13-TRILL Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S12500-X & S12500X-AF Switch Series Configuration Guides(R115x)-6W10213-TRILL Configuration Guide
Table of Contents
Related Documents
01-TRILL configuration
01-TRILL configuration 418.00 KB
Configuring TRILL· 1
Overview·· 1
Basic concepts· 1
TRILL frame formats· 1
How TRILL works· 2
TRILL forwarding mechanisms· 3
Ping TRILL and tracert TRILL· 6
Protocols and standards· 8
Configuration restrictions and guidelines· 8
TRILL configuration task list 9
Enabling TRILL· 9
Configuring the system ID and nickname for an RB· 11
Configuring the link type of a TRILL port 11
Configuration procedure· 11
Configuring the DRB priority of a TRILL port 12
Setting the link cost for a TRILL port 12
Configuring announcing VLANs and the designated VLAN·· 13
Configuring TRILL timers· 13
Configuring TRILL LSP parameters and features· 14
Setting TRILL LSP parameters· 14
Enabling TRILL LSP fast advertisement 16
Enabling TRILL pseudonode bypass· 16
Setting the SPF algorithm parameters· 16
Configuring TRILL distribution trees· 17
Setting basic distribution tree parameters· 17
Enabling TRILL distribution tree multithread calculation· 18
Enabling load balancing over TRILL distribution trees· 18
Configuring TRILL equal-cost routes· 18
Enabling incremental flush for TRILL multicast routing entries· 19
Configuring TRILL Layer 3 forwarding· 20
Enabling logging of TRILL neighbor changes· 21
Configuring SNMP for TRILL· 21
Configuring TRILL GR·· 22
Using ping TRILL and tracert TRILL to test network connectivity· 22
Displaying and maintaining TRILL· 23
TRILL configuration example· 24
Network requirements· 24
Configuration procedure· 24
Verifying the configuration· 27
TRILL configuration example· 28
Network requirements· 28
Configuration procedure· 29
Verifying the configuration· 31
Configuring TRILL
TRansparent Interconnection of Lots of Links (TRILL) uses IS-IS to provide transparent Layer 2 forwarding.
TRILL requires a license to run on the device. For information about feature licensing, see Fundamentals Configuration Guide.
Overview
TRILL combines the simplicity and flexibility of Layer 2 switching with the stability, scalability, and rapid convergence capability of Layer 3 routing. All these advantages make TRILL very suitable for large Layer 2 networks in data centers.
Basic concepts
·          RBridge—Routing bridge (RB) that runs TRILL. RBs are classified into ingress RBs, transit RBs, and egress RBs, depending on their positions in the TRILL network. A frame enters the TRILL network through an ingress RB, travels along transit RBs, and leaves the TRILL network through an egress RB, as shown in Figure 2.
·          TRILL network—A Layer 2 network that contains RBs, as shown in Figure 3.
·          System IDUnique identifier of an RB in the TRILL network. The system ID is 6 bytes in length.
·          NicknameAddress of an RB in the TRILL network. The nickname is 2 bytes in length.
·          Link State Database—The LSDB contains all link state information in the TRILL network.
·          Link State Protocol Data UnitAn LSP describes local link state information and is advertised between neighbor devices.
·          Designated Routing Bridge (DRB)—Similar to the designated IS (DIS) in IS-IS, a DRB exists in a broadcast network. It helps simplify network topology, and assigns AVFs and appointed ports for the VLANs on each RB in the broadcast network.
·          Appointed VLAN-x Forwarder (AVF) and appointed port—To avoid loops, TRILL requires all traffic of a VLAN on a broadcast network to enter and leave the TRILL network through the same port of an RB. The RB is the VLAN's AVF, and the port is the VLAN's appointed port.
For more information about LSDB, LSPDU, and DIS, see Layer 3—IP Routing Configuration Guide.
TRILL frame formats
TRILL frames include protocol frames and data frames.
TRILL protocol frames include TRILL Hello, LSP, CSNP, PSNP, MTU-probe, and MTU-ack. These protocol frames use 802.1Q encapsulation and have a fixed destination multicast address 0180-C200-0041.
TRILL data frames have a specific format, as shown in Figure 1. A TRILL header and an outer Ethernet header are added to the original Ethernet frame.
Figure 1 TRILL data frame format
Table 1 describes the fields in the TRILL header.
Table 1 TRILL header fields
Ethertype
The Ethertype is fixed to TRILL.
V
Version number, which is 0. When an RB receives a TRILL frame, it checks the V field and drops the frame if the V field is not 0.
R
Reserved for future extension. An ingress RB sets the R field to 0 when adding a TRILL header. Transit RBs and egress RBs ignore the field.
M
Multidestination attribute:
·         0—Known unicast frame.
·         1Multidestination frame (multicast, broadcast, or unknown unicast frame).
Op-Length
Length of the Options field. 0 indicates that the Options field does not exist.
Hop Count
Hop count, which is used to avoid loops. An RB drops a TRILL frame whose hop count is decremented to 0.
Egress RB Nickname
Nickname of the egress RB.
Ingress RB Nickname
Nickname of the ingress RB.
Options
Options field. This field exists when the Op-Length field is non-zero.
How TRILL works
TRILL establishes and maintains adjacencies between RBs by periodically advertising Hello frames, distributes LSPs among RB neighbors, and generates an LSDB for all RBs in the network. Based on the LSDB, each RB uses the SPF algorithm to calculate forwarding entries destined to other RBs.
TRILL uses different mechanisms to forward Layer 2 and Layer 3 traffic. The following sections describe these mechanisms.
Layer 2 forwarding mechanisms
TRILL forwards the traffic within a VLAN by using the following mechanisms:
·          Unicast frame forwarding mechanism.
As shown in Figure 2, a unicast frame is forwarded as follows:
a.    When a unicast frame enters the TRILL network, the ingress RB encapsulates the original Ethernet frame with the following headers:
-      A TRILL header (similar to an IP header).
-      An outer Ethernet header (similar to the Ethernet header of a regular Ethernet frame).
b.    RBs forward the frame hop by hop according to the egress RB nickname in the TRILL header in the same way routers forward IP packets. Each hop replaces the outer Ethernet header with an appropriate outer Ethernet header, and decrements the hop count in the TRILL header.
c.    Upon receiving the TRILL frame, the egress RB de-encapsulates it to obtain the original Ethernet frame, and sends the frame to the target device.
Figure 2 Layer 2 unicast frame forwarding flow
The outer Ethernet header enables traditional Ethernet switches to forward TRILL frames and connect RBs.
·          Multidestination frame forwarding mechanism.
In a TRILL network, RBs perform the following operations:
?  Compute a TRILL distribution tree for each VLAN based on the LSDB.
?  Guide the forwarding of multidestination frames in each VLAN by using its TRILL distribution tree.
