- 04-Layer 2 - LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-DRNI configuration
- 04-Port isolation configuration
- 05-VLAN configuration
- 06-MVRP configuration
- 07-QinQ configuration
- 08-VLAN mapping configuration
- 09-Loop detection configuration
- 10-Spanning tree configuration
- 11-LLDP configuration
- 12-L2PT configuration
- 13-Service loopback group configuration
| 13-Service loopback group configuration | 56.50 KB |
Configuring service loopback groups
Configuring a service loopback group
Displaying and maintaining service loopback groups
Service loopback group configuration example
Overview
A service loopback group contains one or multiple Ethernet ports for looping packets sent out by the device back to the device. This feature must work with other features, such as GRE.
A service loopback group provides one of the following services:
· Tunnel—Supports unicast tunnel services.
· Multicast tunnel—Supports multicast tunnel services.
Member ports in a service loopback group are load balanced.
When you configure service loopback groups, follow these restrictions and guidelines:
· The maximum number of service loopback groups and the maximum number of member ports allowed in a service loopback group vary by usage of the following modules:
? LSU1FWCEA0.
? LSU3FWCEA0.
? LSU3WCMD0.
If some member ports or the ingress ports of the traffic are on any of these modules:
? The maximum number of service loopback groups is 128.
? The maximum number of member ports in a service loopback group is 8.
If no member ports are on any of these modules:
? The maximum number of service loopback groups is 1000.
? The maximum number of member ports in a service loopback group is 32.
· Assign ports with the same rate to the same service loopback group for load balancing.
· To avoid IRF split, do not assign a physical interface to a service loopback group if that interface is the only member interface of an IRF port.
· In an IRF 3.1 system, ports on PEXs cannot be assigned to service loopback groups.
· Make sure the ports you are assigning to a service loopback group meet the following requirements:
? The ports are not used for any other purposes. The configuration on a port is removed when it is assigned to a service loopback group.
? The ports support the service type of the service loopback group and are not members of any other service loopback group.
· You can configure only one service loopback group for a service type. However, you can use one service loopback group with multiple features.
· You cannot change the service type of a service loopback group.
· Do not delete a service loopback group that is being used by a feature.
· For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create a service loopback group and specify its service type. |
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | vsi-gateway } |
By default, no service loopback groups exist. In the current software version, the device does not support the multiport and vsi-gateway keywords. |
3. Enter Layer 2 Ethernet interface view. |
N/A |
4. Assign the port to the service loopback group. |
port service-loopback group group-id |
By default, a port does not belong to any service loopback group. You can assign multiple ports to a service loopback group. |
Task |
Command |
Display information about service loopback groups. |
display service-loopback group [ group-id ] |
Network requirements
All Ethernet ports on the device support unicast tunnel services. Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
Configuration procedure
# Create service loopback group 1, and specify its service type as tunnel.
[Sysname] service-loopback group 1 type tunnel
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to service loopback group 1.
[Sysname-GigabitEthernet1/0/1] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-GigabitEthernet1/0/1] quit
[Sysname-GigabitEthernet1/0/2] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-GigabitEthernet1/0/2] quit
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-GigabitEthernet1/0/3] quit
# Create GRE tunnel interface Tunnel 1. The interface will automatically use service loopback group 1.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
