- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Web authentication configuration
- 06-Triple authentication configuration
- 07-Port security configuration
- 08-User profile configuration
- 10-Keychain configuration
- 11-Public key management
- 12-PKI configuration
- 13-IPsec configuration
- 14-SSH configuration
- 15-SSL configuration
- 16-Attack detection and prevention configuration
- 17-IP source guard configuration
- 18-ARP attack protection configuration
- 19-ND attack defense configuration
- 20-uRPF configuration
- 21-SAVI configuration
- 22-MFF configuration
- 23-FIPS configuration
- 24-802.1X client configuration
- 25-Crypto engine configuration
| 00-Preface | 98.53 KB |
This configuration guide describes fundamentals and configuration for security features, including:
· Identity authentication features (such as AAA and PKI).
· Access security features (such as 802.1X, MAC authentication, portal, and port security).
· Data security features (such as public key management, IPsec, SSL, SSH, Crypto engine and FIPS).
· Attack protection features (such as IP source guard, ARP attack protection, MFF, uRPF, and Attack detection and prevention).
· Audience
Audience
· Network planners.
· Network administrators working with the S5560-EI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
