07-Layer 3 - IP Routing Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command References-Release795x-6W10007-Layer 3 - IP Routing Command Reference
03-RIP commands
03-RIP commands 204.05 KB
RIP commands
bfd all-interfaces enable
Use bfd all-interfaces enable to enable BFD on all interfaces of a RIP process.
Use undo bfd all-interfaces enable to restore the default.
bfd all-interfaces enable [ ctrl ]
BFD is disabled on the interfaces of a RIP process.
RIP view
ctrl: Enables BFD bidirectional control detection for both directly and indirectly connected neighbors. If you do not specify this keyword, RIP uses BFD single-hop echo detection for a directly connected neighbor and BFD bidirectional control detection for an indirectly connected neighbor.
RIP supports the following BFD detection modes:
·          Single-hop echo detection—Detection mode for a directly connected neighbor. In this mode, a BFD session is established only when the directly connected neighbor has route information to send.
·          Single-hop echo detection for a specific destination—Detection mode for a directly connected neighbor. In this mode, a BFD session is established to the specified RIP neighbor when RIP is enabled on the local interface.
·          Bidirectional control detection—Detection mode for both directly and indirectly connected neighbors. In this mode, a BFD session is established only when both ends have routes to send and BFD is enabled on the receiving interface.
Bidirectional control detection must be configured on both ends of the link to take effect.
The BFD setting configured in interface view takes precedence over the BFD setting configured in RIP view.
Using the undo peer command cannot delete the neighbor relationship immediately to bring down the BFD session.
# Enable BFD on all interfaces of RIP process 1.
[Sysname] rip 1
[Sysname-rip-1] bfd all-interfaces enable
rip bfd
checkzero
Use checkzero to enable zero field check on RIPv1 messages.
Use undo checkzero to disable zero field check.
checkzero
undo checkzero
The zero field check feature is enabled.
RIP view
When the zero field check is enabled, the router discards RIPv1 messages in which zero fields contain non-zero values. If all messages are trustworthy, disable this feature to reduce the workload of the CPU.
# Disable zero field check on RIPv1 messages for RIP process 1.
[Sysname] rip
[Sysname-rip-1] undo checkzero
default cost
Use default cost to configure a default metric for redistributed routes.
Use undo default cost to restore the default.
default cost cost-value
undo default cost
The default metric of redistributed routes is 0.
RIP view
cost-value: Specifies a default metric for redistributed routes, in the range of 0 to 16.
When you use the import-route command to redistribute routes from another routing protocol without specifying a metric, the metric specified by the default cost command applies.
# Configure a default metric of 3 for redistributed routes.
[Sysname] rip 1
[Sysname-rip-1] default cost 3
import-route
default-route
Use default-route to configure all interfaces running a RIP process to advertise a default route with a specified metric to RIP neighbors.
Use undo default-route to restore the default.
default-route { only | originate } [ cost cost-value | route-policy route-policy-name ] *
undo default-route
No default route is sent to RIP neighbors.
RIP view
only: Advertises only a default route.
originate: Advertises both a default route and other routes.
cost-value: Specifies a cost for the default route, in the range of 1 to 15. The default is 1.
route-policy route-policy-name: Specifies a routing policy by its name, a case sensitive string of 1 to 63 characters. If you specify this option, the command advertises a default route only when a route in the routing table matches the routing policy.
A RIP router configured with this feature does not receive any default route from RIP neighbors.
# Configure all interfaces running RIP process 100 to send only a default route with a metric of 2 to RIP neighbors.
[Sysname] rip 100
[Sysname-rip-100] default-route only cost 2
rip default-route
display rip
Use display rip to display state and configuration information for a RIP process.
display rip [ process-id ]
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. If no process is specified, the command displays state and configuration information for all RIP processes.
# Display current state and configuration information for all RIP processes.
<Sysname> display rip
  Public VPN-instance name:
    RIP process: 1
       RIP version: 1
       Preference: 100
           Routing policy: abc
       Fast-reroute:
           Routing policy: frr
       Checkzero: Enabled
       Default cost: 0
       Summary: Enabled
       Host routes: Enabled
       Maximum number of load balanced routes: 8
       Update time   :   30 secs  Timeout time         :  180 secs
       Suppress time :  120 secs  Garbage-collect time :  120 secs
       Update output delay:   20(ms)  Output count:    3
       Graceful-restart interval:   60 secs
       Triggered Interval : 5 50 200
       BFD: Enabled (ctrl)
       Silent interfaces: None
       Default routes: Originate  Default routes cost: 3
       Verify-source: Enabled
       Networks:
           1.0.0.0
       Configured peers:
           197.168.6.2
       Triggered updates sent: 0
       Number of routes changes: 1
       Number of replies to queries: 0
The RIP process runs on the public network.
Private VPN-instance name
VPN instance where the RIP process runs.
RIP process
RIP process ID.
RIP version
RIP version 1 or 2.
Preference
RIP preference.
Fast-reroute
RIP FRR.
Checkzero
Indicates whether the zero field check is enabled for RIPv1 messages: Enabled or Disabled.
Default cost
Default cost of redistributed routes.
Summary
Indicates whether route summarization is enabled: Enabled or Disabled.
Host routes
Indicates whether to receive host routes: Enabled or Disabled.
Update time
RIP update interval, in seconds.
Timeout time
RIP timeout time, in seconds.
Suppress time
RIP suppress interval, in seconds.
RIP garbage-collect interval, in seconds.
Update output delay
RIP packet sending interval, in seconds.
Output count
Maximum number of RIP packets sent at each interval.
GR interval, in seconds.
Triggered Interval
Triggered update sending interval.
BFD
Whether BFD is enabled:
·         Disabled—Disabled in RIP view.
·         Enabled—Enabled in RIP view. RIP uses BFD single-hop echo detection for a directly connected neighbor and BFD bidirectional control detection for an indirectly connected neighbor.
·         Enabled (ctrl)—Enabled in RIP view. RIP uses BFD bidirectional control detection for both directly and indirectly connected neighbors.
