- 10-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Port security commands
- 06-Password control commands
- 07-Keychain commands
- 08-Public key management commands
- 09-PKI commands
- 10-IPsec commands
- 11-SSH commands
- 12-SSL commands
- 13-Attack detection and prevention commands
- 14-TCP attack prevention commands
- 15-IP source guard commands
- 16-ARP attack protection commands
- 17-ND attack defense commands
- 18-uRPF commands
- 19-MFF commands
- 20-FIPS commands
- 21-MACsec commands
- 22-802.1X client commands
- 23-Web authentication commands
- 24-Object group commands
04-Portal commands | 391.89 KB |
display portal mac-trigger-server
display portal packet statistics
ip (portal authentication server view)
port (MAC binding server view)
port (portal authentication server view)
portal { bas-ip | bas-ipv6 } (interface view)
portal { ipv4-max-user | ipv6-max-user } (interface view)
portal apply mac-trigger-server
portal apply web-server (interface view)
portal authorization strict-checking
portal domain (interface view)
portal enable (interface view)
portal free-all except destination
portal ipv6 free-all except destination
portal user-dhcp-only (interface view)
portal user-rule assign-check enable
reset portal packet statistics
server-detect (portal authentication server view)
server-detect (portal Web server view)
server-type (portal authentication/Web server view)
server-type (MAC binding server view)
Portal commands
aging-time
Use aging-time to set the aging time for MAC-trigger entries.
Use undo aging-time to restore the default.
aging-time seconds
undo aging-time
The aging time for MAC-trigger entries is 300 seconds.
seconds: Specifies the aging time for MAC-trigger entries. The value range is 60 to 7200 seconds.
With MAC-based quick portal authentication enabled, the device generates a MAC-trigger entry for a user when the device detects traffic from the user for the first time. The MAC-trigger entry records the following information:
· MAC address of the user
· Interface index
· VLAN ID
· Traffic statistics
· Aging timer
When the aging time expires, the device deletes the MAC-trigger entry. The device re-creates a MAC-trigger entry for the user when it detects the user's traffic again.
# Specify the aging time as 300 seconds for MAC-trigger entries.
[Sysname] portal mac-trigger-server mts
[Sysname-portal-mac-trigger-server-mts] aging-time 300
authentication-timeout
Use authentication-timeout to specify the authentication timeout, which is the maximum amount of time the device waits for portal authentication to complete after receiving a MAC binding query response.
Use undo authentication-timeout to restore the default.
authentication-timeout minutes
The authentication timeout time is 3 minutes.
minutes: Specifies the authentication timeout in the range of 1 to 15 minutes.
On receiving a MAC binding query response from the MAC binding server, the device starts a timeout timer for portal authentication. When the timer expires, the device deletes the MAC-trigger entry for the user.
# Specify the authentication timeout as 10 minutes.
[Sysname-portal-mac-trigger-server-mts] authentication-timeout 10
binding-retry
Use binding-retry to specify the maximum number of attempts and the interval for sending MAC binding queries to the MAC binding server.
Use undo binding-retry to restore the default.
binding-retry { retries | interval interval } *
undo binding-retry
The maximum number of query attempts is 3 and the query interval is 1 second.
retries: Specifies the maximum number of MAC binding query attempts, in the range of 1 to 10.
interval interval: Specifies the query interval in the range of 1 to 60 seconds.
If the device does not receive a response from the MAC binding server after the maximum number is reached, the device determines that the MAC binding server is unreachable. The device performs normal portal authentication for the user. The user needs to enter the username and password for authentication.
If you execute this command multiple times in the same MAC binding server view, the most recent configuration takes effect.
# Set the maximum number of MAC binding query attempts to 3 and the query interval to 60 seconds.
[Sysname-portal-mac-trigger-server-mts] binding-retry 3 interval 60
captive-bypass enable
Use captive-bypass enable to enable the captive-bypass feature.
Use undo captive-bypass enable to disable the captive-bypass feature.
The captive-bypass feature is disabled. The device automatically pushes the portal authentication page to the iOS devices and some Android devices when they are connected to the network.
Portal Web server view
With this feature enabled, the device does not automatically push the portal authentication page to iOS devices and some Android devices when they are connected to the network. The device pushes the portal authentication page only when the user accesses the Internet by using a browser.
# Enable the captive-bypass feature.
[Sysname] portal web-server wbs
[Sysname-portal-websvr-wbs] captive-bypass enable
display portal web-server
default-logon-page
Use default-logon-page to specify the default authentication page file for the local portal Web service.
Use undo default-logon-page to restore the default.
default-logon-page file-name
The default authentication page file for a local portal Web service is file defaultfile.zip.
Local portal Web service view
file-name: Specifies the default authentication page file by the file name (without the file storage directory). The file name is a case-sensitive string of 1 to 91 characters. Valid characters are letters, digits, dots (.) and underscores (_).
After you use the default-logon-page command to specify the file, the device decompresses the file to get the authentication pages. The device then sets them as the default authentication pages for local portal authentication.
As a best practice for the correct operation of the local portal Web service, use the default authentication page file in the root directory of the device storage medium. To use custom authentication pages, you must strictly follow the related restrictions and guidelines when you customize the authentication pages.
# Specify file pagefile1.zip as the default authentication page file for local portal authentication.
[Sysname] portal local-web-server http
[Sysname-portal-local-websvr-http] default-logon-page pagefile1.zip
display portal
Use display portal to display portal configuration and portal running state.
display portal interface interface-type interface-number
# Display portal configuration and portal running state on VLAN-interface 2.
<Sysname> display portal interface vlan-interface 2
Portal information of Vlan-interface2
NAS-ID profile: aaa
Authorization : Strict checking
ACL : Enabled
User profile : Disabled
IPv4:
Portal status: Enabled
Portal authentication method: Direct
Portal web server: wbs
Portal mac-trigger-server: mts
Authentication domain: my-domain
Pre-auth domain: abc
User-dhcp-only: Enabled
Pre-auth IP pool: ab
Max Portal users: Not configured
Bas-ip: Not configured
User detection : Type: ICMP Interval: 300s Attempts: 5 Idle time: 180s
Action for server detection:
Server type Server name Action
Web server wbs fail-permit
Portal server pts fail-permit
Layer3 source network:
IP address Mask
1.1.1.1 255.255.0.0
Destination authentication subnet:
IP address Mask
2.2.2.2 255.255.255.0
IPv6:
portal status: Disabled
Portal authentication method: Disabled
Portal web server: Not configured
Portal mac-trigger-server: Not configured
Authentication domain: Not configured
Pre-auth domain: Not configured
User-dhcp-only: Disabled
Pre-auth IP pool: Not configured
Bas-ipv6:Not configured
User detection: Not configured
IP address Prefix length
Portal information of interface |
Portal configuration on the interface. |
NAS-ID profile |
NAS-ID profile on the interface. |
Authorization |
Authorization information type: ACL. |
Strict checking |
Whether strict checking is enabled on portal authorization information. |
IPv4 |
IPv4 portal configuration. |
IPv6 |
IPv6 portal configuration. |
Portal status |
Portal authentication status on the interface: · Disabled—Portal authentication is disabled. · Enabled—Portal authentication is enabled. · Authorized—The portal authentication server or portal Web server is unreachable. The interface allows users to have network access without authentication. |
Portal authentication method |
Authentication mode enabled on the interface: · Direct—Direct authentication. · Redhcp—Re-DHCP authentication. · Layer3—Cross-subnet authentication. |
Portal Web server |
Name of the portal Web server specified on the interface. |
Portal mac-trigger-server |
Name of the MAC binding server specified on the interface. |
Authentication domain |
Mandatory authentication domain on the interface. |
Pre-auth domain |
Preauthentication domain for portal users on the interface. |
User-dhcp-only |
Status of the user-dhcp-only feature: · Enabled—Only users with IP addresses obtained through DHCP can perform portal authentication. · Disabled—Both users with IP addresses obtained through DHCP and users with static IP addresses can pass authentication to get online. |
Pre-auth ip-pool |
Name of the IP address pool specified for portal users before authentication. |
Max Portal users |
Maximum number of portal users allowed on an interface. |
Bas-ip |
BAS-IP attribute of the portal packets sent to the portal authentication server. |
Bas-ipv6 |
BAS-IPv6 attribute of the portal packets sent to the portal authentication server. |
Configuration for online detection of portal users on the interface, including detection method (ARP, ICMP, ND, or ICMPv6), detection interval, maximum number of detection attempts, and user idle time. |
Action for server detection |
Portal server detection configuration on the interface: · Server type—Type of the server. Portal server represents the portal authentication server, and Web server represents the portal Web server. · Server name—Name of the server. · Action—Action triggered by the result of server detection. This field displays fail-permit when the portal fail-permit feature is enabled. |
Layer3 source subnet |
Information of the portal authentication source subnet. |
Destination authentication subnet |
Information of the portal authentication destination subnet. |
IP address |
IP address of the portal authentication subnet. |
Mask |
Subnet mask of the portal authentication subnet. |
Prefix length |
Prefix length of the IPv6 portal authentication subnet address. |
portal domain
portal enable
portal ipv6 layer3 source
portal layer3 source
portal web-server
Use display portal mac-trigger-server to display information about MAC binding servers.
display portal mac-trigger-server { all | name server-name }
all: Specifies all MAC binding servers.
name server-name: Specifies a MAC binding server by its name, a case-sensitive string of 1 to 32 characters.
# Display information about all MAC binding servers.
<Sysname> display portal mac-trigger-server all
Portal mac trigger server name: ms1
Version : 2.0
Server type : IMC
IP : 10.1.1.1
Port : 100
VPN instance : Not configured
Aging time : 120 seconds
Free-traffic threshold : 1000 bytes
NAS-Port-Type : 255
Binding retry times : 5
Binding retry interval : 2 seconds
Authentication timeout : 5 minutes
Portal mac trigger server name: mts
Version : 1.0
Server type : IMC
IP : 4.4.4.2
Port : 50100
Aging time : 300 seconds
Free-traffic threshold : 0 bytes
NAS-Port-Type : Not configured
Binding retry times : 3
Binding retry interval : 1 seconds
Authentication timeout : 3 minutes
# Display information about the MAC binding server ms1.
<Sysname> display portal mac-trigger-server name ms1
Version : 2.0
Server type : IMC
IP : 10.1.1.1
Port : 100
NAS-Port-Type : 255
Portal mac trigger server name |
Name of the MAC binding server. |
Version |
Version of the portal protocol: · 1.0—Version 1. · 2.0—Version 2. · 3.0—Version 3. |
Server type |
Type of the MAC binding server. This field always displays IMC, which indicates the H3C IMC server or H3C CAMS server. |
IP |
IP address of the MAC binding server. |
Port |
UDP port number on which the MAC binding server listens for MAC binding query packets. |
VPN instance |
MPLS L3VPN instance where the MAC binding server resides. |
Aging time |
Aging time in seconds. A MAC-trigger entry is aged out when the aging time expires. |
Free-traffic threshold |
Free-traffic threshold in bytes. If a user's traffic is below the threshold, the user can access the network without authentication. |
NAS-Port-Type |
NAS-Port-Type attribute value in RADIUS request packets sent to the RADIUS server. |
Binding retry times |
Maximum number of attempts for sending MAC binding queries to the MAC binding server. |
Binding retry interval |
Interval at which the device sends MAC binding queries to the MAC binding server. |
Authentication timeout |
Maximum amount of time that the device waits for portal authentication to complete after receiving the MAC binding query response. |
Use display portal packet statistics to display packet statistics for portal authentication servers.
display portal packet statistics [ server server-name ]
server server-name: Specifies a portal authentication server by its name, a case-sensitive string of 1 to 32 characters.
This command displays statistics on packets the device sent to and received from portal authentication servers.
If you do not specify the server server-name option, this command displays packet statistics for all portal authentication servers.
