13-High Availability Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command References-Release7951PXX-6W10013-High Availability Command Reference
07-BFD commands
07-BFD commands 149.80 KB
BFD commands
bfd authentication-mode
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
Single-hop BFD control packets are not authenticated.
Interface view
BFD template view
Static BFD session view
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Use this command to enhance BFD session security.
BFD version 0 does not support this command. The configuration does not take effect.
# Configure GigabitEthernet 3/1/1 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] bfd authentication-mode simple 1 plain 123456
bfd dampening
Use bfd dampening to configure BFD session flapping suppression.
Use undo bfd dampening to disable BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
undo bfd dampening
BFD sessions are not suppressed.
maximum-interval: Specifies the maximum time a BFD session is suppressed, in the range of 1 to 3600 seconds. The default is 20 seconds.
initial-interval: Specifies the amount of time a BFD session is suppressed for the first time. The value range for the initial-interval argument is 1 to 3600 seconds. The default is 6 seconds.
secondary-interval: Specifies the amount of time a BFD session is suppressed for the second time. The value range for the secondary-interval argument is 1 to 3600 seconds. The default is 10 seconds.
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability.
This command allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
·          A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
·          After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
·          After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
·          After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡  If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡  If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
# Enable BFD session flapping suppression, and set the maximum-interval, initial-interval, and secondary-interval to 12 seconds, 4 seconds, and 8 seconds, respectively.
[Sysname] bfd dampening maximum 12 initial 4 secondary 8
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued. As a best practice, configure the bfd echo enable command together with this command to detect connectivity by sending echo packets. If the device does not receive any echo packets from the peer end, it considers the session down.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
# Enable the Demand BFD session mode on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] bfd demand enable
bfd echo enable
bfd detect-interface
Use bfd detect-interface source-ip to associate the interface state with BFD.
Use undo bfd detect-interface to remove the association between the interface state and BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ]
The interface state is not associated with BFD.
Interface view
ip-address: Specifies the source IP address for BFD control packets.
discriminator: Specifies BFD session discriminators. If you do not specify discriminators, the device obtains BFD session discriminators through autonegotiation.
local local-value: Specifies the local discriminator. The value range for the local-value argument is 1 to 32768.
remote remote-value: Specifies the remote discriminator in the range of 1 to 4294967295.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence. The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
·          Layer 2 Ethernet interfaces.
·          Member ports in a Layer 2 aggregation group.
·          Layer 3 Ethernet interfaces.
·          Member ports in a Layer 3 aggregation group.
·          Serial interfaces, POS interfaces, serial interfaces created from E1, E3, T1, or T3, MP-group interfaces, member interfaces of an MP-group interface, HDLC link bundle interfaces, and member interfaces of an HDLC link bundle interface.
If the link layer protocol of an interface is modified by using the link-protocol command, the association between the interface state and BFD is automatically cancelled. When associating the state of a member interface of an MP-group interface or of an HDLC link bundle interface, you must specify the discriminator parameter.
This command must be configured on both ends of the link for a BFD session to be established.
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd detect-interface source-ip 20.1.1.1 discriminator local 4501 remote 4502 on the local device, you must configure bfd detect-interface source-ip 20.1.1.1 discriminator local 4502 remote 4501 on the peer device.
The local discriminators of BFD sessions for interfaces on the same device must be different.
The echo function does not take effect on BFD sessions associated with interface states.
# Associate GigabitEthernet 3/1/1 with BFD to detect the interface state, and specify the source IP address for BFD control packets as 20.1.1.1.
[Sysname-GigabitEthernet3/1/1] bfd detect-interface source-ip 20.1.1.1
bfd detect-multiplier
Use bfd detect-multiplier to set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode are both 5.
Interface view
BFD template view
value: Specifies a detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Detection interval calculation method
Mode
Detection interval
Echo packet mode
Detection time multiplier of the sender × actual packet sending interval of the sender
Control packet mode BFD session in asynchronous mode
Detection time multiplier of the receiver × actual packet sending interval of the receiver
Control packet mode BFD session in demand mode
If this command is configured in static BFD session view, it takes effect only on static BFD sessions used for single-hop detection.
# Set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode to 6 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] bfd detect-multiplier 6
bfd static
bfd echo enable
Use bfd echo enable to enable the echo function.
Use undo bfd echo enable to disable the echo function.
undo bfd echo [ receive | send ] enable
The echo function is disabled.
Interface view
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo function for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
·          Periodically sends echo packets to detect link connectivity.