Silent interfaces
Silent interfaces, which do not periodically send updates.
Default routes
Indicates whether a default route is sent to RIP neighbors.
·         only—Only a default route is advertised.
·         originate—A default route is advertised along with other routes.
·         disable—No default route is advertised.
Default routes cost
Metric for a default route.
Verify-source
Indicates whether the source IP address is checked for received RIP routing updates: Enabled or Disabled.
Networks
Networks enabled with RIP.
Configured peers
Configured neighbors.
Number of triggered updates sent.
Number of route changes.
Number of RIP responses.
display rip database
Use display rip database to display active routes for a RIP process.
display rip process-id database [ ip-address { mask-length | mask } ]
ip-address { mask-length | mask }: Displays active routes for the specified IP address. If you do not specify this argument, the command displays all actives routes for a RIP process.
# Display active routes for RIP process 100.
<Sysname> display rip 100 database
   1.0.0.0/8, auto-summary
       1.1.1.0/24, cost 16, interface summary
       1.1.1.0/24, cost 0, nexthop 1.1.1.1, RIP-interface
       1.1.2.0/24, cost 0, imported
   2.0.0.0/8, auto-summary
   2.0.0.0/8, cost 1, nexthop 1.1.1.2
# Display active routes with destination IP address 1.1.1.0 and mask length 24 for RIP process 100.
<Sysname> display rip 100 database 1.1.1.0 24
cost
Cost of the route.
auto-summary
Indicates that the route is a RIP automatic summary route.
interface summary
Indicates that the route is a RIP interface summary route.
nexthop
Address of the next hop.
RIP-interface
Direct route on a RIP-enabled interface.
imported
Indicates that the route is redistributed from another routing protocol.
display rip graceful-restart
Use display rip graceful-restart to display the GR status for a RIP process.
display rip [ process-id ] graceful-restart
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the GR status for all RIP processes.
# Display the GR status for RIP process 1.
<Sysname> display rip 1 graceful-restart
 RIP process: 1
 Graceful Restart capability     : Enabled
 Current GR state                : Normal
 Graceful Restart period         : 60  seconds
 Graceful Restart remaining time : 0   seconds
Indicates whether GR is enabled: Enabled or Disabled.
Current GR state
GR state:
·         Under GR—GR is in progress.
·         Normal—No GR is in progress or GR has completed.
GR interval.
display rip interface
Use display rip interface to display RIP interface information for a RIP process.
display rip process-id interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If no interface is specified, the command displays information about all RIP interfaces for the RIP process.
# Display information about all interfaces for RIP process 1.
<Sysname> display rip 1 interface
Total: 1
 Interface: GigabitEthernet3/1/2
    Address/Mask: 1.1.1.1/24          Version: RIPv1
    MetricIn: 0                       MetricIn route policy: Not designated
    MetricOut: 1                      MetricOut route policy: Not designated
    Split-horizon/Poison-reverse: On/Off  Input/Output: On/On
    Default route: Off
    BFD: Enabled (ctrl), inherited
    Current number of packets/Maximum number of packets: 0/2000
Total
Number of interfaces running RIP.
Name of an interface running RIP.
Address/Mask
IP address and mask of the interface.
Version
RIP version running on the interface.
MetricIn
Additional metric added to incoming routes.
Name of the routing policy used to add an additional metric for incoming routes. If no routing policy is used, the field displays Not designated.
MetricOut
Additional metric added to outgoing routes.
Name of the routing policy used to add an additional routing metric for outgoing routes. If no routing policy is used, the field displays Not designated.
Split-horizon
Indicates whether split horizon is enabled:
·         on—Enabled.
·         off—Disabled.
Poison-reverse
Indicates whether poison reverse is enabled:
·         on—Enabled.
·         off—Disabled.
Input/Output
Indicates whether the interface is enabled to receive and send RIP messages:
·         on—Enabled.
·         off—Disabled.
Default route
Indicates whether to send a default route to RIP neighbors:
·         Only—Advertises only a default route.
·         Originate—Advertises both a default route and other routes.
·         No-originate—Advertises only non-default routes.
·         Off—Advertises no default route.
Default route cost
Update output delay
RIP packet sending interval.
Output count
Maximum number of RIP packets that can be sent at each interval.
BFD
Whether BFD for RIP is enabled:
·         Disabled—Disabled on in interface view and RIP view.
·         Enabled—Enabled on the RIP interface. The interface uses BFD single-hop echo detection for a directly connected neighbor and BFD bidirectional control detection for an indirectly connected neighbor.
·         Enabled (ctrl)—Enabled on the RIP interface. The interface uses BFD bidirectional control detection for both directly and indirectly connected neighbors.
·         Enabled, inherited—Enabled in RIP view. RIP uses BFD single-hop echo detection for a directly connected neighbor and BFD bidirectional control detection for an indirectly connected neighbor. The RIP interface uses the BFD setting configured in RIP view.
·         Enabled (ctrl), inherited—Enabled in RIP view. RIP uses BFD bidirectional control detection for both directly and indirectly connected neighbors. The RIP interface uses the BFD setting configured in RIP view.
·         Enabled (destination)—Enabled on the RIP interface. The interface uses BFD single-hop echo detection for a specific destination.
Current number of packets /Maximum number of packets
Number of RIP packets to be sent/maximum number of RIP packets that can be sent within a certain interval.
display rip neighbor
Use display rip neighbor to display neighbor information for a RIP process.
display rip process-id neighbor [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays all neighbor information for the RIP process.
# Display neighbor information for RIP process 1.
<Sysname> display rip 1 neighbor
 Neighbor address: 197.168.2.3
     Interface  : GigabitEthernet3/1/2
     Version    : RIPv2     Last update: 00h00m02s
     Relay nbr  : N/A       BFD session: N/A
     Bad packets: 0         Bad routes : 0
Table 5 Command output
Output interface that is connected to the neighbor.
Version
Version of RIP that the neighbor runs.
Last update
Time elapsed since the most recent update.
