10-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS5130 SeriesConfigure & DeployConfiguration GuidesH3C S5130-HI Switch Series Configuration Guides-Release 1312-6W10110-Network Management and Monitoring Configuration Guide
03-NTP configuration
03-NTP configuration 412.57 KB
Configuring NTP· 1
Overview·· 1
How NTP works· 1
NTP architecture· 2
Association modes· 3
NTP security· 4
Protocols and standards· 5
Configuration restrictions and guidelines· 5
Configuration task list 6
Enabling the NTP service· 6
Configuring NTP association mode· 6
Configuring NTP in client/server mode· 6
Configuring NTP in symmetric active/passive mode· 7
Configuring NTP in broadcast mode· 7
Configuring NTP in multicast mode· 8
Configuring access control rights· 9
Configuring NTP authentication· 9
Configuring NTP authentication in client/server mode· 9
Configuring NTP authentication in symmetric active/passive mode· 11
Configuring NTP authentication in broadcast mode· 12
Configuring NTP authentication in multicast mode· 14
Configuring NTP optional parameters· 15
Specifying the source interface for NTP messages· 15
Disabling an interface from receiving NTP messages· 16
Configuring the maximum number of dynamic associations· 16
Setting a DSCP value for NTP packets· 17
Configuring the local clock as a reference source· 17
Displaying and maintaining NTP· 17
NTP configuration examples· 18
NTP client/server mode configuration example· 18
IPv6 NTP client/server mode configuration example· 19
NTP symmetric active/passive mode configuration example· 20
IPv6 NTP symmetric active/passive mode configuration example· 21
NTP broadcast mode configuration example· 23
NTP multicast mode configuration example· 24
IPv6 NTP multicast mode configuration example· 27
Configuration example for NTP client/server mode with authentication· 30
Configuration example for NTP broadcast mode with authentication· 32
Configuring SNTP· 35
Configuration restrictions and guidelines· 35
Configuration task list 35
Enabling the SNTP service· 35
Specifying an NTP server for the device· 35
Configuring SNTP authentication· 36
Displaying and maintaining SNTP· 37
SNTP configuration example· 37
Network requirements· 37
Configuration procedure· 37
Configuring NTP
Synchronize your device with a trusted time source by using the Network Time Protocol (NTP) or changing the system time before you run it on a live network. Various tasks, including network management, charging, auditing, and distributed computing depend on an accurate system time setting, because the timestamps of system messages and logs use the system time.
Overview
NTP is typically used in large networks to dynamically synchronize time among network devices. It guarantees higher clock accuracy than manual system clock setting. In a small network that does not require high clock accuracy, you can keep time synchronized among devices by changing their system clocks one by one.
NTP runs over UDP and uses UDP port 123.
How NTP works
Figure 1 shows how NTP synchronizes the system time between two devices (Device A and Device B, in this example). Assume that:
·          Prior to the time synchronization, the time is set to 10:00:00 am for Device A and 11:00:00 am for Device B.
·          Device B is used as the NTP server. Device A is to be synchronized to Device B.
·          It takes 1 second for an NTP message to travel from Device A to Device B, and from Device B to Device A.
·          It takes 1 second for Device B to process the NTP message.
Figure 1 Basic work flow
The synchronization process is as follows:
1.        Device A sends Device B an NTP message, which is timestamped when it leaves Device A. The time stamp is 10:00:00 am (T1).
2.        When this NTP message arrives at Device B, Device B adds a timestamp showing the time when the message arrived at Device B. The timestamp is 11:00:01 am (T2).
3.        When the NTP message leaves Device B, Device B adds a timestamp showing the time when the message left Device B. The timestamp is 11:00:02 am (T3).
4.        When Device A receives the NTP message, the local time of Device A is 10:00:03 am (T4).
Up to now, Device A can calculate the following parameters based on the timestamps:
·          The roundtrip delay of the NTP message: Delay = (T4 – T1) – (T3 – T2) = 2 seconds.
·          Time difference between Device A and Device B: Offset = ((T2 – T1) + (T3 – T4)) /2 = 1 hour.
Based on these parameters, Device A can be synchronized to Device B.
This is only a rough description of the work mechanism of NTP. For more information, see the related protocols and standards.
NTP architecture
NTP uses stratums 1 to 16 to define clock accuracy, as shown in Figure 2. A lower stratum value represents higher accuracy. Clocks at stratums 1 through 15 are in synchronized state, and clocks at stratum 16 are not synchronized.
Figure 2 NTP architecture
A stratum 1 NTP server gets its time from an authoritative time source, such as an atomic clock. It provides time for other devices as the primary NTP server. A stratum 2 time server receives its time from a stratum 1 time server, and so on.
To ensure time accuracy and availability, you can specify multiple NTP servers for a device. The device selects an optimal NTP server as the clock source based on parameters such as stratum. The clock that the device selects is called the reference source. For more information about clock selection, see the related protocols and standards.
If the devices in a network cannot synchronize to an authoritative time source, you can perform the following tasks:
·          Select a device that has a relatively accurate clock from the network.
·          Use the local clock of the device as the reference clock to synchronize other devices in the network.
Association modes
NTP supports the following association modes:
·          Client/server mode
·          Symmetric active/passive mode
·          Broadcast mode
·          Multicast mode
Table 1 NTP association mode
Mode
Working process
Principle
Application scenario
Client/server
On the client, specify the IP address of the NTP server.
A client sends a clock synchronization message to the NTP servers. Upon receiving the message, the servers automatically operate in server mode and send a reply.
If the client can be synchronized to multiple time servers, it selects an optimal clock and synchronizes its local clock to the optimal reference source after receiving the replies from the servers.
A client can synchronize to a server, but a server cannot synchronize to a client.