# Display packet statistics for portal authentication server pts.
<Sysname> display portal packet statistics server pts
Portal server : pts
Invalid packets: 0
Pkt-Type Total Drops Errors
REQ_CHALLENGE 3 0 0
ACK_CHALLENGE 3 0 0
REQ_AUTH 3 0 0
ACK_AUTH 3 0 0
REQ_LOGOUT 1 0 0
ACK_LOGOUT 1 0 0
AFF_ACK_AUTH 3 0 0
NTF_LOGOUT 1 0 0
REQ_INFO 6 0 0
ACK_INFO 6 0 0
NTF_USERDISCOVER 0 0 0
NTF_USERIPCHANGE 0 0 0
AFF_NTF_USERIPCHAN 0 0 0
ACK_NTF_LOGOUT 1 0 0
NTF_HEARTBEAT 0 0 0
NTF_USER_HEARTBEAT 2 0 0
ACK_NTF_USER_HEARTBEAT 0 0 0
NTF_CHALLENGE 0 0 0
NTF_USER_NOTIFY 0 0 0
AFF_NTF_USER_NOTIFY 0 0 0
Portal server |
Name of the portal authentication server. |
Invalid packets |
Number of invalid packets. |
Pkt-Type |
Packet type. |
Total |
Total number of packets. |
Drops |
Number of dropped packets. |
Errors |
Number of packets that carry error information. |
REQ_CHALLENGE |
Challenge request packet the portal authentication server sent to the access device. |
ACK_CHALLENGE |
Challenge acknowledgment packet the access device sent to the portal authentication server. |
REQ_AUTH |
Authentication request packet the portal authentication server sent to the access device. |
ACK_AUTH |
Authentication acknowledgment packet the access device sent to the portal authentication server. |
REQ_LOGOUT |
Logout request packet the portal authentication server sent to the access device. |
ACK_LOGOUT |
Logout acknowledgment packet the access device sent to the portal authentication server. |
AFF_ACK_AUTH |
Affirmation packet the portal authentication server sent to the access device after receiving an authentication acknowledgment packet. |
NTF_LOGOUT |
Forced logout notification packet the access device sent to the portal authentication server. |
REQ_INFO |
Information request packet. |
ACK_INFO |
Information acknowledgment packet. |
NTF_USERDISCOVER |
User discovery notification packet the portal authentication server sent to the access device. |
NTF_USERIPCHANGE |
User IP change notification packet the access device sent to the portal authentication server. |
AFF_NTF_USERIPCHAN |
User IP change success notification packet the portal authentication server sent to the access device. |
ACK_NTF_LOGOUT |
Forced logout acknowledgment packet the portal authentication server sent to the access device. |
NTF_HEARTBEAT |
Server heartbeat packet the portal authentication server periodically sent to the access device. |
NTF_USER_HEARTBEAT |
User synchronization packet the portal authentication server sent to the access device. |
ACK_NTF_USER_HEARTBEAT |
User synchronization acknowledgment packet the access device sent to the portal authentication server. |
NTF_CHALLENGE |
Challenge request packet the access device sent to the portal authentication server. |
NTF_USER_NOTIFY |
User information notification packet the access device sent to the portal authentication server. |
AFF_NTF_USER_NOTIFY |
NTF_USER_NOTIFY acknowledgment packet the portal authentication server sent to the access device. |
display portal rule
Use display portal rule to display portal filtering rules.
In standalone mode:
display portal rule { all | dynamic | static } { interface interface-type interface-number [ slot slot-number ] }
In IRF mode:
display portal rule { all | dynamic | static } { interface interface-type interface-number [ chassis chassis-number slot slot-number ] }
all: Displays all portal filtering rules, including dynamic and static portal filtering rules.
dynamic: Displays dynamic portal filtering rules, which are generated after users pass portal authentication. These rules allow packets with specific source IP addresses to pass the interface.
static: Displays static portal filtering rules, which are generated after portal authentication is enabled. The interface filters packets by these rules when portal authentication is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays portal filtering rules for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays portal filtering rules for all cards. (In IRF mode.)
# (In standalone mode.) Display all portal filtering rules on VLAN-interface 100.
<Sysname> display portal rule all interface vlan-interface 100 slot 1
Slot 1:
IPv4 portal rules on Vlan-interface100:
Rule 1
Type : Static
Action : Permit
Protocol : Any
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
Port : Any
MAC : 0000-0000-0000
Interface : Vlan-interface100
VLAN : 100
Destination:
IP : 192.168.0.111
Mask : 255.255.255.255
Port : Any
Rule 2
Type : Dynamic
Action : Permit
Status : Active
Source:
IP : 2.2.2.2
MAC : 000d-88f8-0eab
VLAN : 100
Author ACL:
Number : 3001
Rule 3
Type : Static
Action : Redirect
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
VLAN : 100
Protocol : TCP
Destination:
IP : 0.0.0.0
Mask : 0.0.0.0
Port : 80
Rule 4:
Type : Static
Action : Deny
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
VLAN : Any
Destination:
IP : 0.0.0.0
Mask : 0.0.0.0
IPv6 portal rules on Vlan-interface100:
Rule 1
Type : Static
Action : Permit
Protocol : Any
Status : Active
Source:
IP : ::
Prefix length : 0
Port : Any
VLAN : 100
Destination:
IP : 3000::1
Prefix length : 64
Port : Any
Rule 2
Type : Dynamic
Action : Permit
Status : Active
Source:
IP : 3000::1
MAC : 0015-e9a6-7cfe
VLAN : 100
Author ACL:
Number : 3001
Rule 3
Type : Static
Action : Redirect
Status : Active
Source:
IP : ::
Prefix length : 0
VLAN : 100
Protocol : TCP
Destination:
IP : ::
Prefix length : 0
Port : 80
Rule 4:
Type : Static
Action : Deny
Status : Active
Source:
IP : ::
Prefix length : 0
VLAN : 100
Destination:
IP : ::
Prefix length : 0
Author ACL:
Number : 3001
Rule |
Number of the portal filtering rule. IPv4 portal filtering rules and IPv6 portal filtering rules are numbered separately. |
Type |
Type of the portal filtering rule: · Static—Static portal filtering rule. · Dynamic—Dynamic portal filtering rule. |
Action |
Action triggered by the portal filtering rule: · Permit—The interface allows packets to pass. · Redirect—The interface redirects packets. · Deny—The interface forbids packets to pass. |
Protocol |
Transport layer protocol permitted by the portal-free rule: · Any—Permits any transport layer protocol. · TCP—Permits TCP. · UDP—Permits UDP. |
Status |
Status of the portal filtering rule: · Active—The portal filtering rule is effective. · Deactive—The portal filtering rule is not activated. |
Source |
Source information of the portal filtering rule. |
IP |
Source IP address. |
Mask |
Subnet mask of the source IPv4 address. |
Prefix length |
Prefix length of the source IPv6 address. |
Port |
Source transport layer port number. |
MAC |
Source MAC address. |
Layer 2 or Layer 3 interface on which the portal filtering rule is implemented. |
VLAN |
Source VLAN ID. |
Protocol |
Transport layer protocol permitted by the portal redirect rule. This field always displays TCP. |
Destination |
Destination information of the portal filtering rule. |
IP |
Destination IP address. |
Port |
Destination transport layer port number. |
Mask |
Subnet mask of the destination IPv4 address. |
Prefix length |
Prefix length of the destination IPv6 address. |
Author ACL |
Authorized ACL assigned to authenticated portal users. This field is displayed only for a dynamic portal filtering rule. |
Number |
Number of the authorized ACL. This field displays N/A if the AAA server does not assign an ACL. |
display portal server
Use display portal server to display information about portal authentication servers.
display portal server [ server-name ]
If you do not specify the server-name argument, this command displays information about all portal authentication servers.
# Display information about the portal authentication server pts.
<Sysname> display portal server pts
Portal server: pts
Type : IMC
IP : 192.168.0.111
Port : 50100
Server detection : Timeout 60s Action: log
User synchronization : Timeout 200s
Status : Up
Table 5 Command output
Type |
Portal authentication server type. This field always displays IMC, which indicates the IMC server. |
Portal server |
IP |
IP address of the portal authentication server. |
VPN instance |
MPLS L3VPN instance where the portal authentication server resides. |
Port |
Listening port on the portal authentication server. |
Server detection |
Parameters for portal authentication server detection: · Detection timeout in seconds. · Action (trap) triggered by the reachability status change of the portal authentication server. |
User synchronization |
User idle timeout in seconds for portal user synchronization. |
Status |
Reachability status of the portal authentication server: · Up—This value indicates one of the following conditions: ¡ Portal authentication server detection is disabled. ¡ Portal authentication server detection is enabled and the server is reachable. · Down—Portal authentication server detection is enabled and the server is unreachable. |
portal enable
portal server
user-sync
display portal user
Use display portal user to display information about portal users.
display portal user { all | interface interface-type interface-number | ip ipv4-address | ipv6 ipv6-address | pre-auth [ interface interface-type interface-number | ip ipv4-address | ipv6 ipv6-address ] } [ verbose ]
all: Displays information about all portal users.
interface interface-type interface-number: Displays information about portal users on the specified interface.
ip ipv4-address: Specifies the IPv4 address of a portal user.
ipv6 ipv6-address: Specifies the IPv6 address of a portal user.
pre-auth: Displays information about preauthentication portal users. A preauthentication user is a user who is authorized with the authorization attributes in a preauthentication domain before portal authentication. If you do not specify the pre-auth keyword, this command displays information about authenticated portal users.
verbose: Displays detailed information about portal users.
# Display information about all portal users.
<Sysname> display portal user all
Total portal users: 2
Username: abc
Portal server: pts
State: Online
VPN instance: N/A
MAC IP VLAN Interface
000d-88f8-0eab 2.2.2.2 100 Vlan-interface100
Authorization information:
DHCP IP pool: N/A
User profile: N/A
Session group profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Username: def
Portal server: pts
State: Online
VPN instance: N/A
000d-88f8-0eac 3.3.3.3 200 Vlan-interface200
DHCP IP pool: N/A
User profile: N/A
ACL number: 3001
Inbound CAR: N/A
Outbound CAR: N/A
# Display information about preauthentication portal users.
<Sysname> display portal user pre-auth
Total portal pre-auth users: 2
000a-eb29-75f1 18.18.0.3 200 Route-Aggregation100
State: Online
VPN instance: N/A
User profile: N/A
ACL number: 3000 (active)
Inbound CAR: N/A
Outbound CAR: N/A
000a-eb29-75f2 18.18.0.4 200 Route-Aggregation100
State: Online
VPN instance: N/A
User profile: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Table 6 Command output
Total portal users |
Total number of portal users. |
Username |
Name of the user. |
Portal server |
State |
Current state of the portal user: · Initialized—The user is initialized and ready for authentication. · Authenticating—The user is being authenticated. · Waiting SetRule—The user is waiting for authorization information. · Authorizing—The user is being authorized. · Online—The user is online. · Waiting Traffic—The last traffic of the user is to be collected. · Stop Accounting—Accounting for the user is stopped. · Done—The user goes offline successfully. |
VPN instance |
MPLS L3VPN instance to which the portal user belongs. If the portal user is on a public network, this field displays N/A. |
MAC |
MAC address of the portal user. |
IP |
IP address of the portal user. |
VLAN |
VLAN where the portal user resides. |
Access interface of the portal user. |
Authorization information |
Authorization information for the portal user. |
DHCP IP pool |
Name of the authorized IP address pool. If no IP address pool is authorized for the portal user, this field displays N/A. |
User profile |
This field is not supported in the current software version. Authorized user profile: · N/A—No user profile is authorized. · active—The authorized user profile is applied to the user access interface successfully. · inactive—The authorized user profile is not applied to the user access interface or the user profile does not exist on the device. |
Session group profile |
This field is not supported in the current software version. Authorized session group profile: · N/A—No session group profile is authorized. · active—The authorized session group profile is applied to the user access interface successfully. · inactive—The authorized session group profile is not applied to the user access interface or the session group profile does not exist on the device. |
ACL number |
Authorized ACL: · N/A—No ACL is authorized. · active—The authorized ACL is applied to the user access interface successfully. · inactive—The authorized ACL is not applied to the user access interface or the ACL does not exist on the device. |
Inbound CAR |
Authorized inbound CAR: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. · active—The authorized inbound CAR is applied to the user access interface successfully. · inactive—The authorized inbound CAR is not applied to the user access interface. · N/A—No inbound CAR is authorized. |
Outbound CAR |
This field is not supported in the current software version. Authorized outbound CAR: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. · active—The authorized outbound CAR is applied to the user access interface successfully. · inactive—The authorized outbound CAR is not applied to the user access interface. · N/A—No outbound CAR is authorized. |
