05-ACL and QoS Command Reference
HomeSupportWirelessWX3000E Series Wireless SwitchesReference GuidesCommand ReferencesH3C WX3000E Series Wireless Switches Switching Engine Command References(R3507P26)-6W10205-ACL and QoS Command Reference
01-ACL Commands
01-ACL Commands 218.81 KB
The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
The WX3000E series comprises WX3024E and WX3010E wireless switches.
The port numbers in this chapter are for illustration only.
acl
acl number acl-number [ name acl-name ] [ match-order { auto | config } ]
undo acl { all | name acl-name | number acl-number }
View
Default level
2: System level
number acl-number: Specifies the number of an IPv4 access control list (ACL):
·           2000 to 2999 for IPv4 basic ACLs
·           3000 to 3999 for IPv4 advanced ACLs
·           4000 to 4999 for Ethernet frame header ACLs
name acl-name: Assigns a name for the IPv4 ACL for easy identification. The acl-name argument takes a case insensitive string of 1 to 32 characters. It must start with an English letter, and to avoid confusion, cannot be all.
match-order: Sets the order in which ACL rules are compared against packets:
·           auto—Compares ACL rules in depth-first order. The depth-first order differs with ACL categories. For more information, see the ACL and QoS Configuration Guide.
·           config—Compares ACL rules in ascending order of rule ID. The rule with a smaller ID has higher priority. If no match order is specified, the config order applies by default.
all: Deletes all IPv4 ACLs.
Use the acl command to create an IPv4 ACL and enter its view. If the ACL has been created, you enter its view directly.
Use the undo acl command to delete the specified IPv4 ACL or all IPv4 ACLs.
By default, no ACL exists.
You can assign a name for an IPv4 ACL only when you create it. After an ACL is created with a name, you cannot rename it or remove its name.
You can change match order only for ACLs that do not contain any rules.
To display any ACLs you have created, use the display acl command.
# Create IPv4 basic ACL 2000, and enter its view.
[Sysname] acl number 2000
[Sysname-acl-basic-2000]
# Create IPv4 basic ACL 2001 with the name flow, and enter its view.
[Sysname] acl number 2001 name flow
[Sysname-acl-basic-2001-flow]
acl copy
acl copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
View
Default level
2: System level
source-acl-number: Specifies a source IPv4 ACL that already exists by its number:
name source-acl-name: Specifies a source IPv4 ACL that already exists by its name. The source-acl-name argument takes a case insensitive string of 1 to 32 characters.
dest-acl-number: Assigns a unique number for the IPv4 ACL you are creating. This number must be from the same ACL category as the source ACL. Available value ranges include:
name dest-acl-name: Assigns a unique name for the IPv4 ACL you are creating. The dest-acl-name takes a case insensitive string of 1 to 32 characters. It must start with an English letter and to avoid confusion, cannot be all. For this ACL, the system automatically picks the smallest number from all available numbers in the same ACL category as the source ACL..
Use the acl copy command to create an IPv4 ACL by copying an IPv4 ACL that already exists. The new ACL has the same properties and content as the source ACL, but not the same ACL number and name.
You can assign a name for an IPv4 ACL only when you create it. After an IPv4 ACL is created with a name, you cannot rename it or remove its name.
# Create IPv4 basic ACL 2002 by copying IPv4 basic ACL 2001.
[Sysname] acl copy 2001 to 2002
acl ipv6
acl ipv6 number acl6-number [ name acl6-name ] [ match-order { auto | config } ]
undo acl ipv6 { all | name acl6-name | number acl6-number }
View
Default level
2: System level
number acl6-number: Specifies the number of an IPv6 ACL:
·           2000 to 2999 for IPv6 basic ACLs
·           3000 to 3999 for IPv6 advanced ACLs
name acl6-name: Assigns a name for the IPv6 ACL for easy identification. The acl6-name argument takes a case insensitive string of 1 to 32 characters. It must start with an English letter, and to avoid confusion, cannot be all.
all: Delete all IPv6 ACLs.
Use the acl ipv6 command to create an IPv6 ACL and enter its ACL view. If the ACL has been created, you enter its view directly.
Use the undo acl ipv6 command to delete the specified IPv6 ACL or all IPv6 ACLs.
You can assign a name for an IPv6 ACL only when you create it. After an IPv6 ACL is created, you cannot rename it or remove its name.