As Figure 2 shows, this mode is intended for configurations where devices of a higher stratum synchronize to devices with a lower stratum.
On the symmetric active peer, specify the IP address of the symmetric passive peer.
A symmetric active peer periodically sends clock synchronization messages to a symmetric passive peer. The symmetric passive peer automatically operates in symmetric passive mode and sends a reply.
If the symmetric active peer can be synchronized to multiple time servers, it selects an optimal clock and synchronizes its local clock to the optimal reference source after receiving the replies from the servers.
A symmetric active peer and a symmetric passive peer can be synchronized to each other. If both of them are synchronized, the peer with a higher stratum is synchronized to the peer with a lower stratum.
As Figure 2 shows, this mode is most often used between servers with the same stratum to operate as a backup for one another. If a server fails to communicate with all the servers of a lower stratum, the server can still synchronize to the servers of the same stratum.
Broadcast
A server periodically sends clock synchronization messages to the broadcast address 255.255.255.255. Clients listen to the broadcast messages from the servers to synchronize to the server according to the broadcast messages.
When a client receives the first broadcast message, the client and the server start to exchange messages to calculate the network delay between them. Then, only the broadcast server sends clock synchronization messages.
A broadcast client can synchronize to a broadcast server, but a broadcast server cannot synchronize to a broadcast client.
A broadcast server sends clock synchronization messages to synchronize clients in the same subnet. As Figure 2 shows, broadcast mode is intended for configurations involving one or a few servers and a potentially large client population.
The broadcast mode has a lower time accuracy than the client/server and symmetric active/passive modes because only the broadcast servers send clock synchronization messages.
Multicast
A multicast server periodically sends clock synchronization messages to the user-configured multicast address. Clients listen to the multicast messages from servers and synchronize to the server according to the received messages.
A multicast client can synchronize to a multicast server, but a multicast server cannot synchronize to a multicast client.
A multicast server can provide time synchronization for clients in the same subnet or in different subnets.
The multicast mode has a lower time accuracy than the client/server and symmetric active/passive modes.
In this document, an "NTP server" or a "server" refers to a device that operates as an NTP server in client/server mode. Time servers refer to all the devices that can provide time synchronization, including NTP servers, NTP symmetric peers, broadcast servers, and multicast servers.
NTP security
To improve time synchronization security, NTP provides the access control and authentication functions.
NTP access control
You can control NTP access by using an ACL. The access rights are in the following order, from the least restrictive to the most restrictive:
·          Peer—Allows time requests and NTP control queries (such as alarms, authentication status, and time server information) and allows the local device to synchronize itself to a peer device.
·          Server—Allows time requests and NTP control queries, but does not allow the local device to synchronize itself to a peer device.
·          Synchronization—Allows only time requests from a system whose address passes the access list criteria.
·          Query—Allows only NTP control queries from a peer device to the local device.
When the device receives an NTP request, it matches the request against the access rights in the order from the least restrictive to the most restrictive: peer, server, synchronization, and query.
·          If no NTP access control is configured, the peer access right applies.
·          If the IP address of the peer device matches a permit statement in an ACL, the access right is granted to the peer device. If a deny statement or no ACL is matched, no access right is granted.
·          If no ACL is specified for an access right or the ACL specified for the access right is not created, the access right is not granted.
·          If none of the ACLs specified for the access rights is created, the peer access right applies.
·          If none of the ACLs specified for the access rights contains rules, no access right is granted.
This feature provides minimal security for a system running NTP. A more secure method is NTP authentication.
NTP authentication
Use this feature to authenticate the NTP messages for security purposes. If an NTP message passes authentication, the device can receive it and get time synchronization information. If not, the device discards the message. This function makes sure the device does not synchronize to an unauthorized time server.
Figure 3 NTP authentication
As shown in Figure 3, NTP authentication works as follows:
1.        The sender uses the key identified by the key ID to calculate a digest for the NTP message through the specified authentication algorithm. Then it sends the calculated digest together with the NTP message and key ID to the receiver.
2.        Upon receiving the message, the receiver performs the following tasks:
a.    Finds the key according to the key ID in the message.
b.    Uses the key and the same authentication algorithm to calculate the digest.
c.    Compares the digest with the digest contained in the NTP message.
-      If they are different, the receiver discards the message.
-      If they are the same and an NTP session is not required to be created, the receiver responds to the message. For information about NTP sessions, see "Configuring the maximum number of dynamic associations."
-      If they are the same and an NTP session is to be created or has been created, the local device determines whether the sender is allowed to use the authentication ID. If the sender is allowed to use the authentication ID, the receiver accepts the message. If the sender is not allowed to use the authentication ID, the receiver discards the message.
·          RFC 1305, Network Time Protocol (Version 3) Specification, Implementation and Analysis
·          RFC 5905, Network Time Protocol Version 4: Protocol and Algorithms Specification
When you configure NTP, follow these restrictions and guidelines:
·          You cannot configure both NTP and SNTP on the same device.
·          NTP is supported only on the following Layer 3 interfaces:
¡  Layer 3 Ethernet interfaces.
¡  Layer 3 Ethernet subinterfaces.
¡  Layer 3 aggregate interfaces.
¡  VLAN interfaces.
·          Do not configure NTP on an aggregate member port.
·          The NTP service and SNTP service are mutually exclusive. You can only enable either NTP service or SNTP service at a time.
·          To avoid frequent time changes or even synchronization failures, do not specify more than one reference source on a network.
·          Make sure you use the clock protocol command to specify the time protocol as NTP. For more information about the clock protocol command, see Fundamentals Command Reference.
