16-BRAS Services Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command References-Release7951PXX-6W10016-BRAS Services Command Reference
01-AAA commands
01-AAA commands 1022.45 KB
AAA commands· 1
General AAA commands· 1
aaa abnormal-offline-record enable· 1
aaa deny-domain· 1
aaa nas-id· 2
aaa nas-id profile· 3
aaa nas-id-profile· 4
aaa nas-ip· 5
aaa normal-offline-record enable· 6
aaa offline-record enable· 7
aaa online-fail-record enable· 7
aaa permit-domain· 8
aaa roam-domain· 9
aaa stop-accounting-packet master-replace-send· 10
aaa session-limit 11
aaa ssid· 11
accounting command· 12
accounting default 13
accounting dual-stack· 14
accounting ipoe· 15
accounting lan-access· 17
accounting login· 18
accounting portal 20
accounting ppp· 21
accounting quota-out 23
accounting start-delay· 24
accounting start-fail 25
accounting update-fail 26
authentication default 26
authentication ipoe· 28
authentication lan-access· 29
authentication login· 30
authentication portal 32
authentication ppp· 33
authentication super 34
authentication-method none authorization-attribute· 35
authorization command· 36
authorization default 37
authorization ipoe· 39
authorization lan-access· 40
authorization login· 41
authorization portal 43
authorization ppp· 44
authorization-attribute (ISP domain view) 45
basic-service-ip-type· 50
dhcpv6-follow-ipv6cp· 51
display aaa abnormal-offline-record· 52
display aaa normal-offline-record· 55
display aaa offline-record· 59
display aaa online-fail-record· 63
display domain· 67
display domain access-user statistics· 76
display max-user history· 77
domain· 79
domain default enable· 80
domain if-unknown· 81
ip-usage-warning· 81
ipv6-usage-warning· 83
ita-policy· 85
l2tp-user radius-force· 86
load-sharing user-group· 87
nas-id· 88
nas-id bind· 89
redirect active-time· 90
redirect move-temporarily enable· 91
redirect server 91
reset aaa abnormal-offline-record· 92
reset aaa normal-offline-record· 93
reset aaa offline-record· 93
reset aaa online-fail-record· 94
service rate-limit mode (ISP domain view) 94
service-type (ISP domain view) 95
session-time include-idle-time· 96
snmp-agent trap enable domain· 97
state (ISP domain view) 98
state block time-range name· 99
user-address-type· 100
user-group bind nat-instance· 101
web-server { ip | ipv6 } 102
web-server url 103
web-server url-parameter 104
Local user commands· 106
access-limit 106
authorization-attribute (local user view/user group view) 107
bind-attribute· 110
company· 111
description· 112
display local-user 112
display user-group· 116
email 118
full-name· 118
group· 119
local-guest auto-delete enable· 120
local-guest email format 120
local-guest email sender 121
local-guest email smtp-server 122
local-guest generate· 123
local-guest send-email 124
local-user 125
local-user-export 126
local-user-import 127
password (device management user view) 129
password (network access user view) 130
phone· 131
service-type (local user view) 131
sponsor-department 132
sponsor-email 133
sponsor-full-name· 134
state (local user view) 134
user-group· 135
validity-datetime· 136
RADIUS commands· 137
aaa device-id· 137
aaa nas-port-id vlanid uppercase· 137
accounting-on enable· 138
accounting-on extended· 139
attribute 5 format 140
attribute 6 value· 141
attribute 15 check-mode· 142
attribute 25 car 142
attribute 31 mac-format 143
attribute 85 preferred· 144
attribute 87 format 145
attribute convert (RADIUS DAS view) 147
attribute convert (RADIUS scheme view) 148
attribute reject (RADIUS DAS view) 149
attribute reject (RADIUS scheme view) 150
attribute remanent-volume· 151
attribute translate· 152
attribute vendor-id 2011 version· 153
client 154
dae-loose-check enable· 155
data-flow-format (RADIUS scheme view) 156
display radius scheme· 156
display radius server-load statistics· 161
display radius statistics· 162
display stop-accounting-buffer (for RADIUS) 165
exclude· 166
include· 167
key (RADIUS scheme view) 169
nas-ip (RADIUS scheme view) 170
port 171
primary accounting (RADIUS scheme view) 172
primary authentication (RADIUS scheme view) 173
radius attribute extended· 175
radius attribute-test-group· 177
radius authentication-request first 177
radius dscp· 178
radius dynamic-author server 179
radius nas-ip· 179
radius offline-reason-convert user-type ppp· 181
radius scheme· 181
radius session-control client 182
radius session-control enable· 183
radius source-ip· 184
radius-server test-profile· 185
reset radius server-load statistics· 186
reset radius statistics· 186
reset stop-accounting-buffer (for RADIUS) 187
response-pending-limit 188
retry· 189
retry realtime-accounting· 190
retry stop-accounting (RADIUS scheme view) 192
secondary accounting (RADIUS scheme view) 193
secondary authentication (RADIUS scheme view) 194
server-block-action· 196
server-load-sharing enable· 197
server-load-sharing mode· 198
snmp-agent trap enable radius· 199
source-ip· 200
state primary· 201
state secondary· 202
stop-accounting-buffer enable (RADIUS scheme view) 204
stop-accounting-packet send-force· 204
test-aaa· 205
threshold remanent-volume· 209
timer quiet (RADIUS scheme view) 210
timer realtime-accounting (RADIUS scheme view) 210
timer response-timeout (RADIUS scheme view) 212
trust ip· 213
trust ipv6· 213
user-name-format (RADIUS scheme view) 214
username-authorization apply· 215
vpn-instance (RADIUS scheme view) 216
HWTACACS commands· 217
data-flow-format (HWTACACS scheme view) 217
display hwtacacs scheme· 218
display stop-accounting-buffer (for HWTACACS) 222
hwtacacs nas-ip· 223
hwtacacs scheme· 224
key (HWTACACS scheme view) 225
nas-ip (HWTACACS scheme view) 226
primary accounting (HWTACACS scheme view) 227
primary authentication (HWTACACS scheme view) 229
primary authorization· 230
reset hwtacacs statistics· 231
reset stop-accounting-buffer (for HWTACACS) 232
retry stop-accounting (HWTACACS scheme view) 232
secondary accounting (HWTACACS scheme view) 233
secondary authentication (HWTACACS scheme view) 235
secondary authorization· 236
stop-accounting-buffer enable (HWTACACS scheme view) 238
timer quiet (HWTACACS scheme view) 238
timer realtime-accounting (HWTACACS scheme view) 239
timer response-timeout (HWTACACS scheme view) 240
user-name-format (HWTACACS scheme view) 241
vpn-instance (HWTACACS scheme view) 242
LDAP commands· 242
attribute-map· 242
authentication-server 243
authorization-server 244
display ldap scheme· 245
ip· 246
ipv6· 247
ldap attribute-map· 248
ldap scheme· 249
ldap server 249
login-dn· 250
login-password· 251
map· 251
protocol-version· 253
search-base-dn· 253
search-scope· 254
server-timeout 255
user-parameters· 255
Local bill cache commands· 256
display local-bill 256
local-bill enable· 259
local-bill export 259
local-bill export-interval 260
local-bill export-url 261
snmp-agent trap enable local-bill 262
AAA commands
AAA configuration related to IPoE, PPPoE, portal, user profile, and session group profile takes effect only on CSPEX cards (except the CSPEX-1104-E card).
Use aaa abnormal-offline-record enable to enable user abnormal offline recording.
Use undo aaa abnormal-offline-record enable to disable user abnormal offline recording.
User abnormal offline recording is enabled.
This feature enables the system to record information about users that go offline abnormally. These records help the administrator analyze the causes and resolve the issues for abnormal offline events. To display user abnormal offline records, use the display aaa abnormal-offline-record command.
This feature takes effect only when user offline recording is enabled.
The device can record a maximum of 32768 user abnormal offline records. When the maximum number is reached, a new record overwrites the oldest record.
To reduce the memory usage, you can disable this feature.
# Enable user abnormal offline recording.
[Sysname] aaa abnormal-offline-record enable
aaa deny-domain
Use aaa deny-domain to specify a denied domain on an interface.
Use undo aaa deny-domain to remove denied domains from an interface.
aaa deny-domain isp-name
undo aaa deny-domain [ isp-name ]
No denied domains are specified on an interface.
Interface view
isp-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. The name cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). You must specify an existing ISP domain.
Use this command to deny users in the specified ISP domain from accessing an interface.
This command is applicable only to PPP, IPoE, and portal and LAN users.
You can specify a maximum of 16 denied domains on an interface.
If you do not specify an ISP domain, the undo form of this command removes all denied domains from an interface.
On an interface, this command is mutually exclusive with the aaa permit-domain command.
# Specify ISP domain my-domain2 as a denied domain on GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] aaa deny-domain my-domain2
aaa permit-domain
domain
aaa nas-id
Use aaa nas-id to set the NAS-ID on an interface.
Use undo aaa nas-id to restore the default.
aaa nas-id nas-identifier
undo aaa nas-id
No NAS-ID is set on an interface.
Layer 3 interface view
nas-identifier: Specifies a NAS-ID, a case-insensitive string of 1 to 253 characters.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
You can configure a NAS-ID in NAS-ID profile view, in interface view, or in ISP domain view. The device selects the NAS-ID for the NAS-Identifier attribute in the following order:
1.        NAS-ID bound with VLANs in a NAS-ID profile.
2.        NAS-ID on an interface.
3.        NAS-ID in an ISP domain.
If no NAS-ID is selected, the device uses the device name as the NAS-ID.
The NAS-ID on an interface is applicable only to PPP, portal and IPoE users.
# Set the NAS-ID to test on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] aaa nas-id test
aaa nas-id profile
nas-id
aaa nas-id profile
Use aaa nas-id profile to create a NAS-ID profile and enter its view, or enter the view of an existing NAS-ID profile.
Use undo aaa nas-id profile to delete a NAS-ID profile.
undo aaa nas-id profile profile-name
No NAS-ID profiles exist.
profile-name: Specifies the NAS-ID profile name, a case-insensitive string of 1 to 31 characters.
Configure a NAS-ID profile to maintain NAS-ID and VLAN bindings on the device.
By default, the device sends its device name in the NAS-Identifier attribute of all RADIUS requests.
A NAS-ID profile enables you to send different NAS-Identifier attribute strings in RADIUS requests from different VLANs. The strings can be organization names, service names, or any user categorization criteria, depending on the administrative requirements.
For example, map the NAS-ID companyA to all VLANs of company A. The device will send companyA in the NAS-Identifier attribute for the RADIUS server to identify requests from any Company A users.
# Create a NAS-ID profile named aaa and enter its view.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa]
aaa nas-id
aaa nas-id-profile
nas-id bind
portal nas-id-profile
aaa nas-id-profile
Use aaa nas-id-profile to specify a NAS-ID profile for an interface.
Use undo aaa nas-id-profile to restore the default.
aaa nas-id-profile profile-name
No NAS-ID profile is specified for an interface.
profile-name: Specifies a NAS-ID profile by its name, a case-insensitive string of 1 to 31 characters.
This command takes effect only on PPP, portal, and IPoE users.
For portal users on an interface, the NAS-ID profile specified by using the portal nas-id-profile command takes priority over that specified by using the aaa nas-id-profile command. For more information about the portal nas-id-profile command, see "Portal commands."
# Specify NAS-ID profile bbb for GigabitEthernet 3/1/1.
[Sysname–GigabitEthernet3/1/1] aaa nas-id-profile bbb
aaa nas-id profile
nas-id bind
aaa nas-ip
Use aaa nas-ip to set the NAS IP address on an interface.
Use undo aaa nas-ip to remove the NAS IP address from the interface.
aaa nas-ip { ipv4-address | ipv6 ipv6-address }
undo aaa nas-ip [ ipv6 ]
No NAS IP address is set on an interface.
ipv4-address: Specifies an IPv4 address. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
Use this command to specify a NAS IP address for the NAS to carry in the NAS-IP-Address or NAS-IPv6-Address attribute in outgoing RADIUS packets. The NAS IP address must be unique for a RADIUS server to identify the NAS.
The NAS can also use the NAS IP address to match incoming RADIUS packets. For example, if the NAS receives a DAE request that contains a NAS IP address, it compares the NAS IP address in the request with the local NAS IP address. The NAS can process this request only when its NAS IP address is the same as the NAS IP address in the request.
You can specify the NAS IP address in interface view, RADIUS scheme view, and system view.
·          The NAS IP address specified by using this command in interface view applies only to users that access the network through the interface.
·          The NAS IP address specified by using the nas-ip command in RADIUS scheme view applies only to the RADIUS scheme.
·          The NAS IP address specified by using the radius nas-ip command in system view applies to all RADIUS schemes.
The priority order is as follows:
1.        The NAS IP address specified in interface view.
2.        The NAS IP address specified in RADIUS scheme view.
3.        The NAS IP address specified in system view.
An interface can have only one NAS IPv4 address and one NAS IPv6 address for RADIUS packets.
If you do not specify the ipv6 keyword for the undo aaa nas-ip command, the command removes the configured NAS IPv4 address for RADIUS packets.
# Specify IP address 1.1.1.1 as the NAS IPv4 address of RADIUS packets on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] aaa nas-ip 1.1.1.1
radius nas-ip
Use aaa normal-offline-record enable to enable user normal offline recording.
Use undo aaa normal-offline-record enable to disable user normal offline recording.
User normal offline recording is enabled.
This feature enables the system to record information about users that go offline normally. These records help the administrator analyze causes of user offline events. To display user normal offline records, use the display aaa normal-offline-record command.
The device can record a maximum of 32768 user normal offline records. When the maximum number is reached, a new record overwrites the oldest record.
# Enable user normal offline recording.
[Sysname] aaa normal-offline-record enable
Use aaa offline-record enable to enable user offline recording.
Use undo aaa offline-record enable to disable user offline recording.
User offline recording is enabled.
You must enable this feature so that user abnormal offline recording and user normal offline recording can take effect. Then, the system can record information about users that go offline normally and abnormally. To display user offline records, use the display aaa offline-record command.
The device can record a maximum of 65536 user offline records. When the maximum number is reached, a new record overwrites the oldest record.
# Enable user offline recording.
[Sysname] aaa offline-record enable
Use aaa online-fail-record enable to enable user online failure recording.
Use undo aaa online-fail-record enable to disable user online failure recording.
User online failure recording is enabled.
This feature enables the system to record information about users that fail to come online. These records help the administrator identify causes of user online failures and check for malicious users. To display user online failure records, use the display aaa online-fail-record command.
The device can record a maximum of 32768 user online failure records. When the maximum number is reached, a new record overwrites the oldest record.
# Enable user online failure recording.
[Sysname] aaa online-fail-record enable
aaa permit-domain
Use aaa permit-domain to specify a permitted domain on an interface.
Use undo aaa permit-domain to remove permitted domains from an interface.
aaa permit-domain isp-name
undo aaa permit-domain [ isp-name ]
No permitted domains are specified on an interface. All ISP domains are permitted.
Interface view
Use this command to allow only users in the specified ISP domain to access an interface.
You can specify a maximum of 16 permitted domains on an interface.
If you do not specify an ISP domain, the undo form of this command removes all permitted domains from an interface. The interface allows users in any ISP domains to access.
On an interface, this command is mutually exclusive with the aaa deny-domain command.
# Specify ISP domain my-domain as a permitted domain on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] aaa permit-domain my-domain
aaa deny-domain
domain
aaa roam-domain
Use aaa roam-domain to specify a roaming domain on an interface.
Use undo aaa roam-domain to remove the roaming domain from an interface.
aaa roam-domain isp-name
No roaming domain is specified on an interface.
Interface view
The device uses the roaming domain to authenticate a user if the user is assigned to a nonexistent domain.
This command is applicable only to IPoE, portal, LAN and PPP users.
# Specify ISP domain domain1 as the roaming domain on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] aaa roam-domain domain1
domain
Use aaa stop-accounting-packet master-replace-send to enable the master-replace-send feature.
Use undo aaa stop-accounting-packet master-replace-send to disable the master-replace-send feature.
The master-replace-send feature is disabled. The master does not replace a slot to send stop-accounting packets for users accessing the slot when the slot fails or is removed.
When a slot fails or is removed, the system does not send stop-accounting packets to the accounting server to log out the users that access this slot. Some accounting servers reject a user to come online if they have an online user entry for that user. If they fail to remove the online user entry for a user that has gone offline incorrectly, that user will be unable to come online again.
To resolve this issue, use the master-replace-send feature.
This feature synchronizes online user information on slots to the master. When a slot fails or is removed, this feature enables the master to replace that slot to send stop-accounting packets to the accounting server for online users accessing that slot. Upon receipt of the stop-accounting requests, the accounting server removes the online user entries. Then, the users can come online correctly.
(In standalone mode.) The term "slot" refers to an interface module and the term "master" refers to the active MPU.
(In IRF mode.) The term "slot" refers to an interface module and the term "master" refers to the global active MPU.
This feature takes effect only on network access users.
This feature occupies an amount of storage and communication resources. As a best practice to save resources, use this feature only when the accounting server requires stop-accounting packets to log out users.
(In standalone mode.) When you disable this feature, the active MPU will delete all user information stored for the users accessing interface modules. When you re-enable this feature, the active MPU will actively synchronize online user information from interface modules.
(In IRF mode.) When you disable this feature, the global active MPU will delete all user information stored for the users accessing interface modules. When you re-enable this feature, the global active MPU will actively synchronize online user information from interface modules.
# Enable the master-replace-send feature.
[Sysname] aaa stop-accounting-packet master-replace-send
aaa session-limit
Use aaa session-limit to set the maximum number of concurrent users that can log on to the device through the specified method.
Use undo aaa session-limit to restore the default maximum number of concurrent users for the specified login method.
aaa session-limit { ftp | http | https | ssh | telnet } max-sessions
undo aaa session-limit { ftp | http | https | ssh | telnet }
The maximum number of concurrent users is 32 for each user type.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
telnet: Telnet users.
max-sessions: Specifies the maximum number of concurrent login users. The value range for FTP, SSH, and Telnet services is 1 to 32, and the value range for HTTP and HTTPS services is 1 to 64.
After the maximum number of concurrent login users for a user type exceeds the upper limit, the system denies the subsequent users of this type.
# Set the maximum number of concurrent FTP users to 4.
[Sysname] aaa session-limit ftp 4
aaa ssid
Use aaa ssid to set the SSID on an interface
Use undo aaa ssid to restore the default.
aaa ssid ssid-name
undo aaa ssid
No SSID is set on an interface.
ssid-name: Specifies an SSID name, a case-sensitive string of 1 to 32 characters.
In a wireless network, the SSID on a user access interface identifies the SSID of the wireless network to which users on the interface access. The SSID is used as follows:
·          Carried in the Web server URL to which the device redirects users.
To carry an SSID in the Web server URL, you must specify the ssid keyword when you execute the web-server url-parameter command.
·          Populated in attribute 30 (Called-Station-Id, a standard RADIUS attribute) in outgoing RADIUS authentication requests. The format of the SSID information is 00-00-00-00-00-00:ssid-name.
Do not execute the aaa ssid command if no wireless users exist on the interface.
# Set the SSID on GigabitEthernet 3/1/1 to test11.
[Sysname-GigabitEthernet3/1/1] aaa ssid test11
accounting command
Use accounting command to specify the command line accounting method.
Use undo accounting command to restore the default.
accounting command hwtacacs-scheme hwtacacs-scheme-name
The default accounting methods of the ISP domain are used for command line accounting.
ISP domain view
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
The command line accounting feature works with the accounting server to record valid commands that have been successfully executed on the device.
·          When the command line authorization feature is disabled, the accounting server records all valid commands that have been successfully executed.
·          When the command line authorization feature is enabled, the accounting server records only authorized commands that have been successfully executed.
Command line accounting can use only a remote HWTACACS server.
# In ISP domain test, perform command line accounting based on HWTACACS scheme hwtac.
[Sysname] domain name test
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
accounting default
command accounting (Fundamentals Command Reference)
hwtacacs scheme
accounting default
Use accounting default to specify default accounting methods for an ISP domain.
Use undo accounting default to restore the default.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting method of an ISP domain is local.
ISP domain view
local: Performs local accounting.
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
The default accounting method is used for all users that support this method and do not have an accounting method configured.
Local accounting is only used for monitoring and controlling the number of local user connections. It does not provide the statistics function that the accounting feature generally provides.
You can specify one primary default accounting method and multiple backup default accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting default radius-scheme radius-scheme-name local none command specifies the primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
When the primary accounting method is local, the following rules apply to the accounting of a user:
·          The device uses the backup accounting methods in sequence only if local accounting is invalid for one of the following reasons:
¡  An exception occurs in the local accounting process.
¡  The user account is not configured on the device or the user is not allowed to use the access service.
·          The device does not turn to the backup accounting methods if local accounting is invalid because of any other reason. Accounting fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default accounting method and use local accounting as the backup.
[Sysname-isp-test] accounting default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
Use accounting dual-stack to specify the accounting method for dual-stack users.
Use undo accounting dual-stack to restore the default.
accounting dual-stack { merge | separate }
The merge method applies.
ISP domain view
merge: Merges IPv4 data with IPv6 data for accounting.
separate: Separates IPv4 data from IPv6 data for accounting.
If the charging rates are different for IPv4 and IPv6 data, use the separate method for the accounting of dual-stack users.
If the separate method is used for the accounting of dual-stack users, the authorization CAR action is also separately applied to IPoE users' basic IPv4 traffic and basic IPv6 traffic.
# In ISP domain test, configure the device to merge IPv4 data with IPv6 data for the accounting of dual-stack users.
[Sysname-isp-test] accounting dual-stack merge
accounting ipoe
Use accounting ipoe to specify accounting methods for IPoE users.
Use undo accounting ipoe to restore the default.
accounting ipoe { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for IPoE users.
ISP domain view
broadcast: Broadcasts accounting requests to servers in RADIUS schemes.
radius-scheme radius-scheme-name1: Specifies the primary broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-scheme radius-scheme-name2: Specifies the backup broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
You can specify one primary accounting method and multiple backup accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡  The user account is not configured on the device or the user is not allowed to use the IPoE service.
The following guidelines apply to broadcast accounting:
·          The device sends start-accounting, update-accounting, and stop-accounting requests to the primary accounting servers in the specified broadcast RADIUS schemes at the real-time accounting interval set in the primary broadcast RADIUS scheme. If the primary server is unavailable in a scheme, the device sends the accounting requests to the secondary servers of the scheme in the order the servers are configured. When a user goes offline, the device sends stop-accounting packets to the primary accounting server in both the primary broadcast RADIUS scheme and the backup broadcast RADIUS scheme.
·          The accounting result is determined by the primary broadcast RADIUS scheme. The accounting result from the backup scheme is used as reference only. If the primary scheme does not return any result, the device considers the accounting as a failure.
# In ISP domain test, perform local accounting for IPoE users.
[Sysname-isp-test] accounting ipoe local
# In ISP domain test, perform RADIUS accounting for IPoE users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting ipoe radius-scheme rd local
# In ISP domain test, broadcast accounting requests of IPoE users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting ipoe broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
Use accounting lan-access to specify accounting methods for LAN users.
Use undo accounting lan-access to restore the default.
accounting lan-access { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for LAN users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡  The user account is not configured on the device or the user is not allowed to use the LAN access service.
·          The device sends start-accounting, update-accounting, and stop-accounting requests to the primary accounting servers in the specified broadcast RADIUS schemes at the real-time accounting interval set in the primary scheme. If the primary server is unavailable in a scheme, the device sends the accounting requests to the secondary servers of the scheme in the order the servers are configured.
# In ISP domain test, perform local accounting for LAN users.
[Sysname-isp-test] accounting lan-access local
# In ISP domain test, perform RADIUS accounting for LAN users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting lan-access radius-scheme rd local
# In ISP domain test, broadcast accounting requests of LAN users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting lan-access broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting login
Use accounting login to specify accounting methods for login users.
Use undo accounting login to restore the default.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting methods of the ISP domain are used for login users.
ISP domain view
Accounting is not supported for FTP, SFTP, and SCP users.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting login radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡  The user account is not configured on the device.
# In ISP domain test, perform local accounting for login users.
[Sysname-isp-test] accounting login local
# In ISP domain test, perform RADIUS accounting for login users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting login radius-scheme rd local
accounting default
hwtacacs scheme
local-user
radius scheme
accounting portal
Use accounting portal to specify accounting methods for portal users.
Use undo accounting portal to restore the default.
accounting portal { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for portal users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting portal radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡  The user account is not configured on the device or the user is not allowed to use the portal service.
# In ISP domain test, perform local accounting for portal users.
[Sysname-isp-test] accounting portal local
# In ISP domain test, perform RADIUS accounting for portal users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting portal radius-scheme rd local
# In ISP domain test, broadcast accounting requests of portal users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting portal broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting ppp
Use accounting ppp to specify accounting methods for PPP users.
Use undo accounting ppp to restore the default.
accounting ppp { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] | hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
undo accounting ppp
The default accounting methods of the ISP domain are used for PPP users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting ppp radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡  The user account is not configured on the device or the user is not allowed to use the PPP service.
# In ISP domain test, perform local accounting for PPP users.
[Sysname-isp-test] accounting ppp local
# In ISP domain test, perform RADIUS accounting for PPP users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting ppp radius-scheme rd local
# In ISP domain test, broadcast accounting requests of PPP users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting ppp broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
hwtacacs scheme
local-user
radius scheme
Use accounting quota-out to configure access control for users that have used up their data or time accounting quotas.
Use undo accounting quota-out to restore the default.
accounting quota-out { offline | online | redirect-url url-string [ stop-accounting ] [ user-profile profile-name ] } [ no-accounting-update ]
The device sends accounting-update packets to the server to request new quotas for the users that have used up their accounting quotas. A user is logged off if the device does not receive any new quota for the user.
ISP domain view
offline: Logs off users that have used up their accounting quotas.
online: Allows users that have used up their accounting quotas to stay online.
redirect-url url-string: Specifies the URL to which users are redirected when they have used up their accounting quotas. The url-string argument is a case-sensitive string of 1 to 255 characters. This option is applicable only to PPPoE users.
stop-accounting: Sends stop-accounting packets for users that have used up their accounting quotas. If you do not specify this keyword, the device does not send stop-accounting packets for users that have used up their accounting quotas.
user-profile profile-name: Specifies a user profile to restrict behavior of users that have used up their data quotas. The profile-name argument is a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or digit, but it cannot be all digits. If you do not specify a user profile, the users that have used up their accounting quotas are not restricted by any user profile before they obtain new accounting quotas.
no-accounting-update: Disables the device from sending accounting-update requests to refresh the users' quotas.
This command takes effect only on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
The server might divide the accounting quota of a user into multiple portions and assign a portion to the user each time. If the server does not support dividing user accounting quota, specify the no-accounting-update keyword to decrease the burden of the server as a best practice.
# In ISP domain test, configure the device to allow users that have used up their accounting quotas to stay online.
[Sysname-isp-test] accounting quota-out online
Use accounting start-delay to set the start-accounting delay (the period of time that the device waits before sending a start-accounting request).
Use undo accounting start-delay to restore the default.
accounting start-delay delay-time
The start-accounting delay is 0 seconds.
ISP domain view
delay-time: Specifies the start-accounting delay, in the range of 1 to 300 seconds.
This command applies only to IPoE and PPPoE dual-stack users.
By default, the device sends a start-accounting request for a dual-stack user immediately after the user obtains the first IP address. Then, the device sends a real-time accounting request each time the dual-stack user obtains another IP address. If the server requires the device not to send an accounting request each time the user obtains an IP address, you can set the start-accounting delay to meet the requirement.
After you set the start-accounting delay, the device sends accounting requests for a dual-stack user as follows:
·          If a dual-stack user obtains all IP addresses within the start-accounting delay, the device sends a start-accounting request immediately after the user obtains all IP addresses.
·          If the dual-stack user does not obtain all IP addresses within the start-accounting delay, the device sends a start-accounting request when the delay ends. Then, the device sends an update-accounting request each time the user obtains an IP address.
Whether the user obtains all IP addresses is determined by the access module.
A long delay affects the accounting accuracy and a short delay causes frequent sending of accounting requests. Set an appropriate start-accounting delay based on the time required by IP address allocation for dual-stack users.
# In ISP domain test, set the start-accounting delay to 10 seconds.
[Sysname-isp-test] accounting start-delay 10
display domain
Use accounting start-fail to configure access control for users that encounter accounting-start failures.
Use undo accounting start-fail to restore the default.
accounting start-fail { offline | online }
The device allows users that encounter accounting-start failures to stay online.
ISP domain view
offline: Logs off users that encounter accounting-start failures.
online: Allows users that encounter accounting-start failures to stay online.
# In ISP domain test, configure the device to allow users that encounter accounting-start failures to stay online.
[Sysname-isp-test] accounting start-fail online
Use accounting update-fail to configure access control for users that have failed all their accounting-update attempts.
Use undo accounting update-fail to restore the default.
accounting update-fail { [ max-times max-times ] offline | online }
The device allows users that have failed all their accounting-update attempts to stay online.
ISP domain view
max-times max-times: Specifies the maximum number of consecutive accounting-update failures allowed by the device for each user. The value range for the times argument is 1 to 255, and the default value is 1.
offline: Logs off users that have failed all their accounting-update attempts.
online: Allows users that have failed all their accounting-update attempts to stay online.
# In ISP domain test, configure the device to allow users that have failed all their accounting-update attempts to stay online.
[Sysname-isp-test] accounting update-fail online
Use authentication default to specify default authentication methods for an ISP domain.
Use undo authentication default to restore the default.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication method of an ISP domain is local.
ISP domain view
ldap-scheme ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters.
local: Performs local authentication.
none: Does not perform authentication.
The default authentication method is used for all users that support this method and do not have an authentication method configured.
You can specify one primary default authentication method and multiple backup default authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication default radius-scheme radius-scheme-name local none command specifies a primary default RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
When the primary authentication method is local, the following rules apply to the authentication of a user:
·          The device uses the backup authentication methods in sequence only if local authentication is invalid for one of the following reasons:
¡  An exception occurs in the local authentication process.
·          The device does not turn to the backup authentication methods if local authentication is invalid because of any other reason. Authentication fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authentication method and use local authentication as the backup.
[Sysname-isp-test] authentication default radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication ipoe
Use authentication ipoe to specify authentication methods for IPoE users.
Use undo authentication ipoe to restore the default.
authentication ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for IPoE users.
ISP domain view
You can specify one primary authentication method and multiple backup authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for IPoE users.
[Sysname-isp-test] authentication ipoe local
# In ISP domain test, perform RADIUS authentication for IPoE users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ipoe radius-scheme rd local
local-user
radius scheme
Use authentication lan-access to specify authentication methods for LAN users.
Use undo authentication lan-access to restore the default.
authentication lan-access { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for LAN users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for LAN users.
[Sysname-isp-test] authentication lan-access local
# In ISP domain test, perform RADIUS authentication for LAN users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication lan-access radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
Use authentication login to specify authentication methods for login users.
Use undo authentication login to restore the default.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication methods of the ISP domain are used for login users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication login radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
¡  The user account is not configured on the device or the user is not allowed to use the service for accessing the device.
# In ISP domain test, perform local authentication for login users.
[Sysname-isp-test] authentication login local
# In ISP domain test, perform RADIUS authentication for login users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication login radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
Use authentication portal to specify authentication methods for portal users.
Use undo authentication portal to restore the default.
authentication portal { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for portal users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication portal radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for portal users.
[Sysname-isp-test] authentication portal local
# In ISP domain test, perform RADIUS authentication for portal users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication portal radius-scheme rd local
ldap scheme
local-user
radius scheme
authentication ppp
Use authentication ppp to specify authentication methods for PPP users.
Use undo authentication ppp to restore the default.
authentication ppp { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication methods of the ISP domain are used for PPP users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication ppp radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for PPP users.
[Sysname-isp-test] authentication ppp local
# In ISP domain test, perform RADIUS authentication for PPP users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ppp radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
Use authentication super to specify methods for user role authentication.
Use undo authentication super to restore the default.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
The default authentication methods of the ISP domain are used for user role authentication.
ISP domain view
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication. The device supports local and remote methods for user role authentication. For more information about user role authentication, see RBAC configuration in Fundamentals Configuration Guide.
You can specify one authentication method and one backup authentication method to use in case that the previous authentication method is invalid.
# In ISP domain test, perform user role authentication based on HWTACACS scheme tac.
[Sysname] super authentication-mode scheme
[Sysname-isp-test] authentication super hwtacacs-scheme tac
hwtacacs scheme
radius scheme
Use authentication-method none authorization-attribute to configure authorization attributes for none-authentication users.
Use undo authentication-method none authorization-attribute to restore the default.
authentication-method none authorization-attribute session-timeout timeout
undo authentication-method none authorization-attribute session-timeout
Authorization attributes for users in an ISP domain are those assigned by the server. If the server does not assign authorization attributes, the authorization attributes configured in the ISP domain are used.
ISP domain view
session-timeout timeout: Specifies an authorization session timeout timer in the range of 1 to 4294967294 seconds. The device logs out a user when the session timeout timer for the user expires. This attribute is applicable only to PPP, IPoE, and portal and LAN users.
None-authentication users refer to the users that are allowed to come online without being authenticated.
Typically, a user's authorization attributes can be assigned by the authorization server or obtained from its ISP domain. The device does not distinguish the authentication methods of users when it issues the authorization attributes obtained from an ISP domain to the users.
To centrally manage authorization attributes for none-authentication users, perform this task to configure authorization attributes specific to these users in an ISP domain.
In the current software version, you can configure only the authorization session timeout timer for none-authentication users.
For none-authentication users, the authorization attributes configured by using this command take precedence over those configured by using the authorization-attribute command in ISP domain view.
# In ISP domain test, set the authorization session timeout timer to 60 seconds for none-authentication users.
[Sysname-isp-test] authentication-method none authorization-attribute session-timeout 60
Use authorization command to specify command authorization methods.
Use undo authorization command to restore the default.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
The default authorization methods of the ISP domain are used for command authorization.
ISP domain view
local: Performs local authorization.
none: Does not perform authorization. The authorization server does not verify whether the entered commands are permitted by the user role. The commands are executed successfully if the user role has permission to the commands.
Command authorization restricts login users to execute only authorized commands by employing an authorization server to verify whether each entered command is permitted.
When local command authorization is configured, the device compares each entered command with the user's configuration on the device. The command is executed only when it is permitted by the user's authorized user roles.
The commands that can be executed are controlled by both the access permission of user roles and command authorization of the authorization server. Access permission only controls whether the authorized user roles have access to the entered commands, but it does not control whether the user roles have obtained authorization to these commands. If a command is permitted by the access permission but denied by command authorization, this command cannot be executed.
