- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Web authentication configuration
- 06-Triple authentication configuration
- 07-Port security configuration
- 08-User profile configuration
- 10-Keychain configuration
- 11-Public key management
- 12-PKI configuration
- 13-IPsec configuration
- 14-SSH configuration
- 15-SSL configuration
- 16-Attack detection and prevention configuration
- 17-IP source guard configuration
- 18-ARP attack protection configuration
- 19-ND attack defense configuration
- 20-uRPF configuration
- 21-SAVI configuration
- 22-MFF configuration
- 23-FIPS configuration
- 24-802.1X client configuration
- 25-Crypto engine configuration
| 03-MAC authentication configuration | 238.06 KB |
Configuring MAC authentication
Specifying a MAC authentication domain
Configuring the user account format
Configuring MAC authentication timers
Setting the maximum number of concurrent MAC authentication users on a port
Enabling MAC authentication multi-VLAN mode on a port
Configuring MAC authentication delay
Enabling parallel processing of MAC authentication and 802.1X authentication
Configuring a MAC authentication guest VLAN
Configuring a MAC authentication critical VLAN
Enabling the MAC authentication critical voice VLAN
Configuring periodic MAC reauthentication
Including user IP addresses in MAC authentication requests
Enabling MAC authentication offline detection
Enabling the authorization VLAN auto-tag feature for MAC authentication
Logging off MAC authentication users
Enabling MAC authentication user logging
Displaying and maintaining MAC authentication
MAC authentication configuration examples
Local MAC authentication configuration example
RADIUS-based MAC authentication configuration example
ACL assignment configuration example
Overview
MAC authentication controls network access by authenticating source MAC addresses on a port. The feature does not require client software, and users do not have to enter a username and password for network access. The device initiates a MAC authentication process when it detects an unknown source MAC address on a MAC authentication-enabled port. If the MAC address passes authentication, the user can access authorized network resources. If the authentication fails, the device marks the MAC address as a silent MAC address, drops the packet, and starts a quiet timer. The device drops all subsequent packets from the MAC address within the quiet time. The quiet mechanism avoids repeated authentication during a short time.
NOTE: If the MAC address that has failed authentication is a static MAC address or a MAC address that has passed any security authentication, the device does not mark the MAC address as a silent address. |
User account policies
MAC authentication supports the following user account policies:
· One MAC-based user account for each user. The access device uses the source MAC addresses in packets as the usernames and passwords of users for MAC authentication. This policy is suitable for an insecure environment.
NOTE: MAC-based user account policy also supports configuring a password shared by all MAC-based user accounts. |
· One shared user account for all users. You specify one username and password, which are not necessarily a MAC address, for all MAC authentication users on the access device. This policy is suitable for a secure environment.
Authentication methods
You can perform MAC authentication on the access device (local authentication) or through a RADIUS server.
For more information about configuring local authentication and RADIUS authentication, see "Configuring AAA."
If MAC-based accounts are used, the access device by default sends the source MAC address of a packet as the username and password to the RADIUS server for authentication. If a password is configured for MAC-based accounts, the access device sends the configured password as the password to the RADIUS server.
If a shared account is used, the access device sends the shared account username and password to the RADIUS server for authentication.
Local authentication
If MAC-based accounts are used, the access device by default uses the source MAC address of a packet as the username and password to search the local account database for a match. If a password is configured for MAC-based accounts, the device uses the configured password to search the local account database for a match.
If a shared account is used, the access device uses the shared account username and password to search the local account database for a match.
VLAN assignment
Authorization VLAN
The authorization VLAN controls the access of a MAC authentication user to authorized network resources. The device supports authorization VLANs assigned locally or by a remote server.
IMPORTANT: Only remote servers can assign tagged authorization VLANs. |
Remote VLAN authorization
In remote VLAN authorization, you must configure an authorization VLAN for a user on the remote server. After the user authenticates to the server, the server assigns authorization VLAN information to the device. Then, the device assigns the user access port to the authorization VLAN as a tagged or untagged member.
The device supports assignment of the following authorization VLAN information by the remote server:
· VLAN ID.
· VLAN name, which must be the same as the VLAN description on the access device.
· A string of VLAN IDs and VLAN names.
In the string, some VLANs are represented by their IDs, and some VLANs are represented by their names.
· VLAN group name.
For more information about VLAN groups, see Layer 2—LAN Switching Configuration Guide.
· VLAN ID with a suffix of t or u.
The t and u suffixes require the device to assign the access port to the VLAN as a tagged or untagged member, respectively. For example, 2u indicates assigning the port to VLAN 2 as an untagged member.
If a VLAN name or VLAN group name is assigned, the device converts the information into a VLAN ID before VLAN assignment.
