13-Network Management and Monitoring Configuration Guide
HomeSupportNFVH3C VSRConfigure & DeployConfiguration GuidesH3C VSR Series Virtual Services Routers Configuration Guides(V7)-R0618-5W20013-Network Management and Monitoring Configuration Guide
21-VNF connection configuration
21-VNF connection configuration 76.98 KB
Configuring a VNF connection
About VNF
The Network Functions Virtualization (NFV) technology decouples network functions from proprietary hardware appliances so they can run in software on standardized hardware such as x86 servers. The decoupled network functions are called Virtualized Network Functions (VNFs).
VNFM
You can connect VNFs to a VNF Manager (VNFM) and then use the VNFM to configure and manage the VNFs.
Available VNFM versions include VNFM2.0 and Tencent VNFM.
VNF connection modes
A VNF can connect to a VNFM in Layer 2 mode or Layer 3 mode, depending on whether they reside in the same broadcast domain.
·           Layer 2 connection mode—If the VNF and VNFM reside in the same broadcast domain, they communicate by using Ethernet packets. The VNF goes through the following steps to establish and maintain a Layer 2 connection to the VNFM:
a.    The VNF sends a broadcast packet to discover the VNFM.
b.    The VNF registers device information with the VNFM.
c.    The VNF sends keepalive packets to the VNFM to maintain the connection.
·           Layer 3 connection mode—If the VNF and VNFM reside in different broadcast domains, they communicate by using UDP packets. The VNF goes through the following steps to establish and maintain a Layer 3 connection to the VNFM:
d.    The VNF registers device information with the VNFM.
e.    The VNF sends keepalive packets to the VNFM to maintain the connection.
A VNF can connect to a VNFM in only one mode at the same time. The available connection modes depend on the VNFM. VNFM2.0 supports only Layer 2 mode. Tencent VNFM supports only Layer 3 mode.
Application scenarios in IRF mode
VNFM provides the following typical application scenarios in IRF mode: VSG, VSG-NAT (NAT-capable VSG), and VSG-vPCpeer. You can also customize your own application scenarios by configuring the configuration commands required for the scenarios on the VNFM.
To use a VNF in a typical or customized application scenario, you only need to select the application scenario and set the relevant parameters. The VNFM will send the required configuration commands to the VNF to configure the VNF.
The application scenarios described in this section are available only in Layer 3 connection mode.
VNF connection configuration tasks at a glance
To configure a VNF connection, perform the following tasks:
1.      Configuring a VNF connection:
?  Configuring a Layer 2 VNF connection
?  Configuring a Layer 3 VNF connection
2.      (Optional.) Specifying the application scenario and setting the relevant parameters
1.      Enter system view.
2.      Configure a Layer 2 VNF connection.
vnfm interface interface-type interface-number
By default, no Layer 2 connection exists between a VNF and a VNFM.
2.      Configure a Layer 3 VNF connection.
In standalone mode:
vnfm ip-address [ udp-port udp-number ] [ source-ip ip-address ] [ vpn-instance vpn-instance-name ]
In IRF mode:
vnfm ip-address [ udp-port udp-number ] [ source-ip ip-address ] [ vpn-instance vpn-instance-name ] [ slot slot-number ]
By default, no Layer 3 connection exists between a VNF and a VNFM.
You can perform this task only if you are configuring VNFs in IRF mode to establish a Layer 3 connection to the VNFM.
2.      Specify the application scenario and set the relevant parameters.
Choose one of the following commands:
?  vnf cluster-mode [ vsg | vsg-nat ] cluster-ip ip-address tunnel unnumbered interface interface-type interface-number
?  vnf cluster-mode vsg-vpcpeer cluster-id string tunnel unnumbered interface interface-type interface-number vsg-ip ip-address [ backup ]
?  vnf cluster-mode string parameter string
By default, no application scenario-related parameters are set.
Display and maintenance commands for VNF connection configuration
Display VNF connection information.
In standalone mode:
display vnfm information
In IRF mode:
display vnfm information [ slot slot-number ]
VNF connection configuration examples
Example: Configuring a VNF connection in Layer 3 mode
As shown in Figure 1, a VNF is running on the device. The VNFM is installed on a server. The VNF and the VNFM resides on different IP networks.
Configure a Layer 3 connection between the VNF and VNFM.
Figure 1 Network diagram
# Assign IP addresses to interfaces and configure routes. Make sure the network connections are available. (Details not shown.)
# On the device, configure a Layer 3 VNF connection to the VNFM.
[Device] vnfm 192.168.1.100
# Set the application scenario to VSG and set the relevant parameters.
[Device] vnf cluster-mode vsg cluster-ip 10.2.0.1 tunnel unnumbered interface LoopBack 0
# Display VNF connection information.
<Device> display vnfm information
Slot 0 :Current connect status: ONLINE
  Connect mode: L3
  VNFM IP: 192.168.1.100
  UDP port: 2093
  Cluster mode: VSG
  Cluster IP: 10.2.0.1
  Borrowed interface: LoopBack0
// The output shows that a Layer 3 connection is already established between the VNF and VNFM.
Example: Configuring a VNF connection in Layer 2 mode
As shown in Figure 2, a VNF is running on the device. The VNFM is installed on a server. The VNF and the VNFM resides in the same broadcast domain.
Configure a Layer 2 connection between the VNF and VNFM.
Figure 2 Network diagram
# Connect the device and VNFM to the Ethernet network. Make sure the Ethernet connections are available. (Details not shown.)
# On the device, configure a Layer 2 VNF connection to the VNFM. Specify GigabitEthernet 1/0 as the source interface.
[Device] vnfm interface GigabitEthernet 1/0
  Connect mode: L2
  Connect VNFM interface: GigabitEthernet1/0
  VNFM MAC: ffff-ffff-ffff
// The output shows that a Layer 2 connection is already established between the VNF and VNFM.