# Display detailed information about the portal user with IP address 50.50.50.3.
<Sysname> display portal user ip 50.50.50.3 verbose
Basic:
Current IP address: 50.50.50.3
Original IP address: 30.30.30.2
Username: user1@hrss
User ID: 0x28000002
Access interface: Vlan-interface20
Service-VLAN/Customer-VLAN: -/-
MAC address: 0000-0000-0001
Domain: hrss
VPN instance: N/A
Status: Online
Portal server: test
AAA:
Realtime accounting interval: 720s, retry times: 5
Idle cut: N/A
Session duration: N/A, remaining: N/A
Remaining traffic: N/A
Login time: 2018-01-04 16:13:35 UTC
Accounting-start fail action: Online
Accounting-update fail action: Online
Accounting quota-out action: Offline
DHCP IP pool: N/A
ACL&QoS&Multicast:
Inbound CAR: N/A
Outbound CAR: N/A
ACL number: 3000 (inactive)
User profile: N/A
Max multicast addresses: 4
Multicast address list: 1.2.3.1, 1.34.33.1, 3.123.123.3, 4.5.6.7
2.2.2.2, 3.3.3.3, 4.4.4.4
User group: 1 (Id=1)
Flow statistic:
Uplink packets/bytes: 7/546
Downlink packets/bytes: 0/0
ITA:
level-1 uplink packets/bytes: 0/0
downlink packets/bytes: 0/0
level-2 uplink packets/bytes: 0/0
Table 7 Command output
Current IP address |
IP address of the portal user after passing authentication. |
Original IP address |
IP address of the portal user during authentication. |
Username |
Name of the portal user. |
User ID |
Portal user ID. |
Access interface |
Service-VLAN/Customer-VLAN |
Public VLAN/Private VLAN to which the portal user belongs. If no VLAN is configured for the portal user, this field displays -/-. |
MAC address |
Domain |
ISP domain name for portal authentication. |
VPN instance |
Status |
Status of the portal user: · Authenticating—The user is being authenticated. · Authorizing—The user is being authorized. · Waiting SetRule—Deploying portal rules to the user. · Online—The user is online. · Waiting Traffic—Waiting for traffic from the user. · Stop Accounting—Stopping accounting for the user. · Done—The user is offline. |
Portal server |
Name of the portal server. |
Portal authentication method on the access interface: · Direct—Direct authentication. · Re-Dhcp—Re-DHCP authentication. · Layer3—Cross-subnet authentication. |
AAA |
AAA information about the portal user. |
Realtime accounting interval |
Interval for sending real-time accounting updates, and the maximum number of accounting attempts. If the real-time accounting is not authorized, this field displays N/A. |
Idle cut |
Idle timeout period and the minimum traffic threshold. If idle cut is not authorized, this field displays N/A. |
direction |
Direction of user traffic: · Both—Inbound and outbound traffic. · Inbound—Inbound traffic. · Outbound—Outbound traffic. |
Session duration |
Session duration and the remaining session time. If the session duration is not authorized, this field displays N/A. |
Remaining traffic |
Remaining traffic for the portal user. If the remaining traffic is not authorized, this field displays N/A. |
Login time |
Time when the user logged in. The field uses the device time format, for example, 2023-1-19 2:42:30 UTC. |
Accounting-start fail action |
This field is not supported in the current software version. Action to take on the user when the user encounters accounting-start failure: · Online—Allow the user to stay online. · Offline—Log out the user. |
Accounting-update fail action |
This field is not supported in the current software version. Action to take on the user when the user encounters accounting-update failure: · Online—Allow the user to stay online. · Offline—Log out the user. |
Accounting quota-out action |
This field is not supported in the current software version. Action to take on the user when the data quotas of the user are used up: · Online—Allow the user to stay online. · Offline—Log out the user. |
DHCP IP pool |
Authorized DHCP IP address pool. If no DHCP IP address pool is authorized for the portal user, this field displays N/A. |
Inbound CAR |
This field is not supported in the current software version. Authorized inbound CAR: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. · active—The authorized inbound CAR is applied to the user access interface successfully. · inactive—The authorized inbound CAR is not applied to the user access interface. · N/A—No inbound CAR is authorized. |
Outbound CAR |
ACL number |
User profile |
Max multicast addresses |
Maximum number of multicast groups the portal user can join. |
Multicast address list |
Multicast group list the portal user can join. If no multicast group is authorized, this field displays N/A. |
User group |
Name of the group where the portal user belongs. This field is invalid if the ID is 0xffffffff. |
Flow statistic |
Flow statistics for the portal user. |
Uplink packets/bytes |
Packet and byte statistics of the upstream traffic. |
Downlink packets/bytes |
Packet and byte statistics of the downstream traffic. |
ITA |
This field is not supported in the current software version. ITA traffic statistics for the portal user. |
Accounting merge |
This field is not supported in the current software version. Status of the accounting merge feature: · Enabled—The accounting merge feature is enabled. The device merges the ITA traffic of all accounting rates in the ITA policy, and applies the lowest rate to the merged traffic. · Disabled—The accounting merge feature is disabled. The device sends separate traffic statistics for each accounting rate to the server. |
Traffic separate |
This field is not supported in the current software version. Whether to exclude the amount of ITA traffic from the overall traffic statistics sent to the accounting server: · Enabled—ITA traffic is excluded from the overall traffic statistics. · Disabled—ITA traffic is included in the overall traffic statistics. |
Quota-out offline |
This field is not supported in the current software version. Whether to prohibit the portal user from accessing the authorized IP subnets when the user has used up its ITA data quota: · Enabled—User cannot access the authorized IP subnets after its ITA data quota is used up. · Disabled—User can access the authorized IP subnets after its ITA data quota is used up. |
Level-n session duration |
This field is not supported in the current software version. Authorized level n session duration and the remaining session duration. Level n represents the accounting level of the portal user in ITA. If the session duration is not authorized, this field displays N/A. |
Remaining traffic |
This field is not supported in the current software version. Remaining ITA traffic for the portal user. |
Traffic action |
This field is not supported in the current software version. Action for traffic destined for the authorized IP subnets when the portal user has used up its ITA data quota: · Permit—Permits traffic destined for the authorized IP subnets. · Deny—Denies traffic destined for the authorized IP subnets. |
Inbound CAR |
This field is not supported in the current software version. Authorized inbound CAR for ITA traffic: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. · active—The authorized inbound CAR is applied to the user access interface successfully. · inactive—The authorized inbound CAR is not applied to the user access interface. · N/A—No inbound CAR is authorized. |
Outbound CAR |
This field is not supported in the current software version. Authorized outbound CAR for ITA traffic: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. · active—The authorized outbound CAR is applied to the user access interface successfully. · inactive—The authorized outbound CAR is not applied to the user access interface. · N/A—No outbound CAR is authorized. |
This field is not supported in the current software version. Packet and byte statistics of the portal user's upstream ITA traffic. |
This field is not supported in the current software version. Packet and byte statistics of the portal user's downstream ITA traffic. |
portal enable
Use display portal web-server to display information about portal Web servers.
display portal web-server [ server-name ]
server-name: Specifies a portal Web server by its name, a case-sensitive string of 1 to 32 characters.
If you do not specify the server-name argument, this command displays information about all portal Web servers.
# Display information about portal Web server wbs.
<Sysname> display portal web-server wbs
Portal Web server: wbs
Type : IMC
URL : http://www.test.com/portal
URL parameters : userurl=http://www.test.com/welcome
userip=source-address
Server detection : Interval: 120s Attempts: 5 Action: log
IPv4 status : Up
IPv6 status : Up
Captive-bypass : Disabled
If-match : original-url http://2.2.2.2 redirect-url http://192.168.56.2
Table 8 Command output
Type |
Portal Web server type. This field always displays IMC, which indicates the IMC server. |
Portal Web server |
Name of the portal Web server. |
URL |
URL of the portal Web server. |
URL parameters |
URL parameters for the portal Web server. |
VPN instance |
Name of the MPLS L3VPN where the portal Web server resides. |
Server detection |
Parameters for portal Web server detection: · Detection interval in seconds. · Maximum number of detection attempts. · Action (trap) triggered by the reachability status change of the portal Web server. |
IPv4 status |
Current state of the IPv4 portal Web server: · Up—This value indicates one of the following conditions: ¡ Portal Web server detection is disabled. ¡ Portal Web server detection is enabled and the server is reachable. · Down—Portal Web server detection is enabled and the server is unreachable. |
IPv6 status |
Current state of the IPv6 portal Web server: · Up—This value indicates one of the following conditions: ¡ Portal Web server detection is disabled. ¡ Portal Web server detection is enabled and the server is reachable. · Down—Portal Web server detection is enabled and the server is unreachable. |
Captive-bypass |
Status of the captive-bypass feature: Enabled or Disabled. |
If-match |
Match rules configured for URL redirection. If no match rules are configured, this field displays Not configured. |
portal enable
portal web-server
display web-redirect rule
Use display web-redirect rule to display information about Web redirect rules.
In standalone mode:
display web-redirect rule interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display web-redirect rule interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays Web redirect rules for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays Web redirect rules for the global active MPU. (In IRF mode.)
# Display all Web redirect rules on VLAN-interface 100.
<Sysname> display web-redirect rule interface vlan-interface 100
IPv4 web-redirect rules on vlan-interface 100:
Rule 1:
Type : Dynamic
Action : Permit
Status : Active
Source:
IP : 192.168.2.114
VLAN : Any
Rule 2:
Type : Static
Action : Redirect
Status : Active
Source:
VLAN : Any
Protocol : TCP
Destination:
Port : 80
IPv6 web-redirect rules on vlan-interface 100:
Rule 1:
Type : Static
Action : Redirect
Status : Active
Source:
VLAN : Any
Protocol : TCP
Destination:
Port : 80
Table 9 Command output
Rule |
Number of the Web redirect rule. |
Type |
Type of the Web redirect rule: · Static—Static Web redirect rule, generated when the Web redirect feature takes effect. · Dynamic—Dynamic Web redirect rule, generated when a user visits a redirect webpage. |
Action |
Action in the Web redirect rule: · Permit—Allows packets to pass. · Redirect—Redirects the packets. |
Status |
Status of the Web redirect rule: · Active—The Web redirect rule is effective. · Inactive—The Web redirect rule is not effective. |
Source |
Source information in the Web redirect rule. |
IP |
Mask |
Prefix length |
VLAN |
Source VLAN. If not specified, this field displays Any. |
Protocol |
Transport layer protocol permitted by the Web redirect rule. This field always displays TCP. |
Destination |
Destination information in the Web redirect rule. |
Port |
Destination transport layer port number. The default port number is 80. |
free-traffic threshold
Use free-traffic threshold to specify the free-traffic threshold for portal users.
Use undo free-traffic threshold to restore the default.
free-traffic threshold value
The free-traffic threshold is 0 bytes.
value: Specifies the free-traffic threshold in the range of 0 to 10240000 bytes. If the free-traffic threshold is set to 0, the device immediately triggers MAC-based quick portal authentication for a user once the user's traffic is deleted.
After MAC-based quick portal authentication is configured, the device monitors a user's network traffic (sent and received) in real time before the MAC-trigger entry for the user ages out. A user can access the network without authentication if the user's network traffic is below the free-traffic threshold. When the user's network traffic reaches the threshold, the device triggers MAC-based quick portal authentication for the user.
If the user passes portal authentication, the device deletes the MAC-trigger entry and clears the user traffic statistics. If the user fails authentication, the device does not trigger MAC-based quick authentication for the user before the MAC-trigger entry ages out. When the MAC-trigger entry ages out, the device clears the user traffic statistics.
When traffic is detected from the user again, the device re-creates a MAC-trigger entry for the user and repeats the previous procedure.
# Specify the free-traffic threshold for portal users as 10240 bytes.
[Sysname-portal-mac-trigger-server-mts] free-traffic threshold 10240
if-match
Use if-match to configure a match rule for URL redirection.
Use undo if-match to delete a URL redirection match rule.
if-match { original-url url-string redirect-url url-string [ url-param-encryption { aes | des } key { cipher | simple } string ] | user-agent string redirect-url url-string }
undo if-match { original-url url-string | user-agent user-agent }
No URL redirection match rules exist.
original-url url-string: Specifies a URL string to match the URL in HTTP requests of a portal user. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
redirect-url url-string: Specifies the URL to which the user is redirected. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
url-param-encryption: Specifies an encryption algorithm to encrypt the parameters carried in the redirection URL. If you do not specify an encryption algorithm, the parameters carried in the redirection URL are not encrypted.
aes: Specifies the AES algorithm.
des: Specifies the DES algorithm.
key: Specifies a key for encryption.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the case-sensitive key string. The string length varies by the selected encryption method:
· If des cipher is specified, the string length is 41 characters.
· If des simple is specified, the string length is 8 characters.
· If aes cipher is specified, the string length is 1 to 73 characters.
· If aes simple is specified, the string length is 1 to 31 characters.
user-agent user-agent: Specifies a user agent string to match the User-Agent string in HTTP or HTTPS requests. The user agent string is a case-sensitive string of 1 to 255 characters. The User-Agent string in HTTP or HTTPS requests includes information about hardware manufacturer, operating system, browser, and search engine.
A URL redirection match rule matches HTTP or HTTPS requests by user-requested URL or User-Agent information, and redirects the matching requests to the specified redirection URL.
For a user to successfully access a redirection URL, configure a portal-free rule to allow HTTP or HTTPS requests destined for the redirection URL to pass. For information about configuring portal-free rules, see the portal free-rule command.
For a portal Web server, you can configure the url command and the if-match command for URL redirection. The url command redirects all HTTP or HTTPS requests from unauthenticated users to the portal Web server for authentication. The if-match command allows for flexible URL redirection by redirecting specific requests to specific redirection URLs. If both commands are executed, the if-match command takes priority to perform URL redirection.