To display any ACLs you have created, use the display acl ipv6 command.
# Create IPv6 ACL 2000 and enter its view.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000]
# Create IPv6 basic ACL 2001 with the name flow, and enter its view.
[Sysname] acl ipv6 number 2001 name flow
[Sysname-acl6-basic-2001-flow]
acl ipv6 copy
acl ipv6 copy { source-acl6-number | name source-acl6-name } to { dest-acl6-number | name dest-acl6-name }
View
Default level
2: System level
source-acl6-number: Specifies a source IPv6 ACL that already exists by its number:
name source-acl6-name: Specifies a source IPv6 ACL that already exists by its name. The source-acl6-name argument takes a case insensitive string of 1 to 32 characters.
dest-acl6-number: Assigns a unique number for the IPv6 ACL you are creating. This number must be from the same ACL category as the source ACL. Available value ranges include:
name dest-acl6-name: Assigns a unique name for the IPv6 ACL you are creating. The dest-acl6-name takes a case insensitive string of 1 to 32 characters. It must start with an English letter and to avoid confusion, cannot be all. For this ACL, the system automatically picks the smallest number from all available numbers in the same ACL category as the source ACL.
Use the acl ipv6 copy command to create an IPv6 ACL by copying an IPv6 ACL that already exists. The new ACL has the same properties and content as the source ACL, but not the same ACL number and name.
You can assign a name for an IPv6 ACL only when you create it. After an ACL is created with a name, you cannot rename it or remove its name.
# Create IPv6 basic ACL 2002 by copying IPv6 basic ACL 2001.
[Sysname] acl ipv6 copy 2001 to 2002
acl ipv6 name
acl ipv6 name acl6-name
View
Default level
2: System level
acl6-name: Specifies the name of an existing IPv6 ACL, a case insensitive string of 1 to 32 characters. It must start with an English letter.
Use the acl ipv6 name command to enter the view of an IPv6 ACL that has a name.
Related commands: acl ipv6.
# Enter the view of IPv6 ACL flow.
[Sysname] acl ipv6 name flow
acl name
acl name acl-name
View
Default level
2: System level
acl-name: Specifies the name of an existing IPv4 ACL, which is a case insensitive string of 1 to 32 characters. It must start with an English letter.
Use the acl name command to enter the view of an IPv4 ACL that has a name.
Related commands: acl.
# Enter the view of IPv4 ACL flow.
[Sysname] acl name flow
description
View
IPv4 basic/advanced ACL view, IPv6 basic/advanced ACL view, Ethernet frame header ACL view
Default level
2: System level
text: ACL description, a case sensitive string of 1 to 127 characters.
Use the description command to configure a description for an ACL.
Use the undo description command to remove the ACL description.
By default, an ACL has no ACL description.
Related commands: display acl and display acl ipv6.
# Configure a description for IPv4 basic ACL 2000.
[Sysname-acl-basic-2000] description This is an IPv4 basic ACL.
# Configure a description for IPv6 basic ACL 2000.
[Sysname-acl6-basic-2000] description This is an IPv6 basic ACL.
display acl
display acl { acl-number | all | name acl-name } [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl-number: Specifies an IPv4 ACL by its number:
·           2000 to 2999 for basic ACLs
·           3000 to 3999 for advanced ACLs
all: Displays information for all IPv4 ACLs.
name acl-name: Specifies an IPv4 ACL by its name. The acl-name argument takes a case insensitive string of 1 to 32 characters. It must start with an English letter.
slot slot-number: Displays the match statistics for IPv4 ACLs on a card. The slot-number argument represents the slot number of the card, and can only be 1.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
Use the display acl command to display configuration and match statistics for the specified or all IPv4 ACLs.
This command displays ACL rules in config or depth-first order, whichever is configured.
# Display the configuration and match statistics for all IPv4 ACLs.
<Sysname> display acl all
Basic ACL  2000, named flow, 2 rules,
ACL's step is 5
 rule 0 permit
 rule 5 permit source 1.1.1.1 0 (5 times matched)
Basic ACL  2001, named -none-, 3 rules, match-order is auto,
ACL's step is 5
 rule 10 permit source 192.168.1.0 0.0.0.255
 rule 10 comment This rule is used in VLAN 2.
 rule 5 permit source 2.2.2.2 0
 rule 0 permit
Table 1 Output description
Basic ACL  2000
Category and number of the ACL. The following field information is about IPv4 basic ACL 2000.
named flow
The name of the ACL is flow. "-none-" means the ACL is not named.
