- 10-Network Management and Monitoring Configuration Guide
- 01-System maintenance and debugging
- 02-NQA configuration
- 03-NTP configuration
- 04-PoE configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-CWMP configuration
- 09-EAA configuration
- 10-Process monitoring and maintenance
- 11-Mirroring configuration
- 12-sFlow configuration
- 13-Information center configuration
- 14-Packet capture configuration
- 15-VCF fabric configuration
- 16-Cloud connection configuration
- 17-SmartMC configuration
| 13-Information center configuration | 151.53 KB |
Configuring the information center
Default output rules for standard system logs
Default output rules for diagnostic logs·
Default output rules for security logs
Default output rules for hidden logs
Default output rules for trace logs
Log formats and field descriptions
Information center tasks at a glance
Enabling the information center
Outputting logs to various destinations·
Outputting logs to the console
Outputting logs to the monitor terminal
Outputting logs to the log buffer
Setting the minimum storage period for logs
Enabling synchronous information output
Enabling duplicate log suppression
Configuring log suppression for a module
Disabling an interface from generating link up or link down logs
Enabling SNMP notifications for system logs
Saving security logs to the security log file
Managing the security log file
Saving diagnostic logs to the diagnostic log file
Setting the maximum size of the trace log file
Display and maintenance commands for information center
Information center configuration examples
Example: Outputting logs to the console·
Example: Outputting logs to a UNIX log host
Example: Outputting logs to a Linux log host
About the information center
The information center on the device receives logs generated by source modules and outputs logs to different destinations according to log output rules. Based on the logs, you can monitor device performance and troubleshoot network problems.
Figure 1 Information center diagram
Log types
Logs are classified into the following types:
· Standard system logs—Record common system information. Unless otherwise specified, the term "logs" in this document refers to standard system logs.
· Diagnostic logs—Record debug messages.
· Security logs—Record security information, such as authentication and authorization information.
· Hidden logs—Record log information not displayed on the terminal, such as input commands.
· Trace logs—Record system tracing and debug messages, which can be viewed only after the devkit package is installed.
Log levels
Logs are classified into eight severity levels from 0 through 7 in descending order. The information center outputs logs with a severity level that is higher than or equal to the specified level. For example, if you specify a severity level of 6 (informational), logs that have a severity level from 0 to 6 are output.
Severity value |
Level |
0 |
Emergency |
The system is unusable. For example, the system authorization has expired. |
1 |
Alert |
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit. |
2 |
Critical |
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails. |
3 |
Error |
Error condition. For example, the link state changes. |
4 |
Warning |
Warning condition. For example, an interface is disconnected, or the memory resources are used up. |
5 |
Notification |
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots. |
6 |
Informational |
Informational message. For example, a command or a ping operation is executed. |
7 |
Debugging |
Debug message. |
Log destinations
The system outputs logs to the following destinations: console, monitor terminal, log buffer, log host, and log file. Log output destinations are independent and you can configure them after enabling the information center. One log can be sent to multiple destinations.
A log output rule specifies the source modules and severity level of logs that can be output to a destination. Logs matching the output rule are output to the destination. Table 2 shows the default log output rules.
Table 2 Default output rules for standard system logs
Destination |
Log source modules |
Output switch |
Severity |
Console |
All supported modules |
Enabled |
Debug |
Monitor terminal |
Disabled |
Debug |
Log host |
Enabled |
Informational |
Log buffer |
Enabled |
Informational |
Log file |
Enabled |
Informational |
Diagnostic logs can only be output to the diagnostic log file, and cannot be filtered by source modules and severity levels. Table 3 shows the default output rule for diagnostic logs.
Table 3 Default output rule for diagnostic logs
Destination |
Output switch |
Severity |
Diagnostic log file |
Enabled |
Debug |
Security logs can only be output to the security log file, and cannot be filtered by source modules and severity levels. Table 4 shows the default output rule for security logs.
Table 4 Default output rule for security logs
Destination |
Output switch |
Severity |
Security log file |
Disabled |
Debug |
Hidden logs can be output to the log host, the log buffer, and the log file. Table 5 shows the default output rules for hidden logs.