As shown in Figure 3, when a multicast frame from VLAN 10 enters the TRILL network, RB 1, which is an ingress RB, encapsulates the multicast frame into a TRILL frame. In the frame, the egress RB is RB 2, the root bridge of the TRILL distribution tree for VLAN 10. When the frame arrives at the root bridge, it is distributed throughout the TRILL distribution tree. Then, the TRILL frame is de-encapsulated by RB 3 and sent to the destination station S2. Because the network segment where RB 4 resides does not have a receiver of this frame, RB 4 drops the frame.
Figure 3 Layer 2 multicast frame forwarding flow
TRILL selects distribution trees for forwarding multidestination frames based on the VLANs to which the frames belong. Because the topologies of TRILL distribution trees are different, traffic can be load shared. However, equal-cost links are not used for load sharing.
When N equal-cost links exist in the network, each TRILL distribution tree selects the link with the largest pseudonode ID for forwarding packets. As shown in Figure 4, two equal-cost links exist between RB 1 and RB 2. Assume the link directly connecting RB 1 to RB 2 has the largest pseudonode ID. Both the TRILL distribution tree rooted at RB 1 and the TRILL distribution tree rooted at RB 4 select the link. For more information about pseudonode IDs, see Layer 3—IP Routing Configuration Guide.
Figure 4 Multicast ECMP
TRILL distribution trees support Equal Cost Multiple Path (ECMP), also known as multicast ECMP. When multicast ECMP is enabled, TRILL assigns equal-cost links to different TRILL distributions trees to improve load sharing performance.
When N equal-cost links exist in the network, each TRILL distribution tree selects an equal-cost link for forwarding packets through J mod N in root bridge priority order. J is the priority sequence number of a TRILL distribution tree and starts from 0.
As shown in Figure 4:
?  The link directly connecting RB 1 to RB 2 is assigned to the TRILL distribution tree rooted at RB 1.
?  The link RB 1-RB 3-RB 2 is assigned to the TRILL distribution tree rooted at RB 4.
TRILL distribution trees support fast root switching. When an RB detects that the root of a distribution tree is unreachable, the RB deletes the LSP of the root from its LSDB. This triggers recalculation of all distribution trees in the TRILL network. Multidestination traffic is switched to new distribution trees.
Layer 3 forwarding mechanisms
IMPORTANT
IMPORTANT:
·      TRILL Layer 3 forwarding is supported only on FE and FX cards.
·      TRILL can perform Layer 3 forwarding only for IPv4 unicast traffic.
As shown in Figure 5, distribution layer device RB 1 is the gateway of a data center network. RB 1 forwards Layer 3 traffic between VLANs in the data center network and Layer 3 traffic between the data center and external networks.
Figure 5 TRILL Layer 3 forwarding
When an access RB receives a unicast frame from a terminal device, the RB encapsulates the frame into a TRILL frame and sends it to the gateway RB. The gateway RB then de-encapsulates the TRILL frame for Layer 3 forwarding.
A gateway RB uses the IP addresses of VLAN interfaces to provide gateway services for terminal devices in different VLANs.
For terminal devices to learn the MAC address of a gateway, enable periodic sending of gratuitous ARP packets on the VLAN interface that acts as the gateway. For information about gratuitous ARP, see Layer 3—IP Services Configuration Guide.
You can use ping TRILL and tracert TRILL to test TRILL network connectivity when network failure occurs or new RBs are added to the network.
Ping TRILL and tracert TRILL are implemented through the TRILL Operation, Administration, and Maintenance (OAM) protocol.
Ping TRILL
Use ping TRILL to determine if an RB is reachable.
As shown in Figure 6, the source RB sends OAM echo requests to ping the destination RB. Upon receiving the requests, the destination RB responds to the source RB with OAM echo replies. The source RB outputs statistics about the ping TRILL operation, including the number of sent echo requests, the number of received echo replies, and the round-trip time. You can measure the network performance by analyzing the statistics.
Figure 6 Ping TRILL packet forwarding
Tracert TRILL
Tracert TRILL enables retrieval of the nicknames of RBs in the path to a destination RB. In the event of network failure, use tracert TRILL to test network connectivity and identify failed nodes.
Tracert TRILL operates as shown in Figure 7.
1.        RB 1 sends RB 3 an OAM echo request with a hop count value of 0.
2.        The first hop RB 2 responds by sending a hop count error notification to the source RB because the hop count of the request is 0. The notification uses the nickname of RB 2 as the ingress RB. In this way, RB 1 can get the nickname of the first hop RB.
3.        RB 1 sends RB 3 an OAM echo request with a hop count value of 1.
4.        RB 2 forwards the request to RB 3 according to the TRILL unicast routing table and decrements the hop count value by 1.
5.        The second hop RB 3 responds to the source RB with a hop count error notification. The notification uses the nickname of RB 3 as the ingress RB.
6.        RB 2 forwards the hop count error notification to RB 1. RB 1 gets the nickname of the second hop RB 3.
Figure 7 Tracert TRILL packet forwarding
·          RFC 6325, Routing Bridges (RBridges): Base Protocol Specification
·          RFC 6326, Transparent Interconnection of Lots of Links (TRILL) Use of IS-IS
·          RFC 6327, Routing Bridges (RBridges): Adjacency
·          RFC 1195, Use of OSI IS-IS for Routing in TCP/IP and Dual Environments
·          RBridges: TRILL RBridge Channel Support
·          RBridges: Operations, Administration, and Maintenance (OAM) Support
When you configure TRILL, follow these restrictions and guidelines:
·          Configuration in Layer 2 Ethernet interface view takes effect only on the current port. Configuration in Layer 2 aggregate interface view takes effect on the current interface and its member ports. Configuration on a member port of an aggregate interface takes effect after the member port leaves the aggregation group.
·          To connect a spanning tree network to a TRILL network, make sure the following requirements are met:
?  The spanning tree protocol is disabled on the TRILL network.
?  An edge port is used to connect the spanning tree network to the TRILL network. The edge port can transit to the forwarding state before DRB election is finished. This prevents multiple DRBs from being elected.
For more information about spanning tree protocols, see Layer 2—LAN Switching Configuration Guide.
·          As a best practice, do not enable loop detection on TRILL ports, because TRILL avoids loops. For more information about loopback detection, see Layer 2—LAN Switching Configuration Guide.
·          If IRF is used, retain the IRF bridge MAC address permanently. Otherwise, traffic interruption might occur after an IRF split. For more information about IRF configuration, see Virtual Technologies Configuration Guide.
·          You cannot use the rewrite inbound tag or rewrite outbound tag command together with TRILL. For information about the rewrite inbound tag and rewrite outbound tag commands, see VXLAN Command Reference.