2 rules
The ACL contains two rules.
match-order is auto
The match order for the ACL is auto, which sorts ACL rules in depth-first order. This field is not present when the match order is config.
ACL's step is 5
The rule numbering step is 5.
rule 0 permit
Content of rule 0
5 times matched
There have been five matches for the rule. The statistic counts only ACL matches performed in software.
This field is not displayed when no packets have matched the rule.
The description of ACL rule 10 is "This rule is used in VLAN 2."
display acl ipv6
display acl ipv6 { acl6-number | all | name acl6-name } [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl6-number: Specifies an IPv6 ACL by its number:
all: Displays information for all IPv6 ACLs.
name acl6-name: Specifies an IPv6 ACL by its name. The acl6-name argument takes a case insensitive string of 1 to 32 characters. It must start with an English letter.
slot slot-number: Displays the match statistics for IPv6 ACLs on a card. The slot-number argument represents the slot number of the card, and can only be 1.
Use the display acl ipv6 command to display the configuration and match statistics for the specified IPv6 ACL or all IPv6 ACLs.
# Display the configuration and match statistics for all IPv6 ACLs.
<Sysname> display acl ipv6 all
 Basic IPv6 ACL  2000, named flow, 3 rules,
 ACL's step is 5
 rule 0 permit
 rule 5 permit source 1::/64
 rule 10 permit source 1::1/128 (5 times matched)
 Basic IPv6 ACL  2001, named -none-, 3 rules, match-order is auto,
 ACL's step is 5
 rule 10 comment This rule is used on GE 1/0/1.
 rule 0 permit
Table 2 Output description
Basic IPv6 ACL  2000
Category and number of the ACL. The following field information is about this IPv6 basic ACL 2000.
named flow
3 rules
The ACL contains three rules.
match-order is auto
ACL's step is 5
rule 0 permit
Content of rule 0
5 times matched
There have been five matches for the rule. The statistic counts only IPv6 ACL matches performed by software.
The description of ACL rule 10 is "This rule is used on GE 1/0/1."
display acl resource
display acl resource [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the usage of ACL rules on a card. The slot-number argument represents the slot number of the card, and can only be 1.  If no slot number is specified, the usage of ACL rules on the main board is displayed.
Use the display acl resource command to display the usage of ACL rules.
If a card does not support counting for ACL rules, the command displays only the slot number of the card.
# Display the usage of ACL rules on a distributed device.
<Sysname> display acl resource
 GE1/0/1..GE1/0/30
 XGE1/1/1 XGE1/1/1
  Type       Total   Reserved  Configured  Remaining
  ACL        1024    388       0           636
  Meter      64      0         0           64
Table 3 Output description
Interface that uses the ACL resource, for example, the interface GE 1/0/1.
Resource type:
ACLACL rule resource
MeterTraffic policing rule resource
Total
Total number of ACL rules supported
Reserved
Number of reserved ACL rules
Configured
Number of ACL rules that have been applied
Remaining
Number of ACL rules that you can apply
display packet-filter
display packet-filter { { all | interface interface-type interface-number } [ inbound ] | interface vlan-interface vlan-interface-number [ inbound ] [ slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Specifies all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. VLAN interfaces are not supported.
inbound: Specifies the inbound direction.
interface vlan-interface vlan-interface-number: Specifies a VLAN interface by its number.
slot slot-number: Specifies a card by its slot number. The slot-number argument represents the slot number of the card, and can only be 1. If no slot number is specified, the command displays application information of ACLs for packet filtering on VLAN interfaces of the device.
Use the display packet-filter command to display whether an ACL has been successfully applied to an interface for packet filtering.
# Display the application status of incoming and outgoing packet filtering ACLs for interface GigabitEthernet 1/0/1.
<Sysname> display packet-filter interface gigabitethernet 1/0/1
  In-bound Policy:
    acl 2001, Successful
Table 4 Output description
Interface to which the ACL applies
In-bound Policy
The ACL used for filtering incoming traffic on the interface
IPv4 ACL 2001 has been applied to the interface
display time-range
display time-range { time-range-name | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
time-range-name: Specifies a time range name, which is a case insensitive string of 1 to 32 characters. It must start with an English letter.
all: Displays the configuration and status of all existing time ranges.
