16-BRAS Services Command Reference
HomeSupportRoutersSR8800-F SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command References-Release7951PXX-6W10016-BRAS Services Command Reference
04-ITA commands
04-ITA commands 61.97 KB
ITA commands
ITA is supported only when the device operates in standard mode. For more information about setting the system operating mode to standard, see device management in Fundamentals Configuration Guide.
ITA is supported only on CSPEX (except CSPEX-1104-E) cards.
ITA services are supported only by portal, IPoE, and PPPoE users.
accounting-level
Use accounting-level to specify a traffic level for ITA accounting.
Use undo accounting-level to remove the ITA accounting configuration for a traffic level.
accounting-level level { { ipv4 | ipv6 } | car { inbound cir committed-information-rate [ pir peak-information-rate ] | outbound cir committed-information-rate [ pir peak-information-rate ] } * } *
undo accounting-level [ level ]
No traffic levels are specified for ITA accounting.
ITA policy view
level: Specifies a traffic level in the range of 1 to 8.
ipv4: Counts the traffic as IPv4 traffic.
ipv6: Counts the traffic as IPv6 traffic.
car: Specifies a CAR action for the level of traffic. If you do not specify this keyword, no CAR action is applied to the level of traffic.
inbound: Specifies the incoming traffic.
outbound: Specifies the outgoing traffic.
cir committed-information-rate: Specifies the committed information rate in kbps. The value range for the committed-information-rate argument is 8 to 160000000.
pir peak-information-rate: Specifies the peak information rate in kbps. The value range for the peak-information-rate argument is 8 to 160000000. The peak information rate cannot be smaller than the committed information rate. If you do not specify this option, the CAR action does not restrict traffic by peak information rate.
By defining different traffic levels based on the destination addresses of users' traffic, you can use ITA to separate the traffic accounting statistics of different levels for each user.
Execute this command multiple times to specify multiple traffic levels for ITA accounting or specify CAR actions for each traffic level. If you specify only CAR actions for a traffic level without specifying the ipv4 or ipv6 keyword, the device does not perform ITA accounting on the traffic of that level.
If you do not specify a level for the undo accounting-level command, this command removes the ITA accounting configuration for all traffic levels in the ITA policy.
If the IP protocol type specified for a traffic level is not the actual IP protocol type, the device counts the traffic of this level as the traffic of the specified IP protocol.
If you do not specify the ipv4 or ipv6 keyword, the device does not perform accounting on ITA traffic.
Supported traffic levels for ITA accounting vary by access types of users, as shown in Table 1.
Table 1 ITA traffic accounting levels for different user types
User type
Number of ITA traffic accounting levels
CSPEX-1204 card
CSPEX cards (except the CSPEX-1204 and CSPEX-1104-E cards)
Portal users that access the network through VLAN interfaces
7 (level-1 to level 8)
Portal users that access the network through the following types of interfaces:
·         Layer 3 Ethernet interface.
·         Layer 3 Ethernet subinterface.
·         Layer 3 aggregate interface.
·         Layer 3 aggregate subinterface.
1 (level-1)
4 (level 1 to level 4)
IPoE users
1 (level-1)
PPPoE users
1 (level-1)
# In ITA policy ita1, specify traffic levels 2 and 4, and count the level-2 traffic as IPv4 traffic and the level-4 traffic as IPv6 traffic.
[Sysname] ita policy ita1
[Sysname-ita-policy-ita1] accounting-level 2 ipv4
[Sysname-ita-policy-ita1] accounting-level 4 ipv6
display ita policy
accounting-merge enable
Use accounting-merge enable to enable the accounting merge feature.
Use undo accounting-merge enable to disable the accounting merge feature.
The accounting merge feature is disabled.
ITA policy view
When accounting merge is enabled, the device merges accounting statistics for the ITA traffic of all levels in the ITA policy. It reports the traffic as the lowest level of the policy to the accounting server.
# Enable the accounting merge feature for ITA policy ita1.
[Sysname-ita-policy-ita1] accounting-merge enable
display ita policy
accounting-method
Use accounting-method to configure the accounting method for an ITA policy.
Use undo accounting-method to restore the default.
accounting-method { none | radius-scheme radius-scheme-name [ none ] }
The default accounting method of an ITA policy is none.
