- 11-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-Event MIB commands
- 08-NETCONF commands
- 09-CWMP commands
- 10-EAA commands
- 11-Process monitoring and maintenance commands
- 12-Mirroring commands
- 13-sFlow commands
- 14-Information center commands
- 15-Packet capture commands
| 14-Information center commands | 176.86 KB |
display diagnostic-logfile summary
display security-logfile summary
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center logfile overwrite-protection
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center syslog trap buffersize
diagnostic-logfile save
Use diagnostic-logfile save to manually save diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
You can specify the directory to save the diagnostic log file by using the info-center diagnostic-logfile directory command.
The system clears the diagnostic log file buffer after saving the buffered diagnostic logs to the diagnostic log file.
If the diagnostic log file buffer is empty, this command displays a success message event though no logs are saved to the diagnostic log file.
# Manually save diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
<Sysname> diagnostic-logfile save
The contents in the diagnostic log file buffer have been saved to the file flash:/diagfile/diagfile.log.
Use display diagnostic-logfile summary to display the diagnostic log file configuration.
# Display the diagnostic log file configuration.
<Sysname> display diagnostic-logfile summary
Diagnostic log file: Enabled.
Diagnostic log file size quota: 10 MB
Diagnostic log file directory: flash:/diagfile
Writing frequency: 24 hour 0 min 0 sec
Diagnostic log file |
Status of the diagnostic log file: · Enabled—Diagnostic logs can be output to the diagnostic log file. · Disabled—Diagnostic logs cannot be output to the diagnostic log file. |
Diagnostic log file size quota |
Maximum size for the diagnostic log file, in MB. |
Log file directory |
Directory where the diagnostic log file is saved. |
Writing frequency |
Interval at which the system saves diagnostic logs from the buffer to the diagnostic log file. |
display info-center
Use display info-center to display information center configuration.
display info-center
# Display information center configuration.
<Sysname> display info-center
Information Center: Enabled
Console: Enabled
Monitor: Enabled
Log host: Enabled
192.168.0.1,
port number: 5000, host facility: local7
Log buffer: Enabled
Max buffer size 1024, current buffer size 512,
Current messages 0, dropped messages 0, overwritten messages 0
Log file: Enabled
Security log file: Enabled
Information timestamp format:
Log host: Date
Other output destination: Date
display logbuffer
Use display logbuffer to display the state of the log buffer and the log information in the log buffer.
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ] *
reverse: Displays log entries chronologically, with the most recent entry at the top. If you do not specify this keyword, the command displays log entries chronologically, with the oldest entry at the top.
level severity: Specifies a severity level in the range of 0 to 7. If you do not specify a severity level, this command displays log information for all levels.
Severity value |
Level |
Keyword in commands |
0 |
Emergency |
The system is unusable. For example, the system authorization has expired. |
emergency |
1 |
Alert |
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit. |
alert |
2 |
Critical |
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails. |
critical |
3 |
Error |
Error condition. For example, the link state changes. |
error |
4 |
Warning |
Warning condition. For example, an interface is disconnected, or the memory resources are used up. |
warning |
5 |
Notification |
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots. |
notification |
6 |
Informational |
Informational message. For example, a command or a ping operation is executed. |
informational |
7 |
Debugging |
Debugging message. |
debugging |
size buffersize: Specifies the number of latest logs to be displayed. The value range is 1 to 1024. If you do not specify this option, the command displays all logs in the log buffer.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
# Display the state and log information of the log buffer.
<Sysname> display logbuffer
Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
Dropped messages: 0
Overwritten messages: 718
Current messages: 512
%Jun 17 15:57:09:578 2016 Sysname SYSLOG/7/SYS_RESTART:System restarted --
Log buffer |
Status of the log buffer: · Enabled—Logs can be output to the log buffer. · Disabled—Logs cannot be output to the buffer. |
Max buffer size |
Maximum buffer size supported by the device. |
Actual buffer size |
Maximum buffer size configured by using the info-center logbuffer size command. |
Dropped messages |
Number of dropped messages. |
Overwritten messages |
Number of overwritten messages. |
Current messages |
Number of current messages. |
reset logbuffer
display logbuffer summary
Use display logbuffer summary to display the summary of the log buffer.
display logbuffer summary [ level severity | slot slot-number ] *
level severity: Specifies a severity level in the range of 0 to 7. If you do not specify a severity level, this command displays log information of all levels in the log buffer. For more information about log levels, see Table 2.
