HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration GuidesH3C S7500X Switch Series Configuration Guides-Release758X-6W10001-Fundamentals Configuration Guide
16-License management
16-License management 85.21 KB
Managing licenses
Overview
License-based features, such as MDC and EVI require a license to run on your device. To use a license-based feature, you must purchase a license or obtain a free trial license.
This chapter describes how to license a feature, transfer a license between devices, remove a license, and manage the license storage space.
License-based feature packages
The following are feature packages available for the device:
·           CAMPUS—Includes the MDC feature.
·           DATACENTER—Includes the EVI and MDC features.
For more information about these features, see EVI Configuration Guide and Virtual Technologies Configuration Guide.
To use features in these packages, you must register and install the feature package licenses.
Switches of this series also support the unified wired and wireless access controller feature. You can purchase licenses to increase the number of manageable APs. For information about the unified wired and wireless access controller feature, see H3C Unified Wired and Wireless Access Controller User Manual. For more information about the version compatibility between the unified wired and wireless access controllers and switches, see the release notes for the relevant software version.
To use the unified wired and wireless access controller feature on the device, you must load the WLAN feature package. For information about loading the WLAN feature package, see performing an ISSU by using install commands in "Performing an ISSU."
License types
The following types of licenses are available depending on validity period:
·           Permanent—A permanent license is always valid and never expires.
·           Days restricted—A license valid for a limited period in days, for example, 30 days.
Trial licenses are typically days restricted.
Locking methods
The following locking methods are available:
·           Device locked—A license can be installed only on the DID-specific device. The license takes effect on any MPU in the device even after an MPU replacement. The device supports this locking method.
·           MPU locked—A license can be installed only on the DID-specific MPU. The license takes effect on the MPU even after the MPU is moved to a different device.
General restrictions and guidelines
When you manage licenses, follow the general restrictions and guidelines:
·           Make sure no one else is performing license management tasks on the device you are working with.
·           Manage licenses on the default MDC, and the licensed features will be licensed to the non-default MDCs automatically. Non-default MDCs do not support the license management. For information about MDCs, see Virtual Technologies Configuration Guide.
·           Trial licenses and expired formal licenses cannot be uninstalled. Expired licenses remain in the license storage area unless you compress the license storage area.
·           Licenses cannot be installed if the license storage area is not sufficient. Before registering licenses, use the display license feature command to identify the number of available licenses. Do not register licenses more than the available number.
·           After a license is activated, it takes 5 minutes for fiber ports that are bound to an IRF port to function correctly.
·           If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors of the HTTP client, contact H3C Support.
License file safety
When you manage licenses, follow these restrictions and guidelines for license file safety:
·           Save and back up the obtained activation file in case of loss.
·           If you use FTP to transfer the activation file, use the Binary mode.
·           Do not open and edit the activation file to avoid file corruption.
·           Do not modify the name of the activation file to avoid licensing error.
·           Do not delete or move files in the flash:/license directory on a device. The license management feature uses this directory for license management. An incorrect file operation can cause problems. For example, if you delete an activation file that is usable or in use, the related feature will not function correctly. If a file is missing or corrupted, use the copy command to copy its backup file to the directory to recover the license. If the state of the recovered license is In use but not all licensed features can function, reboot the device. To verify the license state, use the display license command.
Licenses for different device types
Licenses for the unified wired and wireless access controller feature
You can use the licenses to control the maximum number of concurrent online APs. In an IRF fabric, you can install a license on any member device, but the AP can go online only through the master device.
The total number of concurrent online APs cannot exceed the sum of AP count allowed by licenses on all member devices. For example, the license on member device 1 allows a maximum of 10 concurrent online APs, the license on member device 2 allows 5, and no license is installed on other member devices. In this case, a maximum of 15 concurrent online APs are allowed in the IRF fabric.
If a member device installed with a license leaves the IRF fabric, its license is available for a 30-day grace period in the original IRF to ensure service continuity. Meanwhile, the license continues to take effect on the leaving device.
Licenses for features other than the unified wired and wireless AC feature
To run a license-based feature on a device in standalone mode, install the registered license. The device will copy the activation file to other MPUs on the device during installation.
When you register and install licenses for campus and datacenter feature packages in an IRF fabric, follow these restrictions and guidelines:
·           Install one license for the features on each member in the fabric. Make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified member device.
·           A registered license takes effect on the member device where it is installed, and it is effective even after the member device joins another IRF fabric.
