08-ACL and QoS Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6850 & S9850 Switch Series Command References-Release 655x-6W10008-ACL and QoS Command Reference
03-Data buffer commands
03-Data buffer commands 103.76 KB
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to restore the default.
buffer apply
undo buffer apply
For data buffer settings to take effect, you must execute this command after configuring data buffer settings.
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
This command might cause the PFC function to be on longer in effect or to operate incorrectly. For information about PFC configuration commands, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer packet-drop alarm enable
Use buffer packet-drop alarm enable to enable packet-drop alarms.
Use undo buffer packet-drop alarm enable to disable packet-drop alarms.
Packet-drop alarms are disabled.
The device generates and reports packet-drop alarms to a network management system (such as IMC) for displaying the data buffer usage.
This command does not take effect only on the Headroom buffer.
# Enable packet-drop alarms.
[Sysname] buffer packet-drop alarm enable
buffer usage threshold queue (interface view)
buffer usage threshold queue (system view)
buffer packet-drop alarm interval
Use buffer packet-drop alarm interval to set the interval for sending packet-drop alarms.
Use undo buffer packet-drop alarm interval to restore the default.
buffer packet-drop alarm interval interval
The interval for sending packet-drop alarms is 5 seconds.
interval: Specifies the interval for sending packet-drop alarms, in the range of 0 to 60 seconds. The value of 0 indicates that packet-drop alarms are sent immediately after they are generated.
This command takes effect only when packet-drop alarms are enabled.
# Set the interval for sending packet-drop alarms to 20 seconds.
[Sysname] buffer packet-drop alarm interval 20
buffer queue guaranteed (system view)
Use buffer queue guaranteed to set the fixed-area space for a queue.
Use undo buffer queue guaranteed to delete the fixed-area space setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id guaranteed ratio ratio
undo buffer egress [ slot slot-number ] cell queue queue-id guaranteed
The fixed-area ratio for a queue is 13%.
egress: Specifies the egress buffer.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command applies to all IRF member devices.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 1 to 100.
By default, all queues have an equal share of the fixed area. You can set the fixed-area ratio for a queue. The other queues equally share the remaining part.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of fixed-area space configured for all queues cannot exceed the total fixed-area space. Otherwise, the configuration fails.
# Configure queue 0 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 guaranteed ratio 20
buffer queue guaranteed (interface view)
Use buffer queue guaranteed to set the fixed-area ratio or size for a queue.
Use undo buffer queue guaranteed to delete the fixed-area ratio or size setting of a queue.
buffer egress cell queue queue-id guaranteed ratio ratio
undo buffer egress cell queue queue-id guaranteed
Interface view
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 0 to 100.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of the fixed-area ratios configured for all queues cannot exceed 100%. The queue that causes the sum of the fixed-area ratios to exceed 100% fails to be configured and still uses the default setting.
# Configure queue 0 on Twenty-FiveGigE 1/0/1 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] buffer egress cell queue 0 guaranteed ratio 20
buffer queue map-to service-pool
Use buffer queue map-to service-pool to map a queue to a service pool.
Use undo buffer queue map-to service-pool to restore the default.
buffer { egress | ingress } queue queue-id map-to service-pool sp-id
undo buffer { egress | ingress } queue queue-id map-to
All queues are mapped to service pool 0.
Interface view
ingress: Specifies the ingress buffer.
service-pool sp-id: Specifies a service pool by its ID. The value range for the sp-id argument is 1 to 3.
Before configuring this command, use the buffer service-pool shared command to set the maximum shared-area ratio for the service pool.
For the ingress buffer, the queue ID specified represents the 802.1p priority. The actual queue ID mapped to the service pool is determined by the dot1p-lp priority map.
# Map queue 1 on Twenty-FiveGigE 1/0/1 to service pool 1.
[Sysname-Twenty-FiveGigE1/0/1] buffer egress queue 1 map-to service-pool 1
buffer queue shared (system view)
Use buffer queue shared to set the maximum shared-area ratio for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id shared ratio ratio
undo buffer egress [ slot slot-number ] cell queue queue-id shared
The maximum shared-area ratio for a queue is 20%.
ratio ratio: Specifies the maximum shared-area space ratio, in percentage. The value range for ratio is 0 to 100.
By default, all queues have an equal share of the shared area. You can set the shared-area ratio for a queue. The unconfigured queues use the default setting. The shared-area space for each queue is finally determined by the chip based on your configuration and the number of packets to be received and sent.
# Configure queue 0 to use up to 10% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 shared ratio 10
buffer queue shared (interface view)
Use buffer queue shared to set the maximum shared-area ratio or size for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio or size setting of a queue.
buffer egress cell queue queue-id shared ratio ratio
undo buffer egress cell queue queue-id shared
Interface view
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 100.