Tasks at a glance
(Required.) Enabling TRILL
(Required.) Configuring the system ID and nickname for an RB
(Optional.) Configuring the link type of a TRILL port
(Optional.) Configuring the DRB priority of a TRILL port
(Optional.) Setting the link cost for a TRILL port
(Optional.) Configuring announcing VLANs and the designated VLAN
(Optional.) Configuring TRILL timers
(Optional.) Configuring TRILL LSP parameters and features
(Optional.) Setting the SPF algorithm parameters
(Optional.) Configuring TRILL distribution trees
(Optional.) Configuring TRILL equal-cost routes
(Optional.) Enabling incremental flush for TRILL multicast routing entries
(Optional.) Configuring TRILL Layer 3 forwarding
(Optional.) Enabling logging of TRILL neighbor changes
(Optional.) Configuring SNMP for TRILL
(Optional.) Configuring TRILL GR
(Optional.) Using ping TRILL and tracert TRILL to test network connectivity
Enabling TRILL
Before you enable TRILL on a port, first enable TRILL globally.
Enable or disable TRILL on all ports in a VLAN, so that the ports in a VLAN have the same TRILL status (enabled or disabled).
To avoid loops, use the following procedure to enable TRILL on a port:
1.        Shut down the port by using the shutdown command.
2.        Enable TRILL and assign the port to VLANs.
3.        Bring up the port by using the undo shutdown command.
When you set up a TRILL network, avoid the case that multiple TRILL neighbors are established for one TRILL port, for example, the networks in Figure 8 and Figure 9.
Figure 8 shows a typical network where two TRILL neighbors are established for the same port of an RB. In Figure 9, because TRILL is disabled on the port connecting RB 2 to RB 3, the port will transparently transmit the TRILL Hello frames from RB 3. As a result, two TRILL neighbors are established for the port connecting RB 1 to RB 2.
Figure 8 Two TRILL neighbors are established for a port (1)
Figure 9 Two TRILL neighbors are established for a port (2)
After you enable TRILL on a port, TRILL can operate correctly by using default settings. A port with TRILL enabled is called a TRILL port.
To enable TRILL:
Step
Remarks
1.       Enter system view.
N/A
2.       Enable TRILL globally and enter TRILL view.
trill
By default, TRILL is disabled globally.
3.       Return to system view.
N/A
4.       Enter Layer 2 Ethernet or aggregate interface view.
N/A
5.       Enable TRILL on the port.
trill enable
By default, TRILL is disabled on a port.
The system ID and nickname of an RB are identifiers of the RB in the TRILL network.
·          System ID—Unique identifier of an RB in the TRILL network. The system ID can be automatically assigned or manually configured.
·          Nickname—Address of an RB in the TRILL network. The address can be automatically assigned or manually configured. When multiple RBs in the TRILL network have the same nickname, the RB with the highest priority uses the nickname. When the RBs also have the same priority, the RB with the highest system ID uses the nickname. The system automatically assigns new nicknames to the other RBs.
The system resets the TRILL process when the RB's system ID changes.
To configure the system ID and nickname for the RB:
Step
Remarks
N/A
2.       Enter TRILL view.
trill
N/A
3.       Configure the system ID for the RB.
system-id system-id
By default, the RB automatically generates a system ID based on its MAC address upon startup.
4.       Configure the nickname for the RB.
nickname nickname [ priority priority ]
By default, TRILL automatically assigns nicknames to RBs, and the priority for a RB to hold a nickname is 64.
The following link types are available for a TRILL port:
·          Access—Access ports include access ports without the alone attribute and access ports with the alone attribute. Access ports with the alone attribute do not send or receive Hello frames and do not participate in DRB election or AVF negotiation. Access ports without the alone attribute can process only local data frames and Hello frames.
·          Hybrid—A hybrid port combines the attributes of an access port and a trunk port, and can process local data frames and passing data frames.
·          Trunk—A trunk port can process passing data frames and some of Layer 2 protocol frames (for example, LLDP frames), but it cannot process local data frames.
To configure the link type of a TRILL port:
Step
Remarks
N/A
2.       Enter Layer 2 Ethernet or aggregate interface view.
N/A
3.       Configure the link type of the TRILL port.
trill link-type { access [ alone ] | hybrid | trunk }
By default, the link type of a TRILL port is access without the alone attribute.
On a broadcast network, TRILL must elect a DRB. An RB with a higher DRB priority is preferred in DRB election. When two RBs have the same DRB priority, the RB with a higher MAC address takes precedence.
To configure the DRB priority of a TRILL port:
Step
Remarks
N/A
N/A
3.       Configure the DRB priority of the TRILL port.
trill drb-priority priority
By default, the DRB priority of a TRILL port is 64.
The link cost for a TRILL port can be automatically calculated by the system or manually set.
·          A manually set link cost takes precedence over a calculated link cost.
·          If no link cost is set and automatic link cost calculation is enabled, the calculated link cost takes effect.
·          If no link cost is set and automatic link cost calculation is disabled, the default link cost of 2000 is used.
If you manually set the link cost for a TRILL port, make sure its peer TRILL port uses the same link cost.
The system automatically calculates the link cost of a TRILL port by using the following formula: link cost = 20000000000000/interface baud rate.
To set the link cost for a TRILL port:
Step
Remarks
N/A
trill
N/A
3.       Enable automatic link cost calculation for TRILL ports.
auto-cost enable
By default, automatic link cost calculation is enabled for TRILL ports.
4.       Return to system view.
N/A
5.       Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
6.       Set the link cost for the TRILL port.
trill cost cost-value
The default setting is 2000.
The concepts and symbols used to describe a VLAN on port are as follows:
·          Enabled VLANA VLAN enabled on the port.
·          Forwarding VLANA VLAN for which the port is the appointed port.
·          ∩ and Set operation symbols. indicates set-theoretic intersection, and indicates set-theoretic union.
RBs send Hello frames in a set of VLANs. The VLAN set is calculated as follows:
·          DRBEnabled VLANs ∩ (announcing VLANs designated VLAN).
·          Non-DRBEnabled VLANs ∩ (designated VLAN (announcing VLANs forwarding VLANs)).
To prevent Hello frames from consuming excessive CPU resources, reduce the number of announcing VLANs.
RBs use the designated VLAN to forward TRILL protocol frames (except Hello frames) and local data frames. For RBs to establish adjacencies and forward TRILL data frames, make sure the designated VLAN is an enabled VLAN.
To configure announcing VLANs and the designated VLAN:
Step
Remarks
N/A
2.       Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
3.       Configure announcing VLANs.
trill announcing-vlan { vlan-list | null }
By default, no announcing VLANs are configured, and announcing VLANs are enabled VLANs.
4.       Configure the designated VLAN.
trill designated-vlan vlan-id
By default, no designated VLAN is configured. The system automatically selects an enabled VLAN as the designated VLAN.
You can configure the following TRILL timers:
·          Hello interval and Hello multiplierThe RB advertises Hello frames at the Hello interval to maintain a TRILL adjacency. The shorter the Hello interval, the faster the network convergence. However, a shorter Hello interval consumes more system resources. The adjacency holding time is obtained by multiplying the Hello interval by the Hello multiplier. The RB advertises the adjacency holding time to neighbors through Hello frames. If a neighbor does not receive any Hello frame from the RB within the adjacency holding time, it removes the TRILL adjacency with the RB.
