01-Fundamentals Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release758X-6W10001-Fundamentals Command Reference
10-Preprovisioning commands
10-Preprovisioning commands 50.70 KB
chassis slot
Use chassis slot to select a slot to provision and enter slot view.
chassis chassis-number slot slot-number
chassis chassis-number slot slot-number: Specifies an interface card slot on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the interface card to be preprovisioned.
# Enter the slot view of slot 1 in chassis 1.
[Sysname] chassis 1 slot 1
[Sysname-chassis-1-slot-1]
provision
display provision failed-config
Use display provision failed-config to display preprovisioned-commands application failure records.
A preprovisioned command cannot be applied if it conflicts with the running configuration.
Use this command to verify the application result of preprovisioned commands except for the following commands:
·     duplex
·     location
·     speed
·     sflow
To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands.
# Display preprovisioned-commands application failure records.
<Sysname> display provision failed-config
Configuration applied at: Sat Jun 14 06:06:00 2014
Slot information: slot 1
Commands that failed to be applied:
 speed 10000
provision
reset provision failed-config
provision
Use provision to enable preprovisioning.
Use undo provision to disable preprovisioning.
provision model model
undo provision model
Preprovisioning is disabled.
Slot view
model model: Specifies the card or IRF member device model to be preprovisioned. To obtain available models, enter a question mark (?) for the model argument.
This command allows you to enable preprovisioning on offline modules, including interface cards and IRF member devices.
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command will not display these interfaces until the module comes online. However, you can preprovision the interfaces.
When you disable preprovisioning on a slot, the device removes all preconfigured settings for the slot.
# Enable preprovisioning for the LSUM2TGS48SG0 module on a slot.
[Sysname] slot 2
[Sysname-slot-2] provision model LSUM2TGS48SG0
chassis slot
slot
Use reset provision failed-config to clear preprovisioned-commands application failure records.
Preprovisioned modules that repeatedly come online and go offline (or join and leave the IRF fabric) might leave a number of commands that were not applied in memory. To release the occupied memory space, execute the reset provision failed-config command.
# Clear preprovisioned-commands application failure records.
<Sysname> reset provision failed-config
provision
slot
Use slot to select a slot to provision and enter slot view.
slot slot-number
slot-number: Specifies a slot number.
# Enter the view of a slot.
[Sysname] slot 2
[Sysname-slot-2]
provision