IMPORTANT: For a VLAN represented by its VLAN name to be assigned successfully, you must make sure the VLAN has been created on the device. To assign VLAN IDs with suffixes, make sure the user access port is a hybrid or trunk port. |
IMPORTANT: To ensure a successful assignment, the authorization VLANs assigned by the remote server cannot be any of the following types: · Dynamically learned VLANs. · Reserved VLANs. · Super VLANs. · Private VLANs. |
If the server assigns a group of VLANs, the access device selects a VLAN as described in Table 1.
Table 1 Authorization VLAN selection from a group of VLANs
VLAN information |
Authorization VLAN selection |
VLANs by IDs VLANs by names VLAN group name |
The device selects an authorization VLAN from the VLAN group for a user according to the following rules: · On a hybrid port with MAC-based VLAN enabled: ¡ If the port does not have online users, the device selects the VLAN with the lowest ID. ¡ If the port has online users, the device selects the VLAN that has the fewest online users. If two VLANs have the same number of online MAC authentication users, the device selects the VLAN with the lower ID. · On an access, trunk, or MAC-based VLAN disabled hybrid port: ¡ If the port does not have online users, the device selects the VLAN with the lowest ID. ¡ If the port has online users, the device examines the VLAN group for the VLAN of the online users. If the VLAN is found, the VLAN is assigned to the user as the authorization VLAN. If the VLAN is not found, VLAN authorization fails. |
VLAN IDs with suffixes |
1. The device selects the leftmost VLAN ID without a suffix, or the leftmost VLAN ID suffixed by u as an untagged VLAN, whichever is more leftmost. 2. The device assigns the untagged VLAN to the port as the PVID, and it assigns the remaining as tagged VLANs. If no untagged VLAN is assigned, the PVID of the port does not change. The port permits traffic from these tagged and untagged VLANs to pass through. For example, the authentication server sends the string 1u 2t 3 to the access device for a user. The device assigns VLAN 1 as an untagged VLAN and all remaining VLANs (including VLAN 3) as tagged VLANs. VLAN 1 becomes the PVID. |
Local VLAN authorization
To perform local VLAN authorization for a user, specify the VLAN ID in the authorization attribute list of the local user account for that user. For each local user, you can specify only one authorization VLAN ID. The user access port is assigned to the VLAN as an untagged member.
IMPORTANT: Local VLAN authorization does not support assignment of tagged VLANs. |
For more information about local user configuration, see "Configuring AAA."
Authorization VLAN manipulation on a MAC authentication-enabled port
Table 2 describes the way the network access device handles authorization VLANs (except for the VLANs specified with suffixes) for MAC authenticated users on a port.
Port type |
VLAN manipulation |
· Access port · Trunk port · Hybrid port with MAC-based VLAN disabled |
· The device assigns the port to the first authenticated user's authorization VLAN and sets the VLAN as the PVID if that authorization VLAN has the untagged attribute. · If the authorization VLAN has the tagged attribute, the device assigns the port to the authorization VLAN without changing its PVID. NOTE: The tagged attribute is supported only on trunk and hybrid ports. |
Hybrid port with MAC-based VLAN enabled |
The device maps the MAC address of each user to its own authorization VLAN regardless of whether the port is a tagged member. The PVID of the port does not change. |
IMPORTANT: · If the users are attached to a port whose link type is access, make sure the authorization VLAN assigned by the server has the untagged attribute. VLAN assignment will fail if the server issues a VLAN that has the tagged attribute. · When you assign VLANs to users attached to a trunk port or a MAC-based VLAN disabled hybrid port, make sure there is only one untagged VLAN. If a different untagged VLAN is assigned to a subsequent user, the user cannot pass authentication. · As a best practice to enhance network security, do not use the port hybrid vlan command to assign a hybrid port to an authorization VLAN as a tagged member. |
Guest VLAN
The MAC authentication guest VLAN on a port accommodates users that have failed MAC authentication for any reason other than server unreachable. For example, the VLAN accommodates users with invalid passwords entered.
You can deploy a limited set of network resources in the MAC authentication guest VLAN. For example, a software server for downloading software and system patches.
A hybrid port is always assigned to a MAC authentication guest VLAN as an untagged member. After the assignment, do not reconfigure the port as a tagged member in the VLAN.
Table 3 shows the way that the network access device handles guest VLANs for MAC authentication users.
Authentication status |
VLAN manipulation |
A user in the MAC authentication guest VLAN fails MAC authentication for any reason other than server unreachable. |
The user is still in the MAC authentication guest VLAN. |
A user in the MAC authentication guest VLAN passes MAC authentication. |
The device remaps the MAC address of the user to the authorization VLAN assigned by the authentication server. If no authorization VLAN is configured for the user on the authentication server, the device remaps the MAC address of the user to the PVID of the port. |
Critical VLAN
The MAC authentication critical VLAN on a port accommodates users that have failed MAC authentication because no RADIUS authentication servers are reachable. Users in a MAC authentication critical VLAN can access only network resources in the critical VLAN.
