- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Device management configuration
- 10-Tcl configuration
- 11-Python configuration
- 12-License management
| 12-License management | 76.04 KB |
Licenses for different device types
Restrictions and guidelines: License management
Activation file and DID file operations·
License consistency in an IRF fabric
License management tasks at a glance
Identifying the license storage
Compressing the license storage
Obtaining required information for license register
Restrictions and guidelines for license installation
Restrictions and guidelines for license uninstallation
Uninstalling an activation file
Uninstalling an activation key
Display and maintenance commands for license management
Managing licenses
About licenses
License-based features, , require a license to run on your device.
License types
(In standalone mode.) You must purchase a license key for the entire device. To license the device, use the license key and the device's SN and DID to register an activation file and install the activation file on the device.
(In IRF mode.) You must purchase a license key for each IRF member device. To license an IRF member device, use the license key and the member's SN and DID to register an activation file and install the activation file on the IRF member device. An IRF member device is licensed even if the device joins another IRF fabric.
License operations
Make sure no one else is performing license management tasks on the device you are working with.
When you manage DID files or activation files, follow these restrictions and guidelines:
· Do not open and edit the files to avoid file corruption.
· Do not modify the names of the files to avoid licensing error.
· For licensed features to function correctly, do not delete files that are usable or in use in the flash:/license directory. The license management feature uses this directory for license management.
(In IRF mode.) For licensed features to function correctly in an IRF fabric, make sure all IRF member devices are installed with the same licenses.
To manage licenses, perform the following tasks:
1. Identifying the license storage
2. (Optional.) Compressing the license storage
3. Obtaining required information for license register
6. Managing installed licenses
? Recovering an activation file
7. (Optional.) Installing a license key
8. (Optional.) Uninstalling a license key
To identify the license storage, execute the following command in any view:
display license feature
From the command output, view the Total and Usage fields to examine whether the remaining license storage is sufficient for installing new licenses. If the remaining license storage is not sufficient, compress the license storage.
About license storage compression
Compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
The DID changes each time the license storage is compressed. Licenses generated based on the old DID cannot be installed after the compression.
1. Back up the Uninstall keys of uninstalled licenses.
When you uninstall an unexpired license, an Uninstall key is created. The Uninstall key is required for transferring the license.
2. Make sure all licenses generated based on the old DID have been installed.
3. Enter system view.
4. Compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress slot slot-number
1. (Optional.) Identify features to be licensed by using the display license feature command.
2. Obtain the following information:
? License key, which is obtained by purchasing the license.
? SN and DID information, which can be obtained by using the display license device-id command.
3. Use FTP or TFTP to upload the file to the Web client, such as PC.
If FTP is used to transfer the .id file, use the Binary mode.
4. Back up the license key, SN, and DID information in case of loss.
Registering a license
If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors, contact H3C Support.
1. Access http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/, and select Register the First Time or Register Upgrade Licenses from the navigation tree.
Upgrade licenses are used for add-on nodes, add-on features, or time extensions.
2. Select the product category and use the license key, SN, and DID to register the license.
3. Obtain the activation file or activation key and download it to the PC.
When installing a license, the system automatically searches the storage media for a matching feature package. When a match is found, it stops searching and installs the package.
Installing an activation file
1. Enter system view.
2. Install an activation file.
In standalone mode:
license activation-file install license-file
In IRF mode:
license activation-file install license-file slot slot-number
Installing an activation key
2. Install an activation key.
In standalone mode:
license activation-key install activation-key-string
In IRF mode:
license activation-key install activation-key-string slot slot-number
About license uninstallation
Perform this task to uninstall an unexpired formal license when the license remains unused for a while or needs to be transferred to another device.
After uninstallation, Uninstall keys are generated, which will be used for license transfer.
Trial licenses cannot be transferred. Uninstall a trial license does not create any uninstallation information.
Expired licenses cannot be uninstalled.
A license that was uninstalled on a device cannot be re-installed on the device. It can only be transferred to another device.
2. Uninstall an activation file.
In standalone mode:
license activation-file uninstall license-file
In IRF mode:
license activation-file uninstall license-file slot slot-number
Only unexpired activation files can be uninstalled.
2. Uninstall an activation key.
In standalone mode:
license activation-key uninstall activation-key-string
In IRF mode:
license activation-key uninstall activation-key-string slot slot-number
Only unexpired activation keys can be uninstalled.
Transferring a license
About license transfer
You can transfer a license from one device to another if the license has not expired.
1. Log in to the source device, and uninstall the license to obtain the uninstallation information. For more information, see "Uninstalling a license."
2. Obtain the Uninstall key of the license by using the display license command.
3. Access the target device and obtain SN and DID information. For more information, see "Obtaining required information for license register."
4. Register a license for the target device. For more information, see "Registering a license."
During the license register, you must provide SN and DID information of the target device and the Uninstall key of the source device.
5. Install the new license on the target device. For more information, see "Installing a license."
If you mistakenly delete an activation file, use the following procedure to recover the activation file:
1. Use the copy command to copy the backup activation file to directory flash:/license.
2. Use the display license command to verify that the state of the recovered activation file is In use.
3. Restart the device if the license state is In use but the licensed feature cannot function correctly.
1. Use the display license feature command to identify features to be licensed.
2. Identify the license key on your license.
4. Install the license key.
In standalone mode:
license license-key install license-key-string
In IRF mode:
license license-key install license-key-string slot slot-number
About license key uninstallation
To disable the device to run a license-based feature, uninstall the feature license key.
2. Uninstall a license key.
In standalone mode:
license license-key uninstall license-key-string
In IRF mode:
license license-key uninstall license-key-string slot slot-number
Only unexpired license keys can be uninstalled.
Task |
Command |
Display detailed license information. |
In standalone mode: display license [ activation-file | activation-key | license-key ] In IRF mode: display license [ activation-file | activation-key | license-key ] [ slot slot-number ] |
Display the SN and DID information. |
In standalone mode: display license device-id In IRF mode: display license device-id slot slot-number |
Display brief feature license information. |
display license feature |
