02-Virtual Technologies Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5560S-EI&S5560S-SI&S5500V3-SI Switch Series Command References-R612x-6W10202-Virtual Technologies Command Reference
00-Preface
00-Preface 81.16 KB
Preface
This command reference describes IRF configuration commands for setting up and maintaining an IRF fabric, including:
·          Commands for IRF port binding configuration.
·          Commands for IRF member ID and priority configuration.
·          Commands for detecting IRF splits and maintaining the IRF fabric.
·          Audience
·          Conventions
·          Documentation feedback
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