# Configure a match rule to redirect HTTP requests destined for the URL http://www.abc.com.cn to the URL http://192.168.0.1 and use DES to encrypt the parameters carried in this redirection URL.
[Sysname-portal-websvr-wbs] if-match original-url http://www.abc.com.cn redirect-url http://192.168.0.1 url-param-encryption des key simple 12345678
# Configure a match rule to redirect HTTP requests that carry the user agent string 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 to the URL http://192.168.0.1.
[Sysname-portal-websvr-wbs] if-match user-agent 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 redirect-url http://192.168.0.1
portal free-rule
url
url-parameter
ip (MAC binding server view)
Use ip to specify the IP address of a MAC binding server.
Use undo ip to restore the default.
ip ipv4-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
undo ip
The IP address of the MAC binding server is not specified.
ipv4-address: Specifies the IPv4 address of a MAC binding server.
vpn-instance ipv4-vpn-instance-name: Specifies the MPLS L3VPN instance to which the MAC binding server belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the MAC binding server belongs to the public network, do not specify this option.
key: Specifies a shared key to be used to authenticate packets between the device and the MAC binding server. Portal packets exchanged between the device and MAC binding server carry an authenticator that is generated with the shared key. The receiver uses the authenticator to verify the correctness of the received portal packets. If you do not specify a shared key, the device and MAC binding server do not authenticate the packets between them.
cipher: Specifies a shared key in encrypted form.
simple: Specifies a shared key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the shared key. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
# Specify 192.168.0.111 as the IPv4 address of MAC binding server mts and plaintext key portal as the shared key for communication with the MAC binding server.
[Sysname-portal-mac-trigger-server-mts] ip 192.168.0.111 key simple portal
Use ip to specify the IPv4 address of a portal authentication server.
undo ip
The IPv4 address of the portal authentication server is not specified.
Portal authentication server view
ipv4-address: Specifies the IPv4 address of the portal authentication server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the portal authentication server belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the portal authentication server belongs to the public network, do not specify this option.
key: Specifies a shared key for communication with the portal authentication server. Portal packets exchanged between the access device and the portal authentication server carry an authenticator that is generated with the shared key. The receiver uses the authenticator to check the correctness of the received portal packets.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
A portal authentication server has only one IPv4 address. Therefore, in portal authentication server view, only one IPv4 address exists. If you execute this command multiple times, the most recent configuration takes effect.
Do not configure the same IPv4 address and MPLS L3VPN for different portal authentication servers.
# Specify 192.168.0.111 as the IPv4 address of portal authentication server pts and plaintext key portal as the shared key for communication with the portal authentication server.
[Sysname] portal server pts
[Sysname-portal-server-pts] ip 192.168.0.111 key simple portal
portal server
ipv6
Use ipv6 to specify the IPv6 address of a portal authentication server.
Use undo ipv6 to restore the default.
ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
undo ipv6
The IPv6 address of the portal authentication server is not specified.
ipv6-address: Specifies the IPv6 address of the portal authentication server.
simple: Specifies a key in plaintext form. For security purposes, the key in plaintext form will be stored in encrypted form.
A portal authentication server has only one IPv6 address. Therefore in portal authentication server view, only one IPv6 address exists. If you execute this command multiple times, the most recent configuration takes effect.
Do not configure the same IPv6 address and MPLS L3VPN for different portal authentication servers.
# Specify 2000::1 as the IPv6 address of portal authentication server pts and plaintext key portal as the shared key for communication with the portal authentication server.
[Sysname-portal-server-pts] ipv6 2000::1 key simple portal
portal server
nas-port-type
Use nas-port-type to specify the NAS-Port-Type value carried in RADIUS requests sent to the RADIUS server.
Use undo nas-port-type to restore the default.
nas-port-type value
undo nas-port-type
The NAS-Port-Type value carried in RADIUS requests is 0.
value: Specifies the NAS-Port-Type value in the range of 1 to 255.
Some MAC binding servers identify MAC-based quick portal authentication by a specific NAS-Port-Type value in received RADIUS requests. To communicate with such a MAC binding server, you must configure the device to use the NAS-Port-Type value required by the MAC binding server.
# Set the NAS-Port-Type value in RADIUS requests sent to MAC binding server mts to 30.
[Sysname-portal-mac-trigger-server-mts] nas-port-type 30
Use port to set the UDP port number the MAC binding server uses to listen for MAC binding query packets.
Use undo port to restore the default.
port port-number
undo port
The MAC binding server listens for MAC binding query packets on UDP port 50100.
port-number: Specifies the listening UDP port number in the range of 1 to 65534.
The specified port number must be the same as the query listening port number configured on the MAC binding server.
# Set the UDP port number to 1000 for MAC binding server pts to listen for MAC binding query packets.
<sysname> system-view
[sysname] portal mac-trigger-server mts
[sysname-portal-mac-trigger-server-mts] port 1000
Use port to set the destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server.
port port-number
undo port
The device uses 50100 as the destination UDP port number for unsolicited portal packets.
port-number: Specifies a destination UDP port number the device uses to send unsolicited portal packets to the portal authentication server. The value range for this argument is 1 to 65534.
The specified port must be the port that listens to portal packets on the portal authentication server.
# Set the destination UDP port number to 50000 for the device to send unsolicited portal packets to portal authentication server pts.
[Sysname-portal-server-pts] port 50000
portal server
Use portal { bas-ip | bas-ipv6 } to configure the BAS-IP or BAS-IPv6 attribute carried in the portal packets sent to the portal authentication server.
Use undo portal { bas-ip | bas-ipv6 } to restore the default.
portal { bas-ip ipv4-address | bas-ipv6 ipv6-address }
The BAS-IP attribute of an IPv4 portal reply packet sent to the portal authentication server is the source IPv4 address of the packet. The BAS-IPv6 attribute of an IPv6 portal reply packet sent to the portal authentication server is the source IPv6 address of the packet.
The BAS-IP attribute of an IPv4 portal notification packet sent to the portal authentication server is the IPv4 address of the packet's output interface. The BAS-IPv6 attribute of an IPv6 portal notification packet sent to the portal authentication server is the IPv6 address of the packet's output interface.
Interface view
ipv4-address: Specifies BAS-IP for portal packets sent to the portal authentication server. This attribute must be the IPv4 address of an interface on the device. It cannot be 0.0.0.0, 1.1.1.1, a class D address, a class E address, or a loopback address.
ipv6-address: Specifies BAS-IPv6 for portal packets sent to the portal authentication server. This attribute must be the IPv6 address of an interface on the device. It cannot be a multicast address, an all-0 address, or a link-local address.
If the device runs Portal 2.0, unsolicited portal packets (such as a logout notification packet) sent to the portal authentication server must carry the BAS-IP attribute. If the device runs Portal 3.0, unsolicited portal packets sent to the portal authentication server must carry the BAS-IP or BAS-IPv6 attribute.
After this command takes effect, the source IP address for unsolicited notification portal packets the device sends to the portal authentication server is the configured BAS IP address. Otherwise, the source IP address of the packets is the IP address of the packet output interface.
You must configure the BAS-IP or BAS-IPv6 attribute on a portal authentication-enabled interface if the following conditions are met:
· The portal authentication server is an H3C IMC server or the portal authentication mode on the interface is re-DHCP.
· The portal device IP address specified on the portal authentication server is not the IP address of the portal packet output interface.
# On interface VLAN-interface 100, configure the BAS-IP attribute as 2.2.2.2 for portal packets sent to the portal authentication server.
[Sysname–Vlan-interface100] portal bas-ip 2.2.2.2
display portal
Use portal { ipv4-max-user | ipv6-max-user } to set the maximum number of portal users allowed on an interface.
Use undo portal { ipv4-max-user | ipv6-max-user } to restore the default.
portal { ipv4-max-user | ipv6-max-user } max-number
The maximum number of portal users allowed on an interface is not limited.
Interface view
max-number: Specifies the maximum number of IPv4 or IPv6 portal users allowed on an interface, in the range of 1 to 4294967295.
If the specified maximum number is smaller than the number of current online portal users on the interface, the limit can be set successfully. The limit does not impact the online portal users. However, the device does not allow new portal users to log in from the interface until the number drops down below the limit.
# Set the maximum number of IPv4 portal users to 100 on VLAN-interface 100.
[Sysname–Vlan-interface100] portal ipv4-max-user 100
display portal user
portal max-user
Use portal apply mac-trigger-server to specify a MAC binding server.
Use undo portal apply mac-trigger-server to restore the default.
portal apply mac-trigger-server server-name
No MAC binding server is specified.
Interface view
Only direct portal authentication supports MAC-based quick portal authentication.
For MAC-based quick portal authentication to take effect, perform the following tasks:
· Configure normal portal authentication.
· Configure a MAC binding server.
· Specify the MAC binding server on a portal enabled interface.
# Specify MAC binding server mts on VLAN-interface 1.
[Sysname-Vlan-interface1] portal apply mac-trigger-server mts
Use portal [ ipv6 ] apply web-server to specify a portal Web server. The device redirects the HTTP requests sent by unauthenticated portal users to the portal Web server.
Use undo portal [ ipv6 ] apply web-server to restore the default.
portal [ ipv6 ] apply web-server server-name [ fail-permit ]
No portal Web server is specified.
Interface view
ipv6: Specifies an IPv6 portal Web server. If the server is an IPv4 portal Web server, do not specify this keyword.
server-name: Specifies a portal Web server by its name, a case-sensitive string of 1 to 32 characters. The name must already exist.
fail-permit: Enables the portal fail-permit feature on the interface. The portal fail-permit feature allows portal users to access the Internet without authentication when the portal Web server is unreachable.
You can enable both IPv4 and IPv6 portal authentication on an interface. Therefore, you can specify both an IPv4 portal Web server and an IPv6 portal Web server on the interface.
When portal fail-permit is enabled for a portal authentication server and a portal Web server on the interface, portal authentication is disabled for users on the interface if either server is unreachable. Portal authentication resumes after both servers become reachable.
# Specify portal Web server wbs on VLAN-interface 100 for portal authentication.
[Sysname–Vlan-interface100] portal apply web-server wbs
display portal
portal fail-permit server
portal web-server
portal authorization strict-checking
Use portal authorization strict-checking to enable strict checking on portal authorization information.
Use undo portal authorization strict-checking to disable strict checking on portal authorization information.
portal authorization { acl | user-profile } strict-checking
undo portal authorization { acl | user-profile } strict-checking
Strict checking on portal authorization information is disabled. If an authorized ACL does not exist on the device, the user will not be logged out.
Interface view
acl: Enables strict checking on authorized ACLs.
user-profile: Enables strict checking on authorized user profiles. This keyword is not supported in the current software version.
The strict checking feature on an interface allows a portal user to stay online only when the authorization information for the user is successfully deployed. The strict checking fails if the authorized ACL does not exist on the device.
# Enable strict checking on authorized ACLs on VLAN-interface 100.
[Sysname-Vlan-interface100] portal authorization acl strict-checking
display portal
portal delete-user
Use portal delete-user to log out online portal users.
portal delete-user { ipv4-address | all | interface interface-type interface-number | ipv6 ipv6-address }
ipv4-address: Specifies the IP address of an IPv4 online portal user.
all: Specifies IPv4 and IPv6 online portal users on all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. If you specify this option, this command logs out all IPv4 and IPv6 online portal users on the interface.
ipv6 ipv6-address: Specifies the IP address of an IPv6 online portal user.
# Log out the online portal user whose IP address is 1.1.1.1.
[Sysname] portal delete-user 1.1.1.1
display portal user
portal device-id
Use portal device-id to specify the device ID.
Use undo portal device-id to restore the default.
portal device-id device-id
A device is not configured with a device ID.
device-id: Specifies a device ID for the device, a case-sensitive string of 1 to 63 characters.
The portal authentication server uses device IDs to identify the devices that send protocol packets to the portal server.
Make sure the configured device ID is different than any other access devices communicating with the same portal authentication server.
# Set the device ID of the device to 0002.0010.100.00.
[Sysname] portal device-id 0002.0010.100.00
portal domain (interface view)
Use portal [ ipv6 ] domain to specify a portal authentication domain on an interface. All portal users accessing through the interface must use the authentication domain.
Use undo portal [ ipv6 ] domain to delete the configured portal authentication domain.
portal [ ipv6 ] domain domain-name
No portal authentication domain is configured on an interface.
Interface view
ipv6: Specifies an authentication domain for IPv6 portal users. Do not specify this keyword for IPv4 portal users.
domain-name: Specifies an ISP authentication domain by its name, a case-insensitive string of 1 to 255 characters.
You can specify both an IPv4 portal authentication domain and an IPv6 portal authentication domain on an interface.