You can specify one primary command authorization method and multiple backup command authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization command hwtacacs-scheme hwtacacs-scheme-name local none command specifies the default HWTACACS authorization method and two backup methods (local authorization and no authorization). The device performs HWTACACS authorization by default and performs local authorization when the HWTACACS server is invalid. The device does not perform command authorization when both of the previous methods are invalid.
# In ISP domain test, configure the device to perform local command authorization.
[Sysname-isp-test] authorization command local
# In ISP domain test, perform command authorization based on HWTACACS scheme hwtac and use local authorization as the backup.
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
command authorization (Fundamentals Command Reference)
hwtacacs scheme
local-user
Use authorization default to specify default authorization methods for an ISP domain.
Use undo authorization default to restore the default.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization method of an ISP domain is local.
ISP domain view
none: Does not perform authorization. The following default authorization information applies after users pass authentication:
·          Non-login users can access the network.
·          Login users obtain the level-0 user role. Login users include the Telnet, FTP, SFTP, SCP, and terminal users. Terminal users can access the device through the console port. For more information about the level-0 user role, see RBAC configuration in Fundamentals Configuration Guide.
·          The working directory for FTP, SFTP, and SCP login users is the root directory of the NAS. However, the users do not have permission to access the root directory.
The default authorization method is used for all users that support this method and do not have an authorization method configured.
The RADIUS authorization configuration takes effect only when the authentication method and authorization method of the ISP domain use the same RADIUS scheme.
You can specify one primary authorization method and multiple backup authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization default radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
When the primary authorization method is local, the following rules apply to the authorization of a user:
·          The device uses the backup authorization methods in sequence only if local authorization is invalid for one of the following reasons:
¡  An exception occurs in the local authorization process.
·          The device does not turn to the backup authorization methods if local authorization is invalid because of any other reason. Authorization fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authorization method and use local authorization as the backup.
[Sysname-isp-test] authorization default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization ipoe
Use authorization ipoe to specify authorization methods for IPoE users.
Use undo authorization ipoe to restore the default.
authorization ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for IPoE users.
ISP domain view
The RADIUS authorization configuration takes effect only when authentication and authorization methods of the ISP domain use the same RADIUS scheme.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for IPoE users.
[Sysname-isp-test] authorization ipoe local
# In ISP domain test, perform RADIUS authorization for IPoE users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization ipoe radius-scheme rd local
local-user
radius scheme
authorization lan-access
Use authorization lan-access to specify authorization methods for LAN users.
Use undo authorization lan-access to restore the default.
authorization lan-access { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for LAN users.
ISP domain view
none: Does not perform authorization. An authenticated LAN user directly accesses the network.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for LAN users.
[Sysname-isp-test] authorization lan-access local
# In ISP domain test, perform RADIUS authorization for LAN users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization lan-access radius-scheme rd local
local-user
radius scheme
authorization login
Use authorization login to specify authorization methods for login users.
Use undo authorization login to restore the default.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization methods of the ISP domain are used for login users.
ISP domain view
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization login radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for login users.
[Sysname-isp-test] authorization login local
# In ISP domain test, perform RADIUS authorization for login users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization login radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization portal
Use authorization portal to specify authorization methods for portal users.
Use undo authorization portal to restore the default.
authorization portal { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for portal users.
ISP domain view
none: Does not perform authorization. An authenticated portal user directly accesses the network.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization portal radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for portal users.
[Sysname-isp-test] authorization portal local
# In ISP domain test, perform RADIUS authorization for portal users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization portal radius-scheme rd local
local-user
radius scheme
authorization ppp
Use authorization ppp to specify authorization methods for PPP users.
Use undo authorization ppp to restore the default.
authorization ppp { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization methods of the ISP domain are used for PPP users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization ppp radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for PPP users.
[Sysname-isp-test] authorization ppp local
# In ISP domain test, perform RADIUS authorization for PPP users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization ppp radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization-attribute (ISP domain view)
Use authorization-attribute to configure authorization attributes for users in an ISP domain.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { acl acl-number | car inbound cir committed-information-rate [ pir peak-information-rate ] outbound cir committed-information-rate [ pir peak-information-rate ] | idle-cut minutes [ flow ] [ traffic { both | inbound | outbound } ] | igmp max-access-number max-access-number | ip-pool ipv4-pool-name | ip-pool-group ipv4-pool-group-name | ipv6-nd-prefix-pool ipv6-prefix-pool-name | ipv6-nd-prefix-pool-group ipv6-prefix-pool-group-name | ipv6-pool ipv6-pool-name | ipv6-pool-group ipv6-pool-group-name | ipv6-prefix ipv6-prefix prefix-length | mld max-access-number max-access-number | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | redirect-times times | session-group-profile session-group-profile-name | session-timeout timeout | url url-string [ unlimited ] | user-group user-group-name | user-priority { inbound | outbound } priority | user-profile profile-name | vpn-instance vpn-instance-name }
undo authorization-attribute { acl | car | idle-cut | igmp | ip-pool | ip-pool-group | ipv6-nd-prefix-pool | ipv6-nd-prefix-pool-group | ipv6-pool | ipv6-pool-group | ipv6-prefix | mld | primary-dns | redirect-times | secondary-dns | session-group-profile | session-timeout | url | user-group | user-priority { inbound | outbound } | user-profile | vpn-instance }
The idle cut feature is disabled.
An IPv4 user can concurrently join a maximum of four IGMP multicast groups.
An IPv6 user can concurrently join a maximum of four MLD multicast groups.
The device allows a maximum of two times to redirect the Web visit requests of a user to the redirect URL.
No other authorization attributes exist.
ISP domain view
acl acl-number: Specifies an ACL to filter traffic for users. The value range for the acl-number argument is 2000 to 5999. Only ACL 2000 to ACL 4999 take effect. This option is applicable only to LAN and portal users. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
car: Specifies a CAR action for users. This keyword is applicable only to IPoE, portal, and PPP users.
inbound: Specifies the upload rate of users.
outbound: Specifies the download rate of users.
cir committed-information-rate: Specifies the committed information rate in kbps, in the range of 1 to 4194303.
pir peak-information-rate: Specifies the peak information rate in kbps, in the range of 1 to 4194303. The peak information rate must be equal to or greater than the committed information rate. If you do not specify this option, the CAR action does not restrict users by peak information rate.
idle-cut minutes: Sets an idle timeout period in minutes. The value range for the minutes argument is 1 to 600. This option is applicable only to IPoE, portal, and PPP users.
flow: Specifies the minimum traffic that must be generated in the idle timeout period in bytes. The value range is 1 to 10240000, and the default value is 10240.
traffic: Specifies the traffic direction for the idle cut feature. If you do not specify this keyword, the idle cut feature applies to both traffic directions.
both: Specifies both traffic directions.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
igmp max-access-number max-access-number: Specifies the maximum number of IGMP groups that an IPv4 user can join concurrently. The value range for the max-access-number argument is 1 to 64. This option is applicable only to IPoE, portal, and PPP users.
ip-pool ipv4-pool-name: Specifies an IPv4 address pool for users. The ipv4-pool-name argument is a case-insensitive string of 1 to 63 characters. This option is applicable only to IPoE and PPP users.
ip-pool-group ipv4-pool-group-name: Specifies an IPv4 address pool group for users. The ipv4-pool-group-name argument represents a DHCP address pool group, and it is a case-insensitive string of 1 to 63 characters. This option is applicable only to IPoE and PPP users.
ipv6-nd-prefix-pool ipv6-prefix-pool-name: Specifies an ND prefix pool for users. The ipv6-prefix-pool-name argument represents a DHCPv6 address pool that ND uses to assign prefixes to users, and it is a case-insensitive string of 1 to 63 characters. This option is applicable only to PPP and IPoE users.
ipv6-nd-prefix-pool-group ipv6-pool-group-name: Specifies an ND prefix pool group for users. The ipv6-pool-group-name argument represents a DHCPv6 address pool group that ND uses to assign prefixes to users, and it is a case-insensitive string of 1 to 63 characters. This option is applicable only to PPP users. The ND prefix pool group attribute has a lower priority than the ND prefix pool attribute.
ipv6-pool ipv6-pool-name: Specifies an IPv6 address pool for users. The ipv6-pool-name argument represents a DHCPv6 address pool to assign IPv6 addresses to users, and it is a case-insensitive string of 1 to 63 characters. This option is applicable only to IPoE and PPP users.
ipv6-pool-group ipv6-pool-group-name: Specifies an IPv6 address pool group for users. The ipv6-pool-group-name argument represents a DHCPv6 address pool group, and it is a case-insensitive string of 1 to 63 characters. This option is applicable only to IPoE and PPP users.
ipv6-prefix ipv6-prefix prefix-length: Specifies an IPv6 address prefix for users. The value range for the prefix-length argument is 1 to 128. This option is applicable only to IPoE and PPP users.
mld max-access-number max-access-number: Specifies the maximum number of MLD groups that an IPv6 user can join concurrently. The value range for the max-access-number argument is 1 to 64. This option is applicable only to IPoE, portal, and PPP users.
primary-dns ip ipv4-address: Specifies the IPv4 address of the primary DNS server for users. This option is applicable only to IPoE and PPP users.
primary-dns ipv6 ipv6-address: Specifies the IPv6 address of the primary DNS server for users. This option is applicable only to IPoE and PPP users.
secondary-dns ip ipv4-address: Specifies the IPv4 address of the secondary DNS server for users. This option is applicable only to IPoE and PPP users.
secondary-dns ipv6 ipv6-address: Specifies the IPv6 address of the secondary DNS server for users. This option is applicable only to IPoE and PPP users.
redirect-times times:  Sets the maximum number of times allowed by the device to redirect the Web visit requests of a user to the redirect URL. If the maximum number is reached and the device does not receive any Web visit request destined for the redirect URL from the user, the device stops redirecting that user to the redirect URL. The value range for the times argument is 1 to 10, and the default setting is 2. This option is applicable only to PPP and IPoE users.
session-group-profile session-group-profile-name: Specifies an authorization session group profile for users. The session-group-profile-name argument is a case-sensitive string of 1 to 31 characters and can contain only letters, digits, underscores (_), and dots (.). The string can begin with a letter or a digit, but it cannot be all digits. The session-group-profile session-group-profile-name option is applicable only to IPoE, portal, and PPP users.
session-timeout timeout: Specifies the session timeout time for users, in seconds. The value range for the timeout argument is 1 to 4294967294. The device logs out a user when the session timeout timer for the user expires. If the RADIUS server assigns a user the Session-Timeout attribute, the value in the assigned attribute takes precedence. This attribute is applicable only to LAN, IPoE, portal, and PPP users.
url url-string: Specifies the URL for users. Users are redirected to the URL the first time they access the network after they pass authentication. The URL is a case-sensitive string of 1 to 255 characters and must begin with http:// or https://. This option is applicable only to IPoE and PPP users. For IPoE users, specify a URL that uses port number 80 or 443. For PPP users, specify a URL that uses port number 80 or 8080.
unlimited: Does not limit the number of times that the device redirects the Web visit requests of a user to the redirect URL. If you do not specify this keyword, the device limits the number of times that it redirects the Web visit requests of a user to the redirect URL based on the redirect-times attribute. The unlimited keyword is applicable only to PPP and IPoE users.
user-group user-group-name: Specifies a user group for users. The user-group-name argument is a case-insensitive string of 1 to 32 characters. Authenticated users obtain all attributes of the user group.
user-priority: Specifies a user priority for users. The device uses the specified user priority to perform QoS priority mapping on user packets, and then assigns the user packets to a queue based on the target priority. Packets in a high-priority queue are preferentially scheduled when congestion occurs. In addition, the device replaces the value of the IP Precedence field in upstream packets of users with the specified user priority. You can set the upstream user priority in conjunction with the downstream user priority. By default, no user priority is assigned to users. This keyword is applicable to PPP, L2TP, portal, and IPoE users. This keyword takes effect only on CSPEX cards (except the CSPEX-1204 and CSPEX-1104-E cards).
inbound: Applies the user priority to upstream packets of users.
outbound: Applies the user priority to downstream packets of users.
priority: Specifies a user priority in the range of 0 to 7. The greater the value, the higher the priority.
user-profile profile-name: Specifies an authorization user profile by its name. The profile-name argument is a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or digit, but it cannot be all digits. The user profile restricts the behavior of authenticated users. The user-profile profile-name option is applicable only to LAN, IPoE, portal, and PPP users.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the users belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. When a user passes authentication, it has permission to access the network resources in the specified VPN. This option is applicable only to PPP and IPoE users.
When the idle cut feature is configured, the device periodically detects the traffic of each online user. The device logs out users that do not meet the minimum traffic requirement in the idle timeout period. When the idle cut feature is disabled on the device, the idle cut feature of the server takes effect. The server considers a user idle if the user's traffic is less than 10240 bytes in a configurable idle timeout period.
If authorization attributes are configured in an IPoE preauthentication domain, the device assigns the attributes to the users after the users pass preauthentication and obtain IP addresses. The attributes restrict access behaviors of the users before the users pass Web authentication.
If the server or NAS does not authorize any attributes to an authenticated user, the device authorizes the attributes in the ISP domain to the user. However, if the server authorizes the CAR action or user priority attribute only for one direction, the device does not authorize the CAR action or user priority attribute of the ISP domain for the other direction.
In addition to the redirect-times times and url url-string [ unlimited ] options, the device also supports the Web-URL and Authen-Detail-Result attributes assigned by a RADIUS server. The device interprets the Web-URL attribute as a redirect URL and the Authen-Detail-Result attribute as a redirect action. Redirect actions include stopping redirecting a user to the redirect URL, redirecting a user to the redirect URL every time, and redirecting a user to the redirect URL a number of times.
When a PPP or IPoE user comes online, the following rules apply to the redirect URL attributes:
·          If the server assigns a redirect URL with action redirecting the user to the redirect URL every time, the device uses the server-assigned redirect URL and does not limit the number of redirect times.
·          If the server assigns a redirect URL with action redirecting the user to the redirect URL a number of times, the device uses the server-assigned redirect URL and limits the redirect times based on the redirect-times attribute in the ISP domain. If the redirect-times times option is not configured, the maximum number of redirect times is 2.
·          If the server does not assign a redirect URL, the device uses the configuration of the url and redirect-times parameters in the ISP domain. In addition, the device will ignore the Authen-Detail-Result attribute assigned by the server.
¡  If the unlimited keyword is specified for URL redirection in the ISP domain, the device does not limit the number of redirect times.
¡  If the unlimited keyword is not specified for URL redirection in the ISP domain, the device limits the number of redirect times based on the configuration of the redirect-times times option.
When a PPP or IPoE user is online, the following rules apply to the redirect URL attributes:
·          If the server assigns the action of stopping redirecting the user to the redirect URL, the device stops redirecting the Web visit requests of that user to the redirect URL.
·          If the server assigns the action of redirecting the user to the redirect URL every time, the following rules apply:
¡  If the server assigns a redirect URL, the device uses the server-assigned redirect URL and does not limit the number of redirect times.
¡  If the server does not assign a redirect URL, the device ignores the server-assigned redirect action and returns redirect attribute assignment failure to the server.
·          If the server assigns the action of redirecting the user to the redirect URL a number of times, the following rules apply:
¡  If the server assigns a redirect URL, the device uses the server-assigned redirect URL and limits the number of redirect times based on the configuration of the redirect-times times option in the ISP domain. If the redirect-times times option is not configured, the maximum number of redirect times is 2.
You can configure multiple authorization attributes for users in an ISP domain. If you execute the command multiple times with the same attribute specified, the most recent configuration takes effect.
If both the address pool group and address pool attributes are assigned to a user, the address pool attribute has higher priority.
# Configure the idle cut feature for users in ISP domain test.
[Sysname] domain name test
[Sysname-isp-test] authorization-attribute idle-cut 30 10240
display domain
basic-service-ip-type
Use basic-service-ip-type to specify the types of IP addresses that PPPoE and L2TP users must rely on to use the basic services.
Use undo basic-service-ip-type to restore the default.
basic-service-ip-type { ipv4 | ipv6 | ipv6-pd } *
PPPoE and L2TP users do not rely on any types of IP addresses to use the basic services.
ISP domain view
ipv4: Specifies the IPv4 address type.
ipv6: Specifies the IPv6 address type.
ipv6-pd: Specifies the IPv6-PD address type. This type of IPv6 addresses are generated based on the DHCPv6 server-assigned prefix.
This command takes effect only when the device acts as a PPPoE server or L2TP LNS.
A PPPoE or L2TP user might request multiple services of different IP address types. The device logs off the user if the user does not obtain the IP addresses of all types for the services. This command enables the device to allow the user to come online if the user has obtained IP addresses of the specified types for the basic services.
The device does not allow a PPPoE or L2TP user to come online if the user does not obtain IP addresses of all the specified types for the basic services. For example, if you execute the basic-service-ip-type ipv6 command, the device does not allow a PPPoE or L2TP user to come online if the user does not obtain an IPv6 address.
If you specify both the ipv6 and ipv6-pd keywords, the device does not allow a PPPoE or L2TP user that fails IPv6 address negotiation or PD negotiation to come online.
# In ISP domain test, specify PPPoE and L2TP users to rely on IPv4 addresses to use the basic services.
[Sysname-isp-test] basic-service-ip-type ipv4
display domain
dhcpv6-follow-ipv6cp
Use dhcpv6-follow-ipv6cp to set the IPv6 address wait timer for PPPoE and L2TP users.
Use undo dhcpv6-follow-ipv6cp to restore the default.
dhcpv6-follow-ipv6cp timeout delay-time
The IPv6 address wait timer is 60 seconds for PPPoE and L2TP users.
ISP domain view
timeout delay-time: Specifies the IPv6 address wait timer, in the range of 30 to 1000 seconds.
The IPv6 address wait timer defines the maximum amount of time that a user can wait before the device determines that the user fails to obtain an IPv6 address or PD prefix.
The device starts an IPv6 address wait timer for a user after it finishes IPv6CP negotiation with the user. If the user's basic service relies on an IPv6 address or PD prefix but it fails to obtain any IPv6 address or PD prefix when the timer expires, the user cannot come online.
As a best practice, increase the IPv6 address wait timer in the following situations:
·          The network connectivity is unstable.
·          The device uses DHCPv6 to assign IPv6 addresses to users.
·          The ISP domain serves a large number of PPPoE and L2TP users.
# In ISP domain test, set the IPv6 address wait timer to 90 seconds for PPPoE and L2TP users.
[Sysname-isp-test] dhcpv6-follow-ipv6cp timeout 90
display domain
display aaa abnormal-offline-record
Use display aaa abnormal-offline-record to display user abnormal offline records.
In standalone mode:
display aaa abnormal-offline-record { access-type { ipoe | lan-access | login | portal | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa abnormal-offline-record offline-reason { idle-cut | quota-out | realtime-acct-fail | session-timeout | user-detect-fail } [ brief ]
display aaa abnormal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
In IRF mode:
display aaa abnormal-offline-record { access-type { ipoe | lan-access | login | | portal | ppp } | chassis chassis-number slot slot-number | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | username user-name [ fuzzy-match ] } * [ brief | count count ]
access-type: Specifies users by the access type.
ipoe: Specifies IPoE users.
lan-access: Specifies LAN users.
login: Specifies login users, such as SSH users, Telnet users, and FTP users.
portal: Specifies portal users.
ppp: Specifies PPP users.
domain domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
interface interface-type interface-number: Specifies an interface by its interface type and interface number.
ip ipv4-address: Specifies a user by its IPv4 address.
ipv6 ipv6-address: Specifies a user by its IPv6 address.
mac-address mac-address: Specifies a user by its MAC address in the format of H-H-H.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user abnormal offline records for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user abnormal offline records for all cards. (In IRF mode.)
s-vlan svlan-id: Specifies an SVLAN by its VLAN ID in the range of 1 to 4094.
c-vlan cvlan-id: Specifies a CVLAN by its VLAN ID in the range of 1 to 4094.
username user-name: Specifies users using the specified username, a case-sensitive string of 1 to 253 characters.
fuzzy-match: Matches the username in fuzzy mode. In fuzzy mode, a user matches if the user's username includes the specified username. If you do not specify this keyword, the device matches the username in exact mode. In exact mode, a user matches if the user's username is the same as the specified username.
offline-reason: Specifies a user offline reason.
idle-cut: Specifies the reason as session idle timeout.
quota-out: Specifies the reason as data quota out.
realtime-acct-fail: Specifies the reason as realtime accounting failure.
session-timeout: Specifies the reason as session timeout.
user-detect-fail: Specifies the reason as user online detection failure.
time: Specifies user abnormal offline records generated in a time range.
begin-time: Specifies the start time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59.
end-time: Specifies the end time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59.
date: Specifies a date range. If you do not specify a date range, this command displays user abnormal offline records on the current day.
begin-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
brief: Displays brief information about user abnormal offline records. If you do not specify this keyword, the command displays detailed information about user abnormal offline records.
count count: Specifies the number of user abnormal offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user abnormal offline records. This command displays the most recent user abnormal offline records that match the specified criteria in reverse chronological order.
If user abnormal offline records exist in the system, you can use this command to display the records regardless of whether user abnormal offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user abnormal offline records for all users.
The usernames that the server sends to the device might include invisible characters. For the device to display the records for users with such usernames, you must specify the fuzzy-match keyword in this command.
# Display detailed information about abnormal offline records for all users.
<Sysname> display aaa abnormal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: SSH
Access interface: GigabitEthernet3/1/1
SVLAN/CVLAN: -/-
IP address: 19.19.0.2
IPv6 address: -
Online request time: 2017/01/02 15:20:33
Offline time: 2017/2/28 15:20:56
Offline reason: User disconnected from the server.
# Display brief information about abnormal offline records for login users.
<Sysname> display aaa abnormal-offline-record access-type login brief
Username: jay
MAC address: -
IP address: 11.2.2.41
IPv6 address: -
Total count
Total number of matching user abnormal offline records.
Username
Name of the user.
This field does not display anything if the system failed to obtain the username.
Domain
Name of the ISP domain to which the user belongs.
This field does not display anything if the system failed to obtain the ISP domain.
MAC address
MAC address of the user.
This filed displays a hyphen (-) if the system failed to obtain the MAC address.
Access type
Access type of the user:
·         PPPoPhy—PPP over physical link.
·         PPPoE.
·         PPPoL2TP—PPP over L2TP.
·         PPPoFR—PPP over Frame Relay.
·         VPPP—L2TP auto dial-up.
·         MAC authentication.
·         802.1X.
·         Web authentication.
·         Telnet.
·         FTP.
·         SSH.
·         Portal.
·         IPoE.
·         IPoE interface leased.
·         IPoE subnet leased.
·         IPoE L2VPN leased.
·         NETCONF over SOAP.
·         NETCONF over RESTful.
·         Web.
·         Terminal.
Access interface
Interface through which the user accesses the network.
This field displays a hyphen (-) if the system failed to obtain the access interface.
SVLAN/CVLAN
SVLAN and CVLAN to which the user belongs.
This field displays a hyphen (-) for the SVLAN or CVLAN in the following situations:
·         The user does not belong to an SVLAN.
·         The system failed to obtain the SVLAN or CVLAN of the user.
IP address
IPv4 address of the user.
This field displays a hyphen (-) if the system failed to obtain the IPv4 address.
IPv6 address
IPv6 address of the user.
This field displays a hyphen (-) if the system failed to obtain the IPv6 address.
Online request time
Time when the user requested to come online.
Offline time
Time when the user went offline.
Offline reason
Reason that the user went offline.
reset aaa abnormal-offline-record
display aaa normal-offline-record
Use display aaa normal-offline-record to display user normal offline records.
In standalone mode:
display aaa normal-offline-record { access-type { ipoe | lan-access | login | portal | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa normal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
In IRF mode:
display aaa normal-offline-record { access-type { ipoe | lan-access | login | portal | ppp } | chassis chassis-number slot slot-number | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | username user-name [ fuzzy-match ] } * [ brief | count count ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user normal offline records for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user normal offline records for all cards. (In IRF mode.)
time: Specifies user normal offline records generated in a time range.
brief: Displays brief information about user normal offline records. If you do not specify this keyword, the command displays detailed information about user normal offline records.
count count: Specifies the number of user normal offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user normal offline records. This command displays the most recent user normal offline records that match the specified criteria in reverse chronological order.
If user normal offline records exist in the system, you can use this command to display the records regardless of whether user normal offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user normal offline records for all users.
# Display detailed information about normal offline records for all users.
<Sysname> display aaa normal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Offline reason: User request.
# Display brief information about normal offline records for login users.
<Sysname> display aaa normal-offline-record access-type login brief
Username: jay
MAC address: -
IPv6 address: -
Total count
Total number of matching user normal offline records.
Username
Name of the user.
Domain
MAC address
Access type
·         PPPoE.
·         802.1X.
·         Telnet.
·         FTP.
·         SSH.
·         Portal.
·         IPoE.
·         Web.
·         Terminal.
Access interface
SVLAN/CVLAN
IP address
IPv6 address
Online request time
Offline time
Offline reason
reset aaa normal-offline-record
display aaa offline-record
Use display aaa offline-record to display user offline records.
In standalone mode:
display aaa offline-record { access-type { ipoe | lan-access | login | portal | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
In IRF mode:
display aaa offline-record { access-type { ipoe | lan-access | login | portal | ppp } | chassis chassis-number slot slot-number | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | username user-name [ fuzzy-match ] } * [ brief | count count ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user offline records for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user offline records for all cards. (In IRF mode.)
time: Specifies user offline records generated in a time range.
brief: Displays brief information about user offline records. If you do not specify this keyword, the command displays detailed information about user offline records.
count count: Specifies the number of user offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user offline records. This command displays the most recent user offline records that match the specified criteria in reverse chronological order.
If user offline records exist in the system, you can use this command to display the records regardless of whether user offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user offline records for all users.
# Display detailed information about offline records for all users.
<Sysname> display aaa offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
# Display brief information about offline records for login users
<Sysname> display aaa offline-record access-type login brief
Username: jay
MAC address: -
IP address: 20.20.20.1
IPv6 address: -
Username: test
MAC address: -
IP address: 20.20.20.3
IPv6 address: -
Total count
Total number of matching user offline records.
Username
Name of the user.
Domain
MAC address
Access type
·         PPPoE.
·         802.1X.
·         Telnet.
·         FTP.
·         SSH.
·         Portal.
·         IPoE.
·         Web.
·         Terminal.
Access interface
SVLAN/CVLAN
IP address
IPv6 address
Online request time
Offline time
Offline reason
reset aaa offline-record
display aaa online-fail-record
Use display aaa online-fail-record to display user online failure records.
In standalone mode:
display aaa online-fail-record { access-type { ipoe | lan-access | login | portal | ppp } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa online-fail-record time begin-time end-time [ date begin-date end-date ] [ brief ]
In IRF mode:
display aaa online-fail-record { access-type { ipoe | lan-access | login | portal | ppp } | chassis chassis-number slot slot-number | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | username user-name [ fuzzy-match ] } * [ brief | count count ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user online failure records for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user online failure records for all cards. (In IRF mode.)
time: Specifies user online failure records generated in a time range.
brief: Displays brief information about user online failure records. If you do not specify this keyword, the command displays detailed information about user online failure records.
count count: Specifies the number of user online failure records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user online failure records. This command displays the most recent user online failure records that match the specified criteria in reverse chronological order.
If user online failure records exist in the system, you can use this command to display the records regardless of whether user online failure recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user online failure records for all users.
# Display detailed information about the most recent two online failure records for login users that use the username aaa.
<Sysname> display aaa online-fail-record username aaa access-type login count 2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: 100/-
IP address: 19.19.0.1
IPv6 address: -
Online request time: 2017/01/02 15:20:37
Online failure reason: Authentication failed.
Server reply message: no user exists.
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
# Display brief information about user online failure records generated from 2017/03/01 13:20:50 to 2017/03/02 17:20:30.
<Sysname> display aaa online-fail-record time 13:20:50 10:20:30 date 2017/3/1 2017/3/2 brief
Username: aaa
MAC address: -
IPv6 address: -
# Display detailed information about user online failure records generated from 2017/03/01 13:20:50 to 2017/03/02 17:20:30.
<Sysname> display aaa online-fail-record time 13:20:50 17:20:30 date 2017/3/1 2017/3/2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Online request time: 2017/03/02 16:20:33
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Online request time: 2017/03/01 15:20:51
Total count
Total number of matching user online failure records.
Username
Name of the user.
Domain
MAC address
This filed displays a hyphen (-) if the system failed to obtain the user's MAC address.
Access type
·         PPPoE.
·         802.1X.
·         Telnet.
·         FTP.
·         SSH.
·         Portal.
·         IPoE.
·         Web.
·         Terminal.
Access interface
SVLAN/CVLAN
IP address
IPv6 address
Online request time
Reason that the user failed to come online.
Message sent from the server. This field is not displayed if the server does not send a message.
reset aaa online-fail-record
display domain
Use display domain to display ISP domain configuration.
display domain [ isp-name ]
isp-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. If you do not specify an ISP domain, this command displays the configuration of all ISP domains.
To display load-sharing user groups in an ISP domain and the number of users in each group, you must specify the ISP domain when executing this command.
# Display the configuration of all ISP domains.
<Sysname> display domain
Total 2 domains
Domain: system
  Current state: Active
  State configuration: Active
  Default authentication scheme:  Local
  Default authorization  scheme:  Local
  Default accounting     scheme:  Local
  Accounting start failure action: Online
  Accounting update failure action: Online
  Accounting quota out policy: Offline
    Send accounting update:Yes
  Service type: HSI
  Session time: Exclude idle time
  DHCPv6-follow-IPv6CP timeout: 60 seconds
  Dual-stack accounting method: Merge
  NAS-ID: N/A
  Service rate-limit mode: Separate
  Web server URL              : Not configured
  Web server URL parameters   : Not configured
  Web server IPv4 address     : Not configured
  Web server IPv6 address     : Not configured
  Redirect active time        : Not configured
  Redirect server IPv4 address: Not configured
  Redirect server IPv6 address: Not configured
  Temporary redirect          : Disabled
  L2TP-user RADIUS-force      : Disabled
  Authorization attributes:
    Idle cut: Disabled
    IGMP access limit: 4
    MLD access limit:  4
  IP resource usage warning thresholds:
    High threshold: Not configured
    Low threshold: Not configured
  IPv6 resource usage warning thresholds:
Domain: dm
  State configuration: Blocked during specific time ranges
    Time ranges:
      t1
      t2
    Online-user logoff: Enabled
  Login   authentication scheme:  RADIUS=rad
  Login   authorization  scheme:  HWTACACS=hw
  Super   authentication scheme:  RADIUS=rad
  PPP     accounting     scheme:  RADIUS=r1, (RADIUS=r2), HWTACACS=tc, Local
  Command authorization  scheme:  HWTACACS=hw
  LAN access authentication scheme:  RADIUS=r4
  Portal  authentication scheme:  LDAP=ldp
  IPoE    authentication scheme:  RADIUS=rad, Local, None
  SSL VPN authentication scheme:  LDAP=ldp, Local, None
  SSL VPN authorization  scheme:  LDAP=ldp, Local
  SSL VPN accounting     scheme:  None
  Default authentication scheme:  LDAP=rad, Local, None
  Default accounting     scheme:  None
  Accounting quota out policy: Redirect
    Redirect URL   : http://3.3.3.3/web
    Stop accounting: Yes
    User profile   : abc
  ITA service policy: ita1
  Service type: HSI
  Session time: Include idle time
  User basic service IP type: IPv4 IPv6 IPv6-PD
  Accounting start delay: 60 seconds
  NAS-ID: test
  Web server URL              : http://1.2.3.4
  Web server URL parameters   : userurl=http://www.test.com/welcome
                                userip=source-address
                                usermac=source-mac (format: XXXX-XXXX-XXXX)
  Web server IPv4 address     : 1.2.3.4
  Temporary redirect          : Enabled
    Idle cut : Enabled
      Idle timeout: 2 minutes
      Flow: 10240 bytes
      Traffic direction: Both
    IP pool: appy
    User profile: test
    Session group profile: abc
    Inbound CAR: CIR 64000 bps PIR 640000 bps
    Outbound CAR: CIR 64000 bps PIR 640000 bps
    ACL number: 3000
    User group: ugg
    IPv6 prefix: 1::1/34
    IPv6 pool: ipv6pool
    IPv6 ND prefix pool: rnd
    IPv6 ND prefix pool group: rndg
    Primary DNS server: 6.6.6.6
    Secondary DNS server: 3.6.2.3
    URL: http://abc
    Redirect limit: 5
    VPN instance: vpn1
    IGMP access limit: 12
    MLD access limit: 35
    User session timeout: 28 seconds
    High threshold: 70%
    Low threshold: 10%
    High threshold: 70%
    Low threshold: 10%
  Authorization attributes specific to none authentication:
Default domain name: system
# Display the configuration of ISP domain test and load-sharing user group information in the domain.
<Sysname> display domain bbb
Domain: test
  Service type: HSI
  NAS-ID: N/A
  L2TP-user RADIUS-force      : Enabled
    Idle cut: Disabled
    MLD access limit: 4
    Low threshold: 10%
  Load-sharing user groups:
    g1: 323 user(s)
    g2: 324 user(s)
Table 5 Command output
Domain
ISP domain name.
Current state
Current state of the ISP domain:
·         Blocked.
·         Active.
State configuration
State settings of the ISP domain:
·         Active—The ISP domain is set to the active state.
·         Blocked during specific time ranges—The ISP domain is set to the blocked state during the listed time ranges.
·         Blocked—The ISP domain is set to the blocked state.
Time ranges
Time ranges during which the ISP domain is in blocked state.
Online-user logoff
Status for the feature of logging off online users when the state of the ISP domain changes to blocked:
·         Enabled.
·         Disabled.
Default authentication methods.
Default authorization methods.
Default accounting methods.
ADVPN authentication scheme
Authentication methods for ADVPN users.
ADVPN authorization scheme
Authorization methods for ADVPN users.
ADVPN accounting scheme
Accounting methods for ADVPN users.
Authentication methods for login users.
Authorization methods for login users.
Login accounting scheme
Accounting methods for login users.
Authentication methods for obtaining another user role without reconnecting to the device.
PPP authentication scheme
Authentication methods for PPP users.
PPP authorization scheme
Authorization methods for PPP users.
Accounting methods for PPP users.
Command line authorization methods.
Command accounting scheme
Command line accounting method.
Authentication methods for LAN users.
LAN access authorization scheme
Authorization methods for LAN users.
LAN access accounting scheme
Accounting methods for LAN users.
Authentication methods for portal users.
Portal authorization scheme
Authorization methods for portal users.
Portal accounting scheme
Accounting methods for portal users.
IKE authentication scheme
IKE extended authentication methods.
IKE authorization scheme
Authorization methods for IKE extended authentication.
Authentication methods for IPoE users.
IPoE authorization scheme
Authorization methods for IPoE users.
IPoE accounting scheme
Accounting methods for IPoE users.