The critical VLAN feature takes effect when MAC authentication is performed only through RADIUS servers. If a MAC authentication user fails local authentication after RADIUS authentication, the user is not assigned to the critical VLAN. For more information about the authentication methods, see "Configuring AAA."
Table 4 shows the way that the network access device handles critical VLANs for MAC authentication users.
VLAN manipulation |
A user fails MAC authentication because all the RADIUS servers are unreachable. |
The device maps the MAC address of the user to the MAC authentication critical VLAN. The user is still in the MAC authentication critical VLAN if the user fails MAC reauthentication because all the RADIUS servers are unreachable. If no MAC authentication critical VLAN is configured, the device maps the MAC address of the user to the PVID of the port. |
A user in the MAC authentication critical VLAN fails MAC authentication for any reason other than server unreachable. |
If a guest VLAN has been configured, the device maps the MAC address of the user to the guest VLAN. If no guest VLAN is configured, the device maps the MAC address of the user to the PVID of the port. |
A user in the MAC authentication critical VLAN passes MAC authentication. |
The device remaps the MAC address of the user to the authorization VLAN assigned by the authentication server. If no authorization VLAN is configured for the user on the authentication server, the device remaps the MAC address of the user to the PVID of the access port. |
Critical voice VLAN
The MAC authentication critical voice VLAN on a port accommodates MAC authentication voice users that have failed authentication because none of the RADIUS servers in their ISP domain are reachable.
The critical voice VLAN feature takes effect when MAC authentication is performed only through RADIUS servers. If a MAC authentication voice user fails local authentication after RADIUS authentication, the user is not assigned to the critical voice VLAN. For more information about the authentication methods, see "Configuring AAA."
Table 5 shows the way that the network access device handles critical voice VLANs for MAC authentication voice users.
VLAN manipulation |
A voice user fails MAC authentication because all the RADIUS servers are unreachable. |
The device maps the MAC address of the voice user to the MAC authentication critical voice VLAN. The voice user is still in the MAC authentication critical voice VLAN if the voice user fails MAC reauthentication because all the RADIUS servers are unreachable. If no MAC authentication critical voice VLAN is configured, the device maps the MAC address of the voice user to the PVID of the port. |
A voice user in the MAC authentication critical voice VLAN fails MAC authentication for any reason other than server unreachable. |
If a guest VLAN has been configured, the device maps the MAC address of the voice user to the guest VLAN. If no guest VLAN is configured, the device maps the MAC address of the voice user to the PVID of the port. |
A voice user in the MAC authentication critical voice VLAN passes MAC authentication. |
The device remaps the MAC address of the voice user to the authorization VLAN assigned by the authentication server. If no authorization VLAN is configured for the voice user on the authentication server, the device remaps the MAC address of the voice user to the PVID of the access port. |
ACL assignment
You can specify an authorization ACL in the user account for a MAC authentication user to control the user's access to network resources. After the user passes MAC authentication, the authentication server assigns the authorization ACL to the access port to filter traffic for this user. Only the traffic that matches the deny rules in the ACL are rejected.
The authentication server can be the local access device or a RADIUS server. In either case, the server only specifies the ACL number. You must create the ACL and configure its rules on the access device.
To change the access control criteria for the user, you can use one of the following methods:
· Modify ACL rules on the access device.
· Specify another authorization ACL on the authentication server.
The supported authorization ACLs include basic ACLs with numbers in the range of 2000 to 2999 and advanced ACLs with numbers in the range of 3000 to 3999. For more information about ACLs, see ACL and QoS Configuration Guide.
User profile assignment
You can specify a user profile in the user account for a MAC authentication user to control the user's access to network resources. After the user passes MAC authentication, the authentication server assigns the user profile to the user to filter traffic for this user.
The authentication server can be the local access device or a RADIUS server. In either case, the server only specifies the user profile name. You must configure the user profile on the access device.
To change the user's access permissions, you can use one of the following methods:
· Modify the user profile configuration on the access device.
· Specify another user profile for the user on the authentication server.
For more information about user profiles, see "Configuring user profiles."
Redirect URL assignment
The device supports the URL attribute assigned by a RADIUS server. During MAC authentication, the HTTP or HTTP requests from a user are redirected to the Web interface specified by the server-assigned URL attribute. After the user passes the Web authentication, the RADIUS server records the MAC address of the Web user and uses a DM (Disconnect Message) to log off the Web user. When the user initiates MAC authentication again, it will pass the authentication and come online successfully.
Configuration prerequisites
Before you configure MAC authentication, complete the following tasks:
1. Configure an ISP domain and specify an AAA method. For more information, see "Configuring AAA."
¡ For local authentication, you must also create local user accounts (including usernames and passwords) and specify the lan-access service for local users.
¡ For RADIUS authentication, make sure the device and the RADIUS server can reach each other and create user accounts on the RADIUS server. If you are using MAC-based accounts, make sure the username and password for each account are the same as the MAC address of each MAC authentication user.
