- 14-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PTP commands
- 05-Network synchronization commands
- 06-SNMP commands
- 07-RMON commands
- 08-NETCONF commands
- 09-CWMP commands
- 10-EAA commands
- 11-Process monitoring and maintenance commands
- 12-Sampler commands
- 13-Mirroring commands
- 14-NetStream commands
- 15-IPv6 NetStream commands
- 16-Fast log output commands
- 17-Flow log commands
- 18-Information center commands
- 19-GOLD commands
- 20-Packet capture commands
- 21-Flow monitor commands
| 11-Process monitoring and maintenance commands | 211.43 KB |
display kernel deadloop configuration
display kernel starvation configuration
display process memory heap address
display process memory heap size
monitor kernel deadloop action
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
The display memory, display process, display process cpu, monitor process and monitor thread commands display information about both user processes and kernel threads. In these commands, the term "process" refers to both user processes and kernel threads.
display exception context
Use display exception context to display context information for process exceptions.
In standalone mode:
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display exception context [ count value ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
count value: Specifies the number of context information entries, in the range of 1 to 20. The default value is 1.
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command displays context information for process exceptions on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command displays context information for process exceptions on the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
The system generates a context information entry for each process exception. A context information entry includes the process ID, the crash time, the core dump file directory, stack information, and register information.
# Display the exception context information on the device.
<Sysname> display exception context
Index 1 of 1
Crashed PID: 442 (dhcpd)
Crash signal: SIGSEGV
Crash time: Tue Aug 1 16:22:20 2017
Core file path:
flash:/core/node0_dhcpd_442_11_20170801-162220_1501604540.core
#0 0x00000001200a0c68
#1 0x00000001200a0c38
Backtrace stopped.
Registers' content
zero:0x0000000000000000 at:0xffffffff802050c4
v0:0x000000012014af08 v1:0x0000000000000000
a0:0x000000fffff16bc8 a1:0x0000000000000020
a2:0x0000000000000006 a3:0x0000000000000122
a4:0x000000fffff16a70 a5:0x0000000000000000
a6:0x000000fffff16bc4 a7:0x000000fffff16bc6
t0:0x0000000000000000 t1:0x0000000000000000
t2:0x0000000000000000 t3:0x0000000000000122
s0:0x000000fffff16bc0 s1:0x000000fffff16bc4
s2:0x0000000000000001 s3:0x000000fffff16d38
s4:0x00000000000000c0 s5:0x000000fffff16c92
s6:0x000000fffff16ca0 s7:0x00000000000000c0
t8:0x0000000000000000 t9:0x00000001200a0668
k0:0x0000000000000000 k1:0x0000000000000000
gp:0x0000000120149940 sp:0x000000fffff16a90
s8:0x0000000000000040 ra:0x00000001200a0c38
sr:0x000000004400fff3 lo:0x0000000000000000
hi:0x0000000000000000 bad:0x0000000000000010
cause:0x0000000000800008 pc:0x00000001200a0c68
Filed |
Crashed PID |
ID of the crashed process. |
Crash signal |
Signals that led to the crash: · SIGABRT—Abort. · SIGBUS—Bus error. · SIGFPE—Erroneous arithmetic operation. · SIGILL—Illegal hardware instructions. · SIGQUIT—Quit signal sent by the controlling terminal. · SIGSEGV—Invalid memory access. · SIGSYS—Invalid system call. · SIGTRAP—Trap message. · SIGXCPU—CPU usage limit exceeded. · SIGXFSZ—File size limit exceeded. · SIGUNKNOW—Unknown reason. |
Crash time |
Time when the crash occurred. |
Core file path |
Directory where the core dump file is saved. |
Backtrace stopped |
All stack information has been displayed. |
reset exception context
display exception filepath
Use display exception filepath to display the core dump file directory.
In standalone mode:
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display exception filepath [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command displays the core dump file directory on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command displays the core dump file directory on the global active MPU. (In IRF mode.)
# (In standalone mode.) Display the core dump file directory on a slot.
<Sysname> display exception filepath slot 3
The exception filepath on slot 3 is flash:.
Use display kernel deadloop to display kernel thread deadloop information.
In standalone mode:
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display kernel deadloop show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of deadloops to display, in the range of 1 to 60.
offset: Specifies the offset between the starting deadloop and the most recent deadloop, in the range of 0 to 59. The default value is 0.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays kernel thread deadloop information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify this option, the command displays kernel thread deadloop information for the global active MPU. (In IRF mode.)
# (In standalone mode.) Display brief information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1
----------------- Deadloop record 1 -----------------
Description : BUG: soft lockup - CPU#0 stuck for 61! [comsh: 16306]
Recorded at : 2013-05-01 11:16:00.823018
Occurred at : 2013-05-01 11:16:00.823018
Instruction address : 0x4004158c
Thread : comsh (TID: 16306)
Context : thread context
Slot : 1
Cpu : 0
VCPU ID : 0
Kernel module info : module name (mrpnc) module address (0xe332a000)
# (In standalone mode.) Display detailed information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1 verbose
Slot : 1
Cpu : 0
VCPU ID : 0
Last 5 thread switches : migration/0 (11:16:00.823018)-->
swapper (11:16:00.833018)-->
kthreadd (11:16:00.833518)-->
swapper (11:16:00.833550)-->
disk (11:16:00.833560)
Register content:
Reg: r0, Val = 0x00000000 ; Reg: r1, Val = 0xe2be5ea0 ;
Reg: r2, Val = 0x00000000 ; Reg: r3, Val = 0x77777777 ;
Reg: r4, Val = 0x00000000 ; Reg: r5, Val = 0x00001492 ;
Reg: r6, Val = 0x00000000 ; Reg: r7, Val = 0x0000ffff ;
Reg: r8, Val = 0x77777777 ; Reg: r9, Val = 0x00000000 ;
Reg: r10, Val = 0x00000001 ; Reg: r11, Val = 0x0000002c ;
Reg: r12, Val = 0x057d9484 ; Reg: r13, Val = 0x00000000 ;
Reg: r14, Val = 0x00000000 ; Reg: r15, Val = 0x02000000 ;
Reg: r16, Val = 0xe2be5f00 ; Reg: r17, Val = 0x00000000 ;
Reg: r18, Val = 0x00000000 ; Reg: r19, Val = 0x00000000 ;
Reg: r20, Val = 0x024c10f8 ; Reg: r21, Val = 0x057d9244 ;
Reg: r22, Val = 0x00002000 ; Reg: r23, Val = 0x0000002c ;
Reg: r24, Val = 0x00000002 ; Reg: r25, Val = 0x24000024 ;
Reg: r26, Val = 0x00000000 ; Reg: r27, Val = 0x057d9484 ;
Reg: r28, Val = 0x0000002c ; Reg: r29, Val = 0x00000000 ;
Reg: r30, Val = 0x0000002c ; Reg: r31, Val = 0x00000000 ;
Reg: cr, Val = 0x84000028 ; Reg: nip, Val = 0x057d9550 ;
Reg: xer, Val = 0x00000000 ; Reg: lr, Val = 0x0186eff0 ;
Reg: ctr, Val = 0x682f7344 ; Reg: msr, Val = 0x00784b5c ;
Reg: trap, Val = 0x0000b030 ; Reg: dar, Val = 0x77777777 ;