Do not specify the ipv6 keyword for IPv4 portal users.
# Specify the authentication domain as my-domain for IPv4 portal users on VLAN-interface 100.
[Sysname–Vlan-interface100] portal domain my-domain
display portal
portal enable (interface view)
Use portal [ ipv6 ] enable to enable portal authentication.
Use undo portal [ ipv6 ] enable to disable portal authentication.
portal enable method { direct | layer3 | redhcp }
portal ipv6 enable method { direct | layer3 }
Interface view
ipv6: Enables IPv6 portal authentication. Do not specify this keyword for IPv4 portal authentication.
method: Specifies an authentication mode:
· direct—Direct authentication.
· layer3—Cross-subnet authentication.
· redhcp—Re-DHCP authentication.
To modify the portal authentication mode, first execute the undo portal [ ipv6 ] enable command to disable portal authentication and then execute the portal [ ipv6 ] enable command.
Make sure the device supports IPv6 ACL and IPv6 forwarding before you enable IPv6 portal authentication on the interface.
IPv6 portal authentication does not support the re-DHCP authentication mode.
Do not add a portal authentication-enabled Ethernet interface to an aggregation group. Otherwise, portal authentication cannot take effect on the interface.
# Enable direct IPv4 portal authentication on VLAN-interface 100.
[Sysname–Vlan-interface100] portal enable method direct
display portal
Use portal [ ipv6 ] fail-permit server to enable the portal fail-permit feature for a portal authentication server on the interface.
Use undo portal [ ipv6 ] fail-permit server to disable the portal fail-permit feature for the portal authentication server.
portal [ ipv6 ] fail-permit server server-name
Portal fail-permit is disabled for the portal authentication server.
Interface view
ipv6: Specifies an IPv6 portal authentication server. Do not specify this keyword for an IPv4 portal authentication server.
When portal fail-permit is enabled for a portal authentication server and a portal Web server on an interface, the interface disables portal authentication for portal users if either server is unreachable. Portal authentication resumes on the interface when both servers become reachable. After portal authentication resumes, unauthenticated portal users need to pass authentication to access network resources. Portal users who has passed authentication can continue accessing network resources.
You can enable portal fail-permit for at most one portal authentication server and one portal Web server on an interface.
# Enable portal fail-permit for portal authentication server pts1 on VLAN-interface 100.
[Sysname–Vlan-interface100] portal fail-permit server pts1
display portal
portal free-all except destination
Use portal free-all except destination to configure an IPv4 portal authentication destination subnet on an interface.
Use undo portal free-all except destination to delete the IPv4 portal authentication destination subnets on the interface.
portal free-all except destination ipv4-network-address { mask-length | mask }
undo portal free-all except destination [ ipv4-network-address ]
No IPv4 portal authentication destination subnet is configured on the interface. Portal users must pass portal authentication to access any subnet.
Interface view
ipv4-network-address: Specifies an IPv4 portal authentication subnet address.
mask-length: Specifies the subnet mask length for the authentication subnet address, in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal format.
Portal users on the interface are authenticated when accessing the specified authentication destination subnet (except IP addresses and subnets specified in portal-free rules). The users can access other subnets without portal authentication.
You can configure multiple authentication destination subnets.
If you do not specify the ipv4-network-address argument in the undo portal free-all except destination command, this command deletes all IPv4 portal authentication destination subnets on the interface.
Re-DHCP authentication does not support authentication destination subnets.
If you configure both an authentication source subnet and an authentication destination subnet on an interface, only the authentication destination subnet takes effect.
# Configure an IPv4 portal authentication destination subnet of 11.11.11.0/24 on VLAN-interface 2. Portal users need to pass authentication to access this subnet and can access other subnets without authentication.
[Sysname–Vlan-interface2] portal free-all except destination 11.11.11.0 24
display portal
portal free-rule
Use portal free-rule to configure an IP-based portal-free rule.
Use undo portal free-rule to delete portal-free rules.
portal free-rule rule-number { destination ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | source ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
portal free-rule rule-number { destination ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | source ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
undo portal free-rule { rule-number | all }
No IP-based portal-free rule is configured.
rule-number: Specifies a portal-free rule number. The value range for this argument is 0 to 4294967295.
destination: Specifies the destination information.
source: Specifies the source information.
ip ipv4-address: Specifies an IPv4 address for the portal-free rule.
{ mask-length | mask }: Specifies the subnet mask of the IPv4 address. The value range for the mask-length argument is 0 to 32. The mask argument is in dotted decimal format.
ipv6 ipv6-address: Specifies an IPv6 address for the portal-free rule.
prefix-length: Specifies the prefix length of the IPv6 address, in the range of 0 to 128.
ip any: Represents any IPv4 address.
ipv6 any: Represents any IPv6 address.
tcp tcp-port-number: Specifies a TCP port number for the portal-free rule, in the range of 0 to 65535.
udp udp-port-number: Specifies a UDP port number for the portal-free rule, in the range of 0 to 65535.
all: Specifies all portal-free rules.
interface interface-type interface-number: Specifies a Layer 3 interface on which the portal-free rule takes effect.
You can specify both the source and destination keyword for a portal-free rule. If you specify only one keyword, the other keyword does not act as a filtering criterion.
If you specify both a source port number and a destination port number for a portal-free rule, the two port numbers must belong to the same transport layer protocol.
If you do not specify a Layer 3 interface, the portal-free rule takes effect on all portal-enabled interfaces.
You cannot configure two portal-free rules with the same filtering criteria.
# Configure an IPv4-based portal-free rule:
· Set the rule number to 1.
· Specify the source IP address as 10.10.10.1/24, the destination IP address as 20.20.20.1, and the destination TCP port number as 23.
· Specify the interface where the rule is applied as VLAN-interface 1.
[Sysname] portal free-rule 1 destination ip 20.20.20.1 32 tcp 23 source ip 10.10.10.1 24 interface vlan-interface 1
With this rule, users in subnet 10.10.10.1/24 do not need to pass portal authentication on VLAN-interface 1 when they access services provided on TCP port 23 of host 20.20.20.1.
# Configure an IPv6-based portal-free rule:
· Set the rule number to 2.
· Specify the source IP address as 2000::1/64, the destination IP address as 2001::1, and the destination TCP port number as 23.
· Specify the interface as VLAN-interface 1.
[Sysname] portal free-rule 2 destination ipv6 2001::1 128 tcp 23 source ip 2000::1 64 interface vlan-interface 1
With this rule, users in subnet 2000::1/64 do not need to pass portal authentication on VLAN-interface 1 when they access services provided on TCP port 23 of host 2001::1.
display portal rule
portal free-rule destination
Use portal free-rule destination to configure a destination-based portal-free rule.
portal free-rule rule-number destination host-name
No destination-based portal-free rule is configured.
destination: Specifies the destination host.
host-name: Specifies the destination host by its name, a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, hyphens (-), underscores (_), dots (.), and asterisks (*). The host name string cannot be i, ip, ipv, or ipv6.
Before you configure destination-based portal-free rules, make sure a DNS server is deployed on the network.
You can configure a host name in one of the following ways:
· For exact match—Specify a complete host name. For example, if you configure the host name as abc.com.cn in the portal-free rule, only packets that contain the host name abc.com.cn match the rule. Packets that carry any other host names (such as dfabc.com.cn) do not match the rule.
· For fuzzy match—Specify a host name by placing the asterisk (*) wildcard character at the beginning or end of the host name string. For example, if you configure the host name as *abc.com.cn, abc*, or *abc*, packets that carry the host name ending with abc.com.cn, starting with abc, or including abc match the rule.
¡ The asterisk (*) wildcard character represents any characters. The device treats multiple consecutive asterisks as one.
¡ The configured host name cannot contain only asterisks (*).
The fuzzy match feature takes effect only on HTTP or HTTPS requests initiated by Web browsers.
You cannot configure two destination-based portal-free rules with the same destination information. Otherwise the system prompts you that the same rule already exists.
# Configure a destination-based portal-free rule: specify the rule number as 4 and host name as www.h3c.com. This rule allows the portal user who sends the HTTP/HTTPS request that carries the host name www.h3c.com to access network resources without authentication.
[Sysname] portal free-rule 4 destination www.h3c.com
display portal rule
portal free-rule source
Use portal free-rule source to configure a source-based portal-free rule. The filtering criteria include source MAC address, source interface, and source VLAN.
Use undo portal free-rule to delete a specific or all portal-free rules.
portal free-rule rule-number source { interface interface-type interface-number | mac mac-address | vlan vlan-id } *
No source-based portal-free rules exist.
interface interface-type interface-number: Specifies a source interface by its type and number for the portal-free rule.
mac mac-address: Specifies a source MAC address for the portal-free rule, in the form of H-H-H.
vlan vlan-id: Specifies a source VLAN ID for the portal-free rule. This option takes effect only on portal users that access the network through VLAN interfaces.
If you specify both the source VLAN and the source Layer 2 interface, the interface must be in the VLAN.
# Configure source-based portal-free rule: specify the rule number as 3, source MAC address as 1-1-1, and source VLAN ID as 10. This rule allows the portal user whose source MAC address is 1-1-1 from VLAN 10 to access network resources without authentication.
[Sysname] portal free-rule 3 source mac 1-1-1 vlan 10
display portal rule
portal ipv6 free-all except destination
Use portal ipv6 free-all except destination to configure an IPv6 portal authentication destination subnet on an interface.
Use undo portal ipv6 free-all except destination to delete IPv6 portal authentication destination subnets on the interface.
portal ipv6 free-all except destination ipv6-network-address prefix-length
undo portal ipv6 free-all except destination [ ipv6-network-address ]
No IPv6 portal authentication destination subnet is configured. Portal users must pass portal authentication to access any IPv6 subnet.
Interface view
ipv6-network-address: Specifies an IPv6 portal authentication destination subnet.
prefix-length: Specifies the prefix length of the IPv6 subnet, in the range of 0 to 128.
If you do not specify the ipv6-network-address argument in the undo portal ipv6 free-all except destination command, this command deletes all IPv6 portal authentication destination subnets on the interface.
# Configure an IPv6 portal authentication destination subnet of 1::2/16 on VLAN-interface 2.
[Sysname–Vlan-interface2] portal ipv6 free-all except destination 1::2 16
display portal
portal ipv6 layer3 source
Use portal ipv6 layer3 source to configure an IPv6 portal authentication source subnet.
Use undo portal ipv6 layer3 source to delete IPv6 portal authentication source subnets.
portal ipv6 layer3 source ipv6-network-address prefix-length
undo portal ipv6 layer3 source [ ipv6-network-address ]
No IPv6 portal authentication source subnet is configured. Portal users from any IPv6 subnet must pass portal authentication.
Interface view
ipv6-network-address: Specifies an IPv6 portal authentication source subnet address.
With IPv6 authentication source subnets configured, only packets from IPv6 users on the authentication source subnets can trigger portal authentication. If an unauthenticated IPv6 user is not on any authentication source subnet, the access device discards all the user's packets that do not match any portal-free rule.
If you do not specify the ipv6-network-address argument in the undo portal ipv6 layer3 source command, this command deletes all IPv6 portal authentication source subnets on the interface.
Only cross-subnet authentication supports authentication source subnets.
# Configure an IPv6 portal authentication source subnet of 1::1/16 on VLAN-interface 2. Only portal users from subnet 1::1/16 trigger portal authentication.
[Sysname–Vlan-interface2] portal ipv6 layer3 source 1::1 16
display portal
portal ipv6 user-detect
Use portal ipv6 user-detect to enable online detection of IPv6 portal users.
Use undo portal user-detect to disable online detection of IPv6 portal users.
portal ipv6 user-detect type { icmpv6 | nd } [ retry retries ] [ interval interval ] [ idle time ]
undo portal ipv6 user-detect
Online detection of IPv6 portal users is disabled.
Interface view
type: Specifies the detection type.
· icmpv6—ICMPv6 detection.
· nd—ND detection.
retry retries: Sets the maximum number of detection attempts, in the range of 1 to 10. The default value is 3.
interval interval: Sets a detection interval in the range of 1 to 1200 seconds. The default interval is 3 seconds.
idle time: Sets the user idle timeout in the range of 60 to 3600 seconds. The default idle timeout is 180 seconds. When the timeout expires, online detection of portal users is started.
If the device receives no packets from a portal user within the idle time, the device detects the user's online status as follows:
· ICMPv6 detection—Sends ICMPv6 requests to the user at configurable intervals to detect the user status.
¡ If the device receives a reply within the maximum number of detection attempts, it considers that the user is online and stops sending detection packets. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡ If the device receives no reply after the maximum number of detection attempts, the device logs out the user.
· ND detection—Sends ND requests to the user and detects the ND entry status of the user at configurable intervals.