Use the display time-range command to display the configuration and status of the specified time range or all time ranges.
# Display the configuration and status of time range t4.
<Sysname> display time-range t4
Current time is 17:12:34 4/13/2010 Tuesday
Time-range : t4 ( Inactive )
 10:00 to 12:00 Mon
 14:00 to 16:00 Wed
 from 00:00 1/1/2010 to 23:59 1/31/2010
 from 00:00 6/1/2010 to 23:59 6/30/2010
Table 5 Output description
Current time
Current system time
Time-range
Configuration and status of the time range, including its name, status (active or inactive), and start time and end time.
packet-filter
packet-filter { acl-number | name acl-name } inbound
undo packet-filter { acl-number | name acl-name } inbound
View
Interface view
Default level
2: System level
inbound: Filters incoming packets.
Use the packet-filter command to apply an IPv4 basic, IPv4 advanced or Ethernet frame header to an interface to filter packets.
Use the undo packet-filter command to restore the default.
By default, an interface does not filter packets.
Related commands: display packet-filter.
·           On a centralized device
# Apply IPv4 ACL 2001 to filter incoming traffic on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] packet-filter 2001 inbound
packet-filter ipv6
packet-filter ipv6 { acl6-number | name acl6-name } inbound
undo packet-filter ipv6 { acl6-number | name acl6-name } inbound
View
Interface view
Default level
2: System level
inbound: Filters incoming IPv6 packets
Use the packet-filter ipv6 command to apply an IPv6 basic or IPv6 advanced ACL to an interface to filter IPv6 packets.
Use the undo packet-filter ipv6 command to restore the default.
By default, an interface does not filter IPv6 packets.
Related commands: display packet-filter ipv6.
# Apply IPv6 ACL 2500 to filter incoming packets on GigabitEthernet 1/0/1.
[Sysname] interface gigabitethernet1/0/1
[Sysname-GigabitEthernet1/0/1] packet-filter ipv6 2500 inbound
reset acl counter
reset acl counter { acl-number | all | name acl-name }
View
Default level
2: System level
all: Clears statistics for all IPv4 ACLs.
Use the reset acl counter command to clear statistics for the specified IPv4 ACL or all IPv4 ACLs.
Related commands: display acl.
# Clear statistics for IPv4 basic ACL 2001.
# Clear statistics for IPv4 ACL flow.
<Sysname> reset acl counter name flow
reset acl ipv6 counter
reset acl ipv6 counter { acl6-number | all | name acl6-name }
View
Default level
2: System level
all: Clears statistics for all IPv6 basic and advanced ACLs.
Use the reset acl ipv6 counter command to clear statistics for the specified IPv6 ACL or all IPv6 basic and IPv6 advanced ACLs.
Related commands: display acl ipv6.
# Clear statistics for IPv6 basic ACL 2001.
<Sysname> reset acl ipv6 counter 2001
# Clear statistics for IPv6 ACL flow.
<Sysname> reset acl ipv6 counter name flow
rule (Ethernet frame header ACL view)
rule [ rule-id ] { deny | permit } [ cos vlan-pri | dest-mac dest-addr dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac sour-addr source-mask | time-range time-range-name ] *
undo rule rule-id [ fragment | time-range ]*
View
Default level
2: System level
rule-id: Specifies a rule ID, which ranges from 0 to 65534. If no rule ID is provided when you create an ACL rule, the system automatically assigns it a rule ID. This rule ID takes the nearest higher multiple of the numbering step to the current highest rule ID, starting from 0. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the rule is numbered 30.
deny: Denies matching packets.
permit: Allows matching packets to pass.
cos vlan-pri: Matches an 802.1p priority. The vlan-pri argument can be a number in the range 0 to 7, or in words, best-effort (0), background (1), spare (2), excellent-effort (3), controlled-load (4), video (5), voice (6), or network-management (7).
dest-mac dest-addr dest-mask: Matches a destination MAC address range. The dest-addr and dest-mask arguments represent a destination MAC address and mask in H-H-H format.
lsap lsap-type lsap-type-mask: Matches the DSAP and SSAP fields in LLC encapsulation. The lsap-type argument is a 16-bit hexadecimal number that represents the encapsulation format. The lsap-type-mask argument is a 16-bit hexadecimal number that represents the LSAP mask.
type protocol-type protocol-type-mask: Matches one or more protocols in the Ethernet frame header. The protocol-type argument is a 16-bit hexadecimal number that represents a protocol type in Ethernet_II and Ethernet_SNAP frames. The protocol-type-mask argument is a 16-bit hexadecimal number that represents a protocol type mask.
source-mac sour-addr source-mask: Matches a source MAC address range. The sour-addr argument represents a source MAC address, and the sour-mask argument represents a mask in H-H-H format.
time-range time-range-name: Specifies a time range for the rule. The time-range-name argument is a case insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule; however, the rule using the time range can take effect only after you configure the timer range.