# Display the summary of the log buffer.
<Sysname> display logbuffer summary
Slot EMERG ALERT CRIT ERROR WARN NOTIF INFO DEBUG
1 0 0 0 7 0 34 38 0
EMERG |
Represents emergency. For more information, see Table 2. |
ALERT |
Represents alert. For more information, see Table 2. |
CRIT |
Represents critical. For more information, see Table 2. |
ERROR |
Represents error. For more information, see Table 2. |
WARN |
Represents warning. For more information, see Table 2. |
NOTIF |
Represents notification. For more information, see Table 2. |
INFO |
Represents informational. For more information, see Table 2. |
DEBUG |
Represents debug. For more information, see Table 2. |
display logfile summary
Use display logfile summary to display the log file configuration.
# Display the log file configuration.
<Sysname> display logfile summary
Log file: Enabled.
Log file size quota: 10 MB
Log file directory: flash:/logfile
Writing frequency: 24 hour 0 min 10 sec
Table 5 Command output
Log file |
Log file status: · Enabled—Logs can be output to a log file. · Disabled—Logs cannot be output to a log file. |
Log file size quota |
Maximum storage space reserved for a log file, in MB. |
Log file directory. |
Writing frequency |
Log file writing frequency. |
Use display security-logfile summary to display the summary of the security log file.
security-audit
To use this command, a local user must have the security-audit user role. For information about configuring the security-audit user role, see Security Command Reference.
# Display the summary of the security log file.
<Sysname> display security-logfile summary
Security log file size quota: 10 MB
Security log file directory: flash:/seclog
Alarm threshold: 80%
Current usage: 30%
Table 6 Command output
Security log file |
Status of the security log file: · Enabled—Security logs can be output to the security log file. · Disabled—Security logs cannot be output to the security log file. |
Security log file size quota |
Maximum storage space reserved for the security log file. |
Security log file directory |
Security log file directory. |
Alarm-threshold |
Alarm threshold of the security log file usage. |
Current usage |
Current usage of the security log file. |
Writing frequency |
Security log file writing frequency. |
authorization-attribute (Security Command Reference)
enable log updown
Use enable log updown to enable an interface to generate link up or link down logs when the interface state changes.
Use undo enable log updown to disable an interface from generating link up or link down logs when the interface state changes.
enable log updown
All interfaces are allowed to generate link up and link down logs.
Interface view
# Disable GigabitEthernet 1/0/1 from generating link up or link down logs.
[Sysname-GigabitEthernet1/0/1] undo enable log updown
Use info-center diagnostic-logfile directory to configure the directory to save the diagnostic log file.
The diagnostic log file directory is flash:/diagfile.
dir-name: Specifies a directory by its name, a string of 1 to 64 characters.
The specified directory must have been created.
This command cannot survive an IRF reboot or a master/subordinate switchover.
# Set the diagnostic log file directory to flash:/test.
<Sysname> mkdir test
[Sysname] info-center diagnostic-logfile directory flash:/test
Use info-center diagnostic-logfile enable to enable saving diagnostic logs to the diagnostic log file.
Use undo info-center diagnostic-logfile enable to disable saving diagnostic logs to the diagnostic log file.
Saving diagnostic logs to the diagnostic log file is enabled.
This command enables saving diagnostic logs to the diagnostic log file for centralized management. Users can view the diagnostic logs to monitor device activities and to troubleshoot problems.
# Enable saving diagnostic logs to the diagnostic log file.
[Sysname] info-center diagnostic-logfile enable
Use info-center diagnostic-logfile frequency to configure the interval at which the system saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
Use undo info-center diagnostic-logfile frequency to restore the default.
The diagnostic log file saving interval is 86400 seconds.
freq-sec: Specifies the diagnostic log file saving interval in seconds. The value range is 10 to 86400.
The system outputs diagnostic logs to the diagnostic log file buffer, and then saves the buffered logs to the diagnostic log file at the specified interval.
# Set the diagnostic log file saving interval to 600 seconds.
[Sysname] info-center diagnostic-logfile frequency 600
Use info-center diagnostic-logfile quota to set the maximum size for the diagnostic log file.
Use undo info-center diagnostic-logfile quota to restore the default.