Tasks at a glance
(Required.) Enabling the NTP service
(Required.) Perform one or both of the following tasks:
·         Configuring NTP association mode
·         Configuring the local clock as a reference source
(Optional.) Configuring access control rights
(Optional.) Configuring NTP authentication
(Optional.) Configuring NTP optional parameters
Step
Remarks
1.       Enter system view.
N/A
2.       Enable the NTP service.
ntp-service enable
By default, the NTP service is disabled.
This section describes how to configure NTP association mode.
Follow these guidelines when you configure an NTP client:
·          For the client to synchronize to an NTP server, make sure the server is synchronized by other devices or uses its local clock as a reference source.
·          If the stratum level of a server is higher than or equal to a client, the client will not synchronize to that server.
·          You can configure multiple servers by executing the ntp-service unicast-server or ntp-service ipv6 unicast-server commands multiple times.
·          When the device operates in client/server mode, specify the IP address for the server on the client.
To configure an NTP client:
Step
Remarks
N/A
2.       Specify an NTP server for the device.
·         Specify an NTP server for the device:
ntp-service unicast-server { server-name | ip-address } [ authentication-keyid keyid | priority | source interface-type interface-number | version number ] *
·         Specify an IPv6 NTP server for the device:
ntp-service ipv6 unicast-server { server-name | ipv6-address } [ authentication-keyid keyid | priority | source interface-type interface-number ] *
By default, no NTP server is specified.
Follow these guidelines when you configure a symmetric-active peer:
·          For a symmetric-passive peer to process NTP messages from a symmetric-active peer, execute the ntp-service enable command on the symmetric passive peer to enable NTP.
·          For time synchronization between the symmetric-active peer and the symmetric-passive peer, make sure either or both of them are in synchronized state.
·          You can configure multiple symmetric-passive peers by executing the ntp-service unicast-peer or ntp-service ipv6 unicast-peer command multiple times.
·          When the device operates in symmetric active/passive mode, specify on a symmetric-active peer the IP address for a symmetric-passive peer.
To configure a symmetric-active peer:
Step
Remarks
N/A
2.       Specify a symmetric-passive peer for the device.
·         Specify a symmetric-passive peer:
ntp-service
unicast-peer { peer-name | ip-address } [ authentication-keyid keyid | priority | source interface-type interface-number | version number ] *
·         Specify an IPv6 symmetric-passive peer:
{ peer-name | ipv6-address } [ authentication-keyid keyid | priority | source interface-type interface-number ] *
By default, no symmetric-passive peer is specified.
For a broadcast client to synchronize to a broadcast server, make sure the broadcast server is synchronized by other devices or uses its local clock as a reference source.
Configure NTP in broadcast mode on both the broadcast server and client.
Configuring a broadcast client
Step
Remarks
N/A
2.       Enter interface view.
Enter the interface for receiving NTP broadcast messages.
3.       Configure the device to operate in broadcast client mode.
ntp-service broadcast-client
By default, the device does not operate in any NTP association mode.
After you execute the command, the device receives NTP broadcast messages from the specified interface.
Configuring the broadcast server
Step
Remarks
N/A
Enter the interface for sending NTP broadcast messages.
3.       Configure the device to operate in NTP broadcast server mode.
After you execute the command, the device sends NTP broadcast messages from the specified interface.
For a multicast client to synchronize to a multicast server, make sure the multicast server is synchronized by other devices or uses its local clock as a reference source.
Configure NTP in multicast mode on both the multicast server and client.
Configuring a multicast client
Step
Remarks
N/A
Enter the interface for receiving NTP multicast messages.
3.       Configure the device to operate in multicast client mode.
·         Configure the device to operate in multicast client mode:
ntp-service
multicast-client [ ip-address ]
·         Configure the device to operate in IPv6 multicast client mode:
ntp-service ipv6 multicast-client
ipv6-address
After you execute the command, the device receives NTP multicast messages from the specified interface.
Configuring the multicast server
Step
Remarks
N/A
Enter the interface for sending NTP multicast message.
3.       Configure the device to operate in multicast server mode.
·         Configure the device to operate in multicast server mode:
ntp-service multicast-server
[ ip-address ] [ authentication-keyid keyid | ttl ttl-number | version number ] *
ntp-service ipv6 multicast-server
ipv6-address [ authentication-keyid keyid | ttl ttl-number ] *
Step
Remarks
N/A
2.       Configure the right for the peer devices to access the NTP services on the local device.
·         Configure the right for the peer devices to access the IPv4 NTP services on the local device:
ntp-service access { peer | query | server | synchronization } acl ipv4-acl-number
·         Configure the right for the peer devices to access the IPv6 NTP services on the local device:
ntp-service ipv6 { peer | query | server | synchronization } acl ipv6-acl-number
By default, the right for the peer devices to access the IPv6 NTP services on the local device is peer.
Before you configure the NTP service access control right to the local device, create and configure an ACL associated with the access control right. For more information about ACL, see ACL and QoS Configuration Guide.
This section provides instructions for configuring NTP authentication.
To ensure a successful NTP authentication in client/server mode, configure the same authentication key ID, algorithm, and key on the server and client. Make sure the peer device is allowed to use the key ID on the local device.
To configure NTP authentication for a client:
Step
Remarks
N/A
2.       Enable NTP authentication.
ntp-service authentication enable
By default, NTP authentication is disabled.
3.       Configure an NTP authentication key.
ntp-service authentication-keyid keyid authentication-mode { hmac-sha-1 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 | md5 } { cipher | simple } string [ acl ipv4-acl-number | ipv6 acl ipv6-acl-number ] *
By default, no NTP authentication key exists.
4.       Configure the key as a trusted key.
By default, no authentication key is configured as a trusted key.
