03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS6520XE-HI SeriesConfigure & DeployConfiguration GuidesH3C S6520XE-HI Switch Series Configuration Guides-R7588-6W10003-Layer 2—LAN Switching Configuration Guide
15-Service loopback group configuration
15-Service loopback group configuration 50.76 KB
Configuring service loopback groups
About service loopback groups
A service loopback group contains one or multiple Ethernet ports for looping packets sent out by the device back to the device. This feature must work with other features, such as GRE. Member ports in a service loopback group are load balanced.
A service loopback group provides one of the following services:
·           Tunnel—Supports unicast tunnel services.
·           Multicast tunnel—Supports multicast tunnel services.
·           Multiport—Supports multiport ARP services.
·           VSI gateway—Supports VSI gateway services.
Restrictions and guidelines: Service loopback group configuration
When you add member ports to a service loopback group, follow these restrictions and guidelines:
·           Make sure the ports support the service type of the service loopback group and are not members of any other service loopback group.
·           The configuration on a port is removed when it is assigned to the service loopback group.
·           To avoid IRF split, do not assign a physical interface to the service loopback group if that interface is the only member interface of an IRF port.
·           For correct traffic processing, make sure the service loopback group has a minimum of one member port when it is being used by a feature.
When you apply service loopback groups to features, follow these restrictions and guidelines:
·           One service loopback group can be used by multiple features.
·           You cannot change the service type of a service loopback group.
·           Do not delete a service loopback group that is being used by a feature.
Configuring a service loopback group
1.      Enter system view.
2.      Create a service loopback group and specify its service type.
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | vsi-gateway }
You can configure only one service loopback group for a service type.
3.      Enter Layer 2 Ethernet interface view.
4.      Assign the port to the service loopback group.
port service-loopback group group-id
By default, a port does not belong to a service loopback group.
You can assign a maximum of 32 ports to a service loopback group.
Display and maintenance commands for service loopback groups
Display information about service loopback groups.
display service-loopback group [ group-id ]
Service loopback group configuration examples
Example: Configuring a service loopback group
All Ethernet ports on the device support unicast tunnel services. Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
# Create service loopback group 1, and specify its service type as tunnel.
[Sysname] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[Sysname-Ten-GigabitEthernet1/0/1] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-Ten-GigabitEthernet1/0/1] quit
[Sysname-Ten-GigabitEthernet1/0/2] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-Ten-GigabitEthernet1/0/2] quit
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-Ten-GigabitEthernet1/0/3] quit
# Create the interface Tunnel 1 and set it to GRE mode. The interface will automatically use service loopback group 1.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
