01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-SI[LI]&S5120V2-SI[LI]&S5110V2-SI&S5000V3-EI&S5000E-X&S3100V3-SI Command References-R612x-6W10201-Fundamentals Command Reference
00-Preface
00-Preface 81.73 KB
Preface
This command reference describes commands that help you get started with the device. It includes the commands for the following features and tasks:
·          CLI.
·          RBAC, device login, and device access control.
·          Management of the device, file systems, and configuration files.
·          FTP and TFTP.
·          Software upgrade.
·          Tcl and Python.
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
