| 03-Data buffer commands | 49.97 KB |
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to restore the default.
buffer apply
undo buffer apply
For data buffer settings to take effect, you must execute this command after configuring data buffer settings.
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer queue guaranteed
Use buffer queue guaranteed to set the fixed-area ratio for a queue.
Use undo buffer queue guaranteed to delete the fixed-area ratio setting of a queue.
buffer egress [ slot slot-number ] { cell | packet } queue queue-id guaranteed ratio ratio
undo buffer egress [ slot slot-number ] { cell | packet } queue queue-id guaranteed
The cell resource ratio for a queue is 12% of the total cell resources. The packet resource ratio for a queue is 12% of the total packet resources.
egress: Specifies the egress buffer.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command applies to all IRF member devices.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio: Specifies the fixed-area ratio, in percentage. The value range for ratio is 1 to 100.
By default, all queues have an equal share of the fixed area. You can set the fixed-area ratio for a queue. The other queues equally share the remaining part.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of fixed-area ratios configured for all queues cannot exceed the total fixed-area ratio. Otherwise, the configuration fails.
# Configure queue 0 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 guaranteed ratio 20
buffer shared
Use buffer shared to set the maximum shared-area ratio for each port or a queue.
Use undo buffer shared to delete the maximum shared-area ratio setting of each port or a queue.
buffer egress [ slot slot-number ] { cell | packet } [ queue queue-id ] shared ratio ratio
undo buffer egress [ slot slot-number ] { cell | packet } [ queue queue-id ] shared
The maximum packet resource ratio for a port is 10% of the total packet resources.
The maximum cell resource ratio for a port is 10% of the total cell resources.
packet: Specifies packet resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7. If you do not specify a queue, this command sets the maximum shared-area ratio for each port.
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 100.
By default, all ports or queueshave an equal share of the shared area. You can set the shared-area ratio for each port or a queue. The unconfigured queues use the default setting. The shared-area space for each port or queue is finally determined by the chip based on your configuration and the number of packets to be received and sent.
# Configure queue 0 to use up to 10% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 shared ratio 10
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to delete the total shared-area ratio setting.
buffer egress [ slot slot-number ] { cell | packet } total-shared ratio ratio
undo buffer egress [ slot slot-number ] { cell | packet } total-shared
The default setting is 52% for cell resources and is 50% for packet resources.
ratio ratio: Specifies the ratio of the shared area, in percentage. The value range for ratio is 0 to 100.
After you set the shared-area ratio, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 50% space of cell resources in the egress buffer.
[Sysname] buffer egress cell total-shared ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
· Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
· Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
· Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
After the Burst feature is enabled, the following data buffer settings are changed:
· Fixed-area ratio for a queue.
· Shared-area ratio for a queue.
· Total shared-area ratio.
You can display the data buffer setting changes by using the display buffer command.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer size settings for all IRF member devices.
queue queue-id: Specifies a queue by its number in the range of 0 to 7. If you specify a queue, this command displays the fixed-area ratio and shared-area ratio for the specified queue. If you specify the queue keyword without the queue-id argument, this command displays the fixed-area ratio and shared-area ratio for each queue. If you do not specify the queue keyword, this command displays the total shared-area ratio.
# Display buffer size settings.
<Sysname> display buffer
Slot Type Eg(Total-shared , Shared)
1 packet 50 , 10
1 cell 52 , 10
Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
Shared: Size of the maximum shared buffer per port
Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for the queues.
<Sysname> display buffer queue
Slot Queue Type Eg(Guaranteed , Shared)
1 0-7 packet 12 , --
1 0-7 cell 12 , --
Guaranteed: Size of the minimum guaranteed buffer per queue
Shared: Size of the maximum shared buffer per queue
Unit: Ratio
Type |
Resource type: packet or cell. |
Queue |
Queue ID in the range of 0 to 7. |
Eg |
Egress buffer. |
(Total-shared , Shared) |
Total-shared indicates the total shared-area ratio. Shared indicates the shared-area ratio of a port. |
(Guaranteed , Shared) |
Guaranteed indicates the fixed-area ratio of a queue. Shared indicates the shared-area ratio of a queue. If the device does not support a resource type, this field displays two hyphens (--). |