The maximum size for the diagnostic log file is 10 MB.
size: Specifies the maximum size for the diagnostic log file, in MB. The value range is 1 to 10.
# Set the maximum size to 6 MB for the diagnostic log file.
[Sysname] info-center diagnostic-logfile quota 6
info-center enable
Use info-center enable to enable the information center.
Use undo info-center enable to disable the information center.
info-center enable
The information center is enabled.
# Enable the information center.
[Sysname] info-center enable
info-center format
Use info-center format to set the format for logs sent to log hosts.
Use undo info-center format to restore the default.
info-center format { cmcc | unicom }
Logs are sent to log hosts in standard format.
cmcc: Specifies the China Mobile Communications Corporation (cmcc) format.
unicom: Specifies the China Unicom (unicom) format.
Logs can be sent to log hosts in standard, unicom, or cmcc format. For more information about log formats, see Network Management and Monitoring Configuration Guide.
# Set the log format to unicom for logs sent to log hosts.
[Sysname] info-center format unicom
Use info-center logbuffer to enable log output to the log buffer.
Use undo info-center logbuffer to disable log output to the log buffer.
Log output to the log buffer is enabled.
# Enable log output to the log buffer.
[Sysname] info-center logbuffer
display logbuffer
info-center enable
Use info-center logbuffer size to set the maximum number of logs that can be stored in the log buffer.
Use undo info-center logbuffer size to restore the default.
The log buffer can store a maximum of 512 logs.
buffersize: Specifies the maximum number of logs that can be stored in the log buffer. The value range is 0 to 1024, and the default is 512.
# Set the maximum log buffer size to 50.
[Sysname] info-center logbuffer size 50
# Restore the default maximum log buffer size.
[Sysname] undo info-center logbuffer size
display logbuffer
info-center enable
info-center logfile directory
Use info-center logfile directory to specify the directory to save the log file.
The log file directory is flash:/logfile.
The specified log file directory must have been created.
The log file uses the .log extension.
# Set the log file directory to flash:/test.
[Sysname] info-center logfile directory flash:/test
info-center logfile enable
Use info-center logfile enable to enable the log file feature.
Use undo info-center logfile enable to disable the log file feature.
The log file feature is enabled.
# Enable log output to the log file.
[Sysname] info-center logfile enable
info-center logfile frequency
Use info-center logfile frequency to configure the interval at which the system saves logs from the log file buffer to the log file.
Use undo info-center logfile frequency to restore the default.
The log file saving interval is 86400 seconds.
freq-sec: Specifies the log file saving interval in seconds. The value range is 1 to 86400.
This command enables the system to automatically save logs in the log file buffer to the log file at the specified interval.
# Set the log file saving interval to 60000 seconds.
[Sysname] info-center logfile frequency 60000
Use info-center logfile overwrite-protection to enable log file overwrite-protection.
Use undo info-center logfile overwrite-protection to disable log file overwrite-protection.
info-center logfile overwrite-protection [ all-port-powerdown ]
Log file overwrite-protection is disabled.
all-port-powerdown: Shuts down all the service ports on the device when no log file space or storage device space is available. If you do not specify this keyword, the device does not shut down service ports when no log file space or storage device space is available.
This command is available only in FIPS mode.
Log file overwrite protection enables the system to stop saving new logs when no log file space or storage device space is available.
# Enable log file overwrite-protection.
[Sysname] info-center logfile overwrite-protection
Use info-center logfile size-quota to set the maximum size for the log file.
Use undo info-center logfile size-quota to restore the default.
The maximum size for the log file is 10 MB.
size: Specifies the maximum size for the log file, in MB. The value range is 1 to 10.
# Set the maximum size to 6 MB for the log file.
[Sysname] info-center logfile size-quota 6
Use info-center logging suppress duplicates to enable duplicate log suppression.
Use undo info-center logging suppress duplicate to disable duplicate log suppression.
undo info-center logging suppress duplicates
Duplicate log suppression is disabled.
Outputting consecutive duplicate logs at an interval of less than 30 seconds wastes system and network resources.
With this feature enabled, the system starts a suppression period when outputting a new log:
· During the suppression period, the system does not output logs with the same module name, level, mnemonic, location, and text as the previous log.
· After the suppression period expires, if the same log continues to appear, the system outputs the suppressed logs and the log number and starts another suppression period. The suppression period is 30 seconds the first time, 2 minutes the second time, and 10 minutes for subsequent times.