·          AVF inhibition timeAs the AVF of a VLAN, the RB guarantees that frames of the VLAN enter and leave a broadcast network through the same port. Other RBs on the broadcast network do not process frames from the VLAN.
To avoid loops, the RB suppresses its AVF role during the inhibition time when one of the following conditions exists:
?  The RB detects a root bridge change on the broadcast network.
?  Other RBs advertise a different AVF for the VLAN.
When the inhibition time expires, the RB restores its AVF role if it is still the AVF of the VLAN.
·          CSNP intervalOn a broadcast network, the RB advertises CSNPs at the CSNP interval to perform network-wide LSDB synchronization if it is elected as the DRB. A CSNP records all LSP digests of the RB's local LSDB. A remote RB compares a received CSNP against its local LSDB to verify whether some LSPs are aged out or missing. If the CSNP has an LSP digest that the local LSDB does not have, the remote RB sends a PSNP packet to request the LSP.
To configure TRILL timers:
Step
Remarks
N/A
N/A
3.       Configure the Hello interval.
trill timer hello interval
The default setting is 10 seconds.
This command sets the Hello interval for an RB. The Hello interval of a DRB is 1/3 of the Hello interval of an RB. This allows for DRB failures to be quickly detected.
4.       Configure the Hello multiplier.
trill timer holding-multiplier count
The default setting is 3.
5.       Configure the AVF inhibition time.
trill timer avf-inhibited time
The default setting is 30 seconds.
6.       Configure the CSNP interval.
trill timer csnp interval
You can set the following LSP parameters:
·          LSP maximum ageThe RB uses the LSP maximum age as the remaining lifetime of the LSPs that it originates. When the RB detects that the remaining lifetime of an LSP reaches 0 seconds in the LSDB, the RB performs the following operations:
?  Removes the LSP's content.
?  Keeps the LSP's digest.
?  Sets the LSP's remaining lifetime to 0 and purges the LSP from the network by advertising the LSP to other RBs.
·          LSP refresh intervalA locally originated LSP is forcibly refreshed when its remaining lifetime is no greater than n: n = LSP maximum age – LSP refresh interval. This mechanism avoids frequent LSP aging and ensures network stability.
·          LSP generation timer parameters—By adjusting the TRILL LSP generation timer parameters, you can prevent frequent network changes from consuming excessive bandwidth and device resources.
When the network is stable, the LSP generation timer is set to the minimum interval for each LSP generation. When the network is unstable, the LSP generation timer is added by the incremental interval for each LSP generation until the maximum interval is reached.
·          Maximum length of originated LSPsThe RB selects the smallest value from the following values as the actual maximum length of LSPs to be sent to a neighbor:
?  The configured maximum length of originated LSPs.
?  The interface MTU.
?  The maximum originated LSP length carried in the LSPs sent by the neighbor.
·          Maximum length of received LSPs—When the RB receives an LSP that exceeds the length, the RB drops the LSP.
·          Overload bit of LSPsThe RB sets the Overload bit in LSPs if the RB fails and cannot correctly perform route selection and packet forwarding. When the RB cannot record the complete LSDB because of insufficient memory, routing calculation errors occur. To make troubleshooting easier, temporarily exclude the RB from the TRILL network by setting the Overload bit for the LSPs sent by the RB.
·          Minimum LSP interval and maximum number of LSPs transmitted per interval—To avoid frequent LSP aging in the network, RBs periodically advertise LSPs. The actual refresh interval of an LSP is determined by both the minimum LSP interval and the maximum number of LSPs transmitted per interval. To prevent LSPs from being aged out accidentally, set the LSP maximum age and the LSP refresh interval appropriately.
To set TRILL LSP parameters:
Step
Remarks
N/A
trill
N/A
3.       Set the LSP maximum age.
timer lsp-max-age time
The default setting is 1200 seconds.
4.       Set the LSP refresh interval.
timer lsp-refresh time
The default setting is 900 seconds.
5.       Set the TRILL LSP generation timer parameters.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ]
By default, the maximum LSP generation interval is 2 seconds, the minimum interval is 10 milliseconds, and the incremental interval is 20 milliseconds.
6.       Configure the maximum length of originated LSPs.
lsp-length originate size
The default setting is 1458 bytes.
To prevent the system from generating error messages, do not set the maximum length of originated LSPs to be greater than the maximum length of received LSPs.
7.       Configure the maximum length of received LSPs.
lsp-length receive size
The default setting is 1492 bytes.
8.       Set the Overload bit of LSPs and set the lifetime for the set Overload bit.
set overload [ timeout ]
By default, the Overload bit is not set.
Do not perform this task on the root RB of a TRILL distribution tree. The root RB cannot forward traffic when the Overload bit of LSPs is set on the RB.
9.       Return to system view.
N/A
10.     Enter Layer 2 Ethernet or aggregate interface view.
N/A
11.     Configure the minimum LSP interval and the maximum number of LSPs transmitted per time.
trill timer lsp interval [ count count ]
By default, the minimum LSP interval is 10 milliseconds, and the maximum number of LSPs transmitted per time is 5.
LSP fast advertisement enables TRILL to immediately advertise the specified number of LSPs that invoke SPF calculation. This mechanism improves network convergence time.
To enable TRILL LSP fast advertisement:
Step
Remarks
N/A
trill
N/A
3.       Enable TRILL LSP fast advertisement.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval ] *
By default, TRILL LSP fast advertisement is disabled.
This feature disables a DRB from generating LSPs for the pseudonode when the DRB has only one neighbor on a broadcast network. This reduces the number of LSPs in the network.
To enable the pseudonode bypass feature:
Step
Remarks
N/A
N/A
3.       Enable the pseudonode bypass feature.
trill bypass-pseudonode enable
By default, the pseudonode bypass feature is disabled.
The RB uses the SPF algorithm to calculate a shortest path tree with itself as the root based on the LSDB. The RB uses the shortest path tree to determine the next hop to a destination network. By adjusting the SPF calculation intervals, you can prevent resource overconsumption when the network is unstable.
When the network is stable, the SPF calculation interval for continuous calculations is reduced to minimum-interval. When the network is unstable, the SPF calculation interval is added by incremental-interval × 2n-2 (n is the number of continuous SPF calculation times) for each SPF calculation until the maximum interval is reached.
To set the SPF algorithm parameters:
Step
Remarks
N/A
trill
N/A
3.       Set the SPF calculation interval for TRILL.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
By default, the maximum SPF calculation interval is 10 seconds, the minimum SPF calculation interval is 10 milliseconds, and the SPF calculation incremental interval is 20 milliseconds.
·          Compute TRILL distribution trees according to the LSDB.
·          Use the TRILL distribution trees to guide the forwarding of multidestination frames.
An RB with a higher priority is selected as the root bridge of a TRILL distribution tree.
An LSP sent by an RB carries the following TRILL distribution tree information:
·          The number of TRILL distribution trees that the RB wants all RBs to compute.