# Configure queue 0 on Twenty-FiveGigE 1/0/1 to use 20% shared-area space of cell resources in the egress buffer.
[Sysname-Twenty-FiveGigE1/0/1] buffer egress cell queue 0 shared ratio 20
Use buffer service-pool shared to set the maximum shared-area ratio or size for a service pool.
Use undo buffer service-pool shared to delete the maximum shared-area ratio or size setting of a service pool.
buffer { egress | ingress } [ slot slot-number ] cell service-pool sp-id shared ratio ratio
undo buffer { egress | ingress } [ slot slot-number ] cell service-pool sp-id shared
All of the shared area is reserved for service pool 0.
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 99.
This command takes effect after you executed the buffer apply command.
If you specify the slot slot-number option, this commmand applies to the specified slot. If you do not specify the option, this commmand applies to all slots. The configuration for a slot have higher priority over the configuration for all slots.
# Configure service pool 1 to use up to 50% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell service-pool 1 shared ratio 50
buffer apply
buffer threshold alarm enable
Use buffer threshold alarm enable to enable threshold-crossing alarms.
Use undo buffer threshold alarm enable to disable threshold-crossing alarms.
buffer threshold alarm { egress | headroom | ingress } enable
undo buffer threshold alarm { egress | headroom | ingress } enable
Threshold-crossing alarms are disabled.
headroom: Specifies the Headroom buffer.
The device generates and reports threshold-crossing alarms to a network management system (such as IMC) for displaying the data buffer usage.
# Enable threshold-crossing alarms.
[Sysname] buffer threshold alarm ingress enable
buffer usage threshold headroom
buffer usage threshold headroom queue
buffer threshold alarm interval
Use buffer threshold alarm interval to set the interval for sending threshold-crossing alarms.
Use undo buffer threshold alarm interval to restore the default.
buffer threshold alarm { egress | headroom | ingress } interval interval
undo buffer threshold alarm { egress | headroom | ingress } interval
The interval for sending threshold-crossing alarms is 5 seconds.
interval: Specifies the interval for sending threshold-crossing alarms, in the range of 0 to 60 seconds. 0 indicates that threshold-crossing alarms are sent immediately after they are generated.
This command takes effect only when threshold-crossing alarms are enabled.
# Set the interval for sending threshold-crossing alarms to 20 seconds.
[Sysname] buffer threshold alarm ingress interval 20
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to delete the total shared-area ratio setting.
buffer egress [ slot slot-number ] cell total-shared ratio ratio
undo buffer egress [ slot slot-number ] cell total-shared
The total shared-area ratio is 100%.
ratio ratio: Specifies the ratio of the shared area, in percentage. The value range for ratio is 0 to 100.
After you set the shared-area ratio, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 50% space of cell resources in the egress buffer.
[Sysname] buffer egress cell total-shared ratio 50
Use buffer usage threshold to set a per-interface buffer usage threshold.
Use undo buffer usage threshold to restore the default.
buffer usage threshold slot slot-number ratio ratio
undo buffer usage threshold slot slot-number
The per-interface buffer usage threshold is 100%.
slot slot-number: Specifies an IRF member device by its member ID.
ratio ratio: Specifies the buffer usage threshold in percentage, in the range of 1 to 100.
After you configure this command, the switch automatically records buffer usage for each interface. When a queue on an interface uses more buffer space than the set threshold, the system counts one threshold violation for the queue.
To display the buffer usage statistics for interfaces, use the display buffer usage interface command.
# Set the per-interface buffer usage threshold to 50% for IRF member device 1.
[Sysname] buffer usage threshold slot 1 ratio 50
Use buffer usage threshold headroom to set the global per-queue alarm threshold for the Headroom buffer.
Use undo buffer usage threshold headroom to restore the default.
buffer usage threshold headroom slot slot-number ratio ratio
undo buffer usage threshold headroom slot slot-number ratio
The global per-queue alarm threshold for the Headroom buffer is 100%.
ratio ratio: Specifies the alarm threshold in percentage, in the range of 1 to 100.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global alarm threshold for the Headroom buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
#  Set the global per-queue alarm threshold to 50% for slot 1.
[Sysname] buffer usage threshold headroom slot 1 ratio 50
Use buffer usage threshold headroom queue to set the Headroom buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold headroom queue to restore the default.
buffer usage threshold headroom queue queue-id ratio ratio
undo buffer usage threshold headroom queue queue-id ratio
The global per-queue alarm threshold for the Headroom buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the Headroom buffer alarm threshold to 50% for queue 1 on Twenty-FiveGigE 1/0/1.