Authentication methods for SSL VPN users.
Authorization methods for SSL VPN users.
Accounting methods for SSL VPN users.
RADIUS
RADIUS scheme.
HWTACACS
HWTACACS scheme.
LDAP
LDAP scheme.
Local
Local scheme.
None
No authentication, no authorization, or no accounting.
Access control for users that encounter accounting-start failures:
·         Online—Allows the users to stay online.
·         Offline—Logs off the users.
Accounting update failure max-times
Maximum number of consecutive accounting-update failures allowed by the device for each user in the domain.
Access control for users that have failed all their accounting-update attempts:
Access control for users that have used up their accounting quotas:
·         Redirect—Redirects the users to the specified URL.
Redirect URL
URL to which users are redirected when the users have used up their data quotas.
Stop accounting
Whether to send stop-accounting packets for users that have used up their data quotas.
User profile
Name of the user profile assigned to users that have used up their data quotas.
Whether to send accounting-update packets to refresh users' data quotas:
·         Yes.
·         No.
ITA service policy
ITA policy applied to the ISP domain.
Service type
Service type of the ISP domain, including HSI, STB, and VoIP.
Session time
Online duration sent to the server for users that went offline due to connection failure or malfunction:
·         Include idle time—The online duration includes the idle timeout period.
·         Exclude idle time—The online duration does not include the idle timeout period.
User address type
Type of IP addresses for users in the ISP domain.
This field is not displayed if no user address type is specified for the ISP domain.
Types of IP addresses that PPPoE and L2TP users rely on to use the basic services:
·         IPv4.
·         IPv6.
·         IPv6-PD.
IPv6 address wait timer (in seconds) that starts after IPv6CP negotiation for PPPoE and L2TP users.
Start-accounting delay. This field is not displayed if no start-accounting delay is set.
Accounting method for dual-stack users:
·         Merge—Merges IPv4 data with IPv6 data for accounting.
·         Separate—Separates IPv4 data from IPv6 data for accounting.
NAS-ID
NAS-ID of the device.
This field displays N/A if no NAS-ID is set in the ISP domain.
Rate limit mode for EDSG services:
·         Merge—In-band mode. In this mode, the device limits the overall rates of both EDSG traffic and non-EDSG traffic for a user within the available basic bandwidth of the user.
·         Separate—Out-band mode. In this mode, the device limits the rate of EDSG traffic for a user within the independent EDSG bandwidth of the user. The bandwidth for the non-EDSG traffic is not affected.
Web server URL
URL of the Web server.
Parameters added to the URL of the Web server.
format
Format of the MAC address added to the URL of the Web server:
·         XXXXXXXXXXXX (or xxxxxxxxxxxx)—The MAC address is in the one-section format.
·         XXXX-XXXX-XXXX (or xxxx-xxxx-xxxx)—The MAC address is in the three-section format.
·         XX-XX-XX-XX-XX-XX (or xx-xx-xx-xx-xx-xx)—The MAC address is in the six-section format.
The delimiter in the three-section format and the six-section format is configurable.
IPv4 address of the Web server.
IPv6 address of the Web server.
Active period (in seconds) during which all Web visit requests of a user are redirected to the redirect URL.
IPv4 address of the redirect server.
IPv6 address of the redirect server.
Temporary redirect
Status of the temporary redirect feature.
Status of the forcible use of RADIUS server-authorized L2TP attributes.
·         Enabled—The device decides whether to process a PPP user as an L2TP user based only on the L2TP attributes assigned by the RADIUS server.
·         Disabled—The device decides whether to process a PPP user as an L2TP user based on the local L2TP configuration or the L2TP attributes assigned by the RADIUS server.
Authorization attributes for users in the ISP domain.
Idle cut
Idle cut feature status:
·         Enabled—The feature is enabled. The device logs off users that do not meet the minimum traffic requirements in an idle timeout period.
·         Disabled—The feature is disabled. It is the default idle cut state.
Idle timeout
Idle timeout period, in minutes.
Flow
Minimum traffic that a login user must generate in an idle timeout period, in bytes.
Traffic direction
Traffic direction for the idle cut feature:
·         Both.
·         Inbound.
·         Outbound.
IP pool
Name of the authorization IPv4 address pool.
IP pool group
Name of the authorization IPv4 address pool group.
User profile
Name of the authorization user profile.
Name of the authorization session group profile.
Inbound CAR
Authorization inbound CAR:
·         CIR—Committed information rate in bps.
·         PIR—Peak information rate in bps.
If no inbound CAR is authorized, this field displays N/A.
Outbound CAR
Authorization outbound CAR:
If no outbound CAR is authorized, this field displays N/A.
ACL number
Authorization ACL for users.
User group
Authorization user group for users.
IPv6 prefix
Authorization IPv6 address prefix for users.
IPv6 pool
Name of the authorization IPv6 address pool for users.
IPv6 pool group
Name of the authorization IPv6 address pool group for users.
IPv6 ND prefix pool
Name of the authorization ND prefix pool for users.
Name of the authorization ND prefix pool group for users.
Primary DNS server
IPv4 address of the authorization primary DNS server for users.
IPv4 address of the authorization secondary DNS server for users.
Primary DNSV6 server
IPv6 address of the authorization primary DNS server for users.
Secondary DNSV6 server
IPv6 address of the authorization secondary DNS server for users.
URL
Authorization redirect URL for users.
Redirect limit
Maximum number of times the device redirects the Web visit requests of a user to the redirect URL.
If no limit is set, this field displays Unlimited.
VPN instance
Name of the authorization VPN instance for users.
IGMP access limit
Maximum number of IGMP groups that an IPv4 user is authorized to join concurrently.
MLD access limit
Maximum number of MLD groups that an IPv6 user is authorized to join concurrently.
Inbound user priority
Authorization user priority for users' upstream packets.
Outbound user priority
Authorization user priority for users' downstream packets.
Authorization session timeout time for users, in seconds.
Alarm thresholds for authorization IPv4 address usage.
Alarm thresholds for authorization IPv6 address or prefix usage.
High threshold
High alarm threshold for authorization IPv4 address usage or authorization IPv6 address or prefix usage. This field displays Not configured if the high alarm threshold is not set.
Low threshold
Low alarm threshold for authorization IPv4 address usage or authorization IPv6 address or prefix usage. This field displays Not configured if the low alarm threshold is not set.
Load-sharing user groups and the number of users in each group.
User group and NAT instance bindings
Load-sharing user groups, the number of users in each group, and the NAT instance to which each load-sharing user group is bound.
Authorization attributes for none-authentication users.
display domain access-user statistics
Use display domain access-user statistics to display statistics for online access users in ISP domains.
display domain [ isp-name ] access-user statistics
isp-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. If you do not specify an ISP domain, this command displays online access user statistics for all ISP domains.
This command displays detailed statistics only for online IPoE and PPP users in the current software version. Statistics for portal users are counted in the Others category.
For this command to display statistics for PPP users, you must enable PPP accounting by using the ppp account-statistics enable command.
If users have value-added services (such as EDSG and ITA services), the system independently identifies and performs AAA on the value-added service sessions. This command does not count the value-added service sessions in the number of users.
# Display online access user statistics for all ISP domains.
<Sysname> display domain access-user statistics
Total online access users: 10
   PPP users: 6
   Others: 4
Total domains: 3
Domain                 State             Online user count
system                 Active            10
isp1                   Active            0
isp2                   Active            0
Domain: system
    PPP users: 6 (PPPoE 4, PPPoFR 0, LAC 0, LNS 2)
    Others: 4
# Display online access user statistics for ISP domain isp2.
<Sysname> display domain isp2 access-user statistics
Domain: isp2
  Online user count: 5
    PPP users: 5
    Others: 0
Table 6 Command output
Domain
Name of the ISP domain.
·         Blocked.
·         Active.
Online user count
Total number of online access users.
IPoE users
Type of IPoE users:
·         Bind—IPoE bind authentication users.
·         Web—IPoE Web authentication users.
·         Leased—IPoE leased users.
PPP users
Type of PPP users:
·         PPPoE—PPPoE users.
·         PPPoFR—PPPoFR users.
·         LAC—L2TP users on the LAC.
·         LNS—L2TP users on the LNS.
Others
Total number of online access users other than IPoE and PPP users.
display max-user history
Use display max-user history to display history peak statistics of users.
In standalone mode:
display max-user history [ slot slot-number ]
In IRF mode:
display max-user history [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays history peak statistics of users for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays history peak statistics of users for all cards. (In IRF mode.)
The history peak statistics of users include the following information:
·          Peak values of concurrent authenticated users, concurrent online users, concurrent user sessions that have been issued to the driver, and concurrent users in accounting.
·          The time when each peak value is reached.
This command might fail to display history peak statistics for an access module if the access module is busy. You can re-execute this command later.
This command displays history peak statistics only for PPPoE and IPoE users. The system does not count IPoE Web users at the preauthentication stage into history peak statistics.
The system counts a user that is authenticated on a logical interface (such as an aggregate interface) as follows:
·          For the peak value of concurrent driver sessions, the user is counted for each slot that has a member interface of the logical interface.
·          For the other peak values, the user is counted only for the slot that has the physical interface through which the user accesses the network.
# Display history peak statistics of users for a slot.
<Sysname> display max-user history slot 3
Slot 3:
Max concurrent authenticated PPPoE users: 5000 Time: 2019-04-20 15:51:09
Max concurrent online PPPoE users: 5000 Time: 2019-04-20 15:51:09
Max concurrent PPPoE driver sessions: 5000 Time: 2019-04-20 15:51:09
Max concurrent PPPoE users in accounting: 5000 Time: 2019-04-20 15:51:09
Max concurrent authenticated IPoE users: 15000 Time: 2019-04-20 16:00:43
Max concurrent online IPoE users: 15000 Time: 2019-04-20 16:00:43
Max concurrent IPoE driver sessions: 10908 Time: 2019-04-19 18:59:14
Max concurrent IPoE users in accounting: 10908 Time: 2019-04-19 18:59:14
Table 7 Command output
Max concurrent authenticated xxx users
Peak value of concurrent xxx users that have initiated authentication since the system started up, where xxx represents the type of users.
This field is not displayed if the maximum number is 0.
Max concurrent online xxx users
Peak value of concurrent online xxx users since the system started up, where xxx represents the type of users.
Max concurrent xxx driver sessions
Peak value of concurrent xxx sessions that have been issued to the driver since the system started up, where xxx represents the type of users.
Max concurrent xxx users in accounting
Peak value of concurrent xxx users that are in accounting since the system started up, where xxx represents the type of users.
Time
Time when the peak value is reached.
domain
Use domain to create an ISP domain and enter its view, or enter the view of an existing ISP domain.
Use undo domain to delete an ISP domain.
domain name isp-name
undo domain name isp-name
A system-defined ISP domain exists. The domain name is system.
name isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
All ISP domains are in active state when they are created.
You can modify settings for the system-defined ISP domain system, but you cannot delete this domain.
An ISP domain cannot be deleted when it is the default ISP domain. Before you use the undo domain command, change the domain to a non-default ISP domain by using the undo domain default enable command.
To avoid RADIUS authentication, authorization, or accounting failures, use short domain names to ensure that usernames containing a domain name do not exceed 253 characters.
# Create an ISP domain named test and enter ISP domain view.
[Sysname-isp-test]
display domain
domain if-unknown
state (ISP domain view)
Use domain default enable to specify the default ISP domain. Users without any domain name included in the usernames are considered in the default domain.
Use undo domain default enable to restore the default.
domain default enable isp-name
The default ISP domain is the system-defined ISP domain system.
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The ISP domain must already exist.
The system has only one default ISP domain.
# Create an ISP domain named test, and configure the domain as the default ISP domain.
[Sysname-isp-test] quit
[Sysname] domain default enable test
display domain
domain
domain if-unknown
Use domain if-unknown to specify an ISP domain that accommodates users that are assigned to nonexistent domains.
Use undo domain if-unknown to restore the default.
domain if-unknown isp-name
No ISP domain is specified to accommodate users that are assigned to nonexistent domains.
The device chooses an authentication domain for each user in the following order:
1.        The authentication domain specified for the access module. (Support for the authentication domain configuration depends on the access module.)
2.        The ISP domain in the username.
3.        The default ISP domain of the device.
If the chosen domain does not exist on the device, the device searches for the ISP domain to accommodate users that are assigned to nonexistent domains. If no such ISP domain is configured, user authentication fails.
# Specify ISP domain test to accommodate users that are assigned to nonexistent domains.
[Sysname] domain if-unknown test
display domain
ip-usage-warning
Use ip-usage-warning to set the alarm thresholds for authorization IPv4 address usage.
Use undo ip-usage-warning to cancel an alarm threshold setting for authorization IPv4 address usage.
ip-usage-warning { high-threshold high-value | low-threshold low-value }
undo ip-usage-warning { high-threshold | low-threshold }
No alarm thresholds are set for authorization IPv4 address usage. The system does not generate alarm notifications about authorization IPv4 address usage.
ISP domain view
high-threshold high-value: Specifies the high alarm threshold for authorization IPv4 address usage, in percentage. The value range for the high-value argument is 1 to 100. The default is 100. The high alarm threshold must be greater than the low alarm threshold.
low-threshold low-value: Specifies the low alarm threshold for authorization IPv4 address usage, in percentage. The value range for the low-value argument is 0 to 99. The default is 0.
Authorization IPv4 address usage refers to the usage of IPv4 addresses in the authorization IPv4 address pool or pool group. The IPv4 addresses are allocated by DHCP.
You can monitor authorization IPv4 address usage on an ISP domain basis if you have configured one of the following IPv4 address-related authorization attributes for ISP domains:
·          Authorization IPv4 address pool configured by using the authorization-attribute ip-pool command.
·          Authorization IPv4 address pool group configured by using the authorization-attribute ip-pool-group command.
To implement ISP domain-based authorization IPv4 address usage monitoring, you must enable SNMP notifications for authorization IPv4 address usage and set the alarm thresholds in the ISP domains.
Based on the IPv4 address usage periodically provided by the DHCP module, the device generates notifications and logs as shown in Table 8.
Table 8 Authorization IPv4 address usage alarm notifications and alarm-removed notifications
Notification
Triggering condition
Remarks
Low alarm notification
Authorization IPv4 address usage reaches or drops below the low alarm threshold for the first time.
After generating and sending a low alarm notification, the system typically does not generate or send any additional low alarm notifications until the first low alarm is removed.
Low alarm-removed notification
Authorization IPv4 address usage reaches or exceeds the value calculated by using the following formula: Low alarm threshold + (high alarm threshold – low alarm threshold)*10%.
If you cancel the low alarm threshold setting when the system is still in low alarm state, the system will automatically generate and send a notification to remove the low alarm.
High alarm notification
Authorization IPv4 address usage reaches or exceeds the high alarm threshold for the first time.
After generating and sending a high alarm notification, the system typically does not generate or send any additional high alarm notifications until the first high alarm is removed.
High alarm-removed notification
Authorization IPv4 address usage drops below or reaches the value calculated by using the following formula: High alarm threshold – (high alarm threshold – low alarm threshold)*10%.
If you cancel the high alarm threshold setting when the system is still in high alarm state, the system will automatically generate and send a notification to remove the high alarm.
If you change one of the following settings, the system determines whether to generate one notification only based on the new settings regardless of whether another notification of the same type has been generated:
·          An alarm threshold setting for authorization IPv4 address usage in the ISP domain.
·          The authorization IPv4 address pool or pool group specified for the ISP domain.
·          The configuration in the authorization IPv4 address pool or IPv4 address pool group of the ISP domain.
To enable SNMP notifications for authorization IPv4 address usage in ISP domains, use the snmp-agent trap enable domain ip-pool-warning command.
# In ISP domain test, set the high alarm threshold and low alarm threshold for authorization IPv4 address usage to 70% and 20%, respectively.
[Sysname-isp-test] ip-usage-warning high-threshold 70
[Sysname-isp-test] ip-usage-warning low-threshold 20
authorization-attribute (ISP domain view)
display domain
ipv6-usage-warning
Use ipv6-usage-warning to set the alarm thresholds for authorization IPv6 address or prefix usage.
Use undo ipv6-usage-warning to cancel an alarm threshold setting for authorization IPv6 address or prefix usage.
ipv6-usage-warning { high-threshold high-value | low-threshold low-value }
undo ipv6-usage-warning { high-threshold | low-threshold }
No alarm thresholds are set for authorization IPv6 address or prefix usage. The system does not generate alarm notifications about authorization IPv6 address or prefix usage.
ISP domain view
high-threshold high-value: Specifies the high alarm threshold for authorization IPv6 address or prefix usage, in percentage. The value range for the high-value argument is 1 to 100. The default value is 100. The high alarm threshold must be greater than the low alarm threshold.
low-threshold low-value: Specifies the low alarm threshold for authorization IPv6 address or prefix usage, in percentage. The value range for the low-value argument is 0 to 99. The default value is 0.
Authorization IPv6 address or prefix usage refers to the usage of IPv6 addresses or prefixes in the authorization IPv6 address pool or pool group or in the authorization ND prefix pool or pool group.
You can monitor authorization IPv6 address or prefix usage on an ISP domain basis if you have configured one of the following IPv6 address or prefix-related authorization attributes for ISP domains:
·          Authorization IPv6 address pool configured by using the authorization-attribute ipv6-pool command.
·          Authorization ND prefix pool configured by using the authorization-attribute ipv6-nd-prefix-pool command.
·          Authorization IPv6 address pool group configured by using the authorization-attribute ipv6-pool-group command.
·          Authorization ND prefix pool group configured by using the authorization-attribute ipv6-nd-prefix-pool-group command.
To implement ISP domain-based authorization IPv6 address or prefix usage monitoring, you must enable SNMP notifications for authorization IPv6 address or prefix usage and set the alarm thresholds in the ISP domains.
Based on the IPv6 address or prefix usage periodically provided by the DHCPv6 module, the device generates notifications and logs as shown in Table 9.
Table 9 Authorization IPv6 address or prefix usage alarm notifications and alarm-removed notifications
Notification
Remarks
Authorization IPv6 address or prefix usage reaches or drops below the low alarm threshold for the first time.
Authorization IPv6 address or prefix usage reaches or exceeds the value calculated by using the following formula: Low alarm threshold + (high alarm threshold – low alarm threshold)*10%.
Authorization IPv6 address or prefix usage reaches or exceeds the high alarm threshold for the first time.
Authorization IPv6 address or prefix usage drops below or reaches the value calculated by using the following formula: High alarm threshold – (high alarm threshold – low alarm threshold)*10%.
·          An alarm threshold setting for authorization IPv6 address or prefix usage in the ISP domain.
·          The authorization IPv6 address pool, IPv6 address pool group, ND prefix pool, or ND prefix pool group specified for the ISP domain.
·          The configuration in the authorization IPv6 address pool, authorization IPv6 address pool group, authorization ND prefix pool, or authorization ND prefix pool group of the ISP domain.
To enable SNMP notifications for authorization IPv6 address or prefix usage in ISP domains, use the snmp-agent trap enable domain ipv6-pool-warning command.
# In ISP domain test, set the high alarm threshold and low alarm threshold for authorization IPv6 address or prefix usage to 70% and 20%, respectively.
[Sysname-isp-test] ipv6-usage-warning high-threshold 70
[Sysname-isp-test] ipv6-usage-warning low-threshold 20
display domain
ita-policy
Use ita-policy to apply an ITA policy to users in an ISP domain.
Use undo ita-policy to restore the default.
ita-policy policy-name
undo ita-policy
No ITA policy is applied in an ISP domain.
ISP domain view
policy-name: Specifies an ITA policy by its name, a case-insensitive string of 1 to 31 characters.
This feature is supported only on CSPEX (except CSPEX-1104-E) cards.
The ITA policy assigned from a RADIUS server takes precedence over the ITA policy in an ISP domain. If an ISP domain user has been assigned an ITA policy from the RADIUS server, the ITA policy of the ISP domain does not take effect. The server-assigned ITA policy might not even exist on the device.
If the RADIUS server assigns only EDSG service policies but no ITA policy to a user, the ITA policy applied to the user's ISP domain does not take effect on that user.
# Apply ITA policy ita1 to users in ISP domain test.
[Sysname-isp-test] ita-policy ita1
ita policy
l2tp-user radius-force
Use l2tp-user radius-force to enable the forcible use of RADIUS server-authorized L2TP attributes.
Use undo l2tp-user radius-force to disable the forcible use of RADIUS server-authorized L2TP attributes.
The forcible use of RADIUS server-authorized L2TP attributes is disabled.
ISP domain view
This command is applicable only to PPP users.
Typically, whether the device processes an authenticated PPP user as an L2TP user depends on the local L2TP configuration or the L2TP attributes that the RADIUS server assigns to the user. The server-assigned L2TP attributes take precedence over the L2TP configuration on the device.
Execute this command so the device decides whether to process a PPP user as an L2TP user only based on the server-assigned L2TP attributes.
·          If the RADIUS server assigns the L2TP tunnel type to a PPP user through attribute 64, the device processes the PPP user as an L2TP user.
·          If the RADIUS server does not assign the L2TP tunnel type to a PPP user through attribute 64, the device processes the PPP user as a common PPP user.
# In ISP domain test, enable the forcible use of RADIUS server-authorized L2TP attributes.
[Sysname-isp-test] l2tp-user radius-force
display domain
load-sharing user-group
Use load-sharing user-group to configure a load-sharing user group.
Use undo load-sharing user-group to delete a load-sharing user group.
load-sharing user-group group-name
undo load-sharing user-group [ group-name ]
No load-sharing user groups are configured and the load sharing feature for users is disabled in an ISP domain.
ISP domain view
group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters. You must specify an existing user group. If you do not specify a user group in the undo form of this command, all load-sharing user groups are deleted.
Use load-sharing user groups with service features to implement load sharing for user service traffic.
If load-sharing user groups are used in conjunction with NAT, they are applicable only to interface-based NAT.
If you configure a load-sharing user group in an ISP domain, the load sharing feature for users is enabled for the ISP domain. You can configure a maximum of 32 load-sharing user groups in an ISP domain. After a user in the ISP domain comes online, the device assigns the user to the load-sharing user group that has the smallest number of users. If multiple load-sharing user groups have the same smallest number of users, the user is assigned to the earliest configured group.
The user group to which the device finally assigns a user depends on the configuration. The device selects the user group to accommodate a user in an ISP domain in the following order:
1.        The user group authorized by the server.
2.        The load-sharing user group configured in the ISP domain.
3.        The authorization user group specified in the ISP domain.
The load-sharing user-group and user-group bind nat-instance commands are mutually exclusive in an ISP domain. Before you use the load-sharing user-group command, remove the configuration of the user-group bind nat-instance command. In addition, make sure the ISP domain does not have users that came online before the user-group bind nat-instance command configuration is removed.
# In ISP domain test, configure load-sharing user groups g1 and g2.
[Sysname-isp-test] load-sharing user-group g1
[Sysname-isp-test] load-sharing user-group g2
display domain
user-group
nas-id
Use nas-id to set the NAS-ID in an ISP domain.
Use undo nas-id to delete the NAS-ID from an ISP domain.
nas-id nas-identifier
undo nas-id
No NAS-ID is set in an ISP domain.
ISP domain view
nas-identifier: Specifies a NAS-ID, a case-sensitive string of 1 to 253 characters.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
You can configure a NAS-ID in NAS-ID profile view, in interface view, or in ISP domain view. The device selects the NAS-ID for the NAS-Identifier attribute in the following order:
1.        NAS-ID bound with VLANs in a NAS-ID profile.
2.        NAS-ID on an interface.
3.        NAS-ID in an ISP domain.
If no NAS-ID is selected, the device uses the device name as the NAS-ID.
The NAS-ID on an interface is applicable only to PPP, portal, and IPoE users that access the network through the interface.
# Set the NAS-ID to test for ISP domain test.
[Sysname-isp-test] nas-id test
aaa nas-id
aaa nas-id profile
nas-id bind
Use nas-id bind to configure a NAS-ID and VLAN binding.
Use undo nas-id bind to remove a NAS-ID and VLAN binding.
nas-id nas-identifier bind { { c-vid vlan-id | s-vid vlan-id } * | vlan vlan-id }
undo nas-id nas-identifier bind { { c-vid vlan-id | s-vid vlan-id } * | vlan vlan-id }
No NAS-ID and VLAN bindings exist.
NAS-ID profile view
nas-identifier: Specifies a NAS-ID, a case-sensitive string of 1 to 31 characters.
c-vid vlan-id: Specifies an inner VLAN ID in the range of 1 to 4094.
s-vid vlan-id: Specifies an outer VLAN ID in the range of 1 to 4094.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
You can configure multiple NAS-ID and VLAN bindings in a NAS-ID profile.
In a QinQ network, specify an inner VLAN ID, outer VLAN ID, or both in a binding as a best practice. In a non-QinQ network, you can specify only a VLAN ID in a binding by specifying the vlan vlan-id option.
If you specify an inner VLAN ID or outer VLAN ID in a binding of a NAS-ID profile, you can specify this profile only for an interface by using the aaa nas-id-profile command.
A NAS-ID can be bound with more than one VLAN or one combination of inner VLAN and outer VLAN. A VLAN or a combination of inner VLAN and outer VLAN can be bound with only one NAS-ID. If you configure multiple bindings for the same VLAN, the most recent configuration takes effect.
The device selects a NAS-ID and VLAN binding for double-tagged packets in the following order:
1.        NAS-ID with both matching outer VLAN ID and inner VLAN ID.
2.        NAS-ID with a matching outer VLAN ID.
3.        NAS-ID with a matching inner VLAN ID.
# Bind NAS-ID 222 with VLAN 2 in NAS-ID profile aaa.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa] nas-id 222 bind vlan 2
aaa nas-id profile
redirect active-time
Use redirect active-time to set the redirect URL active period during which all Web visit requests of a user are redirected to the redirect URL.
Use undo redirect active-time to restore the default.
redirect active-time time
The redirect URL active period is not set.
ISP domain view
time: Sets the active period, in the range of 1 to 900 seconds.
If the server assigns a redirect URL to a user after it passes authentication, the device redirects the user to the redirect URL when the user accesses the network for the first time. The redirect URL might provide important information for the user (for example, advertisements, notices, and charge overdue notifications).
Some applications (for example, input software) initiate background Web visit requests to visit the network before the user actively accesses the network. As a result, the device might not redirect the active Web visit requests of the user to the redirect URL because the number of times that the device redirects the background requests has reached the maximum number of redirect times. In this case, the user does not obtain the information provided by the redirect URL.
To resolve this issue, use this command to set the redirect URL active period. In this period, all Web visit requests of a user are redirected to the redirect URL. The period starts for a user when the device redirects the first Web visit request of the user to the redirect URL.
This command takes effect only on PPP and IPoE users.
This command takes effect on a user only when the server assigns the user a redirect URL and the attribute that sets the number of redirect times.
This command has higher priority than the maximum number of redirect times configured by using the authorization-attribute redirect-times command in ISP domain view. If limiting the maximum number of redirect times is required, do not use this command to set the active period.
# In ISP domain test, set the active period of the redirect URL to 60 seconds.
[Sysname] domain name test
[Sysname-isp-test] redirect active-time 60
display domain
redirect server
redirect move-temporarily enable
Use redirect move-temporarily enable to enable the temporary redirect feature.
Use undo redirect move-temporarily enable to disable the temporary redirect feature.
The temporary redirect feature is disabled.
ISP domain view
Typically, the device carries the redirect URL coded in JavaScript in HTTP or HTTPS responses sent to users. The users obtain the redirect URL by parsing the JavaScript codes. If the endpoint of a user (application, for example) does not support JavaScript, the user will fail to be redirected.
To resolve this issue, enable the temporary redirect feature. This feature enables the device to send HTTP or HTTPS responses with status code 302 to users so that the users can obtain the redirect URL.
This feature is applicable only to PPP and IPoE users.
On a forwarding-control separated network, this feature does not take effect.
# In ISP domain test, enable the temporary redirect feature.
[Sysname-isp-test] redirect move-temporarily enable
display domain
redirect server
Use redirect server to specify an IP address of the Web server that owns the redirect URL.
Use undo redirect server to remove an IP address of the Web server that owns the redirect URL.
redirect server { ip ipv4-address | ipv6 ipv6-address }
undo redirect server { ip | ipv6 }
No redirect server IP address is specified.
ISP domain view
ip ipv4-address: Specifies the IPv4 address of the redirect server.
ipv6 ipv6-address: Specifies the IPv6 address of the redirect server.
To improve the efficiency and accuracy of Web redirections, use this command to specify an IP address of the Web server that owns the redirect URL. When the device redirects a Web visit request of a user, it first identifies whether the destination IP address of the request is the specified IP address of the Web server. If the IP addresses are the same one, the device allows the request to pass through. If the IP addresses are different, the device pushes the redirect URL assigned by the server to the user.
·          If the redirect URL does not contain a redirect server IP address, the device uses the IP address specified by using this command as the redirect destination IP address. Make sure the specified IP address is the same as the IP address resolved from the URL.
·          If the redirect URL contains a redirect server IP address but the IP address is different from the IP address specified by using this command, the device uses the IP address specified by using this command as the redirect destination IP address.
·          If the redirect URL does not contain a redirect server IP address and no redirect server IP address is specified, redirection might fail due to lack of redirect server IP address.
In an ISP domain, you can specify only one IPv4 address and one IPv6 address of the Web redirect server.
# In ISP domain test, specify the server at 5.1.1.1 as the redirect server.
[Sysname-isp-test] redirect server ip 5.1.1.1
display domain
redirect aging-time
Use reset aaa abnormal-offline-record to clear all user abnormal offline records.
The device saves user abnormal offline records in memory and does not automatically clear the records unless the active MPU reboots. To prevent the records from overusing the memory, use this command to clear all user abnormal offline records.
Use this command with caution. Cleared records cannot be recovered.
# Clear all user abnormal offline records.
<Sysname> reset aaa abnormal-offline-record
Use reset aaa normal-offline-record to clear all user normal offline records.
The device saves user normal offline records in memory and does not automatically clear the records unless the active MPU reboots. To prevent the records from overusing the memory, use this command to clear all user normal offline records.
# Clear all user normal offline records.
<Sysname> reset aaa normal-offline-record
Use reset aaa offline-record to clear all user offline records.
The device saves user offline records in memory and does not automatically clear the records unless the active MPU reboots. To prevent the records from overusing the memory, use this command to clear all user offline records.
# Clear all user offline records.
<Sysname> reset aaa offline-record
Use reset aaa online-fail-record to clear all user online failure records.
The device saves user online failure records in memory and does not automatically clear the records unless the active MPU reboots. To prevent the records from overusing the memory, use this command to clear all user online failure records.
# Clear all user online failure records.
<Sysname> reset aaa online-fail-record
service rate-limit mode (ISP domain view)
Use service rate-limit mode to set the rate limit mode for EDSG services.
Use undo service rate-limit mode to restore the default.
service rate-limit mode { merge | separate }
The out-band mode is used for EDSG services. The rate of EDSG traffic is limited within an independent bandwidth, and the bandwidth for the non-EDSG traffic is not affected.
ISP domain view
merge: Specifies the in-band mode. In this mode, the device limits the overall rates of both EDSG traffic and non-EDSG traffic for a user within the available basic bandwidth of the user. The bandwidth for the EDSG traffic is preferentially guaranteed.
separate: Specifies the out-band mode. In this mode, the device limits the rate of EDSG traffic within an independent bandwidth. The bandwidth for the non-EDSG traffic is not affected.
Assume that the available basic bandwidth for a user is 20 Mb and the available bandwidth for EDSG traffic of the user is 12 Mb.
·          In in-band mode, the EDSG bandwidth is excluded from the basic bandwidth. The actual bandwidth for the user is 32 Mb, in which 12 Mb is exclusively used for EDSG services.
·          In out-band mode, the EDSG bandwidth is included in the basic bandwidth. The actual bandwidth for the user is 20 Mb, in which 12 Mb is exclusively used for EDSG services, and the remaining 8 Mb is used for non-EDSG services.
The rate limit mode set in EDSG service policy view takes precedence over the rate limit mode set in ISP domain view.
# In ISP domain test, set the rate limit mode for EDSG services to in-band mode.
[Sysname-isp-test] service rate-limit mode merge
service policy
service rate-limit mode (EDSG service policy view)
service-type (ISP domain view)
Use service-type to specify the service type for users in an ISP domain.
Use undo service-type to restore the default.
service-type { hsi | stb | voip }
undo service-type
The service type is hsi for users in an ISP domain.
ISP domain view
hsi: Specifies the High Speed Internet (HSI) service. This service is applicable to users that access the network through 802.1X, PPP, and IPoE.
stb: Specifies the Set Top Box (STB) service. This service is applicable to users that access the network through STB.
voip: Specifies the Voice over IP (VoIP) service. This service is applicable to users that access the network through IP phones.
When the HSI service is specified, the multicast feature of the access module is disabled to save system resources.
When the STB service is specified, the multicast feature of the access module is enabled to improve the performance of the multicast module.
When the VoIP service is specified, the QoS module increases the priority of voice traffic to reduce the transmission delay for IP phone users.
For PPP (except PPPoE) users, IPoE leased line users, and 802.1X users, the system uses the HSI service forcibly even if the STB or VoIP service is specified.
You can configure only one service type for an ISP domain.
# Specify the STB service for users in ISP domain test.
[Sysname-isp-test] service-type stb
session-time include-idle-time
Use session-time include-idle-time to configure the device to include the idle timeout period in the user online duration sent to the server.
Use undo session-time include-idle-time to restore the default.
The device excludes the idle timeout period from the user online duration sent to the server.
ISP domain view
Whether to configure the device to include the idle timeout period in the user online duration sent to the server, depending on the accounting policy in your network. Typically, the idle timeout period is assigned by the authorization server after users pass authentication. For portal users, the idle timeout period set for the online portal user detection feature takes priority over the server-assigned idle timeout period. For more information about online detection for portal users, see portal authentication configuration in BRAS Services Configuration Guide.
If the user goes offline due to connection failure or malfunction, the user online duration sent to the server is not the same as the actual online duration.
·          If the session-time include-idle-time command is used, the device adds the idle timeout period. The online duration sent to the server is longer than the actual online duration of the user.
·          If the undo session-time include-idle-time command is used, the device excludes the idle timeout period from the actual online duration. The online duration sent to the server is shorter than the actual online duration of the user.
# Configure the device to include the idle timeout period in the online duration sent to the server for users in ISP domain test.
[Sysname-isp-test] session-time include-idle-time
display domain
Use snmp-agent trap enable domain to enable SNMP notifications for ISP domains.