Relay nbr
Relay neighbor type.
BFD session
BFD session type.
Bad packets
Number of received bad packets.
Bad routes
Number of received bad routes.
display rip non-stop-routing
Use display rip non-stop-routing to display the NSR status for a RIP process.
display rip [ process-id ] non-stop-routing
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the NSR status for all RIP processes.
# Display the NSR status for RIP process 1.
<Sysname> display rip 1 non-stop-routing
 RIP process: 1
 Nonstop Routing capability: Enabled
 Current NSR state         : Finish
Table 6 Command output
Indicates whether NSR is enabled: Enabled or Disabled.
Current NSR state
NSR state:
·         Initialization.
·         Smooth—Upgrading data.
·         Advertising—Advertising routes.
·         Redistribution—Redistributing routes.
·         Finish.
display rip route
Use display rip route to display routing information for a RIP process.
display rip process-id route [ ip-address { mask-length | mask } [ verbose ] | peer ip-address | statistics ]
ip-address { mask-length | mask }: Displays route information for the specified IP address.
verbose: Displays all routing information for the specified destination IP address. If you do not specify this keyword, the command displays only information about optimal routes with the specified destination IP address.
peer ip-address: Displays route information learned from the specified neighbor.
statistics: Displays route statistics, including the total number of routes and number of routes from each neighbor.
If no optional parameters are specified, the display rip process-id route command displays all routing information for a RIP process.
# Display all routing information for RIP process 1.
<Sysname> display rip 1 route
              D - Direct, O - Optimal, F - Flush to RIB
 Peer 1.1.1.1 on GigabitEthernet3/1/2
      Destination/Mask        Nexthop           Cost    Tag     Flags   Sec
      3.0.0.0/8               1.1.1.1           1       0       RAOF    24
 Local route
      4.4.4.4/32              0.0.0.0           0       0       RDOF    -
      1.1.1.0/24              0.0.0.0           0       0       RDOF    -
# Display specified routing information for RIP process 1.
<Sysname> display rip 1 route 3.0.0.0 8 verbose
  Destination/Mask    OrigNexthop/RealNexthop          Cost  Tag   Flags Sec
  3.0.0.0/8           1.1.1.1/1.1.1.1                  1     0     RAOF  16
Table 7 Command output
Route Flags
·         R—RIP route.
·         T—TRIP route.
·         P—The route never ages out.
·         A—The route is aging.
·         S—The route is suppressed.
·         G—The route is in Garbage-collect state.
·         D—The route is a direct route.
·         O—The route is an optimal route.
·         F—The route has been flushed to the RIB.
Peer X.X.X.X on interface-type interface-number
Routing information learned from a neighbor on a RIP interface.
Local route
Locally generated direct routes.
Destination/Mask
Destination IP address and subnet mask.
Nexthop
Next hop of the route.
If the route is from a directly connected neighbor, the original next hop is the real next hop.
If the route is from an indirectly connected neighbor, the RealNexthop field displays the recursive next hop for the route. Otherwise, the field is blank.
Cost
Cost of the route.
Tag
Route tag.
Flags
Route state.
Sec
Remaining time of the timer corresponding to the route state.
# Display routing statistics for RIP process 1.
<Sysname> display rip 1 route statistics
 Peer                    Optimal/Aging       Optimal/Permanent       Garbage
 1.1.1.1                 1/1                 0/0                     0
 Local                   2/0                 0/0                     0
 Total                   3/1                 0/0                     0
Table 8 Command output
Peer
IP address of a neighbor.
Optimal
Total number of optimal routes.
Aging
Total number of aging routes.
Permanent
Total number of routes that never age out.
Garbage
Total number of routes in the Garbage-collection state.
Local
Total number of locally generated direct routes.
Total
Total number of routes learned from all RIP neighbors.
dscp
Use dscp to set the DSCP value for outgoing RIP packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for outgoing RIP packets is 48.
RIP view
dscp-value: Specifies the DSCP value in the range of 0 to 63.
# Set the DSCP value for outgoing RIP packets to 63 in RIP process 1.
[Sysname] rip 1
[Sysname-rip-1] dscp 63
fast-reroute
Use fast-reroute to configure RIP FRR.
Use undo fast-reroute to disable RIP FRR.
undo fast-reroute
RIP FRR is disabled.
RIP view
route-policy route-policy-name: Specifies a routing policy by its name, a case sensitive string of 1 to 63 characters. If you specify this option, the command designates a backup next hop for the routes that match the routing policy.
RIP FRR is available only when the state of primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down. A unidirectional link refers to the link through which packets are forwarded only from one end to the other.
RIP FRR is only effective for RIP routes that are learned from directly connected neighbors.
Equal-cost routes do not support RIP FRR.
# Enable RIP FRR and use routing policy frr to specify a backup next hop.
[Sysname] route-policy frr permit node 10
[Sysname-route-policy-frr-10] if-match ip address prefix-list abc
[Sysname-route-policy-frr-10] apply fast-reroute backup-interface gigabitethernet 3/1/1 backup-nexthop 193.1.1.8
[Sysname-route-policy-frr-10] quit
[Sysname] rip 100
[Sysname-rip-100] fast-reroute route-policy frr
filter-policy export
Use filter-policy export to configure RIP to filter redistributed routes.
Use undo filter-policy export to remove the filtering.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [ interface-type interface-number | bgp | direct | eigrp [ eigrp-as ] | { isis | ospf | rip } [ process-id ] | static ]
undo filter-policy export [ interface-type interface-number | bgp | direct | eigrp [ eigrp-as ] | { isis | ospf | rip } [ process-id ] | static ]
RIP does not filter redistributed routes.
RIP view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes.
bgp: Filters routes redistributed from BGP.
direct: Filters direct routes.
eigrp: Filters routes redistributed from EIGRP.
isis: Filters routes redistributed from IS-IS.
ospf: Filters routes redistributed from OSPF.
rip: Filters routes redistributed from RIP.
eigrp-as: Specifies an EIGRP process by its ID in the range of 1 to 65535. The default value is 1.
process-id: Specifies a process ID of IS-IS, OSPF, or RIP, in the range of 1 to 65535. The default value is 1.