Use the rule command to create or edit an Ethernet frame header ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an Ethernet frame header ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specific attributes.
By default, an Ethernet frame header ACL does not contain any rule.
Within an ACL, the permit or deny statement of each rule must be unique. If the ACL rule you are creating or editing has the same deny or permit statement as another rule in the ACL, your creation or editing attempt will fail.
To view rules in an ACL and their rule IDs, use the display acl all command.
Related commands: acl, display acl and step.
The lsap keyword is not supported when the Ethernet frame header ACL is for QoS traffic classification.
# Create a rule in ACL 4000 to deny packets with the 802.1p priority of 3.
[Sysname] acl number 4000
[Sysname-acl-ethernetframe-4000] rule deny cos 3
rule (IPv4 advanced ACL view)
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | destination { dest-addr dest-wildcard | any } | destination-port operator port1 [ port2 ] | dscp dscp | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | precedence precedence | source { sour-addr sour-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-range-name | tos tos ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | destination | destination-port | dscp | fragment | icmp-type | precedence | source | source-port | time-range | tos ] *
View
Default level
2: System level
protocol: Protocol carried by IPv4. It can be a number in the range 0 to 255, or in words, gre (47), icmp (1), igmp (2), ip, ipinip (4), ospf (89), tcp (6), or udp (17). Table 6 describes the parameters that you can specify regardless of the value that the protocol argument takes.
Table 6 Match criteria and other rule information for IPv4 advanced ACL rules
Function
Specifies a source address
The sour-addr sour-wildcard arguments represent a source IP address and wildcard mask in dotted decimal notation. An all-zero wildcard specifies a host address.
The any keyword specifies any source IP address.
Specifies a destination address
The dest-addr dest-wildcard arguments represent a destination IP address and wildcard mask in dotted decimal notation. An all-zero wildcard specifies a host address.
The any keyword represents any destination IP address.
Specifies an IP precedence value
The precedence argument can be a number in the range 0 to 7, or in words, routine (0), priority (1), immediate (2), flash (3), flash-override (4), critical (5), internet (6), or network (7).
tos tos
Specifies a ToS preference
The tos argument can be a number in the range 0 to 15, or in words, max-reliability (2), max-throughput (4), min-delay (8), min-monetary-cost (1), or normal (0).
dscp dscp
Specifies a DSCP priority
The dscp argument can be a number in the range 0 to 63, or in words, af11 (10), af12 (12), af13 (14), af21 (18), af22 (20), af23 (22), af31 (26), af32 (28), af33 (30), af41 (34), af42 (36), af43 (38), cs1 (8), cs2 (16), cs3 (24), cs4 (32), cs5 (40), cs6 (48), cs7 (56), default (0), or ef (46).
fragment
Applies the rule to only non-first fragments
Without this keyword, the rule applies to all fragments and non-fragments.
The time-range-name argument takes a case insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule; however, the rule using the time range can take effect only after you configure the timer range.
If you provide the precedence or tos keyword in addition to the dscp keyword, only the dscp keyword takes effect.
If the protocol argument takes tcp (6) or udp (7), you can set the parameters shown in Table 7.
Table 7 TCP/UDP-specific parameters for IPv4 advanced ACL rules
Function
Specifies one or more UDP or TCP source ports
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), or range (inclusive range).
The port1 and port2 arguments are TCP or UDP port numbers in the range 0 to 65535. port2 is needed only when the operator argument is range.
TCP port numbers can be represented in these words: chargen (19), bgp (179), cmd (514), daytime (13), discard (9), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), and www (80).
UDP port numbers can be represented in these words: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), and xdmcp (177).
Specifies one or more UDP or TCP destination ports
Specifies one or more TCP flags including ACK, FIN, PSH, RST, SYN, and URG
Parameters specific to TCP.