2. Make sure the port security feature is disabled. For more information about port security, see "Configuring port security."
When you configure MAC authentication, follow these restrictions and guidelines:
· MAC authentication configuration is supported only on Layer 2 Ethernet interfaces.
· Before enabling MAC authentication on a Layer 2 Ethernet interface, make sure the interface is not added to a Layer 2 aggregation group or a service loopback group.
Configuration task list
For MAC authentication to take effect on a port, you must enable this feature globally and on the port.
To enable MAC authentication:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable MAC authentication globally. |
mac-authentication |
By default, MAC authentication is disabled globally. |
3. Enter interface view. |
N/A |
4. Enable MAC authentication on the port. |
By default, MAC authentication is disabled on a port. |
By default, MAC authentication users are in the system default authentication domain. To implement different access policies for users, you can use one of the following methods to specify authentication domains for MAC authentication users:
· Specify a global authentication domain in system view. This domain setting applies to all ports enabled with MAC authentication.
· Specify an authentication domain for an individual port in interface view.
MAC authentication chooses an authentication domain for users on a port in this order: the port-specific domain, the global domain, and the default domain. For more information about authentication domains, see "Configuring AAA."
To specify an authentication domain for MAC authentication users:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify an authentication domain for MAC authentication users. |
In system view: · In interface view: a. interface interface-type interface-number b. mac-authentication domain domain-name |
By default, the system default authentication domain is used for MAC authentication users. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the MAC authentication user account format. |
Use one MAC-based user account for each user: ·
Use one shared user account for all
users: |
By default, the device uses the MAC address of a user as the username and password for MAC authentication. The MAC address is in hexadecimal notation without hyphens, and letters are in lower case. |
MAC authentication uses the following timers:
· Offline detect timer—Sets the interval that the device waits for traffic from a user before the device determines that the user is idle. If the device has not received traffic from a user before the timer expires, the device logs off that user and requests the accounting server to stop accounting for the user. This timer takes effect only when the MAC authentication offline detection feature is enabled.
As a best practice, set the MAC address aging timer to the same value as the offline detect timer. This operation prevents a MAC authenticated user from being logged off within the offline detect interval because of MAC address entry expiration.
· Quiet timer—Sets the interval that the device must wait before the device can perform MAC authentication for a user that has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
· Server timeout timer—Sets the interval that the device waits for a response from a RADIUS server before the device determines that the RADIUS server is unavailable. If the timer expires during MAC authentication, the user cannot access the network.
To configure MAC authentication timers:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure MAC authentication timers. |
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value } |
By default, the offline detect timer is 300 seconds, the quiet timer is 60 seconds, and the server timeout timer is 100 seconds. |
Perform this task to prevent the system resources from being overused.
To set the maximum number of concurrent MAC authentication users on a port:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Set the maximum number of concurrent MAC authentication users on the port |
mac-authentication max-user max-number |
The default setting is 4294967295. |
The MAC authentication multi-VLAN mode prevents an authenticated online user from service interruption caused by VLAN changes on a port. When the port receives a packet sourced from the user in a VLAN not matching the existing MAC-VLAN mapping, the device neither logs off the user nor reauthenticates the user. The device creates a new MAC-VLAN mapping for the user, and traffic transmission is not interrupted. The original MAC-VLAN mapping for the user remains on the device until it dynamically ages out. As a best practice, configure this feature on hybrid or trunk ports.
This feature improves transmission of data that is vulnerable to delay and interference. It is typically applicable to IP phone users.
To enable MAC authentication multi-VLAN mode on a port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable MAC authentication multi-VLAN mode. |
mac-authentication host-mode multi-vlan |
By default, this feature is disabled on a port. When the port receives a packet sourced from an authenticated user in a VLAN not matching the existing MAC-VLAN mapping, the device logs off and reauthenticates the user. |
When both 802.1X authentication and MAC authentication are enabled on a port, you can delay MAC authentication so that 802.1X authentication is preferentially triggered.
If no 802.1X authentication is triggered or 802.1X authentication fails within the delay period, the port continues to process MAC authentication.
Do not set the port security mode to mac-else-userlogin-secure or mac-else-userlogin-secure-ext when you use MAC authentication delay. The delay does not take effect on a port in either of the two modes. For more information about port security modes, see "Configuring port security."
To configure MAC authentication delay:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable MAC authentication delay and set the delay timer. |
mac-authentication timer auth-delay auth-delay-time |
By default, MAC authentication delay is disabled. |
This feature enables a port that processes MAC authentication after 802.1X authentication is finished to process MAC authentication in parallel with 802.1X authentication.
When the port receives a packet from an unknown MAC address, it sends a unicast EAP-Request/Identity packet to the MAC address. After that, the port immediately processes MAC authentication without waiting for the 802.1X authentication result.
After MAC authentication succeeds, the port is assigned to the MAC authentication authorization VLAN.
· If 802.1X authentication fails, the MAC authentication result takes effect.