Use undo snmp-agent trap enable domain to disable SNMP notifications for ISP domains.
snmp-agent trap enable domain { ip-usage-warning | ipv6-usage-warning }
undo snmp-agent trap enable domain { ip-usage-warning | ipv6-usage-warning }
SNMP notifications are disabled for ISP domains.
ip-usage-warning: Enables SNMP notifications for authorization IPv4 address usage. The device generates a notification when the IPv4 address usage reaches or exceeds the high alarm threshold, drops below or reaches the low alarm threshold, or restores to the normal range.
ipv6-usage-warning: Enables SNMP notifications for authorization IPv6 address or prefix usage. The device generates a notification when the IPv6 address or prefix usage reaches or exceeds the high alarm threshold, drops below or reaches the low alarm threshold, or restores to the normal range.
After you enable SNMP notifications for ISP domains, the device generates a notification if a specific event occurs in an ISP domain. For ISP domain event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
For the device to correctly generate notifications about authorization IPv4 address usage in ISP domains, set the alarm thresholds for authorization IPv4 address usage in the ISP domains.
For the device to correctly generate notifications about authorization IPv6 address or prefix usage in ISP domains, set the alarm thresholds for authorization IPv6 address or prefix usage in the ISP domains.
For this feature to take effect when the device acts as a DHCP or DHCPv6 relay agent, you must execute the network command in the relay address pool on the DHCP relay agent. Make sure the subnet specified in the network command is the same as the subnet specified for the DHCP address pool of the DHCP server.
# Enable SNMP notifications for authorization IPv4 address usage in ISP domains.
[Sysname] snmp-agent trap enable domain ip-usage-warning
ip-usage-warning
ipv6-usage-warning
network (Layer 3—IP Services Command Reference)
Use state to set the status of an ISP domain.
Use undo state to restore the default.
state { active | block [ time-range ][ offline ]}
undo state
An ISP domain is in active state.
ISP domain view
active: Places the ISP domain in active state to allow the users in the ISP domain to request network services.
block: Places the ISP domain in blocked state to prevent users in the ISP domain from requesting network services. This keyword takes effect on all types of users except the SSH users that perform publickey authentication.
time-range: Places the ISP domain in blocked state based on time ranges. If you specify the block keyword but do not specify the time-range keyword, the ISP domain is always placed in blocked state.
offline: Logs off online users in the ISP domain when the state of the ISP domain changes to blocked. If you specify the block keyword but do not specify the offline keyword, the users in the ISP domain stay online when the state of the ISP domain changes to blocked.
To block an ISP domain based on time ranges, specify the time-range keyword in this command, and specify time ranges by using the state block time-range name command.
# Place ISP domain test in blocked state.
[Sysname-isp-test] state block
display domain
Use state block time-range name to specify time ranges during which an ISP domain is placed in blocked state.
Use undo state block time-range name to delete time ranges for placing an ISP domain in blocked state.
state block time-range name time-range-name
undo state block time-range { all | name time-range-name }
No time ranges are specified for placing an ISP domain in blocked state.
ISP domain view
time-range-name: Specifies a time range by its name, a case-insensitive string of 1 to 32 characters. The string must begin with a letter and cannot be all.
all: Specifies all time ranges.
The specified time ranges take effect only when the device is configured to block an ISP domain based on time ranges. To configure the device to block the ISP domain based on time ranges, use the state block time-range command.
You can repeat this command to specify multiple time ranges.
# Specify time ranges t1 and t2 for placing ISP domain test in blocked state.
[Sysname-isp-test] state block time-range name t1
[Sysname-isp-test] state block time-range name t2
state
time-range (ACL and QoS Command Reference)
user-address-type
Use user-address-type to specify the user address type in the ISP domain.
Use undo user-address-type to restore the default.
user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 }
No user address type is specified for the ISP domain.
ISP domain view
ds-lite: Specifies the DS-Lite address type.
ipv6: Specifies the IPv6 address type.
nat64: Specifies the NAT64 address type.
private-ds: Specifies the private-DS address type.
private-ipv4: Specifies the private IPv4 address type.
public-ds: Specifies the public-DS address type.
public-ipv4: Specifies the public IPv4 address type.
Specify the address type for users in an ISP domain according to the actual customer network environment and address assignment policies for the users.
On a CGN network, make sure the correct address type is specified on the device and users obtain private IP addresses of the specified type. Then, the device can cooperate with NAT444 to implement public IP address assignment, port block assignment, and user tracking after the users pass authentication. For more information about NAT444, see NAT Configuration Guide.
Any change to the user address type does not affect online users.
# Specify the private IPv4 address type for users in ISP domain test.
[Sysname-isp-test] user-address-type private-ipv4
display domain
Use user-group bind nat-instance to bind a user group to a NAT instance.
Use undo user-group to remove user group-to-NAT instance bindings.
user-group name group-name bind nat-instance instance-name
undo user-group [ name group-name ]
No user group is bound to any NAT instance and the load sharing feature is disabled in an ISP domain.
ISP domain view
name group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters. The user group must already exist.
instance-name: Specifies a NAT instance by its name, a case-sensitive string of 1 to 31 characters. If the NAT instance name contains spaces, you must enclose the name into double quotation marks (for example, "xxx xxx"). Make sure the specified NAT instance takes effect.
In a NAT and BRAS unification scenario, the load sharing feature in an ISP domain is enabled after you bind a user group in that domain to a NAT instance. Users groups bound to NAT instances are load-sharing user groups.
The device assigns an authenticated user to a load-sharing user group and uses the NAT instance associated with that user group to process the NAT service of the user. The rules are as follows:
·          If the AAA server assigns a user group to the user, the device identifies whether the user group has been bound to a NAT instance in the ISP domain.
¡  If the user group has been bound to a NAT instance, the device will use the NAT instance to process the NAT service of the user.
¡  If the user group is not bound to a NAT instance, the device will log off the user.
·          If the AAA server does not assign a user group to the user, the device selects a user group for the user from the user groups that have been bound to NAT instances in the ISP domain. The selection order is as follows:
a.    The user group that has the fewest number of online users.
b.    The user group that is configured most recently.
The device will use the NAT instance associated with the selected group to process the NAT service of the user.
·          If the AAA server does not assign a user group to the user and no load-sharing user group is configured in the ISP domain, no NAT instance is available for the user. The user will be logged off.
For more information about NAT and NAT instances, see NAT Configuration Guide.
If you do not specify the name group-name option, the undo user-group command removes all user group-to-NAT instance bindings and disables the load sharing feature in the ISP domain.
A user group can be bound to only one NAT instance. Multiple user groups can be bound to the same NAT instance.
To modify a user group-to-NAT instance binding, you must first use the undo user-group name group-name command to remove the original binding. A change to the user group-to-NAT instance binding does not affect users that have been online before the change.
An ISP domain supports a maximum of 32 user group-to-NAT instance bindings.
The user-group bind nat-instance and load-sharing user-group commands are mutually exclusive in an ISP domain. Before you use the user-group bind nat-instance command, remove the configuration of the load-sharing user-group command. In addition, make sure the ISP domain does not have users that came online before the load-sharing user-group command configuration is removed.
# In ISP domain test, bind user group g1 to NAT instance cp1 for load sharing of users.
[Sysname-isp-test] user-group name g1 bind nat-instance cp1
display domain
user-group
web-server { ip | ipv6 }
Use web-server { ip | ipv6 } to specify an IP address of the Web server.
Use undo web-server { ip | ipv6 } to remove an IP address of the Web server.
web-server { ip ipv4-address | ipv6 ipv6-address }
No IP addresses are specified for the Web server.
ISP domain view
ipv4-address: Specifies the IPv4 address of the Web server.
ipv6-address: Specifies the IPv6 address of the Web server.
If the URL of a Web request carries the specified IP address, the Web request is directly forwarded to the Web server without redirection. This configuration avoids unnecessary redirection if the destination of user Web requests is the IP address of the Web server.
You can specify a maximum of one IPv4 address and one IPv6 address.
# Specify 192.168.1.1 as the IP address of the Web server in ISP domain test.
[Sysname-isp-test] web-server ip 192.168.1.1
display domain
web-server url
Use web-server url to specify the Web server URL.
Use undo web-server url to restore the default.
web-server url url-string
undo web-server url
No Web server URL is specified.
ISP domain view
url-string: Specifies the URL of the Web server. The URL is a case-sensitive string of 1 to 255 characters, and it should start with http:// or https://. If the specified URL does not start with http:// or https://, the system considers that the URL starts with http://.
You can specify a Web server in an IPoE preauthentication domain. The device redirects the HTTP requests with destination port 80 and HTTPS requests with destination port 443 from unauthenticated IPoE users to the URL of the Web server. The URL provides the Web authentication page for the IPoE users.
# Specify http://1.2.3.4 as the URL of the Web server in ISP domain test.
[Sysname-isp-test] web-server url http://1.2.3.4
display domain
ip subscriber pre-auth domain
web-server url-parameter
Use web-server url-parameter to add a parameter to the Web server URL.
Use undo web-server url-parameter to remove a parameter from the Web server URL.
web-server url-parameter param-name { nas-id | nas-port-id | original-url | remote-id | source-address | source-mac [ encryption { aes | des } key { cipher | simple } string ] [ section { 1 | { 3 | 6 } [ separator separator-character ] } { lowercase | uppercase } ] | ssid | user-location | value expression }
undo web-server url-parameter param-name
No parameters are added to the URL of the Web server.
ISP domain view
param-name: Specifies a URL parameter name, a case-sensitive string of 1 to 32 characters. Contents of the parameter are determined by the keywords or options following the param-name argument.
nas-id: Specifies the NAS-ID.
nas-port-id: Specifies the NAS-Port-Id attribute value.
original-url: Specifies the URL of the webpage that a user requests.
remote-id: Specifies the Remote ID obtained from user DHCP packets.
source-address: Specifies the user IP address.
source-mac: Specifies the user MAC address.
encryption: Specifies an encryption algorithm to encrypt the user MAC address. If you do not specify this keyword, the device adds the user MAC address in plaintext form to the Web server URL.
aes: Specifies the AES algorithm.
des: Specifies the DES algorithm.
key: Specifies a key for encryption.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies a case-sensitive key string. The string length varies by the selected encryption algorithm:
·          If des cipher is specified, the string length is 41 characters.
·          If des simple is specified, the string length is 8 characters.
·          If aes cipher is specified, the string length is 1 to 73 characters.
·          If aes simple is specified, the string length is 1 to 31 characters.
section: Specifies the number of sections that a MAC address contains. If you do not specify this keyword, the MAC address is in the three-section format with uppercase letters, for example, XXXX-XXXX-XXXX.
·          1: Specifies the one-section format XXXXXXXXXXXX.
·          3: Specifies the three-section format XXXX-XXXX-XXXX.
·          6: Specifies the six-section format XX-XX-XX-XX-XX-XX.
·          separator separator-character: Specifies a delimiter to separate the MAC address into multiple sections. The delimiter is a case-sensitive character. If you do not specify a delimiter, the system uses hyphen (-) as the delimiter.
·          lowercase: Specifies the letters in a MAC address to be in lower case.
·          uppercase: Specifies the letters in a MAC address to be in upper case.
ssid: Specifies the user SSID.
user-location: Specifies the user access location, in the format of port:vlan1.vlan2.
·          The port argument represents the interface type and number (for example, eth/6/0/4). If the access interface is an aggregate interface, the interface type is ethtrunk. For example, ethtrunk/44 represents an aggregate interface.
·          The vlan1 and vlan2 arguments represent the outer VLAN ID and inner VLAN ID, respectively. If only information of a single VLAN is available, 0 is used as the value for the vlan2 argument (for example, eth/6/0/4:10.0). If no VLAN information is available, 0 is used as the value for both the arguments (for example, eth/6/0/4:0.0).
value expression: Specifies a custom case-sensitive string of 1 to 256 characters.
This command takes effect on IPoE and PPPoE users.
You can repeat this command to add multiple parameters to the Web server URL. For example, to attach the user IP address and a custom string of http://www.abc.com/welcome to the Web server URL http://1.2.3.4, perform the following tasks:
·          Execute this command with the userip source-address parameter.
·          Execute this command with the userurl value http://www.abc.com/welcome parameter.
The device will redirect Web requests from IP address 1.1.1.1 to the URL at http://1.2.3.4?userip=1.1.1.1&userurl=http://www.abc.com/welcome.
Make sure names of the specified parameters are the same as those supported by the Web server. Names of supported parameters vary by Web server type. For example, the IMC server supports parameters original-url, source-address, and source-mac, and names of the parameters are userurl, userip, and usermac, respectively. To add the user IP address to the Web server URL, you must configure the param-name argument as userip and specify the source-address keyword.
If you execute this command multiple times to configure the same URL parameter, the most recent configuration takes effect.
# In ISP domain test, add the user IP address and a custom string of http://www.abc.com/welcome to the Web server URL.
[Sysname-isp-test] web-server url-parameter userip source-address
[Sysname-isp-test] web-server url-parameter userurl value http://www.abc.com/welcome
# In ISP domain test, add the user MAC address encrypted by using the DES algorithm to the Web server URL.
[Sysname-isp-test] web-server url-parameter usermac source-mac encryption des key simple 12345678
aaa ssid
display domain
web-server url
Local user commands
access-limit
Use access-limit to set the maximum number of concurrent logins using the local user name.
Use undo access-limit to restore the default.
access-limit max-user-number
undo access-limit
The number of concurrent logins using the local user name is not limited.
Local user view
max-user-number: Specifies the maximum number of concurrent logins, in the range of 1 to 1024.
This command takes effect only when local accounting is configured for the local user. The command does not apply to FTP, SFTP, or SCP users. The users do not support accounting.
For this command to take effect on a network access user, you also need to configure the accounting start-fail offline command in the ISP domain view.
# Set the maximum number of concurrent logins to 5 for the local user account named abc.
[Sysname] local-user abc
[Sysname-luser-manage-abc] access-limit 5
display local-user
authorization-attribute (local user view/user group view)
Use authorization-attribute to configure authorization attributes for a local user or user group. After the local user or a local user in the user group passes authentication, the device assigns these attributes to the user.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { acl acl-number | callback-number callback-number | idle-cut minutes | ip ipv4-address | ip-pool ipv4-pool-name | ipv6 ipv6-address | ipv6-pool ipv6-pool-name | ipv6-prefix ipv6-prefix prefix-length | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | session-group-profile session-group-profile-name | session-timeout minutes | subscriber-id subscriber-id | url url-string | user-profile user-profile-name | user-role role-name | vlan vlan-id | vpn-instance vpn-instance-name | work-directory directory-name } *
undo authorization-attribute { acl | callback-number | idle-cut | ip | ip-pool | ipv6 | ipv6-pool | ipv6-prefix | { primary-dns | secondary-dns } { ip | ipv6 } | session-group-profile | session-timeout | subscriber-id | url | user-profile | user-role role-name | vlan | vpn-instance | work-directory } *
The working directory for FTP, SFTP, and SCP users is the root directory of the NAS. However, the users do not have permission to access the root directory.
The local users created by a network-admin or level-15 user are assigned the network-operator user role.
Local user view
User group view
acl acl-number: Specifies an authorization ACL. The value range for the acl-number argument is 2000 to 5999. Only ACL 2000 to ACL 4999 take effect. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
callback-number callback-number: Specifies an authorized PPP callback number. The callback-number argument is a case-sensitive string of 1 to 64 characters. After a local user passes authentication, the device uses this number to call the user.
idle-cut minutes: Sets an idle timeout period in minutes. The value range for the minutes argument is 1 to 120. An online user is logged out if the user's idle period exceeds the specified idle timeout period.
ip ipv4-address: Assigns a static IPv4 address to the user after it passes authentication.
ip-pool ipv4-pool-name: Specifies an IPv4 address pool for the user. The ipv4-pool-name argument is a case-insensitive string of 1 to 63 characters.
ipv6 ipv6-address: Assigns a static IPv6 address to the user after it passes authentication.
ipv6-pool ipv6-pool-name: Specifies an IPv6 address pool for the user. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters.
ipv6-prefix ipv6-prefix prefix-length: Specifies an IPv6 address prefix for the user. The value range for the prefix-length argument is 1 to 128.
primary-dns ip ipv4-address: Specifies the IPv4 address of the primary DNS server for the user.
primary-dns ipv6 ipv6-address: Specifies the IPv6 address of the primary DNS server for the user.
secondary-dns ip ipv4-address: Specifies the IPv4 address of the secondary DNS server for the user.
secondary-dns ipv6 ipv6-address: Specifies the IPv6 address of the secondary DNS server for the user.
session-group-profile session-group-profile-name: Specifies a session group profile for the user. The session-group-profile-name argument is a case-sensitive string of 1 to 31 characters. For more information about session group profiles, see user profile configuration in BRAS Services Configuration Guide.
session-timeout minutes: Sets the session timeout timer for the user, in minutes. The value range for the minutes argument is 1 to 1440. The device logs off the user after the timer expires.
subscriber-id subscriber-id: Specifies a subscriber ID for the user, in the range of 1 to 4095. Subscriber IDs are used with session group profiles to implement QoS traffic control on a per-group basis or used with local QoS IDs to implement HQoS. For more information about QoS and HQoS, see ACL and QoS Configuration Guide.
url url-string: Specifies the PADM URL to which the user is redirected after it passes authentication. The URL is a case-sensitive string of 1 to 255 characters and must begin with http:// or https://. This option is applicable only to PPP users. You must specify a URL that uses port number 80 or 8080.
user-profile user-profile-name: Specifies an authorization user profile by its name. The user-profile-name argument is a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or digit, but it cannot be all digits. The user profile restricts the behavior of authenticated users. For more information, see user profile configuration in BRAS Services Configuration Guide.
user-role role-name: Specifies an authorized user role. The role-name argument is a case-sensitive string of 1 to 63 characters. A maximum of 64 user roles can be specified for a user. For user role-related commands, see Fundamentals Command Reference for RBAC commands. This option is available only in local user view, and is not available in user group view.
vlan vlan-id: Specifies an authorized VLAN. The value range for the vlan-id argument is 1 to 4094. After passing authentication and being authorized a VLAN, a local user can access only the resources in this VLAN.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the user belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. After passing authentication, the user has permission to access the network resources in the specified VPN.
work-directory directory-name: Specifies the working directory for FTP, SFTP, or SCP users. The directory-name argument is a case-insensitive string of 1 to 255 characters. The directory must already exist.
Configure authorization attributes according to the application environments and purposes. Support for authorization attributes depends on the service types of users.
For PPP users, only the following authorization attributes take effect: callback-number, idle-cut, ip, ip-pool, ipv6-pool, ipv6-prefix, primary-dns, secondary-dns, session-group-profile, session-timeout, subscriber-id, url, user-profile, and vpn-instance.
For IPoE users, only the following authorization attributes take effect: idle-cut, ip-pool, ipv6-pool, ipv6-prefix, primary-dns, secondary-dns, session-group-profile, session-timeout, subscriber-id, user-profile, and vpn-instance. If the IPoE users access the network through leased lines, the vpn-instance authorization attribute does not take effect.
For portal users, only the following authorization attributes take effect: acl, idle-cut, session-timeout, and user-profile.
For LAN users, only the following authorization attributes take effect: acl, session-timeout, user-profile, and vlan.
For SSH, Telnet, and terminal users, only the following authorization attributes take effect: idle-cut and user-role.
For HTTP and HTTPS users, only the user-role authorization attribute takes effect.
For FTP users, only the following authorization attributes take effect: user-role and work-directory.
For other types of local users, no authorization attribute takes effect.
Authorization attributes configured for a user group are intended for all local users in the group. You can group local users to improve configuration and management efficiency. An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view.
To make sure FTP, SFTP, and SCP users can access the directory after an active/standby switchover, do not specify chassis or slot information for the working directory.
To make sure the user have only the user roles authorized by using this command, use the undo authorization-attribute user-role command to remove the default user role.
The security-audit user role has access to the commands for managing security log files and security log file system. To display all the accessible commands of the security-audit user role, use the display role name security-audit command. For more information about security log management, see Network Management and Monitoring Configuration Guide. For more information about file system management, see Fundamentals Configuration Guide.
You cannot delete a local user if the local user is the only user that has the security-audit user role.
The security-audit user role is mutually exclusive with other user roles.
·          When you assign the security-audit user role to a local user, the system requests confirmation for deleting all the other user roles of the user.
·          When you assign other user roles to a local user that has the security-audit user role, the system requests confirmation for deleting the security-audit user role for the local user.
# Configure the authorized VLAN of network access user abc as VLAN 2.
[Sysname] local-user abc class network
[Sysname-luser-network-abc] authorization-attribute vlan 2
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
# Assign the security-audit user role to device management user xyz as the authorized user role.
[Sysname] local-user xyz class manage
[Sysname-luser-manage-xyz] authorization-attribute user-role security-audit
This operation will delete all other roles of the user. Are you sure? [Y/N]:y
display local-user
display user-group
bind-attribute
Use bind-attribute to configure binding attributes for a local user.
Use undo bind-attribute to remove binding attributes of a local user.
bind-attribute { call-number call-number [ : subcall-number ]| ip ip-address | location interface interface-type interface-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { call-number | ip | location | mac | vlan } *
No binding attributes are configured for a local user.
Local user view
call-number call-number: Specifies a calling number for PPP user authentication. The call-number argument is a string of 1 to 64 characters. This option applies only to PPP users.
subcall-number: Specifies the subcalling number. The total length of the calling number and the subcalling number cannot be more than 62 characters.
ip ip-address: Specifies the IP address to which the user is bound. This option applies only to 802.1X users.
location interface interface-type interface-number: Specifies the interface to which the user is bound. The interface-type argument represents the interface type, and the interface-number argument represents the interface number. To pass authentication, the user must access the network through the bound interface. This option applies only to IPoE, LAN, portal, and PPP users.
mac mac-address: Specifies the MAC address of the user in the format H-H-H. This option applies only to IPoE, LAN, portal, and PPP users.
vlan vlan-id: Specifies the VLAN to which the user belongs. The vlan-id argument is in the range of 1 to 4094. This option applies only to IPoE, LAN, portal, and PPP users.
To perform local authentication of a user, the device matches the actual user attributes with the configured binding attributes. If the user has a non-matching attribute or lacks a required attribute, the user will fail authentication.
Binding attribute check takes effect on all access services. Configure the binding attributes for a user based on the access services and make sure the device can obtain all attributes to be checked from the user's packet.
The binding interface type must meet the requirements of the local user. Configure the binding interface based on the service type of the user.
·          If the user is an 802.1X user, specify the 802.1X-enabled Layer 2 Ethernet interface.
·          If the user is a MAC authentication user, specify the MAC authentication-enabled Layer 2 Ethernet interface.
·          If the user is a portal user, specify the portal-enabled interface. Specify the Layer 2 Ethernet interface if portal is enabled on a VLAN interface and the portal roaming enable command is not configured.
# Bind MAC address 0001-0002-0003 with network access user abc.
[Sysname-luser-network-abc] bind-attribute mac 0001-0002-0003
display local-user
company
Use company to specify the company of a local guest.
Use undo company to restore the default.
company company-name
undo company
No company is specified for a local guest.
Local guest view
company-name: Specifies the company name, a case-sensitive string of 1 to 255 characters.
# Specify company yyy for local guest abc.
[Sysname] local-user abc class network guest
[Sysname-luser-network(guest)-abc] company yyy
display local-user
description
Use description to configure a description for a local guest.
No description is configured for a local guest.
Local guest view
text: Configures a description, case-sensitive string of 1 to 255 characters.
# Configure a description for local guest abc.
[Sysname-luser-network(guest)-abc] description Manager of MSC company
display local-user
display local-user
Use display local-user to display the local user configuration and online user statistics.
display local-user [ class { manage | network [ guest ] } | idle-cut { disable | enable } | service-type { ftp | http | https | ipoe | lan-access | portal | ppp | ssh | telnet | terminal } | state { active | block } | user-name user-name class { manage | network [ guest ] } | vlan vlan-id ]
class: Specifies the local user type.
manage: Device management user.
network: Network access user.
guest: Guest user account.
idle-cut { disable | enable }: Specifies local users with the idle cut feature disabled or enabled.
service-type: Specifies the local users that use a specific type of service.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ipoe: IPoE users that access the network through Layer 2 or Layer 3 leased lines or STBs.
lan-access: LAN users that typically access the network through an Ethernet.
portal: Portal users.
ppp: PPP users.
ssh: SSH users.
telnet: Telnet users.
terminal: Terminal users that log in through console ports.
state { active | block }: Specifies local users in active or blocked state. A local user in active state can access network services, but a local user in blocked state cannot.
user-name user-name: Specifies all local users using the specified username, a string of 1 to 80 characters. The specified username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
·          The pure username is a case-sensitive string and must meet the following requirements:
¡  Cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
¡  Cannot be a, al, or all.
·          The domain name is a case-insensitive string and cannot contain an at sign (@).
vlan vlan-id: Specifies all local users in a VLAN. The vlan-id argument is in the range of 1 to 4094.
If you do not specify any parameters, this command displays information about all local users.
# Display information about all local users.
<Sysname> display local-user
Total 3 local users matched.
Device management user root:
  State:                     Active
  Service type:              SSH/Telnet/Terminal
  Access limit:              Enabled           Max access number: 3
  Current access number:     1
  User group:                system
  Bind attributes:
  Authorization attributes:
    Work directory:          flash:
    User role list:          network-admin
    Password aging:          3 days
  Password remaining lifetime: 2 days 12 hours 30 minutes 30 seconds
  Password history was last reset: 0 days ago
Network access user jj:
  State:                     Active
  Service type:              LAN access
  User group:                system
  Bind attributes:
    Location bound:          GigabitEthernet3/1/1
    MAC address:             0001-0001-0001
    VLAN ID:                 2
    Idle timeout:            33 minutes
    ACL number:              2000
    User profile:            pp
    User role list:          network-operator, level-0, level-3
    SSL VPN policy group:    spg
Network access guest user user1:
  State:                     Active
  Service type:              LAN access/Portal
  User group:                guest1
  Full name:                 Jack
  Company:                   cc
  Email:                     [email protected]
  Phone:                     131129237
  Description:               A guest from company cc
  Sponsor full name:         Sam
  Sponsor department:        security
  Sponsor email:             [email protected]
  Period of validity:
    Start date and time:     2015/04/01-08:00:00
    Expiration date and time:2015/04/03-18:00:00
Table 10 Command output
Status of the local user: active or blocked.
Service type
Service types that the local user can use.
Access limit
Whether the concurrent login limit is enabled.
Max access number
Maximum number of concurrent logins using the local user name.
Current number of concurrent logins using the local user name.
User group
Group to which the local user belongs.
Bind attributes
Binding attributes of the local user.
Location bound
Binding port of the local user.
MAC address
MAC address of the local user.
VLAN ID
Binding VLAN of the local user.
Authorization attributes of the local user.
Idle timeout
Idle timeout period of the user, in minutes.
Session-timeout
Session timeout timer of the user, in minutes.
Callback number
Authorized PPP callback number of the local user.
Work directory
Directory that the FTP, SFTP, or SCP user can access.
ACL number
Authorization ACL of the local user.
VLAN ID
Authorized VLAN of the local user.
User profile
Authorization user profile of the local user.
User role list
Authorized roles of the local user.
IP pool
IPv4 address pool authorized to the local user.
SSL VPN policy group authorized to the local user.
IP address
IPv4 address authorized to the local user.
IPv6 address
IPv6 address authorized to the local user.
IPv6 prefix
IPv6 address prefix authorized to the local user.
IPv6 pool
IPv6 address pool authorized to the local user.
Primary DNS server
IPv4 address of the primary DNS server for the local user.
Secondary DNS server
IPv4 address of the secondary DNS server for the local user.
Primary DNSV6 server
IPv6 address of the primary DNS server for the local user.
Secondary DNSV6 server
IPv6 address of the secondary DNS server for the local user.
URL
PADM URL of the local user.
Subscriber ID
Subscriber ID of the local user.
Session group profile
Session group profile of the local user.
VPN instance
Authorization VPN instance of the local user.
Password control attributes that are configured for the local user.
Password aging
Password expiration time.
Password length
Minimum number of characters that a password must contain.
Password composition
Password composition policy:
·         Minimum number of character types that a password must contain.
·         Minimum number of characters from each type in a password.
Password complexity
Password complexity checking policy:
·         Reject a password that contains the username or the reverse of the username.
·         Reject a password that contains any character repeated consecutively three or more times.
Maximum login attempts
Maximum number of consecutive failed login attempts.
Action for exceeding login attempts
Action to take on the user that failed to log in after using up all login attempts.
Remaining lifetime of the user's password.
The most recent time that the password records were cleared.
Full name
Name of the local guest.
Company
Company name of the local guest.
Email
Email address of the local guest.
Phone
Phone number of the local guest.
Description of the local guest.
Sponsor full name
Name of the guest sponsor.
Sponsor department
Department of the guest sponsor.
Sponsor email
Email address of the guest sponsor.
Period of validity
Validity period of the local guest.
Start date and time
Date and time from which the local guest begins to take effect.
Date and time at which the local guest expires.
display user-group
Use display user-group to display user group configuration.
display user-group { all | name group-name }
all: Specifies all user groups.
# Display the configuration of all user groups.
<Sysname> display user-group all
Total 2 user groups matched.
User group: system
User group: jj
    Idle timeout:            2 minutes
    Callback number:         2:2
    Work directory:          flash:/
    ACL number:              2000
    VLAN ID:                 2
    User profile:            pp
    SSL VPN policy group:    policygroup1
    Password aging:          2 days
Table 11 Command output
Authorization attributes of the user group.
Idle timeout
Idle timeout period, in minutes.
Session-timeout
Session timeout timer, in minutes.
Callback number
Authorized PPP callback number.
Work directory
Directory that FTP, SFTP, or SCP users in the group can access.
ACL number
Authorization ACL.
VLAN ID
Authorized VLAN.
User profile
Authorization user profile.
IP pool
IPv4 address pool authorized to the user group.
SSL VPN policy group authorized to the user group.
IPv6 prefix
IPv6 address prefix authorized to the user group.
IPv6 pool
IPv6 address pool authorized to the user group.
Primary DNS server
IPv4 address of the primary DNS server authorized to the user group.
IPv4 address of the secondary DNS server authorized to the user group.
IPv6 address of the primary DNS server authorized to the user group.
IPv6 address of the secondary DNS server authorized to the user group.
URL
PADM URL for the user group.
Subscriber ID
Subscriber ID for the user group.
Session group profile for the user group.
VPN instance
Authorization VPN instance for the user group.
Password control attributes that are configured for the user group.
Password aging
Password length
Password complexity
email
Use email to configure an email address for a local guest.
Use undo email to restore the default.
email email-string
undo email
No email address is configured for a local guest.
Local guest view
email-string: Specifies the email address for the local guest, a case-sensitive string of 1 to 255 characters. For example, [email protected]. The address must comply with RFC 822.
The local guest uses the email address to receive notifications from the device.
# Configure the email address as [email protected] for local guest abc.
[Sysname-luser-network(guest)-abc] email [email protected]
display local-user
full-name
Use full-name to configure the name of a local guest.
Use undo full-name to restore the default.
full-name name-string
undo full-name
No name is configured for a local guest.
Local guest view
name-string: Specifies the local guest name, a case-sensitive string of 1 to 255 characters.
# Configure the name as abc Snow for local guest abc.
[Sysname-luser-network(guest)-abc] full-name abc Snow
display local-user
group
Use group to assign a local user to a user group.
Use undo group to restore the default.
group group-name
undo group
A local user belongs to user group system.
Local user view
group-name: Specifies the user group name, a case-insensitive string of 1 to 32 characters.
# Assign device management user 111 to user group abc.
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
display local-user
local-guest auto-delete enable
Use local-guest auto-delete enable to enable the guest auto-delete feature.
Use undo local-guest auto-delete enable to restore the default.
The guest auto-delete feature is disabled.
This feature enables the device to automatically delete the local guest accounts when they expire.
# Enable the guest auto-delete feature.
[Sysname] local-guest auto-delete enable
validity-datetime
local-guest email format
Use local-guest email format to configure the subject and body for the email notifications of local guest information.
Use undo local-guest email format to delete the configured subject or body for the email notifications of local guest information.
local-guest email format to { guest | manager | sponsor } { body body-string | subject sub-string }
undo local-guest email format to { guest | manager | sponsor } { body | subject }
No subject or body is configured for the email notifications of local guest information.
to: Specifies the email recipient.
guest: Specifies the local guest.
manager: Specifies the guest manager.
sponsor: Specifies the guest sponsor.
body body-string: Configures the body content. The body-string argument is a case-sensitive string of 1 to 255 characters.
subject sub-string: Configures the email subject. The sub-string argument is a case-sensitive string of 1 to 127 characters.
Email notifications need to be sent to notify the local guests, guest sponsors, or guest managers of the guest account information. Use this command to configure the subject and body for the email notifications to be sent by the device.
You can configure one subject and one body for each email recipient. If you configure the subject or body content multiple times for the same recipient, the most recent configuration takes effect.
You must configure both the subject and body for each recipient.
# Configure the subject and body for the email notifications to send to the local guest.
[Sysname] local-guest email format to guest subject Guest account information
[Sysname] local-guest email format to guest body A guest account has been created for you. The username, password, and validity period of the account are given below.
local-guest email sender
local-guest email smtp-server
local-guest send-email
Use local-guest email sender to configure the email sender address in email notifications of local guests sent by the device.
Use undo local-guest email sender to restore the default.
local-guest email sender email-address
No email sender address is configured for the email notifications of local guests sent by the device.
email-address: Specifies the email sender address, a case-sensitive string of 1 to 255 characters.
If you do not specify the email sender address, the device cannot send email notifications.
The device supports only one email sender address. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the email sender address as [email protected] for email notifications of local guests.
[Sysname] local-guest email sender [email protected]
Use local-guest email smtp-server to specify an SMTP server to send email notifications of local guests.
Use undo local-guest email smtp-server to restore the default.
local-guest email smtp-server url-string
No SMTP server is specified to send email notifications of local guests.
url-string: Specifies the path of the SMTP server, a case-sensitive string of 1 to 255 characters. The path must comply with the standard SMTP protocol and start with smtp://.
# Specify the SMTP server at smtp://www.test.com/smtp to send local guest email notifications.
[Sysname] local-guest email smtp-server smtp://www.test.com/smtp
local-guest generate
Use local-guest generate to create local guests in batch.
local-guest generate username-prefix name-prefix [ password-prefix password-prefix ] suffix suffix-number [ group group-name ] count user-count validity-datetime start-date start-time to expiration-date expiration-time
username-prefix name-prefix: Specifies the name prefix. The name-prefix argument is a case-sensitive string of 1 to 70 characters. The prefix cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), and at sign (@).
password-prefix password-prefix: Specifies a prefix for the plaintext password. The password-prefix argument is a case-sensitive string of 1 to 53 characters. If you do not specify a password prefix, the device randomly generates passwords for the local guests.
suffix suffix-number: Specifies the start suffix number of the username and password. The suffix-number argument is a numeric string of 1 to 10 digits.
group group-name: Specifies a user group by the name. The group-name argument is a case-sensitive string of 1 to 32 characters. If you do not specify a user group, the guests are assigned to the system-defined user group system.
count user-count: Specifies the number of local guests to be created. The value range for the user-count argument is 1 to 256.
validity-datetime: Specifies the validity period of the local guests.
start-date: Specifies the start date of the validity period, in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the start time of the validity period, in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the end date and time of the validity period.
expiration-date: Specifies the expiration date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
expiration-time: Specifies the expiration time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
Account names of batch created local guests start with the same string specified by the name prefix, and end with a different number as the suffix. The system increases the start suffix number by 1 for each new local guest created in the batch.