· If a different log is generated during the suppression period, the system aborts the current suppression period, outputs suppressed logs and the log number and then outputs the new log, starting another suppression period.
Suppose the IP address of VLAN-interface 100 on device A conflicts with the IP address of another device on the network, device A will output the following log information repeatedly:
%Jan 1 07:27:48:636 2000 Sysname ARP/6/DUPIFIP:
Duplicate address 172.16.0.1 on interface Vlan-interface100, sourced from 00e0-0058-123d
# Enable duplicate log suppression on device A.
[Sysname] info-center logging suppress duplicates
Device A continues to output the following log information:
%Jan 1 07:28:19:639 2000 Sysname ARP/6/DUPIFIP:
This message repeated 4 times in last 30 seconds.
The output shows that after the duplicate log suppression feature is enabled, the system outputs another duplicate log and starts the first suppression period for 30 seconds.
%Jan 1 07:30:19:643 2000 Sysname ARP/6/DUPIFIP:
This message repeated 20 times in last 2 minutes.
The output shows that the second suppression period lasts for 2 minutes.
%Jan 1 07:30:20:541 2000 Sysname ARP/6/DUPIFIP:
This message repeated 1 times in last 1 second.
%Jan 1 07:30:19:542 2000 Sysname CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=[12]-CommandSource=[2]-ConfigSource=[4]-ConfigDestination=[2]; Configuration is changed.
The output shows that a different log is generated during the suppression period.
%Jan 1 07:30:24:643 2000 Sysname ARP/6/DUPIFIP:
%Jan 1 07:30:55:645 2000 Sysname ARP/6/DUPIFIP:
The output shows that the system starts another suppression period.
Use info-center logging suppress module to configure a log suppression rule for a module.
Use undo info-center logging suppress module to delete a log suppression rule.
undo info-center logging suppress module module-name mnemonic { all | mnemonic-value }
The device does not suppress output of any logs from any modules.
module-name: Specifies a log source module by its name, a case-insensitive string of 1 to 8 characters. To view the list of available log source modules, use the info-center logging suppress module ? command.
mnemonic { all | mnemonic-value }: Configures a mnemonic filter for log suppression.
· all: Suppresses output of all logs of the module.
· mnemonic-value: Suppresses output of logs with the specified mnemonic value. The mnemonic-value argument is a case-insensitive string of 1 to 32 characters, which must be the complete value contained in the mnemonic field of the log message. Log suppression will fail if a partial mnemonic value is specified.
You can configure log suppression rules to filter out the logs that you are not concerned with. A log suppression rule suppresses output of all logs or only logs with a specific mnemonic value for a module.
# Configure a log suppression rule to suppress output of logs with the shell_login mnemonic value for the shell module.
[Sysname] info-center logging suppress module shell mnemonic shell_login
info-center source
info-center loghost
Use info-center loghost to specify a log host and to configure output parameters.
Use undo info-center loghost to remove a log host.
info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ facility local-number ]
undo info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address }
No log hosts are specified.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
hostname: Specifies a log host by its name, a case-insensitive string of 1 to 253 characters. The host name can contain letters, digits, and special characters including hyphen (-), underscore (_), and dot (.).
ipv4-address: Specifies a log host by its IPv4 address.
ipv6 ipv6-address: Specifies a log host by its IPv6 address.
port port-number: Specifies the port number of the log host, in the range of 1 to 65535. The default is 514. It must be the same as the value configured on the log host. Otherwise, logs cannot be sent to the log host.
facility local-number: Specifies a logging facility from local0 to local7 for the log host. The default value is local7. Logging facilities are used to mark different logging sources, and query and filer logs.
The info-center loghost command takes effect only after the information center is enabled by using info-center enable command.
The device supports a maximum of 20 log hosts.
# Output logs to the log host at 1.1.1.1.
[Sysname] info-center loghost 1.1.1.1
info-center loghost source
Use info-center loghost source to specify a source IP address for logs sent to log hosts.
Use undo info-center loghost source to restore the default.
The source IP address of logs sent to log hosts is the primary IP address of the outgoing interface.
The system uses the primary IP address of the specified interface as the source IP address of the logs sent to log hosts.
The info-center loghost source command takes effect only after the information center is enabled by using info-center enable command.
