- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Object group commands
- 16-Attack detection and prevention commands
- 17-TCP attack prevention commands
- 18-IP source guard commands
- 19-ARP attack protection commands
- 20-ND attack defense commands
- 21-uRPF commands
- 22-SAVI commands
- 23-MFF commands
- 24-Crypto engine commands
- 25-FIPS commands
- 26-MACsec commands
20-ND attack defense commands | 101.32 KB |
Source MAC consistency check commands
display ipv6 nd detection statistics
ipv6 nd detection port-match-ignore
reset ipv6 nd detection statistics
display ipv6 nd raguard policy
display ipv6 nd raguard statistics
if-match autoconfig managed-address-flag
if-match autoconfig other-flag
reset ipv6 nd raguard statistics
ipv6 nd check log enable
Use ipv6 nd check log enable to enable the ND logging feature.
Use undo ipv6 nd check log enable to restore the default.
The ND logging feature is disabled.
The ND logging feature logs source MAC inconsistency events, and sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable the ND logging feature to avoid excessive ND logs.
# Enable the ND logging feature.
[Sysname] ipv6 nd check log enable
ipv6 nd mac-check enable
Use ipv6 nd mac-check enable to enable source MAC consistency check for ND messages.
Use undo ipv6 nd mac-check enable to disable source MAC consistency check for ND messages.
Source MAC consistency check for ND messages is disabled.
Use this command to enable source MAC consistency check on a gateway. The gateway checks the source MAC address and the source link-layer address for consistency for each ND message. If an inconsistency is found, the gateway drops the ND message.
# Enable source MAC consistency check for ND messages.
[Sysname] ipv6 nd mac-check enable
ND attack detection commands
Use display ipv6 nd detection statistics to display statistics for ND messages dropped by ND attack detection.
display ipv6 nd detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for ND messages dropped by ND attack detection on all interfaces.
# Display statistics for all ND messages dropped by ND attack detection.
<Sysname> display ipv6 nd detection statistics
ND packets dropped by ND detection:
Interface/AC Packets dropped
XGE1/0/1 78
XGE1/0/2 0
XGE1/0/3 0
XGE1/0/4 0
Interface/AC |
Input interface or AC link of the ND messages. |
Packets dropped |
Number of ND messages dropped by ND attack detection. |
ipv6 nd detection enable
Use ipv6 nd detection enable to enable ND attack detection. This feature checks the ND message validity.
Use undo ipv6 nd detection enable to disable ND attack detection.
ND attack detection is disabled.
VLAN view
# Enable ND attack detection for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] ipv6 nd detection enable
Use ipv6 nd detection port-match-ignore to ignore ingress ports of ND packets in ND attack detection.
Use undo ipv6 nd detection port-match-ignore to remove the configuration.
Ingress ports of ND packets are examined in ND attack detection.
This command configures ND attack detection to ignore the ingress port information of ND packets when the packets are compared with the entries in ND attack detection.
# Ignore ingress ports of ND packets in ND attack detection.
[Sysname] ipv6 nd detection port-match-ignore
ipv6 nd detection trust
Use ipv6 nd detection trust to configure an interface as an ND trusted interface.
Use undo ipv6 nd detection trust to restore the default.
All interfaces are ND untrusted interfaces.
# Configure Ten-GigabitEthernet 1/0/1 as an ND trusted interface.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 nd detection trust
# Configure Bridge-Aggregation 1 as an ND trusted interface.
[Sysname-Bridge-Aggregation1] ipv6 nd detection trust
Use reset ipv6 nd detection statistics to clear ND attack detection statistics.
reset ipv6 nd detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears ND attack detection statistics for all interfaces.
# Clear all ND attack detection statistics.
<Sysname> reset ipv6 nd detection statistics
RA guard commands
Use display ipv6 nd raguard policy to display the RA guard policy configuration.
display ipv6 nd raguard policy [ policy-name ]
policy-name: Specifies an RA guard policy by its name. The policy name is a case-sensitive string of 1 to 31 characters. If you do not specify a policy, this command displays the configuration of all RA guard policies.
