03-Interface Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command References-Release7951PXX-6W10003-Interface Command Reference
01-Bulk interface commands
01-Bulk interface commands 48.42 KB
Bulk interface configuration commands
display interface range
Use display interface range to display information about named interface ranges created by using the interface range name command.
display interface range [ name name ]
name name: Specifies an interface range by its name, a case-sensitive string of 1 to 32 characters. If you do not specify an interface range name, this command displays information about all interface ranges created by using the interface range name command.
# Display information about the interface ranges created by using the interface range name command.
<Sysname> display interface range
Interface range name t2 GigabitEthernet3/1/1 GigabitEthernet3/1/2
The output shows that the interfaces GigabitEthernet 3/1/1 and GigabitEthernet 3/1/2 are added to interface range t2.
interface range
Use interface range to create an interface range and enter the interface range view.
interface range interface-list
interface-list: Specifies a space-separated list of up to 24 interface items. Each item specifies an interface by its type and number or specifies a subrange of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a subrange of interfaces, the interfaces must be all fixed interfaces or on the same interface card. The start interface number must be identical to or lower than the end interface number.
Use this command to bulk configure multiple interfaces with the same feature instead of configuring them one by one. For example, execute the shutdown command in interface range view to shut down a range of interfaces.
The interface range created by using this command is not saved to the running configuration. You cannot use the interface range repeatedly. To create an interface range that can be used repeatedly, use the interface range name command.
In interface range view, only commands supported by the first interface in the specified interface list are available for configuration. To view available commands, enter a question mark (?) in interface range view.
After a command is executed in interface range view, one of the following situations might occur:
·          The system displays an error message and stays in interface range view. It means that the execution failed on one or multiple member interfaces.
¡  If the execution failed on the first member interface, the command is not executed on any member interfaces.
¡  If the execution failed on a non-first member interface, the command takes effect on the remaining member interfaces.
·          The system returns to system view. It means that:
¡  The command is supported in both system view and interface view.
¡  The execution failed on a member interface in interface range view and succeeded in system view.
¡  The command is not executed on the subsequent member interfaces.
You can use the display this command to verify the configuration in interface view of each member interface. In addition, if the configuration in system view is not needed, use the undo form of the command to remove the configuration.
To verify the configuration of the first member interface, you can execute the display this command in interface range view.
When you bulk configure interfaces, follow these guidelines:
·          Before you configure an interface as the first interface in an interface range, make sure you can enter the view of the interface by using the interface interface-type { interface-number | interface-number.subnumber } command.
·          Do not assign both an aggregate interface and any of its member interfaces to an interface range. Some commands, after being executed on both an aggregate interface and its member interfaces, can break up the aggregation.
·          Understand that the more interfaces you specify, the longer the command execution time.
# Shut down interfaces GigabitEthernet 3/1/1 through GigabitEthernet 3/1/3.
[Sysname] interface range gigabitethernet 3/1/1 to gigabitethernet 3/1/3
[Sysname-if-range] shutdown
Use interface range name name interface interface-list to create a named interface range and enter the interface range view.
Use interface range name name without the interface keyword to enter the view of a named interface range.
Use undo interface range name to delete the interface range with the specified name.
interface range name name [ interface interface-list ]
undo interface range name name
name: Specifies an interface range name, a case-sensitive string of 1 to 32 characters.
A named interface range is saved in the running configuration and can be used repeatedly to bulk configure its member interfaces.
To view the member interfaces of a named interface range, use the display interface range command.
·          As a best practice to guarantee bulk interface configuration performance, configure fewer than 1000 interface range names.
# Add GigabitEthernet 3/1/1 through GigabitEthernet 3/1/3 to interface range myEthPort, and enter the interface range view.
[Sysname] interface range name myEthPort interface gigabitethernet 3/1/1 to gigabitethernet 3/1/3
[Sysname-if-range-myEthPort]
# Enter the view of interface range myEthPort.