·          The maximum number of TRILL distribution trees that the RB can compute (this number is fixed at 15).
·          The number of TRILL distribution trees that the RB has computed.
Each RB can compute a maximum of m TRILL distribution trees. An RB determines the number of TRILL distribution trees to compute (n) by selecting the lower value from the following values:
·          The number of TRILL distribution trees that the highest-priority RB wants all RBs to compute.
·          The smallest m value across the TRILL network.
The RB selects the first n nicknames from the nickname list advertised by the highest-priority RB. The RB uses the selected nicknames as the root nicknames for computing distribution trees.
To set basic TRILL distribution tree parameters:
Step
Remarks
N/A
trill
N/A
3.       Set a priority for the RB.
tree-root priority priority
The default setting is 32768.
4.       Configure the number of TRILL distribution trees that the RB wants all RBs to compute.
trees calculate count
The default setting is 1.
This feature enables a multicore CPU device to improve TRILL distribution tree calculation efficiency by using each thread to calculate a distribution tree.
To enable TRILL distribution tree multithread calculation:
Step
Remarks
N/A
trill
N/A
3.       Enable TRILL distribution tree multithread calculation.
multicast multi-thread enable
By default, ingress traffic is not load balanced over TRILL distribution trees after a forwarding VLAN is deleted on the RB. To load balance ingress traffic of the remaining forwarding VLANs over the existing distribution trees, you can enable load balancing over TRILL distribution trees.
Ingress traffic is load balanced in any of the following conditions, regardless of whether load balancing is enabled or not:
·          A forwarding VLAN is added.
·          A distribution tree is added or deleted.
When a distribution tree is added, the RB switches ingress traffic to the new tree to implement load balancing. However, the RB cannot use the new distribution tree to forward traffic before other RBs are ready to use the new tree. In this case, you can set a delay timer for the RB to switch ingress traffic to the new distribution tree.
If traffic is not evenly distributed over distribution trees, you can also perform one-time load balancing over TRILL distribution trees.
To enable load balancing over TRILL distribution trees:
Step
Remarks
N/A
trill
N/A
3.       Enable load balancing over TRILL distribution trees.
ingress assign-rule load-balancing
By default, load balancing over TRILL distribution trees is disabled.
4.       Set the delay timer for the RB to switch ingress traffic to a new TRILL distribution tree.
ingress assign-delay seconds
The default delay timer is 300 seconds.
5.       Perform one-time load balancing over TRILL distribution trees.
set ingress-load-balancing
Perform this task when load balancing over TRILL distribution trees is disabled.
TRILL unicast equal-cost routes share traffic to the same destination. You can configure the maximum number of TRILL unicast equal-cost routes.
When TRILL multicast ECMP is disabled, TRILL distribution trees do not use equal-cost routes to share traffic. When multicast ECMP is enabled, TRILL assigns equal-cost routes to multiple TRILL distribution trees to improve load sharing performance.
To configure TRILL equal-cost routes:
Step
Remarks
N/A
trill
N/A
3.       Set the maximum number of TRILL unicast equal-cost routes.
max-unicast-load-balancing number
By default, the maximum number of TRILL unicast equal-cost routes is 32.
4.       Enable TRILL multicast ECMP.
multicast-ecmp enable  [ p2p-ignore ]
By default, TRILL multicast ECMP is disabled.
Make sure the status of TRILL multicast ECMP is the same across the TRILL network.
TRILL multicast routing entries are classified into three levels according to the following key combinations:
·          RB—Root bridge of a TRILL distribution tree.
·          RB+VLAN—Root bridge and VLAN of a TRILL distribution tree.
·          RB+VLAN+MAC—Root bridge and VLAN of a TRILL distribution tree and a MAC address.
An entry that is identified by fewer keys is at a higher level.
The incremental flush feature enables the device to compare the outgoing port list and local receiving flag of an entry with its next higher level entry. If the two entries have the same outgoing port list and local receiving flag, the higher level entry is issued to the TRILL FIB. For example, if entry RB 2 and entry RB 2+VLAN 10 have the same outgoing port list and local receiving flag, entry RB 2 is issued.
This feature reduces the number of flushed entries in scenarios where an entry and its next higher level entry have the same outgoing port list and local receiving flag. Enabling this feature in other scenarios causes the system to issue a large number of entries at the same time and degrades the device performance.
To enable incremental flush for TRILL multicast routing entries:
Step
Remarks
N/A
trill
N/A
3.       Enable incremental flush for TRILL multicast routing entries.
flush-policy difference
By default, incremental flush is disabled for TRILL multicast routing entries.
IMPORTANT
IMPORTANT:
This feature enables an RB to forward Layer 3 traffic between VLANs in the local network and Layer 3 traffic between the local and external networks.
A gateway RB uses the IP addresses of VLAN interfaces to provide gateway services for terminal devices in different VLANs. For terminal devices to learn the MAC address of a gateway, enable periodic sending of gratuitous ARP packets on the VLAN interface that acts as the gateway.
To configure TRILL Layer 3 forwarding:
Step
Remarks
N/A
trill
N/A
3.       Enable TRILL Layer 3 forwarding globally.
l3-forwarding enable
By default, TRILL Layer 3 forwarding is disabled globally.
Execute this command on the gateway RBs.
4.       Enable TRILL Layer 3 forwarding for VLANs.
l3-forwarding vlan { vlan-list | all }
By default, TRILL Layer 3 forwarding is disabled for VLANs.
Before you enable TRILL Layer 3 forwarding for a VLAN, create the VLAN interface for the VLAN and assign an IP address to the VLAN interface.
5.       Return to system view.
N/A
6.       Enter Layer 2 Ethernet interface or Layer 2 aggregate interface view.
The Layer 2 Ethernet interface or Layer 2 aggregate interface must be a TRILL trunk port on the TRILL Layer 3 forwarding path.
To set the link type of a TRILL port, use the trill link-type command.
7.       Configure the designated VLAN.
8.       Set the link type of the interface.
·         Configure the interface as a trunk port:
port link-type trunk
·         Configure the interface as a hybrid port:
port link-type hybrid
By default, the interface is an access port.
9.       Assign the interface to the VLANs enabled with Layer 3 forwarding and the designated VLAN.
·         Assign the trunk port to the specified VLANs:
port trunk permit vlan vlan-id-list
·         Assign the hybrid port to the specified VLANs:
port hybrid vlan vlan-list { tagged | untagged }
By default, a trunk port allows packets only from VLAN 1 to pass through. A hybrid port is an untagged member of the VLAN to which the port was assigned as an access port.
10.     Configure designated VLAN settings on the interface.
·         Set the PVID of the trunk port to the designated VLAN:
port trunk pvid vlan
vlan-id
·         Configure the hybrid port as an untagged member of the designated VLAN:
port hybrid vlan
vlan-list untagged
N/A
Perform this task to output logs of TRILL neighbor changes to the configuration terminal.