·          Decreases the control packet receiving rate at the same time.
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
# Enable the echo function on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets.
As a best practice, do not configure the source IP address to be on the same network segment as any local interface's IP address. If you configure such a source IP address, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
As a best practice, do not configure the source IPv6 address to be on the same network segment as any local interface's IP address. If you configure such a source IPv6 address, a large number of ICMPv6 redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value  takes 0 or is in the range of 3 to 10000. A value of 0 means the device does not receive echo packets.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
·          The echo function is enabled on the local end.
·          The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 200 milliseconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] bfd min-echo-receive-interval 200
bfd static
bfd min-receive-interval
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in the range of 3 to 10000 milliseconds.
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
·          Minimum interval for transmitting BFD control packets on the peer end.
·          Minimum interval for receiving BFD control packets on the local end.
# Set the minimum interval for receiving single-hop BFD control packets to 200 milliseconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] bfd min-receive-interval 200
bfd static
bfd min-transmit-interval
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in the range of 3 to 10000 milliseconds.
Use this command to prevent the BFD packet sending rate from exceeding the device capability.
The actual BFD control packet transmitting interval on the local end is the greater value between the following values:
·          Minimum interval for transmitting BFD control packets on the local end.
·          Minimum interval for receiving BFD control packets on the peer end.
# Set the minimum interval for transmitting single-hop BFD control packets to 200 milliseconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] bfd min-transmit-interval 200
bfd static
bfd multi-hop authentication-mode
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd static
bfd multi-hop destination-port
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
bfd multi-hop detect-multiplier
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier for control packet mode.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier for control packet mode is 5.
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Detection interval calculation method
Mode
Detection interval
# Set the multihop detection time multiplier to 6 for control packet mode.
[Sysname] bfd multi-hop detect-multiplier 6
bfd static
bfd multi-hop min-receive-interval
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
The minimum interval for receiving multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for receiving multihop BFD control packets, in the range of 3 to 10000 milliseconds.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 200 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 200
bfd static
bfd multi-hop min-transmit-interval
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
The minimum interval for transmitting multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in the range of 3 to 10000 milliseconds.
# Set the minimum interval for transmitting multihop BFD control packets to 200 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 200
bfd static
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
bfd static
Use bfd static to create a static BFD session and enter its view, or enter the view of an existing static BFD session.
Use undo bfd static to delete a static BFD session and all its settings.
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name | interface interface-type interface-number ] source-ip ipv4-address discriminator local local-value remote remote-value ]
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name | interface interface-type interface-number ] source-ipv6 ipv6-address discriminator local local-value remote remote-value ]
undo bfd static session-name
No static BFD sessions exist.
session-name: Specifies a static BFD session name, a case-sensitive string of 1 to 15 characters.
peer-ip ipv4-address: Specifies the peer IPv4 address in dotted decimal notation. It must be a valid unicast IPv4 address.
peer-ipv6 ipv6-address: Specifies the peer IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the static BFD session belongs to the public network.
interface interface-type interface-number: Specifies an interface by its type and number. The command performs single-hop detection on the link with the specified interface as the outgoing interface and the specified peer IP address as the next hop.
source-ip ipv4-address: Specifies the source IPv4 address for control packets, in dotted decimal notation. It must be a valid unicast IPv4 address.
peer-ipv6 ipv6-address: Specifies the source IPv6 address for control packets.
local local-value: Specifies the local discriminator in the range of 1 to 32768.
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see Track in High Availability Configuration Guide.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd static abc peer-ip 20.1.1.1 vpn-instance vpn1 source-ip 20.1.1.2 discriminator local 513 remote 514 on the local device, you must configure bfd static bcd peer-ip 20.1.1.2 vpn-instance vpn1 source-ip 20.1.1.1 discriminator local 514 remote 513 on the peer device.
When creating a static BFD session, you must specify a peer IP address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
The bfd static session-name command without any parameters specified can only be used to enter the view of an existing static BFD session.
To modify a static BFD session, delete the static BFD session and then configure a new static BFD session.
If you do not specify a VPN instance or an interface, the device performs multihop detection in the public network.
If you specify an interface, make sure the following requirements are met for the static BFD session to be successfully established:
·          Specify the IP address of the peer interface where the static BFD session resides as the peer IP address.
·          Specify the IP address of the local interface where the static BFD session resides as the source IP address.
Different static BFD sessions cannot have the same local discriminator.