· If 802.1X authentication succeeds, the device handles the port and the MAC address based on the 802.1X authentication result.
When you enable parallel processing of MAC authentication and 802.1X authentication on a port, follow these restrictions and guidelines:
· Make sure the port meets the following requirements:
¡ The port is configured with both 802.1X authentication and MAC authentication and performs MAC-based access control for 802.1X authentication.
¡ The port is enabled with the 802.1X unicast trigger.
· For the port to perform MAC authentication before it is assigned to the 802.1X guest VLAN, enable new MAC-triggered 802.1X guest VLAN assignment delay.
For information about new MAC-triggered 802.1X guest VLAN assignment delay, see "Configuring 802.1X."
· For the parallel processing feature to work correctly, do not enable MAC authentication delay on the port. This operation will delay MAC authentication after 802.1X authentication is triggered.
· To configure both 802.1X authentication and MAC authentication on the port, use one of the following methods:
¡ Enable the 802.1X and MAC authentication features separately on the port.
¡ Enable port security on the port. The port security mode must be userlogin-secure-or-mac or userlogin-secure-or-mac-ext.
For information about port security mode configuration, see "Configuring port security."
Configuration procedure
To enable parallel processing of MAC authentication and 802.1X authentication on a port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable parallel processing of MAC authentication and 802.1X authentication on the port. |
mac-authentication parallel-with-dot1x |
By default, this feature is disabled. |
You must configure the MAC authentication guest VLAN on a hybrid port. Before you configure the MAC authentication guest VLAN on a hybrid port, complete the following tasks:
· Enable MAC authentication globally and on the port.
· Enable MAC-based VLAN on the port.
· Create the VLAN to be specified as the MAC authentication guest VLAN.
· Configure the VLAN as an untagged member on the port.
When you configure the MAC authentication guest VLAN on a port, follow the guidelines in Table 6.
Table 6 Relationships of the MAC authentication guest VLAN with other security features
Feature |
Relationship description |
Reference |
Quiet feature of MAC authentication |
The MAC authentication guest VLAN feature has higher priority. When a user fails MAC authentication, the user can access the resources in the guest VLAN. The user's MAC address is not marked as a silent MAC address. |
Super VLAN |
You cannot specify a VLAN as both a super VLAN and a MAC authentication guest VLAN. |
See Layer 2—LAN Switching Configuration Guide. |
Port intrusion protection |
The guest VLAN feature has higher priority than the block MAC action but lower priority than the shutdown port action of the port intrusion protection feature. |
See "Configuring port security." |
To configure the MAC authentication guest VLAN on a port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify the MAC authentication guest VLAN on the port. |
mac-authentication guest-vlan guest-vlan-id |
By default, no MAC authentication guest VLAN exists. You can configure only one MAC authentication guest VLAN on a port. |
4. (Optional.) Set the authentication interval for users in the MAC authentication guest VLAN. |
mac-authentication guest-vlan auth-period period-value |
The default setting is 30 seconds. |
You must configure the MAC authentication critical VLAN on a hybrid port. Before you configure the MAC authentication critical VLAN on a hybrid port, complete the following tasks:
· Create the VLAN to be specified as the MAC authentication critical VLAN.
When you configure the MAC authentication critical VLAN on a port, follow the guidelines in Table 7.
Table 7 Relationships of the MAC authentication critical VLAN with other security features
Feature |
Reference |
The MAC authentication critical VLAN feature has higher priority. When a user fails MAC authentication because no RADIUS authentication server is reachable, the user can access the resources in the critical VLAN. The user's MAC address is not marked as a silent MAC address. |
Super VLAN |
You cannot specify a VLAN as both a super VLAN and a MAC authentication critical VLAN. |
The critical VLAN feature has higher priority than the block MAC action but lower priority than the shutdown port action of the port intrusion protection feature. |
To configure the MAC authentication critical VLAN on a port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify the MAC authentication critical VLAN on the port. |
mac-authentication critical vlan critical-vlan-id |
By default, no MAC authentication critical VLAN exists. You can configure only one MAC authentication critical VLAN on a port. |
Before you enable the MAC authentication critical voice VLAN on a port, complete the following tasks:
· Enable LLDP both globally and on the port.
The device uses LLDP to identify voice users. For information about LLDP, see Layer 2—LAN Switching Configuration Guide.
· Enable voice VLAN on the port.
For information about voice VLANs, see Layer 2—LAN Switching Configuration Guide.
To enable the MAC authentication critical voice VLAN feature on a port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the MAC authentication critical voice VLAN feature on a port. |
mac-authentication critical-voice-vlan |
By default, the MAC authentication critical voice VLAN feature is disabled on a port. |
Overview
Periodic MAC reauthentication reauthenticates online MAC authentication users at a user-configurable reauthentication interval. The reauthentication feature tracks the connection status of online users and updates the authorization attributes assigned by the server. The attributes include the ACL and VLAN.