To enable logging of TRILL neighbor changes:
Step
Remarks
N/A
trill
N/A
3.       Enable logging of TRILL neighbor changes.
log-peer-change enable
By default, logging of TRILL neighbor changes is enabled.
To report critical TRILL events to an NMS, enable SNMP notifications for TRILL. For TRILL event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
TRILL shares the standard IS-IS MIB with IS-IS. The standard IS-IS MIB provides only single-instance MIB objects. For SNMP to correctly identify TRILL's management information in the standard IS-IS MIB, you must configure a unique context for TRILL.
Context is a method introduced to SNMPv3 for multiple-instance management. For SNMPv1/v2c, you must specify a community name as a context name for protocol identification.
To configure SNMP for TRILL:
Step
Remarks
N/A
2.       Enable SNMP notifications for TRILL.
snmp-agent trap enable trill [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-drb | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
By default, SNMP notifications are enabled for TRILL.
3.       Enter TRILL view.
trill
N/A
4.       Configure the context name for TRILL.
By default, no context name is configured for TRILL.
Graceful Restart (GR) ensures the continuity of packet forwarding when a protocol restarts or an active/standby switchover occurs on the RB. The RB advertises the restart status to its neighbors, and allows the neighbors to re-establish connections. GR involves the following roles:
·          GR restarter—Graceful restarting router. It must be GR capable.
·          GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
By default, the device acts as the GR helper. Configure TRILL GR on the target GR restarter.
To configure TRILL GR:
Step
Remarks
N/A
trill
N/A
3.       Enable GR for TRILL.
graceful-restart
By default, GR is disabled for TRILL.
4.       (Optional.) Configure the GR interval for TRILL.
The default setting is 300 seconds.
5.       (Optional.) Suppress the SA bit during graceful restart.
graceful-restart suppress-sa
By default, the SA bit is set during graceful restart.
To use ping TRILL to test the network connectivity:
Remarks
Determine if an RB with the specified nickname is reachable.
ping trill [ -c count | -h ttl | -i interface-type interface-number | -m interval | -priority priority | -t timeout ] * nickname
Execute this command in any view.
If multiple routes destined for the RB exist, the RB is reachable if any of the routes is reachable.
To use tracert TRILL to test the network connectivity:
Remarks
Display the route to an RB with the specified nickname.
tracert trill [ -f first-ttl | -i interface-type interface-number | -m max-ttl | -priority priority | -q packet-number | -t timeout | -v [ -name ] ] * nickname
Execute the display commands in any view and the reset command in user view.
Display TRILL Layer 2 adjacency table information.
display trill adjacent-table [ count | nickname nickname interface interface-type interface-number ]
Display brief TRILL information.
display trill brief
Display TRILL Layer 2 FIB information.
display trill fib [ count | nickname nickname ]
Display TRILL GR status.
display trill graceful-restart status
Display TRILL ingress forwarding information.
display trill ingress-route [ vlan vlan-list ]
Display TRILL port information.
display trill interface [ interface-type interface-number | verbose ]
Display the VLANs whose TRILL Layer 3 forwarding status is active.
display trill l3-forwarding active-vlan
Display TRILL Layer 3 adjacency table information.
display trill l3-forwarding adjacent-table [ count | nickname nickname interface interface-type interface-number mac mac-address ]
Display TRILL Layer 3 FIB table information.
display trill l3-forwarding fib [ count | nickname nickname ]
Display TRILL Layer 3 forwarding status for VLAN interfaces.
display trill l3-forwarding interface [ vlan-interface interface-number ]
Display TRILL Layer 3 neighbor table information.
display trill l3-forwarding neighbor-table
Display TRILL Layer 3 unicast routing table information.
display trill l3-forwarding unicast-route
Display TRILL LSDB information.
display trill lsdb [ local | lsp-id lsp-id | verbose ] *
Display all ingress entries in the TRILL multicast FIB (MFIB).
display trill mfib ingress [ vlan vlan-id [ local-entry | remote-entry ] ]
Display all egress entries in the TRILL MFIB.
display trill mfib transit [ nickname nickname [ prune-entry | rpf-entry | vlan vlan-id [ mac-address mac-address ] ] ]
Display information about the TRILL multicast routing table.
display trill multicast-route [ tree-root nickname [ vlan vlan-list [ mac mac-address ] ] ]
Display the TRILL Layer 2 neighbor table.
display trill neighbor-table
Display TRILL neighbor statistics.
display trill peer [ interface interface-type interface-number ]
Display the TRILL RPF check table information.
display trill rpf-table tree-root nickname
Display TRILL topology information.
display trill topology [ verbose ]
Display information about the TRILL Layer 2 unicast routing table.
display trill unicast-route [ nickname nickname ] [ verbose ]
Clear dynamic running statistics of the TRILL process.
reset trill
This example uses TRILL Layer 3 forwarding.
As shown in Figure 10, a data center network has two layers: the distribution layer and the access layer. A port connected to a higher layer device is an uplink port, and a port connected to a lower layer device is a downlink port. RB 1 is the gateway of the data center network.
Configure TRILL in the network as follows:
·          Enable TRILL on both uplink and downlink ports of access layer devices, and enable TRILL on downlink ports of distribution layer devices.
·          Configure two TRILL distribution trees that are rooted at RB 1 and RB 2. Configure a higher priority for RB 1 to be a distribution tree root.
·          Configure TRILL Layer 3 forwarding on RB 1. Specify VLAN-interface 100's IP address 100.1.1.1 as the gateway of the users in VLAN 100 and VLAN-interface 200's IP address 200.1.1.1 as the gateway of the users in VLAN 200.
Figure 10 Network diagram
This section provides only TRILL-related configurations.
1.        Configure the downlink ports of access layer devices:
# Enable TRILL globally on RB 3.
<RB3> system-view
[RB3] trill
[RB3-trill] quit
# Enable TRILL on downlink port Ten-GigabitEthernet 1/0/1, and configure the port's link type as access without the alone attribute.
[RB3] interface ten-gigabitethernet 1/0/1
[RB3-Ten-GigabitEthernet1/0/1] trill enable
[RB3-Ten-GigabitEthernet1/0/1] trill link-type access
[RB3-Ten-GigabitEthernet1/0/1] quit
# Create VLAN 100 and assign Ten-GigabitEthernet 1/0/1 to VLAN 100.
[RB3] vlan 100
[RB3-vlan100] quit
[RB3-Ten-GigabitEthernet1/0/1] port access vlan 100
# Configure RB 4 through RB 6 in the similar way RB 3 is configured. Create VLANs and assign the downlink ports to the corresponding VLANs on RB 4 through RB 6 as shown in Figure 10. (Details not shown.)
2.        Configure the uplink ports of access layer devices:
# Create VLAN 1000.
[RB3] vlan 1000
[RB3-vlan1000] quit
# Configure uplink ports Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 as TRILL trunk ports, and configure VLAN 1000 as the designated VLAN.