Reg: dsisr, Val = 0x40000000 ; Reg: result, Val = 0x00020300 ;
Dump stack (total 1024 bytes, 16 bytes/line):
0xe2be5ea0: 02 be 5e c0 24 00 00 24 00 00 00 00 05 7d 94 84
0xe2be5eb0: 00 00 00 04 00 00 00 00 00 00 00 28 05 8d 34 c4
0xe2be5ec0: 02 be 60 a0 01 86 ef f0 00 00 00 00 00 00 00 00
0xe2be5ed0: 02 04 05 b4 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ee0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ef0: 95 47 73 35 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f00: a0 e1 64 21 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f10: 00 00 00 00 00 00 00 00 00 00 00 00 01 e9 00 00
0xe2be5f20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f30: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be5f40: 02 be 61 e0 00 00 00 02 00 00 00 00 02 44 b3 a4
0xe2be5f50: 02 be 5f 90 00 00 00 08 02 be 5f e0 00 00 00 08
0xe2be5f60: 02 be 5f 80 00 ac 1b 14 00 00 00 00 00 00 00 00
0xe2be5f70: 05 b4 5f 90 02 be 5f e0 00 00 00 30 02 be 5f e0
0xe2be5f80: 02 be 5f c0 00 ac 1b f4 00 00 00 00 02 45 00 00
0xe2be5f90: 00 03 00 00 00 00 00 00 02 be 5f e0 00 00 00 30
0xe2be5fa0: 02 be 5f c0 00 ac 1b 14 61 f1 2e ae 02 45 00 00
0xe2be5fb0: 02 44 b3 74 02 be 5f d0 00 00 00 30 02 be 5f e0
0xe2be5fc0: 02 be 60 60 01 74 ff f8 00 00 00 00 00 00 08 00
0xe2be5fd0: 02 be 5f f0 00 e8 93 7e 02 be 5f f8 02 be 5f fc
0xe2be5fe0: 00 00 00 00 00 00 00 00 00 00 00 00 02 be 60 18
0xe2be5ff0: 02 be 60 10 00 e9 65 98 00 00 00 58 00 00 2a 4f
0xe2be6000: 02 be 60 10 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6010: 02 be 60 40 00 e8 c6 a0 00 00 11 17 00 00 00 00
0xe2be6020: 02 be 60 40 00 00 00 00 00 00 00 00 02 be 60 98
0xe2be6030: 02 27 00 00 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6040: 02 be 60 60 00 00 00 01 00 00 b0 30 02 be 60 98
0xe2be6050: 00 00 00 04 02 21 00 00 00 00 00 00 01 e9 00 00
0xe2be6060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be6070: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be6080: 02 be 61 e0 00 00 00 02 00 00 00 00 02 be 61 70
0xe2be6090: 00 00 00 00 02 21 00 00 05 8d 34 c4 05 7d 92 44
Call trace:
Function Address = 0x8012a4b4
Function Address = 0x8017989c
Function Address = 0x80179b30
Function Address = 0x80127438
Function Address = 0x8012d734
Function Address = 0x80100a00
Function Address = 0xe0071004
Function Address = 0x8016ce0c
Function Address = 0x801223a0
Instruction dump:
41a2fe9c 812300ec 800200ec 7f890000 409efe8c 80010014 540b07b9 40a2fe80
4bfffe6c 80780290 7f64db78 4804ea35 <807f002c> 38800000 38a00080 3863000c
Description for the kernel thread deadloop, including the CPU number, thread running time, thread name, and thread number. |
Recorded at |
Time when the kernel thread deadloop was recorded, with microsecond precision. |
Occurred at |
Time when the kernel thread deadloop occurred, with microsecond precision. |
Instruction address |
Instruction address for the kernel thread deadloop. |
Thread |
Name and number of the kernel thread deadloop. |
Context |
Context for the kernel thread deadloop. |
Cpu |
Number of the CPU where the kernel thread ran. |
VCPU ID |
Number of the CPU core where the kernel thread ran. |
Kernel module info |
Information about kernel modules that had been loaded when the kernel thread deadloop was detected, including kernel module name and memory address. |
Last 5 thread switches |
Last five kernel thread switches on the CPU before the kernel thread deadloop was detected, including kernel thread name and kernel thread switching time with microsecond precision. |
Register content |
Register information: · Reg—Name of a register. · Val—Value saved in a register. |
Dump stack |
Stack information. |
Call trace |
Function call stack information, which shows the instruction address of a called function at each level. |
Instruction dump |
Instruction code when the kernel thread deadloop was detected. ffffffff indicates an illegitimate instruction code. |
No information to display |
No kernel thread deadloop information. |
reset kernel deadloop
Use display kernel deadloop configuration to display kernel thread deadloop detection configuration.
In standalone mode:
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display kernel deadloop configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays kernel thread deadloop detection configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify this option, the command displays kernel thread deadloop detection configuration for the global active MPU. (In IRF mode.)
# Display kernel thread deadloop detection configuration.
<Sysname> display kernel deadloop configuration
Thread dead loop detection: Enabled
Dead loop timer (in seconds): 60
Dead loop core list: 0
Dead loop action: Reboot
Threads excluded from monitoring: 1
TID: 15 Name: co0
Dead loop timer (in seconds): n |
Time interval (in seconds) to identify a kernel thread deadloop. A kernel thread deadloop occurs if a kernel thread runs more than n seconds. |
Dead loop core list |
CPU cores for which kernel thread deadloop detection is performed. |
Dead loop action |
Action to be taken in response to a kernel thread deadloop: · Reboot—Logs the event and reboots the hardware. · Record-only—Logs the event. |
Threads excluded from monitoring |
Kernel threads excluded from kernel thread deadloop detection. This field appears only if the monitor kernel deadloop exclude-thread command is configured. |
Name |
Kernel thread name. |
TID |
Kernel thread number. |
No thread is excluded from monitoring |
All kernel threads are monitored by kernel thread deadloop detection. |
display kernel exception
Use display kernel exception to display kernel thread exception information.
In standalone mode:
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display kernel exception show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of kernel exceptions to display, in the range of 1 to 60.
offset: Specifies the offset between the starting exception and the most recent exception, in the range of 0 to 59. The default value is 0.
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command displays kernel thread exception information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command displays kernel thread exception information for the global active MPU. (In IRF mode.)
If an exception occurs to a running kernel thread, the system automatically records the exception information.
# (In standalone mode.) Display brief information about the most recent kernel thread exception.
<Sysname> display kernel exception 1
----------------- Exception record 1 -----------------
Description : Oops[#0]
Slot : 1
Cpu : 0
VCPU ID : 0
module name (disk) module address (0xe00bd000)
# (In standalone mode.) Display detailed information about the most recent kernel thread exception.
<Sysname> display kernel exception 1 verbose
Slot : 1
Cpu : 0
VCPU ID : 0
module name (12500) module address (0xe00bd000)
Register content:
Call trace:
Instruction dump:
For more information about the command output, see Table 2.
reset kernel exception
display kernel reboot
Use display kernel reboot to display reboot information for a slot.