Table 5 Default output rules for hidden logs
Destination |
Output switch |
Severity |
Log host |
Enabled |
Informational |
Log buffer |
Enabled |
Informational |
Log file |
Enabled |
Informational |
Trace logs can only be output to the trace log file, and cannot be filtered by source modules and severity levels. Table 6 shows the default output rules for trace logs.
Table 6 Default output rules for trace logs
Destination |
Output switch |
Severity |
Trace log file |
Enabled |
Debugging |
Log formats
The format of logs varies by output destinations. Table 7 shows the original format of log information, which might be different from what you see. The actual format varies by the log resolution tool used.
Output destination |
Format |
Example |
Console, monitor terminal, log buffer, or log file |
Prefix Timestamp Sysname Module/Level/Mnemonic: Content |
%Nov 24 14:21:43:502 2016 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.26 |
Log host |
Standard format: ·
unicom format: ·
cmcc format: |
Standard format: ·
unicom format: ·
cmcc format: |
Log field description
Table 8 Log field description
Prefix (information type) |
A log to a destination other than the log host has an identifier in front of the timestamp: · An identifier of percent sign (%) indicates a log with a level equal to or higher than informational. · An identifier of asterisk (*) indicates a debug log or a trace log. · An identifier of caret (^) indicates a diagnostic log. |
PRI (priority) |
A log destined for the log host has a priority identifier in front of the timestamp. The priority is calculated by using this formula: facility*8+level, where: · facility is the facility name. Facility names local0 through local7 correspond to values 16 through 23. The facility name can be configured using the info-center loghost command. It is used to identify log sources on the log host, and to query and filter the logs from specific log sources. · level is in the range of 0 to 7. See Table 1 for more information about severity levels. |
Timestamp |
Records the time when the log was generated. Logs sent to the log host and those sent to the other destinations have different timestamp precisions, and their timestamp formats are configured with different commands. For more information, see Table 9 and Table 10. |
Hostip |
Source IP address of the log. If the info-center loghost source command is configured, this field displays the IP address of the specified source interface. Otherwise, this field displays the sysname. This field exists only in logs in unicom format that are sent to the log host. |
Serial number |
Serial number of the device that generated the log. This field exists only in logs in unicom format that are sent to the log host. |
Sysname (host name or host IP address) |
The sysname is the host name or IP address of the device that generated the log. You can use the sysname command to modify the name of the device. |
%% (vendor ID) |
Indicates that the information was generated by an H3C device. This field exists only in logs sent to the log host. |
vv (version information) |
Identifies the version of the log, and has a value of 10. This field exists only in logs that are sent to the log host. |
Module |
Specifies the name of the module that generated the log. You can enter the info-center source ? command in system view to view the module list. |
Level |
Identifies the level of the log. See Table 1 for more information about severity levels. |
Mnemonic |
Describes the content of the log. It contains a string of up to 32 characters. |
Source |
Optional field that identifies the source of the log. The value contains an IRF member device ID and the IP address of the log sender. |
Content |
Provides the content of the log. |
Table 9 Timestamp precisions and configuration commands
Item |
Destined for the log host |
Destined for the console, monitor terminal, log buffer, and log file |
Precision |
Seconds |
Milliseconds |
Command used to set the timestamp format |
info-center timestamp loghost |
info-center timestamp |
Table 10 Description of the timestamp parameters
Timestamp parameters |
Example |
boot |
Time that has elapsed since system startup, in the format of xxx.yyy. xxx represents the higher 32 bits, and yyy represents the lower 32 bits, of milliseconds elapsed. Logs that are sent to all destinations other than a log host support this parameter. |
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. 0.109391473 is a timestamp in the boot format. |
date |
Current date and time, in the format of mmm dd hh:mm:ss yyy for logs that are output to a log host, or MMM DD hh:mm:ss:xxx YYYY for logs that are output to other destinations. All logs support this parameter. |
%May 30 05:36:29:579 2003 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. May 30 05:36:29:579 2003 is a timestamp in the date format. |
iso |
Timestamp format stipulated in ISO 8601. Only logs that are sent to a log host support this parameter. |