# Create a static BFD session and enter its view. The static BFD session detects the link with the outgoing interface GigabitEthernet 3/1/1 and the next hop 1.1.1.2. The source IP address for the session is 1.1.1.1, the local discriminator is 1537, and the remote discriminator is 2048.
[Sysname] bfd static aaaa peer-ip 1.1.1.2 interface gigabitethernet 3/1/1 source-ip 1.1.1.1 discriminator local 1537 remote 2048
[Sysname-bfd-static-session-aaaa]
track bfd
bfd template
Use bfd template to create a BFD template and enter its view, or enter the view of an existing BFD template.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD templates exist.
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator local local-value | static session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
discriminator local local-value: Specifies a BFD session by its local discriminator in the range of 1 to 4294967295.
static session-name: Specifies a static BFD session by its name, a case-sensitive string of 1 to 15 characters.
dynamic: Specifies dynamic BFD sessions.
static: Specifies static BFD sessions.
control: Specifies BFD sessions in control packet mode.
echo: Specifies BFD sessions in echo mode.
ip: Specifies BFD sessions used to detect IPv4 links.
ipv6: Specifies BFD sessions used to detect IPv6 links.
lsp: Specifies BFD sessions used to detect MPLS LSPs.
te: Specifies BFD sessions used to detect MPLS TE tunnels.
pw: Specifies BFD sessions used to detect PWs.
state: Displays BFD sessions by session state.
down: Specifies BFD sessions in Down state.
admin-down: Specifies BFD sessions in AdminDown state.
init: Specifies BFD sessions in Init state.
up: Specifies BFD sessions in Up state.
discriminator remote remote-value: Specifies a BFD session by its remote discriminator  in the range of 1 to 4294967295.
peer-ip ipv4-address: Specifies a BFD session by the peer IPv4 address in dotted decimal notation.
peer-ipv6 ipv6-address: Specifies a BFD session by the peer IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays the BFD sessions of the public network.
verbose: Displays detailed BFD session information.
If you do not specify the dynamic or static keyword, this command displays all dynamic and static BFD sessions.
# Display brief information about all BFD sessions.
<Sysname> display bfd session
 Total sessions: 9        Up sessions: 9        Init mode: Active
LD/RD            SourceAddr      DestAddr        State  Holdtime    Interface
 513/513         1.1.1.1         1.1.1.2         Up     2297ms      GE3/1/1
 IPv6 session working in control packet mode:
       Local discr: 513                  Remote discr: 513
         Source IP: FE80::20C:29FF:FED4:7171
    Destination IP: FE80::20C:29FF:FE72:AC4D
     Session state: Up                      Interface: GE3/1/2
         Hold time: 2142ms
 MPLS LSP session working in control packet mode:
 513/514        2.2.2.9         127.0.0.1       Up       4410ms      N/A
 514/513        2.2.2.9         1.1.1.9         Up       4358ms      N/A
 IPv6 static session working in control packet mode:
       Local discr: 1700                  Remote discr: 1700
         Hold time: 2142ms
 MPLS TE session working in control packet mode:
 2050/2050      1.1.1.1         127.0.0.1       Up       2458ms      N/A
 MPLS TE session working in echo mode:
 LD             SourceAddr      DestAddr        State    Holdtime    Interface
 2051           1.1.1.1         3.3.3.3         Up       4851ms      Tun2
 MPLS PW session working in control packet mode:
 20481/20481    2.2.2.2         127.0.0.1       Up       2489ms      N/A
Total sessions
Total number of BFD sessions.
Up sessions
Total number of active BFD sessions.
Init mode
BFD operating mode: Active or passive.
BFD session type and operating mode:
·         IPv4 session working in control packet mode.
·         IPv4 session working in echo mode.
·         IPv6 session working in control packet mode.
·         IPv6 session working in echo mode.
·         MPLS LSP session working in control packet mode—BFD session in control packet mode used to detect failures in an LSP.
·         MPLS LSP session working in echo mode—BFD session in echo mode used to detect failures in an LSP.
·         IPv6 SR session working in echo mode—BFD session in echo mode used to detect failures in an SRv6 tunnel.
·         IPv4 static session working in control packet mode.
·         IPv6 static session working in control packet mode.
·         MPLS TE session working in control packet mode.
·         MPLS TE session working in echo mode.
·         MPLS PW session working in control packet mode.
LD/RD
Local discriminator/Remote discriminator of the session.
SourceAddr
Source IPv4 address of the session.
DestAddr
Destination IPv4 address of the session.
Session state: Down, Init, or Up.
Holdtime
Length of time before session detection timer expires.