¡ If the ND entry of the user is refreshed within the maximum number of detection attempts, the device considers that the user is online and stops detecting the user's ND entry. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡ If the ND entry of the user is not refreshed after the maximum number of detection attempts, the device logs out the user.
Direct authentication and re-DHCP authentication support both ND detection and ICMPv6 detection. Cross-subnet authentication only supports ICMPv6 detection.
If the access device filters out ICMPv6 packets, ICMPv6 detection might fail and result in the logout of portal users. Make sure the access device does not block ICMPv6 packets before you enable ICMPv6 detection on an interface.
# Enable online detection of IPv6 portal users on VLAN-interface 100. Configure the detection type as ND, the maximum number of detection attempts as 5, the detection interval as 10 seconds, and the user idle timeout as 300 seconds.
[Sysname–Vlan-interface100] portal ipv6 user-detect type nd retry 5 interval 10 idle 300
display portal
portal layer3 source
Use portal layer3 source to configure an IPv4 portal authentication source subnet.
Use undo portal layer3 source to delete IPv4 portal authentication source subnets.
portal layer3 source ipv4-network-address { mask-length | mask }
undo portal layer3 source [ ipv4-network-address ]
No IPv4 portal authentication source subnet is configured. Portal users from any IPv4 subnet must pass portal authentication.
Interface view
ipv4-network-address: Specifies an IPv4 portal authentication source subnet address.
mask-length: Specifies the subnet mask length of the IPv4 address, in the range of 0 to 32.
With IPv4 authentication source subnets configured, only packets from IPv4 users on the authentication source subnets can trigger portal authentication. If an unauthenticated IPv4 user is not on any authentication source subnet, the access device discards all the user's packets that do not match any portal-free rule.
If you do not specify the ipv4-network-address argument in the undo portal layer3 source command, this command deletes all IPv4 portal authentication source subnets on the interface.
# Configure an IPv4 portal authentication source subnet of 10.10.10.0/24 on VLAN-interface 2.
[Sysname–Vlan-interface2] portal layer3 source 10.10.10.0 24
display portal
portal local-web-server
Use portal local-web-server to enable HTTP- or HTTPS-based local portal Web service and enter its view.
Use undo portal local-web-server to disable the local portal Web service.
portal local-web-server { http | https ssl-server-policy policy-name [ tcp-port port-number ] }
undo portal local-web-server { http | https }
Local portal Web service is disabled.
http: Specifies the HTTP-based local portal Web service, which uses HTTP to exchange authentication information with clients.
https: Specifies the HTTPS-based local portal Web service, which uses HTTPS to exchange authentication information with clients.
ssl-server-policy policy-name: Specifies an existing SSL server policy for HTTPS. The policy name is a case-insensitive string of 1 to 31 characters.
tcp-port port-number: Specifies the listening TCP port number for the HTTPS-based local portal Web service. The value range for the port-number argument is 1 to 65535. The default port number is 443.
In the local portal Web service, the access device also acts as the portal Web server and the portal authentication server. No external portal Web server and portal authentication server are needed.
For an interface to use the local portal Web service, the URL of the portal Web server specified for the interface must meet the following requirements:
· The IP address in the URL must be a local IP address on the device.
· The URL must be ended with /portal/. For example: http://1.1.1.1/portal/.
You cannot delete an SSL server policy by using the undo ssl server-policy command when the policy is associated with HTTPS.
To specify a new SSL server policy for HTTPS, first execute the undo form of this command to disable the existing HTTPS-based local portal Web service.
When you specify the listening TCP port number for the HTTPS-based local portal Web service, follow these restrictions and guidelines:
· For the HTTPS-based local portal Web service and other services that use HTTPS:
¡ If they use the same SSL server policy, they can use the same TCP port number to listen to HTTPS.
¡ If they use different SSL server policies, they cannot use the same TCP port number to listen to HTTPS.
· Do not configure the HTTPS listening TCP port number as the port number used by a known protocol (except HTTPS) or other service. For example, do not specify port numbers 80 and 23, which are used by HTTP and Telnet, respectively.
· Do not configure the same TCP port number for HTTP and HTTPS local portal Web services.
# Enable the HTTP-based local portal Web service and enter its view.
[Sysname] portal local-web-server http
[Sysname-portal-local-websvr-http] quit
# Enable the HTTPS-based local portal Web service and associate SSL server policy policy1 with the service.
[Sysname] portal local-web-server https ssl-server-policy policy1
[Sysname-portal-local-websvr-https] quit
# Change the SSL server policy to policy2.
[Sysname] undo portal local-web-server https
[Sysname] portal local-web-server https ssl-server-policy policy2
# Enable the HTTPS-based local portal Web service. In the service, the associated SSL server policy is policy1 and the listening port number is 442.
[Sysname] portal local-web-server https ssl-server-policy policy1 tcp-port 442
default-logon-page
ssl server-policy
portal log enable
Use portal log enable to enable logging for portal user logins and logouts.
Use undo user log enable to disable logging for portal user logins and logouts.
portal log enable
undo portal log enable
Portal user login and logout logging is disabled.
This feature logs information about portal user login and logout events, including the username, IP address, user's MAC address, interface name, VLAN, and reason for login failure. For portal log messages to be sent correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
# Enable logging for portal user logins and logouts.
[Sysname] portal user log enable
Use portal mac-trigger-server to create a MAC binding server and enter its view, or enter the view of an existing MAC binding server.
Use undo portal mac-trigger-server to delete the MAC binding server.
portal mac-trigger-server server-name
undo portal mac-trigger-server server-name
No MAC binding servers exist.
server-name: Specifies a MAC binding server name, a case-sensitive string of 1 to 32 characters.
After you create a MAC binding server, you can configure MAC binding server parameters, such as the server's IP address, VPN instance, port number, and the free-traffic threshold.
# Create MAC binding server mts and enter its view.
[Sysname] portal mac-trigger-server mts
display portal mac-trigger-server
portal max-user
Use portal max-user to set the maximum number of total portal users allowed in the system.
Use undo portal max-user to restore the default.
portal max-user max-number
The total number of portal users allowed in the system is not limited.
max-number: Specifies the maximum number of total portal users in the system. The value range for this argument is 1 to 4294967295.
If you configure the maximum total number smaller than the number of current online portal users on the device, this command still takes effect. The online users are not affected by this command, but the system forbids new portal users to log in.
This command sets the maximum number of online IPv4 and IPv6 portal users in all.
Make sure the total number of the maximum IPv4 and IPv6 portal users allowed on all interfaces does not exceed the system-allowed maximum number. Otherwise, the exceeding portal users will not be able to log in to the device.
# Set the maximum number of online portal users allowed in the system to 100.
[Sysname] portal max-user 100
display portal user
portal nas-id-profile
Use portal nas-id-profile to specify a NAS-ID profile for an interface.
Use undo portal nas-id-profile to restore the default.
portal nas-id-profile profile-name
No NAS-ID profile is specified for an interface.
Interface view
profile-name: Specifies the name of a NAS-ID profile, a case-insensitive string of 1 to 31 characters.
A NAS-ID profile defines the binding relationship between VLANs and NAS-IDs. To configure a NAS-ID profile, use the aaa nas-id profile command.
Portal access matches only the inner VLAN ID of QinQ packets. For more information about QinQ, see Layer 2—LAN Switching Configuration Guide.
If an interface is specified with a NAS-ID profile, the interface prefers to use the bindings defined in the profile.
If no NAS-ID profile is specified for an interface or no matching binding is found in the specified profile, the device uses the device name as the interface NAS-ID.
# Specify NAS-ID profile aaa for VLAN-interface 2.
[Sysname-Vlan-interface2] portal nas-id-profile aaa
aaa nas-id profile
portal nas-port-id format
Use portal nas-port-id format to specify the NAS-Port-Id attribute format.
Use undo portal nas-port-id format to restore the default.
portal nas-port-id format { 1 | 2 | 3 | 4 }
The format for the NAS-Port-Id attribute is format 2.
1: Uses format 1 for the NAS-Port-Id attribute.
2: Uses format 2 for the NAS-Port-Id attribute.
3: Uses format 3 for the NAS-Port-Id attribute.
4: Uses format 4 for the NAS-Port-Id attribute.
The NAS-Port-Id format supported by RADIUS servers varies by vendor. Use this command to specify the format of the NAS-Port-Id attribute in the RADIUS packets sent for portal users to the RADIUS server. The device then automatically constructs a value for the NAS-Port-Id attribute in the specified format to meet the RADIUS server requirements.
Format 1 contains three space-separated strings: interface-type port-location access-node-id. Spaces are not allowed within a string.
· The interface-type string specifies the interface type of the NAS port. Available options include:
¡ atm—ATM interface.
¡ eth—Common Ethernet interface.
¡ trunk—Ethernet trunk interface.
¡ 0—The interface type information will be reported by the access node to the BRAS.
· The port-location string represents the location of the access line on the BRAS. Its format is NAS_slot/NAS_subslot/NAS_port:XPI.XCI.
NAS_slot |
Slot number of the BRAS, in the range of 0 to 31. |
NAS_subslot |
Subslot number of the BRAS, in the range of 0 to 31. |
NAS_Port |
Port number of the BRAS, in the range of 0 to 63. |
XPI.XCI |
For ATM interfaces: · XPI is VPI in the range of 0 to 255. · XCI is VCI in the range of 0 to 65535. For Ethernet interfaces or Ethernet trunk interfaces: · XPI is PVLAN in the range of 0 to 4095. This field is set to 4096 if there is no PVLAN. · XCI is CVLAN in the range of 0 to 4095. This field is set to 4096 if the user is not assigned to a VLAN as in the situation where the end user device is directly connected to a BRAS port. |
For the access node to report its access line information to the BRAS, all fields will be set to 0s except for the XPI and XCI fields.
· The access-node-id string specifies the attributes the of BRAS. Its format is AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port:ANI_XPI.ANI_XCI, in which the :ANI_XPI.ANI_XCI portion is optional.
AccessNodeIdentifier |
Identifier description of the access node, a string not longer than 50 characters without spaces. |
ANI_rack |
Rack number of the access node, in the range of 0 to 15. |
ANI_frame |
Frame number of the access node, in the range of 0 to 31. |
ANI_slot |
Slot number of the access node, in the range of 0 to 127. |
ANI_subslot |
Subslot number of the access node, in the range of 0 to 31. |
ANI_port |
Port number of the access node, in the range of 0 to 255. |
ANI_XPI.ANI_XCI |
Optional. This field is mainly used to carry CPE-side service information, identifying the further service type requirement. For example, use this field to identify specific services in a multi-PVC scenario. For ATM interfaces: · ANI_XPI is VPI in the range of 0 to 255. · ANI_XCI is VCI in the range of 0 to 65535. For Ethernet interfaces or Ethernet trunk interfaces: · ANI_XPI is PVLAN in the range of 0 to 4095. This field is set to 4096 if there is no PVLAN. · ANI_XCI is CVLAN in the range of 0 to 4095. This field is set to 4096 if the user is not assigned to a VLAN as in the situation where the end user device is directly connected to a BRAS port. |
If the device does not have rack, frame, or subslot information, 0 is padded in the corresponding field.
For ATM interfaces, all fields in the access-node-id string are filled with 0s except for the ANI_XPI and ANI_XCI fields.
· Examples of format 1:
NAS-Port-Id |
atm 31/31/7:255.65535 0/0/0/0/0/0 |
The subscriber interface is an ATM interface. The slot number is 31, the BRAS subslot number is 31, the BRAS port number is 7, the VPI is 255, and the VCI is 65535. |
eth 31/31/7:1234.2345 0/0/0/0/0/0 |
The subscriber interface is an Ethernet interface. The slot number is 31, the subslot number is 31, the port number is 7, the PVLAN is 1234, and the CVLAN is 2345. If there is no PVLAN, 1234 will be replaced with 4096. |
eth 31/31/7:4096.2345 guangzhou001/1/31/63/31/127 |
The subscriber interface is an Ethernet interface. The slot number is 31, the subslot number is 31, the port number is 7, and the VLAN ID is 2345. The access node identifier of the DSLAM is guangzhou001, the rack number is 1, the frame number is 31, the slot number is 63, subslot number is 31, and the port number is 127. |
0 0/0/0:4096.1234 guangzhou001/0/31/63/31/127 |
The 0 and 0/0/0 strings indicate that BRAS does not have access line information and will use the information received from the access node. After receiving access line information from the access node, the BRAS transparently delivers the information or complements the BRAS access link information as configured. For example, the BRAS complements the access line information as eth 31/31/7:4096.1234 guangzhou001/0/31/63/31/127. |
Format 2 is SlotID00IfNOVlanID.
· SlotID—Slot number, a string of 2 characters.
· IfNO—Slot number, a string of 3 characters.
· VlanID—VLAN ID, a string of 9 characters.