<189>2003-05-30T06:42:44 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully. 2003-05-30T06:42:44 is a timestamp in the iso format. |
none |
No timestamp is included. All logs support this parameter. |
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. No timestamp is included. |
no-year-date |
Current date and time without year information, in the format of MMM DD hh:mm:ss:xxx. Only logs that are sent to a log host support this parameter. |
<189>May 30 06:44:22 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully. May 30 06:44:22 is a timestamp in the no-year-date format. |
FIPS compliance
Managing standard system logs
1. Enabling the information center
2. Outputting logs to various destinations
¡ Outputting logs to the console
¡ Outputting logs to the monitor terminal
¡ Outputting logs to log hosts
¡ Outputting logs to the log buffer
3. (Optional.) Setting the minimum storage period for logs
4. (Optional.) Enabling synchronous information output
5. (Optional.) Configuring log suppression
¡ Enabling duplicate log suppression
¡ Configuring log suppression for a module
¡ Disabling an interface from generating link up or link down logs
6. (Optional.) Enabling SNMP notifications for system logs
Managing hidden logs
4. (Optional.) Configuring log suppression
Managing security logs
2. (Optional.) Configuring log suppression
¡ Saving security logs to the security log file
¡ Managing the security log file
Managing diagnostic logs
3. Saving diagnostic logs to the diagnostic log file
Managing trace logs
3. Setting the maximum size of the trace log file
About enabling the information center
The information center can output logs only after it is enabled.
1. Enter system view.
2. Enable the information center.
info-center enable
The information center is enabled by default.
The terminal monitor, terminal debugging, and terminal logging commands take effect only for the current connection between the terminal and the device. If a new connection is established, the default is restored.
2. Configure an output rule for sending logs to the console.
info-center source { module-name | default } console { deny | level severity }
For information about default output rules, see "Default output rules for standard system logs."
3. (Optional.) Configure the timestamp format.
The default timestamp format is date.
4. Return to user view.
5. Enable log output to the console.
terminal monitor
By default, log output to the console is enabled.
6. Enable the display of debug information on the current terminal.
terminal debugging
By default, the display of debug information on the current terminal is disabled .
7. Set the lowest severity level of logs that can be output to the console.
The default setting is 6 (informational).
About monitor terminals
Monitor terminals refer to terminals that log in to the device through the AUX, VTY, or TTY line.
2. Configure an output rule for sending logs to the monitor terminal.
info-center source { module-name | default } monitor { deny | level severity }
5. Enable log output to the monitor terminal.
terminal monitor
By default, log output to the monitor terminal is disabled.
terminal debugging
By default, the display of debug information on the current terminal is disabled.
7. Set the lowest level of logs that can be output to the monitor terminal.
The device supports the following methods (in descending order of priority) for outputting logs of a module to designated log hosts:
· Fast log output.
For information about the modules that support fast log output and how to configure fast log output, see "Configuring fast log output."
· Flow log.
For information about the modules that support flow log output and how to configure flow log output, see "Configuring flow log."
· Information center.
If you configure multiple log output methods for a module, only the method with the highest priority takes effect.
2. Configure an output rule for sending logs to log hosts.
info-center source { module-name | default } loghost { deny | level severity }
3. (Optional.) Specify a source IP address for output logs.
By default, the source IP address of output logs is the primary IP address of their outgoing interfaces.
4. (Optional.) Specify the format in which logs are output to log hosts.
info-center format { unicom |cmcc }
By default, logs are output to log hosts in standard format.
5. (Optional.) Configure the timestamp format.
info-center timestamp loghost { date | iso [ with-timezone ] | no-year-date | none }
6. Specify a log host and configure related parameters.
info-center loghost { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ dscp dscp-value ] [ facility local-number ]
By default, no log hosts or related parameters are specified.
The value for the port-number argument must be the same as the value configured on the log host. Otherwise, the log host cannot receive logs.