5.       Associate the specified key with an NTP server.
·         Associate the specified key with an NTP server:
ntp-service
unicast-server { server-name | ip-address } authentication-keyid keyid
·         Associate the specified key with an IPv6 NTP server:
ntp-service
ipv6 unicast-server { server-name | ipv6-address } authentication-keyid keyid
N/A
To configure NTP authentication for a server:
Step
Remarks
N/A
NTP authentication results differ when different configurations are performed on client and server. For more information, see Table 2. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 2 NTP authentication results
Client
Server
Specify the server and key
Trusted key
Trusted key
Successful authentication
Yes
Yes
Yes
Yes
Yes
Failed authentication
Yes
Yes
Yes
Yes
No
Yes
Yes
Yes
No
N/A
Yes
Yes
No
N/A
N/A
Authentication not performed
Yes
No
N/A
N/A
N/A
No
N/A
N/A
N/A
N/A
To ensure a successful NTP authentication in symmetric active/passive mode, configure the same authentication key ID, algorithm, and key on the active peer and passive peer. Make sure the peer device is allowed to use the key ID on the local device.
To configure NTP authentication for an active peer:
Step
Remarks
N/A
5.       Associate the specified key with a passive peer.
·         Associate the specified key with a passive peer:
{ ip-address | peer-name } authentication-keyid keyid
{ ipv6-address | peer-name } authentication-keyid keyid
N/A
To configure NTP authentication for a passive peer:
Step
Remarks
N/A
NTP authentication results differ when different configurations are performed on active peer and passive peer. For more information, see Table 3. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 3 NTP authentication results
Active peer
Passive peer
Specify the peer and key
Trusted key
Stratum level
Trusted key
Yes
Yes
Yes
N/A
Yes
Yes
Yes
Yes
Yes
N/A
Yes
No
Yes
Yes
Yes
N/A
No
N/A
Yes
No
N/A
N/A
Yes
N/A
No
N/A
N/A
N/A
Yes
N/A
Yes
Yes
No
Larger than the passive peer
N/A
N/A
Yes
Yes
No
Smaller than the passive peer
Yes
N/A
Yes
No
N/A
N/A
No
N/A
No
N/A
N/A
N/A
No
N/A
Yes
Yes
No
No
N/A
To ensure a successful NTP authentication in broadcast mode, configure the same authentication key ID, algorithm, and key on the broadcast server and client. Make sure the peer device is allowed to use the authentication ID on the local device.
To configure NTP authentication for a broadcast client:
Step
Remarks
N/A
To configure NTP authentication for a broadcast server:
Step
Remarks
N/A
5.       Enter interface view.
N/A
6.       Associate the specified key with the broadcast server.
ntp-service broadcast-server authentication-keyid keyid
By default, the broadcast server is not associated with any key.
NTP authentication results differ when different configurations are performed on broadcast client and server. For more information, see Table 4. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 4 NTP authentication results
Broadcast server
Broadcast client
Trusted key
Trusted key
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
Yes
No
N/A
Yes
Yes
No
Yes
N/A
Yes
No
N/A
Yes
N/A
No
N/A
N/A
Yes
N/A
Yes
Yes
No
No
N/A
Yes
No
N/A
No
N/A
No
N/A
N/A
No
N/A
To ensure a successful NTP authentication in multicast mode, configure the same authentication key ID, algorithm, and key on the multicast server and client. Make sure the peer device is allowed to use the authentication ID on the local device.
To configure NTP authentication for a multicast client:
Step
Remarks
N/A
To configure NTP authentication for a multicast server:
Step
Remarks
N/A
N/A
6.       Associate the specified key with the multicast server.
·         Associate the specified key with a multicast server:
[ ip-address ] authentication-keyid keyid
·         Associate the specified key with an IPv6 multicast server:
ipv6-multicast-address authentication-keyid keyid
By default, no multicast server is associated with the specified key.
NTP authentication results differ when different configurations are performed on broadcast client and server. For more information, see Table 5. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 5 NTP authentication results
Multicast server
Multicast client
Trusted key
Trusted key
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
Yes
No
N/A
Yes
Yes
No
Yes
N/A
Yes
No
N/A
Yes
N/A
No
N/A
N/A
Yes
N/A
Yes
Yes
No
No
N/A
Yes
No
N/A
No
N/A
No
N/A
N/A
No
N/A
The configuration tasks in this section are optional tasks. Configure them to improve NTP security, performance, or reliability.
To prevent interface status changes from causing NTP communication failures, configure the device to use the IP address of an interface that is always up. For example, you can configure the device to use a loopback interface as the source IP address for the NTP messages to be sent.
When the device responds to an NTP request, the source IP address of the NTP response is always the IP address of the interface that has received the NTP request.
Follow these guidelines when you specify the source interface for NTP messages:
·          If you have specified the source interface for NTP messages in the ntp-service unicast-server/ntp-service ipv6 unicast-server or ntp-service unicast-peer/ntp-service ipv6 unicast-peer command, the specified interface acts as the source interface for NTP messages.
·          If you have configured the ntp-service broadcast-server or ntp-service multicast-server/ntp-service ipv6 multicast-server command in an interface view, this interface acts as the source interface for broadcast or multicast NTP messages.
To specify the source interface for NTP messages:
Step
Remarks
N/A
2.       Specify the source interface for NTP messages.
·         Specify the source interface for NTP messages:
ntp-service source
·         Specify the source interface for IPv6 NTP messages:
ntp-service ipv6 source
By default, no source interface is specified for NTP messages.
When NTP is enabled, all interfaces by default can receive NTP messages. For security purposes, you can disable some of the interfaces to receive NTP messages.
To disable an interface to receive NTP messages:
Step
Remarks
N/A
N/A
3.       Disable the interface to receive NTP messages.
·         For IPv4:
undo ntp-service inbound enable
·         For IPv6:
undo ntp-service ipv6 inbound enable
By default, an interface receives NTP messages.