Format 3 is SlotID00IfNOVlanIDDHCPoption.
· IfNO—Interface number, a string of 3 characters.
· DHCPoption—DHCP option 82 is appended for IPv4 users and DHCP option 1 is appended for IPv6.
Format 4 is slot=**;subslot=**;port=**;vlanid=**;vlanid2=**.
· For non-VLAN interfaces, the slot=**;subslot=**;port=**;vlanid=0 format is used.
· For interfaces that terminate only the outermost VLAN tag, the slot=**;subslot=**;port=**;vlanid=** format is used.
# Set the format of the NAS-Port-Id attribute to format 1.
[Sysname] portal nas-port-id format 1
portal nas-port-type
Use portal nas-port-type to configure the NAS-Port-Type attribute carried in outgoing RADIUS requests.
Use undo portal nas-port-type to restore the default.
portal nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
The NAS-Port-Type carried in outgoing RADIUS requests is Ethernet (attribute value 15).
Interface view
802.11: Specifies the NAS port type as Wireless-IEEE 802.11 (attribute value 19).
adsl-cap: Specifies the NAS port type as ADSL-CAP (attribute value 12).
adsl-dmt: Specifies the NAS port type as ADSL-DMT (attribute value 13).
async: Specifies the NAS port type as Async (attribute value 0).
cable: Specifies the NAS port type as Cable (attribute value 17).
ethernet: Specifies the NAS port type as Ethernet (attribute value 15).
g.3-fax: Specifies the NAS port type as G.3 Fax (attribute value 10).
hdlc: Specifies the NAS port type as HDLC Clear Channel (attribute value 7).
idsl: Specifies the NAS port type as IDSL (attribute value 14).
isdn-async-v110: Specifies the NAS port type as ISDN Async V.110 (attribute value 4).
isdn-async-v120: Specifies the NAS port type as ISDN Async V.120 (attribute value 3).
isdn-sync: Specifies the NAS port type as ISDN Sync (attribute value 2).
piafs: Specifies the NAS port type as PIAFS (attribute value 6).
sdsl: Specifies the NAS port type as SDSL (attribute value 11).
sync: Specifies the NAS port type as Sync (attribute value 1).
virtual: Specifies the NAS port type as Virtual (attribute value 5).
wireless-other: Specifies the NAS port type as Wireless-Other (attribute value 18).
x.25: Specifies the NAS port type as X.25 (attribute value 8).
x.75: Specifies the NAS port type as X.75 (attribute value 9).
xdsl: Specifies the NAS port type as xDSL (attribute value 16).
# Configure the NAS-Port-Type carried in outgoing RADIUS requests as SDSL on VLAN-interface 20.
[Sysname] interface vlan-interface 20
[Sysname-Vlan-interface20] portal nas-port-type sdsl
portal pre-auth domain
Use portal [ ipv6 ] pre-auth domain to specify a preauthentication domain for portal users.
Use undo portal [ ipv6 ] pre-auth domain to restore the default.
portal [ ipv6 ] pre-auth domain domain-name
No preauthentication domain for portal users is specified for portal users.
Interface view
ipv6: Specifies IPv6 portal users. Do not specify this keyword for IPv4 portal users.
domain-name: Specifies an existing ISP domain by its name, a case-insensitive string of 1 to 255 characters. The string cannot contain the following characters: slashes (/), backslashes (\), vertical bars (|), quotation marks ("), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), and at signs (@).
After you configure a preauthentication domain on a portal-enabled interface, the device authorizes users on the interface as follows:
1. After an unauthenticated user obtains an IP address, the user is assigned authorization attributes (such as ACL) configured for the preauthentication domain.
An unauthenticated user who is authorized the authorization attributes in a preauthentication domain is called a preauthentication user.
2. After the user passes portal authentication, the user is assigned new authorization attributes from the AAA server.
3. After the user goes offline, the user is reassigned the authorization attributes in the preauthentication domain.
The preauthentication domain takes effect only on portal users with IP addresses assigned by DHCP or DHCPv6.
Make sure you specify an existing ISP domain as a preauthentication domain. If the specified ISP domain does not exist, the device might operate incorrectly.
You must delete a preauthentication domain (by using the undo portal [ ipv6 ] pre-auth domain command) and reconfigure it in the following situations:
· You create the ISP domain after specifying it as the preauthentication domain.
· You delete the specified ISP domain and then re-create it.
If you change the preauthentication domain on an interface, the interface uses the new preauthentication domain for both new and existing preauthentication users.
If the authorization ACL attribute in the preauthentication domain is modified, the modified attribute takes effect only on new preauthentication users. Existing preauthentication users use the original authorization attribute.
# Create preauthentication domain abc for VLAN-interface 1.
[Sysname-Vlan-interface1] portal pre-auth domain abc
display portal
portal pre-auth ip-pool
Use portal [ ipv6 ] pre-auth ip-pool to specify a preauthentication IP address pool for portal users.
Use undo portal [ ipv6 ] pre-auth ip-pool to restore the default.
portal [ ipv6 ] pre-auth ip-pool pool-name
No preauthentication IP address pool is specified for portal users.
Interface view
pool-name: Specifies an IP address pool by its name, a case-insensitive string of 1 to 63 characters.
You must use this command to specify a preauthentication IP address pool on a portal-enabled interface in the following situation:
· Portal users access the network through a subinterface of the portal-enabled interface.
· The subinterface does not have an IP address.
· Portal users need to obtain IP addresses through DHCP.
DHCP assigns an IP address from the specified IP address pool to a user. Then, the user can use this IP address to perform portal authentication.
The specified IP address pool takes effect when the following requirements are met:
· The direct portal authentication mode is used on the interface.
· The specified IP address pool must have existed and been correctly configured.
# Create IPv4 address pool abc for VLAN-interface 100.
[Sysname–Vlan-interface100] portal pre-auth ip-pool abc
dhcp server ip-pool (Layer 3—IP Services Command Reference)
display portal
ipv6 dhcp pool (Layer 3—IP Services Command Reference)
portal refresh enable
Use portal refresh { arp | nd } enable to enable the Rule ARP or ND entry feature for portal clients.
Use undo portal refresh { arp | nd } enable to disable the Rule ARP or ND entry feature for portal clients.
The Rule ARP or ND entry feature is enabled for portal clients.
arp: Enables the Rule ARP entry feature.
nd: Enables the Rule ND entry feature.
When the Rule ARP or ND entry feature is enabled for portal clients, ARP or ND entries for portal clients are Rule entries after the clients come online. The Rule ARP or ND entries will not age out and will be deleted immediately after the portal clients go offline.
If portal clients go offline and then try to come online before the ARP or ND entries are relearned for them, the clients will fail the authentication. In this case, disable this feature so that ARP or ND entries are dynamic entries after the clients come online. The dynamic ARP or ND entries are deleted only when they age out.
Enabling or disabling of this feature does not affect existing Rule/dynamic ARP or ND entries for portal users.
# Disable the Rule ARP entry feature for portal clients.
[Sysname] undo portal refresh arp enable
portal roaming enable
Use portal roaming enable to enable portal roaming.
Use undo portal roaming enable to disable portal roaming.
Portal roaming is disabled. An online portal user cannot roam in its VLAN.
Portal roaming applies only to portal users that log in from VLAN interfaces.
This command cannot be executed when online users or preauthentication portal users are present on the device.
If portal roaming is enabled, an online portal user can access network resources from any Layer 2 port in its local VLAN. If portal roaming is disabled, the portal user can access network resources only from the Layer 2 port on which it passes authentication.
For portal roaming to take effect, you must disable the Rule ARP or ND entry feature by using the undo portal refresh { arp | nd } enable command.
# Enable portal roaming.
[Sysname] portal roaming enable
portal server
Use portal server to create a portal authentication server and enter its view, or enter the view of an existing portal authentication server.
Use undo portal server to delete the specified portal authentication server.
portal server server-name
undo portal server server-name
No portal authentication servers exist.
server-name: Specifies a portal authentication server by its name, a case-sensitive string of 1 to 32 characters.
In portal authentication server view, you can configure the following parameters and features for the portal authentication server:
· IP address of the server.
· Destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server.
· MPLS L3VPN where the portal authentication server resides.
· Pre-shared key for communication between the access device and the server.
· Server detection feature.
You can configure multiple portal authentication servers for an access device.
# Create portal authentication server pts and enter its view.
display portal server
portal user-detect
Use portal user-detect to enable online detection of IPv4 portal users.
Use undo portal user-detect to disable online detection of IPv4 portal users.
portal user-detect type { arp | icmp } [ retry retries ] [ interval interval ] [ idle time ]
Online detection of IPv4 portal users is disabled.
Interface view
· arp—ARP detection.
· icmp—ICMP detection.
idle time: Sets a user idle timeout in the range of 60 to 3600 seconds. The default idle timeout is 180 seconds. When the timeout expires, online detection of IPv4 portal users is started.
If the device receives no packets from a portal user within the configured idle time, the device detects the user's online status as follows:
· ICMP detection—Sends ICMP requests to the user at configurable intervals to detect the user status.
· ARP detection—Sends ARP requests to the user and detects the ARP entry status of the user at configurable intervals.
¡ If the ARP entry of the user is refreshed within the maximum number of detection attempts, the device considers that the user is online and stops detecting the user's ARP entry. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡ If the ARP entry of the user is not refreshed after the maximum number of detection attempts, the device logs out the user.
Direct authentication and re-DHCP authentication support both ARP detection and ICMP detection. Cross-subnet authentication only supports ICMP detection.
If the access device filters out ICMP packets, ICMP detection might fail and result in the logout of portal users. Make sure the access device does not block ICMP packets before you enable ICMP detection on an interface.
# Enable online detection of IPv4 portal users on VLAN-interface 100. Configure the detection type as ARP, the maximum number of detection attempts as 5, the detection interval as 10 seconds, and the user idle timeout as 300 seconds.
[Sysname–Vlan-interface100] portal user-detect type arp retry 5 interval 10 idle 300
display portal
portal user-dhcp-only (interface view)
Use portal user-dhcp-only to allow only users with DHCP-assigned IP addresses to pass portal authentication.
Use undo portal user-dhcp-only to restore the default.
portal [ ipv6 ] user-dhcp-only
undo portal [ ipv6 ] user-dhcp-only
Both users with DHCP-assigned IP addresses and users with static IP addresses can pass portal authentication to come online.
Interface view
With this feature enabled, users with static IP addresses cannot pass portal authentication to get online.
To ensure that IPv6 users can pass portal authentication when this feature is enabled, disable the temporary IPv6 address feature on terminal devices. Otherwise, IPv6 users will use temporary IPv6 addresses to access the IPv6 network and will fail portal authentication.
# Allow only users with DHCP-assigned IP addresses on VLAN-interface 100 to pass portal authentication.
[Sysname–Vlan-interface100] portal user-dhcp-only
display portal
portal user-rule assign-check enable
Use portal user-rule assign-check enable to enable the device to check the issuing of category-2 portal filtering rules.
Use undo portal user-rule assign-check enable to disable the device from checking the issuing of category-2 portal filtering rules.
The device does not check the issuing of category-2 portal filtering rules.
To display category-2 portal filtering rules, use the display portal rule dynamic command.
# Enable the device to check the issuing of category-2 portal filtering rules.
[Sysname] portal rule assign-check enable
display portal rule
portal web-proxy port
Use portal web-proxy port to specify the port number of a Web proxy server.
Use undo portal web-proxy port to delete port numbers of Web proxy servers.
portal web-proxy port port-number
undo portal web-proxy port { port-number | all }
No port numbers of Web proxy servers are specified. Proxied HTTP requests are dropped.
port-number: Specifies the port number of a Web proxy server. The value range for this argument is 1 to 65535.
all: Specifies all port numbers of Web proxy servers.
To allow HTTP requests proxied by a Web proxy server to trigger portal authentication, specify the port number of the Web proxy server on the device. If a Web proxy server port is not specified on the device, HTTP requests proxied by the Web proxy server are dropped, and portal authentication cannot be triggered.
You can configure this command multiple times to specify multiple port numbers of Web proxy servers.
If a user's browser uses the Web Proxy Auto-Discovery (WPAD) protocol to discover Web proxy servers, you must perform the following tasks on the device:
· Specify the port numbers of the Web proxy servers on the device.
· Configure portal-free rules to allow user packets destined for the IP address of the WPAD server to pass without authentication.
If portal users enable Web proxy in their browsers, the users must add the IP address of the portal authentication server as a proxy exception in their browsers. Then, HTTP packets that the users send to the portal authentication server will not be sent to Web proxy servers.
You cannot specify Web proxy server port 443 on the device.
# Specify Web proxy server port 8080.
[Sysname] portal web-proxy port 8080
portal web-server
Use portal web-server to create a portal Web server and enter its view, or enter the view of an existing portal Web server.
