- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Device management configuration
- 10-Tcl configuration
- 11-Python configuration
- 12-License management
| 07-Software upgrade configuration | 79.11 KB |
Upgrading device software by using the boot loader method (in standalone mode)
Specifying startup images and completing the upgrade
Upgrading device software by using the boot loader method (in IRF mode)
Display and maintenance commands for software images
Upgrading software
About software upgrade
Software upgrade enables you to upgrade a software version, add new features, and fix software bugs. This chapter describes software types and release forms, compares software upgrade methods, and provides the procedures for upgrading software from the CLI.
Software types
The following software types are available:
· BootWare image—Also called the Boot ROM image. This image contains a basic segment and an extended segment.
¡ The basic segment is the minimum code that bootstraps the system.
¡ The extended segment enables hardware initialization and provides system management menus. When the device cannot start up correctly, you can use the menus to load software and the startup configuration file or manage files.
Typically, the BootWare image is integrated into the Boot image to avoid software compatibility errors.
· Comware image—Includes the following image subcategories:
¡ Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡ System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡ Feature image—A .bin file that contains advanced or customized software features. You can purchase feature images as needed.
¡ Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
Patch images have the following types:
- Incremental patch images—Multiple incremental patch images can coexist on the device at the same time. A new patch image can cover all, part, or none of the functions provided by an old patch image.
- Non-incremental patch images—Only one non-incremental patch image can coexist on the device. The device uninstalls the old non-incremental patch image before installing a new non-incremental patch image. A new non-incremental patch image covers all functions provided by an old non-incremental patch image.
An incremental patch image and a non-incremental patch image can coexist on the device.
Comware images that have been loaded are called current software images. Comware images specified to load at the next startup are called startup software images.
BootWare image, boot image, and system image are required for the device to operate.
Software release forms
Software images are released in one of the following forms:
· Separate .bin files. You must verify compatibility between software images.
· As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
NOTE: Software image file names use the model-comware version-image type-release format. This document uses boot.bin and system.bin as boot and system image file names. |
Upgrade methods
Upgrade method |
Software types |
Remarks |
Upgrading from the CLI by using the boot loader method |
· BootWare image · Comware images (excluding incremental patches) |
This method is disruptive. You must reboot the entire device to complete the upgrade. |
Upgrading from the BootWare menu |
· BootWare image · Comware images |
Use this method when the device cannot start up correctly. To use this method, first connect to the console port and power cycle the device. Then, press Ctrl+B at prompt to access the BootWare menu. For more information about upgrading software from the BootWare menu, see the release notes for the software version.
Use this method only when you do not have any other choice. |
This chapter covers only upgrading software from the CLI by using the boot loader method.
Software image loading
Startup software images
To upgrade software, you must specify the upgrade files as the startup software images for the device to load at next startup. You can specify two lists of software images: one main and one backup. The device first loads the main startup software images. If the main startup software images are not available, the device loads the backup startup software images.
Image loading process at startup
At startup, the device performs the following operations after loading and initializing BootWare:
1. Loads main images.
2. If any main image does not exist or is invalid, loads the backup images.
3. If any backup image does not exist or is invalid, checks the main or backup boot image.
4. If both the main and backup boot images do not exist or are invalid, the device cannot start up.
1. Use the display version command to verify the current BootWare image version and startup software version.
2. Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡ Software and hardware compatibility.
¡ Version and size of the upgrade software.
¡ Compatibility of the upgrade software with the current BootWare image and startup software image.
3. Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image. For more information about licensing, see "Managing licenses."
4. Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing file systems."
5. Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system. For more information about FTP and TFTP, see "Configuring FTP" or "Configuring TFTP." For more information about file systems, see "Managing file systems."
Perform the following steps in user view:
1. Specify main or backup startup images.
¡ Use an .ipe file:
boot-loader file ipe-filename { backup | main }
¡ Use .bin files:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { backup | main }
2. Save the running configuration.
save
This step ensures that any configuration you have made can survive a reboot.
3. Reboot the device.
reboot
4. (Optional.) Verify the software image settings.
display boot-loader
Verify that the current software images are the same as the startup software images.
4. Use the dir command to verify that all IRF member devices have sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing file systems."
1. Specify main or backup startup images for all member devices.
¡ Use an .ipe file:
boot-loader file ipe-filename { all | slot slot-number } { backup | main }
¡ Use .bin files:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { all | slot slot-number } { backup | main }
As a best practice in a multichassis IRF fabric, specify the all keyword for the command. If you use the slot slot-number option to upgrade member devices one by one, version inconsistencies occur among the member devices during the upgrade.
save
3. Reboot the IRF fabric.
reboot
display boot-loader [ slot slot-number ]
Task |
Command |
Display current software images and startup software images. |
In standalone mode: display boot-loader In IRF mode: display boot-loader [ slot slot-number ] |
Software upgrade examples
Example: Upgrading device software (in standalone mode)
As shown in Figure 1, use the file startup-a2105.ipe to upgrade software images for the device.
# Configure IP addresses and routes. Make sure the device and the TFTP server can reach each other. (Details not shown.)
# Configure TFTP settings on both the device and the TFTP server. (Details not shown.)
# Display information about the current software images.
<Sysname> display version
# Back up the current software images.
<Sysname> copy boot.bin boot_backup.bin
<Sysname> copy system.bin system_backup.bin
# Specify boot_backup.bin and system_backup.bin as the backup startup image files.
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin backup
# Use TFTP to download the startup-a2105.ipe image file from the TFTP server to the root directory of the flash memory.
<Sysname> tftp 2.2.2.2 get startup-a2105.ipe
# Specify startup-a2105.ipe as the main startup image file.
<Sysname> boot-loader file flash:/startup-a2105.ipe main
# Verify the startup image settings.
<Sysname> display boot-loader
# Reboot the device to complete the upgrade.
<Sysname> reboot
# Verify that the device is running the correct software.
Example: Upgrading device software (in IRF mode)
As shown in Figure 2, use the file startup-a2105.ipe to upgrade software images for the IRF fabric.
# Specify boot_backup.bin and system_backup.bin as the backup startup image files for all IRF member devices.
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin slot 1 backup
<Sysname> boot-loader file boot flash:/boot_backup.bin system flash:/system_backup.bin slot 2 backup
# Use TFTP to download the startup-a2105.ipe image file from the TFTP server to the root directory of the flash memory on the master device.
# Specify startup-a2105.ipe as the main startup image file for all IRF member devices.
<Sysname> boot-loader file flash:/startup-a2105.ipe slot 1 main
<Sysname> boot-loader file flash:/startup-a2105.ipe slot 2 main
<Sysname> reboot