In standalone mode:
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display kernel reboot show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of kernel thread reboots to display, in the range of 1 to 60.
offset: Specifies the offset between the starting reboot and the most recent reboot, in the range of 0 to 59. The default value is 0.
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command displays kernel thread reboot information for the active MPU. Reboot information for cards is recorded in the memory of the active MPU. If the active MPU is powered off, the reboot information is lost. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command displays kernel thread reboot information for the global active MPU. Reboot information for cards on an IRF member device is recorded in the memory of the active MPU on the IRF member device. If the active MPU is powered off, the reboot information is lost. (In IRF mode.)
# (In standalone mode.) Display brief information about the most recent reboot.
<Sysname> display kernel reboot 1
----------------- Reboot record 1 -----------------
Reason : 0x31
Slot : 1
Target Slot : 0
Cpu : 0
VCPU ID : 0
# (In standalone mode.) Display detailed information about the most recent reboot.
<Sysname> display kernel reboot 1 verbose
Reason : 0x31
Slot : 1
Target Slot : 0
Cpu : 0
VCPU ID : 0
Call trace:
Recorded at |
Time when the reboot was recorded, with microsecond precision. |
Occurred at |
Time when the reboot occurred, with microsecond precision. |
Reason |
Reboot reason. |
Thread |
Name and number of the kernel thread that was running when the reboot occurred. |
Context |
Context where the reboot occurred. |
Chassis |
(In IRF mode.) Number of the IRF member device that triggered the reboot. |
Target Chassis |
(In IRF mode.) Member ID of the rebooted IRF member device. |
Slot |
Number of the slot that triggered the reboot. |
Target Slot |
Number of the rebooted slot. |
Cpu |
Number of the CPU that triggered the reboot. |
VCPU ID |
Number of the CPU core that triggered the reboot. |
Information about kernel modules that had been loaded when the kernel thread rebooted, including kernel module name and memory address. |
Last five kernel thread switches on the CPU before the kernel thread rebooted, including kernel thread name and kernel thread switching time, with microsecond precision. |
Dump stack |
Stack information for the threads that were running when the reboot occurred. |
Call trace |
Function call stack information for the threads that were running when the reboot occurred. |
No reboot information exists. |
reset kernel reboot
Use display kernel starvation to display kernel thread starvation information.
In standalone mode:
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display kernel starvation show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of thread starvations to display, in the range of 1 to 60.
offset: Specifies the offset between the starting starvation and the most recent starvation, in the range of 0 to 59. The default value is 0.
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command displays kernel thread starvation information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command displays kernel thread starvation information for the global active MPU. (In IRF mode.)
# (In standalone mode.) Display brief information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1
----------------- Starvation record 1 -----------------
Description : INFO: task comsh: 16306 blocked for more than 10 seconds.
Slot : 1
Cpu : 0
VCPU ID : 0
# (In standalone mode.) Display detailed information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1 verbose
Slot : 1
Cpu : 0
VCPU ID : 0
Register content:
Call trace:
Instruction dump:
For detailed information about the command output, see Table 2.
reset kernel starvation
Use display kernel starvation configuration to display kernel thread starvation detection configuration.
In standalone mode:
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display kernel starvation configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays kernel thread starvation detection configuration on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify this option, the command displays kernel thread starvation detection configuration for the global active MPU. (In IRF mode.)
# Display kernel thread starvation detection configuration.
<Sysname> display kernel starvation configuration
Thread starvation detection: Enabled
Starvation timer (in seconds): 10
TID: 123 Name: co0
Table 5 Command output
Starvation timer (in seconds): n |
Time interval (in seconds) to identify a kernel thread starvation. A kernel thread starvation occurs if a kernel thread does not run within n seconds. |
Kernel threads excluded from kernel thread starvation detection. |
Name |
TID |
display process
Use display process to display process state information.
In standalone mode:
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process [ all | job job-id | name process-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
all: Specifies all processes. With the all keyword or without any parameters, the command displays state information for all processes.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. Each process has a fixed job ID.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters that must not contain question marks or spaces.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays process state information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for the global active MPU. (In IRF mode.)
# Display state information for the process scmd.
<Sysname> display process name scmd
Job ID: 1
PID: 1
Parent JID: 0
Parent PID: 0
Executable path: -
Instance: 0
Respawn: OFF
Respawn count: 1
Max. spawns per minute: 0
Last started: Wed Jun 1 14:45:46 2013
Process state: sleeping
Max. core: 0
ARGS: -
TID LAST_CPU Stack PRI State HH:MM:SS:MSEC Name
1 0 0K 120 S 0:0:5:220 scmd
Table 6 Command output
Job ID |
Job ID of the process. The job ID never changes. |
PID |
Number of the process. The number identifies the process, and it might change as the process restarts. |
Parent JID |
Job ID of the parent process. |
Parent PID |
Number of the parent process. |
Executable path |
Executable path of the process. For a kernel thread, this field displays a hyphen (-). |
Instance |
Instance number of the process. Whether a process can run multiple instances depends on the software implementation. |
Respawn |
Indicates whether the process restarts when an error occurs: · ON—The process automatically restarts. · OFF—The process does not automatically restarts. |
Respawn count |
Times that the process has restarted. The starting value is 1. |
Max. spawns per minute |
Maximum number of times that the process can restart within one minute. If the threshold is reached, the system automatically shuts down the process. |
Last started |
Time when the most recent restart occurred. |
Process state |
State of the process: · running—Running or waiting in the queue. · sleeping—Interruptible sleep. · traced or stopped—Stopped. · uninterruptible sleep—Uninterruptible sleep. · zombie—The process has quit, but some resources are not released. |
Max. core |
Maximum number of core dump files that the process can create. 0 indicates that the process never creates a core dump file. A process creates a core dump file after it abnormally restarts. If the number of core dump files reaches the maximum value, no more core dump files are created. core dump files are helpful for troubleshooting. |
ARGS |
Parameters carried by the process during startup. If the process carries no parameters, this field displays a hyphen (-). |
TID |
Thread ID. |
LAST_CPU |
Number of the CPU on which the process is last scheduled. |
Stack |
Stack size. |
PRI |
Thread priority. |
State |
Thread state: · R—Running. · S—Sleeping. · T—Traced or stopped. · D—Uninterruptible sleep. · Z—Zombie. |
