05-ACL and QoS Command Reference
HomeSupportWirelessWX3000E Series Wireless SwitchesReference GuidesCommand ReferencesH3C WX3000E Series Wireless Switches Switching Engine Command References(R3507P26)-6W10205-ACL and QoS Command Reference
00-Preface
00-Preface 73.70 KB
Preface
The H3C WX3000E documentation set includes 8 command references, which describe the The H3C WX3000E documentation set includes 8 command references, which describe the commands and command syntax options available for the H3C WX3000E Series Wireless Switches Switching Engine.
The ACL and QoS Command Reference describes the ACL and QoS configuration commands.
This preface includes:
·           Audience
·           Conventions
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the WX3000E Series Wireless Switches Switching Engine
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
We appreciate your comments.