2. Configure an output rule for sending logs to the log buffer.
info-center source { module-name | default } logbuffer { deny | level severity }
4. Enable log output to the log buffer.
info-center logbuffer
By default, log output to the log buffer is enabled.
5. (Optional.) Set the maximum number of logs that can be stored in the log buffer.
By default, the log buffer can store a maximum of 512 logs.
Saving logs to the log file
About log saving to the log file
By default, the log file feature saves logs from the log file buffer to the log file every 24 hours. You can adjust the saving interval or manually save logs to the log file. After saving logs to the log file, the system clears the log file buffer.
The device supports only one log file, which is automatically created when needed. The log file has a maximum capacity. When the log file is full or no storage space is available, the system will replace the oldest logs with new logs.
You can enable log file overwrite-protection to stop the device from saving new logs when the log file is full or no storage space is available.
TIP: Clean up the storage space of the device regularly to ensure sufficient storage space for the log file feature. |
2. Configure an output rule for sending logs to the log file.
info-center source { module-name | default } logfile { deny | level severity }
3. Enable the log file feature.
info-center logfile enable
By default, the log file feature is enabled.
4. (Optional.) Enable log file overwrite-protection.
info-center logfile overwrite-protection [ all-port-powerdown ]
By default, log file overwrite-protection is disabled.
Log file overwrite-protection is supported only in FIPS mode.
5. (Optional.) Set the maximum log file size.
The default maximum log file size is 10 MB.
To ensure normal operation, set the size argument to a value between 1 MB and 10 MB.
6. (Optional.) Specify the log file directory.
The default log file directory is flash:/logfile.
This command cannot survive an IRF reboot or a master/subordinate switchover.
7. Save logs in the log file buffer to the log file. Choose one option as needed:
¡ Configure the automatic log file saving interval.
The default saving interval is 86400 seconds.
¡ Manually save logs in the log file buffer to the log file.
logfile save
This command is available in any view.
About setting the log minimum storage period
Use this feature to set the minimum storage period for logs in the log buffer and log file. This feature ensures that logs will not be overwritten by new logs during a set period of time.
By default, when the log buffer or log file is full, new logs will automatically overwrite the oldest logs. After the minimum storage period is set, the system identifies the storage period of a log to determine whether to delete the log. The system current time minus a log's generation time is the log's storage period.
· If the storage period of a log is shorter than or equal to the minimum storage period, the system does not delete the log. The new log will not be saved.
· If the storage period of a log is longer than the minimum storage period, the system deletes the log to save the new log.
2. Set the log minimum storage period.
info-center syslog min-age min-age
By default, the log minimum storage period is not set.
About synchronous information output
System log output interrupts ongoing configuration operations, obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
2. Enable synchronous information output.
info-center synchronous
By default, synchronous information output is disabled.
About duplicate log suppression
Output of consecutive duplicate logs (logs that have the same module name, level, mnemonic, location, and text) wastes system and network resources.
With duplicate log suppression enabled, the system starts a suppression period upon outputting a log:
· If only duplicate logs are received during the suppression period, the information center does not output the duplicate logs. When the suppression period expires, the information center outputs the suppressed log and the number of times the log is suppressed.
· If a different log is received during the suppression period, the information center performs the following operations:
¡ Outputs the suppressed log and the number of times the log is suppressed.
¡ Outputs the different log and starts a suppression period for that log.
· If no log is received within the suppression period, the information center does not output any message when the suppression period expires.
2. Enable duplicate log suppression.
info-center logging suppress duplicates
By default, duplicate log suppression is disabled.
About log suppression for a module
This feature suppresses output of logs. You can use this feature to filter out the logs that you are not concerned with.
Perform this task to configure a log suppression rule to suppress output of all logs or logs with a specific mnemonic value for a module.
2. Configure a log suppression rule for a module.
By default, the device does not suppress output of any logs from any modules.