HH:MM:SS:MSEC |
Running time since the most recent start. |
Name |
Process name. |
# Display state information for all processes.
<Sysname> display process all
JID PID %CPU %MEM STAT PRI TTY HH:MM:SS COMMAND
1 1 0.0 0.0 S 120 - 00:00:59 scmd
2 2 0.0 0.0 S 115 - 00:00:00 [kthreadd]
3 3 0.0 0.0 S 99 - 00:00:00 [migration/0]
4 4 0.0 0.0 S 115 - 00:00:11 [ksoftirqd/0]
5 5 0.0 0.0 S 99 - 00:00:00 [watchdog/0]
6 6 0.0 0.0 S 99 - 00:00:00 [migration/1]
7 7 0.0 0.0 S 115 - 00:00:01 [ksoftirqd/1]
8 8 0.0 0.0 S 99 - 00:00:00 [watchdog/1]
9 9 0.0 0.0 S 99 - 00:00:00 [migration/2]
10 10 0.0 0.0 S 115 - 00:00:03 [ksoftirqd/2]
11 11 0.0 0.0 S 99 - 00:00:00 [watchdog/2]
12 12 0.0 0.0 S 99 - 00:00:00 [migration/3]
13 13 0.0 0.0 S 115 - 00:00:00 [ksoftirqd/3]
14 14 0.0 0.0 S 99 - 00:00:00 [watchdog/3]
15 15 0.0 0.0 S 99 - 00:00:00 [migration/4]
16 16 0.0 0.0 S 115 - 00:00:00 [ksoftirqd/4]
17 17 0.0 0.0 S 99 - 00:00:00 [watchdog/4]
18 18 0.0 0.0 S 99 - 00:00:00 [migration/5]
---- More ----
Table 7 Command output
JID |
Job ID of a process. It never changes. |
PID |
Number of a process. |
%CPU |
CPU usage in percentage (%). |
%MEM |
Memory usage in percentage (%). |
STAT |
State of a process: · R—Running. · S—Sleeping. · T—Traced or stopped. · D—Uninterruptible sleep. · Z—Zombie. |
PRI |
Priority of a process for scheduling. |
TTY |
TTY used by a process. |
HH:MM:SS |
Running time since the most recent start. If the running time reaches or exceeds 100 hours, this field displays only the number of hours. |
COMMAND |
Name and parameters of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
display process cpu
Use display process cpu to display CPU usage for all processes.
In standalone mode:
display process cpu [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process cpu [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays CPU usage for all processes on the active MPU. (In standalone mode.)
# Display CPU usage for all processes.
<Sysname> display process cpu
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7%
JID 5Sec 1Min 5Min Name
1 0.0% 0.0% 0.0% scmd
2 0.0% 0.0% 0.0% [kthreadd]
3 0.1% 0.0% 0.0% [ksoftirqd/0]
Table 8 Command output
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7% |
System CPU usage within the last 5 seconds, 1 minute, and 5 minutes. |
JID |
5Sec |
CPU usage of the process within the last 5 seconds. |
1Min |
CPU usage of the process within the last minute. |
5Min |
CPU usage of the process within the last 5 minutes. |
Name |
Name of the process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
display process log
Use display process log to display log information for all user processes.
In standalone mode:
display process log [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process log [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays log information for all processes on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays log information for the global active MPU. (In IRF mode.)
# Display log information for all user processes.
<Sysname> display process log
Process JobID PID Abort Core Exit Kill StartTime EndTime
knotify 92 92 N N 0 36 12-17 07:10:27 12-17 07:10:27
knotify 93 93 N N 0 -- 12-17 07:10:27 12-17 07:10:27
automount 94 94 N N 0 -- 12-17 07:10:27 12-17 07:10:28
knotify 111 111 N N 0 -- 12-17 07:10:28 12-17 07:10:28
comsh 121 121 N N 0 -- 12-17 07:10:30 12-17 07:10:30
knotify 152 152 N N 0 -- 12-17 07:10:31 12-17 07:10:31
autocfgd 155 155 N N 0 -- 12-17 07:10:31 12-17 07:10:31
pkg_update 122 122 N N 0 -- 12-17 07:10:30 12-17 07:10:31
Table 9 Command output
Process |
Name of a user process. |
JobID |
Job ID of a user process. |
PID |
Abort |
Indicates whether the process exited abnormally: · Y—Yes. · N—No. |
Core |
Indicates whether the process can generate core dump files: · Y—Yes. · N—No. |
Exit |
Process exit code. This field displays two hyphens (--) if the process was killed by a signal. |
Kill |
Code of the signal that killed the process. This field displays two hyphens (--) if the process exited instead of being killed. |
StartTime |
Time when the user process started. |
EndTime |
Time when the user process ended. |
Use display process memory to display memory usage for all user processes.
In standalone mode:
display process memory [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process memory [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays memory usage for all user processes on the active MPU. (In standalone mode.)
When a user process starts, it requests the following types of memory from the system:
· Text memory—Stores code for the user process.
· Data memory—Stores data for the user process.
· Stack memory—Stores temporary data.
· Dynamic memory—Heap memory dynamically assigned and released by the system according to the needs of the user process. To view dynamic memory information, execute the display process memory heap command.
# Display memory usage for all user processes.
<Sysname> display process memory
JID Text Data Stack Dynamic Name
1 384 1800 16 36 scmd
2 0 0 0 0 [kthreadd]
3 0 0 0 0 [ksoftirqd/0]
4 0 0 0 0 [watchdog/0]
5 0 0 0 0 [events/0]
6 0 0 0 0 [khelper]
29 0 0 0 0 [kblockd/0]
49 0 0 0 0 [vzmond]
52 0 0 0 0 [pdflush]
---- More ----
Table 10 Command output
JID |
Text |
Text memory used by the user process, in KB. The value for a kernel thread is 0. |
Data |
Data memory used by the user process, in KB. The value for a kernel thread is 0. |
Stack |
Stack memory used by the user process, in KB. The value for a kernel thread is 0. |
Dynamic |
Dynamic memory used by the user process, in KB. The value for a kernel thread is 0. |
Name |
Name of the user process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
Use display process memory heap to display heap memory usage for a user process.
In standalone mode:
display process memory heap job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process memory heap job job-id [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a user process by its job ID, in the range of 1 to 2147483647.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays heap memory usage for the user process on the active MPU.(In standalone mode.)
Heap memory comprises fixed-sized blocks such as 16-byte or 64-byte blocks. It stores data and variables used by the user process. When a user process starts, the system dynamically allocates heap memory to the process.
Each memory block has an address represented in hexadecimal format, which can be used to access the memory block. You can view memory block addresses by using the display process memory heap size command, and view memory block contents by using the display process memory heap address command.
# Display brief information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1
Total virtual memory heap space(in bytes) : 2228224
Total physical memory heap space(in bytes) : 262144
Total allocated memory(in bytes) : 161576
# Display detailed information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1 verbose
Heap usage:
Size Free Used Total Free Ratio
16 8 52 60 13%
64 3 1262 1265 0.2%
128 2 207 209 1%
512 3 55 58 5.1%
4096 3 297 300 1%
8192 1 19 20 5%
81920 0 1 1 0%
Summary:
Total virtual memory heap space (in bytes) : 2293760
Total physical memory heap space (in bytes) : 58368
Total allocated memory (in bytes) : 42368
Table 11 Command output
Size |
Size of each memory block, in bytes. |
Free |
Number of free memory blocks. |
Used |
Number of used memory blocks. |
Total |
Total number of memory blocks. |
Free Ratio |
Ratio of free memory to total memory. It helps identify fragment information. |
Use display process memory heap address to display heap memory content starting from a specified memory block for a process.