The device generates plaintext passwords by using the password prefix and suffix number in the same way it batch creates the local guest names.
Consider the system resources when you specify the number of local guests to create. The device might fail to create all accounts for a large batch of local guests because of insufficient resources.
If a local guest to be created has the same name as an existing local guest on the device, the new guest overrides the existing guest.
# Create 20 local guests in batch with user names abc01 through abc20 for user group visit. The user accounts are effective from 2014/10/01 00:00:00 to 2015/10/02 12:00:00.
[Sysname] local-guest generate username-prefix abc suffix 01 group visit count 20 validity-datetime 2014/10/01 00:00:00 to 2015/10/02 12:00:00
local-user
display local-user
Use local-guest send-email to send emails to a local guest or guest sponsor.
local-guest send-email user-name user-name to { guest | sponsor }
user-name user-name: Specifies a local guest by the username, a string of 1 to 80 characters. The username of the specified guest can be a pure username or contain a domain name (in the format of pure-username@domain-name).
Guest managers can use this command to inform local guests or guest sponsors of the guest password and validity period information.
# Send an email to notify local guest abc of the guest password and validity period information.
<Sysname> local-guest send-email user-name abc to guest
email
sponsor-email
local-user
Use local-user to add a local user and enter its view, or enter the view of an existing local user.
Use undo local-user to delete local users.
local-user user-name [ class { manage | network [ guest ] } ]
undo local-user { user-name class { manage | network [ guest ] } | all [ service-type { ftp | http | https | ipoe | lan-access | portal | ppp | ssh | telnet | terminal } | class { manage | network [ guest ] } ] }
No local users exist.
user-name: Specifies the username of a local user, a string of 1 to 80 characters. The specified username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
class: Specifies the local user type. If you do not specify this keyword, the command adds a device management user.
manage: Device management user that can configure and monitor the device after login. Device management users can use FTP, HTTP, HTTPS, Telnet, SSH, and terminal services.
network: Network access user that accesses network resources through the device. Network access users can use LAN, PPP, IPoE, and portal services.
guest: Guest that can access network resources through the device during a specific validity period. Guests can use LAN and portal services.
all: Specifies all users.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ppp: PPP users.
ssh: SSH users.
# Add a device management user named user1 and enter local user view.
[Sysname-luser-manage-user1]
# Add a network access user named user2 and enter local user view.
[Sysname] local-user user2 class network
[Sysname-luser-network-user2]
# Add a local guest named user3 and enter local guest view.
[Sysname] local-user user3 class network guest
[Sysname-luser-network(guest)-user3]
display local-user
service-type (local user view)
local-user-export
Use local-user-export to export local guest account information to a .csv file in the specified path.
local-user-export class network guest url url-string
network: Specifies the network access user.
url url-string: Specifies the URL of the destination file, a case-insensitive string of 1 to 255 characters.
You can import the user account information back to the device or to other devices that support the local-user-import command. Before the import, you can edit the .csv file as needed. However, you must follow the restrictions in "local-user-import."
The device supports TFTP and FTP file transfer modes. Table 12 describes the valid URL formats of the .csv file.
Table 12 URL formats
Protocol
URL format
TFTP
tftp://server/path/filename
Specify a TFTP server by IP address or hostname. For example, specify the file path as tftp://1.1.1.1/user/user.csv.
FTP
·         With FTP user name and password:
ftp://username:password@server/path/filename
·         Without FTP user name and password:
Specify an FTP server by IP address or hostname.
The device ignores the domain name in the FTP user name.
For example, specify the file path as ftp://1:[email protected]/user/user.csv or ftp://1.1.1.1/user/user.csv.
# Export local guest account information to the guest.csv file in the ftp://1.1.1.1/user/ path.
[Sysname] local-user-export class network guest url ftp://1.1.1.1/user/guest.csv
local-user-import
local-user-import
Use local-user-import to import local guest account information from a .csv file in the specified path to the device to create local guests based on the imported information.
local-user-import class network guest url url-string validity-datetime start-date start-time to expiration-date expiration-time [ auto-create-group | override | start-line line-number ] *
url url-string: Specifies the source file path. The url-string argument is a case-insensitive string of 1 to 255 characters.
validity-datetime: Specifies the guest validity period of the local guests.
auto-create-group: Enables the device to automatically create user groups for the imported local guests if the groups in the imported information do not exist on the device. If you do not specify this keyword, the device adds all imported local guests to the system-defined user group system.
override: Enables the device to override the existing account with the same name as an imported guest account. If you do not specify this keyword, the device retains the existing account and does not import the local guest with the same name.
start-line line-number: Specifies the number of the line at which the account import begins. If you do not specify a line number, this command imports all accounts in the .csv file.
The .csv file contains multiple parameters for each account and the parameters must be strictly arranged in the following order:
·          Username—User name of the guest account. The user name cannot be empty.
·          Password—Password of the guest account in plaintext form. If the password is empty, the device generates a random password in encrypted form for the guest.
·          User group—User group to which the guest belongs. If the user group is empty, the device assigns the guest to the system-defined user group system.
·          Guest full name—Name of the guest.
·          Guest company—Company of the guest.
·          Guest email—Email address of the guest.
·          Guest phone—Phone number of the guest.
·          Guest description—Description of the guest.
·          Sponsor full name—Name of the guest sponsor.
·          Sponsor department—Department of the guest sponsor.
·          Sponsor email—Email address of the guest sponsor.
The value of each parameter in the file must meet the requirements of the local user attributes on the device. Any violation results in account import failure and interruption. The system displays the number of the line where the account import is interrupted.
Separate different account entries by a carriage return and separate each parameter value in an account entry by a comma (,). If the value of a parameter contains a comma (,), you must enclose the value within a pair of quotation marks ("") to avoid ambiguity. For example,
Jack,abc,visit,Jack Chen,ETP,[email protected],1399899,"The manager of ETP, come from TP.",Sam Wang,Ministry of personnel,[email protected]
The device supports TFTP and FTP file transfer modes. Table 13 describes the valid URL formats of the .csv file.
Table 13 URL formats
Protocol
URL format
TFTP
FTP
# Import guest account information from the ftp://1.1.1.1/user/guest.csv file and specify a validity period for the imported guests.
[Sysname] local-user-import class network guest url ftp://1.1.1.1/user/guest.csv validity-datetime 2014/10/01 00:00:00 to 2014/10/02 12:00:00
display local-user
local-user-export
password (device management user view)
Use password to configure a password for a device management user.
Use undo password to restore the default.
password [ { hash | simple } string ]
undo password
A device management user does not have a password and can pass authentication after entering the correct username and passing attribute checks.
Device management user view
hash: Specifies a password encrypted by the hash algorithm.
string: Specifies the password string. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its hashed from is a case-sensitive string of 1 to 110 characters.
If you do not specify any parameters, you enter the interactive mode to set a plaintext password.
A device management user for which no password is specified can pass authentication after entering the correct username and passing attribute checks. To enhance security, configure a password for each device management user.
# Set the password to 123456TESTplat&! in plaintext form for device management user user1.
# Configure the password in interactive mode for device management user test.
[Sysname-luser-manage-test] password
Password:
Confirm :
display local-user
password (network access user view)
Use password to configure a password for a network access user.
password [ { cipher | simple } string ]
undo password
A network access user does not have a password and can pass authentication after entering the correct username and passing attribute checks.
Network access user view
string: Specifies a password string. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
As a best practice to enhance security, configure a password for each network access user.
# Set the password to 123456TESTuser&! in plaintext form for network access user user1.
[Sysname] local-user user1 class network
[Sysname-luser-network-user1] password simple 123456TESTuser&!
display local-user
phone
Use phone to specify the phone number of a local guest.
Use undo phone to restore the default.
phone phone-number
undo phone
No phone number is specified for a local guest.
Local guest view
phone-number: Specifies the phone number, a string of 1 to 32 characters.
# Specify the phone number as 138137239201 for local guest abc.
[Sysname-luser-network(guest)-abc] phone 138137239201
display local-user
Use service-type to specify the service types that a local user can use.
Use undo service-type to remove service types configured for a local user.
service-type { ftp | ipoe | lan-access | { http | https | ssh | telnet | terminal } * | portal | ppp }
undo service-type { ftp | ipoe | lan-access | { http | https | ssh | telnet | terminal } * | portal | ppp }
A local user is not authorized to use any service.
Local user view
ftp: Authorizes the user to use the FTP service. The authorized directory can be modified by using the authorization-attribute work-directory command.
http: Authorizes the user to use the HTTP service.
https: Authorizes the user to use the HTTPS service.
ipoe: Authorizes the user to use the IPoE service.
lan-access: Authorizes the user to use the LAN access service. The users are typically Ethernet users.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service and log in from a console port.
portal: Authorizes the user to use the portal service.
ppp: Authorizes the user to use the PPP service.
You can assign multiple service types to a user.
# Authorize device management user user1 to use the Telnet and FTP services.
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
display local-user
sponsor-department
Use sponsor-department to specify the department of the guest sponsor for a local guest.
Use undo sponsor-department to restore the default.
sponsor-department department-string
No department is specified for the guest sponsor of a local guest.
Local guest view
department-string: Specifies the department name, a case-sensitive string of 1 to 127 characters.
# Specify the department as test for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-department test
display local-user
sponsor-email
Use sponsor-email to specify the email address of the guest sponsor for a local guest.
Use undo sponsor-email to restore the default.
sponsor-email email-string
undo sponsor-email
No email address is specified for the guest sponsor.
Local guest view
email-string: Specifies the email address, a case-sensitive string of 1 to 255 characters. The address must comply with RFC 822.
# Specify the email address as [email protected] for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-email [email protected]
display local-user
sponsor-full-name
Use sponsor-full-name to specify the guest sponsor name for a local guest.
Use undo sponsor-full-name to restore the default.
sponsor-full-name name-string
No guest sponsor name is specified for a local guest.
Local guest view
name-string: Specifies the guest sponsor name, a case-sensitive string of 1 to 255 characters.
# Specify the guest sponsor name as Sam Li for local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-full-name Sam Li
display local-user
state (local user view)
Use state to set the status of a local user.
Use undo state to restore the default.
undo state
A local user is in active state.
Local guest view
Local user view
active: Places the local user in active state to allow the local user to request network services.
block: Places the local user in blocked state to prevent the local user from requesting network services.
# Place device management user user1 in blocked state.
[Sysname-luser-manage-user1] state block
display local-user
user-group
Use user-group to create a user group and enter its view, or enter the view of an existing user group.
Use undo user-group to delete a user group.
user-group group-name
undo user-group group-name
A system-defined user group exists. The group name is system.
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group.
A user group that has local users cannot be deleted.
You can modify settings for the system-defined user group system, but you cannot delete the user group.
# Create a user group named abc and enter user group view.
display user-group
validity-datetime
Use validity-datetime to specify the validity period for a local guest.
Use undo validity-datetime to restore the default.
The validity period for a local guest does not expire.
Local guest view
start-date: Specifies the date on which the local guest becomes effective. The date is in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the time on the day when the local guest becomes effective. The time is in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the expiration date and time for the local guest.
The expiration date and time must be later than the start date and time.
Expired local guest accounts cannot be used for authentication.
# Specify the validity period for local guest abc.
[Sysname-luser-network(guest)-abc] validity-datetime 2014/10/01 00:00:00 to 2015/10/02 12:00:00
display local-user
RADIUS commands
aaa device-id
Use aaa device-id to configure the device ID.
Use undo aaa device-id to restore the default.
aaa device-id device-id
undo aaa device-id
The device ID is 0.
device-id: Specifies a device ID in the range of 1 to 255.
RADIUS uses the value of the Acct-Session-ID attribute as the accounting ID for a user. The device generates an Acct-Session-ID value for each online user based on the system time, random digits, and device ID.
If you modify the device ID, the new device ID does not take effect on users that have been online during the change.
# Configure the device ID as 1.
[Sysname] aaa device-id 1
aaa nas-port-id vlanid uppercase
Use aaa nas-port-id vlanid uppercase to configure the device to use uppercase string VLANID in the RADIUS NAS-Port-Id attribute instead of lowercase string vlanid.
Use undo aaa nas-port-id vlanid uppercase to restore the default.
The device uses lowercase string vlanid in the RADIUS NAS-Port-Id attribute.
Use this command if the RADIUS server requires that the vlanid string in the RADIUS NAS-Port-Id attribute be in upper case. For example, if the default format of the NAS-Port-Id attribute is slot=xx;subslot=xx;port=xx;vlanid=xx, the execution of this command changes the attribute format to slot=xx;subslot=xx;port=xx;VLANID=xx.
# Configure the device to use uppercase string VLANID in the RADIUS NAS-Port-Id attribute.
[Sysname] aaa nas-port-id vlanid uppercase
accounting-on enable
Use accounting-on enable to configure the accounting-on feature.
Use undo accounting-on enable to disable the accounting-on feature.
accounting-on enable [ interval interval | send send-times ] *
The accounting-on feature is disabled.
RADIUS scheme view
interval interval: Specifies the time interval for retransmitting an accounting-on packet in seconds. The value range for the interval argument is 1 to 15, and the default setting is 3.
send send-times: Specifies the maximum number of accounting-on packet transmission attempts. The value range for the send-times argument is 1 to 255, and the default setting is 50.
The accounting-on feature enables the device to automatically send an accounting-on packet to the RADIUS server after a device reboot. Upon receiving the accounting-on packet, the RADIUS server logs out all online users so they can log in again through the device.
Execute the save command to ensure that the accounting-on enable command takes effect at the next device reboot. For information about the save command, see Fundamentals Command Reference.
Parameters set by using the accounting-on enable command take effect immediately.
# Enable the accounting-on feature for RADIUS scheme radius1, and set the retransmission interval to 5 seconds and the transmission attempts to 15.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
display radius scheme
accounting-on extended
Use accounting-on extended to enable the extended accounting-on feature.
Use undo accounting-on extended to disable the extended accounting-on feature.
The extended accounting-on feature is disabled.
RADIUS scheme view
The extended accounting-on feature enhances the accounting-on feature by applying to a distributed architecture. For the extended accounting-on feature to take effect, the RADIUS server must run on IMC and the accounting-on feature must be enabled.
The extended accounting-on feature is applicable to LAN, PPP (L2TP LAC-side), and IPoE users. The user data is saved to the cards through which the users access the device.
When the extended accounting-on feature is enabled, the device automatically sends an accounting-on packet to the RADIUS server after a card reboots (device not reboot). The packet contains the card identifier. Upon receiving the accounting-on packet, the RADIUS server logs out all online users that access the device through the card. If no users have come online through the card, the device does not send an accounting-on packet to the RADIUS server after the card reboots.
The device uses the packet retransmission interval and maximum transmission attempts set by using the accounting-on enable command for this feature.
Execute the save command to ensure that the accounting-on extended command takes effect at the next card reboot. For information about the save command, see Fundamentals Command Reference.
# Enable the extended accounting-on feature for RADIUS scheme radius1.
[Sysname-radius-radius1] accounting-on extended
attribute 5 format
Use attribute 5 format to configure the format of the RADIUS NAS-Port attribute (attribute 5).
Use undo attribute 5 format to restore the default.
attribute 5 format qinq
The RADIUS NAS-Port attribute uses the single-VLAN encapsulation format: SlotIDSubslotIDIfIndexVlanID.
·          SlotIDSlot number, 3 bits.
·          SubslotIDSub slot ID, 1 bit.
·          IfIndexInterface number, 4 bits.
·          VlanIDVLAN ID, 12 bits.
RADIUS scheme view
qinq: Specifies the QinQ encapsulation format: SlotIDSubslotIDIfIndexSVlanIDCVlanID.
·          SVlanIDSVLAN ID, 12 bits.
·          CVlanIDCVLAN ID, 12 bits.
As a best practice, use the QinQ encapsulation format for the RADIUS NAS-Port attribute in a QinQ network.
If the QinQ encapsulation format is configured in a non-QinQ network, the device pads the SVlanID part in this attribute with 0s.
If the length of a field in this attribute exceeds the length specified in the format, this field is invalid.
# In RADIUS scheme rad, configure the format of the RADIUS NAS-Port attribute as the QinQ encapsulation format.
[Sysname-radius-rad] attribute 5 format qinq
attribute 6 value
Use attribute 6 value to set the value of the RADIUS Service-Type attribute (attribute 6).
Use undo attribute 6 value to restore the default.
attribute 6 value outbound user-type ipoe [ value-added-service ]
undo attribute 6 value outbound user-type ipoe
The value of the RADIUS Service-Type attribute in outgoing RADIUS packets varies by user type.
·          For MAC authentication users, the value is 10 (CallCheck).
·          For device management users, the value is 1 (Login).
·          For the other types of users, the value is 2 (Framed).
RADIUS scheme view
outbound: Specifies the attribute value as 5 (Outbound). In the current software version, only this value is supported.
user-type ipoe: Specifies the type of access users as IPoE. In the current software version, only this type of access users can be specified.
value-added-service: Applies the configured value to RADIUS packets of value-added services (including ITA and EDSG services). If you do not specify this keyword, the attribute value applies only to RADIUS packets of non-value-added services.
Set the value of the RADIUS Service-Type attribute in outgoing RADIUS packets to meet the requirements of RADIUS servers.
If the service provider requires that the Service-Type attribute in authentication and accounting requests for IPoE users uses value 5 (Outbound), execute the attribute 6 value outbound user-type ipoe command. If the service provider has the same requirements for authentication and accounting requests of IPoE users' value-added services, execute the attribute 6 value outbound user-type ipoe value-added-service command.
# In RADIUS scheme radius1, set the Service-Type attribute value to 5 (Outbound) in outgoing RADIUS packets for IPoE users' non-value-added and value-added services.
[Sysname-radius-radius1] attribute 6 value outbound user-type ipoe value-added-service
attribute 15 check-mode
Use attribute 15 check-mode to configure the Login-Service attribute check method for SSH, FTP, and terminal users.
Use undo attribute 15 check-mode to restore the default.
attribute 15 check-mode { loose | strict }
The strict check method applies for SSH, FTP, and terminal users.
RADIUS scheme view
loose: Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services.
strict: Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively.
Use the loose check method only when the server does not issue Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal users.
# Configure the Login-Service attribute check method as loose for SSH, FTP, and terminal users in RADIUS scheme radius1.
[Sysname-radius-radius1] attribute 15 check-mode loose
attribute 25 car
Use attribute 25 car to configure the device to interpret the RADIUS class attribute (attribute 25) as CAR parameters.
Use undo attribute 25 car to restore the default.
attribute 25 car
The RADIUS class attribute is not interpreted as CAR parameters.
RADIUS scheme view
Configure the device to interpret the RADIUS class attribute if the RADIUS server uses the attribute to deliver CAR parameters for user-based traffic monitoring and control.
The device can interpret the RADIUS class attribute only in the format of string1string2string3string4 as CAR parameters. Each string contains eight characters and each character must be a digit from 0 to 9.
After the device interprets the RADIUS class attribute sent by a RADIUS server as CAR parameters, it carries the interpreted CAR parameters in the subsequent accounting packets sent to that server besides carrying the original class attribute.
# In RADIUS scheme radius1, configure the device to interpret the RADIUS class attribute as CAR parameters.
[Sysname-radius-radius1] attribute 25 car
attribute 31 mac-format
Use attribute 31 mac-format to configure the MAC address format of the RADIUS Calling-Station-Id attribute (attribute 31).
Use undo attribute 31 mac-format to restore the default.
attribute 31 mac-format section { six | three } separator separator-character { lowercase | uppercase }
A MAC address is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
section: Specifies the number of sections that a MAC address contains.
six: Specifies the six-section format HH-HH-HH-HH-HH-HH.
three: Specifies the three-section format HHHH-HHHH-HHHH.
separator separator-character: Specifies a case-sensitive character that separates the sections.
lowercase: Specifies the letters in a MAC address to be in lower case.
uppercase: Specifies the letters in a MAC address to be in upper case.
Configure the MAC address format of the RADIUS Calling-Station-Id attribute to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, configure the MAC address format of the RADIUS Calling-Station-Id attribute as hh:hh:hh:hh:hh:hh.
[Sysname-radius-radius1] attribute 31 mac-format section six separator : lowercase
attribute 85 preferred
Use attribute 85 preferred to configure the device to prefer the real-time accounting interval assigned by the RADIUS server through the RADIUS Acct-Interim-Interval attribute (attribute 85).
Use undo attribute 85 preferred to restore the default.
The real-time accounting interval set in RADIUS scheme view takes precedence over the real-time accounting interval assigned by the server through the RADIUS Acct-Interim-Interval attribute.
RADIUS scheme view
The real-time accounting interval can be set by the timer realtime-accounting command in RADIUS scheme view or assigned by the server through the RADIUS Acct-Interim-Interval attribute. By default, a non-zero interval set in RADIUS scheme view takes precedence over the server-assigned interval. To configure the device to prefer the server-assigned interval, execute the attribute 85 preferred command.
Execution of the attribute 85 preferred command does not change the real-time accounting interval of users that have been online.
Execution of the undo attribute 85 preferred command applies the real-time accounting interval set by the timer realtime-accounting command to users that have been online.
# In RADIUS scheme radius1, configure the device to prefer the real-time accounting interval assigned by the server through the RADIUS Acct-Interim-Interval attribute.
[Sysname-radius-radius1] attribute 85 preferred
attribute 87 format
Use attribute 87 format to configure the format of the RADIUS NAS-Port-Id attribute (attribute 87).
Use undo attribute 87 format to restore the default.
attribute 87 format { custom { c-vid [ delimiter ] | interface-type [ delimiter ] | port [ delimiter ] | s-vid [ delimiter ] | slot [ delimiter ] | string string [ delimiter ] | subslot [ delimiter ] | vxlan-id [ delimiter ] } * | vendor vendor-id }
No format is configured for the RADIUS NAS-Port-Id attribute, and the attribute uses the format defined by each access module.
·          For portal authentication, the format is SlotID00IfNOVlanID, where the SlotID, IfNO, and VlanID fields are strings of 2, 3, and 9 characters, respectively.
·          For IPoE, PPP, MAC, and 802.1X authentication, the format is slot=xx;subslot=xx;port=xx;vlanid=xx;vlanid2=xx.
·          For login authentication, this attribute is empty.
RADIUS scheme view
custom: Specifies a custom format.
c-vid: Includes the inner VLAN ID of user packets.
interface-type: Includes the interface type of the access node.
port: Includes the port number of the access node.
s-vid: Includes the outer VLAN ID of user packets.
slot: Includes the slot number of the access node.
string string: Includes a custom string, a case-sensitive string of 1 to 63 characters.
subslot: Includes the subslot number of the access node.
vxlan-id: Includes the ID of the VXLAN to which a user belongs.
delimiter: Specifies a delimiter to separate attribute fields. The delimiter can be any character except a question mark (?). If you do not specify a delimiter, attribute fields are not separated.
vendor vendor-id: Specifies the format of RADIUS attribute 87 defined by a vendor. The vendor-id argument represents the ID of a vendor. The value can be 9 (Cisco) or 2636 (Juniper).
RADIUS servers of different types might have different requirements for the RADIUS NAS-Port-Id attribute format. Configure the format for this attribute to meet the requirements of the RADIUS servers.
If you specify the format of a vendor, the device constructs the NAS-Port-Id attribute as required by the vendor. Table 14 shows the formats of the NAS-Port-Id attribute defined by different vendors.
Table 14 Formats of the NAS-Port-Id attribute defined by different vendors
Vendor
Interface type
Format
Field description
2636 (Juniper)
ATM
atm slot/port.subinterface:vpi.vci
·         slot—Slot number.
·         port—Interface index.
·         subinterface—Subinterface number.
·         vpi—PVC VPI value.
·         vci —PVC VCI value.
2636 (Juniper)
Ethernet
Aggregate
For double-VLAN tagging:
interface-type slot/port.vpivci:vpi-vci (for example, gigabitEthernet 2/5.40940001:4094-1)
·         interface-type—Interface type, which can be fastEthernet, gigabitEthernet, ethernet, or trunk (aggregate).
·         slot—Slot number.
·         port—Interface number.
·         vpi—Outer VLAN ID.
·         vci—Inner VLAN ID.
The vci field preceding the colon (:) must be padded with 0s to be a string of four bits.
For single-VLAN tagging:
interface-type slot/port.subinterface:vlan (for example, gigabitEthernet 2/5.4:4)
·         slot—Slot number.
·         subinterface—Subinterface number. vlan—VLAN ID. This field is invalid in RADIUS packets on an L2TP network.
For no-VLAN tagging:
interface-type slot/port.0 (for example, gigabitEthernet 2/5.0)
·         slot—Slot number.
9 (Cisco)
Ethernet
Aggregate
ATM
interface-type slot/subslot/port (for example, ethernet 2/0/5)
·         interface-type—Interface type, ethernet, atm, or trunk (aggregate).
·         slot—Slot number.
·         subslot—Subslot number.
If you specify a custom format, the device includes the specified attribute fields in the NAS-Port-Id attribute in the sequence that the fields are specified. If you specify a delimiter in the custom format, the device uses the delimiter to separate the attribute fields.
When you configure a custom format, consider the network environment and the type of the device to avoid specifying an invalid attribute field.
The format of the RADIUS NAS-Port-Id attribute configured by this command takes precedence over the format defined by the access module.
# In RADIUS scheme rad, configure the format of the RADIUS NAS-Port-Id attribute as the format defined by Cisco.
[Sysname-radius-rad] attribute 87 format vendor 9
# In RADIUS scheme rad2, configure the format of the RADIUS NAS-Port-Id attribute as a custom format. The attribute contains the inner VLAN ID and interface type fields in sequence and uses a semicolon (;) as the delimiter.
[Sysname] radius scheme rad2
[Sysname-radius-rad2] attribute 87 format custom c-vid ; interface-type ;
attribute convert (RADIUS DAS view)
Use attribute convert to configure a RADIUS attribute conversion rule.
Use undo attribute convert to delete RADIUS attribute conversion rules.
attribute convert src-attr-name to dest-attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute convert [ src-attr-name ]
No RADIUS attribute conversion rules exist. The system processes RADIUS attributes according to the principles of the standard RADIUS protocol.
RADIUS DAS view
src-attr-name: Specifies the source RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
dest-attr-name: Specifies the destination RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
coa-ack: Specifies the CoA acknowledgment packets.
coa-request: Specifies the CoA request packets.
received: Specifies the received DAE packets.
sent: Specifies the sent DAE packets.
The device replaces the attribute in packets that match a RADIUS attribute conversion rule with the destination RADIUS attribute in the rule.
The conversion rules take effect only when the RADIUS attribute translation feature is enabled.
When you configure RADIUS attribute conversion rules, follow these restrictions and guidelines:
·          The source and destination RADIUS attributes in a rule must use the same data type.
·          The source and destination RADIUS attributes in a rule cannot use the same name.
·          A source RADIUS attribute can be converted only by one criterion, packet type or direction.
·          One source RADIUS attribute cannot be converted to multiple destination attributes.
If you do not specify a source RADIUS attribute, the undo attribute convert command deletes all RADIUS attribute conversion rules.
# In RADIUS DAS view, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute in the received DAE packets with the Connect-Info attribute.
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute convert (RADIUS scheme view)
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
access-accept: Specifies the RADIUS Access-Accept packets.
access-request: Specifies the RADIUS Access-Request packets.
accounting: Specifies the RADIUS accounting packets.
received: Specifies the received RADIUS packets.
sent: Specifies the sent RADIUS packets.
# In RADIUS scheme radius1, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute of received RADIUS packets with the User-Address-Type attribute.
[Sysname-radius-radius1] attribute convert Hw-Server-String to User-Address-Type received
attribute translate
attribute reject (RADIUS DAS view)
Use attribute reject to configure a RADIUS attribute rejection rule.
Use undo attribute reject to delete RADIUS attribute rejection rules.
attribute reject attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute reject [ attr-name ]
No RADIUS attribute rejection rules exist.
RADIUS DAS view
attr-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
Configure RADIUS attribute rejection rules for the following purposes:
·          Delete attributes from the RADIUS packets to be sent if the destination RADIUS server does not identify the attributes.
·          Ignore unwanted attributes in the RADIUS packets received from a RADIUS server.
The RADIUS attribute rejection rules take effect only when the RADIUS attribute translation feature is enabled.
A RADIUS attribute can be rejected only by one criterion, packet type or direction.
If you do not specify a RADIUS attribute, the undo attribute reject command deletes all RADIUS attribute rejection rules.
# In RADIUS DAS view, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the DAE packets to be sent.
[Sysname-radius-da-server] attribute reject Connect-Info sent
attribute translate
attribute reject (RADIUS scheme view)
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
# In RADIUS scheme radius1, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the RADIUS packets to be sent.
[Sysname-radius-radius1] attribute reject Connect-Info sent
attribute translate
attribute remanent-volume
Use attribute remanent-volume to set the data measurement unit for the Remanent_Volume attribute.
Use undo attribute remanent-volume to restore the default.
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
undo attribute remanent-volume unit
The data measurement unit is kilobyte for the Remanent_Volume attribute.
RADIUS scheme view
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
Make sure the measurement unit is the same as the user data measurement unit on the RADIUS server.
# In RADIUS scheme radius1, set the data measurement unit to kilobyte for the Remanent_Volume attribute.
[Sysname-radius-radius1] attribute remanent-volume unit kilo-byte
attribute translate
Use attribute translate to enable the RADIUS attribute translation feature.
Use undo attribute translate to disable the RADIUS attribute translation feature.
attribute translate
The RADIUS attribute translation feature is disabled.
RADIUS DAS view
RADIUS scheme view
To cooperate with RADIUS servers of different vendors, enable the RADIUS attribute translation feature. Configure RADIUS attribute conversion rules and rejection rules to ensure that RADIUS attributes in the packets exchanged between the device and the server are supported by both sides.
# Enable the RADIUS attribute translation feature for RADIUS scheme radius1.
[Sysname-radius-radius1] attribute translate
attribute vendor-id 2011 version
Use attribute vendor-id 2011 version to specify the version of the RADIUS servers with a vendor ID of 2011.
Use undo attribute vendor-id 2011 version to restore the default.
attribute vendor-id 2011 version { 1.0 | 1.1 }
The version is 1.0.
RADIUS scheme view
1.0: Specifies version 1.0.
1.1: Specifies version 1.1.
For the device to correctly interpret RADIUS attributes from the servers with a vendor ID of 2011, specify a server version the same as the actual version of the RADIUS servers.
The following table shows the differences in the way that the device interprets the vendor-specific RADIUS attributes assigned by different versions of RADIUS servers with vendor ID 2011.
RADIUS attribute
RADIUS server with version 1.0
RADIUS server with version 1.1
HW_ARRT_26_1
Upstream peak rate
Upstream burst size
HW_ARRT_26_2
Upstream average rate
HW_ARRT_26_3
N/A
Upstream peak rate
HW_ARRT_26_4
Downstream peak rate
Downstream burst size
HW_ARRT_26_5
Downstream average rate
HW_ARRT_26_6
N/A
# In RADIUS scheme radius1, specify the version of the RADIUS servers with a vendor ID of 2011 as version 1.1.
[Sysname-radius-radius1] attribute vendor-id 2011 version 1.1
client
client
Use client to specify a RADIUS DAC.
Use undo client to remove a RADIUS DAC.
client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vendor-id 2011 version { 1.0 | 1.1 } | vpn-instance vpn-instance-name ] *
undo client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
No RADIUS DACs are specified.
RADIUS DAS view
ip ipv4-address: Specifies a DAC by its IPv4 address.
ipv6 ipv6-address: Specifies a DAC by its IPv6 address.
key: Specifies the shared key for secure communication between the RADIUS DAC and DAS. Make sure the shared key is the same as the key configured on the RADIUS DAC. If the RADIUS DAC does not have any shared key, do not specify this option.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted from is a case-sensitive string of 1 to 117 characters.
vendor-id 2011: Specifies the vendor-ID of the DAC as 2011.
version: Specifies the version of the DAC.
1.0: Specifies the DAC version as version 1.0.
1.1: Specifies the DAC version as version 1.1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS DAC belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
With the RADIUS DAS feature, the device listens to the default or specified UDP port to receive DAE requests from the specified DACs. The device processes the requests and sends DAE responses to the DACs.
The device discards any DAE packets sent from DACs that are not specified for the DAS.
You can execute the client command multiple times to specify multiple DACs for the DAS.
To work with a DAC with vendor-ID 2011 and version 1.0, you do not need to specify the vendor-ID or version attribute. To work with a DAC with vendor-ID 2011 and version 1.1, you must specify the vendor-id 2011 version 1.1 keywords.
# Specify the DAC as 10.110.1.2. Set the shared key to 123456 in plaintext form for secure communication between the DAS and DAC.
[Sysname-radius-da-server] client ip 10.110.1.2 key simple 123456
port
dae-loose-check enable
Use dae-loose-check enable to enable DAE loose check.
Use undo dae-loose-check enable to disable DAE loose check.
DAE loose check is disabled. The device checks both the user identification information and device identification information in DAE requests.
RADIUS DAS view
The DAE loose check feature requires the DAS to check only part of the user identification information in a DAE request and not to check the device identification information.
As a best practice to avoid unnecessary drop of DAE requests, enable this feature when the user and device identification information on DACs are inconsistent with those on the DAS.
# Enable DAE loose check.
[Sysname-radius-da-server] dae-loose-check enable
data-flow-format (RADIUS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
RADIUS scheme view
data: Specifies the unit for data flows.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the RADIUS accounting servers. Otherwise, accounting results might be incorrect.
# In RADIUS scheme radius1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
Use display radius scheme to display RADIUS scheme configuration.
display radius scheme [ radius-scheme-name ]
radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify a RADIUS scheme, this command displays the configuration of all RADIUS schemes.