About disabling an interface from generating link up or link down logs
By default, an interface generates link up or link down log information when the interface state changes. In some cases, you might want to disable certain interfaces from generating this information. For example:
· You are concerned about the states of only some interfaces. In this case, you can use this function to disable other interfaces from generating link up and link down log information.
· An interface is unstable and continuously outputs log information. In this case, you can disable the interface from generating link up and link down log information.
Use the default setting in normal cases to avoid affecting interface status monitoring.
2. Enter interface view.
3. Disable the interface from generating link up or link down logs.
undo enable log updown
By default, an interface generates link up and link down logs when the interface state changes.
About enabling SNMP notifications for system logs
This feature enables the device to send an SNMP notification for each log message it outputs. The device encapsulates the logs in SNMP notifications and then sends them to the SNMP module and the log trap buffer.
You can configure the SNMP module to send received SNMP notifications in SNMP traps or informs to remote hosts. For more information, see "Configuring SNMP."
To view the traps in the log trap buffer, access the MIB corresponding to the log trap buffer.
2. Enable SNMP notifications for system logs.
snmp-agent trap enable syslog
By default, the device does not send SNMP notifications for system logs.
3. Set the maximum number of traps that can be stored in the log trap buffer.
By default, the log trap buffer can store a maximum of 1024 traps.
About security log management
Security logs are very important for locating and troubleshooting network problems. Generally, security logs are output together with other logs. It is difficult to identify security logs among all logs.
To solve this problem, you can save security logs to the security log file without affecting the current log output rules.
After you enable the security log file feature, the system processes security logs as follows:
1. Outputs security logs to the security log file buffer.
2. Saves logs from the security log file buffer to the security log file at the specified interval.
If you have the security-audit role, you can also manually save security logs to the security log file.
3. Clears the security log file buffer immediately after the security logs are saved to the security log file.
The device supports only one security log file. The system will overwrite old logs with new logs when the security log file is full. To avoid security log loss, you can set an alarm threshold for the security log file usage ratio. When the alarm threshold is reached, the system outputs a message to inform you of the alarm. You can log in to the device with the security-audit user role and back up the security log file to prevent the loss of important data.
2. Enable the security log file feature.
info-center security-logfile enable
By default, the security log file feature is disabled.
3. Set the interval at which the system saves security logs.
The default security log file saving interval is 86400 seconds.
4. (Optional.) Set the maximum size for the security log file.
The default maximum security log file size is 10 MB.
5. (Optional.) Set the alarm threshold of the security log file usage.
By default, the alarm threshold of the security log file usage ratio is 80. When the usage of the security log file reaches 80%, the system will send a message.
To use the security log file management commands, you must have the security-audit user role. For information about configuring the security-audit user role, see AAA in Security Configuration Guide.
2. Change the directory of the security log file.
By default, the security log file is saved in the seclog directory in the root directory of the storage device.
3. Manually save all logs in the security log file buffer to the security log file.
security-logfile save
4. (Optional.) Display the summary of the security log file.
display security-logfile summary
About diagnostic log saving
By default, the diagnostic log file feature saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file every 24 hours. You can adjust the saving interval or manually save diagnostic logs to the diagnostic log file. After saving diagnostic logs to the diagnostic log file, the system clears the diagnostic log file buffer.
The device supports only one diagnostic log file. The diagnostic log file has a maximum capacity. When the capacity is reached, the system replaces the oldest diagnostic logs with new logs.
2. Enable the diagnostic log file feature.
info-center diagnostic-logfile enable
By default, the diagnostic log file feature is enabled.
3. (Optional.) Set the maximum diagnostic log file size.
By default, the maximum diagnostic log file size is 10 MB.
4. (Optional.) Specify the diagnostic log file directory.
The default diagnostic log file directory is flash:/diagfile.
5. Save diagnostic logs in the diagnostic log file buffer to the diagnostic log file. Choose one option as needed:
¡ Configure the automatic diagnostic log file saving interval.
¡ Manually save diagnostic logs to the diagnostic log file.
diagnostic-logfile save
About setting the maximum size of the trace log file
The device has only one trace log file. When the trace log file is full, the device overwrites the oldest trace logs with new ones.
