01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-HI[EI]&S5110V2&S3100V3-EI Switch Series Command References-R612x-6W10301-Fundamentals Command Reference
10-Python commands
10-Python commands 36.66 KB
Python commands
exit()
Use exit() to exit the Python shell.
exit()
Python shell
To return to user view from the Python shell, you cannot use the quit command. You must use the exit() command.
# Exit the Python shell.
Python 2.7.3 (default)
[GCC 4.4.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
<Sysname>
python
Use python to enter the Python shell.
python
In the Python shell, you can use the following items:
·          Python 2.7 commands.
·          Python 2.7 standard API.
·          Comware 7 extended API.
# Enter the Python shell.
<Sysname> python
python filename
Use python filename to execute a Python script.
python filename [ param ]
filename: Specifies the name of a Python script on a storage medium of the device. The script name is case sensitive and must use the extension .py. The extension .py is case insensitive.
param: Specifies the parameters to be passed to the script. To enter multiple parameters, use spaces as the delimiter.
You cannot perform any operations while you are executing a Python script.
Make sure the statements in the script meet the syntax requirements. The system stops executing a Python script if it finds a statement with syntax errors.
When executing a script, the system uses the defaults for interactive statements. The system does not stop for human input.
# Execute Python script test.py.
<Sysname> python test.py 1 2
['/flash:/test.py', '1', '2']