# Display the configuration of all RADIUS schemes.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: radius1
  Index : 0
  Primary authentication server:
    IP   : 2.2.2.2                                  Port: 1812
    VPN  : vpn1
    State: Active
    Test profile: 132
      Probe username: test
      Probe interval: 60 minutes
    Weight: 40
  Primary accounting server:
    IP : 1.1.1.1                                    Port: 1813
    VPN : Not configured
    State: Active
    Weight: 40
  Second authentication server:
    IP : 3.3.3.3                                    Port: 1812
    State: Block
    Test profile: Not configured
    Weight: 40
  Second accounting server:
    IP : 3.3.3.3                                    Port: 1813
    State: Block (Mandatory)
    Weight: 0
  Accounting-On function                     : Enabled
    extended function                        : Enabled
    retransmission times                     : 5
    retransmission interval(seconds)         : 2
  Timeout Interval(seconds)                  : 3
  Retransmission Times                       : 3
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(seconds)      : 22
  Stop-accounting packets buffering          : Enabled
    Retransmission times                     : 500
  NAS IP Address                             : 1.1.1.1
  Source IP address                          : 1.1.1.1
  Username format                            : with-domain
  Data flow unit                             : Megabyte
  Packet unit                                : One
  Attribute 6:
    IPoE                                     : Outbound (value-added services included)
  Attribute 15 check-mode                    : Strict
  Attribute 25                               : CAR
  Remanent-Volume threshold                  : 1024
  Attribute Remanent-Volume unit             : Mega
  Server-load-sharing                        : Enabled
  Server-load-sharing mode                   : Session-based
  Attribute 31 MAC format                    : HH-HH-HH-HH-HH-HH
  Stop-accounting-packet send-force          : Disabled
  RADIUS server version (vendor ID 2011)     : 1.1
  Attribute 87 format customized             : c-vid@interface-type/s-vid
  Authentication response pending limit      : 10
  Accounting response pending limit          : 10
  Username authorization                     : Applied
  All-server-block action                    : Attempt the top-priority server
  Attribute 5 format                         : QinQ
  Attribute 85 preferred                     : Enabled
Table 15 Command output
Index
Index number of the RADIUS scheme.
Information about the primary authentication server.
Information about the primary accounting server.
Information about the secondary authentication server.
Information about the secondary accounting server.
IP
IP address of the server. If no server is configured, this field displays Not configured.
Port
Service port number of the server. If no port number is specified, this field displays the default port number.
VPN
MPLS L3VPN instance to which the server belongs. If no VPN instance is specified for the server, this field displays Not configured.
Status of the server:
·         Active—The server is in active state.
·         Block—The server is changed to blocked state automatically.
·         Block (Mandatory)—The server is set to blocked state manually.
Test profile
Test profile used for RADIUS server status detection.
Probe username
Username used for RADIUS server status detection.
Probe interval
Server status detection interval, in minutes.
Weight
Weight value of the RADIUS server.
Whether the accounting-on feature is enabled.
extended function
Whether the extended accounting-on feature is enabled.
Number of accounting-on packet transmission attempts.
Interval at which the device retransmits accounting-on packets, in seconds.
RADIUS server response timeout period, in seconds.
Maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Maximum number of accounting attempts.
Quiet period for the servers, in minutes.
Interval for sending real-time accounting updates, in seconds.
Whether buffering of nonresponded RADIUS stop-accounting requests is enabled.
Maximum number of transmission attempts for individual RADIUS stop-accounting requests.
NAS IP Address
NAS IP address of RADIUS packets. If no NAS IP addresses are specified, this field displays Not configured.
Source IP address
Source IP address for outgoing RADIUS packets. If no source IP addresses are specified, this field displays Not configured.
VPN
MPLS L3VPN instance to which the RADIUS scheme belongs. If no VPN instance is specified for the server, this field displays Not configured.
Username format
Format for the usernames sent to the RADIUS server:
·         with-domain—Includes the domain name.
·         without-domain—Excludes the domain name.
·         keep-original—Forwards the username as the username is entered.
Data flow unit
Measurement unit for data flow.
Packet unit
Measurement unit for packets.
Attribute 6
Value of the RADIUS Service-Type attribute in outgoing RADIUS packets for IPoE users.
·         Outbound (value-added services included)—The attribute value is 5 (Outbound) in authentication and accounting requests for IPoE users and this value applies to both value-added and non-value-added services.
·         Outbound (value-added services excluded)—The attribute value is 5 (Outbound) in authentication and accounting requests for IPoE users, but this value does not apply to value-added services.
RADIUS Login-Service attribute check method for SSH, FTP, and terminal users:
·         Strict—Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively.
·         Loose—Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services.
Attribute 25
RADIUS attribute 25 interpretation status:
·         Standard—The attribute is not interpreted as CAR parameters.
·         CAR—The attribute is interpreted as CAR parameters.
Available data threshold. The unit for the threshold is the same as the data measurement unit for the RADIUS Remanent_Volume attribute.
Data measurement unit for the RADIUS Remanent_Volume attribute.
Server-load-sharing
Status of the RADIUS server load sharing feature:
·         Disabled—The feature is disabled. The device forwards traffic to the server selected based on primary and secondary server roles.
·         Enabled—The feature is enabled. The device distributes traffic among multiple servers for load sharing.
RADIUS authentication server load sharing mode:
·         Session-based.
·         Packet-based.
MAC address format for RADIUS attribute 31.
Whether the device is enabled to forcibly send stop-accounting packets when users for which no start-accounting packets are sent go offline.
Version of the RADIUS servers with a vendor ID of 2011.
Attribute 87 format vendor-specific
ID of the vendor of which the RADIUS attribute 87 format is used.
Custom format for RADIUS attribute 87.
Maximum number of pending authentication requests (requests for which no responses are received from the authentication server).
If the maximum number of pending authentication requests is not set, this field displays Not configured.
Maximum number of pending accounting requests (requests for which no responses are received from the accounting server).
If the maximum number of pending accounting requests is not set, this field displays Not configured.
Whether to allow the device to use the server-assigned usernames for AAA processes subsequent to authentication:
·         Applied—The device uses the server-assigned usernames for AAA processes subsequent to authentication.
·         Not applied—The device uses the usernames used in authentication for AAA processes subsequent to authentication.
Action to take for AAA requests when all servers in the scheme are blocked:
·         Attempt the top-priority server.
·         Skip all servers in the scheme.
Attribute 5 format
Format for the RADIUS NAS-Port attribute (attribute 5):
·         QinQ.
·         Default.
Whether the device prefers the real-time accounting interval assigned by the server through the RADIUS Acct-Interim-Interval attribute to the real-time accounting interval configured in the RADIUS scheme.
·         Enabled—Yes.
·         Disabled—No.
display radius server-load statistics
Use display radius server-load statistics to display authentication and accounting load statistics for all RADIUS servers.
This command displays the following statistics:
·          Last-5-second statistics—Total number of authentication or accounting requests sent to each RADIUS server in the last 5 seconds. From the device sends the first authentication or accounting request to a RADIUS server, it updates the number of authentication or accounting requests sent to that server every 5 seconds.
·          History statistics—Total number of authentication or accounting requests sent to each RADIUS server since the device starts up. The device increases the history statistics for a RADIUS server by 1 each time it sends an authentication or accounting request to that server. The device does not decrease the history statistics even though users go offline or the server fails to respond to a request within the timeout time.
Based on the statistics, you can adjust the load on RADIUS servers by changing the sequence in which the servers are configured or the weight values of the servers.
This command displays statistics only for RADIUS servers whose IP addresses are available or can be resolved from their host names.
The device deletes all statistics for a RADIUS server if that server is removed from a RADIUS scheme or the server's IP address, VPN instance, or service port number changes.
If an active/standby switchover occurs, the last-5-second statistics are deleted. However, the history statistics are not deleted. The history statistics might be inaccurate.
If the device reboots, both the last-5-seconds statistics and the history statistics are deleted.
# Display authentication and accounting load statistics for all RADIUS servers.
<Sysname> display radius server-load statistics
Authentication servers: 2
IP                   VPN              Port    Last 5 sec   History
1.1.1.1              N/A              1812    20           100
1::1                 ABC              1812    0            20
Accounting servers: 2
1.1.1.1              N/A              1813    20           100
1::1                 ABC              1813    0            20
Table 16 Command output
Total number of RADIUS authentication servers.
Accounting servers
Total number of RADIUS accounting servers.
IP
IP address of a RADIUS server.
VPN
MPLS L3VPN instance to which the RADIUS server belongs.
This field displays N/A if no VPN instance is specified for the server.
Port
Service port number of the RADIUS server.
Last 5 sec
Total number of RADIUS authentication or accounting requests sent to the RADIUS server within the last 5 seconds.
History
Total number of RADIUS authentication or accounting requests sent to the RADIUS server since the device starts up.
reset radius server-load statistics
display radius statistics
Use display radius statistics to display RADIUS packet statistics.
display radius statistics [ server { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-number ] { accounting | authentication } ]
server: Specifies a RADIUS server.
ip ipv4-address: Specifies the IPv4 address of the RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of the RADIUS server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
port port-number: Specifies the service port number of the RADIUS server. The value range for the UDP port number is 1 to 65535. The default authentication port number is 1812 and the default accounting port number is 1813.
accounting: Specifies the RADIUS accounting packet statistics.
authentication: Specifies the RADIUS authentication packet statistics.
Use this command to display statistics about RADIUS packets exchanged between the device and RADIUS servers, including authentication packets, accounting packets, DAE packets, and session-control packets.
If you do not specify any parameters, this command displays statistics about all types of RADIUS packets exchanged between the device and all RADIUS servers. If you specify a RADIUS server, this command displays statistics about RADIUS authentication or accounting packets exchanged between the device and the specified RADIUS server.
# Display RADIUS packet statistics for all RADIUS servers.
<Sysname> display radius statistics
                        Auth.         Acct.       SessCtrl.       DAE.
Requests:                 8             16             0            0
Retransmissions:          0             0             -             0
Start requests:           -             8             -             -
Realtime requests:        -             0             -             -
Stop requests:            -             8             -             -
Pending requests:         0             0             -             -
Packet timeouts:          0             0             -             -
Challenge packets:        0             -             -             -
Packets with responses:   0             0             0             0
Packets without responses:0             0             -             -
Reject responses:         0             -             -             -
Dropped responses:        0             0             0             0
Bad authenticator:        0             0             0             0
Terminate request:        -             -             0             0
Set policy:               -             -             0             0
Authentication servers: 1
  IP:  1.1.1.1                                  Port: 1812
  VPN:
  Authentication packets:
    Requests                 : 8          Retransmissions        : 0
    Pending requests         : 0          Packet timeouts        : 0
    Request failures         : 0          Challenge packets      : 0
    Accept responses         : 8          Reject responses       : 0
    Unknown-type responses   : 0          Malformed responses    : 0
    Bad authenticators       : 0          Dropped responses      : 0
Accounting servers: 1
  IP:  1.1.1.1                                  Port: 1813
  VPN:
  Accounting packets:
    Requests                 : 16         Retransmissions        : 0
    Start requests           : 8          Realtime requests      : 0
    Stop requests            : 8          Pending requests       : 0
    Packet timeouts          : 0          Request failures       : 0
# Display RADIUS authentication packet statistics for the RADIUS server at 1.1.1.1 with authentication port 1812.
<Sysname> display radius statistics server ip 1.1.1.1 port 1812 authentication
Table 17 Command output
Auth.
Authentication packets.
Acct.
Accounting packets.
SessCtrl.
Session-control packets.
DAE.
DAE packets.
Requests
Number of request packets.
The statistics in this field does not include retransmissions.
If the statistics of the pending requests increases, the statistics in this field also increases.
Retransmissions
Number of times that request packets were retransmitted.
The statistics of this field is not included in the statistics of the Requests field.
Start requests
Number of start-accounting request packets.
Realtime requests
Number of real-time accounting request packets.
Stop requests
Number of stop-accounting request packets.
Pending requests
Number of request packets waiting for responses.
The packets have not timed out.
Packet timeouts
Number of request packets that have timed out.
Request failures
Number of request packets that the device failed to send.
Challenge packets
Number of challenge packets.
Number of request packets for which no responses were received.
The statistics in this field increases by 1 only after all servers fail to respond to a request.
If this field displays a hyphen (-) for a type of RADIUS packets, the device does not support counting statistics for that type of RADIUS packets.
Number of packets for which responses were received.
Accept responses
Number of Access-Accept packets.
Reject responses
Number of Access-Reject packets.
Number of unknown-type response packets.
Malformed responses
Number of malformed response packets.
This field includes statistics for response packets with an invalid length, a nonexistent user, and an invalid authenticator.
Bad authenticators
Number of response packets that contain invalid authenticators.
Dropped responses
Number of response packets dropped by any reason other than Unknown-type, Malformed, and Bad authenticators.
Terminate request
Number of packets for logging off users forcibly.
Set policy
Number of packets for updating user authorization information.
Number of authentication servers.
Accounting servers
Number of accounting servers.
IP
Port
VPN
If the server belongs to the public network, this field does not display anything.
Statistics of authentication packets.
Accounting packets
Statistics of accounting packets.
reset radius statistics
display stop-accounting-buffer (for RADIUS)
Use display stop-accounting-buffer to display information about buffered RADIUS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
session-id session-id: Specifies a session by its ID. The session-id argument is a string of 1 to 64 characters and cannot contain a letter. A session ID uniquely identifies an online user for a RADIUS scheme.
time-range start-time end-time: Specifies a time range. The start time and end time must be in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd.
user-name user-name: Specifies a user by its name, a case-sensitive string of 1 to 255 characters. Whether the user-name argument should include the domain name depends on the setting configured by using the user-name-format command for the RADIUS scheme.
# Display information about nonresponded RADIUS stop-accounting requests buffered for user abc.
<Sysname> display stop-accounting-buffer user-name abc
Total entries: 2
Scheme     Session ID          Username    First sending time   Attempts
rad1       1000326232325010    abc         23:27:16-08/31/2015  19
aaa        1000326232326010    abc         23:33:01-08/31/2015  20
Table 18 Command output
Session ID
Session ID, which is the Acct-Session-Id attribute value.
First sending time
Time when the stop-accounting request was first sent.
Attempts
Number of attempts that were made to send the stop-accounting request.
reset stop-accounting-buffer (for RADIUS)
retry
retry stop-accounting (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
user-name-format (RADIUS scheme view)
exclude
Use exclude to exclude an attribute from RADIUS requests.
Use undo exclude to cancel the configuration of excluding an attribute from RADIUS requests.
exclude { accounting | authentication } name attribute-name
undo exclude { accounting | authentication } name attribute-name
No attributes are configured to be excluded from RADIUS requests.
RADIUS attribute test group view
accounting: Specifies RADIUS accounting requests.
authentication: Specifies RADIUS authentication requests.
name attribute-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The specified attribute must be an attribute that RADIUS requests carry by default. RADIUS authentication requests carry the following attributes by default: Service-Type, Framed-Protocol, NAS-Identifier, Acct-Session-Id, and NAS-Port-Type. RADIUS accounting requests carry the following attributes by default: NAS-Identifier, Acct-Delay-Time, Acct-Session-Id, and Acct-Terminate-Cause.
Use this command to exclude an attribute from RADIUS requests sent during an AAA test to help troubleshoot authentication or accounting failures.
Before you exclude an attribute that is already configured to be included in RADIUS requests, you must cancel the inclusion configuration by using the undo include command.
# In RADIUS attribute test group t1, exclude Service-Type attribute from RADIUS authentication requests.
[Sysname] radius attribute-test-group t1
[Sysname-radius-attr-test-grp-t1] exclude authentication name Service-Type
include
test-aaa
include
Use include to include an attribute in RADIUS requests.
Use undo include to cancel the configuration of including an attribute in RADIUS requests.
include { accounting | authentication } { name attribute-name | [ vendor vendor-id ] code attribute-code } type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string } value attribute-value
undo include { accounting | authentication} { name attribute-name | [ vendor vendor-id ] code attribute-code }
No attributes are configured to be included in RADIUS authentication or accounting requests.
name attribute-name: Specifies a standard RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters.
vendor vendor-id: Specifies a vendor by its ID in the range of 1 to 65535. If you do not specify a vendor, this command includes a standard attribute in RADIUS requests. The following table shows the IDs of different vendors.
Vendor
ID
Vendor
ID
Vendor
ID
HUAWEI
2011
H3C
25506
Cisco
9
Microsoft
311
3COM
43
DSL Forum
3561
China Telecom
20942
WFA
40808
Juniper
2636
CMCC
28357
code attribute-code: Specifies a RADIUS attribute by its code in the range of 1 to 255.
type: Specifies a data type for the attribute content.
binary: Binary type.
date: Date type.
integer: Integer type.
interface-id: Interface ID type.
ip: IPv4 address type.
ipv6: IPv6 address type.
ipv6-prefix: IPv6 address prefix type.
octets: Octet type.
string: String type.
value attribute-value: Specifies the value for the attribute of the data type. The value range of the attribute-value argument varies by data type.
·          For the binary type, the value is a string of 1 to 256 hexadecimal characters, which represents a binary number with a maximum of 128 bytes.
·          For the date type, the value range is 0 to 4294967295.
·          For the integer type, the value range is 0 to 4294967295.
·          For the interface ID type, the value range is 1 to ffffffffffffffff.
·          For the IPv6 address prefix type, the value is in the format of prefix/prefix-length.
·          For the octet type, the value is a string of 1 to 256 hexadecimal characters, which represents an octet number with a maximum of 126 bytes.
·          For the string type, the value of this argument is a string of 1 to 253 characters.
Usage guidelines
RADIUS requests carry some attributes by default. For these attributes, you can use the include command to change its value or the undo include command to restore its value to the default.
·          RADIUS authentication requests carry the following attributes by default: Service-Type, Framed-Protocol, NAS-Identifier, Acct-Session-Id, and NAS-Port-Type.
·          RADIUS accounting requests carry the following attributes by default: NAS-Identifier, Acct-Delay-Time, Acct-Session-Id, and Acct-Terminate-Cause.
For the accuracy of AAA tests, the value of an attribute must be of the data type specified for that attribute.
The attribute names of standard attributes saved in the configuration file will be converted to attribute codes.
Before you include an attribute that is already configured to be excluded from RADIUS requests, you must cancel the exclusion configuration by using the undo exclude command.
You can include multiple attributes in RADIUS requests. The device adds the included attributes to RADIUS packets in the order they are configured. If the length of a RADIUS request reaches 4096 bytes, the device will not add the remaining attributes to the request. As a best practice, include a reasonable number of attributes in RADIUS requests.
# In RADIUS attribute test group t1, include Calling-Station-Id attribute with value 08-00-27-00-34-D8 in RADIUS authentication requests.
[Sysname-radius-attr-test-grp-t1] include authentication name Calling-Station-Id type string value 08-00-27-00-34-d8
exclude
test-aaa
key (RADIUS scheme view)
Use key to set the shared key for secure RADIUS authentication or accounting communication.
Use undo key to delete the shared key for secure RADIUS authentication or accounting communication.
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
No shared key is configured for secure RADIUS authentication or accounting communication.
RADIUS scheme view
accounting: Specifies the shared key for secure RADIUS accounting communication.
authentication: Specifies the shared key for secure RADIUS authentication communication.
The shared keys configured by using this command apply to all servers in the scheme. Make sure the settings match the shared keys configured on the RADIUS servers.
The shared keys specified for specific RADIUS servers take precedence over the shared key specified with this command.
# In RADIUS scheme radius1, set the shared key to ok in plaintext form for secure accounting communication.
[Sysname-radius-radius1] key accounting simple ok
nas-ip (RADIUS scheme view)
Use nas-ip to specify a NAS IP address for RADIUS packets.
Use undo nas-ip to remove the NAS IP address of the specified type for RADIUS packets.
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip [ ipv6 ]
The NAS IP address of a RADIUS packet is that specified by using the radius nas-ip command in system view.
RADIUS scheme view
ipv4-address: Specifies an IPv4 address. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address and cannot be a loopback address or a link-local address.
Use this command to specify a NAS IP address for the NAS to carry in the NAS-IP-Address or NAS-IPv6-Address attribute in outgoing RADIUS packets. The NAS IP address must be unique for a RADIUS server to identify the NAS.
The NAS can also use the NAS IP address to match incoming RADIUS packets. For example, if the NAS receives a DAE request that contains a NAS IP address, it compares the NAS IP address in the request with the local NAS IP address. The NAS can process this request only when its NAS IP address is the same as the NAS IP address in the request.
You can specify the NAS IP address in interface view, RADIUS scheme view, and system view.
·          The NAS IP address specified by using the aaa nas-ip command in interface view applies only to users that access the network through the interface.
·          The NAS IP address specified by using the nas-ip command in RADIUS scheme view applies only to the RADIUS scheme.
·          The NAS IP address specified by using the radius nas-ip command in system view applies to all RADIUS schemes.
The priority order is as follows:
1.        The NAS IP address specified in interface view.
2.        The NAS IP address specified in RADIUS scheme view.
3.        The NAS IP address specified in system view.
A RADIUS scheme can have only one NAS IPv4 address and one NAS IPv6 address for RADIUS packets.
If you do not specify the ipv6 keyword for the undo nas-ip command, the command removes the configured NAS IPv4 address for RADIUS packets.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the NAS IPv4 address of RADIUS packets.
[Sysname-radius-radius1] nas-ip 10.1.1.1
aaa nas-ip
radius nas-ip
port
Use port to specify the RADIUS DAS port.
Use undo port to restore the default.
port port-number
undo port
The RADIUS DAS port number is 3799.
RADIUS DAS view
port-number: Specifies a UDP port number in the range of 1 to 65535.
The destination port in DAE packets on the DAC must be the same as the RADIUS DAS port on the DAS.
# Enable the RADIUS DAS to listen to UDP port 3790 for DAE requests.
[Sysname-radius-da-server] port 3790
client
primary accounting (RADIUS scheme view)
Use primary accounting to specify the primary RADIUS accounting server.
Use undo primary accounting to restore the default.
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS accounting server is not specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the primary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS accounting server.
port-number: Specifies the service port number of the primary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the primary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process accounting requests.
Make sure the port number and shared key settings of the primary RADIUS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN instance settings.
The shared key configured by using this command takes precedence over the shared key configured with the key accounting command.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the RADIUS scheme.
If you use the primary accounting command to modify or delete the primary accounting server to which the device is sending a start-accounting request, communication with the primary server times out.
·          When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for accounting.
·          When the RADIUS server load sharing feature is enabled, the device returns an accounting failure message rather than searching for another active accounting server.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. It does not buffer the stop-accounting requests. The device can generate incorrect accounting results.
# In RADIUS scheme radius1, specify the primary accounting server with IP address 10.110.1.2, UDP port number 1813, and plaintext shared key 123456TESTacct&!.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456TESTacct&!
secondary accounting (RADIUS scheme view)
server-load-sharing enable
vpn-instance (RADIUS scheme view)
primary authentication (RADIUS scheme view)
Use primary authentication to specify the primary RADIUS authentication server.
Use undo primary authentication to restore the default.
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS authentication server is not specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the primary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS authentication server.
port-number: Specifies the service port number of the primary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the primary RADIUS authentication server.
test-profile profile-name: Specifies a test profile for detecting the RADIUS server status. The profile-name argument is a case-sensitive string of 1 to 31 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process authentication requests.
Make sure the service port and shared key settings of the primary RADIUS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN instance settings.
The shared key configured by this command takes precedence over the shared key configured with the key authentication command.
The server status detection is triggered for the server if the specified test profile exists on the device.
If you use the primary authentication command to modify or delete the primary authentication server during an authentication process, communication with the primary server times out.
·          When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for authentication.
·          When the RADIUS server load sharing feature is enabled, the device performs the following operations:
a.    Checks the weight value and number of currently served users for each active server.
b.    Determines the most appropriate server in performance to receive an AAA request.
# In RADIUS scheme radius1, specify the primary authentication server with IP address 10.110.1.1, UDP port number 1812, and plaintext shared key 123456TESTauth&!.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple 123456TESTauth&!
radius-server test-profile
secondary authentication (RADIUS scheme view)
radius attribute extended
Use radius attribute extended to define an extended RADIUS attribute.
Use undo radius attribute extended to delete user-defined extended RADIUS attributes.
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
undo radius attribute extended [ attribute-name ]
No user-defined extended RADIUS attributes exist.
attribute-name: Specifies the RADIUS attribute name, a case-insensitive string of 1 to 63 characters. The name must be unique among all RADIUS attributes, including the standard and extended RADIUS attributes.
vendor vendor-id: Specifies a vendor ID in the range of 1 to 65535. If you do not specify a vendor ID, the device processes the RADIUS attribute as a standard RADIUS attribute. The following table shows the IDs of different vendors.
Vendor
ID
Vendor
ID
Vendor
ID
HUAWEI
2011
H3C
25506
Cisco
9
Microsoft
311
3COM
43
DSL Forum
3561
China Telecom
20942
WFA
40808
Juniper
2636
CMCC
28357
code attribute-code: Specifies the ID of the RADIUS attribute in the attribute set. The value range for the attribute-code argument is 1 to 255.
date: Date type.
octets: Octet type.
To support the proprietary RADIUS attributes of other vendors, perform the following tasks:
1.        Use this command to define the attributes as extended RADIUS attributes.
2.        Use the attribute convert command to map the extended RADIUS attributes to attributes supported by the system.
3.        Use the attribute translate command to enable the RADIUS attribute translation feature for the mappings to take effect.
To cooperate with RADIUS servers of a third-party vendor, map attributes that cannot be identified by the server to server-supported attributes.
Two RADIUS attributes cannot have the same combination of attribute name, vendor ID, and attribute ID.
If you do not specify a RADIUS attribute name, the undo radius attribute extended command deletes all user-defined extended RADIUS attributes.
# Define a string-type extended RADIUS attribute with the name Owner-Password, vendor ID 122, and attribute ID 80.
[Sysname] radius attribute extended Owner-Password vendor 122 code 80 type string
attribute translate
Use radius attribute-test-group to create a RADIUS attribute test group and enter its view, or enter the view of an existing RADIUS attribute test group.
Use undo radius attribute-test-group to remove a RADIUS attribute test group.
radius attribute-test-group attr-test-group-name
undo radius attribute-test-group attr-test-group-name
No RADIUS attribute test groups exist.
attr-test-group-name: Specifies the name of a RADIUS attribute test group, a case-insensitive string of 1 to 31 characters.
A RADIUS attribute test group is a collection of RADIUS attributes that will be included in or excluded from RADIUS requests.
The system can have multiple RADIUS attribute test groups.
# Create a RADIUS attribute test group named t1 and enter its view.
exclude
include
test-aaa
radius authentication-request first
Use radius authentication-request first to preferentially process RADIUS authentication requests
Use undo radius authentication-request first to restore the default.
The device processes RADIUS requests in the sequence that the requests are initiated.
RADIUS requests include RADIUS authentication requests, RADIUS accounting-start requests, RADIUS accounting-update requests, and RADIUS accounting-stop requests.
When a large number of users go offline and then try to come online immediately, authentication might fail for these users because of authentication request timeout. To resolve this issue, configure the device to preferentially process authentication requests.
Do not perform this task if the RADIUS server identifies users by the username and does not allow repeated authentication for the same username. A violation might cause authentication failure for users that try to come online immediately after going offline.
As a best practice, do not perform this task when the device has online users.
# Configure the device to preferentially process RADIUS authentication requests.
[Sysname] radius authentication-request first
radius dscp
Use radius dscp to change the DSCP priority of RADIUS packets.
Use undo radius dscp to restore the default.
radius [ ipv6 ] dscp dscp-value
undo radius [ ipv6 ] dscp
The DSCP priority of RADIUS packets is 0.
ipv6: Specifies the IPv6 RADIUS packets. If you do not specify this keyword, the command sets the DSCP priority for the IPv4 RADIUS packets.
dscp-value: Specifies the DSCP priority of RADIUS packets, in the range of 0 to 63. A larger value represents a higher priority.
Use this command to set the DSCP priority in the ToS field of RADIUS packets for changing their transmission priority.
# Set the DSCP priority of IPv4 RADIUS packets to 10.
[Sysname] radius dscp 10
Use radius dynamic-author server to enable the RADIUS DAS feature and enter RADIUS DAS view.
Use undo radius dynamic-author server to disable the RADIUS DAS feature.
The RADIUS DAS feature is disabled.
After you enable the RADIUS DAS feature, the device listens to the RADIUS DAS port to receive DAE packets from specified DACs.
# Enable the RADIUS DAS feature and enter RADIUS DAS view.
client
port
radius nas-ip
Use radius nas-ip to specify a NAS IP address for RADIUS packets.
Use undo radius nas-ip to remove the NAS IP address of the specified type for RADIUS packets.
radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The NAS IP address of RADIUS packets is the primary IPv4 address or the IPv6 address of the packet outbound interface.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the NAS IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network NAS IP address, do not specify this option.
You can specify a maximum of 16 NAS IP addresses in system view, including:
·          Zero or one public-network NAS IPv4 address.
·          Zero or one public-network NAS IPv6 address.
·          Private-network NAS IP addresses.
Each VPN instance can have only one private-network NAS IPv4 address and one private-network NAS IPv6 address in system view.
# Specify IP address 129.10.10.1 as the NAS IPv4 address of RADIUS packets.
[Sysname] radius nas-ip 129.10.10.1
aaa nas-ip
radius offline-reason-convert user-type ppp
Use radius offline-reason-convert user-type ppp to enable offline reason conversion for PPP users.
Use undo radius offline-reason-convert user-type ppp to disable offline reason conversion for PPP users.
Offline reason conversion is disabled for PPP users.
This command is applicable only to PPP users. It enables the device to convert user offline reason Lost Carrier (handshake failure) to User Request in RADIUS packets sent to the RADIUS server.
Use this command only to meet the definitions and requirements of user offline reasons determined by the RADIUS server.
This command does not change the user offline reasons in user offline records displayed on the device.
# Enable offline reason conversion for PPP users.
[sysname] radius offline-reason-conver user-type ppp
radius scheme
Use radius scheme to create a RADIUS scheme and enter its view, or enter the view of an existing RADIUS scheme.
Use undo radius scheme to delete a RADIUS scheme.
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
No RADIUS schemes exist.
radius-scheme-name: Specifies the RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
A RADIUS scheme can be used by more than one ISP domain at the same time.
The device supports a maximum of 16 RADIUS schemes.
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
radius session-control client
Use radius session-control client to specify a RADIUS session-control client.
Use undo radius session-control client to remove the specified RADIUS session-control clients.
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo radius session-control client { all | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
No RADIUS session-control clients are specified.
ip ipv4-address: Specifies a session-control client by its IPv4 address.
ipv6 ipv6-address: Specifies a session-control client by its IPv6 address.
key: Specifies the shared key for secure communication with the session-control client.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS session-control client belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the client is on the public network, do not specify this option.
all: Specifies all session-control clients.
To verify the session-control packets sent from a RADIUS server running on IMC, specify the RADIUS server as a session-control client to the device. The IP, VPN instance, and shared key settings of the session-control client must be the same as the corresponding settings of the RADIUS server.
You can specify multiple session-control clients on the device.
The device matches a session-control packet to a session-control client based on IP and VPN instance settings, and then uses the shared key of the matched client to validate the packet.
The device searches the session-control client settings prior to searching all RADIUS settings for finding a server with matching IP and VPN instance settings. This process narrows the search scope for finding the matched RADIUS server.
The session-control client settings take effect only when the RADIUS session-control feature is enabled.
# Specify a session-control client with IP address 10.110.1.2 and shared key 12345 in plaintext form.
[Sysname] radius session-control client ip 10.110.1.2 key simple 12345
radius session-control enable
Use radius session-control enable to enable the RADIUS session-control feature.
Use undo radius session-control enable to disable the RADIUS session-control feature.
The RADIUS session-control feature is disabled.
An H3C IMC RADIUS server uses session-control packets to deliver dynamic authorization change requests or disconnection requests to the device. The session-control feature enables the device to receive the RADIUS session-control packets on UDP port 1812.
This feature must work with H3C IMC servers.
# Enable the RADIUS session-control feature.
[Sysname] radius session-control enable
radius source-ip
Use radius source-ip to specify a source IP address for outgoing RADIUS packets.
Use undo radius source-ip to remove the source IP address of the specified type for outgoing RADIUS packets.
radius source-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius source-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
No IP address is specified as the source IP address of outgoing RADIUS packets.
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the source IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network source IP address, do not specify this option.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, a RADIUS server checks the source IP address of the packet.
·          If the source IP address belongs to a managed NAS, the server processes the packet.
·          If the source IP address does not belong to a managed NAS, the server drops the packet.
As a best practice to avoid RADIUS packet loss caused by physical port errors, specify a loopback interface address as the source IP address of outgoing RADIUS packets.
The device selects a source IP address for outgoing RADIUS packets in the following order:
1.        The source IP address specified by using the source-ip command in RADIUS scheme view.
2.        The source IP address specified by using the radius source-ip command in system view.
3.        The NAS IP address specified by using the nas-ip command in RADIUS scheme view.
4.        The NAS IP address specified by using the radius nas-ip command in system view.
5.        The IP address of the outbound interface for the outgoing RADIUS packets.
The source IP address specified in system view applies to all RADIUS schemes.
You can specify a maximum of 16 source IP addresses in system view, including:
·          Zero or one public-network source IPv4 address.
·          Zero or one public-network source IPv6 address.
·          Private-network source IP addresses.
Each VPN instance can have only one private-network source IPv4 address and one private-network source IPv6 address in system view.
# Specify IP address 129.10.10.1 as the source IPv4 address of outgoing RADIUS packets.
[Sysname] radius source-ip 129.10.10.1
radius nas-ip
source-ip (RADIUS scheme view)
Use radius-server test-profile to configure a test profile for detecting the RADIUS server status.
Use undo radius-server test-profile to delete a RADIUS test profile.
radius-server test-profile profile-name username name [ interval interval ]
undo radius-server test-profile profile-name
No RADIUS test profiles exist.
profile-name: Specifies the name of the test profile, which is a case-sensitive string of 1 to 31 characters.
username name: Specifies the username in the detection packets. The name argument is a case-sensitive string of 1 to 253 characters.
interval interval: Specifies the interval for sending a detection packet, in minutes. The value range for the interval argument is 1 to 3600, and the default value is 60.
You can execute this command multiple times to configure multiple test profiles.
If you specify a nonexistent test profile for a RADIUS server, the device does not detect the status of the server until you create the test profile on the device.
When you delete a test profile, the device stops detecting the status of the RADIUS servers that use the test profile.
# Configure a test profile named abc for RADIUS server status detection. The detection packet uses admin as the username and is sent every 10 minutes.
[Sysname] radius-server test-profile abc username admin interval 10
Use reset radius server-load statistics to clear history authentication and accounting load statistics for all RADIUS servers.
This command does not clear authentication and accounting load statistics in the last 5 seconds.
# Clear history authentication and accounting load statistics for all RADIUS servers.
<Sysname> reset radius server-load statistics
Use reset radius statistics to clear RADIUS packet statistics.
reset radius statistics [ server { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-number ] { accounting | authentication } ]
Use this command to clear statistics about RADIUS packets exchanged between the device and RADIUS servers, including authentication packets, accounting packets, DAE packets, and session-control packets.
If you do not specify any parameters, this command clears statistics about all types of RADIUS packets exchanged between the device and all RADIUS servers.
To obtain RADIUS packet statistics in a period, first use the reset radius statistics command to clear RADIUS packet statistics. After a period of time, use the display radius statistics command to display RADIUS packet statistics.
If you specify a RADIUS server, this command clears statistics about RADIUS authentication or accounting packets exchanged between the device and the specified RADIUS server. However, the clear operation does not reduce the overall statistics in the output from the display radius statistics command.
