12-Security Configuration Guide
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-X Routers Configuration Guides-Release7951PXX-6W10012-Security Configuration Guide
16-uRPF configuration
16-uRPF configuration 221.54 KB
Configuring uRPF
About uRPF
Unicast Reverse Path Forwarding (uRPF) protects a network against source address spoofing attacks, such as DoS and DDoS attacks.
uRPF application scenario
Attackers send packets with a forged source address to access a system that uses IPv4-based authentication, in the name of authorized users or even the administrator. Even if the attackers or other hosts cannot receive any response packets, the attacks are still disruptive to the attacked target.
Figure 1 Source address spoofing attack
As shown in Figure 1, an attacker on Router A sends the server (Router B) requests with a forged source IP address 2.2.2.1 at a high rate. Router B sends response packets to IP address 2.2.2.1 (Router C). Consequently, both Router B and Router C are attacked. If the administrator disconnects Router C by mistake, the network service is interrupted.
Attackers can also send packets with different forged source addresses or attack multiple servers simultaneously to block connections or even break down the network.
uRPF can prevent these source address spoofing attacks. It checks whether an interface that receives a packet is the output interface of the FIB entry that matches the source address of the packet. If not, uRPF considers it a spoofing attack and discards the packet.
uRPF check modes
uRPF supports strict and loose modes.
Strict uRPF check
To pass strict uRPF check, the source address of a packet and the receiving interface must match the destination address and output interface of a FIB entry. In some scenarios (for example, asymmetrical routing), strict uRPF might discard valid packets.
Strict uRPF is often deployed between a PE and a CE.
Loose uRPF check
To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry. Loose uRPF can avoid discarding valid packets, but might let go attack packets.
Loose uRPF is often deployed between ISPs, especially in asymmetrical routing.
uRPF extended functions
Using the default route in uRPF check
When a default route exists, all packets that fail to match a specific FIB entry match the default route during uRPF check and thus are permitted to pass. To avoid this situation, you can disable uRPF from using any default route to discard such packets. If you allow using the default route (set by using allow-default-route), uRPF permits packets that only match the default route.
By default, uRPF discards packets that can only match a default route. Typically, you do not need to configure the allow-default-route keyword on a PE device because it has no default route pointing to the CE. If you enable uRPF on a CE interface and the CE interface has a default route pointing to the PE, specify the allow-default-route keyword.
Using an ACL for uRPF check exemption
To identify specific packets as valid packets, you can use an ACL to match these packets. Even if the packets do not pass uRPF check, they are still forwarded.
uRPF operation
Figure 2 shows how uRPF works.
Figure 2 uRPF work flow
1.        uRPF checks address validity:
¡  uRPF permits a packet with a multicast destination address.
¡  For a packet with an all-zero source address, uRPF permits the packet if it has a broadcast destination address. (A packet with source address 0.0.0.0 and destination address 255.255.255.255 might be a DHCP or BOOTP packet and cannot be discarded.) uRPF proceeds to step 7 if the packet has a non-broadcast destination address.
¡  uRPF proceeds to step 2 for other packets.
2.        uRPF checks whether the source address matches a unicast route:
¡  If yes, uRPF proceeds to step 3.
¡  If no, uRPF proceeds to step 7. A non-unicast source address matches a non-unicast route.
3.        uRPF checks whether the matching route is to the host itself:
¡  If yes, the output interface of the matching route is an InLoop interface. uRPF checks whether the receiving interface of the packet is an InLoop interface. If yes, it does not check the packet. If no, it proceeds to step 7.
¡  If no, uRPF proceeds to step 4.
4.        uRPF checks whether the matching route is a default route:
¡  If yes, uRPF checks whether the allow-default-route keyword is configured to allow using the default route. If yes, it proceeds to step 5. If no, it proceeds to step 7.
¡  If no, uRPF proceeds to step 5.
5.        uRPF checks whether the receiving interface matches the output interface of the matching FIB entry:
¡  If yes, uRPF proceeds to step 6.
¡  If no, uRPF checks whether the check mode is loose. If yes, it proceeds to step 7. If no, it proceeds to step 6.
6.        uRPF checks whether the packet is permitted by the ACL:
¡  If yes, the packet is forwarded (such a packet is displayed in the uRPF information as a "suppressed drop").
¡  If no, the packet is discarded.
Network application
As shown in Figure 3, strict uRPF check is configured between an ISP network and a customer network. Loose uRPF check is configured between ISPs.
For special packets or users, you can configure ACLs.
Figure 3 Network diagram
Restrictions and guidelines: uRPF configuration
If you enable uRPF on an interface, you can use the display ip interface command to display statistics about packets discarded by uRPF (displayed as "Drops" and "Suppressed drops").
Do not configure the allow-default-route keyword for loose uRPF check. Otherwise, uRPF might fail to work.
Enabling uRPF on an interface
1.        Enter system view.
2.        Enter interface view.
3.        Enable uRPF.
¡  For interfaces on the CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E cards, SPEX cards, CSPEX cards, and CEPC cards:
ip urpf { loose [ allow-default-route ] [ acl acl-number ] | strict [ allow-default-route ] [ acl acl-number ] }
¡  For interfaces on the SPC cards and MPE-1104 cards:
ip urpf loose [ allow-default-route ]
By default, uRPF is disabled.
