12-Security Configuration Guide
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-X Routers Configuration Guides-Release7951PXX-6W10012-Security Configuration Guide
17-Crypto engine configuration
17-Crypto engine configuration 39.24 KB
Configuring crypto engines
About crypto engines
Crypto engines encrypt and decrypt data for service modules.
Crypto engine types
Crypto engines include the following types:
·          Hardware crypto engines—A hardware crypto engine is a coprocessor integrated on a CPU or hardware crypto card. Hardware crypto engines can accelerate encryption/decryption speed, which improves device processing efficiency. You can enable or disable hardware crypto engines globally as needed. By default, hardware crypto engines are enabled.
·          Software crypto engines—A software crypto engine is a set of software encryption algorithms. The device uses software crypto engines to encrypt and decrypt data for service modules. They are always enabled. You cannot enable or disable software crypto engines.
Crypto engine processing mechanism
If you disable hardware crypto engines, the device uses only software crypto engines for data encryption/decryption. If you enable hardware crypto engines, the device preferentially uses hardware crypto engines. If the device does not support hardware crypto engines, or if the hardware crypto engines do not support the required encryption algorithm, the device uses software crypto engines for data encryption/decryption.
Crypto engines provide encryption/decryption services for service modules, for example, the IPsec module. When a service module requires data encryption/decryption, it sends the desired data to a crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Restrictions: Hardware compatibility with hardware crypto engines
Hardware crypto engines are supported only on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, SPEX, CSPEX, and CEPC cards.
Display and maintenance commands for crypto engines
Display crypto engine information.
display crypto-engine
(In standalone mode.) Display crypto engine statistics.
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
(In IRF mode.) Display crypto engine statistics.
display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
(In standalone mode.) Clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
(In IRF mode.) Clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