The value for each argument can be 0 (flag bit not set) or 1 (flag bit set).
The TCP flags in a rule are ANDed.
established
Specifies the flags for indicating the established status of a TCP connection
Parameter specific to TCP.
The rule matches TCP connection packets with the ACK or RST flag bit set.
If the protocol argument takes icmp (1), you can set the parameters shown in Table 8.
Table 8 ICMP-specific parameters for IPv4 advanced ACL rules
Function
Specifies the ICMP message type and code
The icmp-type argument ranges from 0 to 255.
The icmp-code argument ranges from 0 to 255.
The icmp-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 9.
Table 9 ICMP message names supported in IPv4 advanced ACL rules
ICMP message name
ICMP message type
ICMP message code
echo
8
0
echo-reply
0
0
fragmentneed-DFset
3
4
host-redirect
5
1
host-tos-redirect
5
3
host-unreachable
3
1
information-reply
16
0
information-request
15
0
net-redirect
5
0
net-tos-redirect
5
2
net-unreachable
3
0
parameter-problem
12
0
port-unreachable
3
3
protocol-unreachable
3
2
reassembly-timeout
11
1
source-quench
4
0
source-route-failed
3
5
timestamp-reply
14
0
timestamp-request
13
0
ttl-exceeded
11
0
Use the rule command to create or edit an IPv4 advanced ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv4 advanced ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specific attributes.
By default, an IPv4 advanced ACL does not contain any rule.
Related commands: acl, display acl, step, and time-range.
# Create an IPv4 advanced ACL rule to permit TCP packets with the destination port 80 from 129.9.0.0/16 to 202.38.160.0/24, and enable logging matching packets.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
rule (IPv4 basic ACL view)
rule [ rule-id ] { deny | permit } [ fragment | source { sour-addr sour-wildcard | any } | time-range time-range-name ] *
undo rule rule-id [ fragment | source | time-range ] *
View
IPv4 basic ACL view
Default level
2: System level
fragment: Applies the rule only to non-first fragments. A rule without this keyword applies to both fragments and non-fragments.
source { sour-addr sour-wildcard | any }: Matches a source address. The sour-addr sour-wildcard arguments represent a source IP address and wildcard mask in dotted decimal notation. A wildcard mask of zeros specifies a host address. The any keyword represents any source IP address.
Use the rule command to create or edit an IPv4 basic ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv4 basic ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specific attributes.
By default, an IPv4 basic ACL does not contain any rule.
# Create a rule in IPv4 basic ACL 2000 to deny packets sourced from 1.1.1.1/32.
[Sysname-acl-basic-2000] rule deny source 1.1.1.1 0
rule (IPv6 advanced ACL view)
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | destination { dest dest-prefix | dest/dest-prefix | any } | destination-port operator port1 [ port2 ] | dscp dscp | flow-label flow-label-value | fragment | icmpv6-type { icmpv6-type icmpv6-code | icmpv6-message } | source { source source-prefix | source/source-prefix | any } | source-port operator port1 [ port2 ] | time-range time-range-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } |  destination | destination-port | dscp | flow-label | fragment | icmpv6-type | source | source-port | time-range ] *
View
Default level
2: System level
protocol: Matches protocol carried over IPv6. It can be a number in the range 0 to 255, or in words, gre (47), icmpv6 (58), ipv6, ipv6-ah (51), ipv6-esp (50), ospf (89), tcp (6), or udp (17). Table 10 describes the parameters that you can specify regardless of the value that the protocol argument takes.
Table 10 Match criteria and other rule information for IPv6 advanced ACL rules
Function
Specifies a source IPv6 address
The source and source-prefix arguments represent an IPv6 source address, and prefix length that ranges from 1 to 128.
The any keyword represents any IPv6 source address.
Specifies a destination IPv6 address
The dest and dest-prefix arguments represent a destination IPv6 address, and prefix length that ranges from 1 to 128.
The any keyword specifies any IPv6 destination address.
dscp dscp
Specifies a DSCP preference
Specifies a flow label value in an IPv6 packet header
The flow-label-value argument is in the range 0 to 1048575.
logging
Logs matching packets
This function requires that the module (for example, a firewall) that uses the ACL supports logging.
routing [ type routing-type ]
Specifies the type of routing header
The routing-type argument takes a value in the range of 0 to 255.