NTP has the following types of associations:
·          Static association—A manually created association.
·          Dynamic association—Temporary association created by the system during NTP operation. A dynamic association is removed if no messages are exchanged within about 12 minutes.
The following describes how an association is established in different association modes:
·          Client/server mode—After you specify an NTP server, the system creates a static association on the client. The server simply responds passively upon the receipt of a message, rather than creating an association (static or dynamic).
·          Symmetric active/passive mode—After you specify a symmetric-passive peer on a symmetric active peer, static associations are created on the symmetric-active peer, and dynamic associations are created on the symmetric-passive peer.
·          Broadcast or multicast mode—Static associations are created on the server, and dynamic associations are created on the client.
A single device can have a maximum of 128 concurrent associations, including static associations and dynamic associations.
Perform this task to restrict the number of dynamic associations to prevent dynamic associations from occupying too many system resources.
To configure the maximum number of dynamic associations:
Step
Remarks
N/A
2.       Configure the maximum number of dynamic sessions allowed to be established.
By default, the command can establish up to 100 dynamic sessions.
The DSCP value determines the sending precedence of a packet.
To set a DSCP value for NTP packets:
Step
Remarks
N/A
2.       Set a DSCP value for NTP packets.
·         IPv4 packets:
ntp-service dscp dscp-value
·         IPv6 packets:
ntp-service ipv6 dscp dscp-value
The default DSCP value is 48 for IPv4 packets and 56 for IPv6 packets.
Follow these guidelines when you configure the local clock as a reference source:
·          Make sure the local clock can provide the time accuracy required for the network. After you configure the local clock as a reference source, the local clock is synchronized, and can operate as a time server to synchronize other devices in the network. If the local clock is incorrect, timing errors occur.
·          Before you configure this feature, adjust the local system time to make sure it is accurate.
·          Devices differ in clock precision. To avoid network flapping and clock synchronization failure, do not configure multiple reference sources on the same network segment.
To configure the local clock as a reference source:
Step
Remarks
N/A
2.       Configure the local clock as a reference source.
By default, the device does not use the local clock as a reference source.
Display information about IPv6 NTP associations.
display ntp-service ipv6 sessions [ verbose ]
Display information about IPv4 NTP associations.
display ntp-service sessions [ verbose ]
Display information about NTP service status.
display ntp-service status
Display brief information about the NTP servers from the local device back to the primary reference source.
display ntp-service trace [ source interface-type interface-number ]
As shown in Figure 4, perform the following tasks:
·          Configure the local clock of Device A as a reference source, with stratum level 2.
·          Configure Device B to operate in client mode and Device A to be used as the NTP server for Device B.
Figure 4 Network diagram
1.        Assign an IP address to each interface, and make sure Device A and Device B can reach each other, as shown in Figure 4. (Details not shown.)
2.        Configure Device A:
# Enable the NTP service.
[DeviceA] ntp-service enable
# Specify the local clock as the reference source, with stratum level 2.
[DeviceA] ntp-service refclock-master 2
3.        Configure Device B:
[DeviceB] ntp-service enable
# Specify the time protocol as NTP.
[DeviceB] clock protocol ntp
# Specify Device A as the NTP server of Device B so that Device B is synchronized to Device A.
[DeviceB] ntp-service unicast-server 1.0.1.11
4.        Verify the configuration:
# Verify that Device B has synchronized to Device A, and the clock stratum level is 3 on Device B and 2 on Device A.
[DeviceB] display ntp-service status
 Clock status: synchronized
 Clock stratum: 3
 System peer: 1.0.1.11
 Local mode: client
 Reference clock ID: 1.0.1.11
 Leap indicator: 00
 Clock jitter: 0.000977 s
 Stability: 0.000 pps
 Clock precision: 2^-20
 Root delay: 0.00383 ms
 Root dispersion: 16.26572 ms
 Reference time: d0c6033f.b9923965  Wed, Dec 29 2010 18:58:07.724
# Verify that an IPv4 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
[12345]1.0.1.11        127.127.1.0        2     1   64   15   -4.0 0.0038 16.262
 Total sessions: 1
As shown in Figure 5, perform the following tasks:
·          Configure Device B to operate in client mode and Device A to be used as the IPv6 NTP server for Device B.
Figure 5 Network diagram
1.        Assign an IP address to each interface, and make sure Device A and Device B can reach each other, as shown in Figure 5. (Details not shown.)
# Specify Device A as the IPv6 NTP server of Device B so that Device B is synchronized to Device A.
[DeviceB] ntp-service ipv6 unicast-server 3000::34
 Clock stratum: 3
 System peer: 3000::34
 Local mode: client
 Reference clock ID: 163.29.247.19
 Leap indicator: 00
 Root delay: 0.02649 ms
 Root dispersion: 12.24641 ms
 Reference time: d0c60419.9952fb3e  Wed, Dec 29 2010 19:01:45.598
# Verify that an IPv6 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service ipv6 sessions
 Source: [12345]3000::34
 Reference: 127.127.1.0          Clock stratum: 2
 Reachabilities: 15              Poll interval: 64
 Last receive time: 19           Offset: 0.0
 Roundtrip delay: 0.0            Dispersion: 0.0
 Total sessions: 1
As shown in Figure 6, perform the following tasks:
·          Configure Device A to operate in symmetric-active mode and specify Device B as the passive peer of Device A.
Figure 6 Network diagram
1.        Assign an IP address to each interface, and make sure Device A and Device B can reach each other, as shown in Figure 6. (Details not shown.)