In standalone mode:
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process memory heap job job-id address starting-address length memory-length [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
address starting-address: Specifies the starting memory block by its address.
length memory-length: Specifies the memory block length in the range of 1 to 1024 bytes.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays memory content information on the active MPU.(In standalone mode.)
When a user process runs abnormally, the command helps locate the problem.
# Display 128-byte memory block content starting from the memory block 0xb7e30580 for the process job 1.
<Sysname> display process memory heap job 1 address b7e30580 length 128
B7E30580: 14 00 EF FF 00 00 00 00 E4 39 E2 B7 7C 05 E3 B7 .........9..|...
B7E30590: 14 00 EF FF 2F 73 62 69 6E 2F 73 6C 62 67 64 00 ..../sbin/slbgd.
B7E305A0: 14 00 EF FF 00 00 00 00 44 3B E2 B7 8C 05 E3 B7 ........D;......
B7E305B0: 14 00 EF FF 2F 73 62 69 6E 2F 6F 73 70 66 64 00 ..../sbin/ospfd.
B7E305C0: 14 00 EF FF 00 00 00 00 A4 3C E2 B7 AC 05 E3 B7 .........<......
B7E305D0: 14 00 EF FF 2F 73 62 69 6E 2F 6D 73 74 70 64 00 ..../sbin/mstpd.
B7E305E0: 14 00 EF FF 00 00 00 00 04 3E E2 B7 CC 05 E3 B7 .........>......
B7E305F0: 14 00 EF FF 2F 73 62 69 6E 2F 6E 74 70 64 00 00 ..../sbin/ntpd..
Use display process memory heap size to display the addresses of heap memory blocks with a specified size used by a process.
In standalone mode:
display process memory heap job job-id size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process memory heap job job-id size memory-size [ offset offset-size ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
size memory-size: Specifies the memory block size in the range of 1 to 4294967295.
offset offset-size: Specifies an offset in the range of 0 to 4294967295. The default value is 128. For example, suppose the system allocates 100 16-byte memory blocks to process job 1, and the process has used 66 blocks. Then if you execute the display process memory heap job 1 size 16 offset 50 command, the output shows the addresses of the 51st through 66th 16-byte blocks used by the process.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays block address information on the active MPU. (In standalone mode.)
The command displays memory block addresses in hexadecimal format. To view memory block content, execute the display process memory heap address command.
# Display the addresses of 16-byte memory blocks used by process job 1.
<Sysname> display process memory heap job 1 size 16
0xb7e300c0 0xb7e300d0 0xb7e300e0 0xb7e300f0
0xb7e30100 0xb7e30110 0xb7e30120 0xb7e30130
0xb7e30140 0xb7e30150 0xb7e30160 0xb7e30170
0xb7e30180 0xb7e30190 0xb7e301a0 0xb7e301b0
0xb7e301c0 0xb7e301d0 0xb7e301e0 0xb7e301f0
0xb7e30200 0xb7e30210 0xb7e30220 0xb7e30230
# Display the addresses of 16-byte memory blocks starting from the fifth block used by process job 1.
<Sysname> display process memory heap job 1 size 16 offset 4
exception filepath
Use exception filepath to specify the directory for saving core dump files.
Use undo exception filepath to remove the specified directory.
exception filepath directory
undo exception filepath directory
The directory for saving core dump files is the root directory of the default file system.
directory: Specifies the directory for saving core dump files.
(In standalone mode.) The specified directory must be the root directory of a file system on the active MPU.
(In IRF mode.) The specified directory must be the root directory of a file system on the global active MPU.
You can use the command to change the directory if there are different kinds of storage media on the device.
The system saves core dump files to the core directory in the specified directory. If the core directory does not exist in the specified directory, the system creates the core directory before saving core dump files.
If no directory is specified or the specified directory is not accessible, the system cannot save core dump files.
# Set the directory for saving core dump files to flash:/.
<Sysname> exception filepath flash:/
process core
Use monitor kernel deadloop action to specify the action to be taken in response to a kernel thread deadloop.
Use undo monitor kernel deadloop action to restore the default.
In standalone mode:
monitor kernel deadloop action { reboot | record-only } [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop action [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel deadloop action { reboot | record-only } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop action [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The device logs the event and reboots the slot or CPU when a kernel thread deadloop occurs.
reboot: Logs the event and reboots the specified slot or CPU.
record-only: Logs the event.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command specifies the action for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify a card, this command specifies the action for the global active MPU. (In IRF mode.)
Use this command only under the guidance of H3C technical support staff. Inappropriate configuration can cause system breakdown.
# (In standalone mode.) Set the kernel thread deadloop protection action to reboot for slot 3.
[Sysname] monitor kernel deadloop action reboot slot 3
Use monitor kernel deadloop enable to enable kernel thread deadloop detection.
Use undo monitor kernel deadloop enable to disable kernel thread deadloop detection.
In standalone mode:
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number [ core core-number&<1-64> ] ] ]
undo monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel deadloop enable [ chassis chassis-number slot slot-number [ cpu cpu-number [ core core-number&<1-64> ] ] ]
undo monitor kernel deadloop enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection is disabled.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command is applied to the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify this option, the command is applied to the global active MPU. (In IRF mode.)
core core-number&<1-64> ]: Specifies a maximum of 64 CPU cores.
Kernel threads share resources in kernel space. If a kernel thread monopolizes the CPU for a long time, other threads cannot run, resulting in a deadloop.
The command enables the device to detect deadloops. If a thread occupies the CPU regularly, the device considers that a deadloop has occurred and outputs a deadloop message.
# Enable kernel thread deadloop detection.
[Sysname] monitor kernel deadloop enable
monitor kernel deadloop time
Use monitor kernel deadloop exclude-thread to disable kernel thread deadloop detection for a kernel thread.
Use undo monitor kernel deadloop exclude-thread to enable kernel thread deadloop detection for a kernel thread.
In standalone mode:
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel deadloop exclude-thread tid [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop exclude-thread [ tid ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection monitors all kernel threads.
tid: Specifies a kernel thread by its ID, in the range of 1 to 2147483647. If no kernel thread is specified for the undo command, the default is restored.
This command can be used multiple times to disable kernel thread deadloop detection for up to 128 kernel threads.
# Disable kernel thread deadloop detection for kernel thread 15.
[Sysname]monitor kernel deadloop exclude-thread 15
Use monitor kernel deadloop time to set the interval for identifying a kernel thread deadloop.
Use undo monitor kernel deadloop time to restore the default.
In standalone mode:
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop time [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel deadloop time time [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop time [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The interval for identifying a kernel thread deadloop is 8 seconds.
time time: Specifies the interval for identifying a kernel thread deadloop, in the range of 1 to 65535 seconds.
If a kernel thread runs for the specified interval, kernel thread deadloop detection considers that a deadloop has occurred.