You can configure only one filtering policy to filter routes redistributed from a routing protocol or an interface. Without any protocol or interface specified, the filtering policy applies globally. If you execute this command multiple times, the most recent configuration takes effect.
To remove the filtering policy configured for a protocol or an interface, use the undo filter-policy export command with the protocol or interface specified.
To reference an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·          To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·          To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route. For the mask configuration to take effect, specify a contiguous subnet mask.
# Use basic ACL 2000 to filter redistributed routes.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 export
# Use IP prefix list abc to filter redistributed routes.
[Sysname] ip prefix-list abc index 10 permit 11.0.0.0 8
[Sysname] rip 1
[Sysname-rip-1] filter-policy prefix-list abc export
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16 to pass. Use ACL 3000 to filter redistributed routes.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 deny ip
[Sysname] rip 1
[Sysname-rip-1] filter-policy 3000 export
acl (ACL and QoS Command Reference)
import-route
ip prefix-list
filter-policy import
Use filter-policy import to configure RIP to filter received routes.
Use undo filter-policy import to remove the filtering.
filter-policy { ipv4-acl-number | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] } import [ interface-type interface-number ]
undo filter-policy import [ interface-type interface-number ]
RIP does not filter received routes.
RIP view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter received routes.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
gateway prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes based on their next hops.
You can configure only one filtering policy to filter routes received on an interface. Without any interface specified, the filtering policy applies globally. If you execute this command multiple times, the most recent configuration takes effect.
To remove the filtering policy configured for an interface, use the undo filter-policy import command with the interface specified.
# Use basic ACL 2000 to filter received RIP routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 import
# Use IP prefix list abc to filter received RIP routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy prefix-list abc import
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16 to pass. Use ACL 3000 to filter received routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 3000 import
ip prefix-list
graceful-restart
Use graceful-restart to enable RIP GR.
Use undo graceful-restart to disable RIP GR.
graceful-restart
RIP GR is disabled.
RIP view
The graceful-restart command and the non-stop-routing command are mutually exclusive.
# Enable GR for RIP process 1.
[Sysname] rip 1
[Sysname-rip-1] graceful-restart
graceful-restart interval
Use graceful-restart interval to set the GR interval.
Use undo graceful-restart interval to restore the default.
The GR interval is 60 seconds.
RIP view
interval: Specifies the GR interval in the range of 5 to 360 seconds.
# Set the GR interval to 200 seconds for RIP process 1.
[Sysname] rip 1
[Sysname-rip-1] graceful-restart interval 200
host-route
Use host-route to enable host route reception.
Use undo host-route to disable host route reception.
host-route
undo host-route
RIP receives host routes.
RIP view
A router might receive many host routes from the same subnet. These routes are not helpful for routing and occupy a large number of resources. To solve this problem, use the undo host-route command to disable RIP from receiving host routes.
This command takes effect only for RIPv2 routes.
# Disable RIP from receiving host routes.
[Sysname] rip 1
[Sysname-rip-1] undo host-route
import-route
Use import-route to enable route redistribution.
Use undo import-route to disable route redistribution.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name | tag tag ] *
import-route { direct | static } [ cost cost-value | route-policy route-policy-name | tag tag ] *
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | cost cost-value | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | cost cost-value | route-policy route-policy-name | tag tag ] *
undo import-route { bgp | direct | eigrp [ eigrp-as | all-as ] | { isis | ospf | rip } [ process-id | all-processes ] | static }
RIP does not redistribute routes.
RIP view
bgp: Redistributes BGP routes.
direct: Redistributes direct routes.
eigrp: Redistributes EIGRP routes.
isis: Redistributes IS-IS routes.
ospf: Redistributes OSPF routes.
rip: Redistributes RIP routes.
static: Redistributes static routes.
as-number: Specifies an AS by its number in the range of 1 to 4294967295. This argument applies only to the BGP protocol. If you do not specify the as-number argument, this command redistributes all IPv4 EBGP routes. As a best practice, specify the AS number to avoid redistributing excessive IPv4 EBGP routes.
all-as: Specifies all EIGRP processes.
process-id: Specifies an IS-IS, OSPF, or RIP process by its ID in the range of 1 to 65535. The default is 1.
all-processes: Enables route redistribution from all IS-IS, OSPF or RIP processes.
allow-ibgp: Allows redistribution of IBGP routes.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. By default, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
cost cost-value: Specifies a cost for redistributed routes, in the range of 0 to 16. The default cost is 0.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag for marking redistributed routes, in the range of 0 to 65535. The default is 0.
This command redistributes only active routes. To view route state information, use the display ip routing-table protocol command.
The import-route bgp command redistributes only EBGP routes if you do not specify the allow-ibgp keyword. To redistribute IBGP routes in addition to EBGP routes, specify the allow-ibgp keyword.
IMPORTANT
IMPORTANT:
Improper redistribution of IBGP routes might cause routing loops. When you use the allow-ibgp keyword, make sure you understand its impact on the network.
When you execute the undo form of the command, per-process setting has higher priority than the all-processes setting.
·          The undo import-route { isis | ospf | rip } all-processes command cannot remove the setting configured for a process by using the import-route { isis | ospf | rip } process-id command. To remove the setting for that process, you must specify the process ID in the undo form of the command.
·          The undo import-route eigrp all-as command cannot remove the setting configured for an EIGRP process by using the import-route eigrp eigrp-as command. To remove the setting for that process, you must specify the process number in the undo form of the command.
# Redistribute static routes into RIP, and set the cost for redistributed routes to 4.
[Sysname] rip 1
[Sysname-rip-1] import-route static cost 4
default cost
maximum load-balancing
Use maximum load-balancing to set the maximum number of RIP equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of RIP ECMP routes is 128.