# Use the IP address of interface Loopback 0 as the source IP address of the logs sent to log hosts.
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 2.2.2.2 32
[Sysname-LoopBack0] quit
[Sysname] info-center loghost source loopback 0
Use info-center security-logfile alarm-threshold to set the alarm threshold for security log file usage.
Use undo info-center security-logfile alarm-threshold to restore the default.
The alarm threshold for security log file usage is 80. When the usage of the security log file reaches 80%, the system outputs a message to inform the administrator.
usage: Specifies an alarm threshold. The value must be an integer in the range of 1 to 100.
When the security log file is full, the system deletes the oldest logs and then writes new logs to the security log file. This feature helps avoid security log loss by setting an alarm threshold for the security log file usage. When the threshold is reached, the system outputs log information to inform the administrator. The administrator can log in to the device with the security-audit user role and back up the security log file.
# Set the alarm threshold for security log file usage to 90.
[Sysname] info-center security-logfile alarm-threshold 90
Use info-center security-logfile directory to specify the security log file directory.
The security log file is saved in the flash:/seclog directory.
security-audit
# Set the security log file directory to flash:/test.
[Sysname] info-center security-logfile directory flash:/test
Use info-center security-logfile enable to enable saving of security logs to the security log file.
Use undo info-center security-logfile enable to restore the default.
The saving of security logs to the security log file is disabled.
This feature enables the system to output security logs to the security log file buffer, and then saves the buffered logs to the security log file regularly.
# Enable saving security logs to the security log file.
[Sysname] info-center security-logfile enable
Use info-center security-logfile frequency to configure the interval for saving security logs to the security log file.
Use undo info-center security-logfile frequency to restore the default.
The security log file saving interval is 86400 seconds.
freq-sec: Specifies the security log file saving interval in seconds. The value range is 10 to 86400 seconds.
The system outputs security logs to the security log file buffer, and then saves the buffered logs to the security log file at the specified interval.
# Set the security log file saving interval to 600 seconds.
[Sysname] info-center security-logfile frequency 600
Use info-center security-logfile size-quota to set the maximum size for the security log file.
Use undo info-center security-logfile size-quota to restore the default.
The maximum size for the security log file is 10 MB.
size: Sets the maximum size for the security log file, in MB. The value range is 1 to 10.
# Set the maximum size to 6 MB for the security log file.
[Sysname] info-center security-logfile size-quota 6
info-center source
Use info-center source to configure a log output rule for a module.
Use undo info-center source to restore the default.
info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor } { deny | level severity }
undo info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor }
Table 7 lists the default log output rules.
Destination |
Source modules |
Common log |
Security log |
Diagnostic log |
Hidden log |
Console |
All supported modules |
debugging |
Disabled |
Disabled |
Disabled |
Monitor terminal |
debugging |
Disabled |
Disabled |
Disabled |
Log host |
informational |
Disabled |
Disabled |
informational |
Log buffer |
informational |
Disabled |
Disabled |
informational |
Log file |
informational |
Disabled |
Disabled |
informational |
Security log file |
All supported modules, cannot be filtered |
Disabled |
Debugging, which cannot be filtered |
Disabled |
Disabled |
Disabled |
Disabled |
Disabled |
module-name: Specifies a module by its name. You can use the info-center source ? command to view the modules supported by the device.
default: Specifies all supported modules.
console: Outputs logs to the console.
logbuffer: Outputs logs to the log buffer.
logfile: Outputs logs to the log file.
loghost: Outputs logs to the log host.
monitor: Outputs logs to the monitor terminal.
deny: Disables log output.
level severity: Specifies a severity level in the range of 0 to 7. The smaller the severity value, the higher the severity level. See Table 2 for more information. Logs at the specified severity level and higher levels are allowed or denied to be output.
If you do not set an output rule for a module, the module uses the output rule set by using the default keyword. If no rule is set by using the default keyword, the module uses the default output rule.
To modify or remove an output rule set for a module, you must use the module-name argument. A new output rule configured by using the default keyword does not take effect on the module.
If you execute this command for a module multiple times, the most recent configuration takes effect.
If you execute this command for the default modules multiple times, the most recent configuration takes effect.
# Output only VLAN module's information with the emergency level to the console.
[Sysname] info-center source default console deny
[Sysname] info-center source vlan console level emergency
# Based on the previous configuration, disable output of VLAN module's information to the console so no system information is output to the console.