# Display the configuration of all RA guard policies.
<Sysname> display ipv6 nd raguard policy
Total number of policies: 2
RA Guard policy: policy1
if-match ACL 2001
if-match autoconfig managed-address-flag on
if-match autoconfig other-flag off
if-match hop-limit maximum 128
if-match hop-limit minimum 100
if-match prefix ACL name aa
if-match router-preference medium
applied to VLAN 1-3 7
RA Guard policy: policy2
if-match ACL name zdd
if-match prefix ACL 2200
RA Guard policy |
Name of the RA guard policy. |
if-match ACL |
Number of the ACL in the ACL match criterion. |
if-match ACL name |
Name of the ACL in ACL match criterion. |
if-match autoconfig managed-address-flag |
Match criterion of the advertised M flag: · on—The value of the advertised M flag is 1. · off—The value of the advertised M flag is 0. |
if-match autoconfig other-flag |
Match criterion of the advertised O flag: · on—The value of the advertised O flag is 1. · off—The value of the advertised O flag is 0. |
if-match hop-limit maximum |
The maximum advertised hop limit match criterion. |
if-match hop-limit minimum |
The minimum advertised hop limit match criterion. |
if-match prefix ACL |
Number of the ACL used to identify the prefix match criterion. |
if-match prefix ACL name |
Name of the ACL used to identify the prefix match criterion. |
applied to VLAN |
ID of the VLAN to which the RA guard policy is applied. |
Use display ipv6 nd raguard statistics to display RA guard statistics.
display ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays RA guard statistics for all interfaces.
# Display RA guard statistics.
<Sysname> display ipv6 nd raguard statistics
RA messages dropped by RA guard:
Interface Dropped
XGE1/0/1 78
XGE1/0/2 0
XGE1/0/3 32
XGE1/0/4 0
Interface that received the dropped RA messages. |
Dropped |
Number of RA messages dropped on the interface. |
ipv6 nd raguard log enable
if-match acl
Use if-match acl to specify an ACL match criterion.
Use undo if-match acl to delete the ACL match criterion.
undo if-match acl
No ACL match criterion exists.
RA guard policy view
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999.
name ipv6-acl-name: Specifies an IPv6 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with an English letter. To avoid confusion, the name cannot be all.
RA guard uses the ACL match criterion to match the IP address of the RA message sender. If the sender IP address matches a permit rule, the message passes the check.
If the specified ACL does not exist or does not contain a rule, the ACL match criterion does not take effect.
# Use IPv6 basic ACL 2001 as the ACL match criterion for the RA guard policy policy1.
[Sysname] ipv6 nd raguard policy policy1
[Sysname-raguard-policy-policy1] if-match acl 2001
Use if-match autoconfig managed-address-flag to specify an M flag match criterion.
Use undo if-match autoconfig managed-address-flag to delete the M flag match criterion.
if-match autoconfig managed-address-flag { off | on }
No M flag match criterion exists.
off: Specifies the advertised M flag as 0
on: Specifies the advertised M flag as 1.
The M flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain an IPv6 address.
· If the M flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
· If the M flag is set to 0, the host uses stateless autoconfiguration. In stateless autoconfiguration, the host generates an IPv6 address according to its link-layer address and the prefix information in the RA message.
# Specify on as the M flag match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match autoconfig managed-address-flag on
Use if-match autoconfig other-flag to specify an O flag match criterion.
Use undo if-match autoconfig other-flag to delete the O flag match criterion.
if-match autoconfig other-flag { off | on }
No O flag match criterion exists.
off: Specifies the advertised O flag as 0.
on: Specifies the advertised O flag as 1.
The O flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain configuration information other than IPv6 address.
· If the O flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
· If the O flag is set to 0, the host uses stateless autoconfiguration.
[Sysname-raguard-policy-policy1] if-match autoconfig other-flag on
if-match hop-limit
Use if-match hop-limit to specify a maximum or minimum hop limit match criterion.
Use undo if-match hop-limit to delete the maximum or minimum hop limit match criterion.
if-match hop-limit { maximum | minimum } limit
undo if-match hop-limit { maximum | minimum }
No maximum or minimum hop limit match criterion exists.
maximum: Specifies the maximum advertised hop limit. An RA message passes the check if its current hop limit is not higher than the maximum advertised hop limit.
minimum: Specifies the minimum advertised hop limit. An RA message passes the check if its current hop limit is not less than the minimum advertised hop limit.
limit: Specifies the advertised hop limit in the range of 1 to 255.