RIP view
number: Specifies the maximum number of RIP ECMP routes. Load balancing is not implemented when the value is 1. The value range for this argument is 1 to 128.
# Set the maximum number of RIP ECMP routes to 2.
[Sysname] rip
[Sysname-rip-1] maximum load-balancing 2
network
Use network to enable RIP on an interface attached to a specified network.
Use undo network to disable RIP on an interface attached to a specified network.
undo network network-address
RIP is disabled on an interface.
RIP view
network-address: Specifies a subnet address where an interface resides.
wildcard-mask: Specifies an IP address wildcard mask. A wildcard mask can be thought of as a subnet mask, with 1s and 0s inverted. For example, a wildcard mask of 255.255.255.0 corresponds to a subnet mask of 0.0.0.255. If you do not specify this argument, the command uses the natural mask.
RIP runs only on an interface attached to the specified network, which can be configured with a wildcard mask. An interface not on the specified network does not receive or send RIP routes, or advertise its direct routes.
For a single RIP process, the network 0.0.0.0 command can enable RIP on all interfaces. If multiple RIP processes exist, the command is not applicable.
If a physical interface is attached to multiple networks, you cannot advertise these networks in different RIP processes.
# Enable RIP process 100 on the interface attached to the network 129.102.0.0.
[Sysname] rip 100
[Sysname-rip-100] network 129.102.0.0
rip enable
non-stop-routing
Use non-stop-routing to enable RIP NSR.
Use undo non-stop-routing to disable RIP NSR.
non-stop-routing
RIP NSR is disabled.
RIP view
RIP NSR enabled for a RIP process takes effect only on that process. As a best practice, enable RIP NSR for each process if multiple RIP processes exist.
The non-stop-routing command and the graceful-restart command are mutually exclusive.
# Enable NSR for RIP process 1.
[Sysname] rip 1
[Sysname-rip-1] non-stop-routing
output-delay
Use output-delay to set the rate at which an interface sends RIP packets.
Use undo output-delay to restore the default.
output-delay time count count
undo output-delay
An interface sends up to three RIP packets every 20 milliseconds.
RIP view
time: Specifies the sending interval in the range of 10 to 100 milliseconds.
count: Specifies the maximum number of RIP packets sent at each interval, in the range of 1 to 30.
# Configure all interfaces running RIP process 1 to send up to 10 RIP packets every 60 milliseconds.
[Sysname] rip 1
[Sysname-rip-1] output-delay 60 count 10
peer
Use peer to specify a RIP neighbor in the NBMA network, where routing updates destined for the neighbor are only unicasts and not multicast or broadcast.
Use undo peer to remove a RIP neighbor.
peer ip-address
undo peer ip-address
RIP does not unicast updates to any neighbor.
RIP view
ip-address: Specifies the IP address of a RIP neighbor, in dotted decimal notation.
Do not use the peer ip-address command when the neighbor is directly connected. Otherwise, the neighbor might receive both unicast and multicast (or broadcast) messages with the same routing information.
This command must be executed together with the undo validate-source-address command, which disables source IP address check on inbound RIP routing updates.
# Configure RIP to unicast updates to peer 202.38.165.1.
[Sysname] rip 1
[Sysname-rip-1] peer 202.38.165.1
preference
Use preference to specify a preference for RIP routes.
Use undo preference to restore the default.
undo preference
The preference of RIP routes is 100.
RIP view
preference: Specifies a preference for RIP routes, in the range of 1 to 255. The smaller the value, the higher the preference.
You can specify a routing policy by using the keyword route-policy to set a preference for matching RIP routes.
·          The preference set by the routing policy applies to all matching RIP routes. The preference of other routes is set by the preference command.
·          If no preference is set by the routing policy, the preference of all RIP routes is set by the preference command.
# Set a preference of 120 for RIP routes.
[Sysname] rip 1
[Sysname-rip-1] preference 120
reset rip process
Use reset rip process to reset a RIP process.
reset rip process-id process
After executing the command, you are prompted to confirm the operation.
# Reset RIP process 100.
<Sysname> reset rip 100 process
Reset RIP process? [Y/N]:y
reset rip statistics
Use reset rip statistics to clear statistics for a RIP process.
reset rip process-id statistics
# Clear statistics for RIP process 100.
<Sysname> reset rip 100 statistics
rip
Use rip to enable RIP and enter RIP view.
Use undo rip to disable RIP.
rip [ process-id ] [ vpn-instance vpn-instance-name ]
undo rip [ process-id ]
RIP is disabled.
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. The default is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the RIP process runs on the public network.
You must enable a RIP process before configuring global parameters for it. This restriction does not apply to configuring interface parameters.
If you disable a RIP process, the configured interface parameters become invalid.
# Enable RIP process 1 and enter RIP view.
[Sysname] rip
[Sysname-rip-1]
rip authentication-mode
Use rip authentication-mode to configure RIPv2 authentication.
Use undo rip authentication-mode to restore the default.
rip authentication-mode { keychain keychain-name { rfc2453 | rfc4822 } | md5 { rfc2082 { cipher | plain } string key-id | rfc2453 { cipher | plain } string } | simple { cipher | plain } string }
RIPv2 authentication is not configured.
Interface view
keychain: Specifies the keychain authentication.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
rfc2453: Uses the message format defined in RFC 2453 (IETF standard).
rfc4822: Uses the message format defined in RFC 4822.
md5: Specifies the MD5 authentication.
rfc2082: Uses the message format defined in RFC 2082.
plain: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
key-id: Specifies the key ID in the range of 1 to 255.
simple: Specifies the simple authentication mode.
A newly configured key overwrites the old one, if any.
Although you can specify an authentication mode for RIPv1 in interface view, the configuration does not take effect because RIPv1 does not support authentication.
When keychain authentication is configured on a RIPv2 interface, RIPv2 performs the following operations before sending a packet:
1.        Obtains a valid send key from the keychain.
RIPv2 does not send the packet if it fails to obtain a valid send key.