By default, the device logs off online MAC authentication users if no server is reachable for MAC reauthentication. The keep-online feature keeps authenticated MAC authentication users online when no server is reachable for MAC reauthentication.
When you configure periodic MAC reauthentication, follow these restrictions and guidelines:
· The server-assigned RADIUS Session-Timeout (attribute 27) and Termination-Action (attribute 29) attributes together can affect the periodic MAC reauthentication feature. To display the server-assigned Session-Timeout and Termination-Action attributes, use the display mac-authentication connection command (see Security Command Reference).
¡ If the termination action is logging off users, periodic MAC reauthentication takes effect only when the periodic reauthentication timer is shorter than the session timeout timer. If the session timeout timer is shorter, the device logs off online authenticated users when the session timeout timer expires.
¡ If the termination action is reauthenticating users, the periodic MAC reauthentication configuration on the device cannot take effect. The device reauthenticates online MAC authentication users after the server-assigned session timeout timer expires.
Support for the server configuration and assignment of session timeout timer and termination action depends on the server model.
· You can set the periodic reauthentication timer either in system view or in interface view by using the mac-authentication timer reauth-period command. A change to the periodic reauthentication timer applies to online users only after the old timer expires.
The device selects a periodic reauthentication timer for MAC reauthentication in the following order:
a. Server-assigned reauthentication timer.
b. Port-specific reauthentication timer.
c. Global reauthentication timer.
d. Default reauthentication timer.
· In a fast-recovery network, you can use the keep-online feature to prevent MAC authentication users from coming online and going offline frequently.
· With the RADIUS DAS feature enabled, the device can receive the reauthentication attribute of a RADIUS authentication server through CoA messages. In this case, reauthentication will be performed regardless of whether periodic MAC reauthentication is enabled on the device. For information about RADIUS DAS configuration, see "Configuring AAA."
· The VLANs assigned to an online user before and after reauthentication can be the same or different.
· Modification to the MAC authentication domain or user account format setting does not affect the reauthentication of online MAC authentication users. The modified setting takes effect only on MAC authentication users that come online after the modification.
To configure periodic MAC reauthentication:
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Set the global periodic MAC reauthentication timer. |
mac-authentication timer reauth-period reauth-period-value |
The default setting is 3600 seconds. |
N/A |
4. Enable periodic MAC reauthentication. |
mac-authentication re-authenticate |
By default, periodic MAC reauthentication is disabled on a port. |
5. (Optional.) Set the periodic reauthentication timer on the port. |
By default, no periodic reauthentication timer is set on a port. The port uses the global periodic MAC reauthentication timer. |
6. (Optional.) Enable the keep-online feature for authenticated MAC authentication users on the port. |
mac-authentication re-authenticate server-unreachable keep-online |
By default, the keep-online feature is disabled. |
Overview
IMPORTANT: This feature can only operate in conjunction with an IMC server. |
To avoid IP conflicts that result from changes to static IP addresses, use this feature on a port that has MAC authentication users with static IP addresses.
This feature adds user IP addresses to the MAC authentication requests sent to the authentication server. When MAC authentication is triggered for a user, the device checks the user's IP address for invalidity.
· If the IP address is valid, the device sends a MAC authentication request with the IP address included.
· If the IP address is not a valid host IP address or the triggering packet does not contain an IP address, the device does not initiate MAC authentication.
· If the packet is a DHCP packet with a source IP address of 0.0.0.0, the device sends a MAC authentication request without including the IP address. In this case, the IMC server does not examine the user IP address when it performs authentication.
Upon receipt of the authentication request that includes a user's IP address, the IMC server compares the user's IP and MAC addresses with its local IP-MAC mappings.
· If an exact match is found or if no match is found, the user passes MAC authentication. In the latter case, the server creates an IP-MAC mapping for the user.
· If a mapping is found for the MAC address but the IP addresses do not match, the user fails the MAC authentication.
Do not use this feature in conjunction with the MAC authentication guest VLAN on a port. The device cannot perform MAC authentication for a user once that user is added to the MAC authentication guest VLAN.
To include user IP addresses in MAC authentication requests:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Include user IP addresses in MAC authentication requests. |
mac-authentication carry user-ip |
By default, a MAC authentication request does not include the user IP address. |
Enable MAC authentication offline detection to detect idle users on a port. If the port has not received traffic from a user when the offline detect timer expires, the device logs off that user and requests the accounting server to stop accounting for the users. For more information about the offline detect timer, see "Configuring MAC authentication timers."
Disabling this feature disables the device from inspecting the online user status.
To enable MAC authentication offline detection:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable MAC authentication offline detection. |
mac-authentication offline-detect enable |
By default, MAC authentication offline detection is enabled. |
Overview
After this feature is enabled on a port, the port will not examine whether the port permits the VLANs tagged in received packets to pass. Packets tagged with VLAN IDs can trigger MAC authentication even though the tagged VLAN IDs are not permitted on the port. When a user passes MAC authentication on a port, the device follows these rules to assign the port to the authorization VLAN:
· If the MAC-authentication-triggered packet is tagged with a VLAN ID, the device assigns the port to the authorization VLAN as a tagged member.