ITA policy view
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
Use this command to configure accounting methods for an ITA policy. ITA accounting is separated from accounting of other services.
You can specify one primary accounting method and one backup accounting method for an ITA policy.
When the primary method is invalid, the device uses the backup method. For example, the accounting-method radius-scheme radius-scheme-name none command specifies RADIUS accounting as the primary method and no accounting as the backup method. The device performs RADIUS accounting by default and does not perform accounting when the RADIUS server is invalid.
# Specify RADIUS accounting scheme radius1 for ITA policy ita1.
[Sysname-ita-policy-ita1] accounting-method radius-scheme radius1
display ita policy
radius scheme
display ita policy
Use display ita policy to display ITA policy information.
display ita policy [ policy-name ]
policy-name: Specifies an ITA policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify an ITA policy, this command displays information about all ITA policies.
# Display information about all ITA policies.
<Sysname> display ita policy
Total 2 ITA policies.
ITA policy: ita1
  Accounting method       : RADIUS=Rd1, None
  Accounting merge        : Enabled
  Accounting levels       :
    Level 1    IPv4
      Inbound  CAR: CIR 100 kbps    PIR 200 kbps
      Outbound CAR: CIR 100 kbps    PIR 200 kbps
    Level 2    IPv6
      Inbound  CAR: CIR 300 kbps    PIR 400 kbps
    Level 3    IPv4
    Level 8    IPv6
  Traffic separation      : Enabled
    Separated levels: 1, 2, 3, 4
  Traffic quota-out action: Online
    Send accounting update: No
ITA policy: ita2
  Accounting method       : None
  Accounting merge        : Disabled
  Accounting levels       : None
  Traffic separation      : Disabled
    Send accounting update: Yes
  User group     NAT instance
    g1           cp1
    g2           cp2
    g3           -
ITA policy
ITA policy name.
Accounting merge
Status of the accounting merge feature:
·         Enabled—The accounting merge feature is enabled. The device merges the ITA traffic of all accounting rates in the ITA policy, and applies the lowest rate to the merged traffic.
·         Disabled—The accounting merge feature is disabled. The device sends separate traffic statistics for each accounting rate to the server.
Accounting levels
ITA traffic accounting levels:
·         Level m IPv4—Applies accounting level m to IPv4 traffic. The value range for the m argument is 1 to 8.
·         Level n IPv6—Applies accounting level n to IPv6 traffic. The value range for the n argument is 1 to 8.
·         None—No ITA traffic accounting level is configured.
Inbound CAR
Inbound CAR:
·         CIR—Committed information rate in kbps.
·         PIR—Peak information rate in kbps.
Outbound CAR
Outbound CAR:
Traffic separation
Whether the amount of ITA traffic is excluded from the overall traffic statistics sent to the accounting server:
·         Enabled—The amount of specific-level ITA traffic is excluded from the overall traffic statistics.
·         Disabled—ITA traffic is included in the overall traffic statistics.
Separated levels
Levels of ITA traffic of which statistics are excluded from the overall traffic statistics sent to the accounting server.
Access control for users that have used up their ITA data quotas:
·         Online—Users can access the authorized IP subnets after their ITA data quotas are used up.
·         Offline—Users cannot access the authorized IP subnets after their ITA data quotas are used up.
Whether to send accounting-update packets to refresh users' data quotas:
·         Yes.
·         No.
User group
User group name.
NAT instance
NAT instance bound to the user group.
If no NAT instance has been bound to the user group, this field displays a hyphen (-).
ita policy
Use ita policy to create an ITA policy and enter its view, or enter the view of an existing ITA policy.
Use undo ita policy to delete an ITA policy.
ita policy policy-name
undo ita policy policy-name
No ITA policies exist.
policy-name: Specifies the ITA policy name, a case-insensitive string of 1 to 31 characters.
# Create an ITA policy named ita1 and enter ITA policy view.
display ita policy
traffic-quota-out
Use traffic-quota-out to configure access control for users that have used up their ITA data quotas.
Use undo traffic-quota-out to restore the default.
traffic-quota-out { offline | online } [ no-accounting-update ]
The device sends accounting-update packets to the server to request new data quotas for the users that have used up their data quotas. A user cannot access the authorized IP subnets if the device does not receive any new data quota from the server for the user.