[Sysname–Twenty-FiveGigE1/0/1] buffer usage threshold headroom queue 1 ratio 50
Use buffer usage threshold queue to set the ingress or egress buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold queue to restore the default.
buffer { egress | ingress } usage threshold queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold queue queue-id ratio
The global per-queue alarm threshold for the ingress or egress buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold for the ingress or egress buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the ingress buffer alarm threshold to 50% for queue 1 on Twenty-FiveGigE 1/0/1.
[Sysname–Twenty-FiveGigE1/0/1] buffer ingress usage threshold queue 1 ratio 50
Use buffer usage threshold queue to set the global ingress or egress buffer alarm threshold for a queue.
buffer { egress | ingress } usage threshold slot slot-number  queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold slot slot-number queue queue-id ratio
The global ingress or egress buffer alarm threshold for a queue is 100%.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global ingress or egress alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
#  Set the global ingress alarm threshold to 50% for queue 1 in slot 1.
[Sysname] buffer ingress usage threshold slot 1 queue 1 ratio 50
buffer usage threshold service-pool
Use buffer usage threshold service-pool to set the alarm threshold for a service pool.
Use undo buffer usage threshold service-pool to restore the default.
buffer { egress | ingress } usage threshold service-pool sp-id slot slot-number ratio ratio
undo buffer { egress | ingress } usage threshold service-pool sp-id slot slot-number ratio
The alarm threshold for a service pool is 100%.
service-pool sp-id: Specifies a service pool by its ID. The value range for the sp-id argument is 0 to 3.
This command takes effect only when threshold-crossing alarms are enabled. When the usage of a service pool exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the alarm threshold to 50% for a service pool in slot 1.
[Sysname] buffer egress usage threshold service-pool 0 slot 1 ratio 50
buffer queue shared
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·          Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·          Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·          Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
The default data buffer settings are changed after the Burst feature is enabled. You can display the data buffer settings by using the display buffer command.
Disabling the Burst feature after enabling it might cause the PFC function to be on longer in effect or to operate incorrectly. For information about PFC configuration commands, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer size settings for all IRF member devices.
queue queue-id: Specifies a queue by its number in the range of 0 to 7. If you specify a queue, this command displays the fixed-area ratio and shared-area ratio for the specified queue. If you specify the queue keyword without the queue-id argument, this command displays the fixed-area ratio and shared-area ratio for each queue. If you do not specify the queue keyword, this command displays the total shared-area ratio.
# Display buffer size settings.
<Sysname> display buffer
Slot  Type    Eg(Total-shared)
1     cell    100
          Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
        Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for the queues.
<Sysname> display buffer queue
Slot  Queue        Type    Eg(Guaranteed , Shared)
1     0-7          cell    13 , 88
  Guaranteed: Size of the minimum guaranteed buffer per queue
      Shared: Size of the maximum shared buffer per queue
        Unit: Ratio
Resource type.
Queue
Queue ID in the range of 0 to 7.
Eg
Egress buffer.
(Total-shared)
Total-shared indicates the total shared-area ratio.
·         Guaranteed indicates the fixed-area ratio of a queue.
·         Shared indicates the shared-area ratio of a queue.
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display buffer usage.
<Sysname> display buffer usage
Inress total-shared cell buffer usage on slot 2 :
XPE 0
Total:   32768 KB
Used:       0 KB
Free:   32768 KB
Global_headroom:       0 KB
SP0_headroom_used:       0 KB
SP0_Headroom_peak:       0 KB
SP0_buffer_total:   32677 KB
SP0_buffer_used:       0 KB
SP0_buffer_peak:       0 KB
SP1_headroom_used:       0 KB
SP1_Headroom_peak:       0 KB
SP1_buffer_total:       0 KB
SP1_buffer_used:       0 KB
SP1_buffer_peak:       0 KB
SP2_headroom_used:       0 KB
SP2_Headroom_peak:       0 KB
SP2_buffer_total:       0 KB
SP2_buffer_used:       0 KB
SP2_buffer_peak:       0 KB
SP3_headroom_used:       0 KB
SP3_Headroom_peak:       0 KB
SP3_buffer_total:       0 KB
SP3_buffer_used:       0 KB
SP3_buffer_peak:       0 KB
Egress total-shared cell buffer usage on slot 2 :
XPE 0
Total:   32768 KB
Used:       0 KB
Free:   32768 KB
                       5sec   1min   5min
WGE2/0/1       XPE 0     0%     0%     0%
WGE2/0/2       XPE 0     0%     0%     0%
WGE2/0/3       XPE 0     0%     0%     0%
WGE2/0/4       XPE 0     0%     0%     0%
WGE2/0/5       XPE 0     0%     0%     0%
Usage of cell resources in the shared area on an IRF member device.
Unit
Chip number.
XPE
Type of the data buffer.
