06-Layer 3-IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600[SR6600-X] Routers Command References(V7)-R7740-6W20006-Layer 3-IP Services Command Reference
06-IP forwarding basics commands
06-IP forwarding basics commands 86.54 KB
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ topology topology-name | vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
topology topology-name: Specifies a topology by its name, a case-sensitive string of 1 to 31 characters. To specify a public topology, use base as the topology name. To display FIB entries for the public network, do not specify this option.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display FIB entries for topology mt.
<Sysname> display fib topology mt
Destination count: 8 FIB entry count: 8
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
224.0.0.0/4        0.0.0.0         UB       NULL0                    Null
224.0.0.0/24       0.0.0.0         UB       NULL0                    Null
255.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
# Display all FIB entries of the public network.
Destination count: 5 FIB entry count: 5
Flag:
  R:Relay     F:FRR
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Destination count: 6 FIB entry count: 6
Flag:
  R:Relay     F:FRR
192.168.1.0/24     192.168.1.247   U        GE1/5/1/0                Null
192.168.1.0/32     192.168.1.247   UBH      GE1/5/1/0                Null
192.168.1.3/32     192.168.1.3     UH       GE1/5/1/0                Null
192.168.1.21/32    192.168.1.21    UH       GE1/5/1/0                Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Destination count
Total number of destination addresses.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address and the mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
ip last-hop hold
Use ip last-hop hold to enable last hop holding.
Use undo ip last-hop hold to disable last hop holding.
ip last-hop hold
Last hop holding is disabled.
Last hop holding implements symmetric routing. It tracks the last hop MAC address for the first incoming IP packet of a connection, and it sends the return packets to the hop that transmits the request.
Last hop holding is based on fast forwarding entries. If the MAC address of a last hop changes, this feature can function correctly only after the fast forwarding entry is updated for the MAC address.
This command is not applicable to an MPLS network.
# Enable the last hop holding feature.
[Sysname-GigabitEthernet2/0/1] ip last-hop hold
Load sharing commands
bandwidth-based-sharing
Use bandwidth-based-sharing to enable IPv4 load sharing based on bandwidth.
Use undo bandwidth-based-sharing to disable IPv4 load sharing based on bandwidth.
The IPv4 load sharing based on bandwidth is disabled.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of their expected bandwidths.
Devices that run load sharing protocols, such as Locator/ID Separation Protocol (LISP), implement load sharing based on the ratios defined by these protocols.
# Enable IPv4 load sharing based on bandwidth.
[Sysname] bandwidth-based-sharing
ip load-sharing mode
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
In standalone mode:
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * | per-packet } { global | slot slot-number }
undo ip load-sharing mode { global | slot slot-number }
In IRF mode:
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * | per-packet } { chassis chassis-number slot slot-number | global }
undo ip load-sharing mode { chassis chassis-number slot slot-number | global }
The device performs per-flow load sharing.
per-flow: Implements per-flow load sharing.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
global: Configures the load sharing mode globally.
per-packet: Implements per-packet load sharing.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command configures the load sharing mode for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command configures the load sharing mode for all cards. (In IRF mode.)
The per-packet load sharing mode does not take effect in fast forwarding.
# (In standalone mode.) Configure per-flow load sharing for slot 1.
[Sysname] ip load-sharing mode per-flow slot 1