Use undo portal web-server to delete a portal Web server.
portal web-server server-name
undo portal web-server server-name
No portal Web servers exist.
The portal Web server pushes portal authentication pages to portal users during authentication. The access device redirects HTTP requests of unauthenticated portal users to the portal Web server. In portal Web server view, you can configure the URL and URL parameters for the portal Web server and the portal Web server detection feature.
# Create portal Web server wbs and enter its view.
[Sysname] portal web-server wbs
[Sysname-portal-websvr-wbs]
display portal web-server
reset portal packet statistics
Use reset portal packet statistics to clear packet statistics for portal authentication servers.
reset portal packet statistics [ server server-name ]
If you do not specify the server server-name option, this command clears packet statistics for all portal authentication servers.
# Clear packet statistics for portal authentication server pts.
<Sysname> reset portal packet statistics server pts
display portal packet statistics
server-detect (portal authentication server view)
Use server-detect to enable portal authentication server detection. After server detection is enabled for a portal authentication server, the device periodically detects portal packets from the server to identify its reachability status.
Use undo server-detect to disable portal authentication server detection.
server-detect [ timeout timeout ] log
undo server-detect
Portal authentication server detection is disabled.
Portal authentication server view
timeout timeout: Specifies the detection timeout in the range of 10 to 3600 seconds. The default is 60 seconds.
log: Configures the device to send a log message after detecting reachability status change of the portal authentication server. The log message contains the name, the original state, and the current state of the portal authentication server.
The portal authentication server detection feature takes effect only when the device has a portal-enabled interface.
To test server reachability by detecting heartbeat packets, you must enable the server heartbeat feature on the portal authentication server. Only the IMC portal authentication server supports sending heartbeat packets.
The detection timeout configured on the device must be greater than the server heartbeat interval configured on the portal authentication server.
If the device receives portal packets from the portal authentication server before the detection timeout expires and verifies the correctness of the packets, the device considers the portal authentication server is reachable. Otherwise, the device considers the portal authentication server is unreachable.
# Enable server detection for portal authentication server pts:
· Set the detection timeout to 600 seconds.
· Configure the device to send a log message if the server reachability status changes.
[Sysname] portal server pts
[Sysname-portal-server-pts] server-detect timeout 600 log
portal server
server-detect (portal Web server view)
Use server-detect to enable portal Web server detection.
Use undo server-detect to disable portal Web server detection.
server-detect [ interval interval ] [ retry retries ] log
undo server-detect
Portal Web server detection is disabled.
Portal Web server view
interval interval: Specifies a detection interval in the range of 10 to 1200 seconds. The default is 20 seconds.
retry retries: Specifies the maximum number of consecutive detection failures, in the range of 1 to 10. The default is 3. If the number of consecutive failed detections reaches this threshold, the device considers the server as unreachable.
log: Configures the device to send a log message after detecting reachability status change of the portal Web server. The log message contains the name, the original state, and the current state of the portal Web server.
The access device performs server detection independently. No configuration on the portal Web server is required for the detection.
The portal Web server detection feature takes effect only when the URL of the portal Web server is specified and the device has a portal-enabled interface.
# Enable server detection for portal Web server wbs:
· Set the detection interval to 600 seconds.
· Set the maximum number of consecutive detection failures to 2.
· Configure the device to send a log message after server reachability status changes.
[Sysname-portal-websvr-wbs] server-detect interval 600 retry 2 log
portal web-server
server-type (portal authentication/Web server view)
Use server-type to specify the type of a portal authentication server or portal Web server.
Use undo server-type to restore the default.
server-type imc
undo server-type
The type of the portal authentication server and portal Web server is IMC.
imc: Specifies the portal server type as IMC.
Specify the portal server type on the device with the server type the device actually uses.
# Specify the type of portal authentication server as imc.
[Sysname-portal-server-pts] server-type imc
# Specify the type of portal Web server as imc.
[Sysname] portal web-server pts
[Sysname-portal-websvr-pts] server-type imc
server-type (MAC binding server view)
Use server-type to specify the type of a MAC binding server.
server-type imc
undo server-type
The type of the MAC binding server is IMC.
imc: Specifies the MAC binding server type as IMC.
# Specify the type of MAC binding server as imc.
[Sysname-portal-mac-trigger-server-mts] server-type imc
tcp-port
Use tcp-port to configure a listening TCP port for the local portal Web service.
Use undo tcp-port to restore the default.
undo tcp-port
The listening TCP port number for HTTP is 80 and that for HTTPS is the TCP port number set by the portal local-web-server command.
Local portal Web service view
port-number: Specifies the listening TCP port number in the range of 1 to 65535.
To use the local portal Web service, make sure the port number in the portal Web server URL and the port number configured in this command are the same.
For successful local portal authentication, follow these guidelines:
· Do not configure the listening TCP port number for a local portal Web service as the port number used by a known protocol. For example, do not specify port numbers 21 and 23, which are used by FTP and Telnet, respectively.
· Do not configure the HTTP listening port number as the default HTTPS listening port number 443.
· Do not configure the HTTPS listening port number as the default HTTP listening port number 80.
· Do not configure the same listening port number for HTTP and HTTPS.
# Set the listening port number to 2331 for the HTTP-based local portal Web service.
[Sysname-portal-local-websvr-http] tcp-port 2331
url
Use url to specify a URL for a portal Web server.
Use undo url to restore the default.
url url-string
undo url
No URL is specified for a portal Web server.
url-string: Specifies a URL for the portal Web server, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
This command specifies a URL that can be accessed through standard HTTP or HTTPS. The URL should start with http:// or https://. If the URL you specify does not start with http:// or https://, the system considers the URL begins with http:// by default.
To redirect users' HTTPS requests to the portal Web server URL, you must specify the HTTPS redirect listening port number by using the http-redirect https-port command. For more information about this command, see HTTP redirect commands in Layer 3—IP Services Command Reference.
# Configure the URL for portal Web server wbs as http://www.test.com/portal.
[Sysname-portal-websvr-wbs] url http://www.test.com/portal
url-parameter
Use url-parameter to configure the parameters carried in the URL of a portal Web server. The access device redirects a portal user by sending the URL with the parameters to the user.
Use undo url-parameter to delete the parameters carried in the URL of the portal Web server.
url-parameter param-name { original-url | source-address | source-mac [ encryption { aes | des } key { cipher | simple } string ] | value expression }
undo url-parameter param-name
No URL parameters are configured for a portal Web server.
param-name: Specifies a URL parameter name, a case-sensitive string of 1 to 32 characters. Content of the parameter is determined by the following keyword you specify.
original-url: Specifies the URL of the original webpage that a portal user visits.
source-address: Specifies the user IP address.
source-mac: Specifies the user MAC address.
encryption: Specifies the encryption algorithm to encrypt the MAC address of the user.
aes: Specifies the AES algorithm.
des: Specifies the DES algorithm.
key: Specifies a key for encryption.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the case-sensitive key string. The string length varies by the selected encryption method:
· If des cipher is specified, the string length is 41 characters.
· If des simple is specified, the string length is 8 characters.
· If aes cipher is specified, the string length is 1 to 73 characters.
· If aes simple is specified, the string length is 1 to 31 characters.
value expression: Specifies a custom case-sensitive string of 1 to 256 characters. The string can include question marks (?). If you enter a question mark (?) in the place of the expression argument, the CLI does not display help information for this argument.
You can configure multiple URL parameters.
If you execute this command multiple times to configure the same URL parameter, the most recent configuration takes effect.
After you configure the URL parameters, the access device sends the portal Web server URL with these parameters to portal users. For example, assume that the URL of a portal Web server is http://www.test.com/portal, and you execute the url-parameter userip source-address and url-parameter userurl value http://www.abc.com/welcome commands. Then, the access device sends to the user whose IP address is 1.1.1.1 the URL http://www.test.com/portal?userip=1.1.1.1&userurl=http://www.abc.com/welcome.
When you configure the param-name argument in this command, you must use the URL parameter name supported by the actual portal server. Different portal server types support different URL parameter names.
For example, the IMC server supports parameter names userurl, userip, and usermac for the keywords original-url, source-address, and source-mac, respectively. To carry the user IP information in the portal Web server URL, you must configure the parameter name as userip and specify the source-address keyword.
If you specify the encryption algorithm for a parameter, the redirection URL carries the encrypted value for the parameter. Execute the url-parameter usermac source-mac encryption des key simple 12345678 command. Then the access device sends to the user with MAC address 1111-1111-1111 the URL http://www.test.com/portal?usermac=xxxxxxxxx&userip=1.1.1.1&userurl=http://www.test.com/welcome, where xxxxxxxxx represents the encrypted user MAC address.
# Configure URL parameters userip and userurl for the portal Web server wbs. Configure the value of the userip parameter as source-address (the IP addresses of users) and that of the userurl parameter as http://www.abc.com/welcome.
[Sysname-portal-websvr-wbs] url-parameter userip source-address
[Sysname-portal-websvr-wbs] url-parameter userurl value http://www.abc.com/welcome
# Configure URL parameter usermac for the portal Web server wbs. Configure the value of the usermac parameter as source-mac (the MAC addresses of users) and specify DES to encrypt the MAC addresses.
[Sysname-portal-websvr-wbs] url-parameter usermac source-mac encryption des key simple 12345678
url
user-sync
Use user-sync to enable portal user synchronization for a portal authentication server.
Use undo user-sync to disable portal user synchronization for a portal authentication server.
user-sync timeout timeout
undo user-sync
Portal user synchronization is disabled for a portal authentication server.
timeout timeout: Sets a detection timeout for synchronization packets, in the range of 60 to 18000 seconds.
After this feature is enabled, the device replies to and periodically detects the synchronization packets from the portal authentication server. In this way, information about online portal users on the device and on the portal authentication server remains consistent.
Portal user synchronization requires that the portal authentication server support the portal user heartbeat feature. Now, only the IMC portal authentication server supports portal user heartbeat. To implement portal user synchronization, you need to configure the user heartbeat feature on the portal authentication server. Make sure the user heartbeat interval configured on the portal authentication server is not greater than the synchronization detection timeout configured on the access device.
Deleting a portal authentication server on the device also deletes the user synchronization configuration for the server.
For information of the users considered as nonexistent on the portal authentication server, the device deletes the information after the configured detection timeout expires.
If the user information from the portal authentication server does not exist on the device, the device encapsulates IP addresses of the users in user heartbeat reply packets to the server. The portal authentication server then deletes the users.
# Enable portal user synchronization for portal authentication server pts and set the detection timeout to 600 seconds. If a use has not appeared in the synchronization packets sent by the portal authentication server for 600 seconds, the access device logs out the user.
[Sysname-portal-server-pts] user-sync timeout 600
portal server
version
Use version to specify the version of the portal protocol.
Use undo version to restore the default.
version version-number
undo version
The version of the portal protocol is 1.
version-number: Specifies the portal protocol version in the range of 1 to 3.
The specified portal protocol version must be the that required by the MAC binding server.
# Configure the device to use portal protocol version 2 to communicate with MAC binding server mts.
[Sysname-portal-mac-trigger-server-mts] version 2
vpn-instance
Use vpn-instance to specify an MPLS L3VPN instance for a portal Web server.
Use undo vpn-instance to restore the default.
undo vpn-instance
A portal Web server belongs to the public network.
vpn-instance-name: Specifies the MPLS L3VPN instance to which the portal Web server belongs, The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters.
A portal Web server belongs to only one MPLS L3VPN instance.
# Specify MPLS L3VPN instance abc for portal Web server wbs.
[Sysname-portal-websvr-wbs] vpn-instance abc
web-redirect url
Use web-redirect url to enable the Web redirect feature.
Use undo web-redirect url to disable the Web redirect feature.
web-redirect [ ipv6 ] url url-string [ interval interval ]
undo web-redirect [ ipv6 ]
The Web redirect feature is disabled.
Interface view
ipv6: Specifies the IPv6 Web redirect feature. Do not specify this keyword for the IPv4 Web redirect feature.
url url-string: Specifies the URL to which the user is redirected. The URL is required to be complete and begins with http:// or https://, a string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
interval interval: Specifies the time interval at which the user is redirected to the specified URL. It is in the range of 60 to 86400 seconds. The default interval is 86400 seconds.
With Web redirect enabled on an interface, a user on the interface is first redirected to the specified URL before the user can access an external network through a Web browser. After the specified interval, the user is redirected to the specified URL again.
Web redirect does not work when both Web redirect and portal authentication are enabled.
The Web redirect feature takes effect only on HTTP packets that use the default port number 80.
# Configure IPv4 Web redirect on VLAN-interface 100. Set the redirect URL to http://192.0.0.1 and the interval to 3600 seconds.
[Sysname–Vlan-interface100] web-redirect url http://192.0.0.1 interval 3600
display web-redirect rule