[Sysname] undo info-center source vlan console
info-center synchronous
Use info-center synchronous to enable synchronous information output.
Use undo info-center synchronous to disable synchronous information output.
Synchronous information output is disabled.
System log output interrupts ongoing configuration operations, including obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
# Enable synchronous information output, and then execute the display current-configuration command to view the current configuration of the device.
[Sysname] info-center synchronous
Info-center synchronous output is on
[Sysname] display current-
At this time, the system receives log information. It displays the log information first, and then displays your previous input, which is display current- in this example.
%May 21 14:33:19:425 2007 Sysname SHELL/4/LOGIN: VTY login from 192.168.1.44
Enter configuration to complete the display current-configuration command, and press the Enter key to execute the command.
# Enable synchronous information output, and then save the current configuration (enter interactive information).
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
At this time, the system receives the log information. It displays the log information first and then displays [Y/N].
[Y/N]:
Enter Y or N to complete your input.
info-center syslog min-age
Use info-center syslog min-age to set the minimum storage period for logs in the log buffer and log file.
Use undo info-center syslog min-age to restore the default.
info-center syslog min-age min-age
The log minimum storage period is not set.
min-age: Sets the minimum storage period in hours. The value range is 1 to 8760.
# Set the log minimum storage period to 168 hours.
[Sysname] info-center syslog min-age 168
Use info-center syslog trap buffersize to set the maximum number of log traps that can be stored in the log trap buffer.
Use undo info-center syslog trap buffersize to restore the default.
The log trap buffer can store a maximum of 1024 traps.
buffersize: Specifies the maximum number of log traps that can be stored in the log trap buffer. The value range is 0 to 65535. Value 0 indicates that the device does not buffer log traps.
Log traps are SNMP notifications stored in the log trap buffer. After the snmp-agent trap enable syslog command is configured, the device sends log messages in SNMP notifications to the log trap buffer. You can view the log traps by accessing the MIB corresponding to the trap buffer.
The default buffer size is usually used. You can adjust the buffer size according to your network condition. New traps overwrite the oldest traps when the log trap buffer is full.
# Set the log trap buffer size to 2048.
[Sysname] info-center syslog trap buffersize 2048
info-center timestamp
Use info-center timestamp to set the timestamp format for logs sent to the console, monitor terminal, log buffer, and log file.
Use undo info-center timestamp to restore the default.
The timestamp format for logs sent to the console, monitor terminal, log buffer, and log file is date.
boot: Sets the timestamp format to xxx.yyy, where xxx is the most significant 32 bits (in milliseconds) and yyy is the least significant 32 bits. For example, 0.21990989 equals Jun 25 14:09:26:881 2007. The boot time shows the time since system startup.
date: Sets the timestamp format to MMM DD hh:mm:ss:xxx YYYY, such as Dec 8 10:12:21:708 2007. The date time shows the current system time.
· MMM: Abbreviations of the months in English, which could be Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, or Dec.
· DD: Date, starting with a space if it is less than 10, for example " 7".
· hh:mm:ss:xxx: Local time, with hh in the range of 00 to 23, mm and ss in the range of 00 to 59, and xxx in the range of 0 to 999.
· YYYY: Year.
none: Indicates no time information is provided.
# Set the timestamp format to boot for logs sent to the console, monitor terminal, log buffer, and log file.
[Sysname] info-center timestamp boot
info-center timestamp loghost
Use info-center timestamp loghost to set the timestamp format for logs sent to log hosts.
Use undo info-center timestamp loghost to restore the default.
info-center timestamp loghost { date | iso [ with-timezone ] | no-year-date | none }
The timestamp format for logs sent to log hosts is date.
date: Sets the timestamp format to mmm dd hh:mm:ss yyyy, such as Dec 8 10:12:21 2007. The date time shows the current system time.
iso: Sets the ISO 8601 timestamp format, for example, 2009-09-21T15:32:55.
with-timezone: Includes the time zone information in the ISO format timestamp. For example, 2009-09-21T15:32:55+01:00. By default, the ISO format timestamp does not contain the time zone information.
no-year-date: Sets the timestamp format to the current system date and time without year.
none: Indicates that no timestamp information is provided.
# Set the timestamp format to no-year-date for logs sent to log hosts.
[Sysname] info-center timestamp loghost no-year-date
info-center trace-logfile quota
Use info-center trace-logfile quota to set the maximum size for the trace log file.