Enabling strict uRPF on a VT interface
About enabling strict uRPF on a VT interface
uRPF enabled on a VT interface checks traffic of PPPoE users for packet validity on the interface.
If you do not specify the subnet-check keyword, strict uRPF checks traffic of all PPPoE users except leased users for packet validity based on source IP address.
If you specify the subnet-check keyword, strict uRPF checks traffic of all PPPoE users including leased users for packet validity. The packet validity check is based on the Framed-Route or Framed-IP-Netmask RADIUS attribute.
Hardware and feature compatibility
This feature is supported only on the CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E cards, SPEX cards, CSPEX cards, and CEPC cards.
2.        Enter VT interface view.
interface virtual-template number
3.        Enable strict uRPF.
ip urpf strict [ subnet-check ]
By default, strict uRPF check is enabled for all PPPoE users except leased users.
The subnet-check keyword is supported only on the CSPEX cards (except CSPEX-1104-E) and CEPC cards.
Display and maintenance commands for uRPF
(In standalone mode.) Display uRPF configuration.
display ip urpf interface interface-type interface-number [ slot slot-number ]
(In IRF mode.) Display uRPF configuration.
display ip urpf interface interface-type interface-number [ chassis chassis-number slot slot-number ]
uRPF configuration examples
Example: Configuring uRPF for interfaces
As shown in Figure 4, perform the following tasks:
·          Configure strict uRPF check on GigabitEthernet 3/1/1 of Router B and permit packets from network 10.1.1.0/24.
·          Configure strict uRPF check on GigabitEthernet 3/1/1 of Router A and allow using the default route for uRPF check.
Figure 4 Network diagram
1.        Configure Router B:
# Configure ACL 2010 to permit traffic from network 10.1.1.0/24.
<RouterB> system-view
[RouterB] acl basic 2010
[RouterB-acl-ipv4-basic-2010] rule permit source 10.1.1.0 0.0.0.255
[RouterB-acl-ipv4-basic-2010] quit
# Specify an IP address for GigabitEthernet 3/1/1.
[RouterB] interface gigabitethernet 3/1/1
[RouterB-GigabitEthernet3/1/1] ip address 1.1.1.2 255.255.255.0
# Configure strict uRPF check on GigabitEthernet 3/1/1.
[RouterB-GigabitEthernet3/1/1] ip urpf strict acl 2010
2.        Configure Router A:
[RouterA] interface gigabitethernet 3/1/1
[RouterA-GigabitEthernet3/1/1] ip address 1.1.1.1 255.255.255.0
# Configure strict uRPF check on GigabitEthernet 3/1/1 and allow using the default route for uRPF check.
[RouterA-GigabitEthernet3/1/1] ip urpf strict allow-default-route
Configuring IPv6 uRPF
About IPv6 uRPF
IPv6 Unicast Reverse Path Forwarding (uRPF) protects a network against source address spoofing attacks, such as DoS and DDoS attacks.
IPv6 uRPF application scenario
Attackers send packets with a forged source address to access a system that uses IPv6-based authentication, in the name of authorized users or even the administrator. Even if the attackers or other hosts cannot receive any response packets, the attacks are still disruptive to the attacked target.
Figure 5 Source address spoofing attack
As shown in Figure 5, an attacker on Router A sends the server (Router B) requests with a forged source IPv6 address 2000::1 at a high rate. Router B sends response packets to IPv6 address 2000::1 (Router C). Consequently, both Router B and Router C are attacked. If the administrator disconnects Router C by mistake, the network service is interrupted.
IPv6 uRPF can prevent these source address spoofing attacks. It checks whether an interface that receives a packet is the output interface of the FIB entry that matches the source address of the packet. If not, IPv6 uRPF considers it a spoofing attack and discards the packet.
IPv6 uRPF check modes
IPv6 uRPF supports strict and loose check modes.
Strict IPv6 uRPF check
To pass strict IPv6 uRPF check, the source address of a packet and the receiving interface must match the destination address and output interface of an IPv6 FIB entry. In some scenarios (for example, asymmetrical routing), strict IPv6 uRPF might discard valid packets.
Strict IPv6 uRPF is often deployed between a PE and a CE.
Loose IPv6 uRPF check
To pass loose IPv6 uRPF check, the source address of a packet must match the destination address of an IPv6 FIB entry. Loose IPv6 uRPF can avoid discarding valid packets, but might let go attack packets.
Loose IPv6 uRPF is often deployed between ISPs, especially in asymmetrical routing.
IPv6 uRPF extended functions
Using the default route in IPv6 uRPF check
When a default route exists, all packets that fail to match a specific IPv6 FIB entry match the default route during IPv6 uRPF check and thus are permitted to pass. If you allow using the default route (by using allow-default-route), IPv6 uRPF permits packets that only match the default route.
By default, IPv6 uRPF discards packets that can only match a default route. Typically, you do not need to configure the allow-default-route keyword on a PE device because it has no default route pointing to the CE device. If you enable uRPF on a CE interface and the CE interface has a default route pointing to the PE, specify the allow-default-route keyword.