# Set the interval for identifying a kernel thread deadloop to 8 seconds.
[Sysname] monitor kernel deadloop time 8
Use monitor kernel starvation enable to enable kernel thread starvation detection.
Use undo monitor kernel starvation enable to disable kernel thread starvation detection.
In standalone mode:
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel starvation enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection is disabled.
Starvation occurs when a thread is unable to access shared resources.
The command enables the system to detect and report thread starvation. If a thread is not executed within an interval, the system considers that a starvation has occurred, and outputs a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
# Enable kernel thread starvation detection.
[Sysname] monitor kernel starvation enable
Use monitor kernel starvation exclude-thread to disable kernel thread starvation detection for a kernel thread.
Use undo monitor kernel starvation exclude-thread to enable kernel thread starvation detection for a kernel thread.
In standalone mode:
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel starvation exclude-thread tid [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation exclude-thread [ tid ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection, if enabled, monitors all kernel threads.
This command can be used multiple times to disable kernel thread starvation detection for up to 128 kernel threads.
# Disable kernel thread starvation detection for kernel thread 15.
[Sysname] monitor kernel starvation exclude-thread 15
Use monitor kernel starvation time to set the interval for identifying a kernel thread starvation.
Use undo monitor kernel starvation time to restore the default.
In standalone mode:
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation time [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel starvation time time [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation time [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The interval for identifying a kernel thread starvation is 120 seconds.
time time: Specifies the interval for identifying a kernel thread starvation, in the range of 1 to 65535 seconds.
If a thread is not executed within the specified interval, the system considers that a starvation has occurred, and outputs a starvation message.
# Set the interval for identifying a kernel thread starvation to 120 seconds.
[Sysname] monitor kernel starvation time 120
monitor process
Use monitor process to display process statistics.
In standalone mode:
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor process [ dumbtty ] [ iteration number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays process statistics in descending order of CPU usage without refreshing statistics. If you do not specify this keyword, the command displays statistics for the top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times and process statistics are refreshed every 5 seconds.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays process statistics for the active MPU.(In standalone mode.)
If you do not specify the dumbtty keyword, the command displays process statistics in an interactive mode. In this mode, the system automatically determines the number of displayed processes according to the screen size, and does not display exceeding processes. You can also input interactive commands as shown in Table 12 to perform relevant operations.
Commands |
? or h |
Displays help information that includes available interactive commands. |
1 |
Displays state information for physical CPUs. For example, if you enter 1 for the first time, the state of each physical CPU is displayed in a separate row. If you enter 1 again, the average value of all CPU states is displayed. If you enter 1 for the third time, separate states are displayed. By default, the average value of all CPU states is displayed. |
c |
Sorts processes by CPU usage in descending order, which is the default setting. |
d |
Sets the interval for refreshing process statistics, in the range of 1 to 2147483647 seconds. The default value is 5 seconds. |
f |
Sorts processes by the number of open files in descending order. Files are identified by file descriptors (FDs). |
k |
Kills a process. Because the command can impact system operation, be cautious to use it. |
l |
Refreshes the screen. |
m |
Sorts processes by memory usage in descending order. |
n |
Changes the maximum number of processes displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only processes not exceeding the screen size can be displayed. |
q |
Quits the interactive mode. |
t |
Sorts processes by running time in descending order. |
Moves sort field to the next left column. |
Moves sort field to the next right column. |
# Display process statistics in dumbtty mode. In this mode, the system displays process statistics once, and then returns to command view.
<Sysname> monitor process dumbtty
301 processes; 412 threads; 3140 fds
Thread states: 5 running, 407 sleeping, 0 stopped, 0 zombie
CPU0: 0.66% idle, 10.89% user, 65.38% kernel, 23.07% interrupt, 0.00% steal
CPU1: 81.03% idle, 4.43% user, 8.22% kernel, 6.32% interrupt, 0.00% steal
CPU2: 98.10% idle, 0.63% user, 0.00% kernel, 1.27% interrupt, 0.00% steal
CPU3: 0.00% idle, 0.00% user, 100.00% kernel, 0.00% interrupt, 0.00% steal
CPU4: 99.37% idle, 0.00% user, 0.63% kernel, 0.00% interrupt, 0.00% steal
CPU5: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt, 0.00% steal
CPU6: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt, 0.00% steal
CPU7: 64.76% idle, 2.56% user, 18.58% kernel, 14.10% interrupt, 0.00% steal
Memory: 3940M total, 2442M available, page size 4K
JID PID PRI State FDs MEM HH:MM:SS CPU Name
125 125 100 R 0 0K 02:17:03 12.48% [MgtPktTask]
364 364 125 R 15 2988K 02:01:04 8.60% dpbackupd
361 361 125 S 94 154072K 00:30:34 2.15% dhcpd
362 362 125 S 85 173272K 00:30:43 2.15% dhcpd
251 251 120 S 15 12116K 00:03:09 1.63% diagd
1 1 120 S 18 11204K 00:00:59 1.54% scmd
# Display process statistics twice in dumbtty mode.
<Sysname> monitor process dumbtty iteration 2
Thread states: 4 running, 408 sleeping, 0 stopped, 0 zombie
CPU0: 0.65% idle, 9.43% user, 65.40% kernel, 24.52% interrupt, 0.00% steal
CPU1: 79.26% idle, 5.03% user, 8.80% kernel, 6.91% interrupt, 0.00% steal
CPU2: 77.51% idle, 1.25% user, 11.87% kernel, 9.37% interrupt, 0.00% steal
CPU4: 98.76% idle, 0.00% user, 0.62% kernel, 0.62% interrupt, 0.00% steal
CPU7: 90.01% idle, 0.62% user, 5.62% kernel, 3.75% interrupt, 0.00% steal
125 125 100 R 0 0K 02:20:17 12.01% [MgtPktTask]
364 364 125 R 15 2988K 02:03:58 8.25% dpbackupd
361 361 125 S 94 154072K 00:31:18 2.12% dhcpd
362 362 125 R 85 173272K 00:31:27 2.12% dhcpd
251 251 120 S 15 12116K 00:03:15 1.63% diagd
1 1 120 S 18 11204K 00:00:59 1.30% scmd
Five seconds later, the system refreshes process statistics as follows (which is the same as executing the monitor process dumbtty command twice at 5-second intervals):
CPU0: 0.58% idle, 12.45% user, 58.62% kernel, 28.35% interrupt, 0.00% steal
CPU1: 94.27% idle, 1.91% user, 3.63% kernel, 0.19% interrupt, 0.00% steal
CPU2: 62.97% idle, 2.11% user, 19.76% kernel, 15.16% interrupt, 0.00% steal
CPU4: 99.81% idle, 0.00% user, 0.19% kernel, 0.00% interrupt, 0.00% steal
CPU7: 99.81% idle, 0.00% user, 0.00% kernel, 0.19% interrupt, 0.00% steal
125 125 100 R 0 0K 02:20:23 11.76% [MgtPktTask]
364 364 125 R 15 2988K 02:04:02 10.61% dpbackupd
361 361 125 R 94 154072K 00:31:19 2.63% dhcpd
362 362 125 S 85 173272K 00:31:28 2.63% dhcpd
251 251 120 S 15 12116K 00:03:16 0.63% diagd
156 156 116 D 0 0K 00:03:14 0.26% [bLK0]
