01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command References(V7)-6W40001-Fundamentals Command Reference
09-Automatic configuration commands
09-Automatic configuration commands 37.54 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware
Command compatibility
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3
No
F100-A-G3, F100-C-G3, F100-E-G3, F100-M-G3, F100-S-G3
Yes
F1000-E-VG, F1000-S-VG
Yes
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2
Yes
F100-A-G2, F100-C-G2, F100-E-G2, F100-M-G2, F100-S-G2
Yes
F1000-C-EI, F100-A-EI, F100-A-SI, F100-C-EI, F100-E-EI
Yes
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet
Yes
F1000-C8180, F1000-C8170, F1000-C8160, F1000-C8150, F1000-C8130, F1000-C8120, F1000-C8110
Yes
F100-C-A6, F100-C-A5, F100-C-A3
Yes
F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W
Yes
F1000-C-HI, F100-A-HI, F100-C-HI, F100-S-HI
Yes
F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI
Yes
LSPM6FWD8, LSQM2FWDSC8
No
USB-based automatic configuration is enabled.
context-admin
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