2.        Configure Device B:
3.        Configure Device A:
[DeviceA] clock protocol ntp
# Configure Device B as a symmetric passive peer.
[DeviceA] ntp-service unicast-peer 3.0.1.32
# Verify that Device B has synchronized to Device A.
 Clock stratum: 3
 System peer: 3.0.1.31
 Local mode: sym_passive
 Reference clock ID: 3.0.1.31
 Leap indicator: 00
 Clock jitter: 0.000916 s
 Root delay: 0.00609 ms
 Root dispersion: 1.95859 ms
 Reference time: 83aec681.deb6d3e5  Wed, Jan  8 2014 14:33:11.081
   [12]3.0.1.31        127.127.1.0        2    62   64   34 0.4251 6.0882 1392.1
 Total sessions: 1
As shown in Figure 7, perform the following tasks:
·          Configure Device A to operate in symmetric-active mode and specify Device B as the IPv6 passive peer of Device A.
Figure 7 Network diagram
1.        Assign an IP address to each interface, and make sure Device A and Device B can reach each other, as shown in Figure 7. (Details not shown.)
# Configure Device B as an IPv6 symmetric passive peer.
[DeviceA] ntp-service ipv6 unicast-peer 3000::36
 Clock stratum: 3
 System peer: 3000::35
 Reference clock ID: 251.73.79.32
 Leap indicator: 11
 Root delay: 0.01855 ms
 Root dispersion: 9.23483 ms
 Reference time: d0c6047c.97199f9f  Wed, Dec 29 2010 19:03:24.590
 Source:  [1234]3000::35
 Total sessions: 1
As shown in Figure 8, Switch C functions as the NTP server for multiple devices on a network segment and synchronizes the time among multiple devices.
·          Configure Switch C's local clock as a reference source, with stratum level 2.
·          Configure Switch C to operate in broadcast server mode and send broadcast messages from VLAN-interface 2.
·          Configure Switch A and Switch B to operate in broadcast client mode, and listen to broadcast messages through VLAN-interface 2.
Figure 8 Network diagram
1.        Assign an IP address to each interface, and make sure Switch A, Switch B, and Switch C can reach each other, as shown in Figure 8. (Details not shown.)
2.        Configure Switch C:
[SwitchC] ntp-service enable
[SwitchC] clock protocol ntp
[SwitchC] ntp-service refclock-master 2
# Configure Switch C to operate in broadcast server mode and send broadcast messages through VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service broadcast-server
3.        Configure Switch A:
[SwitchA] ntp-service enable
[SwitchA] clock protocol ntp
# Configure Switch A to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchA-Vlan-interface2] ntp-service broadcast-client
4.        Configure Switch B:
[SwitchB] ntp-service enable
[SwitchB] clock protocol ntp
# Configure Switch B to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchB-Vlan-interface2] ntp-service broadcast-client
5.        Verify the configuration:
# Verify that Switch A has synchronized to Switch C, and the clock stratum level is 3 on Switch A and 2 on Switch C.
[SwitchA-Vlan-interface2] display ntp-service status
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
 Clock jitter: 0.044281 s
 Root delay: 0.00229 ms
 Root dispersion: 4.12572 ms
 Reference time: d0d289fe.ec43c720  Sat, Jan  8 2011  7:00:14.922
# Verify that an IPv4 NTP association has been established between Switch A and Switch C.
[SwitchA-Vlan-interface2] display ntp-service sessions
 [1245]3.0.1.31        127.127.1.0        2     1   64  519   -0.0 0.0022 4.1257
 Total sessions: 1
As shown in Figure 9, Switch C functions as the NTP server for multiple devices on different network segments and synchronizes the time among multiple devices.
·          Configure Switch C to operate in multicast server mode and send multicast messages from VLAN-interface 2.
·          Configure Switch A and Switch D to operate in multicast client mode and receive multicast messages through VLAN-interface 3 and VLAN-interface 2, respectively.
Figure 9 Network diagram
1.        Assign an IP address to each interface, and make sure the switches can reach each other, as shown in Figure 9. (Details not shown.)
# Configure Switch C to operate in multicast server mode and send multicast messages through VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service multicast-server
3.        Configure Switch D:
<SwitchD> system-view
[SwitchD] ntp-service enable
[SwitchD] clock protocol ntp
# Configure Switch D to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD] interface vlan-interface 2
[SwitchD-Vlan-interface2] ntp-service multicast-client
Switch D and Switch C are on the same subnet, so Switch D can do the following:
¡  Receive the multicast messages from Switch C without being enabled with the multicast functions.
¡  Synchronize to Switch C.
# Verify that Switch D has synchronized to Switch C, and the clock stratum level is 3 on Switch D and 2 on Switch C.
[SwitchD-Vlan-interface2] display ntp-service status
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
# Verify that an IPv4 NTP association has been established between Switch D and Switch C.
[SwitchD-Vlan-interface2] display ntp-service sessions
 Total sessions: 1
5.        Configure Switch B:
Because Switch A and Switch C are on different subnets, you must enable the multicast functions on Switch B before Switch A can receive multicast messages from Switch C.
# Enable IP multicast routing and IGMP.
[SwitchB] multicast routing
[SwitchB-mrib] quit
[SwitchB-Vlan-interface2] pim dm
[SwitchB] vlan 3
[SwitchB-vlan3] port gigabitethernet 1/0/1
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] igmp enable
[SwitchB-Vlan-interface3] igmp static-group 224.0.1.1
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB-GigabitEthernet1/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
6.        Configure Switch A:
# Configure Switch A to operate in multicast client mode and receive multicast messages on VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service multicast-client
7.        Verify the configuration:
[SwitchA-Vlan-interface3] display ntp-service status
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
 Clock jitter: 0.165741 s
 Root delay: 0.00534 ms
 Root dispersion: 4.51282 ms
 Reference time: d0c61289.10b1193f  Wed, Dec 29 2010 20:03:21.065
[SwitchA-Vlan-interface3] display ntp-service sessions
 [1234]3.0.1.31        127.127.1.0        2   247   64  381   -0.0 0.0053 4.5128
 Total sessions: 1
As shown in Figure 10, Switch C functions as the NTP server for multiple devices on different network segments and synchronizes the time among multiple devices.