License consistency in an IRF fabric
License consistency and the concurrent online APs upper limit for the unified wired and wireless AC feature
You can install the unified wired and wireless AC license on any member device in the IRF fabric, and the license versions on the member devices can be different.
The maximum number of concurrent online APs in the whole IRF fabric cannot exceed the following limits:
·           The sum of AP count defined by licenses on all member devices.
·           The upper limit on the AP count supported by the master device.
License consistency for other features
For licensed features to function correctly in an IRF fabric, make sure all MPUs are installed with the same licenses.
Compressing the license storage
CAUTION
CAUTION:
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID change. Before performing a compression, make sure all activation files generated based on the old DID have been installed. You will be unable to install such licenses after the compression.
When the value for the Total field equals that of the Usage field from the output of the display license feature command, the license storage area is full. To ensure sufficient storage space for installing new licenses, compress the license storage area.
To compress the license storage:
1.      Enter system view.
2.      Compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress chassis chassis-number
Obtaining required information for license register
1.      Execute the display license feature command to identify features to be licensed.
2.      Execute the display license command to display the current license status.
3.      Obtain the license key by purchasing a license.
The authorization serial number in the Software License Certificate is the license key.
4.      Execute the display license device-id command to obtain the SN and DID information.
5.      Back up the license key in case of loss.
Registering a license
About registering a license
License registration has the following procedures:
·           Registering licenses for the first time—Register a license for a device that has not previously been registered.
·           Registering upgrade licenses—Register licenses for capacity expansion, feature enhancement, or a time extension.
If you do not know which registration procedure should be used, select registering licenses for the first time. If the selection is not correct, the website will display messages for the correct registration choice after you enter the required information.
If you cannot download the activation file due to problems such as operating system and browser errors, try to re-register the license. If the problem persists, contact H3C Support.
1.      Visit the H3C website at http://www.h3c.com/en/License/.
2.      Select Register the First Time.
3.      Enter the authorization serial number in the Input the license key field and click Submit.
A dialog box opens, displaying product categories matching the license key.
4.      In the dialog box, select a product category from the Product category dropdown list and click OK.
5.      Enter the device S/N.
6.      Enter the DID.
7.      Enter the required contact information and verify code, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
8.      Download the activation file to the PC.
A copy of the activation file will also be sent to the email address that you enter in the contact information.
2.      Select Register Upgrade Licenses.
6.      Enter the DID and click Submit.
Installing a license
2.      Install the activation file.
In standalone mode:
license activation-file install file-name
In IRF mode:
license activation-file install file-name chassis chassis-number
Uninstalling a license
About license uninstallation
Perform this task to uninstall an unexpired formal license when the license remains unused for a while or needs to be transferred to another device.
After uninstallation, Uninstall keys are generated, which will be used for license transfer.
Restrictions and guidelines for license uninstallation
Back up the Uninstall key of a license properly for the license's next use.
Trial licenses cannot be transferred. Uninstall a trial license does not create any uninstallation information.
Expired licenses cannot be uninstalled.
2.      Uninstall an activation file.
In standalone mode:
license activation-file uninstall file-name
Only unexpired activation files can be uninstalled.
In IRF mode:
license activation-file uninstall file-name chassis chassis-number
Transferring a license
About license transfer
You can transfer a license from one device to another if the license has not expired.
1.      Log in to the source device, and uninstall the license to obtain the uninstallation information.
For more information, see "Uninstalling a license."
2.      Obtain the Uninstall key of the license by using the display license command.
3.      Access the target device and obtain SN and DID information.
For more information, see "Obtaining required information for license register."
4.      Register a license for the target device.
For more information, see "Registering a license."
During the license register, you must provide SN and DID information of the target device and the Uninstall key of the source device.
5.      Install the new license on the target device.
For more information, see "Installing a license."
Recovering an activation file
If you mistakenly delete an activation file, use the following procedure to recover the activation file:
1.      Use the copy command to copy the backup activation file to directory flash:/license.
2.      Use the display license command to verify that the state of the recovered activation file is In use.
3.      Restart the device if the license state is In use but the licensed feature cannot function correctly.
Displaying and maintaining licenses
(In standalone mode.) Display the SN and DID of the device.
(In IRF mode.) Display the SN and DID of an IRF member device.
display license device-id chassis chassis-number
(In standalone mode.) Display detailed license information.
display license [ activation-file ]
(In IRF mode.) Display detailed license information.
display license [ activation-file ] [ chassis chassis-number ]
Display brief feature license information.