For a BFD session in Down state, this field displays 0ms. If hardware BFD is enabled, this field displays 0ms.
Name of the interface of the session.
Local discr
Local discriminator of the session.
Remote discr
Source IP
Source IPv6 address of the session.
Destination IP
Destination IPv6 address of the session.
Session state
Session state: Down, Admdown, Init, or Up.
Hold time
# Display detailed BFD session information.
<Sysname> display bfd session verbose
            Source IP: 1.1.1.1                  Destination IP: 1.1.1.2
     Destination port: 3784                      Session state: Up
            Interface: GigabitEthernet3/1/1
      Min Tx interval: 500ms          Actual Tx Interval: 500ms
      Min Rx interval: 500ms                    Detection time: 2500ms
             Rx count: 42                       Tx count: 43
      Connection type: Direct                Up duration: 00:00:20
            Hold time: 2078ms                  Auth mode: None
       Detection mode: Async                        Slot: 0
             Protocol: OSPF
              Version:1
            Diag info: No Diagnostic
        Hardware mode: Disable
            Interface: GigabitEthernet3/1/2
      Min Tx interval: 500ms                Actual Tx interval: 500ms
             Rx count: 38                             Tx count: 38
      Connection type: Direct                      Up duration: 00:00:15
            Hold time: 2211ms                        Auth mode: None
             Protocol: OSPFv3
              Version: 1
          Local discr: 513                        Remote discr: 514
            Source IP: 1.1.1.9                  Destination IP: 127.0.0.1
            Interface: N/A
      Min Tx interval: 1000ms               Actual Tx interval: 1000ms
      Min Rx interval: 1000ms                   Detection time: 5000ms
             Rx count: 8894                           Tx count: 9451
      Connection type: Indirect                    Up duration: 02:17:50
            Hold time: 4292ms                        Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
            Diag info: No Diagnostics
 IPv6 SR session working in echo mode:
          Local discr: 2049
     Destination port: 3785                      Session state: Up
            Interface: Tunnel1
            Hold time: 2049ms               Actual Tx interval: 500ms
          Rx count: 7065                              Tx count: 7065
   Connection type: Indirect                       Up duration: 00:50:08
    Detection mode: Async                                 Slot: 2
          Protocol: SRv6
           Version: 1
 IPv4 static session working in control packet mode:
         Session name: abc
          Local discr: 310                        Remote discr: 308
            Source IP: 12.1.1.1                 Destination IP: 12.1.1.2
      Min Tx interval: 1000ms               Actual Tx interval: 3000ms
             Rx count: 59                             Tx count: 1003
      Connection type: Direct                      Up duration: 00:00:00
            Hold time: 1040ms                           Auth mode: None
             Protocol: STATIC_IPv4
              Version: 1
      Session name: bbbb
             Protocol: STATIC_IPv6
              Version: 1
 MPLS TE Session working in control packet mode:
          Local discr: 2050                       Remote discr: 2050
            Source IP: 1.1.1.1                  Destination IP: 127.0.0.1
            Interface: N/A
             Rx count: 72                             Tx count: 73
      Connection type: Indirect                    Up duration: 00:00:30
            Hold time: 2458ms                        Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
          Local discr: 2051
            Source IP: 1.1.1.1                  Destination IP: 3.3.3.3
            Interface: Tunnel2
            Hold time: 4851ms               Actual Tx interval: 1000ms
             Rx count: 9083                           Tx count: 9637
      Connection type: Indirect                    Up duration: 02:20:42
             Protocol: MPLS_LSPV
              Version: 1
          Local discr: 20481                      Remote discr: 20481
            Source IP: 2.2.2.2                  Destination IP: 127.0.0.1
            Interface: N/A
            Hold time: 2489ms                        Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
Total session
Up session
Init mode
Local discr
Local ID of the session.
Remote discr
Remote ID of the session.
Source IP
Source IP address of the session.
Destination IP
Destination IP address of the session.
Destination port
Destination port number in BFD packets defined in Comware:
·         The destination port number in single-hop BFD control packets is 3784.
·         The destination port number in single-hop or multihop BFD echo packets is 3785.
·         The destination port number in multihop BFD control packets is 4784.
·         The destination port number in BFD control packets for association between link aggregation and BFD is 6784.
The device uses the destination port number in incoming packets that are not defined in Comware as the destination port number in outgoing BFD packets.
Session state
Session state: Down, AdmDown, Init, or Up.
Min Tx interval
Minimum transmit interval.
Min Rx interval
Minimum receive interval.
Actual Tx interval
Actual transmit interval.