# Clear all RADIUS packet statistics.
<Sysname> reset radius statistics
# Clear RADIUS accounting packet statistics for the RADIUS server at 1.1.1.1 with accounting port 1813.
<Sysname> reset radius statistics server ip 1.1.1.1 port 1813 accounting
Use reset stop-accounting-buffer to clear buffered RADIUS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
# Clear nonresponded RADIUS stop-accounting requests buffered for user user0001@test.
<Sysname> reset stop-accounting-buffer user-name user0001@test
# Clear nonresponded RADIUS stop-accounting requests buffered from 0:0:0 to 23:59:59 on August 31, 2015.
<Sysname> reset stop-accounting-buffer time-range 0:0:0-08/31/2015 23:59:59-08/31/2015
response-pending-limit
Use response-pending-limit to set the maximum number of pending RADIUS requests (requests for which no responses are received from the RADIUS server).
Use undo response-pending-limit to cancel the maximum number configuration for the specified type of pending RADIUS requests.
response-pending-limit { accounting | authentication } max-number
undo response-pending-limit { accounting | authentication }
The number of pending RADIUS requests is not restricted.
RADIUS scheme view
accounting: Specifies pending RADIUS accounting requests.
authentication: Specifies pending RADIUS authentication requests.
max-number: Specifies the maximum number of pending RADIUS requests, in the range of 1 to 255.
This command controls the rate of RADIUS requests that are sent to the RADIUS server. Use this command if the RADIUS server has a limited performance and cannot concurrently process too many RADIUS requests.
The device has two types of pending packet counters, one for the RADIUS authentication server and the other for the RADIUS accounting server. A pending packet counter is used to record the number of sent RADIUS requests for which no responses are received from the RADIUS server. The maximum value of a pending packet counter is determined by this command.
If you set the maximum number of pending authentication or accounting requests, a pending packet counter will be started for the RADIUS authentication or accounting server.
1.        The device starts a pending packet counter for a RADIUS authentication or accounting server after sending the first authentication or accounting request to the server.
2.        The device keeps sending the corresponding type of requests to the server before the counter reaches the maximum value. The number of requests that can be sent to the server is the difference between the counter value and the maximum number.
The counter increases by 1 each time the device sends a corresponding request.
The counter decreases by 1 each time the device receives a respond from the server or the respond timeout timer for a request expires.
3.        The device buffers the subsequent requests when the counter reaches the maximum value.
If the value of the counter falls below the maximum value, the device sends the buffered requests in the sequence the requests are buffered.
If you cancel this configuration, the number of pending RADIUS authentication or accounting requests is not restricted.
The device can control the access rate only for LAN, portal, PPP, and IPoE users. The user data is saved to the cards through which the users access the device. This configuration takes effect on a card basis.
# In RADIUS scheme radius1, set the maximum number of pending RADIUS authentication requests to 100.
[Sysname-radius-radius1] response-pending-limit authentication 100
retry
Use retry to set the maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Use undo retry to restore the default.
retry retries
undo retry
The maximum number of RADIUS packet transmission attempts is 3.
RADIUS scheme view
retries: Specifies the maximum number of RADIUS packet transmission attempts, in the range of 1 to 20.
Because RADIUS uses UDP packets to transmit data, the communication is not reliable.
If the device does not receive a response to its request from the RADIUS server within the response timeout period, the device retransmits the RADIUS request. To set the response timeout period, use the timer response-timeout command.
If the device does not receive a response from the RADIUS server after the maximum number of transmission attempts is reached, the device considers the request a failure.
If the client times out during the authentication process, the user is immediately logged off. To avoid user logoffs, the value multiplied by the following items cannot be larger than the client timeout period defined by the access module:
·          The maximum number of RADIUS packet transmission attempts.
·          The RADIUS server response timeout period.
·          The number of RADIUS authentication servers in the RADIUS scheme.
When the device sends a RADIUS request to a new RADIUS server, it checks the total amount of time it has taken to transmit the RADIUS packet. If the amount of time has reached 300 seconds, the device stops sending the RADIUS request to the next RADIUS server. As a best practice, consider the number of RADIUS servers when you configure the maximum number of packet transmission attempts and the RADIUS server response timeout period.
# In RADIUS scheme radius1, set the maximum number of RADIUS packet transmission attempts to 5.
[Sysname-radius-radius1] retry 5
radius scheme
timer response-timeout (RADIUS scheme view)
retry realtime-accounting
Use retry realtime-accounting to set the maximum number of accounting attempts.
Use undo retry realtime-accounting to restore the default.
retry realtime-accounting retries
The maximum number of accounting attempts is 5.
RADIUS scheme view
retries: Specifies the maximum number of accounting attempts, in the range of 1 to 255.
Typically, a RADIUS accounting server checks whether a user is online by using a timeout timer. If the server does not receive a real-time accounting request for a user in the timeout period, it considers that a line or device failure has occurred. The server stops accounting for the user.
To work with the RADIUS server, the NAS needs to send real-time accounting requests to the server before the timer on the server expires and to keep pace with the server in disconnecting the user when a failure occurs. The NAS disconnects from a user according to the maximum number of accounting attempts and specific parameters.
For example, the following conditions exist:
·          The RADIUS server response timeout period is 3 seconds (set by using the timer response-timeout command).
·          The maximum number of RADIUS packet transmission attempts is 3 (set by using the retry command).
·          The real-time accounting interval is 12 minutes (set by using the timer realtime-accounting command).
·          The maximum number of accounting attempts is 5 (set by using the retry realtime-accounting command).
In the above case, the device generates an accounting request every 12 minutes, and retransmits the request if it sends the request but receives no response within 3 seconds. If the device receives no response after transmitting the request three times, it considers the accounting attempt a failure, and makes another accounting attempt. If five consecutive accounting attempts fail, the device cuts the user connection.
# In RADIUS scheme radius1, set the maximum number of accounting attempts to 10.
[Sysname-radius-radius1] retry realtime-accounting 10
retry
timer realtime-accounting (RADIUS scheme view)
Use retry stop-accounting to set the maximum number of transmission attempts for individual RADIUS stop-accounting requests.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retries
The maximum number of transmission attempts is 500 for individual RADIUS stop-accounting requests.
RADIUS scheme view
retries: Specifies the maximum number of transmission attempts. The value range is 10 to 65535.
The maximum number of stop-accounting request transmission attempts controls the transmission of stop-accounting requests together with the following parameters:
·          RADIUS server response timeout timer (set by using the timer response-timeout command).
·          Maximum number of times to transmit a RADIUS packet per round (set by using the retry command).
For example, the following settings exist:
·          The RADIUS server response timeout timer is 3 seconds.
·          The maximum number of times to transmit a RADIUS packet per round is five.
·          The maximum number of stop-accounting request transmission attempts is 20.
A stop-accounting request is retransmitted if the device does not receive a response within 3 seconds. When all five transmission attempts in this round are used, the device buffers the request and starts another round of retransmission. If 20 consecutive rounds of attempts fail, the device discards the request.
# Set the maximum number of stop-accounting request transmission attempts to 1000 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry stop-accounting 1000
retry
Use secondary accounting to specify a secondary RADIUS accounting server.
Use undo secondary accounting to remove a secondary RADIUS accounting server.
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary accounting [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS accounting servers are specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the secondary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary RADIUS accounting server.
port-number: Specifies the service port number of the secondary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the secondary RADIUS accounting server.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted from is a case-sensitive string of 1 to 117 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary RADIUS accounting server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The shared key configured by this command takes precedence over the shared key configured with the key accounting command.
If you use the secondary accounting command to modify or delete a secondary accounting server to which the device is sending a start-accounting request, communication with the secondary server times out.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. The device does not buffer the stop-accounting requests, either.
# In RADIUS scheme radius1, specify a secondary accounting server with IP address 10.110.1.1 and UDP port 1813.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# In RADIUS scheme radius2, specify two secondary accounting servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1813.
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
display radius scheme
Use secondary authentication to specify a secondary RADIUS authentication server.
Use undo secondary authentication to remove a secondary RADIUS authentication server.
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary authentication [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS authentication servers are specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the secondary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary RADIUS authentication server.
port-number: Sets the service port number of the secondary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the secondary RADIUS authentication server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary RADIUS authentication server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The server status detection is triggered for a server if the specified test profile exists on the device.
If you use the secondary authentication command to modify or delete a secondary authentication server during an authentication process, communication with the secondary server times out.
# In RADIUS scheme radius1, specify a secondary authentication server with IP address 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# In RADIUS scheme radius2, specify two secondary authentication servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
server-block-action
Use server-block-action to specify the action to take for AAA requests if all servers in a RADIUS scheme are blocked.
Use undo server-block-action to restore the default.
server-block-action { attempt | skip }
The device attempts to connect to the server with the highest priority in a RADIUS scheme upon receiving AAA requests if all servers in the scheme are blocked.
RADIUS scheme view
attempt: Attempts to connect to a server in the scheme. For more information about the server selection mechanism, see AAA in Security Configuration Guide.
skip: Skips all servers in the scheme and turns to the backup method.
The attempt action enables the device to preferentially use the primary AAA method. However, the device might attempt to communicate with an unavailable server, which increases the response time to AAA requests. As a best practice, specify the skip action in scenarios that require quick responses to AAA requests.
# In RADIUS scheme radius1, configure the device to skip all servers in the scheme upon receiving AAA requests if all servers in the scheme are blocked.
[Sysname] radius scheme hwt1
[Sysname-radius-radius1] server-block-action skip
retry
Use server-load-sharing enable to enable the RADIUS server load sharing feature.
Use undo server-load-sharing enable to disable the RADIUS server load sharing feature.
The RADIUS server load sharing feature is disabled.
RADIUS scheme view
Use the RADIUS server load sharing feature to dynamically distribute the workload over multiple servers regardless of their server roles. The device forwards an AAA request to the most appropriate server of all active servers in the scheme after it compares the weight values and numbers of currently served users. Specify a weight value for each RADIUS server based on the AAA capacity of the server. A larger weight value indicates a higher AAA capacity.
In RADIUS server load sharing, once the device sends a start-accounting request to a server for a user, it forwards all subsequent accounting requests of the user to the same server. If the accounting server is unreachable, the device returns an accounting failure message rather than searching for another active accounting server.
# Enable the RADIUS server load sharing feature for RADIUS scheme radius1.
[Sysname-radius-radius1] server-load-sharing enable
server-load-sharing mode
Use server-load-sharing mode to specify the RADIUS authentication server load sharing mode.
Use undo server-load-sharing mode to restore the default.
server-load-sharing mode { packet-based | session-based }
The RADIUS authentication server load sharing mode is session-based.
RADIUS scheme view
packet-based: Specifies the packet-based mode.
session-based: Specifies the session-based mode.
The RADIUS authentication server load sharing mode controls the workload distribution only for RADIUS authentication servers.
This command takes effect only when the RADIUS server load sharing feature is enabled.
When the RADIUS server load sharing feature is enabled for a RADIUS scheme, the device supports the following modes to distribute workload to authentication servers in the scheme:
·          Session-based mode—The device forwards a RADIUS authentication request to the most appropriate server among all active servers in the scheme after it compares their weights and number of concurrent sessions.
Each time the device sends an authentication request to a server, the number of current sessions to that server increases by one. Each time the device receives an authentication response from a server, the number of current sessions to that server decreases by one.
This mode is applicable to scenarios where the number of concurrent sessions is huge and the servers have similar performance.
·          Packet-based mode—The device forwards a RADIUS authentication request to the most appropriate server among all active servers in the scheme after it compares their weights and number of received authentication requests.
Each time the device sends an authentication request to a server, the number of received packets to that server increases by one.
To evenly distribute authentication requests to all active servers in the scheme, specify the packet-based RADIUS server load sharing mode.
# Specify the packet-based RADIUS authentication server load sharing mode for RADIUS scheme radius1.
[Sysname-radius-radius1] server-load-sharing mode packet-based
snmp-agent trap enable radius
Use snmp-agent trap enable radius to enable SNMP notifications for RADIUS.
Use undo snmp-agent trap enable radius to disable SNMP notifications for RADIUS.
snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
undo snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
All RADIUS SNMP notifications are disabled.
accounting-server-down: Specifies notifications to be sent when the RADIUS accounting server becomes unreachable.
accounting-server-up: Specifies notifications to be sent when the RADIUS accounting server becomes reachable.
authentication-error-threshold: Specifies notifications to be sent when the number of authentication failures exceeds the specified threshold. The threshold is represented by the ratio of the authentication failures to the total number of authentication attempts. The value range is 1 to 100, and the default value is 30. This threshold can only be configured through the MIB.
authentication-server-down: Specifies notifications to be sent when the RADIUS authentication server becomes unreachable.
authentication-server-up: Specifies notifications to be sent when the RADIUS authentication server becomes reachable.
If you do not specify any keywords, this command enables or disables all types of notifications for RADIUS.
When SNMP notifications for RADIUS are enabled, the device supports the following notifications generated by RADIUS:
·          RADIUS server unreachable notification—The RADIUS server cannot be reached. RADIUS generates this notification if it cannot receive any response to an accounting or authentication request within the specified RADIUS request transmission attempts.
·          RADIUS server reachable notification—The RADIUS server can be reached. RADIUS generates this notification for a previously blocked RADIUS server after the quiet timer expires.
·          Excessive authentication failures notification—RADIUS generates this notification when the number of authentication failures to the total number of authentication attempts exceeds the specified threshold.
# Enable the device to send RADIUS accounting server unreachable notifications.
[Sysname] snmp-agent trap enable radius accounting-server-down
source-ip
Use source-ip to specify a source IP address for outgoing RADIUS packets.
Use undo source-ip to remove the source IP address of the specified type for outgoing RADIUS packets.
undo source-ip [ ipv6 ]
The source IP address of an outgoing RADIUS packet is that specified by using the radius source-ip command in system view.
RADIUS scheme view
A RADIUS scheme can have only one source IPv4 address and one source IPv6 address for outgoing RADIUS packets.
If you do not specify the ipv6 keyword for the undo source-ip command, the command removes the configured source IPv4 address for outgoing RADIUS packets.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the source IPv4 address of outgoing RADIUS packets.
[Sysname-radius-radius1] source-ip 10.1.1.1
radius nas-ip
radius source-ip
state primary
Use state primary to set the status of a primary RADIUS server.
state primary { accounting | authentication } { active | block }
A primary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies the primary RADIUS accounting server.
authentication: Specifies the primary RADIUS authentication server.
active: Specifies the active state, the normal operation state.
block: Specifies the blocked state, the out-of-service state.
When the RADIUS server load sharing feature is disabled, the device first tries to communicate with the primary server if the primary server is in active state. If the primary server is unavailable, the device performs the following operations:
·          Changes the status of the primary server to blocked.
·          Starts a quiet timer for the server.
·          Tries to communicate with a secondary server in active state.
When the quiet timer of the primary server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active.
When the RADIUS server load sharing feature is enabled and active servers exist, the device checks the workload on each active server, and then selects the most appropriate server in performance for communication.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a primary RADIUS authentication server.
·          If you set the status of the server to blocked, the device stops detecting the status of the server.
·          If you set the status of the server to active, the device starts to detect the status of the server.
# In RADIUS scheme radius1, set the status of the primary authentication server to blocked.
[Sysname-radius-radius1] state primary authentication block
state secondary
state secondary
Use state secondary to set the status of a secondary RADIUS server.
state secondary { accounting | authentication } [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
A secondary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies a secondary RADIUS accounting server.
authentication: Specifies a secondary RADIUS authentication server.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS server.
port-number: Sets the service port number of a secondary RADIUS server. The value range for the UDP port number is 1 to 65535. The default port numbers for authentication and accounting are 1812 and 1813, respectively.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
If you do not specify an IP address, this command changes the status of all configured secondary RADIUS servers.
If the device finds that a secondary server in active state is unreachable, the device performs the following operations:
·          Changes the status of the secondary server to blocked.
·          Tries to communicate with another secondary server in active state.
When the quiet timer of a server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active. If all configured secondary servers are unreachable, the device considers the authentication or accounting attempt a failure.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a secondary RADIUS authentication server.
# In RADIUS scheme radius1, set the status of all the secondary authentication servers to blocked.
[Sysname-radius-radius1] state secondary authentication block
state primary
stop-accounting-buffer enable (RADIUS scheme view)
Use stop-accounting-buffer enable to enable buffering of RADIUS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable the buffering feature.
The device buffers the RADIUS stop-accounting requests to which no responses have been received.
RADIUS scheme view
This command enables the device to buffer a RADIUS stop-accounting request that has no response after the maximum transmission attempts (set by using the retry command) have been made. The device resends the buffered request until it receives a server response or when the number of stop-accounting request transmission attempts reaches the upper limit. If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of RADIUS stop-accounting requests to which no responses have been received.
[Sysname-radius-radius1] stop-accounting-buffer enable
display stop-accounting-buffer (for RADIUS)
reset stop-accounting-buffer (for RADIUS)
stop-accounting-packet send-force
Use stop-accounting-packet send-force to enable forcibly sending RADIUS stop-accounting packets. The device will send RADIUS stop-accounting packets when users for which no RADIUS start-accounting packets are sent go offline.
Use undo stop-accounting-packet send-force to disable forcibly sending RADIUS stop-accounting packets.
Forcibly sending RADIUS stop-accounting packets is disabled. The device does not send RADIUS stop-accounting packets when users for which no RADIUS start-accounting packets are sent go offline.
RADIUS scheme view
Typically, if the device does not send a RADIUS start-accounting packet to the RADIUS server for an authenticated user, it does not send a RADIUS stop-accounting packet when the user goes offline. If the server has generated a user entry for the user without RADIUS start-accounting packets, it does not release the user entry when the user goes offline. This feature forces the device to send RADIUS stop-accounting packets to the RADIUS server when the user goes offline for timely releasing the user entry on the server.
This feature is not applicable to ITA service scenarios.
# In RADIUS scheme radius1, enable forcibly sending RADIUS stop-accounting packets.
[Sysname-radius-radius1] stop-accounting-packet send-force
test-aaa
Use test-aaa to perform an AAA test.
test-aaa user user-name password password radius-scheme radius-scheme-name [ radius-server { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] ] [ chap | pap ] [ attribute-test-group attr-test-group-name ] [ trace ]
user user-name: Specifies the test username, a string of 1 to 80 characters. The username can be a pure username or contain a domain name. The format for a username containing a domain name is pure-username@domain-name. The pure username is case sensitive and the domain name is case insensitive.
password password: Specifies the password of the test user, a case-sensitive string of 1 to 63 characters.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-server: Specifies a RADIUS server.
ipv4-address: Specifies the IPv4 address of the RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of the RADIUS server.
port-number: Specifies the UDP port number of the RADIUS server, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
chap: Specifies the CHAP authentication method (the default).
pap: Specifies the PAP authentication method.
attribute-test-group attr-test-group-name: Specifies a RADIUS attribute test group by its name, a case-insensitive string of 1 to 31 characters. The RADIUS attribute test group defines RADIUS attributes to be carried in RADIUS requests during an AAA test. If you do not specify a RADIUS attribute test group or the specified RADIUS attribute test group does not exist, the device adds only default attributes to RADIUS requests. For more information about the default attributes carried in RADIUS requests, see AAA configuration in BRAS Configuration Guide.
trace: Displays detailed information about RADIUS packets exchanged during the AAA test. If you do not specify this keyword, the command displays brief information about the AAA test, including the sent and received packets and the test result.
Use this command to identify the reasons for the failure of interaction between the device and the AAA servers.
The device might communicate with the AAA servers incorrectly during an AAA test. Make sure no users come online or go offline during an AAA test.
If the configuration of the specified RADIUS scheme changes, the new configuration does not affect the current AAA test. The modification will take effect in the next test.
The system can have only one AAA test at a time. Another AAA test can be performed only after the current test finishes.
# Perform an AAA test and display detailed information about the test. The test uses username user1, password 123456, the CHAP authentication method, and RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test chap trace
Sent a RADIUS authentication request.
  Server  IP   : 192.168.1.110
  Source  IP   : 192.168.1.166
  VPN instance : N/A
  Server port  : 1812
  Packet type  : Authentication request
  Packet length: 118 bytes
  Packet ID    : 0
  Attribute list:
    [User-Name(1)]                 [6]   [user1]
    [CHAP-Password(3)]             [19]  [******]
    [NAS-IP-Address(4)]            [6]   [192.168.1.166]
    [Service-Type(6)]              [6]   [2] [Framed]
    [Framed-Protocol(7)]           [6]   [1] [PPP]
    [NAS-Identifier(32)]           [5]   [Sysname]
    [Acct-Session-Id(44)]          [40]  [00000008201707241008280000000c16100171]
    [CHAP-Challenge(60)]           [18]  [******]
    [NAS-Port-Type(61)]            [6]   [15] [Ethernet]
Received a RADIUS authentication response.
  VPN instance : N/A
  Server port  : 1812
  Packet type  : Access-Reject
  Packet length: 20 bytes
  Packet ID    : 0
  Reply-Message: "E63032: Incorrect password. You can retry 9 times."
Sent a RADIUS start-accounting request.
  VPN instance : N/A
  Server port  : 1813
  Packet type  : Start-accounting request
  Packet length: 63 bytes
  Packet ID    : 1
  Attribute list:
    [Acct-Status-Type(40)]          [6]   [1] [Start]
Received a RADIUS start-accounting response.
  VPN instance : N/A
  Server port  : 1813
  Packet type  : Start-accounting response
  Packet ID    : 1
Sent a RADIUS stop-accounting request.
  VPN instance : N/A
  Server port  : 1813
  Packet type  : Stop-accounting request
  Packet length: 91 bytes
  Packet ID    : 1
  Attribute list:
    [Acct-Status-Type(40)]          [6]   [2] [Stop]
    [Acct-Delay-Time(41)]           [6]   [0]
    [Acct-Terminate-Cause(49)]      [6]   [1] [User Request]
Received a RADIUS stop-accounting response.
  VPN instance : N/A
  Server port  : 1813
  Packet type  : Stop-accounting response
  Packet ID    : 1
Test result: Failed
# Perform an AAA test and display brief information about the test. The test uses username user1, password 123456 and the CHAP authentication method to test RADIUS server at 192.168.1.110 in RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test radius-server 192.168.1.110 1812
Test result: Successful
Table 19 Command output
Server IP
IP address of the server.
Source IP
Source IP address of the RADIUS packet.
VPN instance
MPLS L3VPN instance to which the server belongs. This field displays N/A if the server belongs to the public network.
Server port
UDP port number of the server.
Packet type
Type of the RADIUS packet:
·         Authentication request.
·         Access-Accept.
·         Access-Reject.
·         Start-accounting request.
·         Start-accounting response.
·         Stop-accounting request.
·         Stop-accounting response.
Packet length
Total length of the RADIUS packet, in bytes.
Packet ID
ID of the RADIUS packet. This field is used to identity a pair of request and response packets.
[attribute-name (code)]  [length]  [value] [description]
Information about a RADIUS attribute:
·         attribute-name—Name of the attribute.
·         code—Code of the attribute.
·         length—Length of the attribute, in bytes.
·         value—Value of the attribute.
·         description—Description of the attribute.
Reply-Message:
The RADIUS server rejected the authentication request and replied a message.
Test result
Result of the AAA test:
·         Successful—The test has succeeded.
·         Failed—The test has failed. If any request is rejected, the test fails.
radius scheme
threshold remanent-volume
Use threshold remanent-volume to set the available data threshold.
Use undo threshold remanent-volume to restore the default.
threshold remanent-volume threshold-value
The available data threshold is 0.
RADIUS scheme view
threshold-value: Specifies the available data threshold, in the range of 0 to 4294967295. The unit is set by using the attribute remanent-volume unit command.
Use this command if the RADIUS server divides the total data quota of an authenticated user into multiple equal portions and assigns one portion to the user each time. When the user's available data on the device reaches the threshold, the device sends a realtime accounting request to the RADIUS server to apply for a new portion. This process continues till the user uses up the total data quota.
# In RADIUS scheme radius1, set the available data threshold to 2048 MB.
[Sysname-radius-radius1] threshold remanent-volume 2048
[Sysname-radius-radius1] attribute remanent-volume unit mega-byte
timer quiet (RADIUS scheme view)
Use timer quiet to set the quiet timer for the servers specified in a RADIUS scheme.
Use undo timer quiet to restore the default.
timer quiet minutes
undo timer quiet
The server quiet timer period is 5 minutes in a RADIUS scheme.
RADIUS scheme view
minutes: Specifies the server quiet period in minutes, in the range of 1 to 255.
Make sure the server quiet timer is set correctly.
A timer that is too short might result in frequent authentication or accounting failures. This is because the device will continue to attempt to communicate with an unreachable server that is in active state.
A timer that is too long might temporarily block a reachable server that has recovered from a failure. This is because the server will remain in blocked state until the timer expires.
# In RADIUS scheme radius1, set the quiet timer to 10 minutes for the servers.
[Sysname-radius-radius1] timer quiet 10
Use timer realtime-accounting to set the real-time accounting interval.
Use undo timer realtime-accounting to restore the default.
timer realtime-accounting interval [ second ]
The real-time accounting interval is 12 minutes.
RADIUS scheme view
interval: Specifies the real-time accounting interval in the range of 0 to 71582.
second: Specifies the measurement unit as second. If you do not specify this keyword, the real-time accounting interval is measured in minutes.
When the real-time accounting interval on the device is not zero, the device sends online user accounting information to the RADIUS accounting server at the configured interval.
When the real-time accounting interval on the device is zero, the device sends online user accounting information to the RADIUS accounting server at the real-time accounting interval configured on the server. If the real-time accounting interval is not configured on the server, the device does not send online user accounting information.
A short interval helps improve accounting precision but requires many system resources.
Table 20 Recommended real-time accounting intervals
Number of users
Real-time accounting interval
1 to 99
3 minutes
100 to 499
6 minutes
500 to 999
12 minutes
1000 or more
15 minutes or longer
When you modify the real-time accounting interval, the following rules apply to users that have been online before the modification:
·          If you modify the real-time accounting interval from a non-zero value to zero or from zero to a non-zero value, the modification does not take effect on these users. These users still use the old real-time accounting interval.
·          If you modify the real-time accounting interval from a non-zero value to another non-zero value, the modification takes effect immediately on these users.
If the device performs RADIUS accounting for a user but not RADIUS authentication or authorization, only the real-time accounting interval set in the user's RADIUS accounting scheme takes effect. The real-time accounting interval assigned by the RADIUS accounting server does not take effect.
The device sends a start-accounting packet for a dual-stack user after the user obtains an IP address of one stack. No matter how long the real-time accounting interval is, the device sends an update-accounting packet for the user immediately after the user obtains an IP address of another stack.
# In RADIUS scheme radius1, set the real-time accounting interval to 51 minutes.
[Sysname-radius-radius1] timer realtime-accounting 51
Use timer response-timeout to set the RADIUS server response timeout timer.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The RADIUS server response timeout period is 3 seconds.
RADIUS scheme view
seconds: Specifies the RADIUS server response timeout period, in the range of 1 to 10 seconds.
If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request, it resends the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
·          The number of RADIUS servers in the RADIUS scheme.
# In RADIUS scheme radius1, set the RADIUS server response timeout timer to 5 seconds.
[Sysname-radius-radius1] timer response-timeout 5
retry
trust ip
Use trust ip to configure a trusted IPv4 DAC.
Use undo trust ip to remove a trusted IPv4 DAC.
trust ip ipv4-address [ vpn-instance vpn-instance-name ]
undo trust ip ipv4-address [ vpn-instance vpn-instance-name ]
No trusted IPv4 DACs are configured.
RADIUS DAS view
ipv4-address: Specifies the IPv4 address of a DAC, which cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the DAC belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the DAC belongs to the public network.
On a DAE proxy network, the DAE proxy checks the legitimacy of DAE requests received from DACs and it sends only legitimate DAE requests to the DAS. To exempt DAE requests from a DAC from being checked, you can configure the DAC as a trusted DAC. In this way, the DAE proxy directly sends DAE requests from the DAC to the DAS. This reduces the burden of the DAE proxy.
You can repeat this command to configure multiple trusted IPv4 DACs.
# Configure the DAC at 10.110.1.2 as a trusted IPv4 DAC.
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] trust ip 10.110.1.2
trust ipv6
trust ipv6
Use trust ipv6 to configure a trusted IPv6 DAC.
Use undo trust ipv6 to remove a trusted IPv6 DAC.
trust ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
undo trust ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
No trusted IPv6 DACs are configured.
RADIUS DAS view
ipv6 ipv6-address: Specifies the IPv6 address of a DAC, which must be a unicast address and cannot be a loopback address or a link-local address.
You can repeat this command to configure multiple trusted IPv6 DACs.
# Configure the DAC at 10:110::1:2 as a trusted IPv6 DAC.
[Sysname-radius-da-server] trust ipv6 10:110::1:2
trust ip
user-name-format (RADIUS scheme view)
Use user-name-format to specify the format of the username to be sent to a RADIUS server.
Use undo user-name-format to restore the default.
user-name-format { keep-original | with-domain | without-domain }
The ISP domain name is included in the usernames sent to a RADIUS server.
RADIUS scheme view
keep-original: Sends the username to the RADIUS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
A username is generally in the userid@isp-name format, of which the isp-name part is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username sent to a RADIUS server.
If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the RADIUS server will consider two users in different ISP domains but with the same userid as one user.
For 802.1X users using EAP authentication, the user-name-format command configured for a RADIUS scheme does not take effect. The device does not change the usernames from clients before forwarding them to the RADIUS server.
# In RADIUS scheme radius1, configure the device to remove the domain name from the usernames sent to the RADIUS servers.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] user-name-format without-domain
username-authorization apply
Use username-authorization apply to configure the device to use server-assigned usernames for AAA processes subsequent to authentication.
Use undo username-authorization apply to restore the default.
The device uses the usernames used in authentication for AAA processes subsequent to authentication.
RADIUS scheme view
A RADIUS server might add the User-Name attribute in an Access-Accept response. This feature enables the device to notify the access module of the User-Name attribute and use the server-assigned username for AAA processes subsequent to authentication. For example, the device includes the username in start-accounting requests sent to the RADIUS server and displays the username in command output instead of the username used in authentication.
The username assigned by the RADIUS server is different from the username used in authentication. How a server-assigned username is encapsulated in the RADIUS User-Name attribute by the device depends on the username format configuration in the RADIUS scheme.
·          If the username format is keep-original, the username is encapsulated without any change.
·          If the username format is without-domain, the username is encapsulated without any domain name.
·          If the username format is with-domain, the username is encapsulated with the authentication domain name. If the server-assigned username contains a domain name other than the authentication domain name, the device replaces the domain name with the authentication domain name.
This command takes effect only on IPoE users.
If this command is used, the usernames in IPoE user information displayed by using the display ip subscriber command are the usernames assigned by the RADIUS server.
# In RADIUS scheme radius1, configure the device to use server-assigned usernames for AAA processes subsequent to authentication.
[Sysname-radius-radius1] username-authorization apply
vpn-instance (RADIUS scheme view)
Use vpn-instance to specify an MPLS L3VPN instance for a RADIUS scheme.
Use undo vpn-instance to restore the default.
undo vpn-instance
The RADIUS scheme belongs to the public network.
RADIUS scheme view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
The VPN instance specified for a RADIUS scheme applies to all authentication and accounting servers in that scheme. If a VPN instance is also configured for an individual RADIUS server, the VPN instance specified for the RADIUS scheme does not take effect on that server.
# Specify VPN instance test for RADIUS scheme radius1.
[Sysname-radius-radius1] vpn-instance test
HWTACACS commands
data-flow-format (HWTACACS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
data: Specifies the unit for data flows.
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the HWTACACS accounting servers. Otherwise, accounting results might be incorrect.
# In HWTACACS scheme hwt1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
display hwtacacs scheme
Use display hwtacacs scheme to display the configuration or statistics of HWTACACS schemes.
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an HWTACACS scheme, this command displays the configuration of all HWTACACS schemes.
statistics: Displays the HWTACACS service statistics. If you do not specify this keyword, the command displays the configuration of the specified HWTACACS scheme.
# Display the configuration of all HWTACACS schemes.
<Sysname> display hwtacacs scheme
Total 1 HWTACACS schemes
HWTACACS scheme name: hwtac
  Index : 0
  Primary authentication server:
    IP  : 2.2.2.2         Port: 49     State: Active
    VPN Instance: 2
    Single-connection: Enabled
  Primary authorization server:
    VPN Instance: 2
    Single-connection: Disabled
  Primary accounting server:
    IP  : Not Configured  Port: 49     State: Block
    VPN Instance: Not configured
  VPN Instance                          : 2
  NAS IP Address                        : 2.2.2.3
  Server Quiet Period(minutes)          : 5
  Realtime Accounting Interval(minutes) : 12
  Stop-accounting packets buffering     : Enabled
    Retransmission times                : 100
  Response Timeout Interval(seconds)    : 5
  Username Format                       : with-domain
  Data flow unit                        : Byte
  Packet unit                           : One
Table 21 Command output
Index
Index number of the HWTACACS scheme.
Primary HWTACACS authentication server.
Primary HWTACACS authorization server.
Primary HWTACACS accounting server.
Secondary authentication server
Secondary HWTACACS authentication server.
Secondary authorization server
Secondary HWTACACS authorization server.
Secondary accounting server
Secondary HWTACACS accounting server.
IP
IP address of the HWTACACS server. If no server is configured, this field displays Not configured.
Port
Service port of the HWTACACS server. If no port configuration is performed, this field displays the default port number.
Status of the HWTACACS server: active or blocked.
VPN Instance
MPLS L3VPN instance to which the HWTACACS server or scheme belongs. If no VPN instance is specified for the server or scheme, this field displays Not configured.
Single-connection
Single connection status:
·         Enabled—Establish only one TCP connection for all users to communicate with the server.
·         Disabled—Establish a TCP connection for each user to communicate with the server.
NAS IP Address
Source IP address for outgoing HWTACACS packets.
Quiet period for the primary servers, in minutes.
Real-time accounting interval, in minutes.
Whether buffering of nonresponded HWTACACS stop-accounting requests is enabled.
Maximum number of transmission attempts for individual HWTACACS stop-accounting requests.
HWTACACS server response timeout period, in seconds.
Username Format
Format for the usernames sent to the HWTACACS server:
·         with-domain—Includes the domain name.
·         without-domain—Excludes the domain name.
·         keep-original—Forwards the username as the username is entered.
Data flow unit
Measurement unit for data flows:
·         Byte.
·         Kilobyte.
·         Megabyte.
·         Gigabyte.
Packet unit
Measurement unit for packets:
·         One.
·         Kilo.
·         Mega.
·         Giga.