If a hop limit match criterion is set, and the RA message's current hop limit is 0, the message will be dropped.
# Set the maximum hop limit match criterion to 128 for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match hop-limit maximum 128
if-match prefix
Use if-match prefix to specify a prefix match criterion.
Use undo if-match prefix to delete the prefix match criterion.
if-match prefix acl { ipv6-acl-number | name ipv6-acl-name }
undo if-match prefix acl
No prefix match criterion exists.
An RA message passes the check if the advertised prefixes in the message match the prefixes set by the ACL.
If the specified ACL does not exist or does not contain a rule, the prefix match criterion does not take effect.
# Use IPv6 basic ACL 2000 as the prefix match criterion for the RA guard policy policy1.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 1001:: 64
[Sysname-acl-ipv6-basic-2000] rule permit source 3124:1123:: 64
[Sysname-acl-ipv6-basic-2000] rule deny source any
[Sysname-raguard-policy-policy1] if-match prefix acl 2000
Use if-match router-preference maximum to specify a router preference match criterion.
Use undo if-match router-preference maximum to delete the router preference match criterion.
if-match router-preference maximum { high | low | medium }
No router preference match criterion exists.
high: Sets the maximum router preference to high. An RA message passes the check if its router preference is not higher than high.
low: Sets the maximum router preference to low. An RA message passes the check if its router preference is not higher than low.
medium: Sets the maximum router preference to medium. An RA message passes the check if its router preference is not higher than medium.
A host selects a router as the default gateway according to the router preference in received RA messages. If router preferences are the same, the host selects the default router from which the first RA message is received.
An RA message will not pass the router preference check if the message does not have a preference value. This RA message will be dropped.
# Specify medium as the router preference match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match router-preference maximum medium
ipv6 nd raguard apply policy
Use ipv6 nd raguard apply policy to apply an RA guard policy to a VLAN.
Use undo ipv6 nd raguard apply policy to remove the RA guard policy from a VLAN.
ipv6 nd raguard apply policy [ policy-name ]
No RA guard policy is applied to a VLAN.
VLAN view
policy-name: Specifies an RA guard policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a policy, RA guard blocks RA messages on all interfaces in the VLAN except interfaces that are defined to be connected to routers.
If an RA message has multiple VLAN tags, RA guard uses the outermost VLAN tag to select the applied RA guard policy.
If the specified RA guard policy does not exist, the command does not take effect.
# Apply the RA guard policy policy1 to VLAN 100.
[Sysname] vlan 100
[Sysname-vlan100] ipv6 nd raguard apply policy policy1
Use ipv6 nd raguard log enable to enable the RA guard logging feature.
Use undo ipv6 nd raguard log enable to disable the RA guard logging feature.
The RA guard logging feature is disabled.
This command allows a device to generate logs when it detects forged RA messages. The log information helps administrators locate and solve problems. Each log records the following information:
· Name of the interface that received the forged RA message.
· Source IP address of the forged RA message.
· Number of RA messages dropped on the interface.
The RA guard logging feature sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable the RA guard logging feature.
[Sysname] ipv6 nd raguard log enable
Use ipv6 nd raguard policy to create an RA guard policy and enter its view, or enter the view of an existing RA guard policy.
Use undo ipv6 nd raguard policy to delete an RA guard policy.
ipv6 nd raguard policy policy-name
undo ipv6 nd raguard policy policy-name
No RA guard policies exist.
policy-name: Assigns a name to the RA guard policy. The name is a case-sensitive string of 1 to 31 characters.
# Create RA guard policy policy1 and enter its view.
ipv6 nd raguard role
Use ipv6 nd raguard role to specify the role of the device attached to the interface.
Use undo ipv6 nd raguard role to remove the role of the device attached to the interface.
ipv6 nd raguard role { host | router }
No role is specified for the device attached to the interface.
host: Specifies the host role. The interface attached to a host drops all received RA messages.
router: Specifies the router role. The interface attached to a router forwards all received RA messages.
Make sure your setting is consistent with the device type. If you are not aware of the attached device type, do not specify a role for the device.
# Specify host as the role for the device attached to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 nd raguard role host
Use reset ipv6 nd raguard statistics to clear RA guard statistics.
reset ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears RA guard statistics for all interfaces.
# Clear RA guard statistics.
<Sysname> reset ipv6 nd raguard statistics