[RB3]interface range Ten-GigabitEthernet 1/0/2 to Ten-GigabitEthernet 1/0/3
[RB3-if-range] trill enable
[RB3-if-range] trill link-type trunk
[RB3-if-range] trill designated-vlan 1000
# Configure Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 as trunk ports, set the PVID of the ports to VLAN 1000, and assign the ports to VLAN 100 and VLAN 1000.
[RB3-if-range] port link-type trunk
[RB3-if-range] port trunk pvid vlan 1000
[RB3-if-range] port trunk permit vlan 100 1000
[RB3-if-range] quit
# Configure RB 4 through RB 6 in the similar way RB 3 is configured. Create VLANs and assign the uplink ports to the corresponding VLANs on RB 4 through RB 6 as shown in Figure 10. (Details not shown.)
3.        Configure the downlink ports of distribution layer devices:
# Enable TRILL globally on RB 1.
<RB1> system-view
[RB1] trill
[RB1-trill] quit
# Create VLAN 100 and VLAN 200.
[RB1] vlan 100
[RB1-vlan100] quit
[RB1] vlan 200
[RB1-vlan200] quit
# Create VLAN 1000.
[RB1] vlan 1000
[RB1-vlan1000] quit
# Configure downlink ports Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as TRILL trunk ports, and configure VLAN 1000 as the designated VLAN.
[RB1]interface range Ten-GigabitEthernet 1/0/1 to Ten-GigabitEthernet 1/0/2
[RB1-if-range] trill enable
[RB1-if-range] trill link-type trunk
[RB1-if-range] trill designated-vlan 1000
# Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as trunk ports, set the PVID of the ports to VLAN 1000, and assign the ports to VLAN 100 and VLAN 1000.
[RB1-if-range] port link-type trunk
[RB1-if-range] port trunk pvid vlan 1000
[RB1-if-range] port trunk permit vlan 100 1000
[RB1-if-range] quit
# Configure downlink ports Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4 as TRILL trunk ports, and configure VLAN 1000 as the designated VLAN.
[RB1]interface range Ten-GigabitEthernet 1/0/3 to Ten-GigabitEthernet 1/0/4
# Configure Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4 as trunk ports, set the PVID of the ports to VLAN 1000, and assign the ports to VLAN 200 and VLAN 1000.
[RB1-if-range] port trunk permit vlan 200 1000
[RB1-if-range] quit
# Configure RB 2 in the same way RB 1 is configured. (Details not shown.)
4.        Configure TRILL Layer 3 forwarding on RB 1:
# Enable TRILL Layer 3 forwarding globally, and enable TRILL Layer 3 forwarding for VLAN 100 and VLAN 200.
[RB1] trill
[RB1-trill] l3-forwarding enable
[RB1-trill] l3-forwarding vlan 100 200
[RB1-trill] quit
# Create VLAN-interface 100, and assign IP address 100.1.1.1/24 to the VLAN interface.
[RB1] interface vlan-interface 100
[RB1-Vlan-interface100] ip address 100.1.1.1 24
# Enable periodic sending of gratuitous ARP packets on VLAN-interface 100.
[RB1-Vlan-interface100] arp send-gratuitous-arp
[RB1-Vlan-interface100] quit
# Create VLAN-interface 200, and assign IP address 200.1.1.1/24 to the VLAN interface.
[RB1] interface vlan-interface 200
[RB1-Vlan-interface200] ip address 200.1.1.1 24
# Enable periodic sending of gratuitous ARP packets on VLAN-interface 200.
[RB1-Vlan-interface200] arp send-gratuitous-arp
[RB1-Vlan-interface200] quit
5.        Configure TRILL distribution trees:
# Set RB 1's priority to 65535, and set the number to 2 for TRILL distribution trees that the RB wants all RBs to compute.
[RB1] trill
[RB1-trill] tree-root priority 65535
[RB1-trill] trees calculate 2
[RB1-trill] quit
# Set RB 2's priority to 65534, and set the number to 2 for TRILL distribution trees that the RB wants all RBs to compute.
[RB2] trill
[RB2-trill] tree-root priority 65534
[RB2-trill] trees calculate 2
[RB2-trill] quit
Suppose that the Layer 2 forwarding nicknames of RB 1 through RB 6 are 0x5801 through 0x5806. The Layer 3 forwarding nickname of RB1 is 0x3001. The system IDs of RB 1 and RB 2 are 0000.0000.0001 and 0000.0000.0002.
# Display brief information about all entries in the TRILL Layer 2 unicast routing table on an access layer device (for example, RB 3).
[RB3] display trill unicast-route
Destination    Interface                 NextHop
0x5801         XGE1/0/2                  Direct
0x3001         XGE1/0/2                  0x5801
0x5802         XGE1/0/3                  Direct
0x5803         N/A                       N/A
0x5804         XGE1/0/2                  0x5801
               XGE1/0/3                  0x5802
0x5805         XGE1/0/2                  0x5801
               XGE1/0/3                  0x5802
0x5806         XGE1/0/2                  0x5801
               XGE1/0/3                  0x5802
# Display TRILL Layer 3 unicast routing table information on RB 1.
[RB1] display trill l3-forwarding unicast-route
Destinations: 6        Unicast routes: 9
Destination   Neighbor ID     MAC address     Interface
0x3001        0x0             N/A             N/A
0x5802        0x01F4          00e0-fc58-1232  XGE1/0/1
XGE1/0/2
XGE1/0/3
XGE1/0/4
0x5803        0x01F5          00e0-fc58-1233  XGE1/0/1
0x5804        0x01F6          00e0-fc58-1234  XGE1/0/2
0x5805        0x01F7          00e0-fc58-1235  XGE1/0/3
0x5806        0x01F8          00e0-fc58-1236  XGE1/0/4
# Display all entries in the TRILL multicast routing table.
[RB3] display trill multicast-route
Root                          Flag
0x5801                        Valid
0x5802                        Valid
# Display multicast routing information for the TRILL distribution tree rooted at RB 1.
[RB3] display trill multicast-route tree-root 5801
Root: 0x5801
LocalRcvFlag: True
List of VLANs:
  100, 200
List of outgoing ports:
  XGE1/0/2
This example does not use TRILL Layer 3 forwarding.
As shown in Figure 11, a data center network has three layers: the core layer, the distribution layer, and the access layer. A port connected to a higher layer device is an uplink port, and a port connected to a lower layer device is a downlink port.
·          Enable TRILL on the downlink ports of access layer devices to connect terminal devices to the TRILL network.
·          Enable TRILL on the uplink ports of access layer devices, and configure these uplink ports as trunk ports to pass TRILL frames to the TRILL network.
·          Enable TRILL on the downlink ports of distribution layer devices, and configure these downlink ports as trunk ports to forward TRILL data frames.
·          Enable TRILL on the uplink ports of the distribution layer devices. These ports send the de-encapsulated TRILL data frames to the core layer.