ITA policy view
offline: Prohibits users from accessing the authorized IP subnets after their ITA data quotas are used up.
online: Permits users to access the authorized IP subnets after their ITA data quotas are used up.
no-accounting-update: Disables the device from sending accounting-update requests to refresh the users' quotas.
The server might divide the data quota of a user into multiple portions and assign a portion to the user each time. If the server does not support dividing user data quota, specify the no-accounting-update keyword to decrease the burden of the server as a best practice.
# In ITA policy ita1, prohibit users from accessing the authorized IP subnets after their ITA data quotas are used up.
[Sysname-ita-policy-ita1] traffic-quota-out offline
display ita policy
traffic-separate
Use traffic-separate enable to exclude the amount of specific-level ITA traffic from the overall traffic statistics that are sent to the accounting server.
Use undo traffic-separate enable to restore the default for an ITA traffic level.
traffic-separate enable [ level level&<1-8> ]
undo traffic-separate enable [ level level&<1-8> ]
The amount of ITA traffic is included in the overall traffic statistics that are sent to the accounting server.
ITA policy view
level level&<1-8>: Specifies a space-separated list of up to eight ITA traffic levels. If you do not specify an ITA traffic level, this command excludes the amount of ITA traffic at all levels from the overall traffic statistics that are sent to the accounting server.
# In ITA policy ita1, exclude the amount of level-1 ITA traffic from the overall traffic statistics that are sent to the accounting server.
[Sysname-ita-policy-ita1] traffic-separate enable level 1
accounting-level
display ita policy
user-group
Use user-group to specify a user group for an ITA policy.
Use undo user-group to remove user group configuration from an ITA policy.
user-group name group-name [ nat-instance instance-name ]
undo user-group [ name group-name ]
No user groups are specified for an ITA policy.
ITA policy view
name group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
nat-instance instance-name: Specifies a NAT instance by its name, a case-sensitive string of 1 to 31 characters. If the NAT instance name contains spaces, you must enclose the name into double quotation marks (for example, "xxx xxx"). If you do not specify this option, the user group is not bound with a NAT instance. Address translation is not performed for ITA services in the user group.
If a user is assigned an ITA policy associated with a user group, the ITA services of that user will be assigned to the user group. Different user groups can be associated with different accounting levels and CAR actions. To dynamically change the ITA accounting levels and CAR actions for an online user, you can dynamically change the ITA policy of the user to assign the ITA services of that user to a new user group.
To match ITA traffic of different user groups and remark the traffic to different accounting levels, you can configure QoS policies. For more information about configuring QoS policies, see ACL and QoS Configuration Guide.
You can specify a maximum of 32 user groups in an ITA policy and only one user group is not bound with a NAT instance.
The device assigns the ITA services of a user to a user group and uses the NAT instance associated with that user group to process NAT services for the ITA traffic. The rules are as follows:
·          If the non-ITA service traffic of the user has been processed by a NAT instance, the ITA services of the user are assigned to the user group associated with the NAT instance. If the user group does not exist in the ITA policy, the ITA services of the user are not assigned to a new user group. The ITA services are processed in the same user group as non-ITA services.
·          If the non-ITA service traffic of the user has not been processed by a NAT instance, the ITA services of the user are assigned to the user group that is not bound with a NAT instance. If no user groups are specified for the ITA policy, the ITA services of the user are not assigned to a new user group. The ITA services are processed in the same user group as non-ITA services.
For more information about NAT and NAT instances, see NAT configuration in Layer 3—IP Services Configuration Guide.
If you do not specify the name group-name option, the undo user-group command removes all user group-to-NAT instance bindings from the ITA policy.
A user group can be bound only to one NAT instance.
Deleting or modifying a user group for an ITA policy does not affect the ITA users that have been assigned the ITA policy. The configuration takes effect only on ITA users that are assigned or re-assigned the ITA policy after the configuration.
# In ITA policy ita1, specify user group g1 and bind NAT instance cp1 to the user group.
[Sysname-ita-policy-ita1] user-group name g1 nat-instance cp1
display ita policy
user-group (system view)