If no authorization VLAN is assigned to the user, the port is automatically assigned to the VLAN tagged in the packet as a tagged member.
· If the MAC-authentication-triggered packet does not contain a VLAN tag, the device assigns the port to the authorization VLAN as an untagged member.
If no authorization VLAN is assigned to the user, the port is automatically assigned to the port VLAN as an untagged member.
When the ignore-config mode is enabled, the device ignores the static VLAN assignment configuration for a port. Whether the port is assigned to the authorization VLAN as a tagged member is determined only by the authorization VLAN auto-tag feature.
When the ignore-config mode is disabled, the tagging status of the port in the authorization VLAN is determined by the static VLAN assignment configuration for the port. For information about the static VLAN assignment configuration for a port, see the port hybrid vlan vlan-list { tagged | untagged command in Layer 2–LAN Switching Command Reference.
When you enable this feature, follow these restrictions and guidelines:
· This feature takes effect only on hybrid ports with MAC-based VLAN enabled.
· The port's tagging status configuration in the authorization VLAN by this feature takes precedence over the AAA server's configuration of the port's tagging status in the authorization VLAN. However, when the authorization VLAN is the port VLAN, this command does not take effect.
· When a port is enabled with this feature, do not use the undo vlan command to delete the authorization VLANs authorized to authenticated users.
· When you configure this feature on a port, make sure the port does not have online users. This feature will not take effect if there are online users.
To enable the authorization VLAN auto-tag feature for MAC authentication:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the authorization VLAN auto-tag feature for MAC authentication. |
mac-authentication auto-tag [ ignore-config ] |
By default, the authorization VLAN auto-tag feature is disabled for MAC authentication. The AAA server's configuration of the port's tagging status in the authorization VLAN applies. |
Perform this task to log off specified MAC authentication users and clear information about these users from the device. These users must perform MAC authentication to come online again.
To log off MAC authentication users in user view:
Task |
Command |
Log off specified MAC authentication users. |
reset mac-authentication access-user [ interface interface-type interface-number | mac mac-address | username username | vlan vlan-id ] |
Overview
This feature enables the device to generate logs about MAC authentication users and send the logs to the information center. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To prevent excessive MAC authentication user log entries, use this feature only if you need to analyze abnormal MAC authentication user logins or logouts.
To enable MAC authentication user logging:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable MAC authentication user logging. |
mac-authentication access-user log enable [ failed-login | logoff | successful-login ] * |
By default, MAC authentication user logging is disabled. If you do not specify any parameters, this command enables all types of MAC authentication user logs. |
Task |
Command |
Display MAC authentication information. |
display mac-authentication [ interface interface-type interface-number ] |
Display MAC authentication connections. |
display mac-authentication connection [ open ] [ interface interface-type interface-number | slot slot-number | user-mac mac-address | user-name user-name ] |
Display MAC address information of MAC authentication users in specific MAC authentication VLANs. |
display mac-authentication mac-address { critical-vlan | guest-vlan } [ interface interface-type interface-number ] |
Clear MAC authentication statistics. |
reset mac-authentication statistics [ interface interface-type interface-number ] |
Remove users from the MAC authentication critical VLAN on a port. |
reset mac-authentication critical vlan interface interface-type interface-number [ mac-address mac-address ] |
Remove users from the MAC authentication critical voice VLAN on a port. |
reset mac-authentication critical-voice-vlan interface interface-type interface-number [ mac-address mac-address ] |
Remove users from the MAC authentication guest VLAN on a port. |
reset mac-authentication guest-vlan interface interface-type interface-number [ mac-address mac-address ] |
Network requirements
As shown in Figure 1, the device performs local MAC authentication on GigabitEthernet 1/0/1 to control Internet access of users.
Configure the device to meet the following requirements:
· Detect whether a user has gone offline every 180 seconds.
· Deny a user for 180 seconds if the user fails MAC authentication.
· Authenticate all users in ISP domain bbb.
· Use the MAC address of each user as both the username and password for authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case.
# Add a network access local user. In this example, configure both the username and password as Host A's MAC address 00-e0-fc-12-34-56.
