01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-HI[EI]&S5110V2&S3100V3-EI Switch Series Command References-R612x-6W10301-Fundamentals Command Reference
11-Automatic configuration commands
11-Automatic configuration commands 27.62 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
This command is available only in Release 6127 and later.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
