets destined for the MAC address.
     Auth type        : None
                        10.1.1.2 (Master)
                        10.1.1.3 (Backup)
   Forwarder information: 2 Forwarders 1 Active
     Config weight  : 255
    Forwarder 02
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Priority       : 255
     Active         : local
5.     Verify that Device B has a higher priority than Device C and becomes the master when Device A fails.
 IPv4 standby information:
     Run mode       : Load balance
     Run method     : Virtual MAC
    VRID              : 1                    Adver timer  : 1 centiseconds
     Auth type        : None
     Member IP list   : 10.1.1.3 (Local, Master)
                        10.1.1.4 (Backup)
     Config weight  : 255
    Forwarder 02
     State          : Active
     Priority       : 255
     Active         : local
    Forwarder 03
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.4
Configuration files
·     Device A:
track 1 interface Ten-GigabitEthernet3/0/2
·     Device B:
 ip address 10.1.1.3 255.255.255.0
·     Device C:
 ip address 10.1.1.4 255.255.255.0
Related documentation
·     H3C SR8800-X Routers High Availability Command Reference-R7951P01
·     H3C SR8800-X Routers High Availability Configuration Guide-R7951P01
·     H3C SR8800-X Routers Layer 2—LAN Switching Command Reference-R7951P01
·     H3C SR8800-X Routers Layer 2—LAN Switching Configuration Guide-R7951P01