2.        Uses the key ID, authentication algorithm, and key string to authenticate the packet.
When keychain authentication is configured on a RIPv2 interface, RIPv2 performs the following operations after receiving a packet:
·          If the packet is in the format defined in RFC 2453, RIPv2 uses all valid accept keys on the keychain to authenticate the packet.
RIPv2 drops the packet if the authentication fails.
·          If the packet is in the format defined in RFC 4822, RIPv2 performs the following operations:
a.    Uses the key ID carried in the packet to obtain a valid accept key.
RIPv2 drops the packet if it fails to obtain a valid accept key.
b.    Uses the authentication algorithm and key string to authenticate the packet.
When you configure keychain authentication on a RIPv2 interface, follow these restrictions and guidelines:
·          If the message format defined in RFC 2453 is specified, the authentication algorithm can only be MD5. The key string cannot contain more than 16 characters. If the key string length exceeds the limit, only the first 16 characters are used for authentication.
·          If the message format defined in RFC 4822 is specified, the key ID can only be in the range of 0 to 255. The authentication algorithm can be MD5 (compliant with the message format defined in RFC 2082), HMAC-SHA-1, HMAC-SHA-256, or HMAC-SM3.
# Configure MD5 authentication with message format defined in RFC 2453 on GigabitEthernet 3/1/1, and specify a plaintext key rose.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] rip version 2
[Sysname-GigabitEthernet3/1/1] rip authentication-mode md5 rfc2453 plain rose
rip version
rip bfd
Use rip bfd to enable or disable BFD for RIP on an interface.
Use undo rip bfd to remove the configuration.
rip bfd { disable | enable [ ctrl | destination ip-address ] }
undo rip bfd
BFD for RIP is disabled on an interface.
Interface view
disable: Disables BFD for RIP on an interface.
enable: Enables BFD for RIP on an interface.
ctrl: Enables BFD bidirectional control detection for both directly and indirectly connected neighbors. If you do not specify this keyword, the interface uses BFD single-hop echo detection for a directly connected neighbor and BFD bidirectional control detection for an indirectly connected neighbor.
destination ip-address: Specifies a destination to which the interface establishes a BFD session. If you do not specify this option, the interface establishes a BFD session to its RIP neighbor.
If you specify the destination ip-address option, the interface uses BFD single-hop echo detection to detect failures on the link to the specified destination. If a failure is detected on the link, the interface does not send or receive RIP packets anymore.
The bfd all-interfaces enable command enables BFD for RIP on all interfaces of a RIP process. If the link to one of the interfaces becomes unstable, the BFD session might flap on the interface. This will affect the stability of the network. To resolve this problem, use the rip bfd disable command to disable BFD on that interface.
# Enable BFD for RIP on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rip bfd enable
rip default-route
Use rip default-route to configure a RIP interface to advertise a default route with a specified metric.
Use undo rip default-route to disable a RIP interface from sending a default route.
rip default-route { { only | originate } [ cost cost-value | route-policy route-policy-name ] * | no-originate }
A RIP interface advertises a default route if the RIP process that the interface runs is enabled to advertise a default route.
Interface view
no-originate: Advertises only non-default routes.
An interface that is enabled to advertise a default route does not receive any default route from RIP neighbors.
# Configure GigabitEthernet 3/1/1 to advertise only a default route with a metric of 2.
[Sysname-GigabitEthernet3/1/1] rip default-route only cost 2
# Configure GigabitEthernet 3/1/1 to advertise a default route with a metric of 4 and other routes.
[Sysname-GigabitEthernet3/1/1] rip default-route originate cost 4
default-route
rip enable
Use rip enable to enable RIP on an interface.
Use undo rip enable to disable RIP on an interface.
rip process-id enable [ exclude-subip ]
undo rip enable
Interface view
exclude-subip: Excludes secondary IP addresses from being enabled with RIP. If you do not specify this keyword, RIP is also enabled on secondary IP addresses of a RIP-enabled interface.
The rip enable command has a higher priority than the network command.
# Enable RIP process 100 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rip 100 enable
network
rip input
Use rip input to enable an interface to receive RIP messages.
Use undo rip input to disable an interface from receiving RIP messages.
rip input
undo rip input
An interface is enabled to receive RIP messages.
Interface view
# Disable GigabitEthernet 3/1/1 from receiving RIP messages.
[Sysname-GigabitEthernet3/1/1] undo rip input
rip max-packet-length
Use rip max-packet-length to set the maximum length of RIP packets.
Use undo rip max-packet-length to restore the default.
rip max-packet-length value
The maximum length of RIP packets is 512 bytes.
Interface view
value: Specifies the maximum length of RIP packets, in the range of 32 to 65535 bytes.
The supported maximum length of RIP packets varies by vendor. Use this feature with caution to avoid compatibility issues.
When authentication is enabled, follow these guidelines to ensure packet forwarding:
·          For simple authentication, the maximum length of RIP packets must be no less than 52 bytes.
·          For MD5 authentication (with packet format defined in RFC 2453), the maximum length of RIP packets must be no less than 56 bytes.
·          For MD5 authentication (with packet format defined in RFC 2082), the maximum length of RIP packets must be no less than 72 bytes.
If the configured value in the rip max-packet-length command is greater than the MTU of an interface, the interface MTU value is used as the maximum length of RIP packets.
# Set the maximum length of RIP packets on GigabitEthernet 3/1/1 to 1024 bytes.
[Sysname-GigabitEthernet3/1/1] rip max-packet-length 1024
rip metricin
Use rip metricin to configure an interface to add a metric to inbound routes.
Use undo rip metricin to restore the default.
rip metricin [ route-policy route-policy-name ] value
undo rip metricin
The additional metric of an inbound route is 0.
Interface view
route-policy route-policy-name: Specifies a routing policy by its name, a case sensitive string of 1 to 63 characters. If you specify this option, the command adds an additional metric for the routes that match the routing policy.
value: Adds an additional metric to inbound routes, in the range of 0 to 16.