Total
Total size of the data buffer.
Used
Size of used data buffer.
Free
Size of free data buffer.
Global_headroom
Total headroom size.
SP
Service pool.
headroom_used
Headroom area usage in KB for the ingress buffer.
Headroom_peak
Peak used Headroom area in KB during the time between two executions of the display buffer usage command.
buffer_total
Total buffer size in KB.
buffer_used
Used buffer size in KB.
buffer_peak
Peak used buffer size in KB during the time between two executions of the display buffer usage command.
5sec
Percentage of the buffer that the port uses for the last 5 seconds.
1min
Percentage of the buffer that the port uses for the last 1 minute.
5min
Percentage of the buffer that the port uses for the last 5 minutes.
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ] [ verbose ]
interface-type [ interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
verbose: Displays detailed buffer usage statistics. If you do not specify this keyword, the command displays brief buffer usage statistics.
# Display brief buffer usage statistics for Twenty-FiveGigE 1/0/1.
<Sysname> display buffer usage interface twenty-fivegige 1/0/1
Interface              QueueID Total       Used        Threshold(%) Violations
HGE1/0/1               0       6692352     0           70           0
                       1       6692352     0           70           0
                       2       6692352     0           70           0
                       3       6692352     0           70           0
                       4       6692352     0           70           0
                       5       6692352     0           70           0
                       6       6692352     0           70           0
                       7       6692352     0           70           0
Total
Data buffer size in bytes allowed for a queue.
Used
Data buffer size in bytes that has been used by a queue.
Threshold(%)
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value.
Violations
Number of threshold violations for a queue.
The value of this field is reset upon a switch reboot.
# Display detailed buffer usage statistics for Twenty-FiveGigE 1/0/1.
[Sysname] display buffer usage interface twenty-fivegige 1/0/1 verbose
  Ingress:
    QueueID: 0
      Total: 127974            Used: 0                  Threshold(%): 70
      Violations: 0            Shared: 0                Headroom: 0
      XoffThres: 127968        IsDynamic: 0
      Used(%): 0               Free: 127968             UsedPeak: 0
      HeadroomUsed(%): 0       HeadroomFree: 0          HeadroomPeak: 0
    QueueID: 1
    QueueID: 2
    QueueID: 3
    QueueID: 4
    QueueID: 5
    QueueID: 6
    QueueID: 7
  Egress:
    QueueID: 0
      Total: 116070            Used: 0                  Threshold(%): 70
      Violations: 0            TailDropThres: 116070    IsDynamic: 1
      DeadlockCount: 0         DeadlockRecover: 0
      Used(%): 0               Free: 116070             UsedPeak: 0
    QueueID: 1
    QueueID: 2
    QueueID: 3
    QueueID: 4
    QueueID: 5
    QueueID: 6
    QueueID: 7
Ingress
Usage statistics for the ingress buffer.
Egress
Usage statistics for the egress buffer.
Total
Data buffer size allowed for a queue, in cell resources.
Used
Data buffer size that has been used by a queue, in cell resources.
Threshold(%)
Violations
Shared
Number of cell resources in the shared area used by a queue.
Headroom
Number of cell resources in the Headroom area used by a queue.
When a queue on an interface enabled with PFC enters PFC XOFF state, the interface sends XOFF frames to notify the peer interface to stop sending packets to that queue. Packets sent by the peer interface before it receives XOFF frames are stored in the Headroom area.
XoffThres
Back pressure frame triggering threshold in number of cell resources.
For commands to configure back pressure frame triggering thresholds, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
TailDropThres
Tail drop threshold, in the number of cell resources calculated according to the ratio value set in the buffer queue shared command.
IsDynamic
For the inbound direction, this field can be one of the following values:
·         0—Indicates a static back pressure frame triggering threshold.
·         1—Indicates a dynamic back pressure frame triggering threshold.
For the outbound direction, this field can only be 1, which indicates a dynamic tail drop threshold.
Used(%)
Buffer usage in percentage.
Free
Free buffer in cell resources.
UsedPeak
Peak used buffer in cell resources during the time between two executions of the display buffer usage interface command.
HeadroomUsed(%)
Headroom area usage in percentage for the ingress buffer.
HeadroomFree
Free Headroom area in number of cell resourcesfor the ingress buffer.
HeadroomPeak
Peak used Headroom area in number of cell resourcesduring the time between two executions of the display buffer usage interface command.
DeadlockCount
Number of times the device entered the PFC deadlock state in the egress buffer.
DeadlockRecover
Number of times the device released the PFC deadlock state in the egress buffer.
For more information about back pressure frame triggering thresholds and PFC deadlock, see Ethernet interface configuration in Layer 2—LAN Switching Configuration Guide.