·          In the TRILL network, configure four TRILL distribution trees with RB 6 through RB 9 as the root bridges. RB 6 through RB 9 are in descending priority order.
Figure 11 Network diagram
# Enable TRILL globally on RB 1, and enable TRILL on downlink port Ten-GigabitEthernet 1/0/1 of RB 1.
<RB1> system-view
[RB1] trill
[RB1-trill] quit
[RB1] interface ten-gigabitethernet 1/0/1
[RB1-Ten-GigabitEthernet1/0/1] trill enable
[RB1-Ten-GigabitEthernet1/0/1] quit
# Configure RB 2 through RB 5 in the same way RB 1 is configured. (Details not shown.)
# Enable TRILL on uplink ports Ten-GigabitEthernet 1/0/2 through Ten-GigabitEthernet 1/0/5 of RB 1, and configure these ports as trunk ports.
[RB1] interface ten-gigabitethernet 1/0/2
[RB1-Ten-GigabitEthernet1/0/2] trill enable
[RB1-Ten-GigabitEthernet1/0/2] trill link-type trunk
[RB1-Ten-GigabitEthernet1/0/2] quit
[RB1] interface ten-gigabitethernet 1/0/3
[RB1-Ten-GigabitEthernet1/0/3] trill enable
[RB1-Ten-GigabitEthernet1/0/3] trill link-type trunk
[RB1-Ten-GigabitEthernet1/0/3] quit
[RB1] interface ten-gigabitethernet 1/0/4
[RB1-Ten-GigabitEthernet1/0/4] trill enable
[RB1-Ten-GigabitEthernet1/0/4] trill link-type trunk
[RB1-Ten-GigabitEthernet1/0/4] quit
[RB1] interface ten-gigabitethernet 1/0/5
[RB1-Ten-GigabitEthernet1/0/5] trill enable
[RB1-Ten-GigabitEthernet1/0/5] trill link-type trunk
[RB1-Ten-GigabitEthernet1/0/5] quit
# Enable TRILL globally on RB 6, enable TRILL on downlink ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/5 of RB 6, and configure these ports as trunk ports.
<RB6> system-view
[RB6] trill
[RB6-trill] quit
[RB6] interface ten-gigabitethernet 1/0/1
[RB6-Ten-GigabitEthernet1/0/1] trill enable
[RB6-Ten-GigabitEthernet1/0/1] trill link-type trunk
[RB6-Ten-GigabitEthernet1/0/1] quit
[RB6] interface ten-gigabitethernet 1/0/2
[RB6-Ten-GigabitEthernet1/0/2] trill enable
[RB6-Ten-GigabitEthernet1/0/2] trill link-type trunk
[RB6-Ten-GigabitEthernet1/0/2] quit
[RB6] interface ten-gigabitethernet 1/0/3
[RB6-Ten-GigabitEthernet1/0/3] trill enable
[RB6-Ten-GigabitEthernet1/0/3] trill link-type trunk
[RB6-Ten-GigabitEthernet1/0/3] quit
[RB6] interface ten-gigabitethernet 1/0/4
[RB6-Ten-GigabitEthernet1/0/4] trill enable
[RB6-Ten-GigabitEthernet1/0/4] trill link-type trunk
[RB6-Ten-GigabitEthernet1/0/4] quit
[RB6] interface ten-gigabitethernet 1/0/5
[RB6-Ten-GigabitEthernet1/0/5] trill enable
[RB6-Ten-GigabitEthernet1/0/5] trill link-type trunk
[RB6-Ten-GigabitEthernet1/0/5] quit
# Configure RB 7 through RB 9 in the same way RB 6 is configured. (Details not shown.)
4.        Configure the uplink ports of the distribution layer devices:
# Enable TRILL on uplink ports Ten-GigabitEthernet 1/0/6 and Ten-GigabitEthernet 1/0/7 of RB 6.
[RB6] interface ten-gigabitethernet 1/0/6
[RB6-Ten-GigabitEthernet1/0/6] trill enable
[RB6-Ten-GigabitEthernet1/0/6] quit
[RB6] interface ten-gigabitethernet 1/0/7
[RB6-Ten-GigabitEthernet1/0/7] trill enable
[RB6-Ten-GigabitEthernet1/0/7] quit
# Set the RB 6's priority to 65535, and set the number of TRILL distribution trees that the RB wants all RBs to compute to 4.
[RB6] trill
[RB6-trill] tree-root priority 65535
[RB6-trill] trees calculate 4
[RB6-trill] quit
# Set the RB 7's priority to 65534, and set the number of TRILL distribution trees that the RB wants all RBs to compute to 4.
[RB7] trill
[RB7-trill] tree-root priority 65534
[RB7-trill] trees calculate 4
[RB7-trill] quit
# Set the RB 8's priority to 65533, and set the number of TRILL distribution trees that the RB wants all RBs to compute to 4.
[RB8] trill
[RB8-trill] tree-root priority 65533
[RB8-trill] trees calculate 4
[RB8-trill] quit
# Set the RB 9's priority to 65532, and set the number of TRILL distribution trees that the RB wants all RBs to compute to 4.
[RB9] trill
[RB9-trill] tree-root priority 65532
[RB9-trill] trees calculate 4
[RB9-trill] quit
Suppose that the nicknames of RB 1 through RB 9 are 0x5801 through 0x5809, respectively.
Use display trill unicast-route to display the TRILL Layer 2 unicast routing table. For example:
# Display brief information about all entries in the TRILL Layer 2 unicast routing table on RB 1.
[RB1] display trill unicast-route
0x5801         N/A                        N/A
0x5802         XGE1/0/2                   0x5806
               XGE1/0/3                   0x5807
               XGE1/0/4                   0x5808
               XGE1/0/5                   0x5809
0x5803         XGE1/0/2                   0x5806
               XGE1/0/3                   0x5807
               XGE1/0/4                   0x5808
               XGE1/0/5                   0x5809
0x5804         XGE1/0/2                   0x5806
               XGE1/0/3                   0x5808
               XGE1/0/4                   0x5808
               XGE1/0/5                   0x5809
0x5805         XGE1/0/2                   0x5806
               XGE1/0/3                   0x5807
               XGE1/0/4                   0x5808
               XGE1/0/5                   0x5809
0x5806         XGE1/0/2                   Direct
0x5807         XGE1/0/3                   Direct
0x5808         XGE1/0/4                   Direct
0x5809         XGE1/0/5                   Direct
Use display trill multicast-route to display the TRILL multicast routing table. For example:
# Display the TRILL multicast routing table on RB 1.
[RB1] display trill multicast-route
Root                          Flag
0x5806                        Valid
0x5807                        Valid
0x5808                        Valid
0x5809                        Valid
# Display TRILL multicast routing table information for the TRILL distribution tree with RB 6 as the root bridge on RB 1.
[RB1] display trill multicast-route tree-root 5806
Root: 0x5806
LocalRcvFlag: True
List of VLANs:
  1
  XGE1/0/2
