| 04-H3C_Software_Patching_Examples | 75.98 KB |
H3C Software Patching Examples |
Software version: Release 7577P04
Document version: 6W100-20190330
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides software patching examples that use ISSU install commands.
This document assumes that you have basic knowledge of ISSU.
Example: Patching software in standalone mode
As shown in Figure 1, the device and the TFTP server can reach each other. The device has one active MPU (slot 0) and one standby MPU (slot 1). The MPUs are running boot image BOOT-R7577P01 and system image SYSTEM-R7577P01.
Use patch image file SYSTEM-R7577P01H01.bin to fix bugs without rebooting the device.
When you patch software, follow these restrictions and guidelines:
· The first time you install patch images, you must start with the active MPU. For subsequent patch installations, you must start with the standby MPU.
· The patch image version must match the device model and Comware version. For example, to fix bugs in R7577P01, you must use SYSTEM-R7577P01H01.bin.
Procedures
# Download patch image file SYSTEM-R7577P01H01.bin from the TFTP server to the root directory of the CF card on the active MPU.
<Sysname> tftp 2.2.2.2 get SYSTEM-R7577P01H01.bin
Press CTRL+C to abort.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 25.2M 0 25.2M 0 0 210k 0 --:--:-- 0:02:02 --:--:-- 209k
# Activate the patch images on the active MPU and standby MPU.
<Sysname> install activate patch flash:/SYSTEM-R7577P01H01.bin slot 0
This operation maybe take several minutes, please wait.............Done.
<Sysname> install activate patch flash:/SYSTEM-R7577P01H01.bin slot 1
The patch images take effect immediately after they are activated.
# For the patch images to take effect after a reboot, commit the software changes.
<Sysname> install commit
# Verify that the patch images have been activated successfully.
<Sysname> display install active
Active packages on slot 0:
flash:/BOOT-R7577P01.bin
flash:/SYSTEM-R7577P01.bin
Active packages on slot 1:
Active packages on slot 3:
Active packages on slot 14:
# Verify that the patch image file has been added to the main startup software image list so the images can take effect after a reboot.
<Sysname> display install committed
Committed packages on slot 0:
Committed packages on slot 1:
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
Example: Patching software in IRF mode
As shown in Figure 2, the two-chassis IRF fabric and the TFTP server can reach each other. Each member of the IRF fabric has one active MPU (slot 0) and one standby MPU (slot 1). The IRF members are running boot image BOOT-R7577P01 and system image SYSTEM-R7577P01.
Use patch image file SYSTEM-R7577P01H01.bin to fix bugs without rebooting the members.
When you patch software on an IRF fabric, follow these restrictions and guidelines:
· To install an image, you must begin with the master. On each member device, you must begin with the active MPU. To upgrade an image, you must begin with a subordinate device. On each member device, you must begin with the standby MPU.
Procedures
# Download patch image file SYSTEM-R7577P01H01.bin from the TFTP server to the root directory of the CF card on the global active MPU.
# Activate the patch images on the global active MPU and global standby MPUs.
<Sysname> install activate patch flash:/SYSTEM-R7577P01H01.bin chassis 2 slot 1
<Sysname> install activate patch flash:/SYSTEM-R7577P01H01.bin chassis 2 slot 0
<Sysname> install activate patch flash:/SYSTEM-R7577P01H01.bin chassis 1 slot 1
<Sysname> install activate patch flash:/SYSTEM-R7577P01H01.bin chassis 1 slot 0
Active packages on chassis 1 slot 0:
Active packages on chassis 1 slot 1:
Active packages on chassis 1 slot 3:
Active packages on chassis 1 slot 14:
Active packages on chassis 2 slot 0:
Active packages on chassis 2 slot 1:
Active packages on chassis 2 slot 3:
Active packages on chassis 2 slot 14:
Committed packages on chassis 1 slot 0:
Committed packages on chassis 1 slot 1:
Committed packages on chassis 2 slot 0:
Committed packages on chassis 2 slot 1:
Configuration files
Related documentation
· H3C S7500E Switch Series Fundamentals Command Reference-R757X
· H3C S7500E Switch Series Fundamentals Configuration Guide-R757X