·          Configure Switch C to operate in IPv6 multicast server mode and send IPv6 multicast messages from VLAN-interface 2.
·          Configure Switch A and Switch D to operate in IPv6 multicast client mode and receive IPv6 multicast messages through VLAN-interface 3 and VLAN-interface 2, respectively.
Figure 10 Network diagram
1.        Assign an IP address to each interface, and make sure the switches can reach each other, as shown in Figure 10. (Details not shown.)
# Configure Switch C to operate in IPv6 multicast server mode and send multicast messages through VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service ipv6 multicast-server ff24::1
# Configure Switch D to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
¡  Receive the IPv6 multicast messages from Switch C without being enabled with the IPv6 multicast functions.
 Clock stratum: 3
 System peer: 3000::2
 Local mode: bclient
 Reference clock ID: 165.84.121.65
 Leap indicator: 00
 Root delay: 0.00000 ms
 Root dispersion: 8.00578 ms
 Reference time: d0c60680.9754fb17  Wed, Dec 29 2010 19:12:00.591
# Verify that an IPv6 NTP association has been established between Switch D and Switch C.
[SwitchD-Vlan-interface2] display ntp-service ipv6 sessions
 Source:  [1234]3000::2
 Reachabilities: 111              Poll interval: 64
 Last receive time: 23            Offset: -0.0
 Total sessions: 1
Because Switch A and Switch C are on different subnets, you must enable the IPv6 multicast functions on Switch B before Switch A can receive IPv6 multicast messages from Switch C.
# Enable IPv6 multicast functions.
[SwitchB] ipv6 multicast routing
[SwitchB-mrib6] quit
[SwitchB-Vlan-interface2] ipv6 pim dm
[SwitchB] vlan 3
[SwitchB-Vlan-interface3] mld enable
[SwitchB-Vlan-interface3] mld static-group ff24::1
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
[SwitchB-GigabitEthernet1/0/1] mld-snooping static-group ff24::1 vlan 3
# Configure Switch A to operate in IPv6 multicast client mode and receive IPv6 multicast messages on VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service ipv6 multicast-client ff24::1
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
# Verify that an IPv6 NTP association has been established between Switch A and Switch C.
[SwitchA-Vlan-interface3] display ntp-service ipv6 sessions
 Source:   [124]3000::2
 Reachabilities: 2                Poll interval: 64
 Last receive time: 71            Offset: -0.0
 Total sessions: 1
As shown in Figure 11, perform the following tasks:
·          Configure Device B to operate in client mode and specify Device A as the NTP server of Device B.
·          Configure NTP authentication on both Device A and Device B.
Figure 11 Network diagram
1.        Assign an IP address to each interface, and make sure Device A and Device B can reach each other, as shown in Figure 11. (Details not shown.)
# Enable NTP authentication on Device B.
[DeviceB] ntp-service authentication enable
# Set an authentication key, and input the key in plain text.
[DeviceB] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
# Specify the key as a trusted key.
[DeviceB] ntp-service reliable authentication-keyid 42
# Specify Device A as the NTP server of Device B, and associate the server with key 42.
[DeviceB] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
Before Device B can synchronize its clock to that of Device A, enable NTP authentication for Device A.
4.        Configure NTP authentication on Device A:
# Enable NTP authentication.
[DeviceA] ntp-service authentication enable
[DeviceA] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[DeviceA] ntp-service reliable authentication-keyid 42
 Clock stratum: 3
 Local mode: client
 Leap indicator: 00
 Clock jitter: 0.005096 s
 Root delay: 0.00655 ms
 Root dispersion: 1.15869 ms
 Reference time: d0c62687.ab1bba7d  Wed, Dec 29 2010 21:28:39.668
 [1245]1.0.1.11        127.127.1.0        2     1   64  519   -0.0 0.0065    0.0
 Total sessions: 1
As shown in Figure 12, Switch C functions as the NTP server for multiple devices on different network segments and synchronizes the time among multiple devices. Switch A and Switch B authenticate the reference source.
·          Configure Switch C's local clock as a reference source, with stratum level 3.
·          Configure Switch A and Switch B to operate in broadcast client mode and receive broadcast messages through VLAN-interface 2.
·          Enable NTP authentication on Switch A, Switch B, and Switch C.
Figure 12 Network diagram
1.        Assign an IP address to each interface, and make sure Switch A, Switch B, and Switch C can reach each other, as shown in Figure 12. (Details not shown.)
2.        Configure Switch A:
# Enable NTP authentication on Switch A. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[SwitchA] ntp-service authentication enable
[SwitchA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchA] ntp-service reliable authentication-keyid 88
# Configure Switch A to operate in NTP broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
3.        Configure Switch B:
# Enable NTP authentication on Switch B. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text and specify it as a trusted key.
[SwitchB] ntp-service authentication enable
[SwitchB] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchB] ntp-service reliable authentication-keyid 88
# Configure Switch B to operate in broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
4.        Configure Switch C:
# Specify the local clock as the reference source, with stratum level 3.
[SwitchC] ntp-service refclock-master 3
# Configure Switch C to operate in NTP broadcast server mode and use VLAN-interface 2 to send NTP broadcast packets.
NTP authentication is enabled on Switch A and Switch B, but not on Switch C, so Switch A and Switch B cannot synchronize their local clocks to Switch C.