If no routing type header is specified, the rule applies to the IPv6 packets that have any type of routing header.
fragment
If the protocol argument takes tcp (6) or udp (17), you can set the parameters shown in Table 11.
Table 11 TCP/UDP-specific parameters for IPv6 advanced ACL rules
Function
Specifies one or more TCP flags, including ACK, FIN, PSH, RST, SYN, and URG
established
If the protocol argument takes icmpv6 (58), you can set the parameters shown in Table 12.
Table 12 ICMPv6-specific parameters for IPv6 advanced ACL rules
Function
Specifies the ICMPv6 message type and code
The icmpv6-type argument ranges from 0 to 255.
The icmpv6-code argument ranges from 0 to 255.
The icmpv6-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 13.
Table 13 ICMPv6 message names supported in IPv6 advanced ACL rules
ICMPv6 message name
ICMPv6 message type
ICMPv6 message code
echo-reply
129
0
echo-request
128
0
err-Header-field
4
0
frag-time-exceeded
3
1
hop-limit-exceeded
3
0
host-admin-prohib
1
1
host-unreachable
1
3
neighbor-advertisement
136
0
neighbor-solicitation
135
0
network-unreachable
1
0
packet-too-big
2
0
port-unreachable
1
4
redirect
137
0
router-advertisement
134
0
router-solicitation
133
0
unknown-ipv6-opt
4
2
unknown-next-hdr
4
1
Use the rule command to create or edit an IPv6 advanced ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv6 advanced ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specific attributes.
By default, an IPv6 advanced ACL does not contain any rule.
To view rules in an ACL and their rule IDs, use the display acl ipv6 all command.
Related commands: acl ipv6, display ipv6 acl, step, and time-range.
The flow-label and fragment keywords are not supported when the ACL is for QoS traffic classification.
# Create an IPv6 ACL rule to permit TCP packets with the destination port 80 from 2030:5060::/64 to FE80:5060::/96.
[Sysname-acl6-adv-3000] rule permit tcp source 2030:5060::/64 destination fe80:5060::/96 destination-port eq 80
rule (IPv6 basic ACL view)
rule [ rule-id ] { deny | permit } [ fragment | source { ipv6-address prefix-length | ipv6-address/prefix-length | any } | time-range time-range-name ] *
View
IPv6 basic ACL view
Default level
2: System level
source { ipv6-address prefix-length | ipv6-address/prefix-length | any }: Matches a source IP address. The ipv6-address and prefix-length arguments represent a source IPv6 address and address prefix length in the range 1 to 128. The any keyword represents any IPv6 source address.
time-range time-range-name: Specifies a time range for the rule. The time-range-name argument takes a case insensitive string of 1 to 32 characters. It must start with an English letter.
Use the rule command to create or edit an IPv6 basic ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv6 basic ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specific attributes.
By default, an IPv6 basic ACL does not contain any rule.
Related commands: acl ipv6, display ipv6 acl, and step.
# Create an IPv6 basic ACL rule to deny packets from source IP segment 1001::/16.
[Sysname-acl6-basic-2000] rule deny source 1001:: 16
rule comment
rule rule-id comment text
undo rule rule-id comment
View
Default level
2: System level
rule-id: Specifies the ID of an existing ACL rule. The ID ranges from 0 to 65534.
text: Adds a comment about the ACL rule, a case sensitive string of 1 to 127 characters.
Use the rule comment command to add a comment about an existing ACL rule or edit its comment to make the rule easy to understand.
Use the undo rule comment command to delete the ACL rule comment.
By default, an IPv4 ACL rule has no rule comment.
# Create a rule in IPv4 basic ACL 2000 and add a comment about the rule.
[Sysname-acl-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-basic-2000] rule 0 comment This rule is used on Ethernet 1/1.
# Create a rule in IPv6 basic ACL 2000 and add a comment about the rule.
[Sysname-acl6-basic-2000] rule 0 permit source 1001::1 128
[Sysname-acl6-basic-2000] rule 0 comment This rule is used on Ethernet 1/1.
step
step step-value
undo step
View
Default level
2: System level
step-value: ACL rule numbering step, which ranges from 1 to 20.
Use the step command to set a rule numbering step for an ACL. The rule numbering step sets the increment by which the system numbers rules automatically. For example, the default ACL rule numbering step is 5. If you do not assign IDs to rules you are creating, they are numbered 0, 5, 10, 15, and so on. The wider the numbering step, the more rules you can insert between two rules. Whenever the step changes, the rules are renumbered, starting from 0. For example, if there are five rules numbered 5, 10, 13, 15, and 20, changing the step from 5 to 2 causes the rules to be renumbered 0, 2, 4, 6 and 8.