2. Set the maximum size for the trace log file.
The default maximum size of the trace log file is 1 MB.
Task |
Command |
Display the diagnostic log file configuration. |
display diagnostic-logfile summary |
Display the information of each output destination. |
display info-center |
Display the state and the log information of the log buffer. |
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ] * |
Display summary information of the log buffer. |
display logbuffer summary [ level severity | slot slot-number ] * |
Display the log file configuration. |
display logfile summary |
Display summary information of the security log file . |
display security-logfile summary |
Clear the log buffer. |
reset logbuffer |
Configure the device to output to the console FTP logs that have a minimum severity level of warning.
Figure 2 Network diagram
# Enable the information center.
[Device] info-center enable
# Disable log output to the console.
[Device] info-center source default console deny
To avoid output of unnecessary information, disable all modules from outputting log information to the specified destination (console in this example) before you configure the output rule.
# Configure an output rule to output to the console FTP logs that have a minimum severity level of warning.
[Device] info-center source ftp console level warning
[Device] quit
# Enable the display of logs on the console. (This function is enabled by default.)
<Device> terminal logging level 6
<Device> terminal monitor
Now, if the FTP module generates logs, the information center automatically sends the logs to the console, and the console displays the logs.
Configure the device to output to the UNIX log host FTP logs that have a minimum severity level of informational.
Figure 3 Network diagram
Before the configuration, make sure the device and the log host can reach each other. (Details not shown.)
1. Configure the device:
# Specify log host 1.2.0.1/16 with local4 as the logging facility.
[Device] info-center loghost 1.2.0.1 facility local4
# Disable log output to the log host.
To avoid output of unnecessary information, disable all modules from outputting logs to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to output to the log host FTP logs that have a minimum severity level of informational.
[Device] info-center source ftp loghost level informational
2. Configure the log host:
The following configurations were performed on Solaris. Other UNIX operating systems have similar configurations.
a. Log in to the log host as a root user.
b. Create a subdirectory named Device in directory /var/log/, and then create file info.log in the Device directory to save logs from Device.
# mkdir /var/log/Device
c. Edit file syslog.conf in directory /etc/ and add the following contents.
In this configuration, local4 is the name of the logging facility that the log host uses to receive logs. The value of info indicates the informational severity level. The UNIX system records the log information that has a minimum severity level of informational to file /var/log/Device/info.log.
NOTE: Follow these guidelines while editing file /etc/syslog.conf: · Comments must be on a separate line and must begin with a pound sign (#). · No redundant spaces are allowed after the file name. · The logging facility name and the severity level specified in the /etc/syslog.conf file must be identical to those configured on the device by using the info-center loghost and info-center source commands. Otherwise, the log information might not be output to the log host correctly. |
d. Display the process ID of syslogd, kill the syslogd process, and then restart syslogd by using the –r option to validate the configuration.
# ps -ae | grep syslogd
147
# kill -HUP 147
# syslogd -r &
Now, the device can output FTP logs to the log host, which stores the logs to the specified file.
Configure the device to output to the Linux log host 1.2.0.1/16 FTP logs that have a minimum severity level of informational.
Figure 4 Network diagram
# Specify log host 1.2.0.1/16 with local5 as the logging facility.
[Device] info-center loghost 1.2.0.1 facility local5
To avoid outputting unnecessary information, disable all modules from outputting log information to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to enable output to the log host FTP logs that have a minimum severity level of informational.
b. Create a subdirectory named Device in directory /var/log/, and create file info.log in the Device directory to save logs of Device.
local5.info /var/log/Device/info.log
In this configuration, local5 is the name of the logging facility that the log host uses to receive logs. The value of info indicates the informational severity level. The Linux system will store the log information with a severity level equal to or higher than informational to file /var/log/Device/info.log.
d. Display the process ID of syslogd, kill the syslogd process, and then restart syslogd by using the -r option to validate the configuration.
Make sure the syslogd process is started with the -r option on a Linux log host.
147
# kill -9 147
# syslogd -r &