# Verify that Switch B has not synchronized to Switch C.
[SwitchB-Vlan-interface2] display ntp-service status
 Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
6.        Enable NTP authentication on Switch C:
# Enable NTP authentication on Switch C. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[SwitchC] ntp-service authentication enable
[SwitchC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchC] ntp-service reliable authentication-keyid 88
# Specify Switch C as an NTP broadcast server, and associate the key 88 with Switch C.
[SwitchC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
# Verify that Switch B has synchronized to Switch C, and the clock stratum level is 4 on Switch B and 3 on Switch C.
 Clock stratum: 4
 Local mode: bclient
 Leap indicator: 00
 Clock jitter: 0.006683 s
 Root delay: 0.00127 ms
 Root dispersion: 2.89877 ms
 Reference time: d0d287a7.3119666f  Sat, Jan  8 2011  6:50:15.191
# Verify that an IPv4 NTP association has been established between Switch B and Switch C.
[SwitchB-Vlan-interface2] display ntp-service sessions
 [1245]3.0.1.31        127.127.1.0        3     3   64   68   -0.0 0.0000    0.0
 Total sessions: 1
Configuring SNTP
SNTP is a simplified, client-only version of NTP specified in RFC 4330. SNTP supports only the client/server mode. An SNTP-enabled device can receive time from NTP servers, but cannot provide time services to other devices.
SNTP uses the same packet format and packet exchange procedure as NTP, but provides faster synchronization at the price of time accuracy.
If you specify multiple NTP servers for an SNTP client, the server with the best stratum is selected. If multiple servers are at the same stratum, the NTP server whose time packet is first received is selected.
When you configure SNTP, follow these restrictions and guidelines:
Tasks at a glance
(Required.) Enabling the SNTP service
(Required.) Specifying an NTP server for the device
(Optional.) Configuring SNTP authentication
To enable the SNTP service:
Step
Remarks
N/A
2.       Enable the SNTP service.
sntp enable
By default, the SNTP service is not enabled.
Step
Remarks
N/A
·         For IPv4:
sntp unicast-server
{ server-name | ip-address } [ authentication-keyid keyid | source interface-type interface-number | version number ] *
·         For IPv6:
sntp ipv6 unicast-server
{ server-name | ipv6-address } [ authentication-keyid keyid | source interface-type interface-number ] *
By default, no NTP server is specified for the device.
Repeat this step to specify multiple NTP servers.
To use authentication, you must specify the authentication-keyid keyid option.
To use an NTP server as the time source, make sure its clock has been synchronized. If the stratum level of the NTP server is greater than or equal to that of the client, the client does not synchronize with the NTP server.
SNTP authentication ensures that an SNTP client is synchronized only to an authenticated trustworthy NTP server.
Follow these guidelines when you configure SNTP authentication:
·          Enable authentication on both the NTP server and the SNTP client.
·          Use the same authentication key ID, algorithm, and key on the NTP server and SNTP client. Specify the key as a trusted key on both the NTP server and the SNTP client. For information about configuring NTP authentication on an NTP server, see "Configuring NTP."
·          On the SNTP client, associate the specified key with an NTP server on the SNTP client. Make sure the server is allowed to use the key ID for authentication on the client.
With authentication disabled, the SNTP client can synchronize with the NTP server regardless of whether the NTP server is enabled with authentication.
To configure SNTP authentication on the SNTP client:
Step
Remarks
N/A
2.       Enable SNTP authentication.
sntp authentication enable
By default, SNTP authentication is disabled.
3.       Configure an SNTP authentication key.
sntp authentication-keyid keyid authentication-mode { hmac-sha-1 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 | md5 } { cipher | simple } string [ acl ipv4-acl-number | ipv6 acl ipv6-acl-number ] *
By default, no SNTP authentication key exists.
4.       Specify the key as a trusted key.
sntp reliable authentication-keyid keyid
By default, no trusted key is specified.
5.       Associate the SNTP authentication key with an NTP server.
·         For IPv4:
sntp unicast-server
·         For IPv6:
Display information about all IPv6 SNTP associations.
display sntp ipv6 sessions
Display information about all IPv4 SNTP associations.
display sntp sessions
As shown in Figure 13, perform the following tasks:
·          Configure Device B to operate in SNTP client mode, and specify Device A as the NTP server.
·          Configure NTP authentication on Device A and SNTP authentication on Device B.
Figure 13 Network diagram
1.        Assign an IP address to each interface, and make sure Device A and Device B can reach each other, as shown in Figure 13. (Details not shown.)
# Configure the local clock of Device A as a reference source, with stratum level 2.
# Enable NTP authentication on Device A.
# Configure an NTP authentication key, with the key ID of 10 and key value of aNiceKey. Input the key in plain text.
[DeviceA] ntp-service authentication-keyid 10 authentication-mode md5 simple aNiceKey
[DeviceA] ntp-service reliable authentication-keyid 10
# Enable the SNTP service.
[DeviceB] sntp enable
# Enable SNTP authentication on Device B.
[DeviceB] sntp authentication enable
# Configure an SNTP authentication key, with the key ID of 10 and key value of aNiceKey. Input the key in plain text.
[DeviceB] sntp authentication-keyid 10 authentication-mode md5 simple aNiceKey
[DeviceB] sntp reliable authentication-keyid 10
# Specify Device A as the NTP server of Device B, and associate the server with key 10.
[DeviceB] sntp unicast-server 1.0.1.11 authentication-keyid 10
# Verify that an SNTP association has been established between Device B and Device A, and Device B has synchronized to Device A.
[DeviceB] display sntp sessions
NTP server     Stratum   Version    Last receive time
1.0.1.11        2         4          Tue, May 17 2011  9:11:20.833 (Synced)