# Display process statistics in interactive mode.
170 processes; 218 threads; 1170 fds
Thread states: 2 running, 216 sleeping, 0 stopped, 0 zombie
CPU: 73.79% idle, 0.81% user, 22.95% kernel, 2.45% interrupt, 0.00% steal
Memory: 500M total, 125M available, page size 4K
116 116 120 S 56 31840K 00:34:27 8.96% apmgrd
1 1 120 S 18 9828K 00:00:08 6.89% scmd
84 84 120 S 17 18320K 00:01:15 6.20% diagd
151 151 120 S 151 41024K 00:07:14 2.06% stamgrd
54 54 105 D 0 0K 00:00:16 0.68% [hellopkt]
118 118 120 S 18 72360K 00:00:11 0.68% comsh
4834 4834 120 S 27 1640K 00:00:00 0.68% top
2 2 115 S 0 0K 00:00:00 0.00% [kthreadd]
3 3 99 S 0 0K 00:00:00 0.00% [migration/0]
4 4 115 S 0 0K 00:00:05 0.00% [ksoftirqd/0]
Press q to quit, or press ? or h for help.
The system refreshes process statistics every 5 seconds. You can enter interactive commands to perform operation as follows:
· Enter h or a question mark (?) to display help information as follows:
Help for interactive commands:
?,h Show the available interactive commands
1 Toggle SMP view: '1' single/separate states
c Sort by the CPU field(default)
d Set the delay interval between screen updates
f Sort by number of open files
k Kill a job
l Refresh the screen
m Sort by memory used
n Set the maximum number of processes to display
q Quit the interactive display
t Sort by run time of processes since last restart
< Move sort field to the next left column
> Move sort field to the next right column
Press any key to continue
· Enter d, and then enter a number to modify the refresh interval. If you enter 3, statistics are refreshed every 3 seconds.
Enter the delay interval between updates(1~2147483647):3
· Enter n, and then enter a number to modify the maximum number of displayed processes. If you enter 5, statistics for five processes are displayed.
Enter the max number of processes to display(0 means unlimited):5
CPU0: 78.44% idle, 0.31% user, 18.75% kernel, 2.50% interrupt, 0.00% steal
116 116 120 S 56 31840K 00:34:33 12.00% apmgrd
151 151 120 S 151 41024K 00:07:15 2.20% stamgrd
84 84 120 S 17 18320K 00:01:16 1.95% diagd
86 86 120 S 28 14440K 00:00:59 0.24% syslogd
128 128 120 S 10 2804K 00:00:44 0.24% hcld
177 177 120 S 45 53128K 00:00:41 0.24% xmlcfgd
87 87 120 S 21 19888K 00:00:34 0.24% devd
166 166 120 S 52 44188K 00:00:26 0.24% qosd
70 70 105 S 0 0K 00:00:24 0.24% [sock/1]
123 123 120 S 44 34464K 00:00:18 0.24% aaad
· Enter f to sort processes by FDs in descending order. (You can also enter command c, m, or t to sort processes.)
CPU: 89.55% idle, 0.32% user, 9.15% kernel, 0.98% interrupt, 0.00% steal
151 151 120 S 151 41024K 00:07:16 1.22% stamgrd
82 82 100 S 92 27204K 00:00:02 0.00% dbmd
116 116 120 S 56 31840K 00:34:37 6.14% apmgrd
166 166 120 S 52 44188K 00:00:26 0.00% qosd
177 177 120 S 45 53128K 00:00:42 0.00% xmlcfgd
123 123 120 S 44 34464K 00:00:18 0.00% aaad
135 135 120 S 42 26380K 00:00:08 0.00% aclmgrd
153 153 120 S 41 11808K 00:00:13 0.20% ethd
96 96 120 S 35 42536K 00:00:07 0.00% pexd
· Enter k and then enter a JID to kill a process. If you enter 123, the process named aaad is killed.
Enter the JID to kill: 123
169 processes; 214 threads; 1110 fds
Thread states: 2 running, 212 sleeping, 0 stopped, 0 zombie
CPU: 89.11% idle, 0.66% user, 7.92% kernel, 2.31% interrupt, 0.00% steal
Memory: 500M total, 127M available, page size 4K
4132 4132 120 S 34 89932K 00:00:05 0.23% comsh
118 118 120 S 18 72360K 00:00:11 0.00% comsh
177 177 120 S 43 53128K 00:00:42 0.23% xmlcfgd
151 151 120 S 144 41024K 00:07:18 1.44% stamgrd
106 106 120 S 28 38424K 00:00:10 0.00% evbd
100 100 120 S 19 37652K 00:00:13 0.00% ifmgr
116 116 120 S 56 31840K 00:34:44 6.28% apmgrd
125 125 110 S 33 31568K 00:00:06 0.23% laggd
· Enter q to quit interactive mode.
Table 13 Command output
xx processes; xx threads; xxx fds |
Numbers of processes, threads, and open files. |
JID |
Job ID of a process, which never changes. |
PID |
ID of a process. |
PRI |
Priority level of a process. |
State |
FDs |
Number of open files for a process. |
MEM |
Memory usage. It displays 0 for a kernel thread. |
HH:MM:SS |
Running time of a process since last restart. |
CPU |
CPU usage of a process. |
Name |
Name of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread. |
monitor thread
Use monitor thread to display thread statistics.
In standalone mode:
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor thread [ dumbtty ] [ iteration number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays all thread statistics in descending order of CPU usage without refreshing statistics. If you do not specify the keyword, the command displays statistics for top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays thread statistics for the active MPU. (In standalone mode.)
If you do not specify the dumbtty keyword, the command displays thread statistics in an interactive mode. In this mode, the system automatically determines the number of displayed thread processes according to the screen size and does not display exceeding processes. You can also input interactive commands as shown in Table 14 to perform relevant operations.