Use undo info-center trace-logfile quota to restore the default.
The maximum size for the trace log file is 1 MB.
size: Sets the maximum size for the trace log file, in MB. The value range is 1 to 10.
# Set the maximum size to 6 MB for the trace log file.
[Sysname] info-center trace-logfile quota 6
logfile save
Use logfile save to manually save logs in the log file buffer to the log file.
logfile save
You can specify the directory to save the log file by using the info-center logfile directory command.
The system clears the log file buffer after saving the buffered logs to the log file automatically or manually.
If the log file buffer is empty, this command displays a success message event though no logs are saved to the log file.
# Manually save logs from the log file buffer to a log file.
<Sysname> logfile save
The contents in the log file buffer have been saved to the file flash:/logfile/logfile.log.
reset logbuffer
Use reset logbuffer to clear the log buffer.
reset logbuffer
# Clear the log buffer.
<Sysname> reset logbuffer
display logbuffer
security-logfile save
Use security-logfile save to manually save security logs from the security log file buffer to the security log file.
security-audit
The system clears the security log file buffer after saving the buffered security logs to the security log file automatically or manually.
If the security log file buffer is empty, this command displays a success message event though no security logs are saved to the security log file.
# Manually save the security logs in the security log file buffer to the security log file.
<Sysname> security-logfile save
The contents in the security log file buffer have been saved to the file flash:/seclog/seclog.log.
Use snmp-agent trap enable syslog to enable SNMP notifications for log messages.
Use undo snmp-agent trap enable syslog to disable SNMP notifications for log messages.
The device does not send SNMP notifications for log messages.
This command enables the device to send an SNMP notification for each log message it outputs. The device encapsulates logs in SNMP notifications and then sends them to the SNMP module and the log trap buffer.
For the SNMP module to send the received SNMP notifications correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To view the traps in the log trap buffer, access the MIB corresponding to the log trap buffer. The log trap buffer size can be set by using the info-center syslog trap buffersize command.
# Enable the device to send SNMP notifications for log messages.
[Sysname] snmp-agent trap enable syslog
terminal debugging
Use terminal debugging to enable display of debug information on the current terminal.
Use undo terminal debugging to disable display of debug information on the current terminal.
terminal debugging
Display of debug information is disabled on the current terminal.
To enable display of debug information on the console, perform the following tasks:
1. Execute the terminal debugging command.
2. Enable the information center. The information center is enabled by default.
3. Use a debugging command to enable the related debugging.
To enable display of debug information on the current terminal, perform the following tasks:
4. Execute the terminal monitor and terminal debugging commands.
5. Enable the information center. The information center is enabled by default.
6. Use a debugging command to enable the related debugging.
This command takes effect only for the current connection between the terminal and the device. If a new connection is established, the default is restored.
You can also enable display of debug information on the current terminal by executing the terminal logging level 7 command. This command has the following differences from the terminal debugging command:
· The terminal logging level 7 command enables log display for all levels (levels 0 through 7) on the current terminal.
· The terminal debugging command only enables display of logs with the following severity levels:
¡ Debug level (level 7).
¡ Severity level higher than or equal to the level specified in the terminal logging level command.
# Enable display of debug information on the current terminal.
<Sysname> terminal debugging
The current terminal is enabled to display debugging information.
terminal monitor
Use terminal logging level to set the lowest level of logs that can be output to the current terminal.
Use undo terminal logging level to restore the default.
The lowest level of logs that can be output to the current terminal is 6 (Informational).
severity: Specifies a log severity level. Valid values are alert, critical, debugging, emergency, error, informational, notification, warning, and digits from 0 to 7.
This command enables the device to output logs with a severity level higher than or equal to the specified level to the current terminal. For example, if you set the severity argument to 6, logs with a severity value from 0 to 6 are output to the current terminal.
# Configure the device to output logs with the debugging level and higher levels to the current terminal.
<Sysname> terminal logging level 7
terminal monitor
Use terminal monitor to enable monitoring of logs on the current terminal.
Use undo terminal monitor to disable monitoring of logs on the current terminal.
terminal monitor
Monitoring of logs is enabled on the console and disabled on the monitor terminal.
# Enable monitoring of logs on the current terminal.
<Sysname> terminal monitor