When a valid RIP route is received, the system adds a metric to it and then installs it into the routing table. The metric of the route received on the configured interface is then increased. If the sum of the additional metric and the original metric is greater than 16, the metric of the route will be 16.
If a routing policy is referenced with the route-policy keyword, the following operations can be performed:
·          Routes matching the policy are added with the metric specified in the apply cost command configured in the policy. Routes not matching it are added with the metric specified in the rip metricin command. The rip metricin command does not support specifying the + or – keyword in the apply cost command to add or reduce a metric.
·          If the apply cost command is not configured in the policy, all the inbound routes are added with the metric specified in the rip metricin command.
# Configure GigabitEthernet 3/1/1 to add a metric of 6 to the inbound route 1.0.0.0/8 and to add a metric of 2 to other inbound routes.
[Sysname] ip prefix-list 123 permit 1.0.0.0 8
[Sysname] route-policy abc permit node 10
[Sysname-route-policy-abc-10] if-match ip address prefix-list 123
[Sysname-route-policy-abc-10] apply cost 6
[Sysname-route-policy-abc-10] quit
[Sysname-GigabitEthernet3/1/1] rip metricin route-policy abc 2
apply cost
rip metricout
Use rip metricout to configure an interface to add a metric to outbound routes.
Use undo rip metricout to restore the default.
rip metricout [ route-policy route-policy-name ] value
undo rip metricout
The additional metric for outbound routes is 1.
Interface view
value: Adds an additional metric to outbound routes, in the range of 1 to 16.
With the command configured on an interface, the metric of RIP routes sent on the interface will be increased.
·          Routes matching the policy is added with the metric specified in the apply cost command configured in the policy. Routes not matching it are added with the metric specified in the rip metricout command. The rip metricout command does not support specifying the + or – keyword in the apply cost command to add or reduce a metric.
·          If the apply cost command is not configured in the policy, all the outbound routes are added with the metric specified in the rip metricout command.
# Configure GigabitEthernet 3/1/1 to add a metric of 6 to the outbound route 1.0.0.0/8 and to add a metric of 2 to other outbound routes.
[Sysname-GigabitEthernet3/1/1] rip metricout route-policy abc 2
apply cost
rip mib-binding
Use rip mib-binding to bind a RIP process to MIB.
Use undo rip mib-binding to restore the default.
rip mib-binding process-id
MIB is bound to the RIP process with the smallest process ID.
If the specified process ID does not exist, the MIB binding configuration does not take effect.
Deleting a RIP process bound to MIB deletes the MIB binding configuration. After the RIP process is deleted, MIB is bound to the RIP process with the smallest process ID.
# Bind RIP process 100 to MIB.
[Sysname] rip mib-binding 100
rip output
Use rip output to enable an interface to send RIP messages.
Use undo rip output to disable an interface from sending RIP messages.
rip output
undo rip output
An interface sends RIP messages.
Interface view
# Disable GigabitEthernet 3/1/1 from sending RIP messages.
[Sysname-GigabitEthernet3/1/1] undo rip output
rip output-delay
Use rip output-delay to set the RIP packet sending interval for an interface and the maximum number of RIP packets that can be sent at each interval.
Use undo rip output-delay to restore the default.
rip output-delay time count count
An interface uses the RIP packet sending rate set for the RIP process that the interface runs.
Interface view
Time: Specifies the RIP packet sending interval in the range of 10 to 100 milliseconds.
# Configure GigabitEthernet 3/1/1 to send a maximum of six RIP packets every 30 milliseconds.
[Sysname-GigabitEthernet3/1/1] rip output-delay 30 count 6
output-delay
rip poison-reverse
Use rip poison-reverse to enable the poison reverse feature.
Use undo rip poison-reverse to disable the poison reverse feature.
rip poison-reverse
The poison reverse feature is disabled.
Interface view
# Enable the poison reverse feature on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rip poison-reverse
rip primary-path-detect bfd
Use rip primary-path-detect bfd to enable BFD for RIP FRR.
Use undo rip primary-path-detect bfd to disable BFD for RIP FRR.
rip primary-path-detect bfd { ctrl | echo }
BFD for RIP FRR is disabled.
Interface view
ctrl: Enables BFD bidirectional control detection for RIP FRR to detect primary link failures.
echo: Enables BFD single-hop echo detection for RIP FRR to detect primary link failures.
For quicker RIP FRR, use BFD on the primary link of redundant links to detect link failure.
# Enable BFD single-hop echo detection for RIP FRR on GigabitEthernet 3/1/1 to detect primary link failures.
[Sysname] rip 1
[Sysname-rip-1] fast-reroute route-policy frr
[Sysname-rip-1] quit
[Sysname-GigabitEthernet3/1/1] rip primary-path-detect bfd echo
rip split-horizon
Use rip split-horizon to enable the split horizon feature.
Use undo rip split-horizon to disable the split horizon feature.
rip split-horizon
The split horizon feature is enabled.
Interface view
The split horizon feature prevents routing loops. If you want to disable the feature, make sure the operation is necessary.
On NBMA networks, where multiple VCs are configured on the primary and secondary interfaces, disable split horizon to ensure correct route advertisement.
If both split horizon and poison reverse are enabled, only the poison reverse feature takes effect.
# Enable the split horizon feature on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rip split-horizon
rip summary-address
Use rip summary-address to configure a summary route on an interface.
Use undo rip summary-address to remove a summary route on an interface.
rip summary-address ip-address { mask-length | mask }
undo rip summary-address ip-address { mask-length | mask }
No summary route is configured on an interface.
Interface view
ip-address: Specifies the destination IP address of the summary route.
mask-length: Specifies the subnet mask length of the summary route, in the range of 0 to 32.
mask: Specifies the subnet mask of the summary route, in dotted decimal notation.
This command takes effect only when automatic route summarization is disabled.
# Configure a summary route on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rip summary-address 10.0.0.0 255.255.255.0
summary
rip version
Use rip version to specify a RIP version on an interface.