Commands |
? or h |
1 |
Displays one of the following items in turn when you press 1 again and again: · Values of parameters of physical CPUs. · Average values of parameters of all CPUs. By default, the command displays the average values of parameters of all CPUs. |
c |
Sorts statistics by CPU usage in descending order. By default, the command sorts statistics by CPU usage in descending order. |
d |
Sets the interval for refreshing statistics. The default interval is 5 seconds. |
k |
Kills a process. Because the command can impact system operation, be cautious when you use it. |
l |
n |
Changes the maximum number of threads displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only threads not exceeding the screen size can be displayed. |
q |
Quits interactive mode. |
t |
Sorts statistics by the running time since the latest startup. |
# Display thread statistics in dumbtty mode.
<Sysname> monitor thread dumbtty
425 processes; 567 threads
Thread states: 5 running, 562 sleeping, 0 stopped, 0 zombie
CPU0: 79.88% idle, 3.14% user, 11.32% kernel, 5.66% interrupt, 0.00% steal
CPU1: 73.43% idle, 4.43% user, 10.12% kernel, 12.02% interrupt, 0.00% steal
CPU2: 98.09% idle, 0.00% user, 1.91% kernel, 0.00% interrupt, 0.00% steal
CPU5: 0.00% idle, 0.00% user, 100.00% kernel, 0.00% interrupt, 0.00% steal
CPU7: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt, 0.00% steal
CPU8: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt, 0.00% steal
CPU9: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt, 0.00% steal
CPU10: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt, 0.00% steal
CPU11: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt, 0.00% steal
CPU12: 99.38% idle, 0.00% user, 0.62% kernel, 0.00% interrupt, 0.00% steal
CPU13: 99.37% idle, 0.00% user, 0.63% kernel, 0.00% interrupt, 0.00% steal
CPU14: 0.00% idle, 0.00% user, 100.00% kernel, 0.00% interrupt, 0.00% steal
CPU15: 0.00% idle, 0.00% user, 100.00% kernel, 0.00% interrupt, 0.00% steal
Memory: 7958M total, 5755M available, page size 4K
JID TID LAST_CPU PRI State HH:MM:SS MAX CPU Name
199 199 3 100 R 22:22:09 3 6.73% [MgtPktT
359 359 5 100 R 22:21:40 1 5.94% [BFDP]
360 360 14 100 R 22:21:40 1 5.94% [BFDRX1]
361 361 15 100 R 22:21:40 1 5.94% [BFDRX2]
1 1 0 120 S 00:01:14 69 1.21% scmd
347 347 4 119 D 01:38:48 2 1.02% [IbcCntR
371 111484 1 120 R 00:00:00 1 0.41% diagd
7 7 1 115 S 00:00:06 0 0.09% [ksoftir
256 256 2 116 D 00:19:58 1 0.09% [bLK0]
286 286 4 115 D 00:16:08 0 0.09% [bRX_Cle
207 207 0 115 D 00:00:11 0 0.04% [DST3]
253 253 2 130 D 00:11:06 1 0.04% [bC.0]
275 275 0 115 D 00:00:09 0 0.04% [MARP]
280 280 0 120 D 00:02:29 1 0.04% [SCAR]
# Display thread statistics in interactive mode.
Thread states: 6 running, 561 sleeping, 0 stopped, 0 zombie
CPU: 73.53% idle, 0.42% user, 26.00% kernel, 0.05% interrupt, 0.00% steal
199 199 3 100 R 22:23:41 3 6.18% [MgtPktT
359 359 5 100 R 22:23:12 1 6.18% [BFDP]
360 360 14 100 R 22:23:13 1 6.12% [BFDRX1]
361 361 15 100 R 22:23:13 1 6.12% [BFDRX2]
347 347 4 119 R 01:38:55 2 0.68% [IbcCntR
371 111673 1 120 R 00:00:00 1 0.47% diagd
253 253 2 130 D 00:11:07 1 0.10% [bC.0]
256 256 2 116 D 00:20:00 1 0.10% [bLK0]
286 286 4 115 D 00:16:09 0 0.10% [bRX_Cle
The command refreshes the thread statistics at 5-second intervals.
k Kill a job
n Set the maximum number of threads to display
t Sort by run time of threads since last restart
Enter the delay interval between screen updates (1~2147483647): 3
· Enter n, and then enter a number to modify the maximum number of displayed threads. If you enter 5, statistics for five threads are displayed.
Enter the max number of threads to display(0 means unlimited): 5
CPU: 74.18% idle, 0.20% user, 25.56% kernel, 0.06% interrupt, 0.00% steal
359 359 5 100 R 22:26:17 1 6.07% [BFDP]
199 199 3 100 R 22:26:46 3 6.06% [MgtPktT
360 360 14 100 R 22:26:17 1 6.06% [BFDRX1]
361 361 15 100 R 22:26:17 1 6.06% [BFDRX2]
347 347 4 119 S 01:39:08 2 0.47% [IbcCntR
Table 15 Command output
84 processes; 107 threads |
Numbers of processes and threads. |
JID |
Job ID of a thread, which never changes. |
TID |
ID of a thread. |
LAST_CPU |
Number of the CPU on which the most recent thread scheduling occurs. |
PRI |
Priority level of a thread. |
State |
State of a thread: · R—Running. · S—Sleeping. · T—Traced or stopped. · D—Uninterruptible sleep. · Z—Zombie. |
HH:MM:SS |
Running time of a thread since last restart. |
MAX |
Longest time that a single thread scheduling occupies the CPU, in milliseconds. |
CPU |
CPU usage of a thread. |
Name |
Name of a thread. If square brackets ([ ]) exist in a thread name, the thread is a kernel thread. |
process core
Use process core to enable core dump for a process and set the maximum number of core dump files or disable core dump for a process.
In standalone mode:
process core { maxcore value | off } { job job-id | name process-name } [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
process core { maxcore value | off } { job job-id | name process-name } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
A process generates a core dump file for the first exception and does not generate any core dump files for subsequent exceptions.
off: Disables core dump.
maxcore value: Enables core dump and sets the maximum number of core dump files, in the range of 1 to 10.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. The job ID does not change after the process restarts.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, the command is applied to the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
The command applies to all instances of a process.
The command enables the system to generate a core dump file each time the specified process crashes until the maximum number of core dump files is reached. A core dump file stores information about the process.
Core dump files consume storage resources. Enable core dump only for processes that might have problems
# Disable core dump for process routed.
<Sysname> process core off name routed
# Enable core dump for process routed and set the maximum number of core dump files to 5.
<Sysname> process core maxcore 5 name routed
display exception context
exception filepath
reset exception context
Use reset exception context to clear context information for process exceptions.
In standalone mode:
reset exception context [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset exception context [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command clears context information for process exceptions on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command clears context information for process exceptions on the global active MPU. (In IRF mode.)
# Clear context information for exceptions.
<Sysname> reset exception context
Use reset kernel deadloop to clear kernel thread deadloop information.
In standalone mode:
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset kernel deadloop [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command clears kernel thread deadloop information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command clears kernel thread deadloop information for the global active MPU. (In IRF mode.)
# Clear kernel thread deadloop information.
<Sysname> reset kernel deadloop
Use reset kernel exception to clear kernel thread exception information.
In standalone mode:
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset kernel exception [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command clears kernel thread exception information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command clears kernel thread exception information for the global active MPU. (In IRF mode.)
# Clear kernel thread exception information.
<Sysname> reset kernel exception
reset kernel reboot
Use reset kernel reboot to clear kernel thread reboot information.
In standalone mode:
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset kernel reboot [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command clears kernel thread reboot information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command clears kernel thread reboot information for the global active MPU. (In IRF mode.)
# Clear kernel thread reboot information.
<Sysname> reset kernel reboot
Use reset kernel starvation to clear kernel thread starvation information.
In standalone mode:
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset kernel starvation [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify this option, the command clears kernel thread starvation information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. If you do not specify this option, the command clears kernel thread starvation information for the global active MPU. (In IRF mode.)
# Clear kernel thread starvation information.
<Sysname> reset kernel starvation
