HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration GuidesH3C S7500X Switch Series Configuration Guides-Release758X-6W10001-Fundamentals Configuration Guide
11-Preprovisioning feature configuration
11-Preprovisioning feature configuration 44.86 KB
Configuring preprovisioning
Preprovisioning allows you to preconfigure offline modules, including interface cards and IRF member devices.
When a preprovisioned module comes online, the preprovisioned settings are applied. After the module goes offline, you can continue to change the existing settings or add new settings for the module. The final settings are applied when the module comes online again.
Preprovisioning is supported only the following cards:
·           MPUs LSQM2SUPA0, LSQM1MPUSA0, LSQM1MPUS10B0, LSQM1MPUSC0, and LSQM1MPUS10C0
·           SG interface cards LSQM1TGS48RSG0, LSQM2TGS48SG0, LSQM1CQGS12SG0, and LSQM1QGS24RSG0
·           FD interface cards
·           FE interface cards
When you disable preprovisioning on a slot, the device removes all preprovisioned commands for the slot.
For the preprovisioned settings to survive a reboot, you must use the save command to save the settings to the next-startup configuration file.
Enabling preprovisioning
To enable preprovisioning:
Step
Remarks
1.      Enter system view.
N/A
2.      Select the slot to preprovision and enter slot view.
In standalone mode:
slot slot-number
In IRF mode:
chassis chassis-number slot slot-number
N/A
3.      Enable preprovisioning on the slot.
provision model model
By default, preprovisioning is disabled on a slot.
The specified model must be the same as the model of the module you want to install. If not, the preprovisioned settings cannot be applied to the module.
4.      Enable preprovisioning on a subslot for a subcard.
provision subslot subslot-number model model
By default, preprovisioning is disabled on a subslot.
The specified model must be the same as the model of the subcard you want to install. If not, the preprovisioned settings cannot be applied to the subcard.
Display and maintenance commands for preprovisioned settings
Execute display commands in any view. Execute the reset command in user view.
Display preprovisioned-commands application failure records.
display provision failed-config
Clear preprovisioned-commands application failure records.
reset provision failed-config
