10-Security Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release758X-6W10010-Security Command Reference
24-Object group commands
24-Object group commands 57.19 KB
description
Use description to configure a description for an object group.
No description is configured for an object group.
Object group view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as This is an IPv4 object-group for an IPv4 address object group.
[Sysname] object-group ip address ipgroup
[Sysname-obj-grp-ip-ipgroup] description This is an IPv4 object-group
display object-group
Use display object-group to display information about object groups.
display object-group [ ip address [ default ] [ name object-group-name ] | name object-group-name ]
ip address: Specifies the IPv4 address object groups.
default: Specifies the default object groups.
name object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 31 characters.
# Display information about all object groups.
<Sysname> display object-group
IP address object group obj1: 0 object(in use)
IP address object group obj2: 4 objects(out of use)
0 network host address 1.1.1.1
10 network host name host
20 network subnet 1.1.1.1 255.255.255.0
60 network host name host vpn-instance vpn1
# Display information about object group obj2.
<Sysname> display object-group name obj2
IP address object-group obj2: 4 objects(out of use)
50 network host name host vpn-instance vpn1
# Display information about all IPv4 address object groups.
<Sysname> display object-group ip address
IP address object-group obj1: 0 object(in use)
# Display information about IPv6 address object group obj4.
in use
The object group is used by an ACL or object group.
out of use
The object group is not used.
network
Use network to configure an IPv4 address object.
Use undo network to delete an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask } }
undo network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask } }
undo object-id
No IPv4 address objects exist.
IPv4 address object group view
object-id: Specifies an object ID in the range of 0 to 4294967294. If you do not specify an object ID, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the system automatically assigns 30.
host: Configures an IPv4 address object with the host address or name.
address ip-address: Specifies an IPv4 host address.
name host-name: Specifies a host name, a case-insensitive string of 1 to 60 characters.
vpn-instance vpn-instance-name: Specifies a VPN instance name, a case-sensitive string of 1 to 31 characters.
subnet ip-address { mask-length | mask }: Configures an IPv4 address object with the subnet address followed by a mask length in the range of 0 to 32 or a mask in dotted decimal notation.
This command fails if you use it to configure or change an IPv4 address object to be identical with an existing object.
This command creates an IPv4 address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
If you configure a subnet with the mask length of 32 or the mask of 255.255.255.255, the system configures the object with a host address.
# Configure an IPv4 address object with the host address of 192.168.0.1.
[Sysname-obj-grp-ip-ipgroup] network host address 192.168.0.1
# Configure an IPv4 address object with the host name of pc3.
[Sysname-obj-grp-ip-ipgroup] network host name pc3
# Configure an IPv4 address object with the host name of pc1 and the VPN instance name of vpn1.
[Sysname-obj-grp-ip-ipgroup] network host name pc1 vpn-instance vpn1
# Configure an IPv4 address object with the IPv4 address of 192.167.0.0 and mask length of 24.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.167.0.0 24
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.166.0.0 255.255.0.0
object-group
Use object-group to configure an object group and enter its view, or enter the view of an existing object group.
Use undo object-group to delete an object group.
object-group ip address object-group-name
undo object-group ip address object-group-name
Default object groups exist.
ip address: Configures an IPv4 address object group.
object-group-name: Specifies an object group name, a case-insensitive string of 1 to 31 characters.
The object-group command execution results vary with the specified object group.
·     If the specified group does not exist, the system creates a new object group and enters the object group view.
·     If the specified group exists but the group type is different from that in the command, the command fails.
The undo object-group command execution results vary with the specified object group.
·     If the specified group does not exist, the system executes the command without any system prompt.
·     If the specified group exists and the group type is the same as that in the command, the system deletes the group.
·     If the specified object group is being used by an ACL, object policy, or object group, the command fails.
Default object groups cannot be deleted.
# Configure an IPv4 address object group named ipgroup.