Use undo rip version to restore the default.
rip version { 1 | 2 [ broadcast | multicast ] }
undo rip version
No RIP version is configured on an interface. The interface can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
Interface view
1: Specifies the RIP version as RIPv1.
2: Specifies the RIP version as RIPv2.
[ broadcast | multicast ]: Sends RIPv2 messages in broadcast mode or multicast mode (default).
If an interface has no RIP version configured, it uses the global RIP version. Otherwise, it uses the RIP version configured on it.
An interface running RIPv1 can perform the following operations:
·          Sends RIPv1 broadcast messages.
·          Receives RIPv1 broadcast and unicast messages.
An interface running RIPv2 in broadcast mode can perform the following operations:
·          Sends RIPv2 broadcast messages.
·          Receives RIPv1 broadcast and unicast messages, and RIPv2 broadcast, multicast, and unicast messages.
An interface running RIPv2 in multicast mode can perform the following operations:
·          Sends RIPv2 multicast messages.
·          Receives RIPv2 broadcast, multicast, and unicast messages.
# Configure RIPv2 in broadcast mode on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rip version 2 broadcast
version
silent-interface
Use silent-interface to disable interfaces from sending RIP messages. The interfaces can still receive RIP messages.
Use undo silent-interface to enable interfaces to send RIP messages.
All RIP interfaces can send RIP messages.
RIP view
interface-type interface-number: Disables a specified interface from sending RIP messages.
all: Disables all interfaces from sending RIP messages.
# Disable all interfaces from sending RIP messages except GigabitEthernet 3/1/1.
[Sysname] rip 100
[Sysname-rip-100] silent-interface all
[Sysname-rip-100] undo silent-interface gigabitethernet 3/1/1
[Sysname-rip-100] network 131.108.0.0
summary
Use summary to enable automatic RIPv2 route summarization. Natural masks are used to advertise summary routes to reduce the size of routing tables.
Use undo summary to disable automatic RIPv2 route summarization to advertise all subnet routes.
summary
undo summary
Automatic RIPv2 route summarization is enabled.
RIP view
Automatic RIPv2 route summarization can reduce the routing table size to enhance the scalability and efficiency for large networks.
# Disable automatic RIPv2 route summarization.
[Sysname] rip
[Sysname-rip-1] undo summary
rip summary-address
rip version
timer triggered
Use timer triggered to set the interval for sending triggered updates.
Use undo timer triggered to restore the default.
The maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
RIP view
maximum-interval: Specifies the maximum interval in the range of 1 to 5 seconds.
minimum-interval: Specifies the minimum interval in the range of 10 to 5000 milliseconds.
incremental-interval: Specifies the incremental interval in the range of 100 to 1000 milliseconds.
The minimum-interval and incremental-interval cannot be greater than the maximum-interval.
For a stable network, the minimum-interval setting is used. If network changes become frequent, the incremental interval incremental-interval is used to extend the triggered update sending interval until the maximum-interval is reached.
# For RIP process 1, set the maximum interval, minimum interval, and incremental interval to 2 seconds, 100 milliseconds, and 100 milliseconds, respectively.
[Sysname] rip 1
[Sysname-rip-1] timer triggered 2 100 100
timers
Use timers to set RIP timers.
Use undo timers to restore the default.
undo timers { garbage-collect | suppress | timeout | update } *
The garbage-collect timer is 120 seconds.
The suppress timer is 120 seconds.
The timeout timer is 180 seconds.
The update timer is 30 seconds.
RIP view
garbage-collect-value: Specifies the garbage-collect timer in the range of 1 to 3600 seconds.
suppress-value: Specifies the suppress timer in the range of 0 to 3600 seconds.
timeout-value: Specifies the timeout timer in the range of 1 to 3600 seconds.
update-value: Specifies the update timer in the range of 1 to 3600 seconds.
RIP uses the following timers:
·          Update timer—Specifies the interval between routing updates.
·          Timeout timer—Specifies the route aging time. If no update for a route is received before the timer expires, RIP sets the metric of the route to 16.
·          Suppress timer—Specifies how long a RIP route stays in suppressed state. When the metric of a route becomes 16, the route enters the suppressed state. If RIP receives an update for the route with a metric less than 16 from the same neighbor, RIP uses this route to replace the suppressed route.
·          Garbage-collect timer—Specifies the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIP advertises the route with a metric of 16. If no update is announced for that route before the garbage-collect timer expires, RIP deletes the route from the routing table.
As a best practice, do not change the default values of these timers.
The timer lengths must be consistent on all routers on the network.
The timeout timer must be greater than the update timer.
# Set the update, timeout, suppress, and garbage-collect timers to 5, 15, 15, and 30 seconds.
[Sysname] rip 100
[Sysname-rip-100] timers update 5 timeout 15 suppress 15 garbage-collect 30
Use validate-source-address to enable source IP address check on inbound RIP routing updates.
Use undo validate-source-address to disable source IP address check on inbound RIP routing updates.
Source IP address check on inbound RIP routing updates is enabled.
RIP view
# Disable source IP address check on inbound RIP routing updates.
[Sysname-rip] rip 100
[Sysname-rip-100] undo validate-source-address
version
Use version to specify a global RIP version.
Use undo version to restore the default.
version { 1 | 2 }
undo version
No global RIP version is configured. An RIP interface can send RIPv1 broadcasts and receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
RIP view
2: Specifies the RIP version as RIPv2. RIPv2 messages are multicast.
An interface prefers the RIP version configured on it over the global RIP version.
If no RIP version is specified for the interface and the global version is RIPv1, the interface uses RIPv1 and can perform the following operations:
·          Send RIPv1 broadcasts.
·          Receive RIPv1 broadcasts and unicasts.
If no RIP version is specified for the interface and the global version is RIPv2, the interface uses RIPv2 multicast mode and can perform the following operations:
·          Send RIPv2 multicasts.
·          Receive RIPv2 broadcasts, multicasts, and unicasts.
# Specify the global RIP version as RIPv2.
[Sysname] rip 100
[Sysname-rip-100] version 2
rip version