Using an ACL for IPv6 uRPF check exemption
To identify specific packets as valid packets, you can use an IPv6 ACL to match these packets. Even if the packets do not pass IPv6 uRPF check, they are still forwarded.
IPv6 uRPF operation
Figure 6 shows how IPv6 uRPF works.
Figure 6 IPv6 uRPF work flow
1.        IPv6 uRPF checks whether the received packet carries a multicast destination address:
¡  If yes, IPv6 uRPF permits the packet.
¡  If no, IPv6 uRPF proceeds to step 2.
2.        IPv6 uRPF checks whether the source address matches a unicast route:
¡  If yes, IPv6 uRPF proceeds to step 3.
¡  If no, IPv6 uRPF proceeds to step 6. A non-unicast source address matches a non-unicast route.
3.        IPv6 uRPF checks whether the matching route is to the host itself:
¡  If yes, the output interface of the matching route is an InLoop interface. IPv6 uRPF checks whether the receiving interface of the packet is an InLoop interface. If yes, IPv6 uRPF permits the packet. If no, IPv6 uRPF proceeds to step 6. If the source address is a link-local address and is the receiving interface address, also proceeds to step 6.
¡  If no, IPv6 uRPF proceeds to step 4.
4.        IPv6 uRPF checks whether the receiving interface matches the output interface of the matching FIB entry:
¡  If yes, IPv6 uRPF proceeds to step 5.
¡  If no, IPv6 uRPF checks whether the check mode is loose. If yes, it proceeds to step 5. If no, it proceeds to step 6.
5.        IPv6 uRPF checks whether the matching route is a default route:
¡  If yes, IPv6 uRPF checks whether the allow-default-route keyword is configured to allow using the default route. If yes, the packet is forwarded. If no, IPv6 uRPF proceeds to step 6.
¡  If no, the packet is forwarded.
6.        IPv6 uRPF checks whether the packet is permitted by the IPv6 ACL:
Network application
As shown in Figure 7, strict IPv6 uRPF check is configured between an ISP network and a customer network. Loose IPv6 uRPF check is configured between ISPs.
For special packets or users, you can configure IPv6 ACLs.
Figure 7 Network diagram
Restrictions and guidelines: IPv6 uRPF configuration
If you enable IPv6 uRPF on an interface, you can use the display ipv6 interface command to view statistics about packets discarded by IPv6 uRPF (displayed as "Drops" and "Suppressed drops").
Do not configure the allow-default-route keyword for loose IPv6 uRPF check. Otherwise, IPv6 uRPF might fail to work.
Enabling IPv6 uRPF on an interface
3.        Enable IPv6 uRPF.
ipv6 urpf { loose | strict } [ allow-default-route ] [ acl acl-number ]
ipv6 urpf loose [ allow-default-route ]
By default, IPv6 uRPF is disabled.
Enabling strict IPv6 uRPF on a VT interface
About enabling strict IPv6 uRPF on a VT interface
Strict IPv6 uRPF enabled on a VT interface checks traffic of all PPPoE users including leased users for packet validity on the interface. The packet validity check is based on the Framed-Route or Framed-IP-Netmask RADIUS attribute.
This feature is supported only on the CSPEX cards (except CSPEX-1104-E) and CEPC cards.
3.        Enable strict IPv6 uRPF.
ipv6 urpf strict subnet-check
By default, strict IPv6 uRPF check is disabled for all PPPoE users.
Display and maintenance commands for IPv6 uRPF
(In standalone mode.) Display IPv6 uRPF configuration.
display ipv6 urpf interface interface-type interface-number [ slot slot-number ]
(In IRF mode.) Display IPv6 uRPF configuration.
display ipv6 urpf interface interface-type interface-number [ chassis chassis-number slot slot-number ]
IPv6 uRPF configuration examples
Example: Configuring IPv6 uRPF for interfaces
As shown in Figure 8, perform the following tasks:
·          Configure strict IPv6 uRPF check on GigabitEthernet 3/1/1 of Router B and permit packets from network 1010::/64.
·          Configure strict IPv6 uRPF check on GigabitEthernet 3/1/1 of Router A and allow using the default route for IPv6 uRPF check.
Figure 8 Network diagram
# Configure IPv6 ACL 2010 to permit traffic from network 1010::/64.
[RouterB] acl ipv6 basic 2010
[RouterB-acl-ipv6-basic-2010] rule permit source 1010:: 64
[RouterB-acl-ipv6-basic-2010] quit
# Specify an IPv6 address for GigabitEthernet 3/1/1.
[RouterB-GigabitEthernet3/1/1] ipv6 address 1000::2/64
[RouterB-GigabitEthernet3/1/1] ipv6 urpf strict acl 2010
[RouterA-GigabitEthernet3/1/1] ipv6 address 1000::1/64
# Configure strict uRPF check on GigabitEthernet 3/1/1 and allow using the default route for IPv6 uRPF check.
[RouterA-GigabitEthernet3/1/1] ipv6 urpf strict allow-default-route