[Device] local-user 00-e0-fc-12-34-56 class network
[Device-luser-network-00-e0-fc-12-34-56] password simple 00-e0-fc-12-34-56
# Specify the LAN access service for the user.
[Device-luser-network-00-e0-fc-12-34-56] service-type lan-access
[Device-luser-network-00-e0-fc-12-34-56] quit
# Configure ISP domain bbb to perform local authentication for LAN users.
[Device] domain bbb
[Device-isp-bbb] authentication lan-access local
[Device-isp-bbb] quit
# Enable MAC authentication on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mac-authentication
# Specify ISP domain bbb as the MAC authentication domain.
[Device] mac-authentication domain bbb
# Configure MAC authentication timers.
[Device] mac-authentication timer offline-detect 180
[Device] mac-authentication timer quiet 180
# Use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case.
[Device] mac-authentication user-name-format mac-address with-hyphen lowercase
# Enable MAC authentication globally.
# Display MAC authentication settings and statistics to verify your configuration.
[Device] display mac-authentication
MAC authentication : Enabled
User name format : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
Username : mac
Password : Not configured
Offline detect period : 180 s
Quiet period : 180 s
Server timeout : 100 s
Reauth period : 3600 s
Authentication domain : bbb
Online MAC-auth users : 1
Silent MAC users:
MAC address VLAN ID From port Port index
00e0-fc11-1111 8 GE1/0/1 1
GigabitEthernet1/0/1 is link-up
Carry User-IP : Not configured
Authentication domain : Not configured
Auth-delay timer : Disabled
Periodic reauth : Disabled
Guest VLAN : Not configured
Guest VLAN auth-period : 30 s
Critical VLAN : Not configured
Critical voice VLAN : Disabled
Host mode : Single VLAN
Offline detection : Enabled
Authentication order : Default
Guest VSI : Not configured
Guest VSI auth-period : 30 s
Critical VSI : Not configured
Auto-tag feature : Disabled
VLAN tag configuration ignoring : Disabled
Max online users : 4294967295
Authentication attempts : successful 1, failed 0
Current online users : 1
MAC address Auth state
00e0-fc12-3456 Authenticated
The output shows that Host A has passed MAC authentication and has come online. Host B failed MAC authentication and its MAC address is marked as a silent MAC address.
As shown in Figure 2, the device uses RADIUS servers to perform authentication, authorization, and accounting for users.
To control user access to the Internet by MAC authentication, perform the following tasks:
· Enable MAC authentication globally and on GigabitEthernet 1/0/1.
· Configure the device to detect whether a user has gone offline every 180 seconds.
· Configure the device to deny a user for 180 seconds if the user fails MAC authentication.
· Configure all users to belong to ISP domain bbb.
· Use a shared user account for all users, with username aaa and password 123456.
1. Make sure the RADIUS server and the access device can reach each other. (Details not shown.)
2. Configure the RADIUS servers:
# Create a shared account for MAC authentication users. (Details not shown.)
# Set username aaa and password 123456 for the account. (Details not shown.)
3. Configure RADIUS-based MAC authentication on the device:
# Configure a RADIUS scheme.
[Device] radius scheme 2000
[Device-radius-2000] primary authentication 10.1.1.1 1812
[Device-radius-2000] primary accounting 10.1.1.2 1813
[Device-radius-2000] key authentication simple abc
[Device-radius-2000] key accounting simple abc
[Device-radius-2000] user-name-format without-domain
[Device-radius-2000] quit
# Apply the RADIUS scheme to ISP domain bbb for authentication, authorization, and accounting.
[Device] domain bbb
[Device-isp-bbb] authentication default radius-scheme 2000
[Device-isp-bbb] authorization default radius-scheme 2000
[Device-isp-bbb] accounting default radius-scheme 2000
# Specify the MAC authentication domain as ISP domain bbb.
# Set MAC authentication timers.
# Specify username aaa and password 123456 in plain text for the account shared by MAC authentication users.
[Device] mac-authentication user-name-format fixed account aaa password simple 123456
# Verify the MAC authentication configuration.
Username format : Fixed account
Username : aaa
Password : ******
Silent MAC users:
As shown in Figure 3, configure the device to meet the following requirements:
· Use RADIUS servers to perform authentication, authorization, and accounting for users.
· Perform MAC authentication on GigabitEthernet 1/0/1 to control Internet access.
· Use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case.
· Use an ACL to deny authenticated users to access the FTP server at 10.0.0.1.
Make sure the RADIUS servers and the access device can reach each other.
1. Configure ACL 3000 to deny packets destined for 10.0.0.1.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 deny ip destination 10.0.0.1 0
2. Configure RADIUS-based MAC authentication on the device:
# Apply the RADIUS scheme to an ISP domain for authentication, authorization, and accounting.
[Device] domain bbb
# Specify the ISP domain for MAC authentication.
3. Configure the RADIUS servers:
# Add a user account with 00-e0-fc-12-34-56 as both the username and password on each RADIUS server. (Details not shown.)
# Specify ACL 3000 as the authorization ACL for the user account. (Details not shown.)
Username format : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
Username : mac
Offline detect period : 300 s
Quiet period : 60 s
Silent MAC users:
# Verify that you cannot ping the FTP server from the host.
C:\>ping 10.0.0.1
Pinging 10.0.0.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.0.0.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The output shows that ACL 3000 has been assigned to GigabitEthernet 1/0/1 to deny access to the FTP server.