Use the undo step command to restore the default.
The default rule numbering step is 5. After you restore the default numbering step by the undo step command, the rules are renumbered in steps of 5.
# Set the rule numbering step to 2 for IPv4 basic ACL 2000.
[Sysname-acl-basic-2000] step 2
# Set the rule numbering step to 2 for IPv6 basic ACL 2000.
[Sysname-acl6-basic-2000] step 2
time-range
time-range time-range-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
undo time-range time-range-name [ start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 ]
View
Default level
2: System level
time-range-name: Specifies a time range name. The name is a case insensitive string of 1 to 32 characters. It must start with an English letter and to avoid confusion, cannot be all.
start-time to end-time: Specifies a periodic statement. Both start-time and end-time are in hh:mm format (24-hour clock), and each value ranges from 00:00 to 23:59. The end time must be greater than the start time.
days: Specifies the day or days of the week (in words or digits) on which the periodic statement is valid. If you specify multiple values, separate each value with a space, and make sure that they do not overlap. These values can take one of the following forms:
·           A digit in the range 0 to 6, respectively for Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
·           A day of a week in words, sun, mon, tue, wed, thu, fri, and sat.
·           working-day for Monday through Friday.
·           off-day for Saturday and Sunday.
·           daily for the whole week.
from time1 date1: Specifies the start time and date of an absolute statement. The time1 argument specifies the time of the day in hh:mm format (24-hour clock). Its value ranges from 00:00 to 23:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format, where MM is the month of the year in the range 1 to 12, DD is the day of the month with the range depending on MM, and YYYY is the year in the calendar in the range 1970 to 2100. If not specified, the start time is 01/01/1970 00:00 AM, the earliest time available in the system.
to time2 date2: Specifies the end time and date of the absolute time statement. The time2 argument has the same format as the time1 argument, but its value ranges from 00:00 to 24:00. The date2 argument has the same format and value range as the date1 argument. The end time must be greater than the start time. If not specified, the end time is 12/31/2100 24:00 PM, the maximum time available in the system.
Use the time-range command to configure a time range.
Use the undo time-range command to delete a time range or a statement in the time range.
By default, no time range exists.
You can create multiple statements in a time range. Each time statement can take one of the following forms:
·           Periodic statement in the start-time to end-time days format. A periodic statement recurs periodically on a day or days of the week.
·           Absolute statement in the from time1 date1 to time2 date2 format. An absolute statement does not recur.
·           Compound statement in the start-time to end-time days from time1 date1 to time2 date2 format. A compound statement recurs on a day or days of the week only within the specified period. For example, to create a time range that is active from 08:00 to 12:00 on Monday between January 1, 2010 00:00 and December 31, 2010 23:59, use the time-range test 08:00 to 12:00 mon from 00:00 01/01/2010 to 23:59 12/31/2010 command.
The active period of a time range is calculated as follows:
1.      Combining all periodic statements
2.      Combining all absolute statements
3.      Taking the intersection of the two statement sets as the active period of the time range
You can create a maximum of 256 time ranges, each with a maximum of 32 periodic statements and 12 absolute statements.
Related commands: display time-range.
# Create a periodic time range t1, setting it to be active between 8:00 to 18:00 during working days.
[Sysname] time-range t1 8:0 to 18:0 working-day
# Create an absolute time range t2, setting it to be active in the whole year of 2010.
[Sysname] time-range t2 from 0:0 1/1/2010 to 23:59 12/31/2010
# Create a compound time range t3, setting it to be active from 08:00 to 12:00 on Saturdays and Sundays of the year 2010.
[Sysname] time-range t3 8:0 to 12:0 off-day from 0:0 1/1/2010 to 23:59 12/31/2010
# Create a compound time range t4, setting it to be active from 10:00 to 12:00 on Mondays and from 14:00 to 16:00 on Wednesdays in the period of January through June of the year 2010.
[Sysname] time-range t4 10:0 to 12:0 1 from 0:0 1/1/2010 to 23:59 1/31/2010
[Sysname] time-range t4 14:0 to 16:0 3 from 0:0 6/1/2010 to 23:59 6/30/2010