# Display statistics for HWTACACS scheme tac.
<Sysname> display hwtacacs scheme tac statistics
HWTACACS scheme name: tac
  Primary authentication server: 3.3.3.3
    Round trip time:                               0 seconds
    Request packets:                               1
    Login request packets:                         1
    Change-password request packets:               0
    Request packets including plaintext password:  0
    Request packets including ciphertext password: 0
    Response packets:                              2
    Pass response packets:                         1
    Failure response packets:                      0
    Get-data response packets:                     0
    Get-username response packets:                 0
    Get-password response packets:                 1
    Restart response packets:                      0
    Error response packets:                        0
    Follow response packets:                       0
    Malformed response packets:                    0
    Continue packets:                              1
    Continue-abort packets:                        0
    Pending request packets:                       0
    Timeout packets:                               0
    Unknown type response packets:                 0
    Dropped response packets:                      0
  Primary authorization server: 3.3.3.3
    Round trip time:                               1 seconds
    Request packets:                               1
    Response packets:                              1
    PassAdd response packets:                      1
    PassReply response packets:                    0
    Timeout packets:                               0
  Primary accounting server: 3.3.3.3
    Request packets:                               2
    Accounting start request packets:              1
    Accounting stop request packets:               1
    Accounting update request packets:             0
    Response packets:                              2
    Success response packets:                      2
    Timeout response packets:                      0
Table 22 Command output
Round trip time
Time between the device processes the latest pair of request and response, in seconds.
Request packets
Number of sent requests.
Response packets
Number of received responses.
Number of responses for authentication or authorization failure.
Number of error authentication responses.
Number of follow authentication responses.
Number of invalid responses.
Number of requests for which the device waits for responses.
Timeout packets
Number of requests that timed out.
Number of unknown responses.
Number of dropped responses.
Number of sent packets that request to log in to the device.
Number of sent packets that request to change user passwords.
Request packets including plaintext passwords
Number of sent requests that include user passwords in plaintext form.
Request packets including ciphertext passwords
Number of requests that include user passwords in encrypted form.
Number of responses that indicate users pass authentication.
Number of responses that get data.
Number of responses that get usernames.
Number of responses that get user passwords.
Number of responses that indicate reauthentication.
Continue packets
Number of sent continue packets.
Number of sent continue-abort packets.
Number of received PassAdd responses. This type of responses indicate that the server agrees to assign all requested authorization attributes and adds other authorization attributes.
Number of received PassReply responses. This type of responses indicate that the server uses the authorization attributes in the responses to replace the requested authorization attributes.
Number of sent start-accounting requests.
Number of sent stop-accounting requests.
Number of sent accounting-update requests.
Number of received responses that indicate accounting success.
reset hwtacacs statistics
display stop-accounting-buffer (for HWTACACS)
Use display stop-accounting-buffer to display information about buffered HWTACACS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
# Display information about nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total entries: 2
Scheme    IP address        Username      First sending time     Attempts
hwt1      192.168.100.1     abc           23:27:16-08/31/2015    19
hwt1      192.168.90.6      bob           23:33:01-08/31/2015    20
Table 23 Command output
First sending time
Time when the stop-accounting request was first sent.
Attempts
Number of attempts that were made to send the stop-accounting request.
reset stop-accounting-buffer (for HWTACACS)
retry stop-accounting (HWTACACS scheme view)
stop-accounting-buffer enable (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
hwtacacs nas-ip
Use hwtacacs nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo hwtacacs nas-ip to delete a source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The source IP address of an HWTACACS packet sent to the server is the primary IP address of the outbound interface.
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the source IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network source IP address, do not specify this option.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, an HWTACACS server checks whether the source IP address of the packet is the IP address of a managed NAS.
·          If the source IP address of the packet is the IP address of a managed NAS, the server processes the packet.
·          If the source IP address of the packet is not the IP address of a managed NAS, the server drops the packet.
As a best practice, specify a loopback interface address as the source IP address for outgoing HWTACACS packets to avoid HWTACACS packet loss caused by physical port errors.
If you use both the nas-ip command and hwtacacs nas-ip command, the following guidelines apply:
·          The setting configured by using the nas-ip command in HWTACACS scheme view applies only to the HWTACACS scheme.
·          The setting configured by using the hwtacacs nas-ip command in system view applies to all HWTACACS schemes.
·          The setting in HWTACACS scheme view takes precedence over the setting in system view.
You can specify a maximum of 16 source IP addresses in system view, including:
·          Zero or one public-network source IPv4 address.
·          Zero or one public-network source IPv6 address.
·          Private-network source IP addresses.
Each VPN instance can have only one private-network source IPv4 address and one private-network source IPv6 address in system view.
# Specify IP address 129.10.10.1 as the source address for HWTACACS packets.
[Sysname] hwtacacs nas-ip 129.10.10.1
nas-ip (HWTACACS scheme view)
hwtacacs scheme
Use hwtacacs scheme to create an HWTACACS scheme and enter its view, or enter the view of an existing HWTACACS scheme.
Use undo hwtacacs scheme to delete an HWTACACS scheme.
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
No HWTACACS schemes exist.
hwtacacs-scheme-name: Specifies the HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
An HWTACACS scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 HWTACACS schemes.
# Create an HWTACACS scheme named hwt1 and enter HWTACACS scheme view.
key (HWTACACS scheme view)
Use key to set the shared key for secure HWTACACS authentication, authorization, or accounting communication.
Use undo key to delete the shared key for secure HWTACACS authentication, authorization, or accounting communication.
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization }
No shared key is configured for secure HWTACACS authentication, authorization, or accounting communication.
accounting: Specifies the shared key for secure HWTACACS accounting communication.
authentication: Specifies the shared key for secure HWTACACS authentication communication.
authorization: Specifies the shared key for secure HWTACACS authorization communication.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 255 characters. Its encrypted from is a case-sensitive string of 1 to 373 characters.
The shared keys configured on the device must match those configured on the HWTACACS servers.
# In HWTACACS scheme hwt1, set the shared key to 123456TESTauth&! in plaintext form for secure HWTACACS authentication communication.
[Sysname-hwtacacs-hwt1] key authentication simple 123456TESTauth&!
# Set the shared key to 123456TESTautr&! in plaintext form for secure HWTACACS authorization communication.
[Sysname-hwtacacs-hwt1] key authorization simple 123456TESTautr&!
# Set the shared key to 123456TESTacct&! in plaintext form for secure HWTACACS accounting communication.
[Sysname-hwtacacs-hwt1] key accounting simple 123456TESTacct&!
Use nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo nas-ip to delete the source IP address of the specified type for outgoing HWTACACS packets.
undo nas-ip [ ipv6 ]
The source IP address of an outgoing HWTACACS packet is that configured by using the hwtacacs nas-ip command in system view.
If the hwtacacs nas-ip command is not configured, the source IP address is the primary IP address of the outbound interface.
You can specify only one source IPv4 address and one source IPv6 address for an HWTACACS scheme.
If you do not specify the ipv6 keyword for the undo nas-ip command, the command deletes the configured source IPv4 address for outgoing HWTACACS packets.
# In HWTACACS scheme hwt1, specify IP address 10.1.1.1 as the source address for outgoing HWTACACS packets.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
hwtacacs nas-ip
primary accounting (HWTACACS scheme view)
Use primary accounting to specify the primary HWTACACS accounting server.
Use undo primary accounting to restore the default.
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS accounting server is not specified.
ipv4-address: Specifies an IPv4 address of the primary HWTACACS accounting server.
ipv6 ipv6-address: Specifies an IPv6 address of the primary HWTACACS accounting server.
port-number: Specifies the service port number of the primary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS accounting server.
single-connection: The device and the primary HWTACACS accounting server use the same TCP connection to exchange accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the primary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN instance settings.
As a best practice, specify the single-connection keyword to reduce TCP connections for improving system performance if the HWTACACS server supports the single-connection method.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the HWTACACS scheme.
You can remove an accounting server only when it is not used for user accounting. Removing an accounting server affects only accounting processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] primary accounting 10.163.155.12 49 key simple 123456TESTacct&!
secondary accounting (HWTACACS scheme view)
vpn-instance (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
Use primary authentication to specify the primary HWTACACS authentication server.
Use undo primary authentication to restore the default.
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authentication server is not specified.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authentication server.
port-number: Specifies the service port number of the primary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authentication server.
single-connection: The device and the primary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authentication packets with the primary authentication server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN instance settings.
You can remove an authentication server only when it is not used for user authentication. Removing an authentication server affects only authentication processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple 123456TESTauth&!
secondary authentication (HWTACACS scheme view)
primary authorization
Use primary authorization to specify the primary HWTACACS authorization server.
Use undo primary authorization to restore the default.
primary authorization { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authorization server is not specified.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authorization server.
port-number: Specifies the service port number of the primary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authorization server.
single-connection: The device and the primary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the primary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authorization server are the same as those configured on the server.
Two authorization servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN instance settings.
You can remove an authorization server only when it is not used for user authorization. Removing an authorization server affects only authorization processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple 123456TESTautr&!
secondary authorization (HWTACACS scheme view)
Use reset hwtacacs statistics to clear HWTACACS statistics.
reset hwtacacs statistics { accounting | all | authentication | authorization }
accounting: Clears the HWTACACS accounting statistics.
all: Clears all HWTACACS statistics.
authentication: Clears the HWTACACS authentication statistics.
authorization: Clears the HWTACACS authorization statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
Use reset stop-accounting-buffer to clear buffered HWTACACS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
# Clear nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
Use retry stop-accounting to set the maximum number of transmission attempts for individual HWTACACS stop-accounting requests.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retries
The maximum number of transmission attempts for individual HWTACACS stop-accounting requests is 100.
retries: Specifies the maximum number of transmission attempts for HWTACACS stop-accounting requests. The value range is 1 to 300.
# In HWTACACS scheme hwt1, set the maximum number of HWTACACS stop-accounting attempts to 300.
[Sysname-hwtacacs-hwt1] retry stop-accounting 300
timer response-timeout (HWTACACS scheme view)
Use secondary accounting to specify a secondary HWTACACS accounting server.
Use undo secondary accounting to remove a secondary HWTACACS accounting server.
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary accounting [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary HWTACACS accounting servers are specified.
ipv4-address: Specifies the IPv4 address of the secondary HWTACACS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary HWTACACS accounting server.
port-number: Specifies the service port number of the secondary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS accounting server.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
single-connection: The device and the secondary HWTACACS accounting server use the same TCP connection to exchange all accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the secondary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS accounting server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary accounting command, the command removes all secondary accounting servers.
# In HWTACACS scheme hwt1, specify a secondary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple 123456TESTacct&!
Use secondary authentication to specify a secondary HWTACACS authentication server.
Use undo secondary authentication to remove a secondary HWTACACS authentication server.
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number I key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authentication [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary HWTACACS authentication servers are specified.
ipv4-address: Specifies the IPv4 address of the secondary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary HWTACACS authentication server.
port-number: Specifies the service port number of the secondary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authentication server.
single-connection: The device and the secondary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authentication packets with the secondary authentication server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary HWTACACS authentication server are the same as those configured on the corresponding server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authentication command, the command removes all secondary authentication servers.
# In HWTACACS scheme hwt1, specify a secondary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple 123456TESTauth&!
Use secondary authorization to specify a secondary HWTACACS authorization server.
Use undo secondary authorization to remove a secondary HWTACACS authorization server.
secondary authorization { ipv4-address | ipv6 ipv6-address } [ port-number I key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authorization [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] *
No secondary HWTACACS authorization servers are specified.
ipv4-address: Specifies the IPv4 address of the secondary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary HWTACACS authorization server.
port-number: Specifies the service port number of the secondary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authorization server.
single-connection: The device and the secondary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the secondary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS authorization server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authorization servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authorization command, the command removes all secondary authorization servers.
# In HWTACACS scheme hwt1, specify a secondary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple 123456TESTautr&!
primary authorization (HWTACACS scheme view)
Use stop-accounting-buffer enable to enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable buffering of HWTACACS stop-accounting requests to which no responses have been received.
The device buffers HWTACACS stop-accounting requests to which no responses have been received.
This command enables the device to buffer an HWTACACS stop-accounting request to which no response has been received. The device resends the buffered request until it receives a server response or when the number of transmission attempts reaches the maximum (set by using the retry stop-accounting command). If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet (HWTACACS scheme view)
Use timer quiet to set the quiet timer for the servers specified in an HWTACACS scheme.
timer quiet minutes
undo timer quiet
The server quiet period is 5 minutes.
# In HWTACACS scheme hwt1, set the server quiet timer to 10 minutes.
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting minutes
minutes: Specifies the real-time accounting interval in minutes, in the range of 0 to 60. Setting this interval to 0 disables the device from sending online user accounting information to the HWTACACS accounting server.
For real-time accounting, a NAS must transmit the accounting information of online users to the HWTACACS accounting server periodically. This command is used to set the interval.
Table 24 Recommended real-time accounting intervals
Number of users
1 to 99
3 minutes
100 to 499
6 minutes
500 to 999
12 minutes
1000 or more
# In HWTACACS scheme hwt1, set the real-time accounting interval to 51 minutes.
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
Use timer response-timeout to set the HWTACACS server response timeout timer.
The HWTACACS server response timeout time is 5 seconds.
seconds: Specifies the HWTACACS server response timeout time, in the range of 1 to 300 seconds.
HWTACACS is based on TCP. When the server response timeout timer or the TCP timeout timer times out, the device is disconnected from the HWTACACS server.
The client timeout period of the associated access module cannot be shorter than the total response timeout timer of all HWTACACS servers in the scheme. Any violation will result in user logoffs before the authentication, authorization, or accounting process is complete.
# In HWTACACS scheme hwt1, set the HWTACACS server response timeout timer to 30 seconds.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
Use user-name-format to specify the format of the username to be sent to an HWTACACS server.
The ISP domain name is included in the usernames sent to an HWTACACS server.
keep-original: Sends the username to the HWTACACS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
A username is generally in the userid@isp-name format, of which the isp-name part is used by the device to determine the ISP domain to which a user belongs. However, some HWTACACS servers cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such an HWTACACS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to an HWTACACS server.
If an HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the HWTACACS server will consider two users in different ISP domains but with the same userid as one user.
# In HWTACACS scheme hwt1, configure the device to remove the ISP domain name from the usernames sent to the HWTACACS servers.
[Sysname-hwtacacs-hwt1] user-name-format without-domain
Use vpn-instance to specify an MPLS L3VPN instance for an HWTACACS scheme.
undo vpn-instance
The HWTACACS scheme belongs to the public network.
The VPN instance specified for an HWTACACS scheme applies to all servers in that scheme. If a VPN instance is also configured for an individual HWTACACS server, the VPN instance specified for the HWTACACS scheme does not take effect on that server.
# Specify VPN instance test for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] vpn-instance test
LDAP commands
attribute-map
Use attribute-map to specify the LDAP attribute map in an LDAP scheme.
Use undo attribute-map to restore the default.
attribute-map map-name
undo attribute-map
An LDAP scheme does not use an LDAP attribute map in an LDAP scheme.
LDAP scheme view
map-name: Specifies an LDAP attribute map by its name, a case-insensitive string of 1 to 31 characters.
When the LDAP scheme used for authorization contains an LDAP attribute map, the device converts server-assigned LDAP attributes to device-recognizable AAA attributes based on the mapping entries.
You can specify only one LDAP attribute map in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
If you specify another attribute map or change the mapping entries, the new settings are effective only on the LDAP authorization that occurs after your operation.
# Specify LDAP attribute map map1 in LDAP scheme test.
[Sysname] ldap scheme test
[Sysname-ldap-test] attribute-map map1
display ldap-scheme
ldap attribute-map
authentication-server
Use authentication-server to specify the LDAP authentication server for an LDAP scheme.
Use undo authentication-server to restore the default.
authentication-server server-name
No LDAP authentication server is specified for an LDAP scheme.
LDAP scheme view
server-name: Specifies the name of an LDAP server, a case-insensitive string of 1 to 64 characters.
You can specify only one LDAP authentication server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authentication server as ccc.
[Sysname] ldap scheme ldap1
[Sysname-ldap-ldap1] authentication-server ccc
display ldap scheme
ldap server
authorization-server
Use authorization-server to specify the LDAP authorization server for an LDAP scheme.
Use undo authorization-server to restore the default.
authorization-server server-name
No LDAP authorization server is specified for an LDAP scheme.
LDAP scheme view
You can specify only one LDAP authorization server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authorization server as ccc.
[Sysname-ldap-ldap1] authorization-server ccc
display ldap scheme
ldap server
display ldap scheme
Use display ldap scheme to display LDAP scheme configuration.
display ldap scheme [ ldap-scheme-name ]
ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an LDAP scheme, this command displays the configuration of all LDAP schemes.
# Display the configuration of all LDAP schemes.
<Sysname> display ldap scheme
Total 1 LDAP schemes
LDAP scheme name             : aaa
  Authentication server      : aaa
    IP                       : 1.1.1.1
    Port                     : 111
    VPN instance             : Not configured
    LDAP protocol version    : LDAPv3
    Server timeout interval  : 10 seconds
    Login account DN         : Not configured
    Base DN                  : Not configured
    Search scope             : all-level
    User searching parameters:
      User object class      : Not configured
      Username attribute     : cn
      Username format        : with-domain
  Authorization server       : aaa
    IP                       : 1.1.1.1
    Port                     : 111
  Attribute map              : map1
Table 25 Command output
Name of the LDAP authentication server. If no server is configured, this field displays Not configured.
Name of the LDAP authorization server. If no server is configured, this field displays Not configured.
IP
IP address of the LDAP server. If no server is specified, this field displays Not configured.
Port
Port number of the server. If no port number is specified, this field displays the default port number.
VPN instance
MPLS L3VPN instance to which the LDAP server belongs. If no VPN instance is specified, this field displays Not configured.
LDAP version, LDAPv2 or LDAPv3.
LDAP server timeout period, in seconds.
Login account DN
DN of the administrator.
Base DN
Base DN for user search.
Search scope
User DN search scope, including:
·         all-level—All subdirectories.
·         single-level—Next lower level of subdirectories under the base DN.
User search parameters.
User object class
User object class for user DN search. If no user object class is configured, this field displays Not configured.
Username attribute
User account attribute for login.
Username format
Format for the username sent to the server.
Attribute map
LDAP attribute map used by the scheme. If no LDAP attribute map is used, this field displays Not configured.
ip
Use ip to configure the IP address of the LDAP server.
Use undo ip to restore the default.
ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ip
An LDAP server does not have an IP address.
LDAP server view
ip-address: Specifies the IP address of the LDAP server.
port port-number: Specifies the TCP port number of the LDAP server. The value range for the port-number argument is 1 to 65535, and the default value is 389.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the LDAP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
The LDAP service port configured on the device must be consistent with the service port of the LDAP server.
If you change the IP address and port number of the LDAP server, the change is effective only on the LDAP authentication that occurs after the change.
# Specify the IP address and port number as 192.168.0.10 and 4300 for LDAP server ccc.
[Sysname] ldap server ccc
[Sysname-ldap-server-ccc] ip 192.168.0.10 port 4300
ldap server
ipv6
Use ipv6 to configure the IPv6 address of the LDAP server.
Use undo ipv6 to restore the default.
ipv6 ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6
An LDAP server does not have an IPv6 address.
LDAP server view
ipv6-address: Specifies the IPv6 address of the LDAP server.
# Specify the IPv6 address and port number as 1:2::3:4 and 4300 for LDAP server ccc.
[Sysname-ldap-server-ccc] ipv6 1:2::3:4 port 4300
ldap server
ldap attribute-map
Use ldap attribute-map to create an LDAP attribute map and enter its view, or enter the view of an existing LDAP attribute map.
Use undo ldap attribute-map to delete an LDAP attribute map.
ldap attribute-map map-name
undo ldap attribute-map map-name
No LDAP attribute maps exist.
map-name: Specifies the name of the LDAP attribute map, a case-insensitive string of 1 to 31 characters.
Execute this command multiple times to create multiple LDAP attribute maps. You can add multiple mapping entries to an LDAP attribute map. Each entry defines the mapping between an LDAP attribute and an AAA attribute.
# Create an LDAP attribute map named map1 and enter LDAP attribute map view.
[Sysname] ldap attribute-map map1
[Sysname-ldap-map-map1]
attribute-map
ldap scheme
map
ldap scheme
Use ldap scheme to create an LDAP scheme and enter its view, or enter the view of an existing LDAP scheme.
Use undo ldap scheme to delete an LDAP scheme.
ldap scheme ldap-scheme-name
undo ldap scheme ldap-scheme-name
No LDAP schemes exist.
ldap-scheme-name: Specifies the LDAP scheme name, a case-insensitive string of 1 to 32 characters.
An LDAP scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 LDAP schemes.
# Create an LDAP scheme named ldap1 and enter LDAP scheme view.
display ldap scheme
ldap server
Use ldap server to create an LDAP server and enter its view, or enter the view of an existing LDAP server.
Use undo ldap server to delete an LDAP server.
ldap server server-name
undo ldap server server-name
No LDAP servers exist.
server-name: Specifies the LDAP server name, a case-insensitive string of 1 to 64 characters.
# Create an LDAP server named ccc and enter LDAP server view.
display ldap scheme
login-dn
Use login-dn to specify the administrator DN.
Use undo login-dn to restore the default.
login-dn dn-string
undo login-dn
No administrator DN is specified.
LDAP server view
dn-string: Specifies the administrator DN for binding with the server, a case-insensitive string of 1 to 255 characters.
The administrator DN specified on the device must be consistent with the administrator DN configured on the LDAP server.
If you change the administrator DN, the change is effective only on the LDAP authentication that occurs after the change.
# Specify the administrator DN as uid=test, ou=people, o=example, c=city for LDAP server ccc.
[Sysname-ldap-server-ccc] login-dn uid=test,ou=people,o=example,c=city
display ldap scheme
login-password
Use login-password to configure the administrator password for binding with the LDAP server during LDAP authentication.
Use undo login-password to restore the default.
login-password { cipher | simple } string
undo login-password
No administrator password is configured.
LDAP server view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 128 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
This command is effective only after the login-dn command is configured.
# Specify the administrator password as abcdefg in plaintext form for LDAP server ccc.
[Sysname-ldap-server-ccc] login-password simple abcdefg
display ldap scheme
login-dn
map
Use map to configure a mapping entry in an LDAP attribute map.
Use undo map to delete the specified mapping entries from the LDAP attribute map.
map ldap-attribute ldap-attribute-name [ prefix prefix-value delimiter delimiter-value ] aaa-attribute { user-group | user-profile }
undo map [ ldap-attribute ldap-attribute-name ]
An LDAP attribute map does not contain mapping entries.
ldap-attribute ldap-attribute-name: Specifies an LDAP attribute by its name. The ldap-attribute-name argument is a case-insensitive string of 1 to 63 characters.
prefix prefix-value delimiter delimiter-value: Specifies a partial value string of the LDAP attribute for attribute mapping. The prefix-value argument represents the position where the partial string starts. The prefix is a case-insensitive string of 1 to 7 characters, such as cn=. The delimiter-value argument represents the position where the partial string ends, such as a comma (,). If you do not specify the prefix prefix-value delimiter delimiter-value option, the mapping entry uses the entire value string of the LDAP attribute.
aaa-attribute: Specifies an AAA attribute.
user-group: Specifies the user group attribute.
user-profile: Specifies the user profile attribute.
Because the device ignores unrecognized LDAP attributes, configure the mapping entries to include important LDAP attributes that should not be ignored.
An LDAP attribute can be mapped only to one AAA attribute. Different LDAP attributes can be mapped to the same AAA attribute.
If you do not specify an LDAP attribute for the undo map command, the command deletes all mapping entries from the LDAP attribute map.
# In LDAP attribute map map1, map a partial value string of the LDAP attribute named memberof to AAA attribute named user-group.
[Sysname-ldap-map-map1] map ldap-attribute memberof prefix cn= delimiter , aaa-attribute user-group
ldap attribute-map
user-group
user-profile
protocol-version
Use protocol-version to specify the LDAP version.
Use undo protocol-version to restore the default.
protocol-version { v2 | v3 }
The LDAP version is LDAPv3.
LDAP server view
v2: Specifies the LDAP version LDAPv2.
v3: Specifies the LDAP version LDAPv3.
For successful LDAP authentication, the LDAP version used by the device must be consistent with the version used by the LDAP server.
If you change the LDAP version, the change is effective only on the LDAP authentication that occurs after the change.
A Microsoft LDAP server supports only LDAPv3.
# Specify the LDAP version as LDAPv2 for LDAP server ccc.
[Sysname-ldap-server-ccc] protocol-version v2
display ldap scheme
search-base-dn
Use search-base-dn to specify the base DN for user search.
Use undo search-base-dn to restore the default.
search-base-dn base-dn
undo search-base-dn
No base DN is specified for user search.
LDAP server view
base-dn: Specifies the base DN for user search, a case-insensitive string of 1 to 255 characters.
# Specify the base DN for user search as dc=ldap,dc=com for LDAP server ccc.
[Sysname-ldap-server-ccc] search-base-dn dc=ldap,dc=com
display ldap scheme
ldap server
search-scope
Use search-scope to specify the user search scope.
Use undo search-scope to restore the default.
search-scope { all-level | single-level }
undo search-scope
The user search scope is all-level.
LDAP server view
all-level: Specifies that the search goes through all subdirectories of the base DN.
single-level: Specifies that the search goes through only the next lower level of subdirectories under the base DN.
# Specify the search scope for the LDAP authentication as all subdirectories of the base DN for LDAP server ccc.
[Sysname-ldap-server-ccc] search-scope all-level
display ldap scheme
ldap server
server-timeout
Use server-timeout to set the LDAP server timeout period, the maximum time that the device waits for an LDAP response.
Use undo server-timeout to restore the default.
server-timeout time-interval
undo server-timeout
The LDAP server timeout period is 10 seconds.
LDAP server view
time-interval: Specifies the LDAP server timeout period in the range of 5 to 20 seconds.
If you change the LDAP server timeout period, the change is effective only on the LDAP authentication that occurs after the change.
# Set the LDAP server timeout period to 15 seconds for LDAP server ccc.
[Sysname-ldap-server-ccc] server-timeout 15
display ldap scheme
user-parameters
Use user-parameters to configure LDAP user attributes, including the username attribute, username format, and user-defined user object class.
Use undo user-parameters to restore the default of an LDAP user attribute.
user-parameters { user-name-attribute { name-attribute | cn | uid } | user-name-format { with-domain | without-domain } | user-object-class object-class-name }
undo user-parameters { user-name-attribute | user-name-format | user-object-class }
The LDAP username attribute is cn and the username format is without-domain. No user object class is specified and the default user object class of the LDAP server is used.
LDAP server view
user-name-attribute { name-attribute | cn | uid }: Specifies the username attribute. The name-attribute argument represents an attribute value, a case-insensitive string of 1 to 64 characters. The cn keyword represents the user account attribute of common name, and the uid keyword represents the user account attribute of user ID.
user-name-format { with-domain | without-domain }: Specifies the format of the username to be sent to the server. The with-domain keyword means that the username contains the domain name, and the without-domain keyword means that the username does not contain the domain name.
user-object-class object-class-name: Specifies the user object class for user search. The object-class-name argument represents a class value, a case-insensitive string of 1 to 64 characters.
If the username on the LDAP server does not contain the domain name, specify the without-domain keyword. If the username contains the domain name, specify the with-domain keyword.
# Set the user object class to person for LDAP server ccc.
[Sysname-ldap-server-ccc] user-parameters user-object-class person
display ldap scheme
login-dn
Local bill cache commands
display local-bill
Use display local-bill to display detailed information about usage statistics of the local bill cache or detailed information about the specified accounting bills in the cache.
display local-bill { cache-usage | verbose start-number count count }
cache-usage: Displays usage statistics of the local bill cache.
verbose: Displays detailed information about a series of consecutive accounting bills.
start-number: Specifies the number of the first accounting bill to be displayed. The value range for this argument is 1 to 50000.
count count: Specifies the total number of consecutive accounting bills to be displayed. The value range for the count argument is 1 to 100.
# Display detailed information about the two consecutive accounting bills starting from the bill numbered 1.
<Sysname> display local-bill verbose 1 count 2
Bill 1 details:
  Session ID  : 00000005201801181806480000195e6176100378
  User name   : user1@h3c
  Start time  : 2013-05-21 18:04:10
  Stop time   : 2013-05-21 18:05:35    Duration   : 0:01:35
  IP address  : 111.8.10.125           MAC address: 0016-ecb7-a879
  IPv6 address: N/A
  Service type: lan-access                    Access type: lan-access
  Interface   : GigabitEthernet3/1/1
  SVLAN/CVLAN : -/-
  Status      : Offline                Reason code: 6  Ref: 98
  User traffic:
    Received: 0            bytes, 0            packets
    Sent    : 0            bytes, 0            packets
Bill 2 details:
  Session ID  : 00000005201801181806480000195e6176100379
  User name   : user2
  Start time  : 2013-05-21 18:14:15
  Stop time   : 2013-05-21 18:15:35    Duration   : 0:01:20
  IP address  : 111.8.10.124           MAC address: 0016-ec89-a8e9
  IPv6 address: N/A
  Interface   : GigabitEthernet3/1/2
  SVLAN/CVLAN : 100/100
  User traffic:
Total bills: 2.
Table 26 Command output
Bill n details
Detailed information about the accounting bill numbered n.
Session ID
Session ID, which uniquely identifies an accounting session of a user.
Start time
Time from which the accounting session starts.
Stop time
Time at which the accounting session stops.
Duration
Online duration of the user.
IPv6 address
IPv6 address of the user.
Interface through which the user is connected to the device.
SVLAN/CVLAN
Customer network VLAN and service provider VLAN in which the user is connected to the device. A hyphen (-) is displayed if the user does not belong to a customer network VLAN or service provider VLAN.
Status
Accounting bill type:
·         Invalid.
·         Realtime.
·         Offline.
·         CRC Failed.
The device supports only offline accounting bills in the current software version.
Reason code
Reason that the accounting session was terminated. The reason code is compliance to RFC 2866.
Ref
Code that represents supplementary information for the session termination. This field is reserved for future use.
User traffic
User traffic statistics, including the uplink bytes, uplink packets, downlink bytes, and downlink packets.
Received
Traffic received by the user.
Sent
Traffic sent from the user.
Total bills
Total number of accounting bills displayed.
# Display usage statistics of the local bill cache.
<Sysname> display local-bill cache-usage
Cache usage:
  Existing bills: 0         Available bills      : 50000
  Max bills     : 50000     Auto export threshold: 4000
  Bytes per bill: 448
Table 27 Command output
Existing bills
Number of accounting bills stored in the local cache.
Available bills
Number of accounting bills that can be stored in the remaining space.
Max bills
Maximum number of accounting bills that the local cache can hold.
Threshold for automatic bill export. When the number of accounting bills reaches the system-defined threshold, automatic bill export is triggered.
Bytes per bill
Size of each accounting bill in the cache, in bytes.
local-bill enable
local-bill export
local-bill export-interval
local-bill export-url
local-bill enable
Use local-bill enable to enable the local bill cache feature.
Use undo local-bill enable to disable the local bill cache feature.
local-bill enable
The local bill cache feature is disabled.
The local bill cache stores accounting bills locally for users that encounter accounting-stop failures (for example, failures caused by unreachable servers).
The local accounting bills can be exported automatically or manually to a storage directory by using FTP or TFTP. The exported accounting bills are saved in TXT format in the directory. You can use the bills for accounting, auditing, or analyzing.
This feature is applicable to LAN, portal, PPP, and IPoE users.
# Enable the local bill cache feature.
[Sysname] local-bill enable
local-bill export
local-bill export
Use local-bill export to manually export local-cached accounting bills to a storage directory.
local-bill export [ url ] [ clear-cache ]
url: Specifies the URL to which accounting bills are exported. The URL is a string of 1 to 256 characters. If you do not specify a URL, this command exports the accounting bills to the storage directory specified by using the local-bill export-url command.
clear-cache: Clears the local bill cache after the accounting bills are exported. If you do not specify this keyword, the command does not clear the local bill cache after the accounting bills are exported.
Use this command for random audit and data analysis or when automatic export for accounting bills is not working correctly (for example, because of server failure).
Table 28 describes the URL formats.
Table 28 URL formats
Protocol
URL format
TFTP
tftp://server/path
You can specify a TFTP server by IP address or hostname. For example, tftp://1.1.1.1/lbill.
FTP
·         With FTP username and password:
ftp://username:password@server/path
·         Without FTP username and password:
ftp://server/path
You can specify an FTP server by IP address or hostname.
You can specify the username with or without the domain name. However, the device ignores the domain name.
For example, you can specify the URL as ftp://1:[email protected]/lbill or ftp://1.1.1.1/lbill.
Use the clear-cache keyword according to the export purposes. Do not use this keyword if the accounting bills are to be exported for troubleshooting or problem solving.
Among all user lines, only one user is allowed to perform a manual bill export at a time. During the export process, other users on the same user line cannot execute any commands. The manual bill export breaks an ongoing automatic bill export process.
# Export accounting bills to the tftp://10.10.10.10/tftp directory, and clears the local bill cache after the export.
[Sysname] local-bill export tftp://10.10.10.10/tftp clear-cache
local-bill enable
Use local-bill export-interval to set an interval at which the device automatically exports accounting bills.
Use undo local-bill export interval to restore the default.
local-bill export-interval interval
The interval is 1440 minutes.
interval: Specifies the interval at which the device automatically exports accounting bills. The value range for the interval is 1 to 65535, in minutes.
The interval takes effect after the local bill cache feature is enabled.
# Set the interval to 100 minutes for the device to automatically export accounting bills.
[Sysname] local-bill export-interval 100
local-bill enable
local-bill export
Use local-bill export-url to specify a URL for automatic bill export.
Use undo local-bill export-url to restore the default.
local-bill export-url url
The URL is not specified and automatic bill export will fail.
With the local bill cache feature, the device exports accounting bills to the specified URL at the automatic export interval or after the number of accounting bills exceeds the system-defined threshold. The accounting bills are saved in TXT format. The local bill cache is cleared each time after an automatic export.
The command supports FTP and TFTP URLs. Table 29 describes the URL formats.
Table 29 URL formats
Protocol
URL format
TFTP
tftp://server/path
FTP
ftp://server/path
# Configure tftp://10.10.10.10/tftp as the URL for automatic bill export.
[Sysname] local-bill export-url tftp://10.10.10.10/tftp
local-bill enable
snmp-agent trap enable local-bill
Use snmp-agent trap enable local-bill to enable SNMP notification for automatic accounting bill export.
Use undo snmp-agent trap enable local-bill to disable SNMP notification for automatic accounting bill export.
SNMP notification is enabled for automatic accounting bill export.
When the system fails to export accounting bills automatically to a server, it sends SNMP notifications to the information center.
The minimum interval for sending SNMP notifications is 10 seconds. The system does not send another SNMP notification if it has sent an SNMP notification within 10 seconds.
# Enable SNMP notification for automatic accounting bill export.
[Sysname] snmp-agent trap enable local-bill