Detection time
Actual session detection timer.
Rx count
Number of packets received.
Tx count
Number of packets sent.
Hold time
For a BFD session in down state, this field displays 0ms. If hardware BFD is enabled, this field displays 0ms.
Auth mode
Session authentication mode.
Connect type
Connection type of the interface: Direct or indirect.
Up duration
Time period for which the session has been up.
Detect mode
Detection mode:
·         Async—Asynchronous mode.
·         Demand—Demand mode.
·         Async/Echo—Asynchronous mode with echo detection enabled.
·         Demand/Echo—Demand mode with echo detection enabled.
Slot
Slot number.
Protocol
Protocol associated with BFD:
·         OSPF.
·         ISIS_BR_L1—IS-IS with the network type as broadcast and the router type as Level 1.
·         ISIS_BR_L2—IS-IS with the network type as broadcast and the router type as Level 2.
·         ISIS_P2P—IS-IS with the network type as P2P.
·         ISIS6_BR_L1—IPv6 IS-IS with the network type as broadcast and the router type as Level 1.
·         ISIS6_BR_L2—IPv6 IS-IS with the network type as broadcast and the router type as Level 2.
·         ISIS6_P2P—IPv6 IS-IS with the network type as P2P.
·         BGP.
·         MPLS_RSVP.
·         STATIC4—IPv4 static routing.
·         TRACK—Track.
·         RIP.
·         IPFRR—FIB IP FRR.
·         MAD.
·         MPLS_LSPV.
·         OSPFv3.
·         BGP4+.
·         PIM.
·         PIM6—IPv6 PIM.
·         STATIC6—IPv6 static routing.
·         RIPNG—RIPng.
·         Interface—Interface state.
·         TUNNEL.
·         VTEP.
·         LAGG—Link aggregation.
·         SRv6.
·         STATIC_IPv4—IPv4 static BFD session.
·         STATIC_IPv6—IPv6 static BFD session.
Diag info
Diagnostic information about the session:
·         No Diagnostic.
·         Control Detection Time Expired—A control packet mode BFD session goes down because local detection times out.
·         Echo Function Failed—An echo mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted.
·         Neighbor Signaled Session Down—The remote end notifies the local end of BFD session down.
·         Administratively Down—The local system prevents a BFD session from being established.
Hardware mode
Mode in which BFD packets are processed in hardware:
·         Enabled.
·         Disable. BFD packets are processed in software.
bfd static
display bfd system mode info
Use display bfd system mode info to display the BFD hardware mode and hardware resource usage.
# Display the BFD hardware mode and hardware resource usage.
<Sysname> display bfd system mode info
Working in hardware BFD mode
Total      Reserved   Configured   Remaining
8          1          0            7
Machine0:   Reserved  interval:         refcnt:0
Machine1:   dynamic   interval:         refcnt:0
Machine2:   dynamic   interval:         refcnt:0
Machine3:   dynamic   interval:         refcnt:0
Machine4:   dynamic   interval:         refcnt:0
Machine5:   dynamic   interval:         refcnt:0
Machine6:   dynamic   interval:         refcnt:0
Machine7:   dynamic   interval:         refcnt:0
Table 5 Command output
Total
Total number of hardware resources.
Reserved
Number of reserved hardware resources.
Configured
Number of hardware resources that has been applied.
Remaining
Number of hardware resources that you can apply.
Machine
Resource type: Reserved or dynamic.
interval
Minimum detection time (configured minimum packet sending interval multiplied by the detection time multiplier).
refcnt
Number of BFD sessions that used a resource.
hardware bfd enable
Use hardware bfd enable to enable hardware BFD.
Use undo hardware bfd enable to disable hardware BFD.
hardware bfd enable [ high-precision ]
Hardware BFD is disabled.
high-precision: Enables high-precision hardware BFD.
To avoid incorrect operation of BFD sessions, follow these guidelines when you enable or disable hardware BFD:
·          Before you enable hardware BFD, make sure only CSPEX cards (except CSPEX-1204 and CSPEX-1104-E) are installed in the device.
·          After you enable hardware BFD, do not install any cards except those cards mentioned above.
·          Make sure no BFD sessions exist when you enable or disable hardware BFD.
Hardware BFD and high-precision hardware BFD take effect only on new BFD sessions.
High-precision hardware BFD supports the shortest detection time of 3 milliseconds.
# Enable hardware BFD.
[Sysname] hardware bfd enable
The operation will enable hardware BFD. Are you sure you want to continue? [Y/N]:y
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
